April 8, 20188 yr Just now, Squid said: After running it, doesn't the banner appear at the top from unRaid stating a new version is available, with a click to download link? In fact, it did I actually didn't like that though, because it applied the update without a confirmation and without giving you the option to read the release notes. Maybe my issue is more with the banner than this plugin
April 15, 20188 yr I ran Extended Tests, and there were a bunch of files with whitespace etc, however, now I have a few blank looking ones. Any ideas on how to find them? The following files / folders contain whitespace at either the beginning or the end of the file names. This will cause issues with Windows / SMB because whitespace is disallowed at either the beginning or end of a file/folder ' ' ' '
April 15, 20188 yr Author 8 hours ago, richardsim7 said: I ran Extended Tests, and there were a bunch of files with whitespace etc, however, now I have a few blank looking ones. Any ideas on how to find them? The following files / folders contain whitespace at either the beginning or the end of the file names. This will cause issues with Windows / SMB because whitespace is disallowed at either the beginning or end of a file/folder ' ' ' ' Try today's update and see if it doesn't let you see the files / folders ( You will probably have to re-run the extended test though)
April 15, 20188 yr On 4/8/2018 at 9:19 AM, jonathanm said: I have an issue, and a suggestion for a fix. I have a box where the results from the extended test are huge, and clicking on the view results button brings up a blank view window and a hung browser, and then after several minutes it crashes firefox. To fix, I suggest adding 2 more things. 1. display size of log file in KB beside buttons 2. add button to download as text file instead of inline viewing @Squid, do you have any suggestions? I poked around to see if I could find a solution, but didn't see anything.
April 15, 20188 yr Author Today's update should be a quick and dirty fix. See how that goes. If it doesn't work good for you, then I'll add the download
April 15, 20188 yr 2 hours ago, Squid said: Today's update should be a quick and dirty fix. See how that goes. If it doesn't work good for you, then I'll add the download That worked.
April 16, 20188 yr 15 hours ago, Squid said: Try today's update and see if it doesn't let you see the files / folders ( You will probably have to re-run the extended test though) Cheers, they've shown up now
April 19, 20188 yr Some quick feedback. I am new to this plugin. First off my compliments. It is super useful and very powerful Couple of enhancements for consideration: we suggest turning off mover logging which makes sense except that it also removes mover error logging.. we should not be hiding errors. not sure what the best fix would be here. when you enter the settings dialogue it actually kicks off a scan. I would suggest this is a break with the GUI design model and that entering settings should be limited to just that. Activating a scan should be a positive user action especially since it can take tens of minutes to complete. Kudos
April 19, 20188 yr Author 2 hours ago, NAS said: we suggest turning off mover logging which makes sense except that it also removes mover error logging.. we should not be hiding errors. not sure what the best fix would be here. LT recommendation is disabled mover logging 2 hours ago, NAS said: when you enter the settings dialogue it actually kicks off a scan. I would suggest this is a break with the GUI design model and that entering settings should be limited to just that. Only the first time. After that it only rescans on your schedule or when pressing rescan
April 19, 20188 yr LT are wrong then But seriously I think all we need here is normal nix separation of error states. The reason I bring this up is that after manually tracking down where cache space had gone i noticed that i have had mover errors for weeks so this is based on real world issues. Also it is not my experience here that it only runs once but PECAK is entirely feasible. Will pay more attention and report back.
April 19, 20188 yr Author 3 minutes ago, NAS said: Also it is not my experience here that it only runs once but PECAK is entirely feasible Here's when it runs: On initial install when going to it's settings * After an update when going to it's settings * 10 minutes after an array start (background) On the schedule the user selects When pressing Rescan * If a scheduled run happens before going to FCP's settings, then a scan will not happen. 7 minutes ago, NAS said: i noticed that i have had mover errors for weeks so this is based on real world issues Put in a feature Req for errors to be logged. The test in FCP is classified as "Other" It will log the fact (if logging is enabled), but it will not trigger a notification from FCP.
April 24, 20188 yr 1 hour ago, kerbys said: How do i remove a share from the "not to be touched" by docker safe perms Could you be a little more specific? Do you mean you want to remove a folder from the appdata share? Or what?
April 24, 20188 yr Sorry what i mean is in the docker safe new perms i had accidentally added my main media storage to not be touched. Now i cant remove that. ive tried ticking and unticking but it never removes itsself.
May 8, 20188 yr What kind of notifications does this plugin send ? I already configured unRaid to send email notifications. Also, just installing it is enough to receive notifications, or I have to set it up to do that?
May 8, 20188 yr Author 2 minutes ago, Mat1926 said: Also, just installing it is enough to receive notifications, or I have to set it up to do that There's a setting on under what circumstances to send notifications.
May 15, 20188 yr tl;dr Can you use curl/wget to http://github.com to determine internet connectivity? Only found out now that the github CDN in my neck of the woods doesn't respond to pings... and FCP is complaining... root@MediaStore:~# ping github.com PING github.com (52.74.223.119) 56(84) bytes of data. ^C --- github.com ping statistics --- 2 packets transmitted, 0 received, 100% packet loss, time 1056ms root@MediaStore:~# curl -v github.com * Rebuilt URL to: github.com/ * Trying 52.74.223.119... * TCP_NODELAY set * Connected to github.com (52.74.223.119) port 80 (#0) > GET / HTTP/1.1 > Host: github.com > User-Agent: curl/7.59.0 > Accept: */* > < HTTP/1.1 301 Moved Permanently < Content-length: 0 < Location: https://github.com/ < * Connection #0 to host github.com left intact
June 13, 20188 yr Author I need a tester to give me data needed to refine Troubleshooting mode Prerequisites You CANNOT be running unraid in GUI mode You must have a keyboard / monitor attached to the server If you qualify, then enter in the following commands at the local shell exec 1> >(tee -a /boot/console.log) 2> >(tee -a /boot/consoleerror.log) blah And then reboot your system. After rebooting, post the resulting file here. (And yes, I want you to type in "blah" - it gives me a baseline). I have to run GUI mode, so this is a PITA for me to do.
June 15, 20188 yr The Unraid OS Warning still shows as below: "You are currently running 6.5.2 and the latest version is 6.5.3. It is recommended to upgrade here: and review the release notes HERE" and should instead link to Unraid 6.5.X separate update page now ( "/Tools/Update" )
June 15, 20188 yr Author I know. One of those stupid things I can never seem to find the time to change.
July 9, 20188 yr Hi how do i disable the continuous flash logging of syslog and diagnostics? I enabled it a couple days ago and cant find how to disable it any more.
July 15, 20188 yr unRAID 6.5.1 The FCP extended test was giving me a long list of 'The following files exist within the same folder on more than one disk. This duplicated file means that only the version on the lowest numbered disk will be readable, and the others are only going to confuse unRaid and take up excess space:' errors. They all existed on cache and one of the other drives. I decided to remove the cache drive completely and followed a guide I found. Following the removal unRAID appears to be happy with everything working as normal. I re-ran the FCP extended test and most of the duplicate file errors have gone. What I can't understand is that there are still warnings related to PlexMediaServer and CrashPlanPro. It's still reporting that files exist on cache and I haven't got a cache drive connected. I've rebooted unRAID twice, once to plug the cache drive, and then again just-in-case.
July 15, 20188 yr 7 minutes ago, bremen1874 said: What I can't understand is that there are still warnings related to PlexMediaServer and CrashPlanPro. It's still reporting that files exist on cache and I haven't got a cache drive connected. Docker will create a cache folder that only exists in RAM if there is no physical cache drive attached and the docker template calls out a /mnt/cache location. Check your plex and crashplan docker settings and be sure you only have /mnt/user and no /mnt/cache.
July 15, 20188 yr I had changed all of the /mnt/cache to /mnt/user. I just realised that unRAID wasn't quite up-to-date. With the update to 6.5.3 installed all of the duplicate errors have gone. I don't know why they survived the previous couple of reboots.
