Drive will not spin down - running hot (~41 degrees) [SOLVED]
I began running UnRaid 5.05 earlier this year and have been nothing but delighted but I recently upgrade from 5.05 to 5.06 with a small hardware refresh in between (new power supply, replaced RMA's MoBo). I now have a single drive that will not remain spun down and is running hot. I am a bit of an amateur and lost as to my next steps. I am hoping this wonderful forum can help me out?
Thank you!
EDIT: Apologies to all, I'm an idiot. I installed BTSync and the share was mounted on the spinning disk. I moved it to my cache SSD and all is well.
Billy_McSkintos
Smart.txt:
smartctl 6.2 2013-07-26 r3841 [i686-linux-3.9.11p-unRAID] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Hitachi Deskstar 7K3000
Device Model:     Hitachi HDS723030ALA640
Serial Number:    MK0333YHGBK2MC
LU WWN Device Id: 5 000cca 225c54037
Firmware Version: MKAOA5C0
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    7200 rpm
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 2.6, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Nov  6 18:05:09 2014 PST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x84)	Offline data collection activity
				was suspended by an interrupting command from host.
				Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)	The previous self-test routine completed
				without error or no self-test has ever
				been run.
Total time to complete Offline
data collection: 		(30457) seconds.
capabilities: 			 (0x5b) SMART execute Offline immediate.
				Auto Offline data collection on/off support.
				Suspend Offline collection upon new
				command.
				Offline surface scan supported.
				Self-test supported.
				No Conveyance Self-test supported.
				Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
				power-saving mode.
				Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
				General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   1) minutes.
Extended self-test routine
recommended polling time: 	 ( 508) minutes.
SCT capabilities: 	       (0x003d)	SCT Status supported.
				SCT Error Recovery Control supported.
				SCT Feature Control supported.
				SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   133   133   054    Pre-fail  Offline      -       91
  3 Spin_Up_Time            0x0007   137   137   024    Pre-fail  Always       -       620 (Average 506)
  4 Start_Stop_Count        0x0012   099   099   000    Old_age   Always       -       4859
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   138   138   020    Pre-fail  Offline      -       25
  9 Power_On_Hours          0x0012   097   097   000    Old_age   Always       -       27616
10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       146
192 Power-Off_Retract_Count 0x0032   096   096   000    Old_age   Always       -       4863
193 Load_Cycle_Count        0x0012   096   096   000    Old_age   Always       -       4863
194 Temperature_Celsius     0x0002   146   146   000    Old_age   Always       -       41 (Min/Max 20/79)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%     27607         -
SMART Selective self-test log data structure revision number 1
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
syslog.zip
smart.txt
