July 8, 201511 yr So I am trying to build a container for hdhomerun dvr and I am completely stumped. I must be doing something wrong. I was using the limetech plex as a template. The install.sh is not running some basic commands. The hdhomerun dvr wont run itself. The container will create and I can install it, but it does nothing. Ideas? https://registry.hub.docker.com/u/yoshiofthewire/hdhomerundvr/
July 8, 201511 yr Author I am getting on of two errors root@evie:/usr/bin# /usr/bin/hdhomerun_record_x86 start bash: /usr/bin/hdhomerun_record_x86: cannot execute binary file: Exec format error root@evie:/usr/bin# sudo /usr/bin/hdhomerun_record_x86 start /usr/bin/hdhomerun_record_x86: 1: /usr/bin/hdhomerun_record_x86: Syntax error: "(" unexpected That said, the log isn't saying anything, because file moves are not working
July 8, 201511 yr I am getting on of two errors root@evie:/usr/bin# /usr/bin/hdhomerun_record_x86 start bash: /usr/bin/hdhomerun_record_x86: cannot execute binary file: Exec format error root@evie:/usr/bin# sudo /usr/bin/hdhomerun_record_x86 start /usr/bin/hdhomerun_record_x86: 1: /usr/bin/hdhomerun_record_x86: Syntax error: "(" unexpected That said, the log isn't saying anything, because file moves are not working the exec format error is because that app is 32 bit and won't run in unraid because there is no 32 bit library support in unraid.
