September 15, 201411 yr Hi all. Recently a thread about broken dockers included a syslong from my unRaid system. JonP pointed out some issues, the main issue was that a certain drive had a possibly dodgy cable. Disk11 I believe, I have replaced the cable, I am going to attach my logs if someone can check please? syslog-old.txt
September 15, 201411 yr sdb has a bad or loose SATA cable or a bad SATA port. Sep 8 13:36:11 DAMOtNSTER kernel: ata2: SError: { UnrecovData 10B8B BadCRC } Trace ata2 in the log and you can determine that the disk is sdb by following the drives serial number.
