July 29, 201511 yr Hey all, I'm trying to create my first docker to run OpenHab from apt repositories. I know there's another OpenHab docker out there, but it isn't setup how I would like (mainly I want /config to contain my bindings, might not make sense if you don't use OpenHab, but this question should be universal). I'm struggling with the startup. Everything installs correctly and if I exec into the docker and run the init.d, everything is fine and it works as expected. But I can't get it to startup on launch. I've tried all sorts of stuff, currently trying to exec the init from /etc/service, running ontop of Phusion. Here is my install script on Github (docker one level back). https://github.com/christianwaite/dockerapp-openhab/blob/master/install.sh If anyone can point me in the right direction I'd be very appreciative! Thank you Christian P.s. Here's the docker on the hub: https://registry.hub.docker.com/u/christianwaite/openhab/ P.p.s. If you see anything else glaringly stupid, let me know. I'm literally cobbling this together blind from various other's work to get it started.
