September 13, 201411 yr Trying to copy from one server (reiserfs) to new server (xfs). I'm following instructions for starting rsync as a daemon from user WeeboTech. The rsync is working, but my source files are root/root for uid/gid, but the destination is getting nobody/users and seems to be failing, presumably trying to chgrp to root. That is, I'm getting rsync failed: Operation not permitted (1) My /etc/rsyncd.conf file is (from the destination machine): uid root gid root use chroot= no max connections = 4 pid file= /var/run/rsyncd.pid timeout 600 [mnt] path = /mnt comment = /mnt files read only = FALSE I'm getting 50-60 MB/sec copies, so I'd like to get this working, but I'm not sure how to either 1) change whatever permissions to allow chgrp to work 2) use the correct uid/gid to start with 3) something else I haven't thought of? Here's my rsync command from the source machine: rsync -av --stats --progress /mnt/user/Media/BluRay/5* rsync://<dest ip>/mnt/disk1/BluRay/ thanks for any help that can be provided. [edit] This is with unRAID 6 beta 9. If someone can move it, that would be great. Sorry. [/edit]
September 13, 201411 yr Try this: rsync -avH --timeout=120 --progress --delete /mnt/user/Media/BluRay/5*/ <dest ip>::mnt/disk1/BluRay/ Did you edit that inetd file on the destination?
