August 3, 201511 yr I am currently running 6.1rc2 and I believe this version is keeping my disks from spinning down on my adaptec 5805Z raid card, onboard drives spin down fine. The drives use to spin down, I have done my best to get my flash back to stock but still no spin down. What is the best way to down grade to a stable release? Here is the error I am getting. Aug 3 17:11:45 UnRaid emhttp: Spinning down all drives... Aug 3 17:11:45 UnRaid kernel: mdcmd (39): spindown 0 Aug 3 17:11:45 UnRaid emhttp: mdcmd: write: Input/output error Aug 3 17:11:45 UnRaid kernel: md: disk0: ATA_OP e0 ioctl error: -5 Aug 3 17:11:45 UnRaid kernel: mdcmd (40): spindown 1 Aug 3 17:11:47 UnRaid kernel: mdcmd (41): spindown 2 Aug 3 17:11:48 UnRaid kernel: mdcmd (42): spindown 3 Aug 3 17:11:48 UnRaid emhttp: mdcmd: write: Input/output error Aug 3 17:11:48 UnRaid kernel: md: disk3: ATA_OP e0 ioctl error: -5 Aug 3 17:11:48 UnRaid kernel: mdcmd (43): spindown 4 Aug 3 17:11:48 UnRaid emhttp: mdcmd: write: Input/output error Aug 3 17:11:48 UnRaid kernel: md: disk4: ATA_OP e0 ioctl error: -5 Aug 3 17:11:48 UnRaid kernel: mdcmd (44): spindown 5 Aug 3 17:11:48 UnRaid emhttp: mdcmd: write: Input/output error Aug 3 17:11:48 UnRaid kernel: md: disk5: ATA_OP e0 ioctl error: -5 Aug 3 17:11:48 UnRaid emhttp: shcmd (40): /usr/sbin/hdparm -y /dev/sdh &> /dev/null ug 3 17:12:12 UnRaid emhttp: Spinning up all drives... Aug 3 17:12:12 UnRaid emhttp: shcmd (41): /usr/sbin/hdparm -S0 /dev/sdh &> /dev/null Aug 3 17:12:12 UnRaid kernel: mdcmd (45): spinup 0 Aug 3 17:12:12 UnRaid kernel: mdcmd (46): spinup 1 Aug 3 17:12:12 UnRaid kernel: mdcmd (47): spinup 2 Aug 3 17:12:12 UnRaid kernel: mdcmd (48): spinup 3 Aug 3 17:12:12 UnRaid kernel: mdcmd (49): spinup 4 Aug 3 17:12:12 UnRaid kernel: mdcmd (50): spinup 5 Aug 3 17:12:12 UnRaid kernel: md: disk5: ATA_OP e3 ioctl error: -5 Aug 3 17:12:12 UnRaid kernel: md: disk3: ATA_OP e3 ioctl error: -5 Aug 3 17:12:12 UnRaid kernel: md: disk4: ATA_OP e3 ioctl error: -5 Aug 3 17:12:12 UnRaid kernel: md: disk0: ATA_OP e3 ioctl error: -5
August 5, 201511 yr What is the best way to down grade to a stable release? You downgrade the same way you used to upgrade. Go to the LimeTech Downloads page, download v6.0.1 and extract bzroot and bzimage from it to your flash drive, and reboot.
