November 8, 201510 yr Hi, I had a power failure in my apartment and the unRAID server shut down. The flash drive looks undamaged (I can see the share files) and the server starts but I can't see the HDD's (through the console) or access the web gui. Help
November 8, 201510 yr Please explain exactly what you mean, possibly with screenshots. The flash drive looks undamaged (I can see the share files)What share files? Where do you see them? I can't see the HDD's (through the console) or access the web gui. What console command are you using to try to see the HDD's? Can you ping your server? Telnet? You might try putting your flash in your PC and letting it checkdisk if you haven't already.
November 8, 201510 yr Author So, after 3 formats of the flash usb (each time copying the files, making bootable and trying to run it) the server finally came back to normal! Thanks anyway!
