December 20, 201510 yr I'm thinking about getting NORCO RPC-4224, but I would have to replace the loud fans with the Noctua fans. I want fans to be pwm so that my motherboard can control my fans. But I quickly learned that my mobo only supports 3 casefans. Are there anyways to combine 3 front fans and 2 back fans into one, and have them connect to both PSU (for power) and mobo for fan control? seems like I can only do one or the other, but just wanted to know if this is possible. I thought of connecting all of them to PSU, but I'm worried that they'll all run at full speed, and I head even Noctua fans are loud under full speed.
December 20, 201510 yr Author I found that there is PWM splitter that combines three 4pin connections into one 4pin and mole. Will this work for my scenario? http://www.newegg.ca/Product/Product.aspx?Item=N82E16812311002&cm_re=PWM_Splitter-_-12-311-002-_-Product
