March 24, 201610 yr Hi Everyone, just like many people (i assume) i am testing unraid as i like the idea of having one machine serving 2 gamers and beeing able to do a lot more besides that. Never tried any Virtualization before. Specs: I am running unraid version 6.19 on an 32Gb SANDISK Extreme stick (USB-3). As for the Hardware i am using a Asus Z10PE-D16WS with 2 E5-2630 v3 and 8x16 GB Ram and 2x Asus GTX 970 Strix. 2x120G Sandisk SSD, 1x 256G Samsung 830 SSD, 1x 512G Samsung 850 SSD, 3x 1TB WD Black HDD. 1x 1TB Samsung 850 SSD for parity and 1x 128G Samsung 830 SSD for Cache (not used yet) Problem Description: I am trying to set up 2x Win10Pro 64-Bit VM's with 8GB Ram and 2x vdisks (160G & 320G) which after many learning by reading seems to work. At least as long as i only create one VM i managed to get that one running and was able to Game without any problems. Then j add the 2nd VM and everything still remains ok. As soon as i end one of the VM's and try to start it again the fun begins. 1. It will try to install Win10 all over again. If you skip that part by waiting you'll get to the CLI where i type exit and then choose EFI Misc whatsoever in the Bootmenu. It'll work once. https://lime-technology.com/forum/index.php?topic=45536.msg434753#msg434753 On the second VM i also had to use that trick: https://lime-technology.com/forum/index.php?topic=46786.msg447100;topicseen#msg447100 2.Once you restart the VM again now the EFI workaround will only lead to a Black Screen. I searched everywhere. But i am kind of stuck. I hope someone sees my mistake or is able to point me to the right spot. What i already tried as well: http://lime-technology.com/forum/index.php?topic=47571.0 https://lime-technology.com/forum/index.php?topic=42186.0 Might that be somethingto look to? http://lime-technology.com/forum/index.php?topic=44010.0 Every help is much appreciated. tower-diagnostics-20160324-0426.zip
March 25, 201610 yr Author This is my current config. I tried to use the fix but it did not solve anything. I already tried everything.Setting it to OVFM or to Seabios and so on. XML_1.txt XML_2.txt
March 25, 201610 yr Author Seems like i found my mistake now. When i started testing i only had 2 Graphicscards in the System. Both had been in the same IOMMU Group so that i had to enable PciE ACS Override. When i started troubleshooting i added a third Graphicscard into the first PciE Slot. That of course changed the IOMMU Grouping. But, the newb i am i did not look into it end kept assuming i need to activate PciE ACS Override. So far it seems to work ok. The vms are still trying to install from scratch when beeing restarted. But by typing Exit in the console and choosing the Misc Device it seems to work right now.
March 26, 201610 yr Author One Night later after downloading some Games and Stuff the Error is back. Just now i only get a Black Screen. By restarting the Server they went up and running. Of course with the whole let's try to reinstall first. Exit, Misc Device. Ok they start. It works but i am not satisfied with that if i have to reboot the whole Server just after 1 day already. But well, it works.
