July 25, 200916 yr I've tried 2 flash drives so far, and both times it says Flash GUID: -1 on the devices page instead of the GUID. From what I've read if the flash drive doesn't have a GUID, it would've shown a string of zeros. I should say that I'm unRAID on a hard drive (even though when I did boot the flash drive it still gave me -1 for the GUID). I'm figuring that since I'm symlinking /mnt/usbflashdrive/config to /boot/config that it would still pick of the GUID of the flash drive that is storing the config files. I was planning on paying for the pro version so any help would be much appreciated. - Chris SOLVED: Finally figured it out, the problem was that I didn't name the volume UNRAID when I formatted. Hopefully this helps out anyone else that comes across this issue.
