November 30, 201411 yr Hi folks, new guy here, please excuse the dumb questions. First off, so far I'm very happy with unRAID (5.x) as a storage platform/media server but I'd also like to migrate the other services from my old server over to it. I've set up a Transmission plugin (thanks Phaze!) and it seems to work pretty well, *BUT* the transfer speed limits do not seem to work?? Here is the settings file I'm currently using for transmission { "alt-speed-down": 50, "alt-speed-enabled": false, "alt-speed-time-begin": 540, "alt-speed-time-day": 127, "alt-speed-time-enabled": false, "alt-speed-time-end": 1020, "alt-speed-up": 50, "bind-address-ipv4": "0.0.0.0", "bind-address-ipv6": "::", "blocklist-enabled": false, "blocklist-url": "http://www.example.com/blocklist", "cache-size-mb": 4, "dht-enabled": true, "download-dir": "//downloads", "download-queue-enabled": true, "download-queue-size": 5, "encryption": 1, "idle-seeding-limit": 30, "idle-seeding-limit-enabled": false, "incomplete-dir": "/mnt/cache/apps/transmission/incomplete", "incomplete-dir-enabled": true, "lpd-enabled": false, "message-level": 2, "peer-congestion-algorithm": "", "peer-id-ttl-hours": 6, "peer-limit-global": 200, "peer-limit-per-torrent": 50, "peer-port": 51413, "peer-port-random-high": 65535, "peer-port-random-low": 49152, "peer-port-random-on-start": false, "peer-socket-tos": "default", "pex-enabled": true, "pidfile": "/var/run/transmission/transmission.pid", "port-forwarding-enabled": true, "preallocation": 1, "prefetch-enabled": 1, "queue-stalled-enabled": true, "queue-stalled-minutes": 30, "ratio-limit": 2, "ratio-limit-enabled": false, "rename-partial-files": true, "rpc-authentication-required": false, "rpc-bind-address": "0.0.0.0", "rpc-enabled": true, "rpc-password": "{d00207a2fa53bcf862f8b37d7e989147cc7ce28c/2D76L7k", "rpc-port": 9091, "rpc-url": "/transmission/", "rpc-username": "", "rpc-whitelist": "127.0.0.1", "rpc-whitelist-enabled": false, "scrape-paused-torrents-enabled": true, "script-torrent-done-enabled": false, "script-torrent-done-filename": "", "seed-queue-enabled": false, "seed-queue-size": 10, "speed-limit-down": 70, "speed-limit-down-enabled": true, "speed-limit-up": 20, "speed-limit-up-enabled": true, "start-added-torrents": true, "trash-original-torrent-files": false, "umask": 0, "upload-slots-per-torrent": 14, "utp-enabled": true }
