5 minutes ago, cybrnook said:
So with the above, is it really an error or issue here?
False positive.  It's one test that I can't replicate a failure.  And since you're already on 6.4, it's obviously not a problem.  Tonight though I'll give you a command to run so I can see where I went wrong on this.
  • Replies 2.5k
  • Views 673.9k
  • kennymc.c
    kennymc.c
Looking forward to it, send it over when you have time and I will run it tonight for you.
On 2/15/2018 at 9:43 AM, halorrr said:
When I first set up the plugin I accidentally told the plugin to ignore the FTP warnings.
download?id=qbhAbmXu9JOLPvzpc1wSafwUtRTI
I don't want this to be the case any more however whenever I click the Monitor Warning/Error button, the items stay. What is strange about this is if I tell it to ignore the warning on other items, I am able to set them to Monitor again just fine, it is just these two items that are stuck. This has persisted through multiple restarts, rescans, and versions of the plugin. I'm currently on unRAID 6.4.1 and Fix Common Problems 2018-02-14
Any help to get these monitoring again would be great.
Anyone have any suggestions on this yet? I'm now on unRAID 6.5.0 and Fix Common Problems 2018.03.14b and the issue still persists.
In the meantime, can you give me your diagnostics
Unfortunately not at the moment, at work...... Give me 10 -12 hours? :-)
You can edit boot/config/plugins/fix.common.problems/ignoreList.json. Just delete the lines associated with those ignored warnings. Good idea to make a copy of the file first though, just in case. Tested this on my server and it worked.
That worked perfectly! Thanks!
noah-diagnostics-20180315-2021.zip
Here ya go! Shoot me whatever syntax you had in mind...
Figures.  I thought you may be a no-show so I pumped out an update.  Oh well...  Post me the output of
fdisk -l /dev/nvme0n1
root@noah:~# fdisk -l /dev/nvme0n1
Disk /dev/nvme0n1: 477 GiB, 512110190592 bytes, 1000215216 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x00000000
Device         Boot Start        End    Sectors  Size Id Type
/dev/nvme0n1p1         64 1000215215 1000215152  477G 83 Linux
EDIT: udpated to your latest push and still get the same error:
Checking cache drive partitioning
Issue Found: Cache drive partition doesn't start on sector 64. You will have problems. See here https://lime-technology.com/forums/topic/46802-faq-for-unraid-v6/?tab=comments#comment-511923 for how to fix this. NOTE: Currently there may be false positives associated with this test
Edited by cybrnook
Disklabel type: dos
Thanks.  There'll be an update tomorrow that will fix this false positive
Mucho Gracis sir! Keep up the great work, and for being thorough, it is appreciated.
Because that update doesn't have this fix.  Tomorrow's will.  I guess I could pump it out today, but every time I start doing releases of 15a, 15b, etc @CHBMB makes fun of me so I only do them nowadays when absolutely necessary.
Edited by Squid
Hello all,
When you run the extended tests, are the results written to disk anywhere?  I can run the tests successfully on my production server, but when I try to read the results it crashes my browser.  This obviously bodes ill for the results, but I'd still like to see them so I can correct them!
Thanks
-P
No worries, take your time. The ride is over at this point.
But remember, it's always 16 somewhere :-).
Edited by cybrnook
4 minutes ago, pengrus said:
Hello all,
Thanks
-P
/tmp/fix.common.problems/extendedLog
But you have to have a ton of problems for it to crash the browser.  Give it a couple of minutes to figure it out and render the display.
Edited by Squid
Disklabel type: dos
Can you update to today's release and try it again.  Thx
No issues were found with your server that may hinder the OS upgrade. You should be good to go
Done
I started seeing the below running update assistant with the last couple of revisions of the plugin for whatever reason.
Diagnostics attached.
I'm aware of the need to get rid of the preclear and statistics plugins and the underscore character in my server name before updating from 6.3 to 6.5
Checking for plugin updates
OK: All plugins up to date
Checking for plugin compatibility
Issue Found: ca.backup2.plg () is not known to Community Applications. Compatibility for this plugin CANNOT be determined and it may cause you issues.
Issue Found: ca.cleanup.appdata.plg () is not known to Community Applications. Compatibility for this plugin CANNOT be determined and it may cause you issues.
Issue Found: ca.update.applications.plg () is not known to Community Applications. Compatibility for this plugin CANNOT be determined and it may cause you issues.
Issue Found: community.applications.plg () is not known to Community Applications. Compatibility for this plugin CANNOT be determined and it may cause you issues.
Issue Found: dynamix.cache.dirs.plg () is not known to Community Applications. Compatibility for this plugin CANNOT be determined and it may cause you issues.
Issue Found: dynamix.local.master.plg () is not known to Community Applications. Compatibility for this plugin CANNOT be determined and it may cause you issues.
Issue Found: dynamix.ssd.trim.plg () is not known to Community Applications. Compatibility for this plugin CANNOT be determined and it may cause you issues.
Issue Found: dynamix.system.autofan.plg () is not known to Community Applications. Compatibility for this plugin CANNOT be determined and it may cause you issues.
Issue Found: fix.common.problems.plg () is not known to Community Applications. Compatibility for this plugin CANNOT be determined and it may cause you issues.
Issue Found: NerdPack.plg () is not known to Community Applications. Compatibility for this plugin CANNOT be determined and it may cause you issues.
Issue Found: preclear.disk.plg () is not known to Community Applications. Compatibility for this plugin CANNOT be determined and it may cause you issues.
Issue Found: speedtest.plg () is not known to Community Applications. Compatibility for this plugin CANNOT be determined and it may cause you issues.
Issue Found: statistics.sender.plg () is not known to Community Applications. Compatibility for this plugin CANNOT be determined and it may cause you issues.
Issue Found: unassigned.devices.plg () is not known to Community Applications. Compatibility for this plugin CANNOT be determined and it may cause you issues.
Issue Found: unbalance.plg () is not known to Community Applications. Compatibility for this plugin CANNOT be determined and it may cause you issues.
Issue Found: user.scripts.plg () is not known to Community Applications. Compatibility for this plugin CANNOT be determined and it may cause you issues.
OK: All plugins are compatible
raid_01-diagnostics-20180317-1247.zip
Edited by dabl
Install today's update for FCP and rerun.  PITA for me to check for 6.3.5 compatibility.  I maintain 2 server's:  One with the "next" branch (ie: any RC), and one with the latest stable, so a minor difference between 6.3.5 and 6.5.0 slipped through.
On 2/20/2018 at 2:47 PM, hmgnsd said:
Hello, getting a strange message that I don't recall seeing when running extended tests:
Warning: parse_ini_file(/boot/config/share.cfg): failed to open stream: No such file or directory in /usr/local/emhttp/plugins/fix.common.problems/include/tests.php on line 1706
I've uninstalled and reinstalled the plugin and still get the error?
I am getting the same when running regular scan ...
line 1706 of test.php is "    $iniFile = parse_ini_file("/boot/config/share.cfg",true);"
Confirmed that /boot/config/share.cfg doesn't exist.
Edited by Encino Stan
Fixed next release.  Only a warning.  Doesn't affect any test.  Cause is that you've never gone to Settings - Share Settings and made a change.  Nothing to worry about on your end.
Thanks looks perfect now.
Updated Update Assistant to properly handle "next" releases.  There's now 2 buttons.  One will check against the "Stable" version, and the other will check against the "Next" version of unRaid  (You must already be on 6.4+ for the "Next" button to appear)
Edited by Squid
Minor issue but for whatever reason I currently have a case where the notification for a problem found doesn't appear to have a dismiss icon/link and continues to show up on the console.
I updated to the latest plugin version and re-ran but this notification remains.
What would be the simplest way to get rid of it?  No problem to stop/restart/reboot as necessary, just wondering.
raid_01-diagnostics-20180322-1614.zip
