Help! Everything is stuck in read-only mode and nothing works!
Everything is stuck in read-only mode and nothing works! Here are 2 videos showing some of the issues.
https://onedrive.live.com/redir?resid=31E84CF772E4B44E!318802&authkey=!AOeAB1QCHkqd7wc&ithint=folder%2c
And here is a error when I try to install a docker app.
Mktemp failed: mkdir /var/lib/docker/graph/_tmp: read-only file system. Error pulling image (latest) from limetech/plex, Mktemp failed: mkdir /var/lib/docker/graph/_tmp: read-only file system.
2e494d81b33d: Error pulling image (latest) from limetech/plex, Mktemp failed: mkdir /var/lib/docker/graph/_tmp: read-only file system
Please help guys!
You really should post the full diagnostics but without them my guess is that the cache drive has a corrupted file system and is set to read only to prevent data loss
Lots of messages about this disk
Jan 17 19:57:58 Tower kernel: ata5.00: ATA-9: WDC WD40EFRX-68WT0N0,      WD-WCC4E4VDLT4Y, 82.00A82, max UDMA/133
which is supposed to be disk1, but no SMART for it in your diagnostics.
Check your connections.
