BTRFS file system corruption after power loss
So basically my power went out when the server was running, when I started it up again the drive would no longer be mountable. So I took the drive out of there and connected it to a Ubuntu PC. The result when trying to mount it is the following :
Error mounting /dev/sdb1 at /media/claudia/28700235-19de-48a7-b96d-6f1a845a13ef: Command-line `mount -t "btrfs" -o "uhelper=udisks2,nodev,nosuid" "/dev/sdb1" "/media/brian/28700235-19de-48a7-b96d-6f1a845a13ef"' exited with non-zero exit status 32: mount: wrong fs type, bad option, bad superblock on /dev/sdb1,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail or so.
The disk outputs this SMART data:
smartctl 6.4 2014-10-07 r4002 [x86_64-linux-4.2.0-16-generic] (local build)
Copyright (C) 2002-14, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Toshiba 3.5" HDD DT01ACA...
Device Model:     TOSHIBA DT01ACA100
Serial Number:    53PXVK0NS
LU WWN Device Id: 5 000039 ff6db358e
Firmware Version: MS2OA750
User Capacity:    1.000.203.804.160 bytes [1,00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Wed Apr 20 18:14:18 2016 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x04)   Offline data collection activity
               was suspended by an interrupting command from host.
               Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)   The previous self-test routine completed
               without error or no self-test has ever
               been run.
Total time to complete Offline
data collection:       ( 7215) seconds.
capabilities:           (0x5b) SMART execute Offline immediate.
               Auto Offline data collection on/off support.
               Suspend Offline collection upon new
               command.
               Offline surface scan supported.
               Self-test supported.
               No Conveyance Self-test supported.
               Selective Self-test supported.
SMART capabilities:            (0x0003)   Saves SMART data before entering
               power-saving mode.
               Supports SMART auto save timer.
Error logging capability:        (0x01)   Error logging supported.
               General Purpose Logging supported.
Short self-test routine
recommended polling time:     (   1) minutes.
Extended self-test routine
recommended polling time:     ( 121) minutes.
SCT capabilities:           (0x003d)   SCT Status supported.
               SCT Error Recovery Control supported.
               SCT Feature Control supported.
               SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   141   141   054    Pre-fail  Offline      -       72
  3 Spin_Up_Time            0x0007   139   139   024    Pre-fail  Always       -       161 (Average 169)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       3928
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   115   115   020    Pre-fail  Offline      -       34
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       6085
10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       2260
192 Power-Off_Retract_Count 0x0032   096   096   000    Old_age   Always       -       5578
193 Load_Cycle_Count        0x0012   096   096   000    Old_age   Always       -       5578
194 Temperature_Celsius     0x0002   171   171   000    Old_age   Always       -       35 (Min/Max 15/54)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       955
SMART Error Log Version: 1
ATA Error Count: 964 (device log contains only the most recent five errors)
   CR = Command Register [HEX]
   FR = Features Register [HEX]
   SC = Sector Count Register [HEX]
   SN = Sector Number Register [HEX]
   CL = Cylinder Low Register [HEX]
   CH = Cylinder High Register [HEX]
   DH = Device/Head Register [HEX]
   DC = Device Command Register [HEX]
   ER = Error register [HEX]
   ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 964 occurred at disk power-on lifetime: 4766 hours (198 days + 14 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  40 51 11 0f 08 00 01  Error: UNC at LBA = 0x0100080f = 16779279
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  60 08 10 10 08 00 41 ff      00:04:27.612  READ FPDMA QUEUED
  60 08 c0 80 ff ff 40 08      00:04:27.605  READ FPDMA QUEUED
  60 20 b8 00 08 00 40 08      00:04:27.605  READ FPDMA QUEUED
  60 08 b0 40 65 70 40 08      00:04:27.605  READ FPDMA QUEUED
  60 08 a8 b8 63 70 40 08      00:04:27.605  READ FPDMA QUEUED
Error 963 occurred at disk power-on lifetime: 4305 hours (179 days + 9 hours)
  84 51 01 e7 b0 60 00  Error: ICRC, ABRT at LBA = 0x0060b0e7 = 6336743
  60 08 00 e7 b0 60 40 ff      00:05:57.768  READ FPDMA QUEUED
  60 08 58 e0 b0 60 40 00      00:05:57.748  READ FPDMA QUEUED
  60 08 50 18 b1 60 40 00      00:05:57.748  READ FPDMA QUEUED
  60 08 48 d8 b0 60 40 00      00:05:57.748  READ FPDMA QUEUED
  60 08 40 90 1b 61 40 00      00:05:57.747  READ FPDMA QUEUED
Error 962 occurred at disk power-on lifetime: 4298 hours (179 days + 2 hours)
  84 51 41 f7 29 a9 0b  Error: ICRC, ABRT at LBA = 0x0ba929f7 = 195635703
  60 90 40 f9 29 a9 4b ff      00:03:48.517  READ FPDMA QUEUED
  60 90 a8 38 2f a9 40 00      00:03:48.496  READ FPDMA QUEUED
  60 00 a0 38 2e a9 40 00      00:03:48.496  READ FPDMA QUEUED
  60 00 98 38 2d a9 40 00      00:03:48.496  READ FPDMA QUEUED
  60 00 90 38 2c a9 40 00      00:03:48.496  READ FPDMA QUEUED
Error 961 occurred at disk power-on lifetime: 2094 hours (87 days + 6 hours)
  84 51 31 79 da d4 02  Error: ICRC, ABRT 49 sectors at LBA = 0x02d4da79 = 47503993
  25 00 40 6a da d4 40 00      00:00:34.697  READ DMA EXT
  60 40 48 6a da d4 40 00      00:00:34.696  READ FPDMA QUEUED
  60 20 40 ba 6c 65 40 00      00:00:34.694  READ FPDMA QUEUED
  60 40 38 a2 67 65 40 00      00:00:34.694  READ FPDMA QUEUED
  60 40 30 fa d5 e0 40 00      00:00:34.694  READ FPDMA QUEUED
Error 960 occurred at disk power-on lifetime: 1904 hours (79 days + 8 hours)
  84 51 11 cf 0f 60 00  Error: ICRC, ABRT 17 sectors at LBA = 0x00600fcf = 6295503
  25 00 20 c0 0f 60 e0 00      00:22:53.619  READ DMA EXT
  ea 00 00 00 00 00 a0 00      00:22:52.978  FLUSH CACHE EXT
  35 00 08 20 3f 5e e0 00      00:22:52.978  WRITE DMA EXT
  35 00 20 a0 0f 60 e0 00      00:22:52.977  WRITE DMA EXT
  35 00 20 c0 3d 06 e0 00      00:22:52.977  WRITE DMA EXT
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
The command "sudo btrfs-show-super /dev/sdb" gave me this result:
superblock: bytenr=65536, device=/dev/sdb
ERROR: bad magic on superblock on /dev/sdb at 65536
I have no experience when it comes to data recovery so please just tell me if you need any more information.
Thank you beforehand, your help is really appreciated
Brian
