January 26, 201511 yr I have installed the VM Manager Plugin on Unraid 6.0 Beta 12 I have successfully created a number of windows 8.1 and 10 preview Virtual machines. From VM Manager I can Stop/Start the VMs and edit the XMLs. However, when I do a full reboot of the unraid server and open up VM Manager after starting libvirt the VMS are not in the list. The VM's hard disks are located outside of the array on a drive shared by the SNAP plugin. This is the same drive that my Dockers are running from. Looking at the folder for the VM's I can see the Harddrive file as well as a single text file containing the autostart setting. Where are the XML files located? I am assuming VM Manager needs to see the XML files to list the VM's. Any help will be appreciated. Thanks for the help - I installed the virtMan plugin and after reboot the VM's were still listed.
January 26, 201511 yr You also need to install the virtMan plugin (it's on the vmMan page) for the xml's to survive reboot and libvirt to auto start. The plan is to move them into one plugin and save the xml in the same folder as the image but I haven't done that yet.
