[SOLVED] Problem with webgui starting up with 6.0rc2
Hey all,
I installed unraid on to a new flash drive. Unraid boots from the flash, but the webgui doesn't seem to want to load during startup. In order for me to get it to load. I have to run the command (nohup /usr/local/sbin/emhttp &) manually in the terminal after the server is fully up and running.
I checked the go script, and this seems to be the only thing in it.
#!/bin/bash
# Start the Management Utility
Doing a fresh install with rc3 seemed to fix the issue.
