December 14, 201510 yr Is there currently an easy way built into unraid to control based on system temps? Currently the fans fin full speed making it exceedingly noisy. Looking through the search on threads about this, they all seem to be a few years old so was looking for an easy way to possibly get the fan noise under control. I currently have a Supermicro X10SL7-F with the following fans connected to the headers: CPU Heatsink - Stock PWM Front intake, 120mm PWM Rear exhaust, 120mm PWM Side exhaust, 120mm PWM Top Exhaust, 200mm non-pwm
December 14, 201510 yr Community Expert Are you sure you know how to use the search on this forum? It can be a little confusing. See search tips in my sig. I was already aware of this, but I also found it easily with a search. System AutoFan in Dynamix - V6 Plugins
December 14, 201510 yr Author Thanks, the links I kept seeing were to: Temperature based fan speed control? - http://lime-technology.com/forum/index.php?topic=5548.0 Supermicro X9SCM-F PWM fan_control - http://lime-technology.com/forum/index.php?topic=22393.0 Temperature-based fan speed control for unRAID - http://lime-technology.com/forum/index.php?topic=5583.45 etc... etc...
December 14, 201510 yr Community Expert Search for: fan speed Search order: Most recent topics first All other Search Parameters left at defaults.
December 14, 201510 yr Author Thanks, I was using a combination of the search box in the upper right and google to pull out links
December 15, 201510 yr You might have to use something like this. Use one PWM fan to drive multiple fans. This http://www.amazon.com/Phobya-4-Pin-Splitter-Power-Eight/dp/B00OD7MO6E/ref=sr_1_1?tag=ds0233-20&ie=UTF8&qid=1449944169&sr=8-1&keywords=Phobya+PWM+splitter or this http://www.amazon.com/Swiftech-8W-PWM-SPL-ST-Way-PWM-Splitter-Sata/dp/B00IF6R4C8/ref=sr_1_sc_1?tag=ds0233-20&ie=UTF8&qid=1449944077&sr=8-1-spell&keywords=Switftech+fan+controler or this http://www.amazon.com/gp/product/B00M0R05WE?tag=ds0233-20&psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
December 15, 201510 yr Community Expert Thanks, I was using a combination of the search box in the upper right and google to pull out links I think that's what a lot of people do. They are missing out on the real search features. I seldom use the upper right search box.
