Help why Unraid Web went missing after starting
I started unraid, with plugins loaded.  I saw unraid web.  All of a sudden, it went missing.  But other plugins still working properly.  Please see attached syslog
syslog-2015-01-13.txt
Don't really understand what you mean by "unraid web". Do you mean the webGUI that shows your drives?
Your syslog shows that you have put dynamix.plugin.control in /boot/plugins. This causes it to try to install before dynamix.webGui and so dynamix.plugin.control install fails.
You must put dynamix.plugin.control in /boot/config/plugins like it says here. This will allow dynamix.webGui in /boot/plugins to install first, then dynamix.plugin.control will install later from /boot/config/plugins.
See here for more about how things get installed at boot time.
Thank you for the explanation trurl.
Yes, upon power up, I saw unraid webgui after a short while, after Plex, sabnzbd, couchpotato and sickbeard got loaded, webgui functioned well.  After a while, it went missing.
Yes, I have dynamix.  Since I was having trouble getting unraid up with plugins installed, I removed the plugins first, and put them back at /boot/config 1 by 1, until I'm sure it's not the plugin that's causing the problem.
Noted on the dynamix.plugin.control.  I'll move it to /boot/config/plugins folder.
But could that be the reason why webgui disappeared after every plugin loaded?
Still unclear what is meant by "missing" or "disappeared". Do you meant that your web browser can't access it at all, or it is accessing it but it isn't working correctly in some way?
hello trurl,
I meant webgui is no longer accessible.
I'll consider this solved after following your instructions to move dynamix plugin to right directory.
