Problems running things like iotop and lsof inside a screen session
I have "screen" installed from the nerdpack and wanted to run both iotop and watch lsof in separate windows during a large backup... I'm having trouble using either of these...
I start screen and then try to run my commands. Here's my output:
root@Tower:/boot/extra# iotop
  File "/usr/sbin/iotop", line 17, in <module>
    main()
  File "/usr/lib64/python2.7/site-packages/iotop/ui.py", line 620, in main
    main_loop()
  File "/usr/lib64/python2.7/site-packages/iotop/ui.py", line 610, in <lambda>
    main_loop = lambda: run_iotop(options)
  File "/usr/lib64/python2.7/site-packages/iotop/ui.py", line 508, in run_iotop
    return curses.wrapper(run_iotop_window, options)
  File "/usr/lib64/python2.7/curses/wrapper.py", line 22, in wrapper
    stdscr = curses.initscr()
  File "/usr/lib64/python2.7/curses/__init__.py", line 33, in initscr
    fd=_sys.__stdout__.fileno())
_curses.error: setupterm: could not find terminal
root@Tower:/boot/extra# watch lsof /mnt/bkup01/
Error opening terminal: vt100.
Thoughts? I'm a tmux guy so not too saavy with screen yet. It should be noted that these apps work fine outside of screen.
