iStarUSA BPN-DE110SS 40mm fan connector problems?
My hard drives idle in these cages are about 32 degrees.  I haven;t started working the drives yet so they wil still get pretty hot without anything sucking the hot air out.  Maybe it wont be necessary since the drives should have a pretty high tolerance.
Products in question:
iStarUSA BPN-DE110SS-BLACK 1x5.25" to 1x3.5" SATA/SAS 6.0 Gb/s Trayless Hot-Swap Cage
http://www.newegg.com/Product/Product.aspx?Item=N82E16816215323
Scythe Mini KAZE 40mm Silent Case Fan (SY124010L)
http://www.amazon.com/Scythe-Mini-KAZE-Silent-SY124010L/dp/B000LB0M8S/ref=sr_1_2?ie=UTF8&qid=1450243563&sr=8-2&keywords=scythe+kaze+40mm
iStarUSA DD-FAN40-2P 40mm Ball Bearing 2-pin Fan for BPN-DE110SS
http://www.istarusa.com/istarusa/products.php?series=Accessories⊂=Fans%20&%20Parts&model=DD-FAN40-2P
Has anyone else tried to hook one of these up?  The 2 pin connector is either way too small and made so that you can only plug iStars 40mm fans into them or the 40mm fan I bought has an incompatible 2 pin plug.
Fan Splitter 4 pin Molex > 3 Qty PWM headers 30cm long CONNECT MULTIPLE PWM FANS
http://www.amazon.com/Splitter-Molex-headers-CONNECT-MULTIPLE/dp/B009D3HV1Q
The fans do come with a 2 pin to 3 pin adapter, so I could get a molex to 3 pin splitter and connect them that way but it wouldnt look as clean inside as connecting the fans to the cage.
I ended up using the 2 pin -> 3 pin adapter and plugged the 3 pin adapters into a molex -> 4x2pin splitter.
The Scythe fans did not come with screws so I picked up some 3mm x 16mm machine screws with some 3mm nuts to hold them in place.  Home Depot carried them for about .50 a package of 3 screws.  I ended up only putting 2 screws in per fan because that is all I had on hand and should be plenty for that tiny fan.
