March 25, 200917 yr Well FINALLY after ages and ages of reading this forum I am ordering my first Unraid server parts (thank you tax return)... Most is LimeTech official/supported parts but I just wanted to make sure the PSU will be ok... Starting system will be 3 new 1.5TB drives, when build is done and files from old NAS are copied over I will add the 5 750GB drives from the NAS... This system is being planned to support the UnRaid max config of 14 data, 1 cache drive... As you can see below it looks like Adaptec may be discontinuing the 1430SA, well at least Newegg is... Hope Tom can get a 8 port card supported soon... PSU: CORSAIR CMPSU-750TX 750W http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006 Other Parts for Unraid: Case: Norco 4020 MotherBoard: SUPERMICRO MBD-C2SEE-O http://www.newegg.com/Product/Product.aspx?Item=N82E16813182162 RAM: G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231144 RAID: Adaptec 2240900-R 1430SA PCI Express X4 4-Port SATA 3GBS Low-profile Host RAID Controller http://www.amazon.com/Adaptec-2240900-R-Express-Low-profile-Controller/dp/B000K8ESLE/ref=pd_bbs_sr_1?ie=UTF8&s=electronics&qid=1237986530&sr=8-1 Not sure why newegg has this is a discontinued item... but I still can get the adaptec from Amazon CPU: Will be using 1 year old C2D from my HTPC, HTPC will be getting new 3Ghz C2D (for software blu-ray decoding) HDD (3): Seagate 1.5 TB drives (still best bang for buck, issues aside, will add 2TB when needed and when they come down in price)
