***GUIDE*** Passthrough Entire PCI USB Controller
Win10 x64, I am just copying over a win 7 iso to try but would rather stick with 10 as I upgraded my install key!
Hmm yeah either should work just fine... So it boots up just fine without error but doesn't find the USB controller, correct? Does the device manager show an unknown device? Maybe check your mobo website for drivers? Other than that I don't have a clue [emoji58]
  • Replies 509
  • Views 455.8k
  • Baltostar
    Baltostar
    I automated steps 1-9 of this guide.   The output shows USB bus #, PCI Address, and IOMMU group #   Bus 1 PCI 0000:00:1a.0 IOMMU 20     Intel Corp.     Linux Foundation 2.0 root hub Bus 2
  • I believe users with this specific card (Startech PEXUSB3S44V) have no issues passing them to the machine, but have issues once passed to the machine inside the VM. Mine throws a Code 10 error on the
  • Not if you use the xen-pciback.hide= method. You use the PCI number instead of id. So yours will look like below for the last two.  xen-pciback.hide=(0d:00.3)(43:00.3)
nothing extra appears in device manager needing drivers. I am stumped really, am I missing something with the XML passthrough?
what is the difference between bus=pcie.0 and bus=root.1 ?? why would the usb be root and not a pcie number? or am I just making things up now as I have tried everything else??
I think you need to add this first
    <qemu:arg value='-device'/>
    <qemu:arg value='ioh3420,bus=pcie.0,addr=1c.0,multifunction=on,port=1,chassis=1,id=root.1'/>
    <qemu:arg value='vfio-pci,host=00:14.0,bus=root.1,addr=00.0'/>
Hi again. No that didn't work. I didn't add this before because I thought it was for a card. Anyways it throws an error for the following:
<qemu:arg value='ioh3420,bus=pcie.0,addr=1c.0,multifunction=on,port=1,chassis=1,id=root.1'/>[/b]
It it possibly the address as I highlighted above?
Thanks
Depends on what the error message says? Can you post a screen shot?
See the scree capture:
I would try making a fresh XML of Windows with unraids VM creator and then only modify the lines necessary for USB passthrough. You will have to view your VM though VNC for the moment but try getting just that working first.
Thanks
Please post your entire XML as well.
Its on page 6 at the bottom.
Thanks
Thanks
I am wanting to see the XML with the above code entered so I can see if I can spot the issue. Your post on line 6 doesn't have the added code.
ok done that, fresh build.
The only thing now in my xml is + using vnc
<qemu:commandline>
    <qemu:arg value='vfio-pci,host=09:00.0,bus=root.1,addr=00.1'/>
  </qemu:commandline>
Still getting the same, no usb devices work :-(
Thanks
Sorry, I was hoping the one on page 6 was current enough because I was installing Ubuntu.
<domain type='kvm' xmlns:qemu='http://libvirt.org/schemas/domain/qemu/1.0'>
  <name>Test 8</name>
  <uuid>738883d4-0137-3e4e-7bc9-8da467c306eb</uuid>
  <description>test 8</description>
  <metadata>
    <vmtemplate name="Custom" icon="windows.png" os="windows"/>
  </metadata>
  <memory unit='KiB'>10485760</memory>
  <currentMemory unit='KiB'>10485760</currentMemory>
  <memoryBacking>
    <nosharepages/>
    <locked/>
  </memoryBacking>
  <vcpu placement='static'>6</vcpu>
  <cputune>
    <vcpupin vcpu='0' cpuset='2'/>
    <vcpupin vcpu='1' cpuset='3'/>
    <vcpupin vcpu='2' cpuset='4'/>
    <vcpupin vcpu='3' cpuset='5'/>
    <vcpupin vcpu='4' cpuset='6'/>
    <vcpupin vcpu='5' cpuset='7'/>
  </cputune>
  <os>
    <type arch='x86_64' machine='pc-i440fx-2.3'>hvm</type>
  </os>
  <features>
    <acpi/>
    <apic/>
  </features>
  <cpu mode='host-passthrough'>
    <topology sockets='1' cores='6' threads='1'/>
  </cpu>
  <clock offset='localtime'>
    <timer name='rtc' tickpolicy='catchup'/>
    <timer name='pit' tickpolicy='delay'/>
  </clock>
  <on_crash>restart</on_crash>
  <devices>
    <emulator>/usr/bin/qemu-system-x86_64</emulator>
      <source file='/mnt/cache/appdata/ISO share/Test 3/Secondary.img'/>
      <boot order='1'/>
    </disk>
      <source file='/mnt/cache/appdata/ISO share/Windows 10 Pro/Win10.PRO.img'/>
      <target dev='hda' bus='ide'/>
      <readonly/>
      <boot order='2'/>
    </disk>
      <source file='/mnt/cache/appdata/ISO share/virtio-win-0.1.102.iso'/>
      <target dev='hdb' bus='ide'/>
      <readonly/>
    </disk>
    <controller type='usb' index='0'>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x01' function='0x2'/>
    </controller>
    </controller>
    </controller>
    <interface type='bridge'>
      <mac address='52:54:00:1a:34:b4'/>
      <source bridge='br0'/>
      <model type='virtio'/>
    </interface>
    <serial type='pty'>
      <target port='0'/>
    </serial>
    <console type='pty'>
    </console>
    <channel type='unix'>
      <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/Test 3.org.qemu.guest_agent.0'/>
    </channel>
    <input type='tablet' bus='usb'/>
    <graphics type='vnc' port='-1' autoport='yes' websocket='-1' listen='0.0.0.0' keymap='en-us'>
    </graphics>
    <video>
      <model type='vmvga' vram='16384' heads='1'/>
    </video>
      <driver name='vfio'/>
      <source>
        <address domain='0x0000' bus='0x00' slot='0x1b' function='0x0'/>
      </source>
    </hostdev>
    <memballoon model='virtio'>
      <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x0'/>
    </memballoon>
  </devices>
  <qemu:commandline>
  </qemu:commandline>
</domain>
For me it's much easier to use the hostdev tag instead of the qemu:arg. It's just too much trouble with it when you don't know what you are doing.
So for passing through a PCI(e) device with the hostdev tag this is the starting code:
      <source>
        <address domain='0x0000' bus='0x00' slot='0x00' function='0x0'/>
      </source>
    </hostdev>
You then have to modify some parts of it to get it to work. The good thing is that you do not have to care about which bus and address it's supposed to have in the VM. You only need to find out the host PCI address.
The part you change is bus, slot and function. In your case it's 00:14.0.
Let's brake it down.
00 is the bus. You simply exchange the two numbers after the 0x.
14 is the slot. Same method as above.
0 is the function. Her it's also the same method as above.
So in your case the full device tag would be like this:
      <source>
        <address domain='0x0000' bus='0x00' slot='0x14' function='0x0'/>
      </source>
    </hostdev>
After you start the VM you will see that there are some lines added to the tag, but those you don't have to care about. They get created automatically. If you copy a host device tag to pass through a new device, be sure to remove the two lines created after the
</source>
tag, as they are specific to that VM.
      <alias name='hostdev2'/>
      <source>
      </source>
    </hostdev>
      <source>
      </source>
    </hostdev>
</source>
Thanks saarg I'll set up another VM and give it a go while pursuing closure on Test VM 8.
saarg,
That work like a charm. I have to let windows do a repair and win it was done every thing was there.
Thanks for your support too archedraft
Best Regards
for trying that passthrough method, what should i do with my gfx card passthrough?
If you have a working VM with gfx pass through, you add the usb controller the same way as I described a few posts above. No need to remove any qemu:arg.
ahh cool that's what I tried and annoyingly no usb devices found on the VM when I boot it up. I think I am destined to fail at this :-(
edit!
I can confirm that this works on my usb2 controller but not on the USB 3 one!
If I run unRAID from the USB 3 controller the pen drive gets so hot that it crashes/corrupts the system!!
Any ideas/ ways round this? I have 3 sets of USB ports, one set on the front of my case (usb2) , one set on the back that's USB3, and another set of USB2 on the back.
I really want the unRaid on the front so that I don't have dangling cables everywhere
scratch previous comment, it does work with my usb 3 controller! slightly excited now!! Just need to work out why the device cant start now... probably a driver update/issue will post when I have mucked about with the VM some more... I love you guys thanks for the help :-)
I added this to the end of the guide, I know it is else where but I think it should be handy anyways. Thanks.
Good choice :)
I just read what you added and it says
Forget passing through an entire controller and just use Hostdev
That's not true :) You are still passing through an entire controller, but only the way to do it is different.
Can someone explain what the difference is between qemu passthrough and hostdev please?  I'm not entirely clear on the use cases for each...
I just edited my post :)
It's the same. The hostdev way is used in the XML and qemu:arg is not a part of the XML. Did that confuse you more maybe?  ::)
No, I've wondered why there are two separate ways to do things, but never given it too much thought.  So basically they're like two routes to the same destination...
No advantages or disadvantages either way?  No reason to choose one over the other?
Good choice :)
Oops good catch, I was editing the whole first page at a million miles a minute and sort of word vomitted that.
So then I suppose even with hostdev you will still have to go through the entire first process of finding out which controller you want?
