Running slow, how to tell which disk is problem?
My unRaid server is running slow, I think its got to be one of the disks ... but I dont know how to find out which disk could be the problem ... what do I need to do?
Attach a copy of your "syslog" to this thread.
Instructions are in the wiki here: http://lime-technology.com/wiki/index.php?title=Troubleshooting#Capturing_your_syslog
Two quick questions???  In what way is your server running slow?  How are you measuring/determining it is slow?
Joe L.
The following are some examples of what happens ...
Sample1:  in process of deleting a folder that contains thousands of folders/files, I click to highlight and then hit delete ... it then will popup a windows dialogue with a waiting animation (implying it is preparing the delete process) ... it will stay this way for a long time (a couple hours one time when I went to delete a folder that contained 10gig of file/folders) ... after the few hours it finally refreshed to the "Are you sure you want to delete?" dialogue box ... of which I clicked yes ... and then it took a few hours to delete.
Sample2: generall copying from and too the server is noticably slower ... it took like 5 or so minutes to copy 550mb ...
SYSLOG:
Nov  3 21:51:55 TOWER syslogd 1.4.1: restart.
Nov  3 21:51:55 TOWER kernel: klogd 1.4.1, log source = /proc/kmsg started.
Nov  3 21:51:55 TOWER kernel: Linux version 2.6.29.1-unRAID (root@Develop) (gcc version 4.2.4) #2 SMP Thu Apr 23 14:17:18 MDT 2009
Nov  3 21:51:55 TOWER kernel: KERNEL supported cpus:
Nov  3 21:51:55 TOWER kernel:  Intel GenuineIntel
Nov  3 21:51:55 TOWER kernel:  AMD AuthenticAMD
Nov  3 21:51:55 TOWER kernel:  NSC Geode by NSC
Nov  3 21:51:55 TOWER kernel:  Cyrix CyrixInstead
Nov  3 21:51:55 TOWER kernel:  Centaur CentaurHauls
Nov  3 21:51:55 TOWER kernel:  Transmeta GenuineTMx86
Nov  3 21:51:55 TOWER kernel:  Transmeta TransmetaCPU
Nov  3 21:51:55 TOWER kernel:  UMC UMC UMC UMC
Nov  3 21:51:55 TOWER kernel: BIOS-provided physical RAM map:
Nov  3 21:51:55 TOWER kernel:  BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
Nov  3 21:51:55 TOWER kernel:  BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
Nov  3 21:51:55 TOWER kernel:  BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
Nov  3 21:51:55 TOWER kernel:  BIOS-e820: 0000000000100000 - 000000003f673000 (usable)
Nov  3 21:51:55 TOWER kernel:  BIOS-e820: 000000003f673000 - 000000003f6e8000 (ACPI NVS)
Nov  3 21:51:55 TOWER kernel:  BIOS-e820: 000000003f6e8000 - 000000003f6ec000 (usable)
Nov  3 21:51:55 TOWER kernel:  BIOS-e820: 000000003f6ec000 - 000000003f6ff000 (ACPI data)
Nov  3 21:51:55 TOWER kernel:  BIOS-e820: 000000003f6ff000 - 000000003f700000 (usable)
Nov  3 21:51:55 TOWER kernel: DMI 2.3 present.
Nov  3 21:51:55 TOWER kernel: last_pfn = 0x3f700 max_arch_pfn = 0x1000000
Nov  3 21:51:55 TOWER kernel: x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
Nov  3 21:51:55 TOWER kernel: kernel direct mapping tables up to 379fe000 @ 7000-d000
Nov  3 21:51:55 TOWER kernel: NX (Execute Disable) protection: active
Nov  3 21:51:55 TOWER kernel: RAMDISK: 3c951000 - 3f672003
Nov  3 21:51:55 TOWER kernel: Allocated new RAMDISK: 004d7000 - 031f8003
Nov  3 21:51:55 TOWER kernel: Move RAMDISK from 000000003c951000 - 000000003f672002 to 004d7000 - 031f8002
Nov  3 21:51:55 TOWER kernel: ACPI: RSDP 000FE020, 0014 (r0 INTEL )
Nov  3 21:51:55 TOWER kernel: ACPI: RSDT 3F6FDE48, 0044 (r1 INTEL  D945GNT      F9C MSFT  1000013)
Nov  3 21:51:55 TOWER kernel: ACPI: FACP 3F6FCF10, 0074 (r1 INTEL  D945GNT      F9C MSFT  1000013)
Nov  3 21:51:55 TOWER kernel: FADT: X_PM1a_EVT_BLK.bit_width (16) does not match PM1_EVT_LEN (4)
Nov  3 21:51:55 TOWER kernel: ACPI: DSDT 3F6F7010, 42BF (r1 INTEL  D945GNT      F9C MSFT  1000013)
Nov  3 21:51:55 TOWER kernel: ACPI: FACS 3F6DCC40, 0040
Nov  3 21:51:55 TOWER kernel: ACPI: APIC 3F6FCE10, 0078 (r1 INTEL  D945GNT      F9C MSFT  1000013)
Nov  3 21:51:55 TOWER kernel: ACPI: WDDT 3F6F6F90, 0040 (r1 INTEL  D945GNT      F9C MSFT  1000013)
Nov  3 21:51:55 TOWER kernel: ACPI: MCFG 3F6F6F10, 003C (r1 INTEL  D945GNT      F9C MSFT  1000013)
Nov  3 21:51:55 TOWER kernel: ACPI: ASF! 3F6FCD10, 00A6 (r32 INTEL  D945GNT      F9C MSFT  1000013)
Nov  3 21:51:55 TOWER kernel: ACPI: HPET 3F6F6E90, 0038 (r1 INTEL  D945GNT      F9C MSFT  1000013)
Nov  3 21:51:55 TOWER kernel: ACPI: SSDT 3F6F6E10, 002F (r1 INTEL  SetupVar      F9C MSFT  1000013)
Nov  3 21:51:55 TOWER kernel: ACPI: TCPA 3F6E3D90, 0028 (r1 INTEL  TIANO          2 MSFT  1000013)
Nov  3 21:51:55 TOWER kernel: ACPI: Local APIC address 0xfee00000
Nov  3 21:51:55 TOWER kernel: 125MB HIGHMEM available.
Nov  3 21:51:55 TOWER kernel: 889MB LOWMEM available.
Nov  3 21:51:55 TOWER kernel:  mapped low ram: 0 - 379fe000
Nov  3 21:51:55 TOWER kernel:  low ram: 00000000 - 379fe000
Nov  3 21:51:55 TOWER kernel:  bootmap 00009000 - 0000ff40
Nov  3 21:51:55 TOWER kernel: (9 early reservations) ==> bootmem [0000000000 - 00379fe000]
Nov  3 21:51:55 TOWER kernel:  #0 [0000000000 - 0000001000]  BIOS data page ==> [0000000000 - 0000001000]
Nov  3 21:51:55 TOWER kernel:  #1 [0000001000 - 0000002000]    EX TRAMPOLINE ==> [0000001000 - 0000002000]
Nov  3 21:51:55 TOWER kernel:  #2 [0000006000 - 0000007000]      TRAMPOLINE ==> [0000006000 - 0000007000]
Nov  3 21:51:55 TOWER kernel:  #3 [0000100000 - 00004cf1fc]    TEXT DATA BSS ==> [0000100000 - 00004cf1fc]
Nov  3 21:51:55 TOWER kernel:  #4 [00004d0000 - 00004d7000]    INIT_PG_TABLE ==> [00004d0000 - 00004d7000]
Nov  3 21:51:55 TOWER kernel:  #5 [000009e800 - 0000100000]    BIOS reserved ==> [000009e800 - 0000100000]
Nov  3 21:51:55 TOWER kernel:  #6 [0000007000 - 0000009000]          PGTABLE ==> [0000007000 - 0000009000]
Nov  3 21:51:55 TOWER kernel:  #7 [00004d7000 - 00031f8003]      NEW RAMDISK ==> [00004d7000 - 00031f8003]
Nov  3 21:51:55 TOWER kernel:  #8 [0000009000 - 0000010000]          BOOTMAP ==> [0000009000 - 0000010000]
Nov  3 21:51:55 TOWER kernel: found SMP MP-table at [c00fe680] 000fe680
Nov  3 21:51:55 TOWER kernel: Zone PFN ranges:
Nov  3 21:51:55 TOWER kernel:  DMA      0x00000000 -> 0x00001000
Nov  3 21:51:55 TOWER kernel:  Normal  0x00001000 -> 0x000379fe
Nov  3 21:51:55 TOWER kernel:  HighMem  0x000379fe -> 0x0003f700
Nov  3 21:51:55 TOWER kernel: Movable zone start PFN for each node
Nov  3 21:51:55 TOWER kernel: early_node_map[4] active PFN ranges
Nov  3 21:51:55 TOWER kernel:    0: 0x00000000 -> 0x0000009f
Nov  3 21:51:55 TOWER kernel:    0: 0x00000100 -> 0x0003f673
Nov  3 21:51:55 TOWER kernel:    0: 0x0003f6e8 -> 0x0003f6ec
Nov  3 21:51:55 TOWER kernel:    0: 0x0003f6ff -> 0x0003f700
Nov  3 21:51:55 TOWER kernel: On node 0 totalpages: 259607
Nov  3 21:51:55 TOWER kernel: free_area_init_node: node 0, pgdat c042fa80, node_mem_map c31f9000
Nov  3 21:51:55 TOWER kernel:  DMA zone: 32 pages used for memmap
Nov  3 21:51:55 TOWER kernel:  DMA zone: 0 pages reserved
Nov  3 21:51:55 TOWER kernel:  DMA zone: 3967 pages, LIFO batch:0
Nov  3 21:51:55 TOWER kernel:  Normal zone: 1748 pages used for memmap
Nov  3 21:51:55 TOWER kernel:  Normal zone: 221994 pages, LIFO batch:31
Nov  3 21:51:55 TOWER kernel:  HighMem zone: 251 pages used for memmap
Nov  3 21:51:55 TOWER kernel:  HighMem zone: 31615 pages, LIFO batch:7
Nov  3 21:51:55 TOWER kernel: ACPI: PM-Timer IO Port: 0x408
Nov  3 21:51:55 TOWER kernel: ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
Nov  3 21:51:55 TOWER kernel: ACPI: LAPIC (acpi_id[0x02] lapic_id[0x81] disabled)
Nov  3 21:51:55 TOWER kernel: ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
Nov  3 21:51:55 TOWER kernel: ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
Nov  3 21:51:55 TOWER kernel: ACPI: LAPIC_NMI (acpi_id[0x01] dfl dfl lint[0x1])
Nov  3 21:51:55 TOWER kernel: ACPI: LAPIC_NMI (acpi_id[0x02] dfl dfl lint[0x1])
Nov  3 21:51:55 TOWER kernel: ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
Nov  3 21:51:55 TOWER kernel: IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
Nov  3 21:51:55 TOWER kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Nov  3 21:51:55 TOWER kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
Nov  3 21:51:55 TOWER kernel: ACPI: IRQ0 used by override.
Nov  3 21:51:55 TOWER kernel: ACPI: IRQ2 used by override.
Nov  3 21:51:55 TOWER kernel: ACPI: IRQ9 used by override.
Nov  3 21:51:55 TOWER kernel: Enabling APIC mode:  Flat.  Using 1 I/O APICs
Nov  3 21:51:55 TOWER kernel: Using ACPI (MADT) for SMP configuration information
Nov  3 21:51:55 TOWER kernel: ACPI: HPET id: 0x8086a201 base: 0xfed00000
Nov  3 21:51:55 TOWER kernel: SMP: Allowing 4 CPUs, 3 hotplug CPUs
Nov  3 21:51:55 TOWER kernel: nr_irqs_gsi: 24
Nov  3 21:51:55 TOWER kernel: Allocating PCI resources starting at 40000000 (gap: 3f700000:c0900000)
Nov  3 21:51:55 TOWER kernel: NR_CPUS:4 nr_cpumask_bits:4 nr_cpu_ids:4 nr_node_ids:1
Nov  3 21:51:55 TOWER kernel: PERCPU: Allocating 32768 bytes of per cpu data
Nov  3 21:51:55 TOWER kernel: Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 257576
Nov  3 21:51:55 TOWER kernel: Kernel command line: initrd=bzroot rootdelay=10 BOOT_IMAGE=bzimage
Nov  3 21:51:55 TOWER kernel: Enabling fast FPU save and restore... done.
Nov  3 21:51:55 TOWER kernel: Enabling unmasked SIMD FPU exception support... done.
Nov  3 21:51:55 TOWER kernel: Initializing CPU#0
Nov  3 21:51:55 TOWER kernel: PID hash table entries: 4096 (order: 12, 16384 bytes)
Nov  3 21:51:55 TOWER kernel: Fast TSC calibration using PIT
Nov  3 21:51:55 TOWER kernel: Detected 2533.322 MHz processor.
Nov  3 21:51:55 TOWER kernel: Console: colour VGA+ 80x25
Nov  3 21:51:55 TOWER kernel: console [tty0] enabled
Nov  3 21:51:55 TOWER kernel: Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Nov  3 21:51:55 TOWER kernel: Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Nov  3 21:51:55 TOWER kernel: Memory: 978724k/1039360k available (2332k kernel code, 59380k reserved, 1032k data, 264k init, 127464k highmem)
Nov  3 21:51:55 TOWER kernel: virtual kernel memory layout:
Nov  3 21:51:55 TOWER kernel:    fixmap  : 0xfff85000 - 0xfffff000  ( 488 kB)
Nov  3 21:51:55 TOWER kernel:    pkmap  : 0xffa00000 - 0xffc00000  (2048 kB)
Nov  3 21:51:55 TOWER kernel:    vmalloc : 0xf81fe000 - 0xff9fe000  ( 120 MB)
Nov  3 21:51:55 TOWER kernel:    lowmem  : 0xc0000000 - 0xf79fe000  ( 889 MB)
Nov  3 21:51:55 TOWER kernel:      .init : 0xc0450000 - 0xc0492000  ( 264 kB)
Nov  3 21:51:55 TOWER kernel:      .data : 0xc0347206 - 0xc04495b8  (1032 kB)
Nov  3 21:51:55 TOWER kernel:      .text : 0xc0100000 - 0xc0347206  (2332 kB)
Nov  3 21:51:55 TOWER kernel: Checking if this processor honours the WP bit even in supervisor mode...Ok.
Nov  3 21:51:55 TOWER kernel: SLUB: Genslabs=12, HWalign=128, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
Nov  3 21:51:55 TOWER kernel: hpet clockevent registered
Nov  3 21:51:55 TOWER kernel: HPET: 3 timers in total, 0 timers will be used for per-cpu timer
Nov  3 21:51:55 TOWER kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 5066.64 BogoMIPS (lpj=25333220)
Nov  3 21:51:55 TOWER kernel: Mount-cache hash table entries: 512
Nov  3 21:51:55 TOWER kernel: CPU: Trace cache: 12K uops, L1 D cache: 16K
Nov  3 21:51:55 TOWER kernel: CPU: L2 cache: 256K
Nov  3 21:51:55 TOWER kernel: CPU: Hyper-Threading is disabled
Nov  3 21:51:55 TOWER kernel: Intel machine check architecture supported.
Nov  3 21:51:55 TOWER kernel: Intel machine check reporting enabled on CPU#0.
Nov  3 21:51:55 TOWER kernel: CPU0: Intel P4/Xeon Extended MCE MSRs (24) available
Nov  3 21:51:55 TOWER kernel: using mwait in idle threads.
Nov  3 21:51:55 TOWER kernel: Checking 'hlt' instruction... OK.
Nov  3 21:51:55 TOWER kernel: SMP alternatives: switching to UP code
Nov  3 21:51:55 TOWER kernel: ACPI: Core revision 20081204
Nov  3 21:51:55 TOWER kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
Nov  3 21:51:55 TOWER kernel: CPU0: Intel® Celeron® CPU 2.53GHz stepping 09
Nov  3 21:51:55 TOWER kernel: Brought up 1 CPUs
Nov  3 21:51:55 TOWER kernel: Total of 1 processors activated (5066.64 BogoMIPS).
Nov  3 21:51:55 TOWER kernel: net_namespace: 532 bytes
Nov  3 21:51:55 TOWER kernel: NET: Registered protocol family 16
Nov  3 21:51:55 TOWER kernel: ACPI: bus type pci registered
Nov  3 21:51:55 TOWER kernel: PCI: Found Intel Corporation 945G/GZ/P/PL Express Memory Controller Hub without MMCONFIG support.
Nov  3 21:51:55 TOWER kernel: PCI: Using configuration type 1 for base access
Nov  3 21:51:55 TOWER kernel: bio: create slab <bio-0> at 0
Nov  3 21:51:55 TOWER kernel: ACPI: EC: Look up EC in DSDT
Nov  3 21:51:55 TOWER kernel: ACPI: Interpreter enabled
Nov  3 21:51:55 TOWER kernel: ACPI: (supports S0 S1 S3 S5)
Nov  3 21:51:55 TOWER kernel: ACPI: Using IOAPIC for interrupt routing
Nov  3 21:51:55 TOWER kernel: ACPI: No dock devices found.
Nov  3 21:51:55 TOWER kernel: ACPI: PCI Root Bridge [PCI0] (0000:00)
Nov  3 21:51:55 TOWER kernel: pci 0000:00:02.0: reg 10 32bit mmio: [0x50200000-0x5027ffff]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:02.0: reg 14 io port: [0x30e0-0x30e7]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:02.0: reg 18 32bit mmio: [0x40000000-0x4fffffff]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:02.0: reg 1c 32bit mmio: [0x50280000-0x502bffff]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.0: PME# disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.2: PME# disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.3: PME# disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.4: PME# disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.5: PME# disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1d.0: reg 20 io port: [0x3080-0x309f]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1d.1: reg 20 io port: [0x3060-0x307f]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1d.2: reg 20 io port: [0x3040-0x305f]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1d.3: reg 20 io port: [0x3020-0x303f]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1d.7: reg 10 32bit mmio: [0x502c0400-0x502c07ff]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1d.7: PME# disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1f.0: quirk: region 0400-047f claimed by ICH6 ACPI/GPIO/TCO
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1f.0: quirk: region 0500-053f claimed by ICH6 GPIO
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1f.0: ICH7 LPC Generic IO decode 1 PIO at 0680 (mask 007f)
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1f.1: reg 10 io port: [0x00-0x07]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1f.1: reg 14 io port: [0x00-0x03]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1f.1: reg 18 io port: [0x00-0x07]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1f.1: reg 1c io port: [0x00-0x03]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1f.1: reg 20 io port: [0x30b0-0x30bf]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1f.2: reg 10 io port: [0x30c8-0x30cf]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1f.2: reg 14 io port: [0x30ec-0x30ef]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1f.2: reg 18 io port: [0x30c0-0x30c7]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1f.2: reg 1c io port: [0x30e8-0x30eb]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1f.2: reg 20 io port: [0x30a0-0x30af]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1f.2: reg 24 32bit mmio: [0x502c0000-0x502c03ff]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1f.2: PME# supported from D3hot
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1f.2: PME# disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1f.3: reg 20 io port: [0x3000-0x301f]
Nov  3 21:51:55 TOWER kernel: pci 0000:01:00.0: reg 10 32bit mmio: [0x50100000-0x5011ffff]
Nov  3 21:51:55 TOWER kernel: pci 0000:01:00.0: reg 18 io port: [0x2000-0x201f]
Nov  3 21:51:55 TOWER kernel: pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
Nov  3 21:51:55 TOWER kernel: pci 0000:01:00.0: PME# disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.0: bridge io port: [0x2000-0x2fff]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.0: bridge 32bit mmio: [0x50100000-0x501fffff]
Nov  3 21:51:55 TOWER kernel: pci 0000:06:00.0: reg 10 io port: [0x1018-0x101f]
Nov  3 21:51:55 TOWER kernel: pci 0000:06:00.0: reg 14 io port: [0x1024-0x1027]
Nov  3 21:51:55 TOWER kernel: pci 0000:06:00.0: reg 18 io port: [0x1010-0x1017]
Nov  3 21:51:55 TOWER kernel: pci 0000:06:00.0: reg 1c io port: [0x1020-0x1023]
Nov  3 21:51:55 TOWER kernel: pci 0000:06:00.0: reg 20 io port: [0x1000-0x100f]
Nov  3 21:51:55 TOWER kernel: pci 0000:06:00.0: reg 24 32bit mmio: [0x50000000-0x50003fff]
Nov  3 21:51:55 TOWER kernel: pci 0000:06:00.0: reg 30 32bit mmio: [0xffffc000-0xffffffff]
Nov  3 21:51:55 TOWER kernel: pci 0000:06:00.0: supports D1
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1e.0: transparent bridge
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1e.0: bridge io port: [0x1000-0x1fff]
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1e.0: bridge 32bit mmio: [0x50000000-0x500fffff]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:00: on NUMA node 0
Nov  3 21:51:55 TOWER kernel: ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
Nov  3 21:51:55 TOWER kernel: ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P32_._PRT]
Nov  3 21:51:55 TOWER kernel: ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX0._PRT]
Nov  3 21:51:55 TOWER kernel: ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX2._PRT]
Nov  3 21:51:55 TOWER kernel: ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX3._PRT]
Nov  3 21:51:55 TOWER kernel: ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX4._PRT]
Nov  3 21:51:55 TOWER kernel: ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX5._PRT]
Nov  3 21:51:55 TOWER kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 7 9 10 *11 12)
Nov  3 21:51:55 TOWER kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
Nov  3 21:51:55 TOWER kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 7 9 10 *11 12)
Nov  3 21:51:55 TOWER kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 7 9 *10 11 12)
Nov  3 21:51:55 TOWER kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
Nov  3 21:51:55 TOWER kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 7 *9 10 11 12)
Nov  3 21:51:55 TOWER kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 7 9 10 11 12) *0, disabled.
Nov  3 21:51:55 TOWER kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 7 *9 10 11 12)
Nov  3 21:51:55 TOWER kernel: SCSI subsystem initialized
Nov  3 21:51:55 TOWER kernel: usbcore: registered new interface driver usbfs
Nov  3 21:51:55 TOWER kernel: usbcore: registered new interface driver hub
Nov  3 21:51:55 TOWER kernel: usbcore: registered new device driver usb
Nov  3 21:51:55 TOWER kernel: PCI: Using ACPI for IRQ routing
Nov  3 21:51:55 TOWER kernel: pnp: PnP ACPI init
Nov  3 21:51:55 TOWER kernel: ACPI: bus type pnp registered
Nov  3 21:51:55 TOWER kernel: pnp: PnP ACPI: found 11 devices
Nov  3 21:51:55 TOWER kernel: ACPI: ACPI bus type pnp unregistered
Nov  3 21:51:55 TOWER kernel: system 00:01: iomem range 0xf0000000-0xf3ffffff has been reserved
Nov  3 21:51:55 TOWER kernel: system 00:01: iomem range 0xfed13000-0xfed13fff has been reserved
Nov  3 21:51:55 TOWER kernel: system 00:01: iomem range 0xfed14000-0xfed17fff has been reserved
Nov  3 21:51:55 TOWER kernel: system 00:01: iomem range 0xfed18000-0xfed18fff has been reserved
Nov  3 21:51:55 TOWER kernel: system 00:01: iomem range 0xfed19000-0xfed19fff has been reserved
Nov  3 21:51:55 TOWER kernel: system 00:01: iomem range 0xfed1c000-0xfed1ffff has been reserved
Nov  3 21:51:55 TOWER kernel: system 00:01: iomem range 0xfed20000-0xfed3ffff has been reserved
Nov  3 21:51:55 TOWER kernel: system 00:01: iomem range 0xfed45000-0xfed99fff has been reserved
Nov  3 21:51:55 TOWER kernel: system 00:01: iomem range 0xc0000-0xdffff could not be reserved
Nov  3 21:51:55 TOWER kernel: system 00:01: iomem range 0xe0000-0xfffff could not be reserved
Nov  3 21:51:55 TOWER kernel: system 00:06: ioport range 0x500-0x53f has been reserved
Nov  3 21:51:55 TOWER kernel: system 00:06: ioport range 0x400-0x47f has been reserved
Nov  3 21:51:55 TOWER kernel: system 00:06: ioport range 0x680-0x6ff has been reserved
Nov  3 21:51:55 TOWER kernel: system 00:07: iomem range 0xfed40000-0xfed44fff has been reserved
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.0: PCI bridge, secondary bus 0000:01
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.0:  IO window: 0x2000-0x2fff
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.0:  MEM window: 0x50100000-0x501fffff
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.0:  PREFETCH window: disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.2: PCI bridge, secondary bus 0000:02
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.2:  IO window: disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.2:  MEM window: disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.2:  PREFETCH window: disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.3: PCI bridge, secondary bus 0000:03
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.3:  IO window: disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.3:  MEM window: disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.3:  PREFETCH window: disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.4: PCI bridge, secondary bus 0000:04
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.4:  IO window: disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.4:  MEM window: disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.4:  PREFETCH window: disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.5: PCI bridge, secondary bus 0000:05
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.5:  IO window: disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.5:  MEM window: disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.5:  PREFETCH window: disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1e.0: PCI bridge, secondary bus 0000:06
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1e.0:  IO window: 0x1000-0x1fff
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1e.0:  MEM window: 0x50000000-0x500fffff
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1e.0:  PREFETCH window: disabled
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.0: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.2: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.3: PCI INT D -> GSI 19 (level, low) -> IRQ 19
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.3: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.4: PCI INT A -> GSI 17 (level, low) -> IRQ 17
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.4: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.5: PCI INT B -> GSI 16 (level, low) -> IRQ 16
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1c.5: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: pci 0000:00:1e.0: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:00: resource 0 io:  [0x00-0xffff]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffffffffffff]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:01: resource 0 io:  [0x2000-0x2fff]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:01: resource 1 mem: [0x50100000-0x501fffff]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:01: resource 2 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:01: resource 3 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:02: resource 0 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:02: resource 1 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:02: resource 2 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:02: resource 3 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:03: resource 0 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:03: resource 1 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:03: resource 2 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:03: resource 3 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:04: resource 0 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:04: resource 1 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:04: resource 2 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:04: resource 3 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:05: resource 0 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:05: resource 1 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:05: resource 2 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:05: resource 3 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:06: resource 0 io:  [0x1000-0x1fff]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:06: resource 1 mem: [0x50000000-0x500fffff]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:06: resource 2 mem: [0x0-0x0]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:06: resource 3 io:  [0x00-0xffff]
Nov  3 21:51:55 TOWER kernel: pci_bus 0000:06: resource 4 mem: [0x000000-0xffffffffffffffff]
Nov  3 21:51:55 TOWER kernel: NET: Registered protocol family 2
Nov  3 21:51:55 TOWER kernel: IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
Nov  3 21:51:55 TOWER kernel: TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
Nov  3 21:51:55 TOWER kernel: TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
Nov  3 21:51:55 TOWER kernel: TCP: Hash tables configured (established 131072 bind 65536)
Nov  3 21:51:55 TOWER kernel: TCP reno registered
Nov  3 21:51:55 TOWER kernel: Unpacking initramfs... done
Nov  3 21:51:55 TOWER kernel: Freeing initrd memory: 46212k freed
Nov  3 21:51:55 TOWER kernel: Machine check exception polling timer started.
Nov  3 21:51:55 TOWER kernel: highmem bounce pool size: 64 pages
Nov  3 21:51:55 TOWER kernel: Installing knfsd (copyright © 1996 [email protected]).
Nov  3 21:51:55 TOWER kernel: fuse init (API version 7.11)
Nov  3 21:51:55 TOWER kernel: io scheduler noop registered (default)
Nov  3 21:51:55 TOWER kernel: io scheduler anticipatory registered
Nov  3 21:51:55 TOWER kernel: io scheduler deadline registered
Nov  3 21:51:55 TOWER kernel: io scheduler cfq registered
Nov  3 21:51:55 TOWER kernel: pci 0000:00:02.0: Boot video device
Nov  3 21:51:55 TOWER kernel: pcieport-driver 0000:00:1c.0: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: pcieport-driver 0000:00:1c.0: irq 24 for MSI/MSI-X
Nov  3 21:51:55 TOWER kernel: pcieport-driver 0000:00:1c.2: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: pcieport-driver 0000:00:1c.2: irq 25 for MSI/MSI-X
Nov  3 21:51:55 TOWER kernel: pcieport-driver 0000:00:1c.3: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: pcieport-driver 0000:00:1c.3: irq 26 for MSI/MSI-X
Nov  3 21:51:55 TOWER kernel: pcieport-driver 0000:00:1c.4: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: pcieport-driver 0000:00:1c.4: irq 27 for MSI/MSI-X
Nov  3 21:51:55 TOWER kernel: pcieport-driver 0000:00:1c.5: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: pcieport-driver 0000:00:1c.5: irq 28 for MSI/MSI-X
Nov  3 21:51:55 TOWER kernel: input: Power Button (FF) as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
Nov  3 21:51:55 TOWER kernel: ACPI: Power Button (FF) [PWRF]
Nov  3 21:51:55 TOWER kernel: input: Sleep Button (CM) as /devices/LNXSYSTM:00/device:00/PNP0C0E:00/input/input1
Nov  3 21:51:55 TOWER kernel: ACPI: Sleep Button (CM) [sLPB]
Nov  3 21:51:55 TOWER kernel: processor ACPI_CPU:00: registered as cooling_device0
Nov  3 21:51:55 TOWER kernel: lp: driver loaded but no devices found
Nov  3 21:51:55 TOWER kernel: Real Time Clock Driver v1.12b
Nov  3 21:51:55 TOWER kernel: intel_rng: Firmware space is locked read-only. If you can't or
Nov  3 21:51:55 TOWER kernel: intel_rng: don't want to disable this in firmware setup, and if
Nov  3 21:51:55 TOWER kernel: intel_rng: you are certain that your system has a functional
Nov  3 21:51:55 TOWER kernel: intel_rng: RNG, try using the 'no_fwh_detect' option.
Nov  3 21:51:55 TOWER kernel: Hangcheck: starting hangcheck timer 0.9.0 (tick is 180 seconds, margin is 60 seconds).
Nov  3 21:51:55 TOWER kernel: Hangcheck: Using get_cycles().
Nov  3 21:51:55 TOWER kernel: Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
Nov  3 21:51:55 TOWER kernel: floppy0: no floppy controllers found
Nov  3 21:51:55 TOWER kernel: loop: module loaded
Nov  3 21:51:55 TOWER kernel: Driver 'sd' needs updating - please use bus_type methods
Nov  3 21:51:55 TOWER kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Nov  3 21:51:55 TOWER kernel: ehci_hcd 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
Nov  3 21:51:55 TOWER kernel: ehci_hcd 0000:00:1d.7: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: ehci_hcd 0000:00:1d.7: EHCI Host Controller
Nov  3 21:51:55 TOWER kernel: ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
Nov  3 21:51:55 TOWER kernel: ehci_hcd 0000:00:1d.7: debug port 1
Nov  3 21:51:55 TOWER kernel: ehci_hcd 0000:00:1d.7: cache line size of 128 is not supported
Nov  3 21:51:55 TOWER kernel: ehci_hcd 0000:00:1d.7: irq 23, io mem 0x502c0400
Nov  3 21:51:55 TOWER kernel: ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
Nov  3 21:51:55 TOWER kernel: usb usb1: configuration #1 chosen from 1 choice
Nov  3 21:51:55 TOWER kernel: hub 1-0:1.0: USB hub found
Nov  3 21:51:55 TOWER kernel: hub 1-0:1.0: 8 ports detected
Nov  3 21:51:55 TOWER kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
Nov  3 21:51:55 TOWER kernel: uhci_hcd: USB Universal Host Controller Interface driver
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.0: PCI INT A -> GSI 23 (level, low) -> IRQ 23
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.0: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.0: UHCI Host Controller
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.0: irq 23, io base 0x00003080
Nov  3 21:51:55 TOWER kernel: usb usb2: configuration #1 chosen from 1 choice
Nov  3 21:51:55 TOWER kernel: hub 2-0:1.0: USB hub found
Nov  3 21:51:55 TOWER kernel: hub 2-0:1.0: 2 ports detected
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.1: PCI INT B -> GSI 19 (level, low) -> IRQ 19
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.1: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.1: UHCI Host Controller
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.1: irq 19, io base 0x00003060
Nov  3 21:51:55 TOWER kernel: usb usb3: configuration #1 chosen from 1 choice
Nov  3 21:51:55 TOWER kernel: hub 3-0:1.0: USB hub found
Nov  3 21:51:55 TOWER kernel: hub 3-0:1.0: 2 ports detected
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.2: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.2: UHCI Host Controller
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.2: irq 18, io base 0x00003040
Nov  3 21:51:55 TOWER kernel: usb usb4: configuration #1 chosen from 1 choice
Nov  3 21:51:55 TOWER kernel: hub 4-0:1.0: USB hub found
Nov  3 21:51:55 TOWER kernel: hub 4-0:1.0: 2 ports detected
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.3: PCI INT D -> GSI 16 (level, low) -> IRQ 16
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.3: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.3: UHCI Host Controller
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
Nov  3 21:51:55 TOWER kernel: uhci_hcd 0000:00:1d.3: irq 16, io base 0x00003020
Nov  3 21:51:55 TOWER kernel: usb usb5: configuration #1 chosen from 1 choice
Nov  3 21:51:55 TOWER kernel: hub 5-0:1.0: USB hub found
Nov  3 21:51:55 TOWER kernel: hub 5-0:1.0: 2 ports detected
Nov  3 21:51:55 TOWER kernel: Initializing USB Mass Storage driver...
Nov  3 21:51:55 TOWER kernel: usbcore: registered new interface driver usb-storage
Nov  3 21:51:55 TOWER kernel: USB Mass Storage support registered.
Nov  3 21:51:55 TOWER kernel: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
Nov  3 21:51:55 TOWER kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Nov  3 21:51:55 TOWER kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Nov  3 21:51:55 TOWER kernel: mice: PS/2 mouse device common for all mice
Nov  3 21:51:55 TOWER kernel: input: PC Speaker as /devices/platform/pcspkr/input/input2
Nov  3 21:51:55 TOWER kernel: cpuidle: using governor ladder
Nov  3 21:51:55 TOWER kernel: usbcore: registered new interface driver hiddev
Nov  3 21:51:55 TOWER kernel: usbcore: registered new interface driver usbhid
Nov  3 21:51:55 TOWER kernel: usbhid: v2.6:USB HID core driver
Nov  3 21:51:55 TOWER kernel: TCP cubic registered
Nov  3 21:51:55 TOWER kernel: NET: Registered protocol family 17
Nov  3 21:51:55 TOWER kernel: RPC: Registered udp transport module.
Nov  3 21:51:55 TOWER kernel: RPC: Registered tcp transport module.
Nov  3 21:51:55 TOWER kernel: Using IPI No-Shortcut mode
Nov  3 21:51:55 TOWER kernel: Freeing unused kernel memory: 264k freed
Nov  3 21:51:55 TOWER kernel: input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
Nov  3 21:51:55 TOWER kernel: e1000e: Intel® PRO/1000 Network Driver - 0.3.3.3-k6
Nov  3 21:51:55 TOWER kernel: e1000e: Copyright © 1999-2008 Intel Corporation.
Nov  3 21:51:55 TOWER kernel: e1000e 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
Nov  3 21:51:55 TOWER kernel: e1000e 0000:01:00.0: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: e1000e 0000:01:00.0: irq 29 for MSI/MSI-X
Nov  3 21:51:55 TOWER kernel: e1000e 0000:01:00.0: Warning: detected DSPD enabled in EEPROM
Nov  3 21:51:55 TOWER kernel: hub 1-0:1.0: unable to enumerate USB device on port 4
Nov  3 21:51:55 TOWER kernel: 0000:01:00.0: eth0: (PCI Express:2.5GB/s:Width x1) 00:16:76:bb:3f:0e
Nov  3 21:51:55 TOWER kernel: 0000:01:00.0: eth0: Intel® PRO/1000 Network Connection
Nov  3 21:51:55 TOWER kernel: 0000:01:00.0: eth0: MAC: 2, PHY: 2, PBA No: ffffff-0ff
Nov  3 21:51:55 TOWER kernel: Uniform Multi-Platform E-IDE driver
Nov  3 21:51:55 TOWER kernel: pdc202xx_new 0000:06:00.0: IDE controller (0x105a:0x4d68 rev 0x02)
Nov  3 21:51:55 TOWER kernel: Promise_IDE 0000:06:00.0: PCI INT A -> GSI 21 (level, low) -> IRQ 21
Nov  3 21:51:55 TOWER kernel: pdc202xx_new 0000:06:00.0: PLL input clock is 16618 kHz
Nov  3 21:51:55 TOWER kernel: pdc202xx_new 0000:06:00.0: 100%% native mode on irq 21
Nov  3 21:51:55 TOWER kernel:    ide2: BM-DMA at 0x1000-0x1007
Nov  3 21:51:55 TOWER kernel:    ide3: BM-DMA at 0x1008-0x100f
Nov  3 21:51:55 TOWER kernel: Probing IDE interface ide2...
Nov  3 21:51:55 TOWER kernel: usb 1-4: new high speed USB device using ehci_hcd and address 3
Nov  3 21:51:55 TOWER kernel: hde: Maxtor 98196H8, ATA DISK drive
Nov  3 21:51:55 TOWER kernel: usb 1-4: configuration #1 chosen from 1 choice
Nov  3 21:51:55 TOWER kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Nov  3 21:51:55 TOWER kernel: usb-storage: device found at 3
Nov  3 21:51:55 TOWER kernel: usb-storage: waiting for device to settle before scanning
Nov  3 21:51:55 TOWER kernel: hdf: WDC WD3200AAJB-00J3A0, ATA DISK drive
Nov  3 21:51:55 TOWER kernel: hde: host max PIO4 wanted PIO255(auto-tune) selected PIO4
Nov  3 21:51:55 TOWER kernel: hde: UDMA/100 mode selected
Nov  3 21:51:55 TOWER kernel: hdf: host max PIO4 wanted PIO255(auto-tune) selected PIO4
Nov  3 21:51:55 TOWER kernel: hdf: UDMA/100 mode selected
Nov  3 21:51:55 TOWER kernel: Probing IDE interface ide3...
Nov  3 21:51:55 TOWER kernel: ide2 at 0x1018-0x101f,0x1026 on irq 21
Nov  3 21:51:55 TOWER kernel: ide3 at 0x1010-0x1017,0x1022 on irq 21
Nov  3 21:51:55 TOWER kernel: piix 0000:00:1f.1: IDE controller (0x8086:0x27df rev 0x01)
Nov  3 21:51:55 TOWER kernel: PIIX_IDE 0000:00:1f.1: PCI INT A -> GSI 18 (level, low) -> IRQ 18
Nov  3 21:51:55 TOWER kernel: piix 0000:00:1f.1: IDE port disabled
Nov  3 21:51:55 TOWER kernel: piix 0000:00:1f.1: not 100%% native mode: will probe irqs later
Nov  3 21:51:55 TOWER kernel:    ide0: BM-DMA at 0x30b0-0x30b7
Nov  3 21:51:55 TOWER kernel: Probing IDE interface ide0...
Nov  3 21:51:55 TOWER kernel: hda: WDC WD3200AAJB-00J3A0, ATA DISK drive
Nov  3 21:51:55 TOWER kernel: hdb: HDS725050KLAT80, ATA DISK drive
Nov  3 21:51:55 TOWER kernel: hda: host max PIO4 wanted PIO255(auto-tune) selected PIO4
Nov  3 21:51:55 TOWER kernel: hda: UDMA/100 mode selected
Nov  3 21:51:55 TOWER kernel: hdb: host max PIO4 wanted PIO255(auto-tune) selected PIO4
Nov  3 21:51:55 TOWER kernel: hdb: UDMA/100 mode selected
Nov  3 21:51:55 TOWER kernel: ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Nov  3 21:51:55 TOWER kernel: libata version 3.00 loaded.
Nov  3 21:51:55 TOWER kernel: ahci 0000:00:1f.2: version 3.0
Nov  3 21:51:55 TOWER kernel: ahci 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
Nov  3 21:51:55 TOWER kernel: ahci 0000:00:1f.2: irq 30 for MSI/MSI-X
Nov  3 21:51:55 TOWER kernel: ahci 0000:00:1f.2: AHCI 0001.0100 32 slots 4 ports 3 Gbps 0xf impl SATA mode
Nov  3 21:51:55 TOWER kernel: ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part
Nov  3 21:51:55 TOWER kernel: ahci 0000:00:1f.2: setting latency timer to 64
Nov  3 21:51:55 TOWER kernel: scsi1 : ahci
Nov  3 21:51:55 TOWER kernel: scsi2 : ahci
Nov  3 21:51:55 TOWER kernel: scsi3 : ahci
Nov  3 21:51:55 TOWER kernel: scsi4 : ahci
Nov  3 21:51:55 TOWER kernel: ata1: SATA max UDMA/133 abar m1024@0x502c0000 port 0x502c0100 irq 30
Nov  3 21:51:55 TOWER kernel: ata2: SATA max UDMA/133 abar m1024@0x502c0000 port 0x502c0180 irq 30
Nov  3 21:51:55 TOWER kernel: ata3: SATA max UDMA/133 abar m1024@0x502c0000 port 0x502c0200 irq 30
Nov  3 21:51:55 TOWER kernel: ata4: SATA max UDMA/133 abar m1024@0x502c0000 port 0x502c0280 irq 30
Nov  3 21:51:55 TOWER kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Nov  3 21:51:55 TOWER kernel: ata1.00: ATA-7: ST3250620AS, 3.AAC, max UDMA/133
Nov  3 21:51:55 TOWER kernel: ata1.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 31/32)
Nov  3 21:51:55 TOWER kernel: ata1.00: configured for UDMA/133
Nov  3 21:51:55 TOWER kernel: scsi 1:0:0:0: Direct-Access    ATA      ST3250620AS      3.AA PQ: 0 ANSI: 5
Nov  3 21:51:55 TOWER kernel: sd 1:0:0:0: [sda] 488397168 512-byte hardware sectors: (250 GB/232 GiB)
Nov  3 21:51:55 TOWER kernel: sd 1:0:0:0: [sda] Write Protect is off
Nov  3 21:51:55 TOWER kernel: sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
Nov  3 21:51:55 TOWER kernel: sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Nov  3 21:51:55 TOWER kernel:  sda: sda1
Nov  3 21:51:55 TOWER kernel: sd 1:0:0:0: [sda] Attached SCSI disk
Nov  3 21:51:55 TOWER kernel: ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Nov  3 21:51:55 TOWER kernel: ata2.00: ATA-8: ST31000340AS, SD15, max UDMA/133
Nov  3 21:51:55 TOWER kernel: ata2.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32)
Nov  3 21:51:55 TOWER kernel: ata2.00: configured for UDMA/133
Nov  3 21:51:55 TOWER kernel: scsi 2:0:0:0: Direct-Access    ATA      ST31000340AS    SD15 PQ: 0 ANSI: 5
Nov  3 21:51:55 TOWER kernel: sd 2:0:0:0: [sdb] 1953525168 512-byte hardware sectors: (1.00 TB/931 GiB)
Nov  3 21:51:55 TOWER kernel: sd 2:0:0:0: [sdb] Write Protect is off
Nov  3 21:51:55 TOWER kernel: sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Nov  3 21:51:55 TOWER kernel: sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Nov  3 21:51:55 TOWER kernel:  sdb: sdb1
Nov  3 21:51:55 TOWER kernel: sd 2:0:0:0: [sdb] Attached SCSI disk
Nov  3 21:51:55 TOWER kernel: ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Nov  3 21:51:55 TOWER kernel: ata3.00: ATA-7: ST3320620AS, 3.AAK, max UDMA/133
Nov  3 21:51:55 TOWER kernel: ata3.00: 625142448 sectors, multi 16: LBA48 NCQ (depth 31/32)
Nov  3 21:51:55 TOWER kernel: ata3.00: configured for UDMA/133
Nov  3 21:51:55 TOWER kernel: scsi 3:0:0:0: Direct-Access    ATA      ST3320620AS      3.AA PQ: 0 ANSI: 5
Nov  3 21:51:55 TOWER kernel: sd 3:0:0:0: [sdc] 625142448 512-byte hardware sectors: (320 GB/298 GiB)
Nov  3 21:51:55 TOWER kernel: sd 3:0:0:0: [sdc] Write Protect is off
Nov  3 21:51:55 TOWER kernel: sd 3:0:0:0: [sdc] Mode Sense: 00 3a 00 00
Nov  3 21:51:55 TOWER kernel: sd 3:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Nov  3 21:51:55 TOWER kernel:  sdc: sdc1
Nov  3 21:51:55 TOWER kernel: sd 3:0:0:0: [sdc] Attached SCSI disk
Nov  3 21:51:55 TOWER kernel: ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Nov  3 21:51:55 TOWER kernel: ata4.00: ATA-7: ST3250410AS, 3.AAA, max UDMA/133
Nov  3 21:51:55 TOWER kernel: ata4.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 31/32)
Nov  3 21:51:55 TOWER kernel: ata4.00: configured for UDMA/133
Nov  3 21:51:55 TOWER kernel: scsi 4:0:0:0: Direct-Access    ATA      ST3250410AS      3.AA PQ: 0 ANSI: 5
Nov  3 21:51:55 TOWER kernel: sd 4:0:0:0: [sdd] 488397168 512-byte hardware sectors: (250 GB/232 GiB)
Nov  3 21:51:55 TOWER kernel: sd 4:0:0:0: [sdd] Write Protect is off
Nov  3 21:51:55 TOWER kernel: sd 4:0:0:0: [sdd] Mode Sense: 00 3a 00 00
Nov  3 21:51:55 TOWER kernel: sd 4:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Nov  3 21:51:55 TOWER kernel:  sdd: sdd1
Nov  3 21:51:55 TOWER kernel: sd 4:0:0:0: [sdd] Attached SCSI disk
Nov  3 21:51:55 TOWER kernel: ide-gd driver 1.18
Nov  3 21:51:55 TOWER kernel: hde: max request size: 128KiB
Nov  3 21:51:55 TOWER kernel: hde: Host Protected Area detected.
Nov  3 21:51:55 TOWER kernel: ^Icurrent capacity is 156250000 sectors (80000 MB)
Nov  3 21:51:55 TOWER kernel: ^Inative  capacity is 160086528 sectors (81964 MB)
Nov  3 21:51:55 TOWER kernel: hde: Host Protected Area disabled.
Nov  3 21:51:55 TOWER kernel: hde: 160086528 sectors (81964 MB) w/2048KiB Cache, CHS=65535/16/63
Nov  3 21:51:55 TOWER kernel: hde: cache flushes not supported
Nov  3 21:51:55 TOWER kernel:  hde: hde1
Nov  3 21:51:55 TOWER kernel: hdf: max request size: 512KiB
Nov  3 21:51:55 TOWER kernel: hdf: 625142448 sectors (320072 MB) w/8192KiB Cache, CHS=38913/255/63
Nov  3 21:51:55 TOWER kernel: hdf: cache flushes supported
Nov  3 21:51:55 TOWER kernel:  hdf: hdf1
Nov  3 21:51:55 TOWER kernel: hda: max request size: 512KiB
Nov  3 21:51:55 TOWER kernel: hda: 625142448 sectors (320072 MB) w/8192KiB Cache, CHS=38913/255/63
Nov  3 21:51:55 TOWER kernel: hda: cache flushes supported
Nov  3 21:51:55 TOWER kernel:  hda: hda1
Nov  3 21:51:55 TOWER kernel: hdb: max request size: 512KiB
Nov  3 21:51:55 TOWER kernel: hdb: 976773168 sectors (500107 MB) w/7663KiB Cache, CHS=60801/255/63
Nov  3 21:51:55 TOWER kernel: hdb: cache flushes supported
Nov  3 21:51:55 TOWER kernel:  hdb: hdb1
Nov  3 21:51:55 TOWER kernel: scsi 0:0:0:0: Direct-Access    LEXAR    JD FIREFLY      3000 PQ: 0 ANSI: 0 CCS
Nov  3 21:51:55 TOWER kernel: sd 0:0:0:0: [sde] 506880 512-byte hardware sectors: (259 MB/247 MiB)
Nov  3 21:51:55 TOWER kernel: sd 0:0:0:0: [sde] Write Protect is off
Nov  3 21:51:55 TOWER kernel: sd 0:0:0:0: [sde] Mode Sense: 43 00 00 00
Nov  3 21:51:55 TOWER kernel: sd 0:0:0:0: [sde] Assuming drive cache: write through
Nov  3 21:51:55 TOWER kernel:  sde: sde1
Nov  3 21:51:55 TOWER kernel: sd 0:0:0:0: [sde] Attached SCSI removable disk
Nov  3 21:51:55 TOWER kernel: usb-storage: device scan complete
Nov  3 21:51:55 TOWER logger: /etc/rc.d/rc.inet1:  /sbin/ifconfig lo 127.0.0.1
Nov  3 21:51:55 TOWER logger: /etc/rc.d/rc.inet1:  /sbin/route add -net 127.0.0.0 netmask 255.0.0.0 lo
Nov  3 21:51:55 TOWER ifplugd(eth0)[1207]: ifplugd 0.28 initializing.
Nov  3 21:51:55 TOWER ifplugd(eth0)[1207]: Using interface eth0/00:16:76:BB:3F:0E with driver <e1000e> (version: 0.3.3.3-k6)
Nov  3 21:51:55 TOWER ifplugd(eth0)[1207]: Using detection mode: SIOCETHTOOL
Nov  3 21:51:55 TOWER ifplugd(eth0)[1207]: Initialization complete, link beat not detected.
Nov  3 21:51:55 TOWER rpc.statd[1219]: Version 1.1.4 Starting
Nov  3 21:51:55 TOWER emhttp: unRAID System Management Utility version 4.5-beta6
Nov  3 21:51:55 TOWER emhttp: Copyright © 2005-2009, Lime Technology, LLC
Nov  3 21:51:55 TOWER emhttp: Pro key detected, GUID: 05DC-A560-7804-014335100606
Nov  3 21:51:55 TOWER emhttp: shcmd (1): cp /boot/config/passwd /etc
Nov  3 21:51:55 TOWER emhttp: shcmd (2): cp /boot/config/smbpasswd /etc/samba/private
Nov  3 21:51:55 TOWER emhttp: Device inventory:
Nov  3 21:51:55 TOWER emhttp: pci-0000:00:1f.1-ide-0:0 (hda) ata-WDC_WD3200AAJB-00J3A0_WD-WCAV20888325
Nov  3 21:51:55 TOWER emhttp: pci-0000:00:1f.1-ide-0:1 (hdb) ata-HDS725050KLAT80_KRVA45ZAHASZ5F
Nov  3 21:51:55 TOWER emhttp: pci-0000:00:1f.2-scsi-0:0:0:0 (sda) ata-ST3250620AS_5QF0GSQE
Nov  3 21:51:55 TOWER emhttp: pci-0000:00:1f.2-scsi-1:0:0:0 (sdb) ata-ST31000340AS_9QJ1NPMX
Nov  3 21:51:55 TOWER emhttp: pci-0000:00:1f.2-scsi-2:0:0:0 (sdc) ata-ST3320620AS_6QF07N6Z
Nov  3 21:51:55 TOWER emhttp: pci-0000:00:1f.2-scsi-3:0:0:0 (sdd) ata-ST3250410AS_6RY038L1
Nov  3 21:51:55 TOWER emhttp: pci-0000:06:00.0-ide-0:0 (hde) ata-Maxtor_98196H8_V80MHNYC
Nov  3 21:51:55 TOWER emhttp: pci-0000:06:00.0-ide-0:1 (hdf) ata-WDC_WD3200AAJB-00J3A0_WD-WCAV20885312
Nov  3 21:51:55 TOWER emhttp: shcmd (3): rmmod md-mod >>/var/log/go 2>&1
Nov  3 21:51:55 TOWER emhttp: _shcmd: shcmd (3): exit status: 1
Nov  3 21:51:55 TOWER emhttp: shcmd (4): modprobe md-mod super=/boot/config/super.dat slots=8,16,3,0,33,64,33,0,8,0,8,32,8,48,3,64,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0 >>/var/log/go 2>&1
Nov  3 21:51:56 TOWER kernel: md: unRAID driver 0.95.2 installed
Nov  3 21:51:56 TOWER kernel: md: xor using function: pIII_sse (4007.200 MB/sec)
Nov  3 21:51:56 TOWER kernel: md: import disk0: [8,16] (sdb) ST31000340AS                                        9QJ1NPMX offset: 63 size: 976762552
Nov  3 21:51:56 TOWER kernel: md: import disk1: [3,0] (hda) WDC WD3200AAJB-00J3A0 WD-WCAV20888325 offset: 63 size: 312571192
Nov  3 21:51:56 TOWER kernel: md: import disk2: [33,64] (hdf) WDC WD3200AAJB-00J3A0 WD-WCAV20885312 offset: 63 size: 312571192
Nov  3 21:51:56 TOWER kernel: md: import disk3: [33,0] (hde) Maxtor 98196H8 V80MHNYC offset: 63 size: 80043232
Nov  3 21:51:56 TOWER kernel: md: import disk4: [8,0] (sda) ST3250620AS                                          5QF0GSQE offset: 63 size: 244198552
Nov  3 21:51:56 TOWER kernel: md: import disk5: [8,32] (sdc) ST3320620AS                                          6QF07N6Z offset: 63 size: 312571192
Nov  3 21:51:56 TOWER kernel: md: import disk6: [8,48] (sdd) ST3250410AS                                          6RY038L1 offset: 63 size: 244198552
Nov  3 21:51:56 TOWER kernel: md: import disk7: [3,64] (hdb) HDS725050KLAT80 KRVA45ZAHASZ5F offset: 63 size: 488386552
Nov  3 21:51:56 TOWER emhttp: shcmd (5): rm /etc/samba/smb-shares.conf >/dev/null 2>&1
Nov  3 21:51:56 TOWER emhttp: _shcmd: shcmd (5): exit status: 1
Nov  3 21:51:56 TOWER emhttp: shcmd (6): cp /etc/exports- /etc/exports
Nov  3 21:51:56 TOWER emhttp: shcmd (7): killall -HUP smbd
Nov  3 21:51:56 TOWER emhttp: shcmd (8): /etc/rc.d/rc.nfsd restart | logger
Nov  3 21:51:57 TOWER ifplugd(eth0)[1207]: Link beat detected.
Nov  3 21:51:57 TOWER kernel: e1000e: eth0 NIC Link is Up 100 Mbps Half Duplex, Flow Control: None
Nov  3 21:51:57 TOWER kernel: 0000:01:00.0: eth0: 10/100 speed: disabling TSO
Nov  3 21:51:58 TOWER kernel: md: import disk0: [8,16] (sdb) ST31000340AS                                        9QJ1NPMX offset: 63 size: 976762552
Nov  3 21:51:58 TOWER kernel: md: import disk1: [3,0] (hda) WDC WD3200AAJB-00J3A0 WD-WCAV20888325 offset: 63 size: 312571192
Nov  3 21:51:58 TOWER kernel: md: import disk2: [33,64] (hdf) WDC WD3200AAJB-00J3A0 WD-WCAV20885312 offset: 63 size: 312571192
Nov  3 21:51:58 TOWER kernel: md: import disk3: [33,0] (hde) Maxtor 98196H8 V80MHNYC offset: 63 size: 80043232
Nov  3 21:51:58 TOWER kernel: md: import disk4: [8,0] (sda) ST3250620AS                                          5QF0GSQE offset: 63 size: 244198552
Nov  3 21:51:58 TOWER kernel: md: import disk5: [8,32] (sdc) ST3320620AS                                          6QF07N6Z offset: 63 size: 312571192
Nov  3 21:51:58 TOWER kernel: md: import disk6: [8,48] (sdd) ST3250410AS                                          6RY038L1 offset: 63 size: 244198552
Nov  3 21:51:58 TOWER kernel: md: import disk7: [3,64] (hdb) HDS725050KLAT80 KRVA45ZAHASZ5F offset: 63 size: 488386552
Nov  3 21:51:58 TOWER ifplugd(eth0)[1207]: Executing '/etc/ifplugd/ifplugd.action eth0 up'.
Nov  3 21:51:58 TOWER logger: /etc/rc.d/rc.inet1:  /sbin/ifconfig eth0 hw ether 00:16:76:BB:3F:0E
Nov  3 21:51:58 TOWER logger: /etc/rc.d/rc.inet1:  /sbin/ifconfig eth0 10.20.1.2 broadcast 10.20.1.255 netmask 255.255.255.0
Nov  3 21:51:58 TOWER ifplugd(eth0)[1207]: Program executed successfully.
Nov  3 21:51:58 TOWER emhttp: shcmd (9): /usr/local/sbin/set_ncq sdb 1 | logger
Nov  3 21:51:58 TOWER logger: set_ncq: setting sdb queue_depth to 1
Nov  3 21:51:58 TOWER emhttp: shcmd (10): /usr/local/sbin/set_ncq hda 1 | logger
Nov  3 21:51:58 TOWER emhttp: shcmd (11): /usr/local/sbin/set_ncq hdf 1 | logger
Nov  3 21:51:58 TOWER emhttp: shcmd (12): /usr/local/sbin/set_ncq hde 1 | logger
Nov  3 21:51:58 TOWER emhttp: shcmd (13): /usr/local/sbin/set_ncq sda 1 | logger
Nov  3 21:51:58 TOWER logger: set_ncq: setting sda queue_depth to 1
Nov  3 21:51:58 TOWER emhttp: shcmd (14): /usr/local/sbin/set_ncq sdc 1 | logger
Nov  3 21:51:58 TOWER logger: set_ncq: setting sdc queue_depth to 1
Nov  3 21:51:58 TOWER emhttp: shcmd (15): /usr/local/sbin/set_ncq sdd 1 | logger
Nov  3 21:51:58 TOWER logger: set_ncq: setting sdd queue_depth to 1
Nov  3 21:51:58 TOWER emhttp: shcmd (16): /usr/local/sbin/set_ncq hdb 1 | logger
Nov  3 21:51:58 TOWER kernel: mdcmd (3): start
Nov  3 21:51:58 TOWER kernel: unraid: allocated 17528kB
Nov  3 21:51:58 TOWER kernel: md1: running, size: 312571192 blocks
Nov  3 21:51:58 TOWER kernel: md2: running, size: 312571192 blocks
Nov  3 21:51:58 TOWER kernel: md3: running, size: 80043232 blocks
Nov  3 21:51:58 TOWER kernel: md4: running, size: 244198552 blocks
Nov  3 21:51:58 TOWER kernel: md5: running, size: 312571192 blocks
Nov  3 21:51:58 TOWER kernel: md6: running, size: 244198552 blocks
Nov  3 21:51:58 TOWER kernel: md7: running, size: 488386552 blocks
Nov  3 21:51:59 TOWER emhttp: shcmd (17): mkdir /mnt/disk1
Nov  3 21:51:59 TOWER emhttp: shcmd (18): mount -t reiserfs -o noacl,nouser_xattr,noatime,nodiratime /dev/md1 /mnt/disk1  >/dev/null 2>&1
Nov  3 21:51:59 TOWER kernel: mdcmd (5): check
Nov  3 21:51:59 TOWER kernel: md: recovery thread woken up ...
Nov  3 21:51:59 TOWER kernel: md: recovery thread checking parity...
Nov  3 21:51:59 TOWER emhttp: shcmd (18): mkdir /mnt/disk2
Nov  3 21:51:59 TOWER emhttp: shcmd (19): mount -t reiserfs -o noacl,nouser_xattr,noatime,nodiratime /dev/md2 /mnt/disk2  >/dev/null 2>&1
Nov  3 21:51:59 TOWER emhttp: shcmd (19): mkdir /mnt/disk3
Nov  3 21:51:59 TOWER emhttp: shcmd (20): mount -t reiserfs -o noacl,nouser_xattr,noatime,nodiratime /dev/md3 /mnt/disk3  >/dev/null 2>&1
Nov  3 21:51:59 TOWER emhttp: shcmd (20): mkdir /mnt/disk4
Nov  3 21:51:59 TOWER emhttp: shcmd (21): mount -t reiserfs -o noacl,nouser_xattr,noatime,nodiratime /dev/md4 /mnt/disk4  >/dev/null 2>&1
Nov  3 21:51:59 TOWER emhttp: shcmd (21): mkdir /mnt/disk5
Nov  3 21:51:59 TOWER emhttp: shcmd (22): mount -t reiserfs -o noacl,nouser_xattr,noatime,nodiratime /dev/md5 /mnt/disk5  >/dev/null 2>&1
Nov  3 21:51:59 TOWER kernel: md: using 1152k window, over a total of 976762552 blocks.
Nov  3 21:51:59 TOWER emhttp: shcmd (22): mkdir /mnt/disk6
Nov  3 21:51:59 TOWER emhttp: shcmd (23): mount -t reiserfs -o noacl,nouser_xattr,noatime,nodiratime /dev/md6 /mnt/disk6  >/dev/null 2>&1
Nov  3 21:51:59 TOWER emhttp: shcmd (23): mkdir /mnt/disk7
Nov  3 21:51:59 TOWER emhttp: shcmd (24): mount -t reiserfs -o noacl,nouser_xattr,noatime,nodiratime /dev/md7 /mnt/disk7  >/dev/null 2>&1
Nov  3 21:51:59 TOWER kernel: ReiserFS: md4: found reiserfs format "3.6" with standard journal
Nov  3 21:51:59 TOWER kernel: ReiserFS: md4: using ordered data mode
Nov  3 21:51:59 TOWER kernel: ReiserFS: md1: found reiserfs format "3.6" with standard journal
Nov  3 21:51:59 TOWER kernel: ReiserFS: md1: using ordered data mode
Nov  3 21:51:59 TOWER kernel: ReiserFS: md3: found reiserfs format "3.6" with standard journal
Nov  3 21:51:59 TOWER kernel: ReiserFS: md3: using ordered data mode
Nov  3 21:51:59 TOWER kernel: ReiserFS: md4: journal params: device md4, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
Nov  3 21:51:59 TOWER kernel: ReiserFS: md4: checking transaction log (md4)
Nov  3 21:51:59 TOWER kernel: ReiserFS: md5: found reiserfs format "3.6" with standard journal
Nov  3 21:51:59 TOWER kernel: ReiserFS: md5: using ordered data mode
Nov  3 21:51:59 TOWER kernel: ReiserFS: md6: found reiserfs format "3.6" with standard journal
Nov  3 21:51:59 TOWER kernel: ReiserFS: md6: using ordered data mode
Nov  3 21:51:59 TOWER kernel: ReiserFS: md7: found reiserfs format "3.6" with standard journal
Nov  3 21:51:59 TOWER kernel: ReiserFS: md7: using ordered data mode
Nov  3 21:51:59 TOWER kernel: ReiserFS: md2: found reiserfs format "3.6" with standard journal
Nov  3 21:51:59 TOWER kernel: ReiserFS: md2: using ordered data mode
Nov  3 21:51:59 TOWER kernel: ReiserFS: md5: journal params: device md5, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
Nov  3 21:51:59 TOWER kernel: ReiserFS: md5: checking transaction log (md5)
Nov  3 21:51:59 TOWER kernel: ReiserFS: md1: journal params: device md1, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
Nov  3 21:51:59 TOWER kernel: ReiserFS: md1: checking transaction log (md1)
Nov  3 21:51:59 TOWER kernel: ReiserFS: md3: journal params: device md3, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
Nov  3 21:51:59 TOWER kernel: ReiserFS: md3: checking transaction log (md3)
Nov  3 21:51:59 TOWER kernel: ReiserFS: md2: journal params: device md2, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
Nov  3 21:51:59 TOWER kernel: ReiserFS: md2: checking transaction log (md2)
Nov  3 21:51:59 TOWER kernel: ReiserFS: md6: journal params: device md6, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
Nov  3 21:51:59 TOWER kernel: ReiserFS: md6: checking transaction log (md6)
Nov  3 21:51:59 TOWER kernel: ReiserFS: md7: journal params: device md7, size 8192, journal first block 18, max trans len 1024, max batch 900, max commit age 30, max trans age 30
Nov  3 21:51:59 TOWER kernel: ReiserFS: md7: checking transaction log (md7)
Nov  3 21:51:59 TOWER emhttp: shcmd (24): cp /var/spool/cron/crontabs/root- /var/spool/cron/crontabs/root
Nov  3 21:51:59 TOWER emhttp: shcmd (25): echo '# Generated mover schedule:' >>/var/spool/cron/crontabs/root
Nov  3 21:51:59 TOWER emhttp: shcmd (26): echo '40 3 * * * /usr/local/sbin/mover 2>&1 | logger' >>/var/spool/cron/crontabs/root
Nov  3 21:51:59 TOWER emhttp: shcmd (27): crontab /var/spool/cron/crontabs/root
Nov  3 21:52:19 TOWER kernel: ReiserFS: md2: replayed 24 transactions in 20 seconds
Nov  3 21:52:20 TOWER kernel: ReiserFS: md2: Using r5 hash to sort names
Nov  3 21:52:23 TOWER kernel: can't shrink filesystem on-line
Nov  3 21:53:06 TOWER kernel: ReiserFS: md1: replayed 91 transactions in 67 seconds
Nov  3 21:53:06 TOWER kernel: ReiserFS: md1: Using r5 hash to sort names
Nov  3 21:53:09 TOWER kernel: can't shrink filesystem on-line
Nov  3 21:53:29 TOWER kernel: ReiserFS: md4: replayed 219 transactions in 90 seconds
Nov  3 21:53:29 TOWER kernel: ReiserFS: md4: Using r5 hash to sort names
Nov  3 21:53:29 TOWER kernel: can't shrink filesystem on-line
Nov  3 21:54:07 TOWER kernel: ReiserFS: md5: replayed 135 transactions in 128 seconds
Nov  3 21:54:07 TOWER kernel: ReiserFS: md5: Using r5 hash to sort names
Nov  3 21:54:07 TOWER kernel: ReiserFS: md5: Removing [984218 984254 0x0 SD]..done
Nov  3 21:54:07 TOWER kernel: ReiserFS: md5: Removing [979522 984218 0x0 SD]..done
Nov  3 21:54:07 TOWER kernel: ReiserFS: md5: Removing [959275 979522 0x0 SD]..done
Nov  3 21:54:07 TOWER kernel: ReiserFS: md5: Removing [959271 959275 0x0 SD]..done
Nov  3 21:54:07 TOWER kernel: ReiserFS: md5: Removing [959270 959271 0x0 SD]..done
Nov  3 21:54:07 TOWER kernel: ReiserFS: md5: Removing [58905 959270 0x0 SD]..done
Nov  3 21:54:07 TOWER kernel: ReiserFS: md5: There were 6 uncompleted unlinks/truncates. Completed
Nov  3 21:54:08 TOWER kernel: can't shrink filesystem on-line
Nov  3 21:55:30 TOWER kernel: ReiserFS: md6: replayed 1862 transactions in 211 seconds
Nov  3 21:55:30 TOWER kernel: ReiserFS: md6: Using r5 hash to sort names
Nov  3 21:55:31 TOWER kernel: can't shrink filesystem on-line
Nov  3 21:55:46 TOWER kernel: ReiserFS: md7: replayed 578 transactions in 227 seconds
Nov  3 21:55:46 TOWER kernel: ReiserFS: md7: Using r5 hash to sort names
Nov  3 21:55:47 TOWER kernel: can't shrink filesystem on-line
Nov  3 21:59:54 TOWER kernel: ReiserFS: md3: replayed 773 transactions in 475 seconds
Nov  3 21:59:54 TOWER kernel: ReiserFS: md3: Using r5 hash to sort names
Nov  3 21:59:55 TOWER kernel: can't shrink filesystem on-line
Nov  3 21:59:55 TOWER emhttp: shcmd (35): rm /etc/samba/smb-shares.conf >/dev/null 2>&1
Nov  3 21:59:56 TOWER emhttp: shcmd (36): cp /etc/exports- /etc/exports
Nov  3 21:59:56 TOWER emhttp: shcmd (37): echo \"/mnt/disk1\" '-async,no_subtree_check,anongid=0,anonuid=0,all_squash' '*(rw,no_root_squash)' >>/etc/exports
Nov  3 21:59:56 TOWER emhttp: shcmd (38): echo \"/mnt/disk2\" '-async,no_subtree_check,anongid=0,anonuid=0,all_squash' '*(rw,no_root_squash)' >>/etc/exports
Nov  3 21:59:56 TOWER emhttp: shcmd (39): echo \"/mnt/disk3\" '-async,no_subtree_check,anongid=0,anonuid=0,all_squash' '*(rw,no_root_squash)' >>/etc/exports
Nov  3 21:59:56 TOWER emhttp: shcmd (40): echo \"/mnt/disk4\" '-async,no_subtree_check,anongid=0,anonuid=0,all_squash' '*(rw,no_root_squash)' >>/etc/exports
Nov  3 21:59:56 TOWER emhttp: shcmd (41): echo \"/mnt/disk5\" '-async,no_subtree_check,anongid=0,anonuid=0,all_squash' '*(rw,no_root_squash)' >>/etc/exports
Nov  3 21:59:56 TOWER emhttp: shcmd (42): echo \"/mnt/disk6\" '-async,no_subtree_check,anongid=0,anonuid=0,all_squash' '*(rw,no_root_squash)' >>/etc/exports
Nov  3 21:59:56 TOWER emhttp: shcmd (43): echo \"/mnt/disk7\" '-async,no_subtree_check,anongid=0,anonuid=0,all_squash' '*(rw,no_root_squash)' >>/etc/exports
Nov  3 21:59:56 TOWER emhttp: shcmd (44): mkdir /mnt/user
Nov  3 21:59:56 TOWER emhttp: shcmd (45): /usr/local/sbin/shfs  /mnt/user -o allow_other,attr_timeout=0,entry_timeout=0,negative_timeout=0
Nov  3 21:59:57 TOWER shfs0: duplicate object: /mnt/disk2/./._.TemporaryItems
Nov  3 21:59:57 TOWER shfs0: duplicate object: /mnt/disk2/./.DS_Store
Nov  3 21:59:57 TOWER shfs0: duplicate object: /mnt/disk3/./._.TemporaryItems
Nov  3 21:59:57 TOWER shfs0: duplicate object: /mnt/disk3/./.DS_Store
Nov  3 21:59:57 TOWER shfs0: duplicate object: /mnt/disk4/./._.TemporaryItems
Nov  3 21:59:57 TOWER shfs0: duplicate object: /mnt/disk4/./.DS_Store
Nov  3 21:59:57 TOWER shfs0: duplicate object: /mnt/disk5/./._.TemporaryItems
Nov  3 21:59:57 TOWER shfs0: duplicate object: /mnt/disk5/./.DS_Store
Nov  3 21:59:57 TOWER emhttp: shcmd (46): echo \"/mnt/user/VM-1\" '-async,no_subtree_check,anongid=0,anonuid=0,all_squash,fsid=100' '*(rw,no_root_squash)' >>/etc/exports
Nov  3 21:59:57 TOWER emhttp: shcmd (47): killall -HUP smbd
Nov  3 21:59:57 TOWER emhttp: shcmd (48): /etc/rc.d/rc.nfsd restart | logger
Nov  3 21:59:59 TOWER logger: Starting NFS server daemons:
Nov  3 21:59:59 TOWER logger:  /usr/sbin/exportfs -r
Nov  3 21:59:59 TOWER logger:  /usr/sbin/rpc.nfsd 8
Nov  3 21:59:59 TOWER logger:  /usr/sbin/rpc.mountd
Nov  4 05:54:45 TOWER kernel: md: sync done. time=28966sec rate=33721K/sec
Nov  4 05:54:45 TOWER kernel: md: recovery thread sync completion status: 0
Nov  5 04:51:45 TOWER in.telnetd[4240]: connect from 10.20.1.50 (10.20.1.50)
Nov  5 04:51:47 TOWER login[4241]: ROOT LOGIN  on `pts/0' from `10.20.1.50'
Nov  5 05:00:42 TOWER in.telnetd[4279]: connect from 10.20.1.50 (10.20.1.50)
Nov  5 05:00:44 TOWER login[4280]: ROOT LOGIN  on `pts/0' from `10.20.1.50'
Nov 13 06:08:01 TOWER emhttp: shcmd (49): ln -sf /usr/share/zoneinfo/Etc/GMT+6 /etc/localtime-copied-from
Nov 13 06:08:01 TOWER emhttp: shcmd (50): cp /etc/localtime-copied-from /etc/localtime
Nov 13 06:08:01 TOWER emhttp: shcmd (51): /etc/rc.d/rc.ntpd stop >/dev/null 2>&1
Nov 13 06:08:01 TOWER emhttp: _shcmd: shcmd (51): exit status: 1
Nov 13 06:08:01 TOWER emhttp: shcmd (52): date -s '11/12/2009 5:30:29 AM' >/dev/null
Nov 12 05:30:29 TOWER emhttp: shcmd (53): hwclock --utc --systohc --noadjfile
Nov 12 05:30:39 TOWER emhttp: shcmd (54): ln -sf /usr/share/zoneinfo/Etc/GMT+6 /etc/localtime-copied-from
Nov 12 05:30:39 TOWER emhttp: shcmd (55): cp /etc/localtime-copied-from /etc/localtime
Nov 12 05:30:39 TOWER emhttp: shcmd (56): /etc/rc.d/rc.ntpd stop >/dev/null 2>&1
Nov 12 05:30:39 TOWER emhttp: _shcmd: shcmd (56): exit status: 1
Nov 12 05:30:39 TOWER emhttp: shcmd (57): date -s '11/12/2009 5:30:30 PM' >/dev/null
Nov 12 17:30:30 TOWER emhttp: shcmd (58): hwclock --utc --systohc --noadjfile
Nov 14 02:45:13 TOWER kernel: ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
Nov 14 02:45:13 TOWER kernel: ata2.00: irq_stat 0x40000001
Nov 14 02:45:13 TOWER kernel: ata2.00: cmd c8/00:10:27:f0:53/00:00:00:00:00/e0 tag 0 dma 8192 in
Nov 14 02:45:13 TOWER kernel:          res 51/40:00:33:f0:53/00:00:00:00:00/00 Emask 0x9 (media error)
Nov 14 02:45:13 TOWER kernel: ata2.00: status: { DRDY ERR }
Nov 14 02:45:13 TOWER kernel: ata2.00: error: { UNC }
Nov 14 02:45:14 TOWER kernel: ata2.00: configured for UDMA/133
Nov 14 02:45:14 TOWER kernel: ata2: EH complete
Nov 14 02:45:19 TOWER kernel: ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
Nov 14 02:45:19 TOWER kernel: ata2.00: irq_stat 0x40000001
Nov 14 02:45:19 TOWER kernel: ata2.00: cmd c8/00:10:27:f0:53/00:00:00:00:00/e0 tag 0 dma 8192 in
Nov 14 02:45:19 TOWER kernel:          res 51/40:00:35:f0:53/00:00:00:00:00/00 Emask 0x9 (media error)
Nov 14 02:45:19 TOWER kernel: ata2.00: status: { DRDY ERR }
Nov 14 02:45:19 TOWER kernel: ata2.00: error: { UNC }
Nov 14 02:45:19 TOWER kernel: ata2.00: configured for UDMA/133
Nov 14 02:45:19 TOWER kernel: ata2: EH complete
Nov 14 02:45:23 TOWER kernel: ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
Nov 14 02:45:23 TOWER kernel: ata2.00: irq_stat 0x40000001
Nov 14 02:45:23 TOWER kernel: ata2.00: cmd c8/00:10:27:f0:53/00:00:00:00:00/e0 tag 0 dma 8192 in
Nov 14 02:45:23 TOWER kernel:          res 51/40:00:34:f0:53/00:00:00:00:00/00 Emask 0x9 (media error)
Nov 14 02:45:23 TOWER kernel: ata2.00: status: { DRDY ERR }
Nov 14 02:45:23 TOWER kernel: ata2.00: error: { UNC }
Nov 14 02:45:23 TOWER kernel: ata2.00: configured for UDMA/133
Nov 14 02:45:23 TOWER kernel: ata2: EH complete
Nov 14 02:45:26 TOWER kernel: ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
Nov 14 02:45:26 TOWER kernel: ata2.00: irq_stat 0x40000001
Nov 14 02:45:26 TOWER kernel: ata2.00: cmd c8/00:10:27:f0:53/00:00:00:00:00/e0 tag 0 dma 8192 in
Nov 14 02:45:26 TOWER kernel:          res 51/40:00:34:f0:53/00:00:00:00:00/00 Emask 0x9 (media error)
Nov 14 02:45:26 TOWER kernel: ata2.00: status: { DRDY ERR }
Nov 14 02:45:26 TOWER kernel: ata2.00: error: { UNC }
Nov 14 02:45:26 TOWER kernel: ata2.00: configured for UDMA/133
Nov 14 02:45:26 TOWER kernel: ata2: EH complete
Nov 14 02:45:31 TOWER kernel: ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
Nov 14 02:45:31 TOWER kernel: ata2.00: irq_stat 0x40000001
Nov 14 02:45:31 TOWER kernel: ata2.00: cmd c8/00:10:27:f0:53/00:00:00:00:00/e0 tag 0 dma 8192 in
Nov 14 02:45:31 TOWER kernel:          res 51/40:00:35:f0:53/00:00:00:00:00/00 Emask 0x9 (media error)
Nov 14 02:45:31 TOWER kernel: ata2.00: status: { DRDY ERR }
Nov 14 02:45:31 TOWER kernel: ata2.00: error: { UNC }
Nov 14 02:45:31 TOWER kernel: ata2.00: configured for UDMA/133
Nov 14 02:45:31 TOWER kernel: ata2: EH complete
Nov 14 02:45:34 TOWER kernel: ata2.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x0
Nov 14 02:45:34 TOWER kernel: ata2.00: irq_stat 0x40000001
Nov 14 02:45:34 TOWER kernel: ata2.00: cmd c8/00:10:27:f0:53/00:00:00:00:00/e0 tag 0 dma 8192 in
Nov 14 02:45:34 TOWER kernel:          res 51/40:00:35:f0:53/00:00:00:00:00/00 Emask 0x9 (media error)
Nov 14 02:45:34 TOWER kernel: ata2.00: status: { DRDY ERR }
Nov 14 02:45:34 TOWER kernel: ata2.00: error: { UNC }
Nov 14 02:45:34 TOWER kernel: ata2.00: configured for UDMA/133
Nov 14 02:45:34 TOWER kernel: sd 2:0:0:0: [sdb] Unhandled sense code
Nov 14 02:45:34 TOWER kernel: sd 2:0:0:0: [sdb] Result: hostbyte=0x00 driverbyte=0x08
Nov 14 02:45:34 TOWER kernel: sd 2:0:0:0: [sdb] Sense Key : 0x3 [current] [descriptor]
Nov 14 02:45:34 TOWER kernel: Descriptor sense data with sense descriptors (in hex):
Nov 14 02:45:34 TOWER kernel:        72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
Nov 14 02:45:34 TOWER kernel:        00 53 f0 35
Nov 14 02:45:34 TOWER kernel: sd 2:0:0:0: [sdb] ASC=0x11 ASCQ=0x4
Nov 14 02:45:34 TOWER kernel: end_request: I/O error, dev sdb, sector 5500981
Nov 14 02:45:34 TOWER kernel: ata2: EH complete
Nov 14 02:45:34 TOWER kernel: md: disk0 read error
Nov 14 02:45:34 TOWER kernel: handle_stripe read error: 5500912/0, count: 1
Nov 14 02:45:34 TOWER kernel: sd 2:0:0:0: [sdb] 1953525168 512-byte hardware sectors: (1.00 TB/931 GiB)
Nov 14 02:45:34 TOWER kernel: sd 2:0:0:0: [sdb] Write Protect is off
Nov 14 02:45:34 TOWER kernel: sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
Nov 14 02:45:34 TOWER kernel: sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
Dec  8 12:07:47 TOWER in.telnetd[12869]: connect from 10.20.1.50 (10.20.1.50)
Dec  8 12:07:49 TOWER login[12870]: ROOT LOGIN  on `pts/0' from `10.20.1.50'
Guess you missed the paragraph in the wiki that suggested zipping up the syslog and attaching it (under Additional-Options) as an attachment.
The disk known as /dev/sdb is the cause of your errors:
Thank you so very much for helping us solve this .... (and I apologize for not noticing the zipped file attachment process)
