June 23, 201511 yr I've got UR 6.0 RC2 that I'm trying to upgrade to final release 6.0.0. In the web gui I navigate to Plugins tab and click check for updates (correct place to upgrade, right?). It runs, but does not upgrade anything. Here's a screenshot. http://my.jetscreenshot.com/12412/20150623-hvxm-83kb.jpg Thanks!
June 23, 201511 yr Do you already have an update pending on a reboot? Ive seen that cause issues with the update detection before.
June 24, 201511 yr Yeah, I tired that, but didn't make any difference. Updates are read from github (the place where the developer has stored his PLG file). Do you have a working internet connection (including DNS) ?
June 24, 201511 yr Yeah, I tired that, but didn't make any difference. Worst comes to worst, you can always download the zip file from LT's website, and copy bzimage and bzroot onto your flash drive
June 24, 201511 yr From the console or a telnet session type: ping google.com And see if you a response.
June 24, 201511 yr Author Yep, I have full internet. Ping anything and get a response. When I click the update button I get this... http://my.jetscreenshot.com/12412/20150624-gyx9-91kb.jpg And nothing happens. I also have a problem where I can't load the pro.key from the registration page. Had to load the pro.key manually... perhaps related? I can access my system from outside my firewall with no problems...so I know I'm talking to the internet... and I can ping gethub no problems (which is where I believe the files load from...)... http://my.jetscreenshot.com/12412/20150624-nyep-74kb.jpg Thoughts?
June 24, 201511 yr Yep, I have full internet. Ping anything and get a response. When I click the update button I get this... http://my.jetscreenshot.com/12412/20150624-gyx9-91kb.jpg And nothing happens. I also have a problem where I can't load the pro.key from the registration page. Had to load the pro.key manually... perhaps related? I can access my system from outside my firewall with no problems...so I know I'm talking to the internet... and I can ping gethub no problems (which is where I believe the files load from...)... http://my.jetscreenshot.com/12412/20150624-nyep-74kb.jpg Thoughts? I hope this doesn't come across as too painfully obvious. But have you pressed "Done" and then scrolled back down and saw if unRaid had "update available" next to it?
June 25, 201511 yr Yep, I have full internet. Ping anything and get a response. When I click the update button I get this... http://my.jetscreenshot.com/12412/20150624-gyx9-91kb.jpg And nothing happens. I also have a problem where I can't load the pro.key from the registration page. Had to load the pro.key manually... perhaps related? I can access my system from outside my firewall with no problems...so I know I'm talking to the internet... and I can ping gethub no problems (which is where I believe the files load from...)... http://my.jetscreenshot.com/12412/20150624-nyep-74kb.jpg Thoughts? Do you have any adblockers or other filtering software running for your browser, if yes temperaray stop it.
June 25, 201511 yr Author No I've tried the upgrade button from different pcs and browsers same result and message.
June 25, 201511 yr Author Yep, I have full internet. Ping anything and get a response. When I click the update button I get this... http://my.jetscreenshot.com/12412/20150624-gyx9-91kb.jpg And nothing happens. I also have a problem where I can't load the pro.key from the registration page. Had to load the pro.key manually... perhaps related? I can access my system from outside my firewall with no problems...so I know I'm talking to the internet... and I can ping gethub no problems (which is where I believe the files load from...)... http://my.jetscreenshot.com/12412/20150624-nyep-74kb.jpg Thoughts? I hope this doesn't come across as too painfully obvious. But have you pressed "Done" and then scrolled back down and saw if unRaid had "update available" next to it? Squid you win the (painfully obvious) prize. Can't believe I didn't see it but when I went back to the page the update button was there. Perhaps it just took awhile to download? Perhaps there should be a progress message of some sort... But thanks, you got it!
June 25, 201511 yr Yep, I have full internet. Ping anything and get a response. When I click the update button I get this... http://my.jetscreenshot.com/12412/20150624-gyx9-91kb.jpg And nothing happens. I also have a problem where I can't load the pro.key from the registration page. Had to load the pro.key manually... perhaps related? I can access my system from outside my firewall with no problems...so I know I'm talking to the internet... and I can ping gethub no problems (which is where I believe the files load from...)... http://my.jetscreenshot.com/12412/20150624-nyep-74kb.jpg Thoughts? I hope this doesn't come across as too painfully obvious. But have you pressed "Done" and then scrolled back down and saw if unRaid had "update available" next to it? Squid you win the (painfully obvious) prize. Can't believe I didn't see it but when I went back to the page the update button was there. Perhaps it just took awhile to download? Perhaps there should be a progress message of some sort... But thanks, you got it! Nothing is downloaded when you hit check for updates. After hitting done next to the plugin there will be an update notice if one is available. At that point it starts downloading
