November 27, 201510 yr Anyone know of a SATA power splitter for a power supply mounted at the bottom? Like this: http://www.amazon.com/gp/product/B0086OGN9E?psc=1&redirect=true&ref_=ox_sc_sfl_title_13&smid=ATVPDKIKX0DER But this is for a power supply mounted at the top. For the life of me I cant find one for power supplies at the bottom.
November 27, 201510 yr Anyone know of a SATA power splitter for a power supply mounted at the bottom? Like this: http://www.amazon.com/gp/product/B0086OGN9E?psc=1&redirect=true&ref_=ox_sc_sfl_title_13&smid=ATVPDKIKX0DER But this is for a power supply mounted at the top. For the life of me I cant find one for power supplies at the bottom. Maybe I'm missing something, but what difference does it make of where the power supply is mounted when you are splitting a cable coming off of it?
November 27, 201510 yr Author They connectors are keyed one way. So that strip mounts one direction. From bottom to top. At the top is the connector to attach to the existing cable. So I will need to run the power cable from the power supply at the bottom of my case all the way to the top and then use this splitter to run down the hard drives. Just looks messy. Its possible, but not clean.
November 27, 201510 yr Author I can but the way my case is I lose a slot because the holes in the hard drives are not centered. I guess that's the best option at this point.
November 27, 201510 yr Well, i think the "best" option at this point is to not be so OCD ... but I'm not you
