  • 4 weeks later...
  • Replies 2.6k
  • Views 686.6k
  • kennymc.c
    kennymc.c
For your consideration, I have two suggestions to add to check for FCP. I just recovered from an incident where the default postgresql17 install created /mnt/cache/appdata/postgresql17, but my server doesn't have a cache pool, so it mounted the database into an unintended RAM disk. Full mechanics: https://product.unraid.net/p/7-3-1-mover-moves-array-data-into-ram-rootfs-when-a-share-s-configured-pool-doesn-t-exist-but-mnt-pool-is-a-plain-directory
Suggested behavior: Warn the user when a share has shareUseCache of yes/prefer/only and shareCachePool names a pool that isn't defined (regardless of what exists under /mnt), — especially when the system has zero pools. I've also asked for stock Unraid to surface this proactively (https://product.unraid.net/p/proactively-surface-share-references-to-nonexistent-pools-and-flag-legacy-prefer-cache-configs-on-upgrade), but FCP fixing the test would protect people today.
Two suggested COAs in the "share references non existent pool" test include/tests.php, version 2026.05.16):
1. The test builds $pools[] from defined Cache-type disks, then if ( ! isset($pools) ) return; — so on a system with no pools at all, the whole test is skipped. Poolless systems are exactly where legacy prefercache share settings are dangerous: if a plain directory appears at /mnt/cache (Docker auto-creates one from any stale template host path), the mover could move array data into it — i.e. into RAM.
2. The existence test is !is_dir("/mnt/$sharePool") — mountpoint -q (or checking the pool config) would be more robust.
On 7/17/2026 at 7:18 AM, Revan335 said:
And again!
Any Information about that?
Other Dynamix Plugins too:
* The plugin dynamix.password.validator.plg is not known to Community Applications and is possibly incompatible with your server
With Internal Boot introduced in unraid 7.3.0 this is not necessarily valid?
The missing question.png bugfix takes too long to be released. ;)
@flurec Known bug in Unraid. We need to wait for it to be fixed in 7.3.3. Reboot will fix it until next time you delete containers using the question.png default icon.
You can install the PR with the bugfix from here if you don't wan't to wait:
https://github.com/unraid/webgui/pull/2693#issuecomment-5072886036
Edited by Niklas
/var/log is getting full
Hi, hopefully you can help, new server build only been online a couple of days, recently replaced failing Parity drive with a precleared but older HDD so it may be the issue? Ordering some replacement drives shortly.
Thank you :)
server-diagnostics-20260803-1122.zip
There are multiple issues spamming the log, frst one you should look at is the apparent power/connection issues with the parity disk. Check/replace cables and post new diags after arrays start (and please create a new thread in the general support forum)
Hi, my log files are filled. it was recommended to post here. Something about HDCP not being initialized. Makes sense, i don't have any monitors connected. Thanks for any help anyone can offer.
tower-diagnostics-20260803-0953.zip
Edited by Chocco
Your logs fills with the question.png missing bug I just mentioned in this thread. Temp fix in my post.
Yes, the HDCP log line also happens but not as big of a problem.
Edited by Niklas
1 minute ago, ehrw said:
I think you've gotten this mixed up with Unraid 8.
oops, maybe. the infos from limetech are a bit confusing sometimes. I will delete my post
Same issue here. I found this in the phplog
[18-Aug-2026 17:32:48 Europe/London] PHP Fatal error: Cannot redeclare function curl_socket() (previously declared in /usr/local/emhttp/plugins/dynamix/include/publish.php:18) in /usr/local/emhttp/plugins/fix.common.problems/include/helpers.php on line 530 [18-Aug-2026 17:33:08 Europe/London] PHP Fatal error: Cannot redeclare function curl_socket() (previously declared in /usr/local/emhttp/plugins/dynamix/include/publish.php:18) in /usr/local/emhttp/plugins/fix.common.problems/include/helpers.php on line 530 [18-Aug-2026 17:35:32 Europe/London] PHP Fatal error: Cannot redeclare function curl_socket() (previously declared in /usr/local/emhttp/plugins/dynamix/include/publish.php:18) in /usr/local/emhttp/plugins/fix.common.problems/include/helpers.php on line 530 [18-Aug-2026 17:23:32 Europe/London] PHP Warning: parse_ini_file(/var/local/emhttp/var.ini): Failed to open stream: No such file or directory in /usr/local/emhttp/plugins/appdata.backup/include/ABHelper.php on line 46 [18-Aug-2026 17:23:37 Europe/London] PHP Warning: stream_socket_client(): Unable to connect to unix:///var/run/docker.sock (No such file or directory) in /usr/local/emhttp/plugins/dynamix.docker.manager/include/DockerClient.php on line 805 [18-Aug-2026 17:24:03 Europe/London] PHP Warning: stream_socket_client(): Unable to connect to unix:///var/run/docker.sock (No such file or directory) in /usr/local/emhttp/plugins/dynamix.docker.manager/include/DockerClient.php on line 805 [18-Aug-2026 17:32:48 Europe/London] PHP Fatal error: Cannot redeclare function curl_socket() (previously declared in /usr/local/emhttp/plugins/dynamix/include/publish.php:18) in /usr/local/emhttp/plugins/fix.common.problems/include/helpers.php on line 530 [18-Aug-2026 17:33:08 Europe/London] PHP Fatal error: Cannot redeclare function curl_socket() (previously declared in /usr/local/emhttp/plugins/dynamix/include/publish.php:18) in /usr/local/emhttp/plugins/fix.common.problems/include/helpers.php on line 530 [18-Aug-2026 17:35:32 Europe/London] PHP Fatal error: Cannot redeclare function curl_socket() (previously declared in /usr/local/emhttp/plugins/dynamix/include/publish.php:18) in /usr/local/emhttp/plugins/fix.common.problems/include/helpers.php on line 530
same
Same too. Is the only fix to roll back unraid?
hopefully someone in the know is following this, cause it's an annoying bug. thanks
Same on 7.4.0-beta 2
Long standing server, had been 40 days since last reboot, suddenly could not access plex from my server. I can still access the server though.
Following errors:
*Unable to write to cache
*Docker Image either full or corrupted.
Worried about memproblems (have switced mem bricks 3 times already) but have not run memtest yet, since I am not at my computer right now.
As you can see none of the disks are near full:image.png
selje-tower-diagnostics-20260906-2120.zip
You should, pool went read only due to filesystem corruption:
Sep 6 20:21:16 Selje-Tower kernel: BTRFS critical (device nvme1n1p1 state EA): unable to find ref byte nr 7848738816 parent 0 root 5 owner 2407754 offset 7323648 slot 150
Sep 6 20:21:16 Selje-Tower kernel: BTRFS error (device nvme1n1p1 state EA): failed to run delayed ref for logical 7848738816 num_bytes 8192 type 178 action 2 ref_mod 1: -2
Sep 6 20:21:16 Selje-Tower kernel: BTRFS: error (device nvme1n1p1 state EA) in btrfs_run_delayed_refs:2161: errno=-2 No such entry
/var/log is getting full (currently 69 % used)
I get this message every day from Fix Common Problems, each day with a higher percentage.
But I can't figure out at all WHAT is taking up the space in /var/log.
If I look with df then /var/log is indeed getting fuller. That's exactly the value reported by Fix Common Problems:
root@UNRAID:/var/log# df -h /var/log
Filesystem Size Used Avail Use% Mounted on
tmpfs 128M 88M 41M 69% /var/log
However, if I look inside /var/log with du, there seems to be NOTHING that's taking up any real space on the file system.
df reports 88M, but du sees only 812K ??? 🤔
root@UNRAID:/var/log# du -h --max-depth=1 /var/log
20K /var/log/.pm2
0 /var/log/pwfail
0 /var/log/preclear
0 /var/log/unraid-api
0 /var/log/swtpm
400K /var/log/samba
0 /var/log/pm2
0 /var/log/plugins
80K /var/log/pkgtools
0 /var/log/nginx
0 /var/log/nfsd
16K /var/log/libvirt
812K /var/log
So what is filling up /var/log and what can I do to prevent this in the future?
For example, the syslog file is small, around 100K.
The current uptime of the server is around 2 month, which I don't find particularly high. Of course I could reboot to solve this problem, but that would probably only postpone the problem to later. I've attached the server diagnostics.
Thanks!
unraid-diagnostics-20260920-1218.zip
So just back from vacation. Have tested both pairs of memory sticks (2 by 2x8gb) the last two days. 0 errors on the sticks. It seems to me the same issues persist. WHat can I do?image.png
20K /var/log/.pm2
0 /var/log/pwfail
0 /var/log/preclear
0 /var/log/swtpm
400K /var/log/samba
0 /var/log/pm2
0 /var/log/plugins
0 /var/log/nginx
0 /var/log/nfsd
812K /var/log
Thanks!
Found it! lsof +L1 showed an already deleted log file that was still opened by a process and used 40M on /var/log!
The log file didn't show up in the directory, because it was already deleted, so du could not see it. Killing the process immediately freed the space 😊
