December 3, 201510 yr Had an issue with my server and a bad power plug on a hard drive. This caused the drive to go offline and caused me a ton of frustration until I figured out that a 25 cent part was the source of my problems. Shortly thereafter or during the issues, the drive popped up with 240 reallocated sectors. This is a new drive (30 days) and I could possibly still return it for an exchange. Thoughts? It originally passed 1 preclear successfully and then I loaded it with about 1.5TB and had no issues for a week or two. Smart report below. smartctl 6.2 2013-07-26 r3841 [x86_64-linux-4.0.4-unRAID] (local build) Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Device Model: TOSHIBA MD04ACA500 Serial Number: 9549K5XIFS9A LU WWN Device Id: 5 000039 68bb00711 Firmware Version: FP2A User Capacity: 5,000,981,078,016 bytes [5.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Device is: Not in smartctl database [for details use: -P showall] ATA Version is: ATA8-ACS (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 1.5 Gb/s) Local Time is: Wed Dec 2 23:26:27 2015 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 120) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 552) minutes. SCT capabilities: (0x003d) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0 2 Throughput_Performance 0x0005 100 100 050 Pre-fail Offline - 0 3 Spin_Up_Time 0x0027 100 100 001 Pre-fail Always - 8835 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 54 5 Reallocated_Sector_Ct 0x0033 100 100 050 Pre-fail Always - 240 7 Seek_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0 8 Seek_Time_Performance 0x0005 100 100 050 Pre-fail Offline - 0 9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 412 10 Spin_Retry_Count 0x0033 101 100 030 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 23 191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 49 192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 17 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 114 194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 28 (Min/Max 19/41) 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 27 197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 220 Disk_Shift 0x0002 100 100 000 Old_age Always - 0 222 Loaded_Hours 0x0032 100 100 000 Old_age Always - 240 223 Load_Retry_Count 0x0032 100 100 000 Old_age Always - 0 224 Load_Friction 0x0022 100 100 000 Old_age Always - 0 226 Load-in_Time 0x0026 100 100 000 Old_age Always - 206 240 Head_Flying_Hours 0x0001 100 100 001 Pre-fail Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 411 - # 2 Extended offline Aborted by host 70% 409 - # 3 Short offline Completed without error 00% 218 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
December 3, 201510 yr I would move the data to another drive and put it through 2 more cycles of preclear. I have found 1 cycle is not enough and had drives die during cycle 3.
December 3, 201510 yr I agree. With 240 remapped sectors already and 27 different reallocation events, that's somewhat troubling. What's amazing is that 240 didn't even bump the Reallocated Sectors count VALUE, indicating the drive may have more than 24000 spare sectors! That's a lot, perhaps they are expecting a lot of reallocations?!?
December 3, 201510 yr Author I'll run a few more preclears, but will it possible fix the reallocated sectors... Or just confirm its not worse than that? Or I'm against the timeline for returning to Amazon, so should I just return it and call it a day... When I got the drive, the first preclears took almost 3 days. I had limited time so only got one done.
December 3, 201510 yr If it was me I would just return it or exchange it on Amazon for a new one. Re-running the preclear will not remove the reallocated sectors (they are permanent), you would just be confirming that it isn't getting worse.
