December 19, 20223 yr Hi all. I'm getting this message and I've not run across it before. Can I get some guidance please? I don't want to screw up my VM or anything else... lol Share domains set to use pool cache_nvme, but files / folders exist on the cache_ssd pool Thank you! tower-diagnostics-20221218-2128.zip
December 19, 20223 yr Author appdata shareUseCache="prefer" # Share exists on cache_nvme a--s shareUseCache="no" # Share does not exist C--------------------------------pshareUseCache="no" # Share exists on disk1 D--a shareUseCache="no" # Share does not exist domains shareUseCache="prefer" # Share exists on cache_nvme, cache_ssd D-------s shareUseCache="prefer" # Share does not exist D-----x shareUseCache="no" # Share does not exist h---------s shareUseCache="no" # Share exists on disk1 i--v shareUseCache="only" # Share exists on cache_ssd isos shareUseCache="yes" # Share exists on disk1 m------a shareUseCache="prefer" # Share exists on cache_ssd m--c shareUseCache="no" # Share exists on disk1 M----s shareUseCache="no" # Share does not exist n-------d shareUseCache="no" # Share does not exist O---r shareUseCache="no" # Share exists on disk1 p------s shareUseCache="no" # Share exists on disk1 system shareUseCache="prefer" # Share exists on cache_nvme t------------s shareUseCache="only" # Share exists on cache_ssd t--------------g shareUseCache="prefer" # Share exists on cache_ssd t------s shareUseCache="no" # Share exists on disk1 TV shareUseCache="no" # Share does not exist T------s shareUseCache="no" # Share exists on disk1 V----s shareUseCache="no" # Share does not exist d-------s shareUseCache="no" # Share exists on cache_nvme m----s shareUseCache="no" # Share exists on disk1, disk2, disk3, disk4 v----s shareUseCache="no" # Share exists on disk1 To fix, you have to stop the docker and VM services, set the share to be use cache:yes run mover. When it's finished you set the share to be use cache:prefer and run the mover This would have happened originally because the file(s) were on the other cache pool (say before you renamed it) and didn't stop the services when you ran mover to move the stuff around....
December 19, 20223 yr Dear Squid! As usual, thank you for your great work for this community! I just have a question regarding having appdata split over multiple pools, and backup thereof. I have all but one appdata-folder on /cache and only my Plex appdata on a separate pool /cache_plex. FCP flags this as a problem: Quote Share appdata set to use pool cache, but files / folders exist on the cache_plex pool So far I've just ignored it, since the update seems to still be functioning correctly. Question is, can I leave it as is (and solve the issue of "how to backup my plex pool" this way) or is this a bad practice? Merry Christmas!
December 20, 20223 yr There have been thousands of login attempts over the past week. here is the most recent FCP and info Possible Hack Attempt on Dec 19On Dec 19 there were 861 invalid login attempts. This could either be yourself attempting to login to your server (SSH / Telnet) with the wrong user or password, or you could be actively be the victim of hack attacks. A common cause of this would be placing your server within your routers DMZ, or improperly forwarding ports. This is a major issue and needs to be addressed IMMEDIATELY NOTE: Because this check is done against the logged entries in the syslog, the only way to clear it is to either increase the number of allowed invalid logins per day (if determined that it is not a hack attempt) or to reset your server. It is not recommended under any circumstance to ignore this error More Information Dec 18 20:32:43 Claimco kernel: microcode: microcode updated early to revision 0x28, date = 2019-11-12 Dec 18 20:32:43 Claimco kernel: Linux version 5.19.17-Unraid (root@Develop) (gcc (GCC) 12.2.0, GNU ld version 2.39-slack151) #2 SMP PREEMPT_DYNAMIC Wed Nov 2 11:54:15 PDT 2022 Dec 18 20:32:43 Claimco kernel: Command line: BOOT_IMAGE=/bzimage initrd=/bzroot Dec 18 20:32:43 Claimco kernel: x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers' Dec 18 20:32:43 Claimco kernel: x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers' Dec 18 20:32:43 Claimco kernel: x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers' Dec 18 20:32:43 Claimco kernel: x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256 Dec 18 20:32:43 Claimco kernel: x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'standard' format. Dec 18 20:32:43 Claimco kernel: signal: max sigframe size: 1776 Dec 18 20:32:43 Claimco kernel: BIOS-provided physical RAM map: Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x0000000000000000-0x000000000009d7ff] usable Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x000000000009d800-0x000000000009ffff] reserved Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x00000000000e0000-0x00000000000fffff] reserved Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x0000000000100000-0x00000000a9ab9fff] usable Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x00000000a9aba000-0x00000000a9ac0fff] ACPI NVS Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x00000000a9ac1000-0x00000000aa787fff] usable Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x00000000aa788000-0x00000000aac6cfff] reserved Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x00000000aac6d000-0x00000000bcd4dfff] usable Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x00000000bcd4e000-0x00000000bd1a6fff] reserved Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x00000000bd1a7000-0x00000000bd1eefff] usable Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x00000000bd1ef000-0x00000000bd329fff] ACPI NVS Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x00000000bd32a000-0x00000000bdffefff] reserved Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x00000000bdfff000-0x00000000bdffffff] usable Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x00000000bf000000-0x00000000cf1fffff] reserved Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved Dec 18 20:32:43 Claimco kernel: BIOS-e820: [mem 0x0000000100000000-0x000000082fdfffff] usable Dec 18 20:32:43 Claimco kernel: NX (Execute Disable) protection: active Dec 18 20:32:43 Claimco kernel: SMBIOS 2.8 present. Dec 18 20:32:43 Claimco kernel: DMI: To Be Filled By O.E.M. To Be Filled By O.E.M./Z97 Extreme6, BIOS P2.80 03/06/2018 Dec 18 20:32:43 Claimco kernel: tsc: Fast TSC calibration using PIT Dec 18 20:32:43 Claimco kernel: tsc: Detected 3998.495 MHz processor Dec 18 20:32:43 Claimco kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved Dec 18 20:32:43 Claimco kernel: e820: remove [mem 0x000a0000-0x000fffff] usable Dec 18 20:32:43 Claimco kernel: last_pfn = 0x82fe00 max_arch_pfn = 0x400000000 Dec 18 20:32:43 Claimco kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT Dec 18 20:32:43 Claimco kernel: e820: update [mem 0xbf000000-0xffffffff] usable ==> reserved Dec 18 20:32:43 Claimco kernel: last_pfn = 0xbe000 max_arch_pfn = 0x400000000 Dec 18 20:32:43 Claimco kernel: found SMP MP-table at [mem 0x000fd380-0x000fd38f] Dec 18 20:32:43 Claimco kernel: Using GB pages for direct mapping Dec 18 20:32:43 Claimco kernel: RAMDISK: [mem 0x76242000-0x7fffffff] Dec 18 20:32:43 Claimco kernel: ACPI: Early table checksum verification disabled Dec 18 20:32:43 Claimco kernel: ACPI: RSDP 0x00000000000F04A0 000024 (v02 ALASKA) Dec 18 20:32:43 Claimco kernel: ACPI: XSDT 0x00000000BD2F7088 000094 (v01 ALASKA A M I 01072009 AMI 00010013) Dec 18 20:32:43 Claimco kernel: ACPI: FACP 0x00000000BD308090 00010C (v05 ALASKA A M I 01072009 AMI 00010013) Dec 18 20:32:43 Claimco kernel: ACPI: DSDT 0x00000000BD2F71B8 010ED6 (v02 ALASKA A M I 00000280 INTL 20120711) Dec 18 20:32:43 Claimco kernel: ACPI: FACS 0x00000000BD329F80 000040 Dec 18 20:32:43 Claimco kernel: ACPI: APIC 0x00000000BD3081A0 000092 (v03 ALASKA A M I 01072009 AMI 00010013) Dec 18 20:32:43 Claimco kernel: ACPI: FPDT 0x00000000BD308238 000044 (v01 ALASKA A M I 01072009 AMI 00010013) Dec 18 20:32:43 Claimco kernel: ACPI: SSDT 0x00000000BD308280 000539 (v01 PmRef Cpu0Ist 00003000 INTL 20051117) Dec 18 20:32:43 Claimco kernel: ACPI: SSDT 0x00000000BD3087C0 000B74 (v01 CpuRef CpuSsdt 00003000 INTL 20051117) Dec 18 20:32:43 Claimco kernel: ACPI: SSDT 0x00000000BD309338 0001C7 (v01 PmRef LakeTiny 00003000 INTL 20051117) Dec 18 20:32:43 Claimco kernel: ACPI: MCFG 0x00000000BD309500 00003C (v01 ALASKA A M I 01072009 MSFT 00000097) Dec 18 20:32:43 Claimco kernel: ACPI: HPET 0x00000000BD309540 000038 (v01 ALASKA A M I 01072009 AMI. 00000005) Dec 18 20:32:43 Claimco kernel: ACPI: SSDT 0x00000000BD309578 00036D (v01 SataRe SataTabl 00001000 INTL 20120711) Dec 18 20:32:43 Claimco kernel: ACPI: SSDT 0x00000000BD3098E8 005A36 (v01 SaSsdt SaSsdt 00003000 INTL 20120711) Dec 18 20:32:43 Claimco kernel: ACPI: AAFT 0x00000000BD30F320 0005A0 (v01 ALASKA OEMAAFT 01072009 MSFT 00000097) Dec 18 20:32:43 Claimco kernel: ACPI: UEFI 0x00000000BD30F8C0 000042 (v01 ALASKA A M I 01072009 00000000) Dec 18 20:32:43 Claimco kernel: ACPI: DMAR 0x00000000BD30F908 0000B8 (v01 INTEL BDW 00000001 INTL 00000001) Dec 18 20:32:43 Claimco kernel: ACPI: SSDT 0x00000000BD30F9C0 000579 (v01 Intel_ IsctTabl 00001000 INTL 20120711) Dec 18 20:32:43 Claimco kernel: ACPI: Reserving FACP table memory at [mem 0xbd308090-0xbd30819b] Dec 18 20:32:43 Claimco kernel: ACPI: Reserving DSDT table memory at [mem 0xbd2f71b8-0xbd30808d] Dec 18 20:32:43 Claimco kernel: ACPI: Reserving FACS table memory at [mem 0xbd329f80-0xbd329fbf] Dec 18 20:32:43 Claimco kernel: ACPI: Reserving APIC table memory at [mem 0xbd3081a0-0xbd308231] Dec 18 20:32:43 Claimco kernel: ACPI: Reserving FPDT table memory at [mem 0xbd308238-0xbd30827b] Dec 18 20:32:43 Claimco kernel: ACPI: Reserving SSDT table memory at [mem 0xbd308280-0xbd3087b8] Dec 18 20:32:43 Claimco kernel: ACPI: Reserving SSDT table memory at [mem 0xbd3087c0-0xbd309333] Dec 18 20:32:43 Claimco kernel: ACPI: Reserving SSDT table memory at [mem 0xbd309338-0xbd3094fe] Dec 18 20:32:43 Claimco kernel: ACPI: Reserving MCFG table memory at [mem 0xbd309500-0xbd30953b] Dec 18 20:32:43 Claimco kernel: ACPI: Reserving HPET table memory at [mem 0xbd309540-0xbd309577] Dec 18 20:32:43 Claimco kernel: ACPI: Reserving SSDT table memory at [mem 0xbd309578-0xbd3098e4] Dec 18 20:32:43 Claimco kernel: ACPI: Reserving SSDT table memory at [mem 0xbd3098e8-0xbd30f31d] Dec 18 20:32:43 Claimco kernel: ACPI: Reserving AAFT table memory at [mem 0xbd30f320-0xbd30f8bf] Dec 18 20:32:43 Claimco kernel: ACPI: Reserving UEFI table memory at [mem 0xbd30f8c0-0xbd30f901] Dec 18 20:32:43 Claimco kernel: ACPI: Reserving DMAR table memory at [mem 0xbd30f908-0xbd30f9bf] Dec 18 20:32:43 Claimco kernel: ACPI: Reserving SSDT table memory at [mem 0xbd30f9c0-0xbd30ff38] Dec 18 20:32:43 Claimco kernel: No NUMA configuration found Dec 18 20:32:43 Claimco kernel: Faking a node at [mem 0x0000000000000000-0x000000082fdfffff] Dec 18 20:32:43 Claimco kernel: NODE_DATA(0) allocated [mem 0x82fdf7000-0x82fdfafff] Dec 18 20:32:43 Claimco kernel: Zone ranges: Dec 18 20:32:43 Claimco kernel: DMA [mem 0x0000000000001000-0x0000000000ffffff] Dec 18 20:32:43 Claimco kernel: DMA32 [mem 0x0000000001000000-0x00000000ffffffff] Dec 18 20:32:43 Claimco kernel: Normal [mem 0x0000000100000000-0x000000082fdfffff] Dec 18 20:32:43 Claimco kernel: Movable zone start for each node Dec 18 20:32:43 Claimco kernel: Early memory node ranges Dec 18 20:32:43 Claimco kernel: node 0: [mem 0x0000000000001000-0x000000000009cfff] Dec 18 20:32:43 Claimco kernel: node 0: [mem 0x0000000000100000-0x00000000a9ab9fff] Dec 18 20:32:43 Claimco kernel: node 0: [mem 0x00000000a9ac1000-0x00000000aa787fff] Dec 18 20:32:43 Claimco kernel: node 0: [mem 0x00000000aac6d000-0x00000000bcd4dfff] Dec 18 20:32:43 Claimco kernel: node 0: [mem 0x00000000bd1a7000-0x00000000bd1eefff] Dec 18 20:32:43 Claimco kernel: node 0: [mem 0x00000000bdfff000-0x00000000bdffffff] Dec 18 20:32:43 Claimco kernel: node 0: [mem 0x0000000100000000-0x000000082fdfffff] Dec 18 20:32:43 Claimco kernel: Initmem setup node 0 [mem 0x0000000000001000-0x000000082fdfffff] Dec 18 20:32:43 Claimco kernel: On node 0, zone DMA: 1 pages in unavailable ranges Dec 18 20:32:43 Claimco kernel: On node 0, zone DMA: 99 pages in unavailable ranges Dec 18 20:32:43 Claimco kernel: On node 0, zone DMA32: 7 pages in unavailable ranges Dec 18 20:32:43 Claimco kernel: On node 0, zone DMA32: 1253 pages in unavailable ranges Dec 18 20:32:43 Claimco kernel: On node 0, zone DMA32: 1113 pages in unavailable ranges Dec 18 20:32:43 Claimco kernel: On node 0, zone DMA32: 3600 pages in unavailable ranges Dec 18 20:32:43 Claimco kernel: On node 0, zone Normal: 8192 pages in unavailable ranges Dec 18 20:32:43 Claimco kernel: On node 0, zone Normal: 512 pages in unavailable ranges Dec 18 20:32:43 Claimco kernel: Reserving Intel graphics memory at [mem 0xbf200000-0xcf1fffff] Dec 18 20:32:43 Claimco kernel: ACPI: PM-Timer IO Port: 0x1808 Dec 18 20:32:43 Claimco kernel: ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1]) Dec 18 20:32:43 Claimco kernel: IOAPIC[0]: apic_id 8, version 32, address 0xfec00000, GSI 0-23 Dec 18 20:32:43 Claimco kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl) Dec 18 20:32:43 Claimco kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level) Dec 18 20:32:43 Claimco kernel: ACPI: Using ACPI (MADT) for SMP configuration information Dec 18 20:32:43 Claimco kernel: ACPI: HPET id: 0x8086a701 base: 0xfed00000 Dec 18 20:32:43 Claimco kernel: TSC deadline timer available Dec 18 20:32:43 Claimco kernel: smpboot: Allowing 8 CPUs, 0 hotplug CPUs Dec 18 20:32:43 Claimco kernel: [mem 0xcf200000-0xefffffff] available for PCI devices Dec 18 20:32:43 Claimco kernel: Booting paravirtualized kernel on bare hardware Dec 18 20:32:43 Claimco kernel: clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns Dec 18 20:32:43 Claimco kernel: setup_percpu: NR_CPUS:256 nr_cpumask_bits:256 nr_cpu_ids:8 nr_node_ids:1 Dec 18 20:32:43 Claimco kernel: percpu: Embedded 55 pages/cpu s185960 r8192 d31128 u262144 Dec 18 20:32:43 Claimco kernel: pcpu-alloc: s185960 r8192 d31128 u262144 alloc=1*2097152 Dec 18 20:32:43 Claimco kernel: pcpu-alloc: [0] 0 1 2 3 4 5 6 7 Dec 18 20:32:43 Claimco kernel: Fallback order for Node 0: 0 Dec 18 20:32:43 Claimco kernel: Built 1 zonelists, mobility grouping on. Total pages: 8178320 Dec 18 20:32:43 Claimco kernel: Policy zone: Normal Dec 18 20:32:43 Claimco kernel: Kernel command line: BOOT_IMAGE=/bzimage initrd=/bzroot Dec 18 20:32:43 Claimco kernel: Unknown kernel command line parameters "BOOT_IMAGE=/bzimage", will be passed to user space. Dec 18 20:32:43 Claimco kernel: Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear) Dec 18 20:32:43 Claimco kernel: Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear) Dec 18 20:32:43 Claimco kernel: mem auto-init: stack:off, heap alloc:off, heap free:off Dec 18 20:32:43 Claimco kernel: Memory: 32406612K/33233180K available (12295K kernel code, 1681K rwdata, 3916K rodata, 1836K init, 1820K bss, 826312K reserved, 0K cma-reserved) Dec 18 20:32:43 Claimco kernel: SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1 Dec 18 20:32:43 Claimco kernel: Kernel/User page tables isolation: enabled Dec 18 20:32:43 Claimco kernel: ftrace: allocating 41888 entries in 164 pages Dec 18 20:32:43 Claimco kernel: ftrace: allocated 164 pages with 3 groups Dec 18 20:32:43 Claimco kernel: Dynamic Preempt: voluntary Dec 18 20:32:43 Claimco kernel: rcu: Preemptible hierarchical RCU implementation. Dec 18 20:32:43 Claimco kernel: rcu: RCU event tracing is enabled. Dec 18 20:32:43 Claimco kernel: rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=8. Dec 18 20:32:43 Claimco kernel: Trampoline variant of Tasks RCU enabled. Dec 18 20:32:43 Claimco kernel: Rude variant of Tasks RCU enabled. Dec 18 20:32:43 Claimco kernel: Tracing variant of Tasks RCU enabled. Dec 18 20:32:43 Claimco kernel: rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies. Dec 18 20:32:43 Claimco kernel: rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8 Dec 18 20:32:43 Claimco kernel: NR_IRQS: 16640, nr_irqs: 488, preallocated irqs: 16 Dec 18 20:32:43 Claimco kernel: rcu: srcu_init: Setting srcu_struct sizes based on contention. Dec 18 20:32:43 Claimco kernel: Console: colour VGA+ 80x25 Dec 18 20:32:43 Claimco kernel: printk: console [tty0] enabled Dec 18 20:32:43 Claimco kernel: ACPI: Core revision 20220331 Dec 18 20:32:43 Claimco kernel: clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484882848 ns Dec 18 20:32:43 Claimco kernel: APIC: Switch to symmetric I/O mode setup Dec 18 20:32:43 Claimco kernel: DMAR: Host address width 39 Dec 18 20:32:43 Claimco kernel: DMAR: DRHD base: 0x000000fed90000 flags: 0x0 Dec 18 20:32:43 Claimco kernel: DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap c0000020660462 ecap f0101a Dec 18 20:32:43 Claimco kernel: DMAR: DRHD base: 0x000000fed91000 flags: 0x1 Dec 18 20:32:43 Claimco kernel: DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c20660462 ecap f010da Dec 18 20:32:43 Claimco kernel: DMAR: RMRR base: 0x000000bde9e000 end: 0x000000bdeacfff Dec 18 20:32:43 Claimco kernel: DMAR: RMRR base: 0x000000bf000000 end: 0x000000cf1fffff Dec 18 20:32:43 Claimco kernel: DMAR-IR: IOAPIC id 8 under DRHD base 0xfed91000 IOMMU 1 Dec 18 20:32:43 Claimco kernel: DMAR-IR: HPET id 0 under DRHD base 0xfed91000 Dec 18 20:32:43 Claimco kernel: DMAR-IR: x2apic is disabled because BIOS sets x2apic opt out bit. Dec 18 20:32:43 Claimco kernel: DMAR-IR: Use 'intremap=no_x2apic_optout' to override the BIOS setting. Dec 18 20:32:43 Claimco kernel: DMAR-IR: Enabled IRQ remapping in xapic mode Dec 18 20:32:43 Claimco kernel: x2apic: IRQ remapping doesn't support X2APIC mode Dec 18 20:32:43 Claimco kernel: ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1 Dec 18 20:32:43 Claimco kernel: clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x73459ffc2a6, max_idle_ns: 881590838124 ns Dec 18 20:32:43 Claimco kernel: Calibrating delay loop (skipped), value calculated using timer frequency.. 7996.99 BogoMIPS (lpj=3998495) Dec 18 20:32:43 Claimco kernel: pid_max: default: 32768 minimum: 301 Dec 18 20:32:43 Claimco kernel: Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) Dec 18 20:32:43 Claimco kernel: Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) Dec 18 20:32:43 Claimco kernel: CPU0: Thermal monitoring enabled (TM1) Dec 18 20:32:43 Claimco kernel: process: using mwait in idle threads Dec 18 20:32:43 Claimco kernel: Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 1024 Dec 18 20:32:43 Claimco kernel: Last level dTLB entries: 4KB 1024, 2MB 1024, 4MB 1024, 1GB 4 Dec 18 20:32:43 Claimco kernel: Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization Dec 18 20:32:43 Claimco kernel: Spectre V2 : Mitigation: Retpolines Dec 18 20:32:43 Claimco kernel: Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch Dec 18 20:32:43 Claimco kernel: Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT Dec 18 20:32:43 Claimco kernel: Spectre V2 : Enabling Restricted Speculation for firmware calls Dec 18 20:32:43 Claimco kernel: Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier Dec 18 20:32:43 Claimco kernel: Spectre V2 : User space: Mitigation: STIBP via prctl Dec 18 20:32:43 Claimco kernel: Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl Dec 18 20:32:43 Claimco kernel: MDS: Mitigation: Clear CPU buffers Dec 18 20:32:43 Claimco kernel: MMIO Stale Data: Unknown: No mitigations Dec 18 20:32:43 Claimco kernel: SRBDS: Mitigation: Microcode Dec 18 20:32:43 Claimco kernel: Freeing SMP alternatives memory: 24K Dec 18 20:32:43 Claimco kernel: smpboot: CPU0: Intel(R) Core(TM) i7-4790K CPU @ 4.00GHz (family: 0x6, model: 0x3c, stepping: 0x3) Dec 18 20:32:43 Claimco kernel: cblist_init_generic: Setting adjustable number of callback queues. Dec 18 20:32:43 Claimco kernel: cblist_init_generic: Setting shift to 3 and lim to 1. ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 18 20:32:43 Claimco kernel: Performance Events: PEBS fmt2+, Haswell events, 16-deep LBR, full-width counters, Intel PMU driver. Dec 18 20:32:43 Claimco kernel: ... version: 3 Dec 18 20:32:43 Claimco kernel: ... bit width: 48 Dec 18 20:32:43 Claimco kernel: ... generic registers: 4 Dec 18 20:32:43 Claimco kernel: ... value mask: 0000ffffffffffff Dec 18 20:32:43 Claimco kernel: ... max period: 00007fffffffffff Dec 18 20:32:43 Claimco kernel: ... fixed-purpose events: 3 Dec 18 20:32:43 Claimco kernel: ... event mask: 000000070000000f Dec 18 20:32:43 Claimco kernel: Estimated ratio of average max frequency by base frequency (times 1024): 1177 Dec 18 20:32:43 Claimco kernel: rcu: Hierarchical SRCU implementation. Dec 18 20:32:43 Claimco kernel: rcu: Max phase no-delay instances is 400. Dec 18 20:32:43 Claimco kernel: smp: Bringing up secondary CPUs ... Dec 18 20:32:43 Claimco kernel: x86: Booting SMP configuration: Dec 18 20:32:43 Claimco kernel: .... node #0, CPUs: #1 #2 #3 #4 Dec 18 20:32:43 Claimco kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details. Dec 18 20:32:43 Claimco kernel: #5 #6 #7 Dec 18 20:32:43 Claimco kernel: smp: Brought up 1 node, 8 CPUs Dec 18 20:32:43 Claimco kernel: smpboot: Max logical packages: 1 Dec 18 20:32:43 Claimco kernel: smpboot: Total of 8 processors activated (63975.92 BogoMIPS) Dec 18 20:32:43 Claimco kernel: devtmpfs: initialized Dec 18 20:32:43 Claimco kernel: x86/mm: Memory block size: 128MB Dec 18 20:32:43 Claimco kernel: ACPI: PM: Registering ACPI NVS region [mem 0xa9aba000-0xa9ac0fff] (28672 bytes) Dec 18 20:32:43 Claimco kernel: ACPI: PM: Registering ACPI NVS region [mem 0xbd1ef000-0xbd329fff] (1290240 bytes) Dec 18 20:32:43 Claimco kernel: clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns Dec 18 20:32:43 Claimco kernel: futex hash table entries: 2048 (order: 5, 131072 bytes, linear) Dec 18 20:32:43 Claimco kernel: pinctrl core: initialized pinctrl subsystem Dec 18 20:32:43 Claimco kernel: NET: Registered PF_NETLINK/PF_ROUTE protocol family Dec 18 20:32:43 Claimco kernel: thermal_sys: Registered thermal governor 'fair_share' Dec 18 20:32:43 Claimco kernel: thermal_sys: Registered thermal governor 'bang_bang' Dec 18 20:32:43 Claimco kernel: thermal_sys: Registered thermal governor 'step_wise' Dec 18 20:32:43 Claimco kernel: thermal_sys: Registered thermal governor 'user_space' Dec 18 20:32:43 Claimco kernel: cpuidle: using governor ladder Dec 18 20:32:43 Claimco kernel: cpuidle: using governor menu Dec 18 20:32:43 Claimco kernel: HugeTLB: can optimize 4095 vmemmap pages for hugepages-1048576kB Dec 18 20:32:43 Claimco kernel: ACPI FADT declares the system doesn't support PCIe ASPM, so disable it Dec 18 20:32:43 Claimco kernel: PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000) Dec 18 20:32:43 Claimco kernel: PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820 Dec 18 20:32:43 Claimco kernel: pmd_set_huge: Cannot satisfy [mem 0xf0000000-0xf0200000] with a huge-page mapping due to MTRR override. Dec 18 20:32:43 Claimco kernel: PCI: Using configuration type 1 for base access Dec 18 20:32:43 Claimco kernel: core: PMU erratum BJ122, BV98, HSD29 worked around, HT is on Dec 18 20:32:43 Claimco kernel: kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible. Dec 18 20:32:43 Claimco kernel: HugeTLB: can optimize 7 vmemmap pages for hugepages-2048kB Dec 18 20:32:43 Claimco kernel: HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages Dec 18 20:32:43 Claimco kernel: HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages Dec 18 20:32:43 Claimco kernel: raid6: avx2x4 gen() 37753 MB/s Dec 18 20:32:43 Claimco kernel: raid6: avx2x2 gen() 36392 MB/s Dec 18 20:32:43 Claimco kernel: raid6: avx2x1 gen() 29126 MB/s Dec 18 20:32:43 Claimco kernel: raid6: using algorithm avx2x4 gen() 37753 MB/s Dec 18 20:32:43 Claimco kernel: raid6: .... xor() 14630 MB/s, rmw enabled Dec 18 20:32:43 Claimco kernel: raid6: using avx2x2 recovery algorithm Dec 18 20:32:43 Claimco kernel: ACPI: Added _OSI(Module Device) Dec 18 20:32:43 Claimco kernel: ACPI: Added _OSI(Processor Device) Dec 18 20:32:43 Claimco kernel: ACPI: Added _OSI(3.0 _SCP Extensions) Dec 18 20:32:43 Claimco kernel: ACPI: Added _OSI(Processor Aggregator Device) Dec 18 20:32:43 Claimco kernel: ACPI: Added _OSI(Linux-Dell-Video) Dec 18 20:32:43 Claimco kernel: ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio) Dec 18 20:32:43 Claimco kernel: ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics) Dec 18 20:32:43 Claimco kernel: ACPI: 7 ACPI AML tables successfully acquired and loaded Dec 18 20:32:43 Claimco kernel: ACPI: Dynamic OEM Table Load: Dec 18 20:32:43 Claimco kernel: ACPI: SSDT 0xFFFF888100207400 0003D3 (v01 PmRef Cpu0Cst 00003001 INTL 20051117) Dec 18 20:32:43 Claimco kernel: ACPI: Dynamic OEM Table Load: Dec 18 20:32:43 Claimco kernel: ACPI: SSDT 0xFFFF8881001F1800 0005AA (v01 PmRef ApIst 00003000 INTL 20051117) Dec 18 20:32:43 Claimco kernel: ACPI: Dynamic OEM Table Load: Dec 18 20:32:43 Claimco kernel: ACPI: SSDT 0xFFFF88810027CC00 000119 (v01 PmRef ApCst 00003000 INTL 20051117) Dec 18 20:32:43 Claimco kernel: ACPI: Interpreter enabled Dec 18 20:32:43 Claimco kernel: ACPI: PM: (supports S0 S3 S5) Dec 18 20:32:43 Claimco kernel: ACPI: Using IOAPIC for interrupt routing Dec 18 20:32:43 Claimco kernel: PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug Dec 18 20:32:43 Claimco kernel: PCI: Using E820 reservations for host bridge windows Dec 18 20:32:43 Claimco kernel: ACPI: Enabled 11 GPEs in block 00 to 3F Dec 18 20:32:43 Claimco kernel: ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-7e]) Dec 18 20:32:43 Claimco kernel: acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3] Dec 18 20:32:43 Claimco kernel: acpi PNP0A08:00: _OSC: platform does not support [PME LTR] Dec 18 20:32:43 Claimco kernel: acpi PNP0A08:00: _OSC: OS now controls [AER PCIeCapability] Dec 18 20:32:43 Claimco kernel: acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration Dec 18 20:32:43 Claimco kernel: PCI host bridge to bus 0000:00 Dec 18 20:32:43 Claimco kernel: pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000e7fff window] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:00: root bus resource [mem 0xcf200000-0xfeafffff window] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:00: root bus resource [bus 00-7e] Dec 18 20:32:43 Claimco kernel: pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000 Dec 18 20:32:43 Claimco kernel: pci 0000:00:01.0: [8086:0c01] type 01 class 0x060400 Dec 18 20:32:43 Claimco kernel: pci 0000:00:01.0: PME# supported from D0 D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:00:01.2: [8086:0c09] type 01 class 0x060400 Dec 18 20:32:43 Claimco kernel: pci 0000:00:01.2: PME# supported from D0 D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:00:02.0: [8086:0412] type 00 class 0x030000 Dec 18 20:32:43 Claimco kernel: pci 0000:00:02.0: reg 0x10: [mem 0xef400000-0xef7fffff 64bit] Dec 18 20:32:43 Claimco kernel: pci 0000:00:02.0: reg 0x18: [mem 0xd0000000-0xdfffffff 64bit pref] Dec 18 20:32:43 Claimco kernel: pci 0000:00:02.0: reg 0x20: [io 0xf000-0xf03f] Dec 18 20:32:43 Claimco kernel: pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:03.0: [8086:0c0c] type 00 class 0x040300 Dec 18 20:32:43 Claimco kernel: pci 0000:00:03.0: reg 0x10: [mem 0xefd34000-0xefd37fff 64bit] Dec 18 20:32:43 Claimco kernel: pci 0000:00:14.0: [8086:8cb1] type 00 class 0x0c0330 Dec 18 20:32:43 Claimco kernel: pci 0000:00:14.0: reg 0x10: [mem 0xefd20000-0xefd2ffff 64bit] Dec 18 20:32:43 Claimco kernel: pci 0000:00:14.0: PME# supported from D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:00:16.0: [8086:8cba] type 00 class 0x078000 Dec 18 20:32:43 Claimco kernel: pci 0000:00:16.0: reg 0x10: [mem 0xefd3e000-0xefd3e00f 64bit] Dec 18 20:32:43 Claimco kernel: pci 0000:00:16.0: PME# supported from D0 D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:00:19.0: [8086:15a1] type 00 class 0x020000 Dec 18 20:32:43 Claimco kernel: pci 0000:00:19.0: reg 0x10: [mem 0xefd00000-0xefd1ffff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:19.0: reg 0x14: [mem 0xefd3c000-0xefd3cfff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:19.0: reg 0x18: [io 0xf080-0xf09f] Dec 18 20:32:43 Claimco kernel: pci 0000:00:19.0: PME# supported from D0 D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:00:1a.0: [8086:8cad] type 00 class 0x0c0320 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1a.0: reg 0x10: [mem 0xefd3b000-0xefd3b3ff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:00:1b.0: [8086:8ca0] type 00 class 0x040300 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1b.0: reg 0x10: [mem 0xefd30000-0xefd33fff 64bit] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.0: [8086:8c90] type 01 class 0x060400 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.0: Enabling MPC IRBNCE Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.0: Intel PCH root port ACS workaround enabled Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.2: [8086:8c94] type 01 class 0x060400 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.2: Enabling MPC IRBNCE Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.2: Intel PCH root port ACS workaround enabled Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.3: [8086:8c96] type 01 class 0x060400 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.3: Enabling MPC IRBNCE Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.3: Intel PCH root port ACS workaround enabled Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.6: [8086:8c9c] type 01 class 0x060400 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.6: Enabling MPC IRBNCE Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.6: Intel PCH root port ACS workaround enabled Dec 18 20:32:43 Claimco kernel: pci 0000:00:1d.0: [8086:8ca6] type 00 class 0x0c0320 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1d.0: reg 0x10: [mem 0xefd3a000-0xefd3a3ff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:00:1f.0: [8086:8cc4] type 00 class 0x060100 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1f.2: [8086:8c82] type 00 class 0x010601 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1f.2: reg 0x10: [io 0xf0d0-0xf0d7] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1f.2: reg 0x14: [io 0xf0c0-0xf0c3] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1f.2: reg 0x18: [io 0xf0b0-0xf0b7] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1f.2: reg 0x1c: [io 0xf0a0-0xf0a3] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1f.2: reg 0x20: [io 0xf060-0xf07f] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1f.2: reg 0x24: [mem 0xefd39000-0xefd397ff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1f.2: PME# supported from D3hot Dec 18 20:32:43 Claimco kernel: pci 0000:00:1f.3: [8086:8ca2] type 00 class 0x0c0500 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1f.3: reg 0x10: [mem 0xefd38000-0xefd380ff 64bit] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1f.3: reg 0x20: [io 0xf040-0xf05f] Dec 18 20:32:43 Claimco kernel: pci 0000:00:01.0: PCI bridge to [bus 01] Dec 18 20:32:43 Claimco kernel: pci 0000:02:00.0: [8086:f1aa] type 00 class 0x010802 Dec 18 20:32:43 Claimco kernel: pci 0000:02:00.0: reg 0x10: [mem 0xefc00000-0xefc03fff 64bit] Dec 18 20:32:43 Claimco kernel: pci 0000:02:00.0: reg 0x1ac: [mem 0x00000000-0x00003fff 64bit] Dec 18 20:32:43 Claimco kernel: pci 0000:02:00.0: VF(n) BAR0 space: [mem 0x00000000-0x00017fff 64bit] (contains BAR0 for 6 VFs) Dec 18 20:32:43 Claimco kernel: pci 0000:00:01.2: PCI bridge to [bus 02] Dec 18 20:32:43 Claimco kernel: pci 0000:00:01.2: bridge window [mem 0xefc00000-0xefcfffff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.0: PCI bridge to [bus 03] Dec 18 20:32:43 Claimco kernel: pci 0000:04:00.0: [10ec:8168] type 00 class 0x020000 Dec 18 20:32:43 Claimco kernel: pci 0000:04:00.0: reg 0x10: [io 0xe000-0xe0ff] Dec 18 20:32:43 Claimco kernel: pci 0000:04:00.0: reg 0x18: [mem 0xefb00000-0xefb00fff 64bit] Dec 18 20:32:43 Claimco kernel: pci 0000:04:00.0: reg 0x20: [mem 0xe0000000-0xe0003fff 64bit pref] Dec 18 20:32:43 Claimco kernel: pci 0000:04:00.0: supports D1 D2 Dec 18 20:32:43 Claimco kernel: pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.2: PCI bridge to [bus 04] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.2: bridge window [io 0xe000-0xefff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.2: bridge window [mem 0xefb00000-0xefbfffff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.2: bridge window [mem 0xe0000000-0xe00fffff 64bit pref] Dec 18 20:32:43 Claimco kernel: pci 0000:05:00.0: [1b21:1184] type 01 class 0x060400 Dec 18 20:32:43 Claimco kernel: pci 0000:05:00.0: enabling Extended Tags Dec 18 20:32:43 Claimco kernel: pci 0000:05:00.0: PME# supported from D0 D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.3: PCI bridge to [bus 05-0a] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.3: bridge window [io 0xc000-0xdfff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.3: bridge window [mem 0xef800000-0xef9fffff] Dec 18 20:32:43 Claimco kernel: pci 0000:06:01.0: [1b21:1184] type 01 class 0x060400 Dec 18 20:32:43 Claimco kernel: pci 0000:06:01.0: enabling Extended Tags Dec 18 20:32:43 Claimco kernel: pci 0000:06:01.0: PME# supported from D0 D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:06:03.0: [1b21:1184] type 01 class 0x060400 Dec 18 20:32:43 Claimco kernel: pci 0000:06:03.0: enabling Extended Tags Dec 18 20:32:43 Claimco kernel: pci 0000:06:03.0: PME# supported from D0 D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:06:05.0: [1b21:1184] type 01 class 0x060400 Dec 18 20:32:43 Claimco kernel: pci 0000:06:05.0: enabling Extended Tags Dec 18 20:32:43 Claimco kernel: pci 0000:06:05.0: PME# supported from D0 D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:06:07.0: [1b21:1184] type 01 class 0x060400 Dec 18 20:32:43 Claimco kernel: pci 0000:06:07.0: enabling Extended Tags Dec 18 20:32:43 Claimco kernel: pci 0000:06:07.0: PME# supported from D0 D3hot D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:05:00.0: PCI bridge to [bus 06-0a] Dec 18 20:32:43 Claimco kernel: pci 0000:05:00.0: bridge window [io 0xc000-0xdfff] Dec 18 20:32:43 Claimco kernel: pci 0000:05:00.0: bridge window [mem 0xef800000-0xef9fffff] Dec 18 20:32:43 Claimco kernel: pci 0000:06:01.0: PCI bridge to [bus 07] Dec 18 20:32:43 Claimco kernel: pci 0000:08:00.0: [1b21:0612] type 00 class 0x010601 Dec 18 20:32:43 Claimco kernel: pci 0000:08:00.0: reg 0x10: [io 0xd050-0xd057] Dec 18 20:32:43 Claimco kernel: pci 0000:08:00.0: reg 0x14: [io 0xd040-0xd043] Dec 18 20:32:43 Claimco kernel: pci 0000:08:00.0: reg 0x18: [io 0xd030-0xd037] Dec 18 20:32:43 Claimco kernel: pci 0000:08:00.0: reg 0x1c: [io 0xd020-0xd023] Dec 18 20:32:43 Claimco kernel: pci 0000:08:00.0: reg 0x20: [io 0xd000-0xd01f] Dec 18 20:32:43 Claimco kernel: pci 0000:08:00.0: reg 0x24: [mem 0xef900000-0xef9001ff] Dec 18 20:32:43 Claimco kernel: pci 0000:06:03.0: PCI bridge to [bus 08] Dec 18 20:32:43 Claimco kernel: pci 0000:06:03.0: bridge window [io 0xd000-0xdfff] Dec 18 20:32:43 Claimco kernel: pci 0000:06:03.0: bridge window [mem 0xef900000-0xef9fffff] Dec 18 20:32:43 Claimco kernel: pci 0000:06:05.0: PCI bridge to [bus 09] Dec 18 20:32:43 Claimco kernel: pci 0000:0a:00.0: [1b21:0612] type 00 class 0x010601 Dec 18 20:32:43 Claimco kernel: pci 0000:0a:00.0: reg 0x10: [io 0xc050-0xc057] Dec 18 20:32:43 Claimco kernel: pci 0000:0a:00.0: reg 0x14: [io 0xc040-0xc043] Dec 18 20:32:43 Claimco kernel: pci 0000:0a:00.0: reg 0x18: [io 0xc030-0xc037] Dec 18 20:32:43 Claimco kernel: pci 0000:0a:00.0: reg 0x1c: [io 0xc020-0xc023] Dec 18 20:32:43 Claimco kernel: pci 0000:0a:00.0: reg 0x20: [io 0xc000-0xc01f] Dec 18 20:32:43 Claimco kernel: pci 0000:0a:00.0: reg 0x24: [mem 0xef800000-0xef8001ff] Dec 18 20:32:43 Claimco kernel: pci 0000:06:07.0: PCI bridge to [bus 0a] Dec 18 20:32:43 Claimco kernel: pci 0000:06:07.0: bridge window [io 0xc000-0xcfff] Dec 18 20:32:43 Claimco kernel: pci 0000:06:07.0: bridge window [mem 0xef800000-0xef8fffff] Dec 18 20:32:43 Claimco kernel: pci 0000:0b:00.0: [1b21:1142] type 00 class 0x0c0330 Dec 18 20:32:43 Claimco kernel: pci 0000:0b:00.0: reg 0x10: [mem 0xefa00000-0xefa07fff 64bit] Dec 18 20:32:43 Claimco kernel: pci 0000:0b:00.0: PME# supported from D3cold Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.6: PCI bridge to [bus 0b] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.6: bridge window [mem 0xefa00000-0xefafffff] Dec 18 20:32:43 Claimco kernel: ACPI: PCI: Interrupt link LNKA configured for IRQ 11 Dec 18 20:32:43 Claimco kernel: ACPI: PCI: Interrupt link LNKB configured for IRQ 0 Dec 18 20:32:43 Claimco kernel: ACPI: PCI: Interrupt link LNKB disabled Dec 18 20:32:43 Claimco kernel: ACPI: PCI: Interrupt link LNKC configured for IRQ 10 Dec 18 20:32:43 Claimco kernel: ACPI: PCI: Interrupt link LNKD configured for IRQ 5 Dec 18 20:32:43 Claimco kernel: ACPI: PCI: Interrupt link LNKE configured for IRQ 3 Dec 18 20:32:43 Claimco kernel: ACPI: PCI: Interrupt link LNKF configured for IRQ 0 Dec 18 20:32:43 Claimco kernel: ACPI: PCI: Interrupt link LNKF disabled Dec 18 20:32:43 Claimco kernel: ACPI: PCI: Interrupt link LNKG configured for IRQ 11 Dec 18 20:32:43 Claimco kernel: ACPI: PCI: Interrupt link LNKH configured for IRQ 10 Dec 18 20:32:43 Claimco kernel: iommu: Default domain type: Passthrough Dec 18 20:32:43 Claimco kernel: SCSI subsystem initialized Dec 18 20:32:43 Claimco kernel: libata version 3.00 loaded. Dec 18 20:32:43 Claimco kernel: ACPI: bus type USB registered Dec 18 20:32:43 Claimco kernel: usbcore: registered new interface driver usbfs Dec 18 20:32:43 Claimco kernel: usbcore: registered new interface driver hub Dec 18 20:32:43 Claimco kernel: usbcore: registered new device driver usb Dec 18 20:32:43 Claimco kernel: pps_core: LinuxPPS API ver. 1 registered Dec 18 20:32:43 Claimco kernel: pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]> Dec 18 20:32:43 Claimco kernel: PTP clock support registered Dec 18 20:32:43 Claimco kernel: PCI: Using ACPI for IRQ routing Dec 18 20:32:43 Claimco kernel: PCI: pci_cache_line_size set to 64 bytes Dec 18 20:32:43 Claimco kernel: e820: reserve RAM buffer [mem 0x0009d800-0x0009ffff] Dec 18 20:32:43 Claimco kernel: e820: reserve RAM buffer [mem 0xa9aba000-0xabffffff] Dec 18 20:32:43 Claimco kernel: e820: reserve RAM buffer [mem 0xaa788000-0xabffffff] Dec 18 20:32:43 Claimco kernel: e820: reserve RAM buffer [mem 0xbcd4e000-0xbfffffff] Dec 18 20:32:43 Claimco kernel: e820: reserve RAM buffer [mem 0xbd1ef000-0xbfffffff] Dec 18 20:32:43 Claimco kernel: e820: reserve RAM buffer [mem 0xbe000000-0xbfffffff] Dec 18 20:32:43 Claimco kernel: e820: reserve RAM buffer [mem 0x82fe00000-0x82fffffff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:02.0: vgaarb: setting as boot VGA device Dec 18 20:32:43 Claimco kernel: pci 0000:00:02.0: vgaarb: bridge control possible Dec 18 20:32:43 Claimco kernel: pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none Dec 18 20:32:43 Claimco kernel: vgaarb: loaded Dec 18 20:32:43 Claimco kernel: hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0 Dec 18 20:32:43 Claimco kernel: hpet0: 8 comparators, 64-bit 14.318180 MHz counter Dec 18 20:32:43 Claimco kernel: clocksource: Switched to clocksource tsc-early Dec 18 20:32:43 Claimco kernel: FS-Cache: Loaded Dec 18 20:32:43 Claimco kernel: pnp: PnP ACPI init Dec 18 20:32:43 Claimco kernel: system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved Dec 18 20:32:43 Claimco kernel: system 00:01: [io 0x0800-0x087f] has been reserved Dec 18 20:32:43 Claimco kernel: system 00:03: [io 0x1854-0x1857] has been reserved Dec 18 20:32:43 Claimco kernel: system 00:04: [io 0x0290-0x029f] has been reserved Dec 18 20:32:43 Claimco kernel: system 00:05: [io 0x04d0-0x04d1] has been reserved Dec 18 20:32:43 Claimco kernel: pnp 00:06: [dma 0 disabled] Dec 18 20:32:43 Claimco kernel: system 00:07: [mem 0xfed1c000-0xfed1ffff] has been reserved Dec 18 20:32:43 Claimco kernel: system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved Dec 18 20:32:43 Claimco kernel: system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved Dec 18 20:32:43 Claimco kernel: system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved Dec 18 20:32:43 Claimco kernel: system 00:07: [mem 0xf0000000-0xf7ffffff] has been reserved Dec 18 20:32:43 Claimco kernel: system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved Dec 18 20:32:43 Claimco kernel: system 00:07: [mem 0xfed90000-0xfed93fff] could not be reserved Dec 18 20:32:43 Claimco kernel: system 00:07: [mem 0xfed45000-0xfed8ffff] has been reserved Dec 18 20:32:43 Claimco kernel: system 00:07: [mem 0xff000000-0xffffffff] has been reserved Dec 18 20:32:43 Claimco kernel: system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved Dec 18 20:32:43 Claimco kernel: system 00:07: [mem 0xeffe0000-0xeffeffff] has been reserved Dec 18 20:32:43 Claimco kernel: pnp: PnP ACPI: found 8 devices Dec 18 20:32:43 Claimco kernel: clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns Dec 18 20:32:43 Claimco kernel: NET: Registered PF_INET protocol family Dec 18 20:32:43 Claimco kernel: IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear) Dec 18 20:32:43 Claimco kernel: tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear) Dec 18 20:32:43 Claimco kernel: Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear) Dec 18 20:32:43 Claimco kernel: TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear) Dec 18 20:32:43 Claimco kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear) Dec 18 20:32:43 Claimco kernel: TCP: Hash tables configured (established 262144 bind 65536) Dec 18 20:32:43 Claimco kernel: UDP hash table entries: 16384 (order: 7, 524288 bytes, linear) Dec 18 20:32:43 Claimco kernel: UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear) Dec 18 20:32:43 Claimco kernel: pci_bus 0000:00: max bus depth: 3 pci_try_num: 4 Dec 18 20:32:43 Claimco kernel: pci 0000:00:01.0: PCI bridge to [bus 01] Dec 18 20:32:43 Claimco kernel: pci 0000:02:00.0: BAR 7: assigned [mem 0xefc04000-0xefc1bfff 64bit] Dec 18 20:32:43 Claimco kernel: pci 0000:00:01.2: PCI bridge to [bus 02] Dec 18 20:32:43 Claimco kernel: pci 0000:00:01.2: bridge window [mem 0xefc00000-0xefcfffff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.0: PCI bridge to [bus 03] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.2: PCI bridge to [bus 04] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.2: bridge window [io 0xe000-0xefff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.2: bridge window [mem 0xefb00000-0xefbfffff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.2: bridge window [mem 0xe0000000-0xe00fffff 64bit pref] Dec 18 20:32:43 Claimco kernel: pci 0000:06:01.0: PCI bridge to [bus 07] Dec 18 20:32:43 Claimco kernel: pci 0000:06:03.0: PCI bridge to [bus 08] Dec 18 20:32:43 Claimco kernel: pci 0000:06:03.0: bridge window [io 0xd000-0xdfff] Dec 18 20:32:43 Claimco kernel: pci 0000:06:03.0: bridge window [mem 0xef900000-0xef9fffff] Dec 18 20:32:43 Claimco kernel: pci 0000:06:05.0: PCI bridge to [bus 09] Dec 18 20:32:43 Claimco kernel: pci 0000:06:07.0: PCI bridge to [bus 0a] Dec 18 20:32:43 Claimco kernel: pci 0000:06:07.0: bridge window [io 0xc000-0xcfff] Dec 18 20:32:43 Claimco kernel: pci 0000:06:07.0: bridge window [mem 0xef800000-0xef8fffff] Dec 18 20:32:43 Claimco kernel: pci 0000:05:00.0: PCI bridge to [bus 06-0a] Dec 18 20:32:43 Claimco kernel: pci 0000:05:00.0: bridge window [io 0xc000-0xdfff] Dec 18 20:32:43 Claimco kernel: pci 0000:05:00.0: bridge window [mem 0xef800000-0xef9fffff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.3: PCI bridge to [bus 05-0a] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.3: bridge window [io 0xc000-0xdfff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.3: bridge window [mem 0xef800000-0xef9fffff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.6: PCI bridge to [bus 0b] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.6: bridge window [mem 0xefa00000-0xefafffff] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000e7fff window] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:00: resource 8 [mem 0xcf200000-0xfeafffff window] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:02: resource 1 [mem 0xefc00000-0xefcfffff] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:04: resource 0 [io 0xe000-0xefff] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:04: resource 1 [mem 0xefb00000-0xefbfffff] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:04: resource 2 [mem 0xe0000000-0xe00fffff 64bit pref] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:05: resource 0 [io 0xc000-0xdfff] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:05: resource 1 [mem 0xef800000-0xef9fffff] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:06: resource 0 [io 0xc000-0xdfff] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:06: resource 1 [mem 0xef800000-0xef9fffff] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:08: resource 0 [io 0xd000-0xdfff] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:08: resource 1 [mem 0xef900000-0xef9fffff] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:0a: resource 0 [io 0xc000-0xcfff] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:0a: resource 1 [mem 0xef800000-0xef8fffff] Dec 18 20:32:43 Claimco kernel: pci_bus 0000:0b: resource 1 [mem 0xefa00000-0xefafffff] Dec 18 20:32:43 Claimco kernel: pci 0000:00:1a.0: quirk_usb_early_handoff+0x0/0x63b took 16414 usecs Dec 18 20:32:43 Claimco kernel: pci 0000:00:1d.0: quirk_usb_early_handoff+0x0/0x63b took 16221 usecs Dec 18 20:32:43 Claimco kernel: PCI: CLS 64 bytes, default 64 Dec 18 20:32:43 Claimco kernel: DMAR: No ATSR found Dec 18 20:32:43 Claimco kernel: Unpacking initramfs... Dec 18 20:32:43 Claimco kernel: DMAR: No SATC found Dec 18 20:32:43 Claimco kernel: DMAR: IOMMU feature pgsel_inv inconsistent Dec 18 20:32:43 Claimco kernel: DMAR: IOMMU feature sc_support inconsistent Dec 18 20:32:43 Claimco kernel: DMAR: IOMMU feature pass_through inconsistent Dec 18 20:32:43 Claimco kernel: DMAR: dmar0: Using Queued invalidation Dec 18 20:32:43 Claimco kernel: DMAR: dmar1: Using Queued invalidation Dec 18 20:32:43 Claimco kernel: pci 0000:00:00.0: Adding to iommu group 0 Dec 18 20:32:43 Claimco kernel: pci 0000:00:01.0: Adding to iommu group 1 Dec 18 20:32:43 Claimco kernel: pci 0000:00:01.2: Adding to iommu group 1 Dec 18 20:32:43 Claimco kernel: pci 0000:00:02.0: Adding to iommu group 2 Dec 18 20:32:43 Claimco kernel: pci 0000:00:03.0: Adding to iommu group 3 Dec 18 20:32:43 Claimco kernel: pci 0000:00:14.0: Adding to iommu group 4 Dec 18 20:32:43 Claimco kernel: pci 0000:00:16.0: Adding to iommu group 5 Dec 18 20:32:43 Claimco kernel: pci 0000:00:19.0: Adding to iommu group 6 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1a.0: Adding to iommu group 7 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1b.0: Adding to iommu group 8 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.0: Adding to iommu group 9 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.2: Adding to iommu group 10 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.3: Adding to iommu group 11 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1c.6: Adding to iommu group 12 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1d.0: Adding to iommu group 13 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1f.0: Adding to iommu group 14 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1f.2: Adding to iommu group 14 Dec 18 20:32:43 Claimco kernel: pci 0000:00:1f.3: Adding to iommu group 14 Dec 18 20:32:43 Claimco kernel: pci 0000:02:00.0: Adding to iommu group 1 Dec 18 20:32:43 Claimco kernel: pci 0000:04:00.0: Adding to iommu group 15 Dec 18 20:32:43 Claimco kernel: pci 0000:05:00.0: Adding to iommu group 16 Dec 18 20:32:43 Claimco kernel: pci 0000:06:01.0: Adding to iommu group 17 Dec 18 20:32:43 Claimco kernel: pci 0000:06:03.0: Adding to iommu group 18 Dec 18 20:32:43 Claimco kernel: pci 0000:06:05.0: Adding to iommu group 19 Dec 18 20:32:43 Claimco kernel: pci 0000:06:07.0: Adding to iommu group 20 Dec 18 20:32:43 Claimco kernel: pci 0000:08:00.0: Adding to iommu group 18 Dec 18 20:32:43 Claimco kernel: pci 0000:0a:00.0: Adding to iommu group 20 Dec 18 20:32:43 Claimco kernel: pci 0000:0b:00.0: Adding to iommu group 21 Dec 18 20:32:43 Claimco kernel: DMAR: Intel(R) Virtualization Technology for Directed I/O Dec 18 20:32:43 Claimco kernel: PCI-DMA: Using software bounce buffering for IO (SWIOTLB) Dec 18 20:32:43 Claimco kernel: software IO TLB: mapped [mem 0x00000000b8d4e000-0x00000000bcd4e000] (64MB) Dec 18 20:32:43 Claimco kernel: workingset: timestamp_bits=40 max_order=23 bucket_order=0 Dec 18 20:32:43 Claimco kernel: squashfs: version 4.0 (2009/01/31) Phillip Lougher Dec 18 20:32:43 Claimco kernel: fuse: init (API version 7.36) Dec 18 20:32:43 Claimco kernel: xor: automatically using best checksumming function avx Dec 18 20:32:43 Claimco kernel: Key type asymmetric registered Dec 18 20:32:43 Claimco kernel: Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250) Dec 18 20:32:43 Claimco kernel: io scheduler mq-deadline registered Dec 18 20:32:43 Claimco kernel: io scheduler kyber registered Dec 18 20:32:43 Claimco kernel: io scheduler bfq registered Dec 18 20:32:43 Claimco kernel: IPMI message handler: version 39.2 Dec 18 20:32:43 Claimco kernel: Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled Dec 18 20:32:43 Claimco kernel: 00:06: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A Dec 18 20:32:43 Claimco kernel: tsc: Refined TSC clocksource calibration: 3998.839 MHz Dec 18 20:32:43 Claimco kernel: clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x734828d9c6f, max_idle_ns: 881591008321 ns Dec 18 20:32:43 Claimco kernel: clocksource: Switched to clocksource tsc Dec 18 20:32:43 Claimco kernel: Freeing initrd memory: 161528K Dec 18 20:32:43 Claimco kernel: lp: driver loaded but no devices found Dec 18 20:32:43 Claimco kernel: Hangcheck: starting hangcheck timer 0.9.1 (tick is 180 seconds, margin is 60 seconds). Dec 18 20:32:43 Claimco kernel: AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug. Dec 18 20:32:43 Claimco kernel: loop: module loaded Dec 18 20:32:43 Claimco kernel: Rounding down aligned max_sectors from 4294967295 to 4294967288 Dec 18 20:32:43 Claimco kernel: db_root: cannot open: /etc/target Dec 18 20:32:43 Claimco kernel: VFIO - User Level meta-driver version: 0.3 Dec 18 20:32:43 Claimco kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver Dec 18 20:32:43 Claimco kernel: ehci-pci: EHCI PCI platform driver Dec 18 20:32:43 Claimco kernel: ehci-pci 0000:00:1a.0: EHCI Host Controller Dec 18 20:32:43 Claimco kernel: ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 1 Dec 18 20:32:43 Claimco kernel: ehci-pci 0000:00:1a.0: debug port 2 Dec 18 20:32:43 Claimco kernel: ehci-pci 0000:00:1a.0: irq 16, io mem 0xefd3b000 Dec 18 20:32:43 Claimco kernel: ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00 Dec 18 20:32:43 Claimco kernel: hub 1-0:1.0: USB hub found Dec 18 20:32:43 Claimco kernel: hub 1-0:1.0: 2 ports detected Dec 18 20:32:43 Claimco kernel: ehci-pci 0000:00:1d.0: EHCI Host Controller Dec 18 20:32:43 Claimco kernel: ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 2 Dec 18 20:32:43 Claimco kernel: ehci-pci 0000:00:1d.0: debug port 2 Dec 18 20:32:43 Claimco kernel: ehci-pci 0000:00:1d.0: irq 23, io mem 0xefd3a000 Dec 18 20:32:43 Claimco kernel: ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00 Dec 18 20:32:43 Claimco kernel: hub 2-0:1.0: USB hub found Dec 18 20:32:43 Claimco kernel: hub 2-0:1.0: 2 ports detected Dec 18 20:32:43 Claimco kernel: ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver Dec 18 20:32:43 Claimco kernel: ohci-pci: OHCI PCI platform driver Dec 18 20:32:43 Claimco kernel: uhci_hcd: USB Universal Host Controller Interface driver Dec 18 20:32:43 Claimco kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller Dec 18 20:32:43 Claimco kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3 Dec 18 20:32:43 Claimco kernel: xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000000009810 Dec 18 20:32:43 Claimco kernel: xhci_hcd 0000:00:14.0: xHCI Host Controller Dec 18 20:32:43 Claimco kernel: xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4 Dec 18 20:32:43 Claimco kernel: xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed Dec 18 20:32:43 Claimco kernel: hub 3-0:1.0: USB hub found Dec 18 20:32:43 Claimco kernel: hub 3-0:1.0: 14 ports detected Dec 18 20:32:43 Claimco kernel: hub 4-0:1.0: USB hub found Dec 18 20:32:43 Claimco kernel: hub 4-0:1.0: 6 ports detected Dec 18 20:32:43 Claimco kernel: xhci_hcd 0000:0b:00.0: xHCI Host Controller Dec 18 20:32:43 Claimco kernel: xhci_hcd 0000:0b:00.0: new USB bus registered, assigned bus number 5 Dec 18 20:32:43 Claimco kernel: xhci_hcd 0000:0b:00.0: hcc params 0x0200e080 hci version 0x100 quirks 0x0000000010800410 Dec 18 20:32:43 Claimco kernel: xhci_hcd 0000:0b:00.0: xHCI Host Controller Dec 18 20:32:43 Claimco kernel: xhci_hcd 0000:0b:00.0: new USB bus registered, assigned bus number 6 Dec 18 20:32:43 Claimco kernel: xhci_hcd 0000:0b:00.0: Host supports USB 3.0 SuperSpeed Dec 18 20:32:43 Claimco kernel: hub 5-0:1.0: USB hub found Dec 18 20:32:43 Claimco kernel: hub 5-0:1.0: 2 ports detected Dec 18 20:32:43 Claimco kernel: usb usb6: We don't know the algorithms for LPM for this host, disabling LPM. Dec 18 20:32:43 Claimco kernel: hub 6-0:1.0: USB hub found Dec 18 20:32:43 Claimco kernel: hub 6-0:1.0: 2 ports detected Dec 18 20:32:43 Claimco kernel: usbcore: registered new interface driver usb-storage Dec 18 20:32:43 Claimco kernel: i8042: PNP: No PS/2 controller found. Dec 18 20:32:43 Claimco kernel: mousedev: PS/2 mouse device common for all mice Dec 18 20:32:43 Claimco kernel: usbcore: registered new interface driver synaptics_usb Dec 18 20:32:43 Claimco kernel: input: PC Speaker as /devices/platform/pcspkr/input/input0 Dec 18 20:32:43 Claimco kernel: rtc_cmos 00:02: RTC can wake from S4 Dec 18 20:32:43 Claimco kernel: rtc_cmos 00:02: registered as rtc0 Dec 18 20:32:43 Claimco kernel: rtc_cmos 00:02: setting system clock to 2022-12-19T04:32:22 UTC (1671424342) Dec 18 20:32:43 Claimco kernel: rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram, hpet irqs Dec 18 20:32:43 Claimco kernel: intel_pstate: Intel P-state driver initializing Dec 18 20:32:43 Claimco kernel: hid: raw HID events driver (C) Jiri Kosina Dec 18 20:32:43 Claimco kernel: usbcore: registered new interface driver usbhid Dec 18 20:32:43 Claimco kernel: usbhid: USB HID core driver Dec 18 20:32:43 Claimco kernel: ipip: IPv4 and MPLS over IPv4 tunneling driver Dec 18 20:32:43 Claimco kernel: NET: Registered PF_INET6 protocol family Dec 18 20:32:43 Claimco kernel: Segment Routing with IPv6 Dec 18 20:32:43 Claimco kernel: RPL Segment Routing with IPv6 Dec 18 20:32:43 Claimco kernel: In-situ OAM (IOAM) with IPv6 Dec 18 20:32:43 Claimco kernel: 9pnet: Installing 9P2000 support Dec 18 20:32:43 Claimco kernel: microcode: sig=0x306c3, pf=0x2, revision=0x28 Dec 18 20:32:43 Claimco kernel: microcode: Microcode Update Driver: v2.2. Dec 18 20:32:43 Claimco kernel: IPI shorthand broadcast: enabled Dec 18 20:32:43 Claimco kernel: sched_clock: Marking stable (11398344270, 6470341)->(11407941959, -3127348) Dec 18 20:32:43 Claimco kernel: registered taskstats version 1 Dec 18 20:32:43 Claimco kernel: Btrfs loaded, crc32c=crc32c-generic, zoned=no, fsverity=no Dec 18 20:32:43 Claimco kernel: usb 1-1: new high-speed USB device number 2 using ehci-pci Dec 18 20:32:43 Claimco kernel: usb 3-9: new high-speed USB device number 2 using xhci_hcd Dec 18 20:32:43 Claimco kernel: usb 2-1: new high-speed USB device number 2 using ehci-pci Dec 18 20:32:43 Claimco kernel: hub 1-1:1.0: USB hub found Dec 18 20:32:43 Claimco kernel: hub 1-1:1.0: 6 ports detected Dec 18 20:32:43 Claimco kernel: hub 3-9:1.0: USB hub found Dec 18 20:32:43 Claimco kernel: hub 3-9:1.0: 4 ports detected Dec 18 20:32:43 Claimco kernel: hub 2-1:1.0: USB hub found Dec 18 20:32:43 Claimco kernel: hub 2-1:1.0: 8 ports detected Dec 18 20:32:43 Claimco kernel: usb 4-3: new SuperSpeed USB device number 2 using xhci_hcd Dec 18 20:32:43 Claimco kernel: hub 4-3:1.0: USB hub found Dec 18 20:32:43 Claimco kernel: hub 4-3:1.0: 4 ports detected Dec 18 20:32:43 Claimco kernel: usb 3-9.3: new high-speed USB device number 3 using xhci_hcd Dec 18 20:32:43 Claimco kernel: usb-storage 3-9.3:1.0: USB Mass Storage device detected Dec 18 20:32:43 Claimco kernel: scsi host0: usb-storage 3-9.3:1.0 Dec 18 20:32:43 Claimco kernel: scsi 0:0:0:0: Direct-Access Memorex TRAVELDRIVE 005B PMAP PQ: 0 ANSI: 0 CCS Dec 18 20:32:43 Claimco kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0 Dec 18 20:32:43 Claimco kernel: sd 0:0:0:0: [sda] 31277056 512-byte logical blocks: (16.0 GB/14.9 GiB) Dec 18 20:32:43 Claimco kernel: sd 0:0:0:0: [sda] Write Protect is off Dec 18 20:32:43 Claimco kernel: sd 0:0:0:0: [sda] Mode Sense: 23 00 00 00 Dec 18 20:32:43 Claimco kernel: sd 0:0:0:0: [sda] No Caching mode page found Dec 18 20:32:43 Claimco kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through Dec 18 20:32:43 Claimco kernel: floppy0: no floppy controllers found Dec 18 20:32:43 Claimco kernel: sda: sda1 Dec 18 20:32:43 Claimco kernel: sd 0:0:0:0: [sda] Attached SCSI removable disk Dec 18 20:32:43 Claimco kernel: Freeing unused kernel image (initmem) memory: 1836K Dec 18 20:32:43 Claimco kernel: Write protecting the kernel read-only data: 18432k Dec 18 20:32:43 Claimco kernel: Freeing unused kernel image (text/rodata gap) memory: 2040K Dec 18 20:32:43 Claimco kernel: Freeing unused kernel image (rodata/data gap) memory: 180K Dec 18 20:32:43 Claimco kernel: rodata_test: all tests were successful Dec 18 20:32:43 Claimco kernel: Run /init as init process Dec 18 20:32:43 Claimco kernel: with arguments: Dec 18 20:32:43 Claimco kernel: /init Dec 18 20:32:43 Claimco kernel: with environment: Dec 18 20:32:43 Claimco kernel: HOME=/ Dec 18 20:32:43 Claimco kernel: TERM=linux Dec 18 20:32:43 Claimco kernel: BOOT_IMAGE=/bzimage Dec 18 20:32:43 Claimco kernel: random: crng init done Dec 18 20:32:43 Claimco kernel: loop0: detected capacity change from 0 to 241472 Dec 18 20:32:43 Claimco kernel: loop1: detected capacity change from 0 to 39792 Dec 18 20:32:43 Claimco kernel: NET: Registered PF_UNIX/PF_LOCAL protocol family Dec 18 20:32:43 Claimco kernel: input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1 Dec 18 20:32:43 Claimco kernel: ACPI: button: Power Button [PWRB] Dec 18 20:32:43 Claimco kernel: input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2 Dec 18 20:32:43 Claimco kernel: ACPI: button: Sleep Button [SLPB] Dec 18 20:32:43 Claimco kernel: input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3 Dec 18 20:32:43 Claimco kernel: ACPI: button: Power Button [PWRF] Dec 18 20:32:43 Claimco kernel: e1000e: Intel(R) PRO/1000 Network Driver Dec 18 20:32:43 Claimco kernel: e1000e: Copyright(c) 1999 - 2015 Intel Corporation. Dec 18 20:32:43 Claimco kernel: ahci 0000:00:1f.2: version 3.0 Dec 18 20:32:43 Claimco kernel: e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode Dec 18 20:32:43 Claimco kernel: ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3f impl SATA mode Dec 18 20:32:43 Claimco kernel: ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst Dec 18 20:32:43 Claimco kernel: r8169 0000:04:00.0: can't disable ASPM; OS doesn't have ASPM control Dec 18 20:32:43 Claimco kernel: i801_smbus 0000:00:1f.3: SPD Write Disable is set Dec 18 20:32:43 Claimco kernel: i801_smbus 0000:00:1f.3: SMBus using PCI interrupt Dec 18 20:32:43 Claimco kernel: i2c i2c-0: 4/4 memory slots populated (from DMI) Dec 18 20:32:43 Claimco kernel: nvme nvme0: pci function 0000:02:00.0 Dec 18 20:32:43 Claimco kernel: i2c i2c-0: Successfully instantiated SPD at 0x50 Dec 18 20:32:43 Claimco kernel: i2c i2c-0: Successfully instantiated SPD at 0x51 Dec 18 20:32:43 Claimco kernel: i2c i2c-0: Successfully instantiated SPD at 0x52 Dec 18 20:32:43 Claimco kernel: i2c i2c-0: Successfully instantiated SPD at 0x53 Dec 18 20:32:43 Claimco kernel: r8169 0000:04:00.0 eth0: RTL8168g/8111g, d0:50:99:5a:1b:96, XID 4c0, IRQ 49 Dec 18 20:32:43 Claimco kernel: r8169 0000:04:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko] Dec 18 20:32:43 Claimco kernel: scsi host1: ahci Dec 18 20:32:43 Claimco kernel: scsi host2: ahci Dec 18 20:32:43 Claimco kernel: scsi host3: ahci Dec 18 20:32:43 Claimco kernel: scsi host4: ahci Dec 18 20:32:43 Claimco kernel: scsi host5: ahci Dec 18 20:32:43 Claimco kernel: scsi host6: ahci Dec 18 20:32:43 Claimco kernel: ata1: SATA max UDMA/133 abar m2048@0xefd39000 port 0xefd39100 irq 46 Dec 18 20:32:43 Claimco kernel: ata2: SATA max UDMA/133 abar m2048@0xefd39000 port 0xefd39180 irq 46 Dec 18 20:32:43 Claimco kernel: ata3: SATA max UDMA/133 abar m2048@0xefd39000 port 0xefd39200 irq 46 Dec 18 20:32:43 Claimco kernel: ata4: SATA max UDMA/133 abar m2048@0xefd39000 port 0xefd39280 irq 46 Dec 18 20:32:43 Claimco kernel: ata5: SATA max UDMA/133 abar m2048@0xefd39000 port 0xefd39300 irq 46 Dec 18 20:32:43 Claimco kernel: ata6: SATA max UDMA/133 abar m2048@0xefd39000 port 0xefd39380 irq 46 Dec 18 20:32:43 Claimco kernel: ahci 0000:08:00.0: SSS flag set, parallel bus scan disabled Dec 18 20:32:43 Claimco kernel: ahci 0000:08:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl SATA mode Dec 18 20:32:43 Claimco kernel: ahci 0000:08:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc sxs Dec 18 20:32:43 Claimco kernel: scsi host7: ahci Dec 18 20:32:43 Claimco kernel: scsi host8: ahci Dec 18 20:32:43 Claimco kernel: ata7: SATA max UDMA/133 abar m512@0xef900000 port 0xef900100 irq 50 Dec 18 20:32:43 Claimco kernel: ata8: SATA max UDMA/133 abar m512@0xef900000 port 0xef900180 irq 50 Dec 18 20:32:43 Claimco kernel: ahci 0000:0a:00.0: SSS flag set, parallel bus scan disabled Dec 18 20:32:43 Claimco kernel: ahci 0000:0a:00.0: AHCI 0001.0200 32 slots 2 ports 6 Gbps 0x3 impl SATA mode Dec 18 20:32:43 Claimco kernel: ahci 0000:0a:00.0: flags: 64bit ncq sntf stag led clo pmp pio slum part ccc sxs Dec 18 20:32:43 Claimco kernel: nvme nvme0: 8/0/0 default/read/poll queues Dec 18 20:32:43 Claimco kernel: scsi host9: ahci Dec 18 20:32:43 Claimco kernel: scsi host10: ahci Dec 18 20:32:43 Claimco kernel: ata9: SATA max UDMA/133 abar m512@0xef800000 port 0xef800100 irq 59 Dec 18 20:32:43 Claimco kernel: ata10: SATA max UDMA/133 abar m512@0xef800000 port 0xef800180 irq 59 Dec 18 20:32:43 Claimco kernel: nvme0n1: p1 Dec 18 20:32:43 Claimco kernel: Linux agpgart interface v0.103 Dec 18 20:32:43 Claimco kernel: RAPL PMU: API unit is 2^-32 Joules, 4 fixed counters, 655360 ms ovfl timer Dec 18 20:32:43 Claimco kernel: RAPL PMU: hw unit of domain pp0-core 2^-14 Joules Dec 18 20:32:43 Claimco kernel: RAPL PMU: hw unit of domain package 2^-14 Joules Dec 18 20:32:43 Claimco kernel: RAPL PMU: hw unit of domain dram 2^-14 Joules Dec 18 20:32:43 Claimco kernel: RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules Dec 18 20:32:43 Claimco kernel: e1000e 0000:00:19.0 0000:00:19.0 (uninitialized): registered PHC clock Dec 18 20:32:43 Claimco kernel: cryptd: max_cpu_qlen set to 1000 Dec 18 20:32:43 Claimco kernel: AVX2 version of gcm_enc/dec engaged. Dec 18 20:32:43 Claimco kernel: AES CTR mode by8 optimization enabled Dec 18 20:32:43 Claimco kernel: e1000e 0000:00:19.0 eth1: (PCI Express:2.5GT/s:Width x1) d0:50:99:5a:1b:98 Dec 18 20:32:43 Claimco kernel: e1000e 0000:00:19.0 eth1: Intel(R) PRO/1000 Network Connection Dec 18 20:32:43 Claimco kernel: e1000e 0000:00:19.0 eth1: MAC: 11, PHY: 12, PBA No: FFFFFF-0FF Dec 18 20:32:43 Claimco kernel: ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300) Dec 18 20:32:43 Claimco kernel: ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300) Dec 18 20:32:43 Claimco kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Dec 18 20:32:43 Claimco kernel: ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Dec 18 20:32:43 Claimco kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300) Dec 18 20:32:43 Claimco kernel: ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Dec 18 20:32:43 Claimco kernel: ata2.00: ATA-9: WDC WD4005FZBX-00K5WB0, 01.01A01, max UDMA/133 Dec 18 20:32:43 Claimco kernel: ata6.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out Dec 18 20:32:43 Claimco kernel: ata6.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out Dec 18 20:32:43 Claimco kernel: ata4.00: ATA-8: ST32000542AS, CC38, max UDMA/133 Dec 18 20:32:43 Claimco kernel: ata4.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32) Dec 18 20:32:43 Claimco kernel: ata1.00: ATA-8: ST32000644NS, SN12, max UDMA/133 Dec 18 20:32:43 Claimco kernel: ata1.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32) Dec 18 20:32:43 Claimco kernel: ata6.00: ATA-8: WDC WD6400AAKS-22A7B2, 01.03B01, max UDMA/133 Dec 18 20:32:43 Claimco kernel: ata6.00: 1250263728 sectors, multi 16: LBA48 NCQ (depth 32), AA Dec 18 20:32:43 Claimco kernel: ata4.00: configured for UDMA/133 Dec 18 20:32:43 Claimco kernel: ata6.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out Dec 18 20:32:43 Claimco kernel: ata6.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out Dec 18 20:32:43 Claimco kernel: ata1.00: configured for UDMA/133 Dec 18 20:32:43 Claimco kernel: scsi 1:0:0:0: Direct-Access ATA ST32000644NS SN12 PQ: 0 ANSI: 5 Dec 18 20:32:43 Claimco kernel: ata6.00: configured for UDMA/133 Dec 18 20:32:43 Claimco kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0 Dec 18 20:32:43 Claimco kernel: sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB) Dec 18 20:32:43 Claimco kernel: sd 1:0:0:0: [sdb] Write Protect is off Dec 18 20:32:43 Claimco kernel: sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00 Dec 18 20:32:43 Claimco kernel: sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Dec 18 20:32:43 Claimco kernel: ata5.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out Dec 18 20:32:43 Claimco kernel: ata5.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out Dec 18 20:32:43 Claimco kernel: sd 1:0:0:0: [sdb] Preferred minimum I/O size 512 bytes Dec 18 20:32:43 Claimco kernel: ata2.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 32), AA Dec 18 20:32:43 Claimco kernel: ata2.00: Features: NCQ-sndrcv NCQ-prio Dec 18 20:32:43 Claimco kernel: sdb: sdb1 Dec 18 20:32:43 Claimco kernel: sd 1:0:0:0: [sdb] Attached SCSI disk Dec 18 20:32:43 Claimco kernel: ata2.00: configured for UDMA/133 Dec 18 20:32:43 Claimco kernel: scsi 2:0:0:0: Direct-Access ATA WDC WD4005FZBX-0 1A01 PQ: 0 ANSI: 5 Dec 18 20:32:43 Claimco kernel: sd 2:0:0:0: Attached scsi generic sg2 type 0 Dec 18 20:32:43 Claimco kernel: sd 2:0:0:0: [sdc] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) Dec 18 20:32:43 Claimco kernel: sd 2:0:0:0: [sdc] 4096-byte physical blocks Dec 18 20:32:43 Claimco kernel: sd 2:0:0:0: [sdc] Write Protect is off Dec 18 20:32:43 Claimco kernel: sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00 Dec 18 20:32:43 Claimco kernel: sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Dec 18 20:32:43 Claimco kernel: sd 2:0:0:0: [sdc] Preferred minimum I/O size 4096 bytes Dec 18 20:32:43 Claimco kernel: ata3.00: ATA-10: ST8000DM004-2CX188, 0001, max UDMA/133 Dec 18 20:32:43 Claimco kernel: ata5.00: supports DRM functions and may not be fully accessible Dec 18 20:32:43 Claimco kernel: ata5.00: ATA-10: ST4000DM004-2U9104, SED1, max UDMA/133 Dec 18 20:32:43 Claimco kernel: ata3.00: 15628053168 sectors, multi 16: LBA48 NCQ (depth 32), AA Dec 18 20:32:43 Claimco kernel: sdc: sdc1 Dec 18 20:32:43 Claimco kernel: sd 2:0:0:0: [sdc] Attached SCSI disk Dec 18 20:32:43 Claimco kernel: ata3.00: configured for UDMA/133 Dec 18 20:32:43 Claimco kernel: scsi 3:0:0:0: Direct-Access ATA ST8000DM004-2CX1 0001 PQ: 0 ANSI: 5 Dec 18 20:32:43 Claimco kernel: sd 3:0:0:0: Attached scsi generic sg3 type 0 Dec 18 20:32:43 Claimco kernel: sd 3:0:0:0: [sdd] 15628053168 512-byte logical blocks: (8.00 TB/7.28 TiB) Dec 18 20:32:43 Claimco kernel: scsi 4:0:0:0: Direct-Access ATA ST32000542AS CC38 PQ: 0 ANSI: 5 Dec 18 20:32:43 Claimco kernel: sd 3:0:0:0: [sdd] 4096-byte physical blocks Dec 18 20:32:43 Claimco kernel: sd 3:0:0:0: [sdd] Write Protect is off Dec 18 20:32:43 Claimco kernel: sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00 Dec 18 20:32:43 Claimco kernel: sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Dec 18 20:32:43 Claimco kernel: sd 3:0:0:0: [sdd] Preferred minimum I/O size 4096 bytes Dec 18 20:32:43 Claimco kernel: sd 4:0:0:0: Attached scsi generic sg4 type 0 Dec 18 20:32:43 Claimco kernel: sd 4:0:0:0: [sde] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB) Dec 18 20:32:43 Claimco kernel: sd 4:0:0:0: [sde] Write Protect is off Dec 18 20:32:43 Claimco kernel: sd 4:0:0:0: [sde] Mode Sense: 00 3a 00 00 Dec 18 20:32:43 Claimco kernel: sd 4:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Dec 18 20:32:43 Claimco kernel: sd 4:0:0:0: [sde] Preferred minimum I/O size 512 bytes Dec 18 20:32:43 Claimco kernel: sde: sde1 Dec 18 20:32:43 Claimco kernel: sd 4:0:0:0: [sde] Attached SCSI disk Dec 18 20:32:43 Claimco kernel: ata9: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Dec 18 20:32:43 Claimco kernel: ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Dec 18 20:32:43 Claimco kernel: ata9.00: ATA-9: APPLE HDD ST2000DM001, AQ03, max UDMA/133 Dec 18 20:32:43 Claimco kernel: ata9.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32) Dec 18 20:32:43 Claimco kernel: ata7.00: ATA-9: ST2000DM001-1ER164, CC26, max UDMA/133 Dec 18 20:32:43 Claimco kernel: ata7.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA Dec 18 20:32:43 Claimco kernel: ata9.00: configured for UDMA/133 Dec 18 20:32:43 Claimco kernel: ata7.00: configured for UDMA/133 Dec 18 20:32:43 Claimco kernel: sdd: sdd1 Dec 18 20:32:43 Claimco kernel: sd 3:0:0:0: [sdd] Attached SCSI disk Dec 18 20:32:43 Claimco kernel: ata5.00: 7814037168 sectors, multi 1: LBA48 NCQ (depth 32), AA Dec 18 20:32:43 Claimco kernel: ata5.00: Features: Trust Dec 18 20:32:43 Claimco kernel: ata5.00: ACPI cmd f5/00:00:00:00:00:00(SECURITY FREEZE LOCK) filtered out Dec 18 20:32:43 Claimco kernel: ata5.00: ACPI cmd b1/c1:00:00:00:00:00(DEVICE CONFIGURATION OVERLAY) filtered out Dec 18 20:32:43 Claimco kernel: ata5.00: supports DRM functions and may not be fully accessible Dec 18 20:32:43 Claimco kernel: ata5.00: configured for UDMA/133 Dec 18 20:32:43 Claimco kernel: scsi 5:0:0:0: Direct-Access ATA ST4000DM004-2U91 SED1 PQ: 0 ANSI: 5 Dec 18 20:32:43 Claimco kernel: sd 5:0:0:0: Attached scsi generic sg5 type 0 Dec 18 20:32:43 Claimco kernel: sd 5:0:0:0: [sdf] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) Dec 18 20:32:43 Claimco kernel: sd 5:0:0:0: [sdf] 4096-byte physical blocks Dec 18 20:32:43 Claimco kernel: sd 5:0:0:0: [sdf] Write Protect is off Dec 18 20:32:43 Claimco kernel: sd 5:0:0:0: [sdf] Mode Sense: 00 3a 00 00 Dec 18 20:32:43 Claimco kernel: scsi 6:0:0:0: Direct-Access ATA WDC WD6400AAKS-2 3B01 PQ: 0 ANSI: 5 Dec 18 20:32:43 Claimco kernel: sd 5:0:0:0: [sdf] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Dec 18 20:32:43 Claimco kernel: sd 5:0:0:0: [sdf] Preferred minimum I/O size 4096 bytes Dec 18 20:32:43 Claimco kernel: sd 6:0:0:0: Attached scsi generic sg6 type 0 Dec 18 20:32:43 Claimco kernel: sd 6:0:0:0: [sdg] 1250263728 512-byte logical blocks: (640 GB/596 GiB) Dec 18 20:32:43 Claimco kernel: sd 6:0:0:0: [sdg] Write Protect is off Dec 18 20:32:43 Claimco kernel: sd 6:0:0:0: [sdg] Mode Sense: 00 3a 00 00 Dec 18 20:32:43 Claimco kernel: scsi 7:0:0:0: Direct-Access ATA ST2000DM001-1ER1 CC26 PQ: 0 ANSI: 5 Dec 18 20:32:43 Claimco kernel: sd 6:0:0:0: [sdg] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Dec 18 20:32:43 Claimco kernel: sd 6:0:0:0: [sdg] Preferred minimum I/O size 512 bytes Dec 18 20:32:43 Claimco kernel: sd 7:0:0:0: Attached scsi generic sg7 type 0 Dec 18 20:32:43 Claimco kernel: sd 7:0:0:0: [sdh] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB) Dec 18 20:32:43 Claimco kernel: sd 7:0:0:0: [sdh] 4096-byte physical blocks Dec 18 20:32:43 Claimco kernel: sd 7:0:0:0: [sdh] Write Protect is off Dec 18 20:32:43 Claimco kernel: sd 7:0:0:0: [sdh] Mode Sense: 00 3a 00 00 Dec 18 20:32:43 Claimco kernel: sd 7:0:0:0: [sdh] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Dec 18 20:32:43 Claimco kernel: sd 7:0:0:0: [sdh] Preferred minimum I/O size 4096 bytes Dec 18 20:32:43 Claimco kernel: sdg: sdg1 Dec 18 20:32:43 Claimco kernel: sd 6:0:0:0: [sdg] Attached SCSI disk Dec 18 20:32:43 Claimco kernel: sdf: sdf1 Dec 18 20:32:43 Claimco kernel: sd 5:0:0:0: [sdf] Attached SCSI disk Dec 18 20:32:43 Claimco kernel: sdh: sdh1 Dec 18 20:32:43 Claimco kernel: sd 7:0:0:0: [sdh] Attached SCSI disk Dec 18 20:32:43 Claimco kernel: ata8: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Dec 18 20:32:43 Claimco kernel: ata8.00: ATA-9: WDC WD4005FZBX-00K5WB0, 01.01A01, max UDMA/133 Dec 18 20:32:43 Claimco kernel: ata8.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 32), AA Dec 18 20:32:43 Claimco kernel: ata8.00: Features: NCQ-sndrcv NCQ-prio Dec 18 20:32:43 Claimco kernel: ata8.00: configured for UDMA/133 Dec 18 20:32:43 Claimco kernel: scsi 8:0:0:0: Direct-Access ATA WDC WD4005FZBX-0 1A01 PQ: 0 ANSI: 5 Dec 18 20:32:43 Claimco kernel: sd 8:0:0:0: Attached scsi generic sg8 type 0 Dec 18 20:32:43 Claimco kernel: sd 8:0:0:0: [sdi] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB) Dec 18 20:32:43 Claimco kernel: sd 8:0:0:0: [sdi] 4096-byte physical blocks Dec 18 20:32:43 Claimco kernel: scsi 9:0:0:0: Direct-Access ATA APPLE HDD ST2000 AQ03 PQ: 0 ANSI: 5 Dec 18 20:32:43 Claimco kernel: sd 8:0:0:0: [sdi] Write Protect is off Dec 18 20:32:43 Claimco kernel: sd 8:0:0:0: [sdi] Mode Sense: 00 3a 00 00 Dec 18 20:32:43 Claimco kernel: sd 8:0:0:0: [sdi] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Dec 18 20:32:43 Claimco kernel: sd 8:0:0:0: [sdi] Preferred minimum I/O size 4096 bytes Dec 18 20:32:43 Claimco kernel: sd 9:0:0:0: Attached scsi generic sg9 type 0 Dec 18 20:32:43 Claimco kernel: sd 9:0:0:0: [sdj] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB) Dec 18 20:32:43 Claimco kernel: sd 9:0:0:0: [sdj] 4096-byte physical blocks Dec 18 20:32:43 Claimco kernel: sd 9:0:0:0: [sdj] Write Protect is off Dec 18 20:32:43 Claimco kernel: sd 9:0:0:0: [sdj] Mode Sense: 00 3a 00 00 Dec 18 20:32:43 Claimco kernel: sd 9:0:0:0: [sdj] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Dec 18 20:32:43 Claimco kernel: sd 9:0:0:0: [sdj] Preferred minimum I/O size 4096 bytes Dec 18 20:32:43 Claimco kernel: sdj: sdj1 Dec 18 20:32:43 Claimco kernel: sd 9:0:0:0: [sdj] Attached SCSI disk Dec 18 20:32:43 Claimco kernel: sdi: sdi1 Dec 18 20:32:43 Claimco kernel: sd 8:0:0:0: [sdi] Attached SCSI disk Dec 18 20:32:43 Claimco kernel: ata10: SATA link up 6.0 Gbps (SStatus 133 SControl 300) Dec 18 20:32:43 Claimco kernel: ata10.00: ATA-9: ST2000DM001-1CH164, HP33, max UDMA/100 Dec 18 20:32:43 Claimco kernel: ata10.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 32), AA Dec 18 20:32:43 Claimco kernel: ata10.00: configured for UDMA/100 Dec 18 20:32:43 Claimco kernel: scsi 10:0:0:0: Direct-Access ATA ST2000DM001-1CH1 HP33 PQ: 0 ANSI: 5 Dec 18 20:32:43 Claimco kernel: sd 10:0:0:0: Attached scsi generic sg10 type 0 Dec 18 20:32:43 Claimco kernel: sd 10:0:0:0: [sdk] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB) Dec 18 20:32:43 Claimco kernel: sd 10:0:0:0: [sdk] 4096-byte physical blocks Dec 18 20:32:43 Claimco kernel: sd 10:0:0:0: [sdk] Write Protect is off Dec 18 20:32:43 Claimco kernel: sd 10:0:0:0: [sdk] Mode Sense: 00 3a 00 00 Dec 18 20:32:43 Claimco kernel: sd 10:0:0:0: [sdk] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA Dec 18 20:32:43 Claimco kernel: sd 10:0:0:0: [sdk] Preferred minimum I/O size 4096 bytes Dec 18 20:32:43 Claimco kernel: sdk: sdk1 Dec 18 20:32:43 Claimco kernel: sd 10:0:0:0: [sdk] Attached SCSI disk Dec 18 20:32:43 Claimco kernel: BTRFS: device fsid 4cc8cdfc-7d04-4842-8583-e99d5458e912 devid 1 transid 631 /dev/nvme0n1p1 scanned by udevd (724) Dec 18 20:32:43 Claimco kernel: ACPI: bus type drm_connector registered Dec 18 20:32:43 Claimco kernel: i915 0000:00:02.0: [drm] VT-d active for gfx access Dec 18 20:32:43 Claimco kernel: i915 0000:00:02.0: vgaarb: deactivate vga console Dec 18 20:32:43 Claimco kernel: Console: switching to colour dummy device 80x25 Dec 18 20:32:43 Claimco kernel: i915 0000:00:02.0: [drm] Transparent Hugepage mode 'huge=within_size' Dec 18 20:32:43 Claimco kernel: i915 0000:00:02.0: [drm] DMAR active, disabling use of stolen memory Dec 18 20:32:43 Claimco kernel: i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem Dec 18 20:32:43 Claimco kernel: [drm] Initialized i915 1.6.0 20201103 for 0000:00:02.0 on minor 0 Dec 18 20:32:43 Claimco kernel: ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no) Dec 18 20:32:43 Claimco kernel: input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input4 Dec 18 20:32:43 Claimco kernel: i915 0000:00:02.0: [drm] Cannot find any crtc or sizes ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 18 20:32:43 Claimco kernel: e1000e 0000:00:19.0 eth1: removed PHC Dec 18 20:32:43 Claimco kernel: r8169 0000:04:00.0: can't disable ASPM; OS doesn't have ASPM control Dec 18 20:32:43 Claimco kernel: r8169 0000:04:00.0 eth0: RTL8168g/8111g, d0:50:99:5a:1b:96, XID 4c0, IRQ 47 Dec 18 20:32:43 Claimco kernel: r8169 0000:04:00.0 eth0: jumbo features [frames: 9194 bytes, tx checksumming: ko] Dec 18 20:32:43 Claimco kernel: e1000e: Intel(R) PRO/1000 Network Driver Dec 18 20:32:43 Claimco kernel: e1000e: Copyright(c) 1999 - 2015 Intel Corporation. Dec 18 20:32:43 Claimco kernel: e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode Dec 18 20:32:43 Claimco kernel: e1000e 0000:00:19.0 0000:00:19.0 (uninitialized): registered PHC clock Dec 18 20:32:43 Claimco kernel: e1000e 0000:00:19.0 eth1: (PCI Express:2.5GT/s:Width x1) d0:50:99:5a:1b:98 Dec 18 20:32:43 Claimco kernel: e1000e 0000:00:19.0 eth1: Intel(R) PRO/1000 Network Connection Dec 18 20:32:43 Claimco kernel: e1000e 0000:00:19.0 eth1: MAC: 11, PHY: 12, PBA No: FFFFFF-0FF Dec 18 20:32:43 Claimco rc.inet1: ip -4 addr add 127.0.0.1/8 dev lo Dec 18 20:32:43 Claimco rc.inet1: ip -6 addr add ::1/128 dev lo Dec 18 20:32:43 Claimco rc.inet1: ip link set lo up Dec 18 20:32:43 Claimco kernel: MII link monitoring set to 100 ms Dec 18 20:32:43 Claimco rc.inet1: ip link add name bond0 type bond mode 0 miimon 100 Dec 18 20:32:43 Claimco rc.inet1: ip link set bond0 up Dec 18 20:32:43 Claimco rc.inet1: ip link set eth0 master bond0 down Dec 18 20:32:43 Claimco kernel: Generic FE-GE Realtek PHY r8169-0-400:00: attached PHY driver (mii_bus:phy_addr=r8169-0-400:00, irq=MAC) Dec 18 20:32:43 Claimco rc.inet1: ip link set eth1 master bond0 down Dec 18 20:32:43 Claimco kernel: r8169 0000:04:00.0 eth0: Link is Down Dec 18 20:32:43 Claimco kernel: bond0: (slave eth0): Enslaving as an active interface with a down link Dec 18 20:32:44 Claimco kernel: bond0: (slave eth1): Enslaving as an active interface with a down link Dec 18 20:32:44 Claimco rsyslogd: [origin software="rsyslogd" swVersion="8.2102.0" x-pid="927" x-info="https://www.rsyslog.com"] start Dec 18 20:32:46 Claimco kernel: r8169 0000:04:00.0 eth0: Link is Up - 1Gbps/Full - flow control rx/tx Dec 18 20:32:46 Claimco kernel: bond0: (slave eth0): link status definitely up, 1000 Mbps full duplex Dec 18 20:32:46 Claimco kernel: bond0: active interface up! Dec 18 20:32:46 Claimco kernel: IPv6: ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready Dec 18 20:32:46 Claimco kernel: e1000e 0000:00:19.0 eth1: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx Dec 18 20:32:47 Claimco kernel: bond0: (slave eth1): link status definitely up, 1000 Mbps full duplex Dec 18 20:32:47 Claimco rc.inet1: ip link add name br0 type bridge stp_state 0 forward_delay 0 Dec 18 20:32:47 Claimco kernel: bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this. Dec 18 20:32:47 Claimco rc.inet1: ip link set br0 up Dec 18 20:32:47 Claimco rc.inet1: ip link set bond0 down Dec 18 20:32:47 Claimco rc.inet1: ip -4 addr flush dev bond0 Dec 18 20:32:47 Claimco rc.inet1: ip link set bond0 promisc on master br0 up Dec 18 20:32:47 Claimco kernel: device bond0 entered promiscuous mode Dec 18 20:32:47 Claimco kernel: device eth0 entered promiscuous mode Dec 18 20:32:47 Claimco kernel: device eth1 entered promiscuous mode Dec 18 20:32:47 Claimco kernel: br0: port 1(bond0) entered blocking state Dec 18 20:32:47 Claimco kernel: br0: port 1(bond0) entered disabled state Dec 18 20:32:47 Claimco kernel: br0: port 1(bond0) entered blocking state Dec 18 20:32:47 Claimco kernel: br0: port 1(bond0) entered forwarding state Dec 18 20:32:47 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 18 20:32:48 Claimco rc.inet1: ip -4 addr add 192.168.1.233/255.255.255.0 dev br0 Dec 18 20:32:48 Claimco rc.inet1: ip link set br0 up Dec 18 20:32:48 Claimco rc.inet1: ip -4 route add default via 192.168.1.254 dev br0 Dec 18 20:32:48 Claimco mcelog: failed to prefill DIMM database from DMI data Dec 18 20:32:48 Claimco mcelog: Kernel does not support page offline interface Dec 18 20:32:48 Claimco elogind-daemon[1125]: New seat seat0. Dec 18 20:32:48 Claimco elogind-daemon[1125]: Watching system buttons on /dev/input/event3 (Power Button) Dec 18 20:32:48 Claimco elogind-daemon[1125]: Watching system buttons on /dev/input/event1 (Power Button) Dec 18 20:32:48 Claimco elogind-daemon[1125]: Watching system buttons on /dev/input/event2 (Sleep Button) Dec 18 20:32:48 Claimco sshd[1147]: Server listening on 0.0.0.0 port 22. Dec 18 20:32:48 Claimco sshd[1147]: Server listening on :: port 22. Dec 18 20:32:48 Claimco ntpd[1156]: ntpd [email protected] Fri Jun 3 04:17:10 UTC 2022 (1): Starting Dec 18 20:32:48 Claimco ntpd[1156]: Command line: /usr/sbin/ntpd -g -u ntp:ntp Dec 18 20:32:48 Claimco ntpd[1156]: ---------------------------------------------------- Dec 18 20:32:48 Claimco ntpd[1156]: ntp-4 is maintained by Network Time Foundation, Dec 18 20:32:48 Claimco ntpd[1156]: Inc. (NTF), a non-profit 501(c)(3) public-benefit Dec 18 20:32:48 Claimco ntpd[1156]: corporation. Support and training for ntp-4 are Dec 18 20:32:48 Claimco ntpd[1156]: available at https://www.nwtime.org/support Dec 18 20:32:48 Claimco ntpd[1156]: ---------------------------------------------------- Dec 18 20:32:48 Claimco ntpd[1158]: proto: precision = 0.037 usec (-25) Dec 18 20:32:48 Claimco ntpd[1158]: basedate set to 2022-05-22 Dec 18 20:32:48 Claimco ntpd[1158]: gps base set to 2022-05-22 (week 2211) Dec 18 20:32:48 Claimco ntpd[1158]: Listen normally on 0 lo 127.0.0.1:123 Dec 18 20:32:48 Claimco ntpd[1158]: Listen normally on 1 br0 192.168.1.233:123 Dec 18 20:32:48 Claimco ntpd[1158]: Listen normally on 2 lo [::1]:123 Dec 18 20:32:48 Claimco ntpd[1158]: Listening on routing socket on fd #19 for interface updates Dec 18 20:32:48 Claimco ntpd[1158]: kernel reports TIME_ERROR: 0x41: Clock Unsynchronized ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:32:48 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 18 20:32:48 Claimco acpid: starting up with netlink and the input layer Dec 18 20:32:48 Claimco acpid: 1 rule loaded Dec 18 20:32:48 Claimco acpid: waiting for events: event logging is off Dec 18 20:32:48 Claimco crond[1179]: /usr/sbin/crond 4.5 dillon's cron daemon, started with loglevel notice Dec 18 20:32:48 Claimco smbd[1191]: [2022/12/18 20:32:48.360436, 0] ../../source3/smbd/server.c:1741(main) Dec 18 20:32:48 Claimco smbd[1191]: smbd version 4.17.3 started. Dec 18 20:32:48 Claimco smbd[1191]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Dec 18 20:32:48 Claimco wsdd2[1205]: starting. Dec 18 20:32:48 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:32:48 Claimco winbindd[1206]: [2022/12/18 20:32:48.424243, 0] ../../source3/winbindd/winbindd.c:1440(main) Dec 18 20:32:48 Claimco winbindd[1206]: winbindd version 4.17.3 started. Dec 18 20:32:48 Claimco winbindd[1206]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Dec 18 20:32:48 Claimco winbindd[1208]: [2022/12/18 20:32:48.426703, 0] ../../source3/winbindd/winbindd_cache.c:3116(initialize_winbindd_cache) Dec 18 20:32:48 Claimco winbindd[1208]: initialize_winbindd_cache: clearing cache and re-creating with version number 2 Dec 18 20:32:48 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 18 20:32:48 Claimco root: Installing plugins Dec 18 20:32:48 Claimco root: plugin: installing: ProFTPd.plg Dec 18 20:32:48 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:32:48 Claimco root: plugin: skipping: /boot/config/plugins/ProFTPd/README already exists Dec 18 20:32:48 Claimco root: plugin: skipping: /boot/config/plugins/ProFTPd/proftpd.conf already exists Dec 18 20:32:48 Claimco root: plugin: skipping: /boot/config/plugins/ProFTPd/ProFTPd.cfg already exists Dec 18 20:32:48 Claimco root: plugin: skipping: /boot/config/plugins/ProFTPd/mountscript.sh already exists Dec 18 20:32:48 Claimco root: plugin: skipping: /boot/config/plugins/ProFTPd/unmountscript.sh already exists Dec 18 20:32:48 Claimco root: plugin: creating: /tmp/ProFTPd-script - from INLINE content Dec 18 20:32:48 Claimco root: plugin: running: /tmp/ProFTPd-script Dec 18 20:32:48 Claimco root: Cleaning up previous install files... Dec 18 20:32:48 Claimco root: Executing selfremoval commands if present... Dec 18 20:32:48 Claimco root: #011 Found correct version of plugin control files. Ignoring Dec 18 20:32:48 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 18 20:32:48 Claimco root: #011 Found correct version of plugin dependency files. Ignoring Dec 18 20:32:48 Claimco root: ...Cleanup complete! Dec 18 20:32:48 Claimco root: Downloading any missing plugin files... Dec 18 20:32:49 Claimco root: ...Downloading complete! Dec 18 20:32:49 Claimco root: Running install script for ProFTPd... Dec 18 20:32:49 Claimco root: #011 Installing plugin control files Dec 18 20:32:49 Claimco root: #011 Installing plugin dependency files Dec 18 20:32:49 Claimco root: #011 Detect if MySQL/MariaDB is installed... Dec 18 20:32:49 Claimco root: #011 Move Config Editor archive to plugin dir... Dec 18 20:32:49 Claimco root: Dec 18 20:32:49 Claimco root: +============================================================================== Dec 18 20:32:49 Claimco root: | Installing new package /tmp/ProFTPd-inst/install-B/proftpd-1.3.7a-64-sql.tgz Dec 18 20:32:49 Claimco root: +============================================================================== Dec 18 20:32:49 Claimco root: Dec 18 20:32:49 Claimco root: Verifying package proftpd-1.3.7a-64-sql.tgz. Dec 18 20:32:49 Claimco root: Installing package proftpd-1.3.7a-64-sql.tgz: Dec 18 20:32:49 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:32:49 Claimco root: Executing install script for proftpd-1.3.7a-64-sql.tgz. Dec 18 20:32:49 Claimco root: Package proftpd-1.3.7a-64-sql.tgz installed. Dec 18 20:32:49 Claimco root: Dec 18 20:32:49 Claimco root: +============================================================================== Dec 18 20:32:49 Claimco root: | Installing new package /tmp/ProFTPd-inst/install-B/proftpd-1.3.7a-64.tgz Dec 18 20:32:49 Claimco root: +============================================================================== Dec 18 20:32:49 Claimco root: Dec 18 20:32:49 Claimco root: Verifying package proftpd-1.3.7a-64.tgz. Dec 18 20:32:50 Claimco root: Installing package proftpd-1.3.7a-64.tgz: Dec 18 20:32:50 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:32:50 Claimco root: Executing install script for proftpd-1.3.7a-64.tgz. Dec 18 20:32:50 Claimco root: Package proftpd-1.3.7a-64.tgz installed. Dec 18 20:32:50 Claimco root: Remove example config file... Dec 18 20:32:50 Claimco root: Symlink new config file... Dec 18 20:32:50 Claimco root: Renewing userjail... Dec 18 20:32:51 Claimco root: ...OK Dec 18 20:32:52 Claimco root: Starting ProFTPd... Dec 18 20:32:53 Claimco root: Dec 18 20:32:53 Claimco sudo: root : TTY=console ; PWD=/usr/local/emhttp ; USER=root ; COMMAND=/usr/local/SlrG-Common/usr/local/sbin/proftpd -c /etc/proftpd.conf Dec 18 20:32:53 Claimco sudo: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0) Dec 18 20:32:53 Claimco proftpd[1655]: 127.0.0.1 - ProFTPD 1.3.7a (maint) (built Thu Feb 18 2021 00:42:08 CET) standalone mode STARTUP Dec 18 20:32:53 Claimco sudo: pam_unix(sudo:session): session closed for user root Dec 18 20:32:54 Claimco root: ...OK Dec 18 20:32:55 Claimco root: #011 Cleaning up temp files/folders Dec 18 20:32:55 Claimco root: ...Install complete! Dec 18 20:32:55 Claimco root: plugin: ProFTPd.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:32:55 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:32:55 Claimco root: plugin: installing: ca.cleanup.appdata.plg Dec 18 20:32:55 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:32:55 Claimco root: plugin: running: anonymous Dec 18 20:32:55 Claimco root: ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 18 20:32:55 Claimco root: plugin: running: anonymous Dec 18 20:32:55 Claimco root: plugin: checking: /boot/config/plugins/ca.cleanup.appdata/ca.cleanup.appdata-2022.10.21-x86_64-1.txz - MD5 Dec 18 20:32:55 Claimco root: plugin: skipping: /boot/config/plugins/ca.cleanup.appdata/ca.cleanup.appdata-2022.10.21-x86_64-1.txz already exists Dec 18 20:32:55 Claimco root: plugin: running: /boot/config/plugins/ca.cleanup.appdata/ca.cleanup.appdata-2022.10.21-x86_64-1.txz Dec 18 20:32:55 Claimco root: Dec 18 20:32:55 Claimco root: +============================================================================== Dec 18 20:32:55 Claimco root: | Installing new package /boot/config/plugins/ca.cleanup.appdata/ca.cleanup.appdata-2022.10.21-x86_64-1.txz Dec 18 20:32:55 Claimco root: +============================================================================== Dec 18 20:32:55 Claimco root: Dec 18 20:32:55 Claimco root: Verifying package ca.cleanup.appdata-2022.10.21-x86_64-1.txz. Dec 18 20:32:55 Claimco root: Installing package ca.cleanup.appdata-2022.10.21-x86_64-1.txz: Dec 18 20:32:55 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:32:55 Claimco root: Package ca.cleanup.appdata-2022.10.21-x86_64-1.txz installed. Dec 18 20:32:55 Claimco root: plugin: running: anonymous Dec 18 20:32:55 Claimco root: Dec 18 20:32:55 Claimco root: ---------------------------------------------------- Dec 18 20:32:55 Claimco root: ca.cleanup.appdata has been installed. Dec 18 20:32:55 Claimco root: Copyright 2015-2016, Andrew Zawadzki Dec 18 20:32:55 Claimco root: Version: 2022.10.21 Dec 18 20:32:55 Claimco root: ---------------------------------------------------- Dec 18 20:32:55 Claimco root: Dec 18 20:32:55 Claimco root: plugin: ca.cleanup.appdata.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:32:55 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:32:55 Claimco root: plugin: installing: ca.turbo.plg Dec 18 20:32:55 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:32:55 Claimco root: plugin: running: anonymous Dec 18 20:32:55 Claimco root: ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 18 20:32:55 Claimco root: plugin: running: anonymous Dec 18 20:32:55 Claimco root: plugin: checking: /boot/config/plugins/ca.turbo/ca.turbo-2022.09.16-x86_64-1.txz - MD5 Dec 18 20:32:55 Claimco root: plugin: skipping: /boot/config/plugins/ca.turbo/ca.turbo-2022.09.16-x86_64-1.txz already exists Dec 18 20:32:55 Claimco root: plugin: running: /boot/config/plugins/ca.turbo/ca.turbo-2022.09.16-x86_64-1.txz Dec 18 20:32:55 Claimco root: Dec 18 20:32:55 Claimco root: +============================================================================== Dec 18 20:32:55 Claimco root: | Installing new package /boot/config/plugins/ca.turbo/ca.turbo-2022.09.16-x86_64-1.txz Dec 18 20:32:55 Claimco root: +============================================================================== Dec 18 20:32:55 Claimco root: Dec 18 20:32:55 Claimco root: Verifying package ca.turbo-2022.09.16-x86_64-1.txz. Dec 18 20:32:55 Claimco root: Installing package ca.turbo-2022.09.16-x86_64-1.txz: Dec 18 20:32:55 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:32:55 Claimco root: Package ca.turbo-2022.09.16-x86_64-1.txz installed. Dec 18 20:32:55 Claimco root: plugin: running: anonymous Dec 18 20:32:55 Claimco root: ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:32:55 Claimco root: Checking for running background process Dec 18 20:32:55 Claimco root: Dec 18 20:32:55 Claimco root: plugin: running: anonymous Dec 18 20:32:55 Claimco root: Dec 18 20:32:55 Claimco root: ---------------------------------------------------- Dec 18 20:32:55 Claimco root: ca.turbo has been installed. Dec 18 20:32:55 Claimco root: Copyright 2017-2020, Andrew Zawadzki Dec 18 20:32:55 Claimco root: Version: 2022.09.16 Dec 18 20:32:55 Claimco root: ---------------------------------------------------- Dec 18 20:32:55 Claimco root: Dec 18 20:32:55 Claimco root: plugin: ca.turbo.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:32:55 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:32:55 Claimco root: plugin: installing: ca.update.applications.plg Dec 18 20:32:55 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:32:55 Claimco root: plugin: running: anonymous Dec 18 20:32:55 Claimco root: ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 18 20:32:55 Claimco root: plugin: running: anonymous Dec 18 20:32:55 Claimco root: plugin: checking: /boot/config/plugins/ca.update.applications/ca.update.applications-2021.09.24-x86_64-1.txz - MD5 Dec 18 20:32:55 Claimco root: plugin: skipping: /boot/config/plugins/ca.update.applications/ca.update.applications-2021.09.24-x86_64-1.txz already exists Dec 18 20:32:55 Claimco root: plugin: running: /boot/config/plugins/ca.update.applications/ca.update.applications-2021.09.24-x86_64-1.txz Dec 18 20:32:55 Claimco root: Dec 18 20:32:55 Claimco root: +============================================================================== Dec 18 20:32:55 Claimco root: | Installing new package /boot/config/plugins/ca.update.applications/ca.update.applications-2021.09.24-x86_64-1.txz Dec 18 20:32:55 Claimco root: +============================================================================== Dec 18 20:32:55 Claimco root: Dec 18 20:32:55 Claimco root: Verifying package ca.update.applications-2021.09.24-x86_64-1.txz. Dec 18 20:32:55 Claimco root: Installing package ca.update.applications-2021.09.24-x86_64-1.txz: Dec 18 20:32:55 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:32:55 Claimco root: Package ca.update.applications-2021.09.24-x86_64-1.txz installed. Dec 18 20:32:55 Claimco root: plugin: running: anonymous Dec 18 20:32:55 Claimco root: Dec 18 20:32:55 Claimco root: ---------------------------------------------------- Dec 18 20:32:55 Claimco root: ca.update.applications has been installed. Dec 18 20:32:55 Claimco root: Copyright 2015-2021, Andrew Zawadzki Dec 18 20:32:55 Claimco root: Version: 2021.09.24 Dec 18 20:32:55 Claimco root: ---------------------------------------------------- Dec 18 20:32:55 Claimco root: Dec 18 20:32:55 Claimco root: plugin: ca.update.applications.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:32:55 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:32:55 Claimco root: plugin: installing: community.applications.plg Dec 18 20:32:55 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:32:55 Claimco root: plugin: running: anonymous Dec 18 20:32:55 Claimco root: ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:32:55 Claimco root: Cleaning Up Old Versions Dec 18 20:32:55 Claimco root: Fixing pinned apps Dec 18 20:32:55 Claimco root: Setting up cron for background notifications Dec 18 20:32:55 Claimco root: Dec 18 20:32:55 Claimco root: plugin: running: anonymous Dec 18 20:32:55 Claimco root: plugin: checking: /boot/config/plugins/community.applications/community.applications-2022.12.03-x86_64-1.txz - MD5 Dec 18 20:32:55 Claimco root: plugin: skipping: /boot/config/plugins/community.applications/community.applications-2022.12.03-x86_64-1.txz already exists Dec 18 20:32:55 Claimco root: plugin: running: /boot/config/plugins/community.applications/community.applications-2022.12.03-x86_64-1.txz Dec 18 20:32:55 Claimco root: Dec 18 20:32:55 Claimco root: +============================================================================== Dec 18 20:32:55 Claimco root: | Installing new package /boot/config/plugins/community.applications/community.applications-2022.12.03-x86_64-1.txz Dec 18 20:32:55 Claimco root: +============================================================================== Dec 18 20:32:55 Claimco root: Dec 18 20:32:56 Claimco root: Verifying package community.applications-2022.12.03-x86_64-1.txz. Dec 18 20:32:56 Claimco root: Installing package community.applications-2022.12.03-x86_64-1.txz: Dec 18 20:32:56 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:32:56 Claimco root: Package community.applications-2022.12.03-x86_64-1.txz installed. Dec 18 20:32:56 Claimco root: plugin: running: anonymous Dec 18 20:32:56 Claimco root: Creating Directories Dec 18 20:32:56 Claimco root: Dec 18 20:32:56 Claimco root: Adjusting icon for unRaid version Dec 18 20:32:56 Claimco root: Dec 18 20:32:56 Claimco root: ---------------------------------------------------- Dec 18 20:32:56 Claimco root: community.applications has been installed. Dec 18 20:32:56 Claimco root: Copyright 2015-2022, Andrew Zawadzki Dec 18 20:32:56 Claimco root: Version: 2022.12.03 Dec 18 20:32:56 Claimco root: ---------------------------------------------------- Dec 18 20:32:56 Claimco root: Dec 18 20:32:56 Claimco root: plugin: community.applications.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:32:56 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:32:56 Claimco root: plugin: installing: corsairpsu.plg Dec 18 20:32:56 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:32:56 Claimco root: plugin: skipping: /boot/config/plugins/corsairpsu/corsairpsu-2021.10.05-x86_64.txz already exists Dec 18 20:32:56 Claimco root: plugin: running: /boot/config/plugins/corsairpsu/corsairpsu-2021.10.05-x86_64.txz Dec 18 20:32:56 Claimco root: Dec 18 20:32:56 Claimco root: +============================================================================== Dec 18 20:32:56 Claimco root: | Installing new package /boot/config/plugins/corsairpsu/corsairpsu-2021.10.05-x86_64.txz Dec 18 20:32:56 Claimco root: +============================================================================== Dec 18 20:32:56 Claimco root: Dec 18 20:32:56 Claimco root: Verifying package corsairpsu-2021.10.05-x86_64.txz. Dec 18 20:32:56 Claimco root: Installing package corsairpsu-2021.10.05-x86_64.txz: Dec 18 20:32:56 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:32:56 Claimco root: Package corsairpsu-2021.10.05-x86_64.txz installed. Dec 18 20:32:56 Claimco root: plugin: corsairpsu.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:32:56 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:32:56 Claimco root: plugin: installing: disklocation-master.plg Dec 18 20:32:56 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:32:56 Claimco root: plugin: creating: /tmp/disklocation-install - from INLINE content Dec 18 20:32:56 Claimco root: plugin: running: /tmp/disklocation-install Dec 18 20:32:56 Claimco root: Dec 18 20:32:56 Claimco root: Installing plugin... Dec 18 20:32:56 Claimco root: Dec 18 20:32:56 Claimco root: Plugin folder /boot/config/plugins/disklocation already exists Dec 18 20:32:56 Claimco root: Dec 18 20:32:56 Claimco root: Checking existing package /boot/config/plugins/disklocation/disklocation.2022.06.18.zip... Dec 18 20:32:56 Claimco root: Dec 18 20:32:56 Claimco root: Extracting plugin package... Dec 18 20:32:56 Claimco root: Archive: /boot/config/plugins/disklocation/disklocation.2022.06.18.zip Dec 18 20:32:56 Claimco root: 2462e74eb17559ec64f10abedac817fc8eb0c60e Dec 18 20:32:56 Claimco root: creating: /tmp/disklocation-packages/disklocation-master/ Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/COPYING Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/README.md Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation-devel.plg Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation-master.plg Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation.png Dec 18 20:32:56 Claimco root: creating: /tmp/disklocation-packages/disklocation-master/disklocation/ Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/disklocation.cron Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/disklocation.page Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/disklocationConfig.page Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/disklocationConfig_allocations.page Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/disklocationConfig_drives.page Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/disklocationConfig_main.page Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/disklocationConfig_system.page Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/disklocation_dashboard.page Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/disklocation_devices.page Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/disklocation_info.page Dec 18 20:32:56 Claimco root: creating: /tmp/disklocation-packages/disklocation-master/disklocation/pages/ Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/pages/config.php Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/pages/config_drives.php Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/pages/config_system.php Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/pages/config_trayalloc.php Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/pages/devices.php Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/pages/info.php Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/pages/locate.php Dec 18 20:32:56 Claimco root: creating: /tmp/disklocation-packages/disklocation-master/disklocation/pages/script/ Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/pages/script/locate_script_bottom.js Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/pages/script/locate_script_top.js.php Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/pages/sqlite_tables.php Dec 18 20:32:56 Claimco root: creating: /tmp/disklocation-packages/disklocation-master/disklocation/pages/styles/ Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/pages/styles/disk.css.php Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/pages/styles/help.css Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/pages/styles/signals.css Dec 18 20:32:56 Claimco root: inflating: /tmp/disklocation-packages/disklocation-master/disklocation/pages/system.php Dec 18 20:32:56 Claimco root: Dec 18 20:32:56 Claimco root: Extraction done. Dec 18 20:32:56 Claimco root: Dec 18 20:32:56 Claimco root: Package file disklocation.2022.06.18.zip extracted. Dec 18 20:32:56 Claimco root: Dec 18 20:32:56 Claimco root: Adding disks into database, please wait... this might take a while... Dec 18 20:32:56 Claimco root: [203256] system.php:92 @ functions: Debug function active. Dec 18 20:32:56 Claimco root: [203256] system.php:1140 @ array: LSSCSI:13 Dec 18 20:32:56 Claimco root: [203256] system.php:1157 @ loop: Scanning: 0:0:0:0 Node: /dev/sg0 Dec 18 20:32:56 Claimco root: [203256] system.php:1157 @ loop: Scanning: 1:0:0:0 Node: /dev/sg1 Dec 18 20:32:56 Claimco root: [203256] system.php:1167 @ SMART: #:1|DEV:1:0:0:0=array Dec 18 20:32:56 Claimco root: [203256] system.php:1197 @ SMART: #:1|DEV:1:0:0:0|PROTOCOL=ATA Dec 18 20:32:56 Claimco root: [203256] system.php:1209 @ HASH: #:1:bc5eec264cd70d0c829e2a6670743fa8e944d41294074960086a5c7ca77a1556 Dec 18 20:32:56 Claimco root: [203256] system.php:1157 @ loop: Scanning: 2:0:0:0 Node: /dev/sg2 Dec 18 20:32:56 Claimco root: [203256] system.php:1167 @ SMART: #:2|DEV:2:0:0:0=array Dec 18 20:32:56 Claimco root: [203256] system.php:1197 @ SMART: #:2|DEV:2:0:0:0|PROTOCOL=ATA Dec 18 20:32:56 Claimco root: [203256] system.php:1209 @ HASH: #:2:1b71cfab9d0f9b1b565f49fb19514872d9251b574437e6b8e143ddc3532f1620 Dec 18 20:32:57 Claimco root: [203257] system.php:1157 @ loop: Scanning: 3:0:0:0 Node: /dev/sg3 Dec 18 20:32:57 Claimco root: [203257] system.php:1167 @ SMART: #:3|DEV:3:0:0:0=array Dec 18 20:32:57 Claimco root: [203257] system.php:1197 @ SMART: #:3|DEV:3:0:0:0|PROTOCOL=ATA Dec 18 20:32:57 Claimco root: [203257] system.php:1209 @ HASH: #:3:98f08b946ed5c999eba342dc76d2c570a4afbab0498c5b6f490438c882568a17 Dec 18 20:32:57 Claimco root: [203257] system.php:1157 @ loop: Scanning: 4:0:0:0 Node: /dev/sg4 Dec 18 20:32:57 Claimco root: [203257] system.php:1167 @ SMART: #:4|DEV:4:0:0:0=array Dec 18 20:32:57 Claimco root: [203257] system.php:1197 @ SMART: #:4|DEV:4:0:0:0|PROTOCOL=ATA Dec 18 20:32:57 Claimco root: [203257] system.php:1209 @ HASH: #:4:69934fc65ffee9accacdbf90dd8bf3720dfa46060096a94c0f4d429a2e7fd1c6 Dec 18 20:32:57 Claimco root: [203257] system.php:1157 @ loop: Scanning: 5:0:0:0 Node: /dev/sg5 Dec 18 20:32:58 Claimco root: [203258] system.php:1167 @ SMART: #:5|DEV:5:0:0:0=array Dec 18 20:32:58 Claimco root: [203258] system.php:1197 @ SMART: #:5|DEV:5:0:0:0|PROTOCOL=ATA Dec 18 20:32:58 Claimco root: [203258] system.php:1209 @ HASH: #:5:73df74bc4e29eab476fcb1fba1730d6b6b4190764ecd31f67d46d9e7d0158cd5 Dec 18 20:32:58 Claimco root: [203258] system.php:1157 @ loop: Scanning: 6:0:0:0 Node: /dev/sg6 Dec 18 20:32:58 Claimco root: [203258] system.php:1167 @ SMART: #:6|DEV:6:0:0:0=array Dec 18 20:32:58 Claimco root: [203258] system.php:1197 @ SMART: #:6|DEV:6:0:0:0|PROTOCOL=ATA Dec 18 20:32:58 Claimco root: [203258] system.php:1209 @ HASH: #:6:3e7079997f1408bbc68d3600e8c84d8fcd44793cd02426a64e52dadb99260f39 Dec 18 20:32:58 Claimco root: [203258] system.php:1157 @ loop: Scanning: 7:0:0:0 Node: /dev/sg7 Dec 18 20:32:58 Claimco root: [203258] system.php:1167 @ SMART: #:7|DEV:7:0:0:0=array Dec 18 20:32:58 Claimco root: [203258] system.php:1197 @ SMART: #:7|DEV:7:0:0:0|PROTOCOL=ATA Dec 18 20:32:58 Claimco root: [203258] system.php:1209 @ HASH: #:7:c48602aa03d6838bebdddd451bf250faa4df7a880ab646fb4fe17987472296b6 Dec 18 20:32:58 Claimco root: [203258] system.php:1157 @ loop: Scanning: 8:0:0:0 Node: /dev/sg8 Dec 18 20:32:59 Claimco root: [203259] system.php:1167 @ SMART: #:8|DEV:8:0:0:0=array Dec 18 20:32:59 Claimco root: [203259] system.php:1197 @ SMART: #:8|DEV:8:0:0:0|PROTOCOL=ATA Dec 18 20:32:59 Claimco root: [203259] system.php:1209 @ HASH: #:8:fd72c242b27fed988b5e4b41c29456d805163c32dd2693ee23649a0253f6385f Dec 18 20:32:59 Claimco root: [203259] system.php:1157 @ loop: Scanning: 9:0:0:0 Node: /dev/sg9 Dec 18 20:32:59 Claimco root: [203259] system.php:1167 @ SMART: #:9|DEV:9:0:0:0=array Dec 18 20:32:59 Claimco root: [203259] system.php:1197 @ SMART: #:9|DEV:9:0:0:0|PROTOCOL=ATA Dec 18 20:32:59 Claimco root: [203259] system.php:1209 @ HASH: #:9:c4f7b6cd8ccb8af6db41dbc73f8477faeed5cc0e35feac598149a2b61f082923 Dec 18 20:32:59 Claimco root: [203259] system.php:1157 @ loop: Scanning: 10:0:0:0 Node: /dev/sg10 Dec 18 20:32:59 Claimco root: [203259] system.php:1167 @ SMART: #:10|DEV:10:0:0:0=array Dec 18 20:32:59 Claimco root: [203259] system.php:1197 @ SMART: #:10|DEV:10:0:0:0|PROTOCOL=ATA Dec 18 20:32:59 Claimco root: [203259] system.php:1209 @ HASH: #:10:89304e011f3c13093d7f2a8d932749c0047c9cfd9309cb2935bd3e75b57080be Dec 18 20:32:59 Claimco root: [203259] system.php:1157 @ loop: Scanning: N:0:1:1 Node: /dev/nvme0n1 Dec 18 20:32:59 Claimco root: [203259] system.php:1167 @ SMART: #:11|DEV:N:0:1:1=array Dec 18 20:32:59 Claimco root: [203259] system.php:1197 @ SMART: #:11|DEV:N:0:1:1|PROTOCOL=NVMe Dec 18 20:32:59 Claimco root: [203259] system.php:1209 @ HASH: #:11:27e59d365ac0963eac3cfb7cd6d655c56ee2c1807a0ea92f6cb7c94d2316f5b0 Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: Plugin installed successfully! Dec 18 20:33:00 Claimco root: plugin: disklocation-master.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:00 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:33:00 Claimco root: plugin: installing: dynamix.active.streams.plg Dec 18 20:33:00 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:33:00 Claimco root: plugin: running: anonymous Dec 18 20:33:00 Claimco root: plugin: checking: /boot/config/plugins/dynamix.active.streams/dynamix.active.streams.txz - MD5 Dec 18 20:33:00 Claimco root: plugin: skipping: /boot/config/plugins/dynamix.active.streams/dynamix.active.streams.txz already exists Dec 18 20:33:00 Claimco root: plugin: running: /boot/config/plugins/dynamix.active.streams/dynamix.active.streams.txz Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: +============================================================================== Dec 18 20:33:00 Claimco root: | Installing new package /boot/config/plugins/dynamix.active.streams/dynamix.active.streams.txz Dec 18 20:33:00 Claimco root: +============================================================================== Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: Verifying package dynamix.active.streams.txz. Dec 18 20:33:00 Claimco root: Installing package dynamix.active.streams.txz: Dec 18 20:33:00 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:33:00 Claimco root: Package dynamix.active.streams.txz installed. Dec 18 20:33:00 Claimco root: plugin: running: anonymous Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: ----------------------------------------------------------- Dec 18 20:33:00 Claimco root: Plugin dynamix.active.streams is installed. Dec 18 20:33:00 Claimco root: This plugin requires Dynamix webGui to operate Dec 18 20:33:00 Claimco root: Copyright 2020, Bergware International Dec 18 20:33:00 Claimco root: Version: 2020.06.17 Dec 18 20:33:00 Claimco root: ----------------------------------------------------------- Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: plugin: dynamix.active.streams.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:00 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:33:00 Claimco root: plugin: installing: dynamix.file.manager.plg Dec 18 20:33:00 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:33:00 Claimco root: plugin: running: anonymous Dec 18 20:33:00 Claimco root: plugin: checking: /boot/config/plugins/dynamix.file.manager/dynamix.file.manager.txz - MD5 Dec 18 20:33:00 Claimco root: plugin: skipping: /boot/config/plugins/dynamix.file.manager/dynamix.file.manager.txz already exists Dec 18 20:33:00 Claimco root: plugin: running: /boot/config/plugins/dynamix.file.manager/dynamix.file.manager.txz Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: +============================================================================== Dec 18 20:33:00 Claimco root: | Installing new package /boot/config/plugins/dynamix.file.manager/dynamix.file.manager.txz Dec 18 20:33:00 Claimco root: +============================================================================== Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: Verifying package dynamix.file.manager.txz. Dec 18 20:33:00 Claimco root: Installing package dynamix.file.manager.txz: Dec 18 20:33:00 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:33:00 Claimco root: Package dynamix.file.manager.txz installed. Dec 18 20:33:00 Claimco root: plugin: running: anonymous Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: ----------------------------------------------------------- Dec 18 20:33:00 Claimco root: Plugin dynamix.file.manager is installed. Dec 18 20:33:00 Claimco root: This plugin requires Dynamix webGui to operate Dec 18 20:33:00 Claimco root: Copyright 2022, Bergware International Dec 18 20:33:00 Claimco root: Version: 2022.11.10 Dec 18 20:33:00 Claimco root: ----------------------------------------------------------- Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: plugin: dynamix.file.manager.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:00 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:33:00 Claimco root: plugin: installing: dynamix.system.buttons.plg Dec 18 20:33:00 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:33:00 Claimco root: plugin: running: anonymous Dec 18 20:33:00 Claimco root: plugin: checking: /boot/config/plugins/dynamix.system.buttons/dynamix.system.buttons.txz - MD5 Dec 18 20:33:00 Claimco root: plugin: skipping: /boot/config/plugins/dynamix.system.buttons/dynamix.system.buttons.txz already exists Dec 18 20:33:00 Claimco root: plugin: running: /boot/config/plugins/dynamix.system.buttons/dynamix.system.buttons.txz Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: +============================================================================== Dec 18 20:33:00 Claimco root: | Installing new package /boot/config/plugins/dynamix.system.buttons/dynamix.system.buttons.txz Dec 18 20:33:00 Claimco root: +============================================================================== Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: Verifying package dynamix.system.buttons.txz. Dec 18 20:33:00 Claimco root: Installing package dynamix.system.buttons.txz: Dec 18 20:33:00 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:33:00 Claimco root: Package dynamix.system.buttons.txz installed. Dec 18 20:33:00 Claimco root: plugin: running: anonymous Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: ----------------------------------------------------------- Dec 18 20:33:00 Claimco root: Plugin dynamix.system.buttons is installed. Dec 18 20:33:00 Claimco root: This plugin requires Dynamix webGui to operate Dec 18 20:33:00 Claimco root: Copyright 2020, Bergware International Dec 18 20:33:00 Claimco root: Version: 2020.06.20 Dec 18 20:33:00 Claimco root: ----------------------------------------------------------- Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: plugin: dynamix.system.buttons.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:00 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:33:00 Claimco root: plugin: installing: dynamix.system.info.plg Dec 18 20:33:00 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:33:00 Claimco root: plugin: running: anonymous Dec 18 20:33:00 Claimco root: plugin: checking: /boot/config/plugins/dynamix.system.info/dynamix.system.info.txz - MD5 Dec 18 20:33:00 Claimco root: plugin: skipping: /boot/config/plugins/dynamix.system.info/dynamix.system.info.txz already exists Dec 18 20:33:00 Claimco root: plugin: running: /boot/config/plugins/dynamix.system.info/dynamix.system.info.txz Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: +============================================================================== Dec 18 20:33:00 Claimco root: | Installing new package /boot/config/plugins/dynamix.system.info/dynamix.system.info.txz Dec 18 20:33:00 Claimco root: +============================================================================== Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: Verifying package dynamix.system.info.txz. Dec 18 20:33:00 Claimco root: Installing package dynamix.system.info.txz: Dec 18 20:33:00 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:33:00 Claimco root: Package dynamix.system.info.txz installed. Dec 18 20:33:00 Claimco root: plugin: running: anonymous Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: ----------------------------------------------------------- Dec 18 20:33:00 Claimco root: Plugin dynamix.system.info is installed. Dec 18 20:33:00 Claimco root: This plugin requires Dynamix webGui to operate Dec 18 20:33:00 Claimco root: Copyright 2020, Bergware International Dec 18 20:33:00 Claimco root: Version: 2020.06.21 Dec 18 20:33:00 Claimco root: ----------------------------------------------------------- Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: plugin: dynamix.system.info.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:00 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:33:00 Claimco root: plugin: installing: dynamix.system.temp.plg Dec 18 20:33:00 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:33:00 Claimco root: plugin: running: anonymous Dec 18 20:33:00 Claimco root: plugin: checking: /boot/config/plugins/dynamix.system.temp/dynamix.system.temp.txz - MD5 Dec 18 20:33:00 Claimco root: plugin: skipping: /boot/config/plugins/dynamix.system.temp/dynamix.system.temp.txz already exists Dec 18 20:33:00 Claimco root: plugin: running: /boot/config/plugins/dynamix.system.temp/dynamix.system.temp.txz Dec 18 20:33:00 Claimco root: Dec 18 20:33:00 Claimco root: +============================================================================== Dec 18 20:33:00 Claimco root: | Installing new package /boot/config/plugins/dynamix.system.temp/dynamix.system.temp.txz Dec 18 20:33:00 Claimco root: +============================================================================== Dec 18 20:33:00 Claimco root: Dec 18 20:33:01 Claimco root: Verifying package dynamix.system.temp.txz. Dec 18 20:33:01 Claimco root: Installing package dynamix.system.temp.txz: Dec 18 20:33:01 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:33:01 Claimco root: Package dynamix.system.temp.txz installed. Dec 18 20:33:01 Claimco root: plugin: skipping: sensors-detect - Unraid version too high, requires at most version 6.7.2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:01 Claimco root: plugin: running: anonymous Dec 18 20:33:01 Claimco kernel: nct6775: Found NCT6791D or compatible chip at 0x2e:0x290 Dec 18 20:33:01 Claimco root: Dec 18 20:33:01 Claimco root: ----------------------------------------------------------- Dec 18 20:33:01 Claimco root: Plugin dynamix.system.temp is installed. Dec 18 20:33:01 Claimco root: This plugin requires Dynamix webGui to operate Dec 18 20:33:01 Claimco root: Copyright 2021, Bergware International Dec 18 20:33:01 Claimco root: Version: 2022.09.16b Dec 18 20:33:01 Claimco root: ----------------------------------------------------------- Dec 18 20:33:01 Claimco root: Dec 18 20:33:01 Claimco root: plugin: dynamix.system.temp.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:01 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:33:01 Claimco root: plugin: installing: dynamix.unraid.net.plg Dec 18 20:33:01 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:33:01 Claimco root: plugin: running: anonymous Dec 18 20:33:01 Claimco root: Installing dynamix.unraid.net.plg 2022.11.29.0742 with Unraid API 2.54.0 Dec 18 20:33:01 Claimco root: plugin: running: anonymous Dec 18 20:33:01 Claimco root: Checking DNS... Dec 18 20:33:01 Claimco root: Validating /boot/config/plugins/dynamix.my.servers/dynamix.unraid.net.txz... ok. Dec 18 20:33:02 Claimco root: Validating /boot/config/plugins/dynamix.my.servers/unraid-api.tgz... ok. Dec 18 20:33:02 Claimco root: plugin: checking: /boot/config/plugins/dynamix.my.servers/dynamix.unraid.net.txz - SHA256 Dec 18 20:33:02 Claimco root: plugin: skipping: /boot/config/plugins/dynamix.my.servers/dynamix.unraid.net.txz already exists Dec 18 20:33:02 Claimco root: plugin: checking: /boot/config/plugins/dynamix.my.servers/unraid-api.tgz - SHA256 Dec 18 20:33:02 Claimco root: plugin: skipping: /boot/config/plugins/dynamix.my.servers/unraid-api.tgz already exists Dec 18 20:33:02 Claimco root: plugin: running: anonymous ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:02 Claimco root: 🕹️ Installing JavaScript web components Dec 18 20:33:03 Claimco root: ✅ Finished installing web components Dec 18 20:33:03 Claimco root: plugin: running: anonymous ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:03 Claimco root: Dec 18 20:33:03 Claimco root: +============================================================================== Dec 18 20:33:03 Claimco root: | Installing new package /boot/config/plugins/dynamix.my.servers/dynamix.unraid.net.txz Dec 18 20:33:03 Claimco root: +============================================================================== Dec 18 20:33:03 Claimco root: Dec 18 20:33:03 Claimco root: Verifying package dynamix.unraid.net.txz. Dec 18 20:33:03 Claimco root: Installing package dynamix.unraid.net.txz: Dec 18 20:33:03 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:33:03 Claimco root: Package dynamix.unraid.net.txz installed. Dec 18 20:33:03 Claimco root: ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:03 Claimco root: ✅ Installation is complete Dec 18 20:33:03 Claimco root: Dec 18 20:33:03 Claimco root: plugin: dynamix.unraid.net.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:03 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:33:03 Claimco root: plugin: installing: fix.common.problems.plg Dec 18 20:33:03 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:33:03 Claimco root: plugin: checking: /boot/config/plugins/fix.common.problems/fix.common.problems-2022.12.18-x86_64-1.txz - MD5 Dec 18 20:33:03 Claimco root: plugin: skipping: /boot/config/plugins/fix.common.problems/fix.common.problems-2022.12.18-x86_64-1.txz already exists Dec 18 20:33:03 Claimco root: plugin: running: /boot/config/plugins/fix.common.problems/fix.common.problems-2022.12.18-x86_64-1.txz Dec 18 20:33:03 Claimco root: Dec 18 20:33:03 Claimco root: +============================================================================== Dec 18 20:33:03 Claimco root: | Installing new package /boot/config/plugins/fix.common.problems/fix.common.problems-2022.12.18-x86_64-1.txz Dec 18 20:33:03 Claimco root: +============================================================================== Dec 18 20:33:03 Claimco root: Dec 18 20:33:03 Claimco root: Verifying package fix.common.problems-2022.12.18-x86_64-1.txz. Dec 18 20:33:03 Claimco root: Installing package fix.common.problems-2022.12.18-x86_64-1.txz: Dec 18 20:33:03 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:33:03 Claimco root: Package fix.common.problems-2022.12.18-x86_64-1.txz installed. Dec 18 20:33:03 Claimco root: plugin: running: anonymous Dec 18 20:33:03 Claimco root: ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:03 Claimco root: ---------------------------------------------------- Dec 18 20:33:03 Claimco root: fix.common.problems has been installed. Dec 18 20:33:03 Claimco root: Copyright 2016-2022, Andrew Zawadzki Dec 18 20:33:03 Claimco root: Version: 2022.12.18 Dec 18 20:33:03 Claimco root: ---------------------------------------------------- Dec 18 20:33:03 Claimco root: Dec 18 20:33:03 Claimco root: plugin: fix.common.problems.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:03 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:33:03 Claimco root: plugin: installing: recycle.bin.plg Dec 18 20:33:03 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:33:03 Claimco root: plugin: checking: /boot/config/plugins/recycle.bin/recycle.bin-2022.12.10.tgz - MD5 Dec 18 20:33:03 Claimco root: plugin: skipping: /boot/config/plugins/recycle.bin/recycle.bin-2022.12.10.tgz already exists Dec 18 20:33:03 Claimco root: plugin: creating: /tmp/recycle.bin/wait_recycle.bin - from INLINE content Dec 18 20:33:03 Claimco root: plugin: setting: /tmp/recycle.bin/wait_recycle.bin - mode to 0770 Dec 18 20:33:03 Claimco root: plugin: creating: /tmp/recycle.bin/remove-smb-extra - from INLINE content Dec 18 20:33:03 Claimco root: plugin: setting: /tmp/recycle.bin/remove-smb-extra - mode to 0770 Dec 18 20:33:03 Claimco root: plugin: running: anonymous ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:03 Claimco root: plugin: skipping: /boot/config/plugins/recycle.bin/recycle.bin.cfg already exists Dec 18 20:33:03 Claimco root: plugin: running: anonymous Dec 18 20:33:03 Claimco root: ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 18 20:33:03 Claimco root: plugin: running: anonymous Dec 18 20:33:03 Claimco root: Dec 18 20:33:03 Claimco root: ----------------------------------------------------------- Dec 18 20:33:03 Claimco root: recycle.bin has been installed. Dec 18 20:33:03 Claimco root: Copyright 2015-2022 dlandon Dec 18 20:33:03 Claimco root: Version: 2022.12.10 Dec 18 20:33:03 Claimco root: ----------------------------------------------------------- Dec 18 20:33:03 Claimco root: Dec 18 20:33:03 Claimco root: plugin: recycle.bin.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:03 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:33:04 Claimco root: plugin: installing: unassigned.devices-plus.plg Dec 18 20:33:04 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:33:04 Claimco root: plugin: running: anonymous Dec 18 20:33:04 Claimco root: plugin: checking: /boot/config/plugins/unassigned.devices-plus/packages/parted-3.3-x86_64-1.txz - MD5 Dec 18 20:33:04 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices-plus/packages/parted-3.3-x86_64-1.txz already exists Dec 18 20:33:04 Claimco root: plugin: running: /boot/config/plugins/unassigned.devices-plus/packages/parted-3.3-x86_64-1.txz Dec 18 20:33:04 Claimco root: Dec 18 20:33:04 Claimco root: +============================================================================== Dec 18 20:33:04 Claimco root: | Installing new package /boot/config/plugins/unassigned.devices-plus/packages/parted-3.3-x86_64-1.txz Dec 18 20:33:04 Claimco root: +============================================================================== Dec 18 20:33:04 Claimco root: Dec 18 20:33:04 Claimco root: Verifying package parted-3.3-x86_64-1.txz. Dec 18 20:33:04 Claimco root: Installing package parted-3.3-x86_64-1.txz: Dec 18 20:33:04 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:33:04 Claimco root: # parted (GNU disk partitioning tool) Dec 18 20:33:04 Claimco root: # Dec 18 20:33:04 Claimco root: # GNU Parted is a program for creating, destroying, resizing, checking Dec 18 20:33:04 Claimco root: # and copying partitions, and the filesystems on them. This is useful Dec 18 20:33:04 Claimco root: # for creating space for new operating systems, reorganizing disk Dec 18 20:33:04 Claimco root: # usage, copying data between hard disks, and disk imaging. Dec 18 20:33:04 Claimco root: # Dec 18 20:33:04 Claimco root: Executing install script for parted-3.3-x86_64-1.txz. Dec 18 20:33:04 Claimco root: Package parted-3.3-x86_64-1.txz installed. Dec 18 20:33:04 Claimco root: plugin: checking: /boot/config/plugins/unassigned.devices-plus/packages/parted-3.5-x86_64-1.txz - MD5 Dec 18 20:33:04 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices-plus/packages/parted-3.5-x86_64-1.txz already exists Dec 18 20:33:04 Claimco root: plugin: running: /boot/config/plugins/unassigned.devices-plus/packages/parted-3.5-x86_64-1.txz Dec 18 20:33:04 Claimco root: Dec 18 20:33:04 Claimco root: +============================================================================== Dec 18 20:33:04 Claimco root: | Upgrading parted-3.3-x86_64-1 package using /boot/config/plugins/unassigned.devices-plus/packages/parted-3.5-x86_64-1.txz Dec 18 20:33:04 Claimco root: +============================================================================== Dec 18 20:33:04 Claimco root: Pre-installing package parted-3.5-x86_64-1... Dec 18 20:33:04 Claimco root: Removing package: parted-3.3-x86_64-1-upgraded-2022-12-18,20:33:04 Dec 18 20:33:04 Claimco root: --> Deleting /usr/doc/parted-3.3/API Dec 18 20:33:04 Claimco root: --> Deleting /usr/doc/parted-3.3/AUTHORS Dec 18 20:33:04 Claimco root: --> Deleting /usr/doc/parted-3.3/BUGS Dec 18 20:33:04 Claimco root: --> Deleting /usr/doc/parted-3.3/COPYING Dec 18 20:33:04 Claimco root: --> Deleting /usr/doc/parted-3.3/ChangeLog Dec 18 20:33:04 Claimco root: --> Deleting /usr/doc/parted-3.3/FAT Dec 18 20:33:04 Claimco root: --> Deleting /usr/doc/parted-3.3/NEWS Dec 18 20:33:04 Claimco root: --> Deleting /usr/doc/parted-3.3/README Dec 18 20:33:04 Claimco root: --> Deleting /usr/doc/parted-3.3/THANKS Dec 18 20:33:04 Claimco root: --> Deleting /usr/doc/parted-3.3/TODO Dec 18 20:33:04 Claimco root: --> Deleting /usr/doc/parted-3.3/USER.jp Dec 18 20:33:04 Claimco root: --> Deleting /usr/lib64/libparted-fs-resize.so.0.0.2 Dec 18 20:33:04 Claimco root: --> Deleting /usr/lib64/libparted.so.2.0.2 Dec 18 20:33:04 Claimco root: --> Deleting empty directory /usr/doc/parted-3.3/ Dec 18 20:33:04 Claimco root: Verifying package parted-3.5-x86_64-1.txz. Dec 18 20:33:04 Claimco root: Installing package parted-3.5-x86_64-1.txz: Dec 18 20:33:04 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:33:04 Claimco root: # parted (GNU disk partitioning tool) Dec 18 20:33:04 Claimco root: # Dec 18 20:33:04 Claimco root: # GNU Parted is a program for creating, destroying, resizing, checking Dec 18 20:33:04 Claimco root: # and copying partitions, and the filesystems on them. This is useful Dec 18 20:33:04 Claimco root: # for creating space for new operating systems, reorganizing disk Dec 18 20:33:04 Claimco root: # usage, copying data between hard disks, and disk imaging. Dec 18 20:33:04 Claimco root: # Dec 18 20:33:04 Claimco root: Executing install script for parted-3.5-x86_64-1.txz. Dec 18 20:33:04 Claimco root: Package parted-3.5-x86_64-1.txz installed. Dec 18 20:33:04 Claimco root: Package parted-3.3-x86_64-1 upgraded with new package /boot/config/plugins/unassigned.devices-plus/packages/parted-3.5-x86_64-1.txz. Dec 18 20:33:04 Claimco root: plugin: checking: /boot/config/plugins/unassigned.devices-plus/packages/exfat-utils-1.3.0-x86_64-1_slonly.txz - MD5 Dec 18 20:33:04 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices-plus/packages/exfat-utils-1.3.0-x86_64-1_slonly.txz already exists Dec 18 20:33:04 Claimco root: plugin: running: /boot/config/plugins/unassigned.devices-plus/packages/exfat-utils-1.3.0-x86_64-1_slonly.txz Dec 18 20:33:04 Claimco root: Dec 18 20:33:04 Claimco root: +============================================================================== Dec 18 20:33:04 Claimco root: | Installing new package /boot/config/plugins/unassigned.devices-plus/packages/exfat-utils-1.3.0-x86_64-1_slonly.txz Dec 18 20:33:04 Claimco root: +============================================================================== Dec 18 20:33:04 Claimco root: Dec 18 20:33:04 Claimco root: Verifying package exfat-utils-1.3.0-x86_64-1_slonly.txz. Dec 18 20:33:04 Claimco root: Installing package exfat-utils-1.3.0-x86_64-1_slonly.txz: Dec 18 20:33:04 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:33:04 Claimco root: # exfat-utils (exFAT system utilities) Dec 18 20:33:04 Claimco root: # Dec 18 20:33:04 Claimco root: # This project aims to provide a full-featured exFAT file system Dec 18 20:33:04 Claimco root: # implementation for GNU/Linux and other Unix-like systems as a FUSE Dec 18 20:33:04 Claimco root: # module and a set of utilities. Dec 18 20:33:04 Claimco root: # module. Dec 18 20:33:04 Claimco root: # Dec 18 20:33:04 Claimco root: # This package contains the utilities. Dec 18 20:33:04 Claimco root: # Dec 18 20:33:04 Claimco root: # Homepage: https://github.com/relan/exfat Dec 18 20:33:04 Claimco root: # Dec 18 20:33:04 Claimco root: Executing install script for exfat-utils-1.3.0-x86_64-1_slonly.txz. Dec 18 20:33:04 Claimco root: Package exfat-utils-1.3.0-x86_64-1_slonly.txz installed. Dec 18 20:33:04 Claimco root: plugin: checking: /boot/config/plugins/unassigned.devices-plus/packages/fuse-exfat-1.3.0-x86_64-1_slonly.txz - MD5 Dec 18 20:33:04 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices-plus/packages/fuse-exfat-1.3.0-x86_64-1_slonly.txz already exists Dec 18 20:33:04 Claimco root: plugin: running: /boot/config/plugins/unassigned.devices-plus/packages/fuse-exfat-1.3.0-x86_64-1_slonly.txz Dec 18 20:33:04 Claimco root: Dec 18 20:33:04 Claimco root: +============================================================================== Dec 18 20:33:04 Claimco root: | Installing new package /boot/config/plugins/unassigned.devices-plus/packages/fuse-exfat-1.3.0-x86_64-1_slonly.txz Dec 18 20:33:04 Claimco root: +============================================================================== Dec 18 20:33:04 Claimco root: Dec 18 20:33:04 Claimco root: Verifying package fuse-exfat-1.3.0-x86_64-1_slonly.txz. Dec 18 20:33:04 Claimco root: Installing package fuse-exfat-1.3.0-x86_64-1_slonly.txz: Dec 18 20:33:04 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:33:04 Claimco root: # fuse-exfat (exFAT FUSE module) Dec 18 20:33:04 Claimco root: # Dec 18 20:33:04 Claimco root: # This project aims to provide a full-featured exFAT file system Dec 18 20:33:04 Claimco root: # implementation for GNU/Linux and other Unix-like systems as a FUSE Dec 18 20:33:04 Claimco root: # module and a set of utilities. Dec 18 20:33:04 Claimco root: # module. Dec 18 20:33:04 Claimco root: # Dec 18 20:33:04 Claimco root: # This package contains the FUSE module. Dec 18 20:33:04 Claimco root: # Dec 18 20:33:04 Claimco root: # Homepage: https://github.com/relan/exfat Dec 18 20:33:04 Claimco root: # Dec 18 20:33:04 Claimco root: Executing install script for fuse-exfat-1.3.0-x86_64-1_slonly.txz. Dec 18 20:33:04 Claimco root: Package fuse-exfat-1.3.0-x86_64-1_slonly.txz installed. Dec 18 20:33:04 Claimco root: plugin: checking: /boot/config/plugins/unassigned.devices-plus/packages/hfsprogs-332.25-x86_64-2sl.txz - MD5 Dec 18 20:33:04 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices-plus/packages/hfsprogs-332.25-x86_64-2sl.txz already exists Dec 18 20:33:04 Claimco root: plugin: running: /boot/config/plugins/unassigned.devices-plus/packages/hfsprogs-332.25-x86_64-2sl.txz Dec 18 20:33:04 Claimco root: Dec 18 20:33:04 Claimco root: +============================================================================== Dec 18 20:33:04 Claimco root: | Installing new package /boot/config/plugins/unassigned.devices-plus/packages/hfsprogs-332.25-x86_64-2sl.txz Dec 18 20:33:04 Claimco root: +============================================================================== Dec 18 20:33:04 Claimco root: Dec 18 20:33:04 Claimco root: Verifying package hfsprogs-332.25-x86_64-2sl.txz. Dec 18 20:33:04 Claimco root: Installing package hfsprogs-332.25-x86_64-2sl.txz: Dec 18 20:33:04 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:33:04 Claimco root: # hfsprogs - hfs+ user space utils Dec 18 20:33:04 Claimco root: # Dec 18 20:33:04 Claimco root: # The HFS+ file system used by Apple Computer for their Mac OS is Dec 18 20:33:04 Claimco root: # supported by the Linux kernel. Apple provides mkfs and fsck for Dec 18 20:33:04 Claimco root: # HFS+ with the Unix core of their operating system, Darwin. Dec 18 20:33:04 Claimco root: # Dec 18 20:33:04 Claimco root: # This package is a port of Apple's tools for HFS+ filesystems. Dec 18 20:33:04 Claimco root: # Dec 18 20:33:04 Claimco root: # http://www.opensource.apple.com Dec 18 20:33:04 Claimco root: Package hfsprogs-332.25-x86_64-2sl.txz installed. Dec 18 20:33:04 Claimco root: plugin: checking: /boot/config/plugins/unassigned.devices-plus/packages/libbsd-0.10.0-x86_64-2_slonly.txz - MD5 Dec 18 20:33:04 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices-plus/packages/libbsd-0.10.0-x86_64-2_slonly.txz already exists Dec 18 20:33:04 Claimco root: plugin: running: /boot/config/plugins/unassigned.devices-plus/packages/libbsd-0.10.0-x86_64-2_slonly.txz Dec 18 20:33:04 Claimco root: Dec 18 20:33:04 Claimco root: +============================================================================== Dec 18 20:33:04 Claimco root: | Installing new package /boot/config/plugins/unassigned.devices-plus/packages/libbsd-0.10.0-x86_64-2_slonly.txz Dec 18 20:33:04 Claimco root: +============================================================================== Dec 18 20:33:04 Claimco root: Dec 18 20:33:05 Claimco root: Verifying package libbsd-0.10.0-x86_64-2_slonly.txz. Dec 18 20:33:05 Claimco root: Installing package libbsd-0.10.0-x86_64-2_slonly.txz: Dec 18 20:33:05 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:33:05 Claimco root: # libbsd (library of BSD functions) Dec 18 20:33:05 Claimco root: # Dec 18 20:33:05 Claimco root: # This library provides useful functions commonly found on BSD systems, Dec 18 20:33:05 Claimco root: # and lacking on others like GNU systems, thus making it easier to port Dec 18 20:33:05 Claimco root: # projects with strong BSD origins, without needing to embed the same Dec 18 20:33:05 Claimco root: # code over and over again on each project. Dec 18 20:33:05 Claimco root: # Dec 18 20:33:05 Claimco root: # Homepage: http://libbsd.freedesktop.org/wiki/ Dec 18 20:33:05 Claimco root: # Dec 18 20:33:05 Claimco root: Executing install script for libbsd-0.10.0-x86_64-2_slonly.txz. Dec 18 20:33:05 Claimco root: Package libbsd-0.10.0-x86_64-2_slonly.txz installed. Dec 18 20:33:05 Claimco root: plugin: checking: /boot/config/plugins/unassigned.devices-plus/packages/apfsfuse-v20200708-x86_64-1.txz - MD5 Dec 18 20:33:05 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices-plus/packages/apfsfuse-v20200708-x86_64-1.txz already exists Dec 18 20:33:05 Claimco root: plugin: running: /boot/config/plugins/unassigned.devices-plus/packages/apfsfuse-v20200708-x86_64-1.txz Dec 18 20:33:05 Claimco root: Dec 18 20:33:05 Claimco root: +============================================================================== Dec 18 20:33:05 Claimco root: | Installing new package /boot/config/plugins/unassigned.devices-plus/packages/apfsfuse-v20200708-x86_64-1.txz Dec 18 20:33:05 Claimco root: +============================================================================== Dec 18 20:33:05 Claimco root: Dec 18 20:33:05 Claimco root: Verifying package apfsfuse-v20200708-x86_64-1.txz. Dec 18 20:33:05 Claimco root: Installing package apfsfuse-v20200708-x86_64-1.txz: Dec 18 20:33:05 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:33:05 Claimco root: # apfs-fuse v20200708 Dec 18 20:33:05 Claimco root: # Dec 18 20:33:05 Claimco root: # Custom apfs-fuse v20200708 package for Unraid by ich777 Dec 18 20:33:05 Claimco root: # https://github.com/sgan81/apfs-fuse Dec 18 20:33:05 Claimco root: Package apfsfuse-v20200708-x86_64-1.txz installed. Dec 18 20:33:05 Claimco root: plugin: creating: /usr/local/emhttp/plugins/unassigned.devices-plus/README.md - from INLINE content Dec 18 20:33:05 Claimco root: plugin: running: anonymous Dec 18 20:33:05 Claimco root: Dec 18 20:33:05 Claimco root: ----------------------------------------------------------- Dec 18 20:33:05 Claimco root: unassigned.devices-plus has been installed. Dec 18 20:33:05 Claimco root: Copyright 2015, gfjardim Dec 18 20:33:05 Claimco root: Copyright 2016-2021, dlandon Dec 18 20:33:05 Claimco root: Version: 2022.11.06 Dec 18 20:33:05 Claimco root: ----------------------------------------------------------- Dec 18 20:33:05 Claimco root: Dec 18 20:33:05 Claimco root: plugin: unassigned.devices-plus.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:05 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:33:05 Claimco root: plugin: installing: unassigned.devices.plg Dec 18 20:33:05 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:33:05 Claimco root: plugin: checking: /boot/config/plugins/unassigned.devices/unassigned.devices-2022.12.12.tgz - MD5 Dec 18 20:33:05 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices/unassigned.devices-2022.12.12.tgz already exists Dec 18 20:33:05 Claimco root: plugin: running: anonymous Dec 18 20:33:05 Claimco root: plugin: creating: /tmp/start_unassigned_devices - from INLINE content Dec 18 20:33:05 Claimco root: plugin: setting: /tmp/start_unassigned_devices - mode to 0770 Dec 18 20:33:05 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices/unassigned.devices.cfg already exists Dec 18 20:33:05 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices/samba_mount.cfg already exists Dec 18 20:33:05 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices/iso_mount.cfg already exists Dec 18 20:33:05 Claimco root: plugin: creating: /tmp/unassigned.devices/add-smb - from INLINE content Dec 18 20:33:05 Claimco root: plugin: setting: /tmp/unassigned.devices/add-smb - mode to 0770 Dec 18 20:33:05 Claimco root: plugin: running: anonymous Dec 18 20:33:05 Claimco root: Dec 18 20:33:05 Claimco root: ----------------------------------------------------------- Dec 18 20:33:05 Claimco root: unassigned.devices has been installed. Dec 18 20:33:05 Claimco root: Copyright 2015, gfjardim Dec 18 20:33:05 Claimco root: Copyright 2016-2022, dlandon Dec 18 20:33:05 Claimco root: Version: 2022.12.12 Dec 18 20:33:05 Claimco root: Dec 18 20:33:05 Claimco root: Note: Dec 18 20:33:05 Claimco root: Install the Unassigned Devices Plus plugin if you need to Dec 18 20:33:05 Claimco root: mount exFAT, HFS+, apfs file formats or format disks. Dec 18 20:33:05 Claimco root: ----------------------------------------------------------- Dec 18 20:33:05 Claimco root: Dec 18 20:33:05 Claimco root: plugin: unassigned.devices.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:05 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:33:05 Claimco root: plugin: installing: unassigned.devices.preclear.plg Dec 18 20:33:05 Claimco root: Executing hook script: pre_plugin_checks Dec 18 20:33:05 Claimco root: plugin: running: anonymous Dec 18 20:33:05 Claimco root: plugin: checking: /boot/config/plugins/unassigned.devices.preclear/unassigned.devices.preclear-2022.12.12.tgz - MD5 Dec 18 20:33:05 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices.preclear/unassigned.devices.preclear-2022.12.12.tgz already exists Dec 18 20:33:05 Claimco root: plugin: checking: /boot/config/plugins/unassigned.devices.preclear/tmux-3.1b-x86_64-1.txz - MD5 Dec 18 20:33:05 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices.preclear/tmux-3.1b-x86_64-1.txz already exists Dec 18 20:33:05 Claimco root: plugin: running: /boot/config/plugins/unassigned.devices.preclear/tmux-3.1b-x86_64-1.txz Dec 18 20:33:05 Claimco root: Dec 18 20:33:05 Claimco root: +============================================================================== Dec 18 20:33:05 Claimco root: | Installing new package /boot/config/plugins/unassigned.devices.preclear/tmux-3.1b-x86_64-1.txz Dec 18 20:33:05 Claimco root: +============================================================================== Dec 18 20:33:05 Claimco root: Dec 18 20:33:05 Claimco root: Verifying package tmux-3.1b-x86_64-1.txz. Dec 18 20:33:05 Claimco root: Installing package tmux-3.1b-x86_64-1.txz: Dec 18 20:33:05 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:33:05 Claimco root: # tmux (terminal multiplexer) Dec 18 20:33:05 Claimco root: # Dec 18 20:33:05 Claimco root: # tmux is a terminal multiplexer. It enables a number of terminals Dec 18 20:33:05 Claimco root: # (or windows) to be accessed and controlled from a single terminal. Dec 18 20:33:05 Claimco root: # tmux is intended to be a simple, modern, BSD-licensed alternative to Dec 18 20:33:05 Claimco root: # programs such as GNU screen. Dec 18 20:33:05 Claimco root: # Dec 18 20:33:05 Claimco root: # Homepage: https://github.com/tmux/tmux/wiki Dec 18 20:33:05 Claimco root: # Dec 18 20:33:05 Claimco root: Executing install script for tmux-3.1b-x86_64-1.txz. Dec 18 20:33:05 Claimco root: Package tmux-3.1b-x86_64-1.txz installed. Dec 18 20:33:05 Claimco root: plugin: checking: /boot/config/plugins/unassigned.devices.preclear/tmux-3.3a-x86_64-1.txz - MD5 Dec 18 20:33:05 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices.preclear/tmux-3.3a-x86_64-1.txz already exists Dec 18 20:33:05 Claimco root: plugin: running: /boot/config/plugins/unassigned.devices.preclear/tmux-3.3a-x86_64-1.txz Dec 18 20:33:05 Claimco root: Dec 18 20:33:05 Claimco root: +============================================================================== Dec 18 20:33:05 Claimco root: | Upgrading tmux-3.1b-x86_64-1 package using /boot/config/plugins/unassigned.devices.preclear/tmux-3.3a-x86_64-1.txz Dec 18 20:33:05 Claimco root: +============================================================================== Dec 18 20:33:05 Claimco root: Pre-installing package tmux-3.3a-x86_64-1... Dec 18 20:33:05 Claimco root: Removing package: tmux-3.1b-x86_64-1-upgraded-2022-12-18,20:33:05 Dec 18 20:33:05 Claimco root: --> Deleting /usr/doc/tmux-3.1b/CHANGES Dec 18 20:33:05 Claimco root: --> Deleting /usr/doc/tmux-3.1b/README Dec 18 20:33:05 Claimco root: --> Deleting /usr/doc/tmux-3.1b/example_tmux.conf Dec 18 20:33:05 Claimco root: --> Deleting empty directory /usr/doc/tmux-3.1b/ Dec 18 20:33:05 Claimco root: Verifying package tmux-3.3a-x86_64-1.txz. Dec 18 20:33:05 Claimco root: Installing package tmux-3.3a-x86_64-1.txz: Dec 18 20:33:05 Claimco root: PACKAGE DESCRIPTION: Dec 18 20:33:05 Claimco root: # tmux (terminal multiplexer) Dec 18 20:33:05 Claimco root: # Dec 18 20:33:05 Claimco root: # tmux is a terminal multiplexer. It enables a number of terminals Dec 18 20:33:05 Claimco root: # (or windows) to be accessed and controlled from a single terminal. Dec 18 20:33:05 Claimco root: # tmux is intended to be a simple, modern, BSD-licensed alternative to Dec 18 20:33:05 Claimco root: # programs such as GNU screen. Dec 18 20:33:05 Claimco root: # Dec 18 20:33:05 Claimco root: # Homepage: https://github.com/tmux/tmux/wiki Dec 18 20:33:05 Claimco root: # Dec 18 20:33:05 Claimco root: Executing install script for tmux-3.3a-x86_64-1.txz. Dec 18 20:33:05 Claimco root: Package tmux-3.3a-x86_64-1.txz installed. Dec 18 20:33:05 Claimco root: Package tmux-3.1b-x86_64-1 upgraded with new package /boot/config/plugins/unassigned.devices.preclear/tmux-3.3a-x86_64-1.txz. Dec 18 20:33:05 Claimco root: plugin: checking: /boot/config/plugins/unassigned.devices.preclear/utempter-1.2.0-x86_64-3.txz - MD5 Dec 18 20:33:05 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices.preclear/utempter-1.2.0-x86_64-3.txz already exists Dec 18 20:33:05 Claimco root: plugin: running: /boot/config/plugins/unassigned.devices.preclear/utempter-1.2.0-x86_64-3.txz Dec 18 20:33:05 Claimco root: Dec 18 20:33:05 Claimco root: +============================================================================== Dec 18 20:33:05 Claimco root: | Skipping package utempter-1.2.0-x86_64-3 (already installed) Dec 18 20:33:05 Claimco root: +============================================================================== Dec 18 20:33:05 Claimco root: Dec 18 20:33:05 Claimco root: plugin: running: anonymous ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:05 Claimco root: Checking tmux operation... Dec 18 20:33:09 Claimco root: Dec 18 20:33:09 Claimco root: ----------------------------------------------------------- Dec 18 20:33:09 Claimco root: unassigned.devices.preclear has been installed. Dec 18 20:33:09 Claimco root: Copyright 2015-2020, gfjardim Dec 18 20:33:09 Claimco root: Copyright 2022, dlandon Dec 18 20:33:09 Claimco root: Version: 2022.12.12 Dec 18 20:33:09 Claimco root: ----------------------------------------------------------- Dec 18 20:33:09 Claimco root: Dec 18 20:33:09 Claimco root: plugin: unassigned.devices.preclear.plg installed ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:09 Claimco root: Executing hook script: post_plugin_checks Dec 18 20:33:09 Claimco root: Installing language packs Dec 18 20:33:09 Claimco root: Starting go script Dec 18 20:33:09 Claimco root: Starting emhttpd Dec 18 20:33:09 Claimco emhttpd: Unraid(tm) System Management Utility version 6.11.5 Dec 18 20:33:09 Claimco emhttpd: Copyright (C) 2005-2022, Lime Technology, Inc. Dec 18 20:33:09 Claimco emhttpd: shcmd (3): /usr/local/emhttp/webGui/scripts/update_access Dec 18 20:33:09 Claimco sshd[1147]: Received signal 15; terminating. Dec 18 20:33:10 Claimco sshd[6415]: Server listening on 0.0.0.0 port 22. Dec 18 20:33:10 Claimco sshd[6415]: Server listening on :: port 22. Dec 18 20:33:11 Claimco emhttpd: shcmd (5): modprobe md-mod super=/boot/config/super.dat Dec 18 20:33:11 Claimco kernel: md: unRAID driver 2.9.25 installed Dec 18 20:33:11 Claimco emhttpd: Plus key detected, GUID: 1..0 FILE: /boot/config/Plus.key Dec 18 20:33:11 Claimco emhttpd: Device inventory: Dec 18 20:33:11 Claimco emhttpd: APPLE_HDD_ST2000DM001_Z8E0AL3H (sdj) 512 3907029168 Dec 18 20:33:11 Claimco emhttpd: ST2000DM001-1CH164_Z1E4ZXL1 (sdk) 512 3907029168 Dec 18 20:33:11 Claimco emhttpd: ST2000DM001-1ER164_Z4Z7FTDQ (sdh) 512 3907029168 Dec 18 20:33:11 Claimco emhttpd: WDC_WD6400AAKS-22A7B2_WD-WMASY5990247 (sdg) 512 1250263728 Dec 18 20:33:11 Claimco emhttpd: ST8000DM004-2CX188_ZR10QKFN (sdd) 512 15628053168 Dec 18 20:33:11 Claimco emhttpd: ST32000542AS_5XW1JRXG (sde) 512 3907029168 Dec 18 20:33:11 Claimco emhttpd: ST32000644NS_9WM55H64 (sdb) 512 3907029168 Dec 18 20:33:11 Claimco emhttpd: ST4000DM004-2U9104_ZTT3YVPM (sdf) 512 7814037168 Dec 18 20:33:11 Claimco emhttpd: WDC_WD4005FZBX-00K5WB0_V3GDVTJG (sdc) 512 7814037168 Dec 18 20:33:11 Claimco emhttpd: INTEL_SSDPEKNU020TZ_BTKA204200RJ2P0C (nvme0n1) 512 4000797360 Dec 18 20:33:11 Claimco emhttpd: WDC_WD4005FZBX-00K5WB0_VBHN4KNF (sdi) 512 7814037168 Dec 18 20:33:11 Claimco emhttpd: Memorex_TRAVELDRIVE_005B_079117160100-0:0 (sda) 512 31277056 Dec 18 20:33:11 Claimco kernel: mdcmd (1): import 0 sdd 64 7814026532 0 ST8000DM004-2CX188_ZR10QKFN Dec 18 20:33:11 Claimco kernel: md: import disk0: (sdd) ST8000DM004-2CX188_ZR10QKFN size: 7814026532 Dec 18 20:33:11 Claimco kernel: mdcmd (2): import 1 sdk 64 1953514552 0 ST2000DM001-1CH164_Z1E4ZXL1 Dec 18 20:33:11 Claimco kernel: md: import disk1: (sdk) ST2000DM001-1CH164_Z1E4ZXL1 size: 1953514552 Dec 18 20:33:11 Claimco kernel: mdcmd (3): import 2 sdh 64 1953514552 0 ST2000DM001-1ER164_Z4Z7FTDQ Dec 18 20:33:11 Claimco kernel: md: import disk2: (sdh) ST2000DM001-1ER164_Z4Z7FTDQ size: 1953514552 Dec 18 20:33:11 Claimco kernel: mdcmd (4): import 3 sde 64 1953514552 0 ST32000542AS_5XW1JRXG Dec 18 20:33:11 Claimco kernel: md: import disk3: (sde) ST32000542AS_5XW1JRXG size: 1953514552 Dec 18 20:33:11 Claimco kernel: mdcmd (5): import 4 sdb 64 1953514552 0 ST32000644NS_9WM55H64 Dec 18 20:33:11 Claimco kernel: md: import disk4: (sdb) ST32000644NS_9WM55H64 size: 1953514552 Dec 18 20:33:11 Claimco kernel: mdcmd (6): import 5 sdj 64 1953514552 0 APPLE_HDD_ST2000DM001_Z8E0AL3H Dec 18 20:33:11 Claimco kernel: md: import disk5: (sdj) APPLE_HDD_ST2000DM001_Z8E0AL3H size: 1953514552 Dec 18 20:33:11 Claimco kernel: mdcmd (7): import 6 sdc 64 3907018532 0 WDC_WD4005FZBX-00K5WB0_V3GDVTJG Dec 18 20:33:11 Claimco kernel: md: import disk6: (sdc) WDC_WD4005FZBX-00K5WB0_V3GDVTJG size: 3907018532 Dec 18 20:33:11 Claimco kernel: mdcmd (8): import 7 sdf 64 3907018532 0 ST4000DM004-2U9104_ZTT3YVPM Dec 18 20:33:11 Claimco kernel: md: import disk7: (sdf) ST4000DM004-2U9104_ZTT3YVPM size: 3907018532 Dec 18 20:33:11 Claimco kernel: mdcmd (9): import 8 sdg 64 625131832 0 WDC_WD6400AAKS-22A7B2_WD-WMASY5990247 Dec 18 20:33:11 Claimco kernel: md: import disk8: (sdg) WDC_WD6400AAKS-22A7B2_WD-WMASY5990247 size: 625131832 Dec 18 20:33:11 Claimco kernel: mdcmd (10): import 9 sdi 64 3907018532 0 WDC_WD4005FZBX-00K5WB0_VBHN4KNF Dec 18 20:33:11 Claimco kernel: md: import disk9: (sdi) WDC_WD4005FZBX-00K5WB0_VBHN4KNF size: 3907018532 Dec 18 20:33:11 Claimco kernel: mdcmd (11): import 10 Dec 18 20:33:11 Claimco kernel: mdcmd (12): import 11 Dec 18 20:33:11 Claimco kernel: mdcmd (13): import 12 Dec 18 20:33:11 Claimco kernel: mdcmd (14): import 13 Dec 18 20:33:11 Claimco kernel: mdcmd (15): import 14 Dec 18 20:33:11 Claimco kernel: mdcmd (16): import 15 Dec 18 20:33:11 Claimco kernel: mdcmd (17): import 16 Dec 18 20:33:11 Claimco kernel: mdcmd (18): import 17 Dec 18 20:33:11 Claimco kernel: mdcmd (19): import 18 Dec 18 20:33:11 Claimco kernel: mdcmd (20): import 19 Dec 18 20:33:11 Claimco kernel: mdcmd (21): import 20 Dec 18 20:33:11 Claimco kernel: mdcmd (22): import 21 Dec 18 20:33:11 Claimco kernel: mdcmd (23): import 22 Dec 18 20:33:11 Claimco kernel: mdcmd (24): import 23 Dec 18 20:33:11 Claimco kernel: mdcmd (25): import 24 Dec 18 20:33:11 Claimco kernel: mdcmd (26): import 25 Dec 18 20:33:11 Claimco kernel: mdcmd (27): import 26 Dec 18 20:33:11 Claimco kernel: mdcmd (28): import 27 Dec 18 20:33:11 Claimco kernel: mdcmd (29): import 28 Dec 18 20:33:11 Claimco kernel: mdcmd (30): import 29 Dec 18 20:33:11 Claimco kernel: md: import_slot: 29 empty Dec 18 20:33:11 Claimco emhttpd: import 30 cache device: (nvme0n1) INTEL_SSDPEKNU020TZ_BTKA204200RJ2P0C Dec 18 20:33:11 Claimco emhttpd: import flash device: sda Dec 18 20:33:11 Claimco emhttpd: read SMART /dev/sdj Dec 18 20:33:11 Claimco emhttpd: read SMART /dev/sdk Dec 18 20:33:11 Claimco emhttpd: read SMART /dev/sdh Dec 18 20:33:11 Claimco emhttpd: read SMART /dev/sdg Dec 18 20:33:11 Claimco emhttpd: read SMART /dev/sdd Dec 18 20:33:11 Claimco emhttpd: read SMART /dev/sde Dec 18 20:33:11 Claimco emhttpd: read SMART /dev/sdb Dec 18 20:33:11 Claimco emhttpd: read SMART /dev/sdf Dec 18 20:33:11 Claimco emhttpd: read SMART /dev/sdc Dec 18 20:33:11 Claimco emhttpd: read SMART /dev/nvme0n1 Dec 18 20:33:11 Claimco emhttpd: read SMART /dev/sdi Dec 18 20:33:11 Claimco emhttpd: read SMART /dev/sda Dec 18 20:33:11 Claimco emhttpd: Starting services... Dec 18 20:33:11 Claimco emhttpd: shcmd (18): /etc/rc.d/rc.samba restart Dec 18 20:33:11 Claimco wsdd2[1205]: 'Terminated' signal received. Dec 18 20:33:11 Claimco winbindd[1208]: [2022/12/18 20:33:11.563277, 0] ../../source3/winbindd/winbindd_dual.c:1957(winbindd_sig_term_handler) Dec 18 20:33:11 Claimco winbindd[1208]: Got sig[15] terminate (is_parent=1) Dec 18 20:33:11 Claimco winbindd[1210]: [2022/12/18 20:33:11.563274, 0] ../../source3/winbindd/winbindd_dual.c:1957(winbindd_sig_term_handler) Dec 18 20:33:11 Claimco winbindd[1210]: Got sig[15] terminate (is_parent=0) Dec 18 20:33:11 Claimco wsdd2[1205]: terminating. Dec 18 20:33:11 Claimco winbindd[1653]: [2022/12/18 20:33:11.563297, 0] ../../source3/winbindd/winbindd_dual.c:1957(winbindd_sig_term_handler) Dec 18 20:33:11 Claimco winbindd[1653]: Got sig[15] terminate (is_parent=0) Dec 18 20:33:11 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 18 20:33:14 Claimco root: Starting Samba: /usr/sbin/smbd -D Dec 18 20:33:14 Claimco smbd[6526]: [2022/12/18 20:33:14.151351, 0] ../../source3/smbd/server.c:1741(main) Dec 18 20:33:14 Claimco smbd[6526]: smbd version 4.17.3 started. Dec 18 20:33:14 Claimco smbd[6526]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Dec 18 20:33:14 Claimco root: /usr/sbin/wsdd2 -d Dec 18 20:33:14 Claimco root: /usr/sbin/winbindd -D Dec 18 20:33:14 Claimco wsdd2[6540]: starting. Dec 18 20:33:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:14 Claimco winbindd[6541]: [2022/12/18 20:33:14.213848, 0] ../../source3/winbindd/winbindd.c:1440(main) Dec 18 20:33:14 Claimco winbindd[6541]: winbindd version 4.17.3 started. Dec 18 20:33:14 Claimco winbindd[6541]: Copyright Andrew Tridgell and the Samba Team 1992-2022 Dec 18 20:33:14 Claimco winbindd[6543]: [2022/12/18 20:33:14.216227, 0] ../../source3/winbindd/winbindd_cache.c:3116(initialize_winbindd_cache) Dec 18 20:33:14 Claimco winbindd[6543]: initialize_winbindd_cache: clearing cache and re-creating with version number 2 Dec 18 20:33:14 Claimco emhttpd: shcmd (22): /etc/rc.d/rc.avahidaemon start Dec 18 20:33:14 Claimco root: Starting Avahi mDNS/DNS-SD Daemon: /usr/sbin/avahi-daemon -D Dec 18 20:33:14 Claimco avahi-daemon[6560]: Found user 'avahi' (UID 61) and group 'avahi' (GID 214). Dec 18 20:33:14 Claimco avahi-daemon[6560]: Successfully dropped root privileges. Dec 18 20:33:14 Claimco avahi-daemon[6560]: avahi-daemon 0.8 starting up. Dec 18 20:33:14 Claimco avahi-daemon[6560]: Successfully called chroot(). Dec 18 20:33:14 Claimco avahi-daemon[6560]: Successfully dropped remaining capabilities. Dec 18 20:33:14 Claimco avahi-daemon[6560]: Loading service file /services/sftp-ssh.service. Dec 18 20:33:14 Claimco avahi-daemon[6560]: Loading service file /services/smb.service. Dec 18 20:33:14 Claimco avahi-daemon[6560]: Loading service file /services/ssh.service. Dec 18 20:33:14 Claimco avahi-daemon[6560]: Joining mDNS multicast group on interface br0.IPv4 with address 192.168.1.233. Dec 18 20:33:14 Claimco avahi-daemon[6560]: New relevant interface br0.IPv4 for mDNS. Dec 18 20:33:14 Claimco avahi-daemon[6560]: Joining mDNS multicast group on interface lo.IPv6 with address ::1. Dec 18 20:33:14 Claimco avahi-daemon[6560]: New relevant interface lo.IPv6 for mDNS. Dec 18 20:33:14 Claimco avahi-daemon[6560]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Dec 18 20:33:14 Claimco avahi-daemon[6560]: New relevant interface lo.IPv4 for mDNS. Dec 18 20:33:14 Claimco avahi-daemon[6560]: Network interface enumeration completed. Dec 18 20:33:14 Claimco avahi-daemon[6560]: Registering new address record for 192.168.1.233 on br0.IPv4. Dec 18 20:33:14 Claimco avahi-daemon[6560]: Registering new address record for ::1 on lo.*. Dec 18 20:33:14 Claimco avahi-daemon[6560]: Registering new address record for 127.0.0.1 on lo.IPv4. Dec 18 20:33:14 Claimco emhttpd: shcmd (23): /etc/rc.d/rc.avahidnsconfd start Dec 18 20:33:14 Claimco root: Starting Avahi mDNS/DNS-SD DNS Server Configuration Daemon: /usr/sbin/avahi-dnsconfd -D Dec 18 20:33:14 Claimco avahi-dnsconfd[6569]: Successfully connected to Avahi daemon. Dec 18 20:33:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 18 20:33:14 Claimco emhttpd: Autostart enabled Dec 18 20:33:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 18 20:33:15 Claimco avahi-daemon[6560]: Server startup complete. Host name is Claimco.local. Local service cookie is 1048842507. Dec 18 20:33:16 Claimco avahi-daemon[6560]: Service "Claimco" (/services/ssh.service) successfully established. Dec 18 20:33:16 Claimco avahi-daemon[6560]: Service "Claimco" (/services/smb.service) successfully established. Dec 18 20:33:16 Claimco avahi-daemon[6560]: Service "Claimco" (/services/sftp-ssh.service) successfully established. Dec 18 20:33:16 Claimco emhttpd: shcmd (28): /etc/rc.d/rc.php-fpm start Dec 18 20:33:16 Claimco root: Starting php-fpm done Dec 18 20:33:16 Claimco emhttpd: shcmd (29): /etc/rc.d/rc.unraid-api install Dec 18 20:33:16 Claimco root: unraid-api installed Dec 18 20:33:16 Claimco emhttpd: shcmd (30): /etc/rc.d/rc.nginx start Dec 18 20:33:17 Claimco kernel: net_ratelimit: 8 callbacks suppressed Dec 18 20:33:17 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 18 20:33:17 Claimco root: Starting Nginx server daemon... Dec 18 20:33:18 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 18 20:33:19 Claimco root: Starting [email protected] Dec 18 20:33:19 Claimco emhttpd: shcmd (31): /etc/rc.d/rc.flash_backup start Dec 18 20:33:20 Claimco flash_backup: flush: /usr/local/emhttp/plugins/dynamix.my.servers/scripts/UpdateFlashBackup update Dec 18 20:33:20 Claimco flash_backup: start watching for file changes Dec 18 20:33:20 Claimco unraid-api[6848]: ✔️ UNRAID API started successfully! Dec 18 20:33:21 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 18 20:33:22 Claimco emhttpd: shcmd (33): echo 128 > /sys/block/sdd/queue/nr_requests Dec 18 20:33:22 Claimco kernel: mdcmd (31): set md_num_stripes 4096 Dec 18 20:33:22 Claimco kernel: mdcmd (32): set md_queue_limit 80 Dec 18 20:33:22 Claimco kernel: mdcmd (33): set md_sync_limit 32 Dec 18 20:33:22 Claimco kernel: mdcmd (34): set md_write_method 1 Dec 18 20:33:22 Claimco emhttpd: shcmd (34): echo 128 > /sys/block/sdk/queue/nr_requests Dec 18 20:33:22 Claimco emhttpd: shcmd (35): echo 128 > /sys/block/sdh/queue/nr_requests Dec 18 20:33:22 Claimco emhttpd: shcmd (36): echo 128 > /sys/block/sde/queue/nr_requests Dec 18 20:33:22 Claimco emhttpd: shcmd (37): echo 128 > /sys/block/sdb/queue/nr_requests Dec 18 20:33:22 Claimco emhttpd: shcmd (38): echo 128 > /sys/block/sdj/queue/nr_requests Dec 18 20:33:22 Claimco emhttpd: shcmd (39): echo 128 > /sys/block/sdc/queue/nr_requests Dec 18 20:33:22 Claimco emhttpd: shcmd (40): echo 128 > /sys/block/sdf/queue/nr_requests Dec 18 20:33:22 Claimco emhttpd: shcmd (41): echo 128 > /sys/block/sdg/queue/nr_requests Dec 18 20:33:22 Claimco emhttpd: shcmd (42): echo 128 > /sys/block/sdi/queue/nr_requests Dec 18 20:33:22 Claimco kernel: mdcmd (35): start STOPPED Dec 18 20:33:22 Claimco kernel: unraid: allocating 181472K for 4096 stripes (11 disks) Dec 18 20:33:22 Claimco kernel: md1: running, size: 1953514552 blocks Dec 18 20:33:22 Claimco kernel: md2: running, size: 1953514552 blocks Dec 18 20:33:22 Claimco kernel: md3: running, size: 1953514552 blocks Dec 18 20:33:22 Claimco kernel: md4: running, size: 1953514552 blocks Dec 18 20:33:22 Claimco kernel: md5: running, size: 1953514552 blocks Dec 18 20:33:22 Claimco kernel: md6: running, size: 3907018532 blocks Dec 18 20:33:22 Claimco kernel: md7: running, size: 3907018532 blocks Dec 18 20:33:22 Claimco kernel: md8: running, size: 625131832 blocks Dec 18 20:33:22 Claimco kernel: md9: running, size: 3907018532 blocks Dec 18 20:33:22 Claimco emhttpd: shcmd (43): udevadm settle Dec 18 20:33:23 Claimco emhttpd: Opening encrypted volumes... Dec 18 20:33:23 Claimco emhttpd: shcmd (44): touch /boot/config/forcesync Dec 18 20:33:23 Claimco emhttpd: Mounting disks... Dec 18 20:33:24 Claimco emhttpd: shcmd (46): mkdir -p /mnt/disk1 Dec 18 20:33:24 Claimco emhttpd: shcmd (47): mount -t xfs -o noatime,nouuid /dev/md1 /mnt/disk1 Dec 18 20:33:24 Claimco kernel: SGI XFS with ACLs, security attributes, no debug enabled Dec 18 20:33:24 Claimco kernel: XFS (md1): Mounting V5 Filesystem Dec 18 20:33:24 Claimco kernel: XFS (md1): Ending clean mount Dec 18 20:33:24 Claimco emhttpd: shcmd (48): xfs_growfs /mnt/disk1 Dec 18 20:33:24 Claimco root: meta-data=/dev/md1 isize=512 agcount=4, agsize=122094660 blks Dec 18 20:33:24 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 18 20:33:24 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 18 20:33:24 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 18 20:33:24 Claimco root: data = bsize=4096 blocks=488378638, imaxpct=5 Dec 18 20:33:24 Claimco root: = sunit=0 swidth=0 blks Dec 18 20:33:24 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 18 20:33:24 Claimco root: log =internal log bsize=4096 blocks=238466, version=2 Dec 18 20:33:24 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 18 20:33:24 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 18 20:33:24 Claimco emhttpd: shcmd (49): mkdir -p /mnt/disk2 Dec 18 20:33:24 Claimco emhttpd: shcmd (50): mount -t xfs -o noatime,nouuid /dev/md2 /mnt/disk2 Dec 18 20:33:24 Claimco kernel: XFS (md2): Mounting V5 Filesystem Dec 18 20:33:25 Claimco kernel: XFS (md2): Ending clean mount Dec 18 20:33:25 Claimco emhttpd: shcmd (51): xfs_growfs /mnt/disk2 Dec 18 20:33:25 Claimco root: meta-data=/dev/md2 isize=512 agcount=4, agsize=122094660 blks Dec 18 20:33:25 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 18 20:33:25 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 18 20:33:25 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 18 20:33:25 Claimco root: data = bsize=4096 blocks=488378638, imaxpct=5 Dec 18 20:33:25 Claimco root: = sunit=0 swidth=0 blks Dec 18 20:33:25 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 18 20:33:25 Claimco root: log =internal log bsize=4096 blocks=238466, version=2 Dec 18 20:33:25 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 18 20:33:25 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 18 20:33:25 Claimco emhttpd: shcmd (52): mkdir -p /mnt/disk3 Dec 18 20:33:25 Claimco emhttpd: shcmd (53): mount -t xfs -o noatime,nouuid /dev/md3 /mnt/disk3 Dec 18 20:33:25 Claimco kernel: XFS (md3): Mounting V5 Filesystem Dec 18 20:33:25 Claimco kernel: XFS (md3): Ending clean mount Dec 18 20:33:25 Claimco emhttpd: shcmd (54): xfs_growfs /mnt/disk3 Dec 18 20:33:25 Claimco root: meta-data=/dev/md3 isize=512 agcount=4, agsize=122094660 blks Dec 18 20:33:25 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 18 20:33:25 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 18 20:33:25 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 18 20:33:25 Claimco root: data = bsize=4096 blocks=488378638, imaxpct=5 Dec 18 20:33:25 Claimco root: = sunit=0 swidth=0 blks Dec 18 20:33:25 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 18 20:33:25 Claimco root: log =internal log bsize=4096 blocks=238466, version=2 Dec 18 20:33:25 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 18 20:33:25 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 18 20:33:25 Claimco emhttpd: shcmd (55): mkdir -p /mnt/disk4 Dec 18 20:33:25 Claimco emhttpd: shcmd (56): mount -t xfs -o noatime,nouuid /dev/md4 /mnt/disk4 Dec 18 20:33:25 Claimco kernel: XFS (md4): Mounting V5 Filesystem Dec 18 20:33:25 Claimco kernel: XFS (md4): Ending clean mount Dec 18 20:33:25 Claimco emhttpd: shcmd (57): xfs_growfs /mnt/disk4 Dec 18 20:33:25 Claimco root: meta-data=/dev/md4 isize=512 agcount=4, agsize=122094660 blks Dec 18 20:33:25 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 18 20:33:25 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 18 20:33:25 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 18 20:33:25 Claimco root: data = bsize=4096 blocks=488378638, imaxpct=5 Dec 18 20:33:25 Claimco root: = sunit=0 swidth=0 blks Dec 18 20:33:25 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 18 20:33:25 Claimco root: log =internal log bsize=4096 blocks=238466, version=2 Dec 18 20:33:25 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 18 20:33:25 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 18 20:33:25 Claimco emhttpd: shcmd (58): mkdir -p /mnt/disk5 Dec 18 20:33:25 Claimco emhttpd: shcmd (59): mount -t xfs -o noatime,nouuid /dev/md5 /mnt/disk5 Dec 18 20:33:25 Claimco kernel: XFS (md5): Mounting V5 Filesystem Dec 18 20:33:25 Claimco kernel: XFS (md5): Ending clean mount Dec 18 20:33:25 Claimco emhttpd: shcmd (60): xfs_growfs /mnt/disk5 Dec 18 20:33:25 Claimco root: meta-data=/dev/md5 isize=512 agcount=8, agsize=61047660 blks Dec 18 20:33:25 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 18 20:33:25 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 18 20:33:25 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 18 20:33:25 Claimco root: data = bsize=4096 blocks=488378638, imaxpct=25 Dec 18 20:33:25 Claimco root: = sunit=0 swidth=0 blks Dec 18 20:33:25 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 18 20:33:25 Claimco root: log =internal log bsize=4096 blocks=119233, version=2 Dec 18 20:33:25 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 18 20:33:25 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 18 20:33:25 Claimco emhttpd: shcmd (61): mkdir -p /mnt/disk6 Dec 18 20:33:25 Claimco emhttpd: shcmd (62): mount -t xfs -o noatime,nouuid /dev/md6 /mnt/disk6 Dec 18 20:33:25 Claimco kernel: XFS (md6): Mounting V5 Filesystem Dec 18 20:33:25 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 18 20:33:25 Claimco kernel: XFS (md6): Ending clean mount Dec 18 20:33:25 Claimco emhttpd: shcmd (63): xfs_growfs /mnt/disk6 Dec 18 20:33:25 Claimco root: meta-data=/dev/md6 isize=512 agcount=4, agsize=244188659 blks Dec 18 20:33:25 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 18 20:33:25 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 18 20:33:25 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 18 20:33:25 Claimco root: data = bsize=4096 blocks=976754633, imaxpct=5 Dec 18 20:33:25 Claimco root: = sunit=0 swidth=0 blks Dec 18 20:33:25 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 18 20:33:25 Claimco root: log =internal log bsize=4096 blocks=476930, version=2 Dec 18 20:33:25 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 18 20:33:25 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 18 20:33:25 Claimco emhttpd: shcmd (64): mkdir -p /mnt/disk7 Dec 18 20:33:25 Claimco emhttpd: shcmd (65): mount -t xfs -o noatime,nouuid /dev/md7 /mnt/disk7 Dec 18 20:33:25 Claimco kernel: XFS (md7): Mounting V5 Filesystem Dec 18 20:33:26 Claimco kernel: XFS (md7): Ending clean mount Dec 18 20:33:26 Claimco emhttpd: shcmd (66): xfs_growfs /mnt/disk7 Dec 18 20:33:26 Claimco root: meta-data=/dev/md7 isize=512 agcount=4, agsize=244188659 blks Dec 18 20:33:26 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 18 20:33:26 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 18 20:33:26 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 18 20:33:26 Claimco root: data = bsize=4096 blocks=976754633, imaxpct=5 Dec 18 20:33:26 Claimco root: = sunit=0 swidth=0 blks Dec 18 20:33:26 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 18 20:33:26 Claimco root: log =internal log bsize=4096 blocks=476930, version=2 Dec 18 20:33:26 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 18 20:33:26 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 18 20:33:26 Claimco emhttpd: shcmd (67): mkdir -p /mnt/disk8 Dec 18 20:33:26 Claimco emhttpd: shcmd (68): mount -t xfs -o noatime,nouuid /dev/md8 /mnt/disk8 Dec 18 20:33:26 Claimco kernel: XFS (md8): Mounting V5 Filesystem Dec 18 20:33:26 Claimco emhttpd: shcmd (69): xfs_growfs /mnt/disk8 Dec 18 20:33:26 Claimco kernel: XFS (md8): Ending clean mount Dec 18 20:33:26 Claimco root: meta-data=/dev/md8 isize=512 agcount=4, agsize=39070740 blks Dec 18 20:33:26 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 18 20:33:26 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 18 20:33:26 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 18 20:33:26 Claimco root: data = bsize=4096 blocks=156282958, imaxpct=25 Dec 18 20:33:26 Claimco root: = sunit=0 swidth=0 blks Dec 18 20:33:26 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 18 20:33:26 Claimco root: log =internal log bsize=4096 blocks=76310, version=2 Dec 18 20:33:26 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 18 20:33:26 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 18 20:33:26 Claimco emhttpd: shcmd (70): mkdir -p /mnt/disk9 Dec 18 20:33:26 Claimco emhttpd: shcmd (71): mount -t xfs -o noatime,nouuid /dev/md9 /mnt/disk9 Dec 18 20:33:26 Claimco kernel: XFS (md9): Mounting V5 Filesystem Dec 18 20:33:26 Claimco kernel: XFS (md9): Ending clean mount Dec 18 20:33:26 Claimco emhttpd: shcmd (72): xfs_growfs /mnt/disk9 Dec 18 20:33:26 Claimco root: meta-data=/dev/md9 isize=512 agcount=4, agsize=244188659 blks Dec 18 20:33:26 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 18 20:33:26 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 18 20:33:26 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 18 20:33:26 Claimco root: data = bsize=4096 blocks=976754633, imaxpct=5 Dec 18 20:33:26 Claimco root: = sunit=0 swidth=0 blks Dec 18 20:33:26 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 18 20:33:26 Claimco root: log =internal log bsize=4096 blocks=476930, version=2 Dec 18 20:33:26 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 18 20:33:26 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 18 20:33:26 Claimco emhttpd: shcmd (73): mkdir -p /mnt/cache Dec 18 20:33:26 Claimco emhttpd: shcmd (74): mount -t btrfs -o noatime,space_cache=v2 /dev/nvme0n1p1 /mnt/cache Dec 18 20:33:26 Claimco kernel: BTRFS info (device nvme0n1p1): using free space tree Dec 18 20:33:26 Claimco kernel: BTRFS info (device nvme0n1p1): has skinny extents Dec 18 20:33:26 Claimco kernel: BTRFS info (device nvme0n1p1): enabling ssd optimizations Dec 18 20:33:27 Claimco emhttpd: shcmd (75): sync Dec 18 20:33:27 Claimco emhttpd: shcmd (76): mkdir /mnt/user0 Dec 18 20:33:27 Claimco emhttpd: shcmd (77): /usr/local/sbin/shfs /mnt/user0 -disks 1022 -o default_permissions,allow_other,noatime |& logger Dec 18 20:33:27 Claimco emhttpd: shcmd (78): mkdir /mnt/user Dec 18 20:33:27 Claimco emhttpd: shcmd (79): /usr/local/sbin/shfs /mnt/user -disks 1023 -o default_permissions,allow_other,noatime -o remember=0 |& logger Dec 18 20:33:27 Claimco emhttpd: shcmd (81): /usr/local/sbin/update_cron Dec 18 20:33:28 Claimco ProFTPd: Running mountscript.sh... Dec 18 20:33:28 Claimco emhttpd: ProFTPd already running. Dec 18 20:33:29 Claimco root: Starting CA Auto Turbo Mode Dec 18 20:33:29 Claimco root: Delaying execution of fix common problems scan for 10 minutes Dec 18 20:33:29 Claimco Recycle Bin: Starting Recycle Bin Dec 18 20:33:29 Claimco emhttpd: Starting Recycle Bin... Dec 18 20:33:29 Claimco kernel: mdcmd (36): set md_write_method 1 Dec 18 20:33:29 Claimco kernel: Dec 18 20:33:29 Claimco wsdd2[6540]: 'Terminated' signal received. Dec 18 20:33:29 Claimco winbindd[6543]: [2022/12/18 20:33:29.272125, 0] ../../source3/winbindd/winbindd_dual.c:1957(winbindd_sig_term_handler) Dec 18 20:33:29 Claimco winbindd[6545]: [2022/12/18 20:33:29.272118, 0] ../../source3/winbindd/winbindd_dual.c:1957(winbindd_sig_term_handler) Dec 18 20:33:29 Claimco winbindd[6543]: Got sig[15] terminate (is_parent=1) Dec 18 20:33:29 Claimco winbindd[6545]: Got sig[15] terminate (is_parent=0) Dec 18 20:33:29 Claimco wsdd2[6540]: terminating. Dec 18 20:33:29 Claimco winbindd[6650]: [2022/12/18 20:33:29.272174, 0] ../../source3/winbindd/winbindd_dual.c:1957(winbindd_sig_term_handler) Dec 18 20:33:29 Claimco winbindd[6650]: Got sig[15] terminate (is_parent=0) Dec 18 20:33:29 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 18 20:33:31 Claimco wsdd2[7732]: starting. Dec 18 20:33:31 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:32 Claimco unassigned.devices: Mounting 'Auto Mount' Devices... Dec 18 20:33:32 Claimco emhttpd: Starting services... Dec 18 20:33:32 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 18 20:33:32 Claimco emhttpd: shcmd (83): /etc/rc.d/rc.samba restart Dec 18 20:33:32 Claimco wsdd2[7732]: 'Terminated' signal received. Dec 18 20:33:32 Claimco wsdd2[7732]: terminating. Dec 18 20:33:32 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 18 20:33:34 Claimco root: Starting Samba: /usr/sbin/smbd -D Dec 18 20:33:34 Claimco root: /usr/sbin/wsdd2 -d Dec 18 20:33:34 Claimco root: /usr/sbin/winbindd -D Dec 18 20:33:34 Claimco wsdd2[7837]: starting. Dec 18 20:33:34 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:34 Claimco emhttpd: shcmd (87): /etc/rc.d/rc.avahidaemon restart Dec 18 20:33:34 Claimco root: Stopping Avahi mDNS/DNS-SD Daemon: stopped Dec 18 20:33:34 Claimco avahi-daemon[6560]: Got SIGTERM, quitting. Dec 18 20:33:34 Claimco avahi-dnsconfd[6569]: read(): EOF Dec 18 20:33:34 Claimco avahi-daemon[6560]: Leaving mDNS multicast group on interface br0.IPv4 with address 192.168.1.233. Dec 18 20:33:34 Claimco avahi-daemon[6560]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1. Dec 18 20:33:34 Claimco avahi-daemon[6560]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Dec 18 20:33:34 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 20:33:34 Claimco avahi-daemon[6560]: avahi-daemon 0.8 exiting. Dec 18 20:33:34 Claimco root: Starting Avahi mDNS/DNS-SD Daemon: /usr/sbin/avahi-daemon -D Dec 18 20:33:34 Claimco avahi-daemon[7857]: Found user 'avahi' (UID 61) and group 'avahi' (GID 214). Dec 18 20:33:34 Claimco avahi-daemon[7857]: Successfully dropped root privileges. Dec 18 20:33:34 Claimco avahi-daemon[7857]: avahi-daemon 0.8 starting up. Dec 18 20:33:34 Claimco avahi-daemon[7857]: Successfully called chroot(). Dec 18 20:33:34 Claimco avahi-daemon[7857]: Successfully dropped remaining capabilities. Dec 18 20:33:34 Claimco avahi-daemon[7857]: Loading service file /services/sftp-ssh.service. Dec 18 20:33:34 Claimco avahi-daemon[7857]: Loading service file /services/smb.service. Dec 18 20:33:34 Claimco avahi-daemon[7857]: Loading service file /services/ssh.service. Dec 18 20:33:34 Claimco avahi-daemon[7857]: Joining mDNS multicast group on interface br0.IPv4 with address 192.168.1.233. Dec 18 20:33:34 Claimco avahi-daemon[7857]: New relevant interface br0.IPv4 for mDNS. Dec 18 20:33:34 Claimco avahi-daemon[7857]: Joining mDNS multicast group on interface lo.IPv6 with address ::1. Dec 18 20:33:34 Claimco avahi-daemon[7857]: New relevant interface lo.IPv6 for mDNS. Dec 18 20:33:34 Claimco avahi-daemon[7857]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Dec 18 20:33:34 Claimco avahi-daemon[7857]: New relevant interface lo.IPv4 for mDNS. Dec 18 20:33:34 Claimco avahi-daemon[7857]: Network interface enumeration completed. Dec 18 20:33:34 Claimco avahi-daemon[7857]: Registering new address record for 192.168.1.233 on br0.IPv4. Dec 18 20:33:34 Claimco avahi-daemon[7857]: Registering new address record for ::1 on lo.*. Dec 18 20:33:34 Claimco avahi-daemon[7857]: Registering new address record for 127.0.0.1 on lo.IPv4. Dec 18 20:33:34 Claimco emhttpd: shcmd (88): /etc/rc.d/rc.avahidnsconfd restart Dec 18 20:33:34 Claimco root: Stopping Avahi mDNS/DNS-SD DNS Server Configuration Daemon: stopped Dec 18 20:33:34 Claimco root: Starting Avahi mDNS/DNS-SD DNS Server Configuration Daemon: /usr/sbin/avahi-dnsconfd -D Dec 18 20:33:34 Claimco avahi-dnsconfd[7866]: Successfully connected to Avahi daemon. Dec 18 20:33:34 Claimco emhttpd: shcmd (103): /usr/local/sbin/mount_image '/mnt/user/system/libvirt/libvirt.img' /etc/libvirt 1 Dec 18 20:33:34 Claimco kernel: loop2: detected capacity change from 0 to 2097152 Dec 18 20:33:34 Claimco kernel: BTRFS: device fsid 0ea8134e-f967-4769-951f-02285f840935 devid 1 transid 31 /dev/loop2 scanned by mount (7904) Dec 18 20:33:34 Claimco kernel: BTRFS info (device loop2): using free space tree Dec 18 20:33:34 Claimco kernel: BTRFS info (device loop2): has skinny extents Dec 18 20:33:34 Claimco root: Resize device id 1 (/dev/loop2) from 1.00GiB to max Dec 18 20:33:34 Claimco emhttpd: shcmd (105): /etc/rc.d/rc.libvirt start Dec 18 20:33:34 Claimco root: Starting virtlockd... Dec 18 20:33:34 Claimco root: Starting virtlogd... Dec 18 20:33:34 Claimco root: Starting libvirtd... Dec 18 20:33:34 Claimco kernel: tun: Universal TUN/TAP device driver, 1.6 Dec 18 20:33:34 Claimco emhttpd: nothing to sync Dec 18 20:33:34 Claimco unassigned.devices: Mounting 'Auto Mount' Remote Shares... Dec 18 20:33:35 Claimco avahi-daemon[7857]: Joining mDNS multicast group on interface virbr0.IPv4 with address 192.168.122.1. Dec 18 20:33:35 Claimco avahi-daemon[7857]: New relevant interface virbr0.IPv4 for mDNS. Dec 18 20:33:35 Claimco avahi-daemon[7857]: Registering new address record for 192.168.122.1 on virbr0.IPv4. Dec 18 20:33:35 Claimco dnsmasq[8062]: started, version 2.87 cachesize 150 Dec 18 20:33:35 Claimco dnsmasq[8062]: compile time options: IPv6 GNU-getopt DBus no-UBus i18n IDN2 DHCP DHCPv6 no-Lua TFTP conntrack ipset no-nftset auth cryptohash DNSSEC loop-detect inotify dumpfile Dec 18 20:33:35 Claimco dnsmasq-dhcp[8062]: DHCP, IP range 192.168.122.2 -- 192.168.122.254, lease time 1h Dec 18 20:33:35 Claimco dnsmasq-dhcp[8062]: DHCP, sockets bound exclusively to interface virbr0 Dec 18 20:33:35 Claimco dnsmasq[8062]: reading /etc/resolv.conf Dec 18 20:33:35 Claimco dnsmasq[8062]: using nameserver 192.168.1.254#53 Dec 18 20:33:35 Claimco dnsmasq[8062]: read /etc/hosts - 2 addresses Dec 18 20:33:35 Claimco dnsmasq[8062]: read /var/lib/libvirt/dnsmasq/default.addnhosts - 0 addresses Dec 18 20:33:35 Claimco dnsmasq-dhcp[8062]: read /var/lib/libvirt/dnsmasq/default.hostsfile Dec 18 20:33:35 Claimco kernel: r8169 0000:04:00.0: invalid VPD tag 0x00 (size 0) at offset 0; assume missing optional EEPROM Dec 18 20:33:36 Claimco avahi-daemon[7857]: Server startup complete. Host name is Claimco.local. Local service cookie is 1330551079. Dec 18 20:33:36 Claimco kernel: net_ratelimit: 13 callbacks suppressed Dec 18 20:33:36 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 18 20:33:37 Claimco avahi-daemon[7857]: Service "Claimco" (/services/ssh.service) successfully established. Dec 18 20:33:37 Claimco avahi-daemon[7857]: Service "Claimco" (/services/smb.service) successfully established. Dec 18 20:33:37 Claimco avahi-daemon[7857]: Service "Claimco" (/services/sftp-ssh.service) successfully established. Dec 18 20:33:37 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 19 TIMES] ### Dec 18 20:38:27 Claimco ntpd[1158]: kernel reports TIME_ERROR: 0x41: Clock Unsynchronized Dec 18 20:39:47 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 18 20:43:00 Claimco root: Fix Common Problems Version 2022.12.18 Dec 18 20:43:05 Claimco root: Fix Common Problems: Other Warning: Mover logging is enabled Dec 18 20:43:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 8 TIMES] ### Dec 18 20:59:30 Claimco sshd[14769]: Connection from 61.177.173.43 port 38380 on 192.168.1.233 port 22 rdomain "" Dec 18 20:59:30 Claimco sshd[14769]: Unable to negotiate with 61.177.173.43 port 38380: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 18 21:00:36 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 7 TIMES] ### Dec 18 21:09:30 Claimco sshd[17247]: Connection from 172.104.11.4 port 24972 on 192.168.1.233 port 22 rdomain "" Dec 18 21:09:30 Claimco sshd[17247]: Connection closed by 172.104.11.4 port 24972 [preauth] Dec 18 21:09:30 Claimco sshd[17249]: Connection from 172.104.11.4 port 24988 on 192.168.1.233 port 22 rdomain "" Dec 18 21:09:30 Claimco sshd[17249]: Connection closed by 172.104.11.4 port 24988 [preauth] Dec 18 21:09:30 Claimco sshd[17251]: Connection from 172.104.11.4 port 25004 on 192.168.1.233 port 22 rdomain "" Dec 18 21:09:31 Claimco sshd[17251]: Connection closed by 172.104.11.4 port 25004 [preauth] Dec 18 21:10:56 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 11 TIMES] ### Dec 18 21:27:58 Claimco sshd[21772]: Connection from 61.177.173.55 port 10382 on 192.168.1.233 port 22 rdomain "" Dec 18 21:27:58 Claimco sshd[21772]: Unable to negotiate with 61.177.173.55 port 10382: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 18 21:29:41 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 12 TIMES] ### Dec 18 21:47:35 Claimco sshd[26643]: Connection from 92.46.108.20 port 50544 on 192.168.1.233 port 22 rdomain "" Dec 18 21:47:36 Claimco sshd[26643]: Invalid user lzw from 92.46.108.20 port 50544 Dec 18 21:47:36 Claimco sshd[26643]: pam_unix(sshd:auth): check pass; user unknown Dec 18 21:47:36 Claimco sshd[26643]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=92.46.108.20 Dec 18 21:47:38 Claimco sshd[26643]: Failed password for invalid user lzw from 92.46.108.20 port 50544 ssh2 Dec 18 21:47:39 Claimco sshd[26643]: Connection closed by invalid user lzw 92.46.108.20 port 50544 [preauth] Dec 18 21:48:24 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 18 21:56:46 Claimco sshd[28935]: Connection from 61.177.172.61 port 59782 on 192.168.1.233 port 22 rdomain "" Dec 18 21:56:48 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 18 21:57:06 Claimco sshd[29035]: Connection from 84.110.99.202 port 57302 on 192.168.1.233 port 22 rdomain "" Dec 18 21:57:07 Claimco sshd[29035]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=84.110.99.202 user=root Dec 18 21:57:10 Claimco sshd[29035]: Failed password for root from 84.110.99.202 port 57302 ssh2 Dec 18 21:57:12 Claimco sshd[29035]: Connection closed by authenticating user root 84.110.99.202 port 57302 [preauth] Dec 18 21:58:46 Claimco sshd[28935]: fatal: Timeout before authentication for 61.177.172.61 port 59782 Dec 18 21:58:52 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 22:01:05 Claimco sshd[29962]: Connection from 141.98.11.30 port 42766 on 192.168.1.233 port 22 rdomain "" Dec 18 22:01:05 Claimco sshd[29962]: error: kex_exchange_identification: Connection closed by remote host Dec 18 22:01:05 Claimco sshd[29962]: Connection closed by 141.98.11.30 port 42766 Dec 18 22:01:23 Claimco sshd[30004]: Connection from 141.98.11.30 port 53576 on 192.168.1.233 port 22 rdomain "" Dec 18 22:01:23 Claimco sshd[30004]: Unable to negotiate with 141.98.11.30 port 53576: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:01:31 Claimco sshd[30047]: Connection from 141.98.11.30 port 60418 on 192.168.1.233 port 22 rdomain "" Dec 18 22:01:31 Claimco sshd[30047]: Unable to negotiate with 141.98.11.30 port 60418: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:01:39 Claimco sshd[30065]: Connection from 141.98.11.30 port 39008 on 192.168.1.233 port 22 rdomain "" Dec 18 22:01:39 Claimco sshd[30065]: Unable to negotiate with 141.98.11.30 port 39008: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:01:48 Claimco sshd[30085]: Connection from 141.98.11.30 port 45836 on 192.168.1.233 port 22 rdomain "" Dec 18 22:01:48 Claimco sshd[30085]: Unable to negotiate with 141.98.11.30 port 45836: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:01:57 Claimco sshd[30106]: Connection from 141.98.11.30 port 52662 on 192.168.1.233 port 22 rdomain "" Dec 18 22:01:57 Claimco sshd[30106]: Unable to negotiate with 141.98.11.30 port 52662: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:02:06 Claimco sshd[30184]: Connection from 141.98.11.30 port 59486 on 192.168.1.233 port 22 rdomain "" Dec 18 22:02:06 Claimco sshd[30184]: Unable to negotiate with 141.98.11.30 port 59486: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:02:15 Claimco sshd[30204]: Connection from 141.98.11.30 port 38080 on 192.168.1.233 port 22 rdomain "" Dec 18 22:02:15 Claimco sshd[30204]: Unable to negotiate with 141.98.11.30 port 38080: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:02:23 Claimco sshd[30229]: Connection from 65.2.28.105 port 43500 on 192.168.1.233 port 22 rdomain "" Dec 18 22:02:24 Claimco sshd[30229]: Invalid user oracle from 65.2.28.105 port 43500 Dec 18 22:02:24 Claimco sshd[30248]: Connection from 141.98.11.30 port 44904 on 192.168.1.233 port 22 rdomain "" Dec 18 22:02:24 Claimco sshd[30248]: Unable to negotiate with 141.98.11.30 port 44904: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:02:24 Claimco sshd[30229]: pam_unix(sshd:auth): check pass; user unknown Dec 18 22:02:24 Claimco sshd[30229]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=65.2.28.105 Dec 18 22:02:26 Claimco sshd[30229]: Failed password for invalid user oracle from 65.2.28.105 port 43500 ssh2 Dec 18 22:02:27 Claimco sshd[30229]: Connection closed by invalid user oracle 65.2.28.105 port 43500 [preauth] Dec 18 22:02:33 Claimco sshd[30292]: Connection from 141.98.11.30 port 51724 on 192.168.1.233 port 22 rdomain "" Dec 18 22:02:33 Claimco sshd[30292]: Unable to negotiate with 141.98.11.30 port 51724: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:02:59 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 8 TIMES] ### Dec 18 22:16:37 Claimco sshd[1463]: Connection from 116.255.227.98 port 54212 on 192.168.1.233 port 22 rdomain "" Dec 18 22:17:36 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 18 22:18:37 Claimco sshd[1463]: fatal: Timeout before authentication for 116.255.227.98 port 54212 Dec 18 22:19:43 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 18 22:24:37 Claimco sshd[3453]: Connection from 61.177.173.55 port 33712 on 192.168.1.233 port 22 rdomain "" Dec 18 22:24:38 Claimco sshd[3453]: Unable to negotiate with 61.177.173.55 port 33712: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 18 22:25:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 13 TIMES] ### Dec 18 22:48:00 Claimco sshd[9339]: Connection from 34.70.203.215 port 48310 on 192.168.1.233 port 22 rdomain "" Dec 18 22:48:13 Claimco sshd[9339]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=34.70.203.215 user=root Dec 18 22:48:15 Claimco sshd[9339]: Failed password for root from 34.70.203.215 port 48310 ssh2 Dec 18 22:48:17 Claimco sshd[9339]: Connection closed by authenticating user root 34.70.203.215 port 48310 [preauth] Dec 18 22:48:50 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 18 22:49:07 Claimco sshd[9645]: Connection from 141.98.11.30 port 44640 on 192.168.1.233 port 22 rdomain "" Dec 18 22:49:08 Claimco sshd[9645]: error: kex_exchange_identification: Connection closed by remote host Dec 18 22:49:08 Claimco sshd[9645]: Connection closed by 141.98.11.30 port 44640 Dec 18 22:49:27 Claimco sshd[9716]: Connection from 141.98.11.30 port 40358 on 192.168.1.233 port 22 rdomain "" Dec 18 22:49:27 Claimco sshd[9716]: Unable to negotiate with 141.98.11.30 port 40358: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:49:35 Claimco sshd[9732]: Connection from 141.98.11.30 port 46330 on 192.168.1.233 port 22 rdomain "" Dec 18 22:49:35 Claimco sshd[9732]: Unable to negotiate with 141.98.11.30 port 46330: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:49:43 Claimco sshd[9750]: Connection from 141.98.11.30 port 52300 on 192.168.1.233 port 22 rdomain "" Dec 18 22:49:43 Claimco sshd[9750]: Unable to negotiate with 141.98.11.30 port 52300: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:49:51 Claimco sshd[9771]: Connection from 141.98.11.30 port 58268 on 192.168.1.233 port 22 rdomain "" Dec 18 22:49:51 Claimco sshd[9771]: Unable to negotiate with 141.98.11.30 port 58268: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:49:59 Claimco sshd[9813]: Connection from 141.98.11.30 port 36006 on 192.168.1.233 port 22 rdomain "" Dec 18 22:50:00 Claimco sshd[9813]: Unable to negotiate with 141.98.11.30 port 36006: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:50:08 Claimco sshd[9914]: Connection from 141.98.11.30 port 41968 on 192.168.1.233 port 22 rdomain "" Dec 18 22:50:08 Claimco sshd[9914]: Unable to negotiate with 141.98.11.30 port 41968: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:50:17 Claimco sshd[9932]: Connection from 141.98.11.30 port 47940 on 192.168.1.233 port 22 rdomain "" Dec 18 22:50:17 Claimco sshd[9932]: Unable to negotiate with 141.98.11.30 port 47940: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:50:25 Claimco sshd[9983]: Connection from 141.98.11.30 port 53912 on 192.168.1.233 port 22 rdomain "" Dec 18 22:50:26 Claimco sshd[9983]: Unable to negotiate with 141.98.11.30 port 53912: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:50:34 Claimco sshd[10002]: Connection from 141.98.11.30 port 59882 on 192.168.1.233 port 22 rdomain "" Dec 18 22:50:34 Claimco sshd[10002]: Unable to negotiate with 141.98.11.30 port 59882: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 18 22:51:02 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 18 22:53:34 Claimco sshd[10678]: Connection from 61.177.173.56 port 17324 on 192.168.1.233 port 22 rdomain "" Dec 18 22:53:34 Claimco sshd[10678]: Unable to negotiate with 61.177.173.56 port 17324: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 18 22:55:05 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 14 TIMES] ### Dec 18 23:22:01 Claimco sshd[17718]: Connection from 61.177.172.76 port 31908 on 192.168.1.233 port 22 rdomain "" Dec 18 23:22:02 Claimco sshd[17718]: Unable to negotiate with 61.177.172.76 port 31908: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 18 23:22:09 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 18 23:29:39 Claimco sshd[19624]: Connection from 84.110.99.202 port 45566 on 192.168.1.233 port 22 rdomain "" Dec 18 23:29:39 Claimco sshd[19624]: Invalid user db2inst2 from 84.110.99.202 port 45566 Dec 18 23:29:40 Claimco sshd[19624]: pam_unix(sshd:auth): check pass; user unknown Dec 18 23:29:40 Claimco sshd[19624]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=84.110.99.202 Dec 18 23:29:42 Claimco sshd[19624]: Failed password for invalid user db2inst2 from 84.110.99.202 port 45566 ssh2 Dec 18 23:29:43 Claimco sshd[19624]: Connection closed by invalid user db2inst2 84.110.99.202 port 45566 [preauth] Dec 18 23:30:30 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 7 TIMES] ### Dec 18 23:41:49 Claimco sshd[22566]: Connection from 65.2.28.105 port 48490 on 192.168.1.233 port 22 rdomain "" Dec 18 23:41:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 18 23:41:50 Claimco sshd[22566]: Invalid user zhangyao from 65.2.28.105 port 48490 Dec 18 23:41:50 Claimco sshd[22566]: pam_unix(sshd:auth): check pass; user unknown Dec 18 23:41:50 Claimco sshd[22566]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=65.2.28.105 Dec 18 23:41:52 Claimco sshd[22566]: Failed password for invalid user zhangyao from 65.2.28.105 port 48490 ssh2 Dec 18 23:41:54 Claimco sshd[22566]: Connection closed by invalid user zhangyao 65.2.28.105 port 48490 [preauth] Dec 18 23:43:00 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 18 23:50:48 Claimco sshd[24865]: Connection from 61.177.172.76 port 54988 on 192.168.1.233 port 22 rdomain "" Dec 18 23:50:49 Claimco sshd[24865]: Unable to negotiate with 61.177.172.76 port 54988: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 18 23:51:20 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 4 TIMES] ### Dec 19 00:00:26 Claimco root: /etc/libvirt: 1022.3 MiB (1071943680 bytes) trimmed on /dev/loop2 Dec 19 00:00:26 Claimco root: /mnt/cache: 1.9 TiB (2047013031936 bytes) trimmed on /dev/nvme0n1p1 Dec 19 00:01:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 10 TIMES] ### Dec 19 00:19:25 Claimco sshd[31924]: Connection from 61.177.172.76 port 34894 on 192.168.1.233 port 22 rdomain "" Dec 19 00:20:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 00:21:25 Claimco sshd[31924]: fatal: Timeout before authentication for 61.177.172.76 port 34894 Dec 19 00:22:33 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 00:26:02 Claimco sshd[1247]: Connection from 131.0.0.11 port 54884 on 192.168.1.233 port 22 rdomain "" Dec 19 00:26:23 Claimco sshd[1247]: Connection closed by authenticating user root 131.0.0.11 port 54884 [preauth] Dec 19 00:26:52 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 19 00:34:04 Claimco sshd[3062]: Connection from 162.218.126.136 port 53404 on 192.168.1.233 port 22 rdomain "" Dec 19 00:34:04 Claimco sshd[3062]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=162.218.126.136 user=root Dec 19 00:34:06 Claimco sshd[3062]: Failed password for root from 162.218.126.136 port 53404 ssh2 Dec 19 00:34:07 Claimco sshd[3062]: Connection closed by authenticating user root 162.218.126.136 port 53404 [preauth] Dec 19 00:35:12 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 6 TIMES] ### Dec 19 00:43:03 Claimco proftpd[5263]: 127.0.0.1 (34.78.6.216[34.78.6.216]) - USER anonymous: no such user found from 34.78.6.216 [34.78.6.216] to ::ffff:192.168.1.233:21 Dec 19 00:43:25 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 00:43:48 Claimco sshd[5449]: Connection from 92.46.108.20 port 44366 on 192.168.1.233 port 22 rdomain "" Dec 19 00:43:49 Claimco sshd[5449]: Invalid user user from 92.46.108.20 port 44366 Dec 19 00:43:50 Claimco sshd[5449]: pam_unix(sshd:auth): check pass; user unknown Dec 19 00:43:50 Claimco sshd[5449]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=92.46.108.20 Dec 19 00:43:52 Claimco sshd[5449]: Failed password for invalid user user from 92.46.108.20 port 44366 ssh2 Dec 19 00:43:53 Claimco sshd[5449]: Connection closed by invalid user user 92.46.108.20 port 44366 [preauth] Dec 19 00:45:32 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 00:47:08 Claimco sshd[6429]: Connection from 61.177.172.76 port 23280 on 192.168.1.233 port 22 rdomain "" Dec 19 00:47:08 Claimco sshd[6429]: Unable to negotiate with 61.177.172.76 port 23280: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 00:47:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 4 TIMES] ### Dec 19 00:57:35 Claimco sshd[9157]: Connection from 93.62.178.248 port 55484 on 192.168.1.233 port 22 rdomain "" Dec 19 00:57:36 Claimco sshd[9157]: Invalid user user from 93.62.178.248 port 55484 Dec 19 00:57:36 Claimco sshd[9157]: pam_unix(sshd:auth): check pass; user unknown Dec 19 00:57:36 Claimco sshd[9157]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=93.62.178.248 Dec 19 00:57:37 Claimco sshd[9157]: Failed password for invalid user user from 93.62.178.248 port 55484 ssh2 Dec 19 00:57:37 Claimco sshd[9157]: Connection closed by invalid user user 93.62.178.248 port 55484 [preauth] Dec 19 00:58:03 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 01:00:01 Claimco Plugin Auto Update: Checking for available plugin updates Dec 19 01:00:04 Claimco Plugin Auto Update: Checking for language updates Dec 19 01:00:04 Claimco Plugin Auto Update: Community Applications Plugin Auto Update finished Dec 19 01:00:05 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 01:02:18 Claimco sshd[10459]: Connection from 84.110.99.202 port 35228 on 192.168.1.233 port 22 rdomain "" Dec 19 01:02:19 Claimco sshd[10459]: Invalid user user from 84.110.99.202 port 35228 Dec 19 01:02:19 Claimco sshd[10459]: pam_unix(sshd:auth): check pass; user unknown Dec 19 01:02:19 Claimco sshd[10459]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=84.110.99.202 Dec 19 01:02:20 Claimco sshd[10459]: Failed password for invalid user user from 84.110.99.202 port 35228 ssh2 Dec 19 01:02:22 Claimco sshd[10459]: Connection closed by invalid user user 84.110.99.202 port 35228 [preauth] Dec 19 01:04:18 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 7 TIMES] ### Dec 19 01:14:57 Claimco sshd[13504]: Connection from 61.177.173.56 port 23722 on 192.168.1.233 port 22 rdomain "" Dec 19 01:14:58 Claimco sshd[13504]: Unable to negotiate with 61.177.173.56 port 23722: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 01:16:46 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 01:20:49 Claimco sshd[15084]: Connection from 65.2.28.105 port 45608 on 192.168.1.233 port 22 rdomain "" Dec 19 01:20:50 Claimco sshd[15084]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=65.2.28.105 user=root Dec 19 01:20:52 Claimco sshd[15084]: Failed password for root from 65.2.28.105 port 45608 ssh2 Dec 19 01:20:53 Claimco sshd[15084]: Connection closed by authenticating user root 65.2.28.105 port 45608 [preauth] Dec 19 01:21:00 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 13 TIMES] ### Dec 19 01:43:29 Claimco sshd[20578]: Connection from 61.177.173.43 port 8538 on 192.168.1.233 port 22 rdomain "" Dec 19 01:43:55 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 01:45:18 Claimco sshd[21184]: Connection from 141.98.11.57 port 35890 on 192.168.1.233 port 22 rdomain "" Dec 19 01:45:18 Claimco sshd[21184]: error: kex_exchange_identification: Connection closed by remote host Dec 19 01:45:18 Claimco sshd[21184]: Connection closed by 141.98.11.57 port 35890 Dec 19 01:45:29 Claimco sshd[20578]: fatal: Timeout before authentication for 61.177.173.43 port 8538 Dec 19 01:45:40 Claimco sshd[21324]: Connection from 141.98.11.57 port 41758 on 192.168.1.233 port 22 rdomain "" Dec 19 01:45:40 Claimco sshd[21324]: Unable to negotiate with 141.98.11.57 port 41758: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:45:53 Claimco sshd[21355]: Connection from 141.98.11.57 port 49138 on 192.168.1.233 port 22 rdomain "" Dec 19 01:45:53 Claimco sshd[21355]: Unable to negotiate with 141.98.11.57 port 49138: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:45:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 01:46:07 Claimco sshd[21443]: Connection from 141.98.11.57 port 56518 on 192.168.1.233 port 22 rdomain "" Dec 19 01:46:07 Claimco sshd[21443]: Unable to negotiate with 141.98.11.57 port 56518: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:46:22 Claimco sshd[21474]: Connection from 141.98.11.57 port 35666 on 192.168.1.233 port 22 rdomain "" Dec 19 01:46:22 Claimco sshd[21474]: Unable to negotiate with 141.98.11.57 port 35666: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:46:36 Claimco sshd[21536]: Connection from 141.98.11.57 port 43046 on 192.168.1.233 port 22 rdomain "" Dec 19 01:46:36 Claimco sshd[21536]: Unable to negotiate with 141.98.11.57 port 43046: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:46:51 Claimco sshd[21569]: Connection from 141.98.11.57 port 50426 on 192.168.1.233 port 22 rdomain "" Dec 19 01:46:51 Claimco sshd[21569]: Unable to negotiate with 141.98.11.57 port 50426: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:47:07 Claimco sshd[21663]: Connection from 141.98.11.57 port 57806 on 192.168.1.233 port 22 rdomain "" Dec 19 01:47:07 Claimco sshd[21663]: Unable to negotiate with 141.98.11.57 port 57806: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:47:23 Claimco sshd[21698]: Connection from 141.98.11.57 port 36954 on 192.168.1.233 port 22 rdomain "" Dec 19 01:47:23 Claimco sshd[21698]: Unable to negotiate with 141.98.11.57 port 36954: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:47:40 Claimco sshd[21763]: Connection from 141.98.11.57 port 44334 on 192.168.1.233 port 22 rdomain "" Dec 19 01:47:40 Claimco sshd[21763]: Unable to negotiate with 141.98.11.57 port 44334: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:47:57 Claimco sshd[21800]: Connection from 141.98.11.57 port 51714 on 192.168.1.233 port 22 rdomain "" Dec 19 01:47:57 Claimco sshd[21800]: Unable to negotiate with 141.98.11.57 port 51714: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:48:02 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 01:48:15 Claimco sshd[21896]: Connection from 141.98.11.57 port 59094 on 192.168.1.233 port 22 rdomain "" Dec 19 01:48:15 Claimco sshd[21896]: Unable to negotiate with 141.98.11.57 port 59094: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:48:33 Claimco sshd[21968]: Connection from 141.98.11.57 port 38242 on 192.168.1.233 port 22 rdomain "" Dec 19 01:48:33 Claimco sshd[21968]: Unable to negotiate with 141.98.11.57 port 38242: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:48:53 Claimco sshd[22036]: Connection from 141.98.11.57 port 45622 on 192.168.1.233 port 22 rdomain "" Dec 19 01:48:53 Claimco sshd[22036]: Unable to negotiate with 141.98.11.57 port 45622: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:49:13 Claimco sshd[22151]: Connection from 141.98.11.57 port 53002 on 192.168.1.233 port 22 rdomain "" Dec 19 01:49:13 Claimco sshd[22151]: Unable to negotiate with 141.98.11.57 port 53002: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:49:34 Claimco sshd[22202]: Connection from 141.98.11.57 port 60382 on 192.168.1.233 port 22 rdomain "" Dec 19 01:49:34 Claimco sshd[22202]: Unable to negotiate with 141.98.11.57 port 60382: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:49:56 Claimco sshd[22272]: Connection from 141.98.11.57 port 39530 on 192.168.1.233 port 22 rdomain "" Dec 19 01:49:56 Claimco sshd[22272]: Unable to negotiate with 141.98.11.57 port 39530: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:50:04 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 01:50:19 Claimco sshd[22427]: Connection from 141.98.11.57 port 46910 on 192.168.1.233 port 22 rdomain "" Dec 19 01:50:19 Claimco sshd[22427]: Unable to negotiate with 141.98.11.57 port 46910: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:50:45 Claimco sshd[22508]: Connection from 141.98.11.57 port 54290 on 192.168.1.233 port 22 rdomain "" Dec 19 01:50:45 Claimco sshd[22508]: Unable to negotiate with 141.98.11.57 port 54290: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:51:11 Claimco sshd[22623]: Connection from 141.98.11.57 port 33438 on 192.168.1.233 port 22 rdomain "" Dec 19 01:51:11 Claimco sshd[22623]: Unable to negotiate with 141.98.11.57 port 33438: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:51:38 Claimco sshd[22686]: Connection from 141.98.11.57 port 40818 on 192.168.1.233 port 22 rdomain "" Dec 19 01:51:38 Claimco sshd[22686]: Unable to negotiate with 141.98.11.57 port 40818: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:52:08 Claimco sshd[22808]: Connection from 141.98.11.57 port 48198 on 192.168.1.233 port 22 rdomain "" Dec 19 01:52:08 Claimco sshd[22808]: Unable to negotiate with 141.98.11.57 port 48198: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:52:08 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 01:52:40 Claimco sshd[22904]: Connection from 141.98.11.57 port 55578 on 192.168.1.233 port 22 rdomain "" Dec 19 01:52:40 Claimco sshd[22904]: Unable to negotiate with 141.98.11.57 port 55578: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:53:14 Claimco sshd[23056]: Connection from 141.98.11.57 port 34726 on 192.168.1.233 port 22 rdomain "" Dec 19 01:53:14 Claimco sshd[23056]: Unable to negotiate with 141.98.11.57 port 34726: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:53:48 Claimco sshd[23183]: Connection from 141.98.11.57 port 42106 on 192.168.1.233 port 22 rdomain "" Dec 19 01:53:48 Claimco sshd[23183]: Unable to negotiate with 141.98.11.57 port 42106: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:54:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 01:54:23 Claimco sshd[23333]: Connection from 141.98.11.57 port 49486 on 192.168.1.233 port 22 rdomain "" Dec 19 01:54:24 Claimco sshd[23333]: Unable to negotiate with 141.98.11.57 port 49486: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:55:03 Claimco sshd[23482]: Connection from 141.98.11.57 port 56866 on 192.168.1.233 port 22 rdomain "" Dec 19 01:55:03 Claimco sshd[23482]: Unable to negotiate with 141.98.11.57 port 56866: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:55:46 Claimco sshd[23844]: Connection from 141.98.11.57 port 36014 on 192.168.1.233 port 22 rdomain "" Dec 19 01:55:46 Claimco sshd[23844]: Unable to negotiate with 141.98.11.57 port 36014: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:56:27 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 01:56:31 Claimco sshd[24027]: Connection from 141.98.11.57 port 43394 on 192.168.1.233 port 22 rdomain "" Dec 19 01:56:31 Claimco sshd[24027]: Unable to negotiate with 141.98.11.57 port 43394: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:57:23 Claimco sshd[24216]: Connection from 141.98.11.57 port 50774 on 192.168.1.233 port 22 rdomain "" Dec 19 01:57:23 Claimco sshd[24216]: Unable to negotiate with 141.98.11.57 port 50774: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:58:19 Claimco sshd[24393]: Connection from 141.98.11.57 port 58154 on 192.168.1.233 port 22 rdomain "" Dec 19 01:58:19 Claimco sshd[24393]: Unable to negotiate with 141.98.11.57 port 58154: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 01:58:27 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 01:59:22 Claimco sshd[24655]: Connection from 141.98.11.57 port 37302 on 192.168.1.233 port 22 rdomain "" Dec 19 01:59:22 Claimco sshd[24655]: Unable to negotiate with 141.98.11.57 port 37302: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:00:30 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:00:32 Claimco sshd[24963]: Connection from 141.98.11.57 port 44682 on 192.168.1.233 port 22 rdomain "" Dec 19 02:00:32 Claimco sshd[24963]: Unable to negotiate with 141.98.11.57 port 44682: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:01:51 Claimco sshd[25212]: Connection from 141.98.11.57 port 52062 on 192.168.1.233 port 22 rdomain "" Dec 19 02:01:51 Claimco sshd[25212]: Unable to negotiate with 141.98.11.57 port 52062: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:02:34 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:03:01 Claimco sshd[25503]: Connection from 141.98.11.57 port 59442 on 192.168.1.233 port 22 rdomain "" Dec 19 02:03:01 Claimco sshd[25503]: Unable to negotiate with 141.98.11.57 port 59442: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:03:53 Claimco sshd[25669]: Connection from 141.98.11.57 port 38590 on 192.168.1.233 port 22 rdomain "" Dec 19 02:03:53 Claimco sshd[25669]: Unable to negotiate with 141.98.11.57 port 38590: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:04:37 Claimco sshd[25864]: Connection from 141.98.11.57 port 45970 on 192.168.1.233 port 22 rdomain "" Dec 19 02:04:37 Claimco sshd[25864]: Unable to negotiate with 141.98.11.57 port 45970: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:04:42 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:05:19 Claimco sshd[26053]: Connection from 141.98.11.57 port 53350 on 192.168.1.233 port 22 rdomain "" Dec 19 02:05:19 Claimco sshd[26053]: Unable to negotiate with 141.98.11.57 port 53350: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:05:56 Claimco sshd[26364]: Connection from 141.98.11.57 port 60730 on 192.168.1.233 port 22 rdomain "" Dec 19 02:05:56 Claimco sshd[26364]: Unable to negotiate with 141.98.11.57 port 60730: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:06:35 Claimco sshd[26507]: Connection from 141.98.11.57 port 39878 on 192.168.1.233 port 22 rdomain "" Dec 19 02:06:35 Claimco sshd[26507]: Unable to negotiate with 141.98.11.57 port 39878: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:06:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 02:07:10 Claimco sshd[26663]: Connection from 141.98.11.57 port 47258 on 192.168.1.233 port 22 rdomain "" Dec 19 02:07:11 Claimco sshd[26663]: Unable to negotiate with 141.98.11.57 port 47258: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:07:44 Claimco sshd[26761]: Connection from 141.98.11.57 port 54638 on 192.168.1.233 port 22 rdomain "" Dec 19 02:07:44 Claimco sshd[26761]: Unable to negotiate with 141.98.11.57 port 54638: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:07:49 Claimco sshd[26776]: Connection from 61.177.173.49 port 29188 on 192.168.1.233 port 22 rdomain "" Dec 19 02:07:50 Claimco sshd[26776]: Received disconnect from 61.177.173.49 port 29188:11: [preauth] Dec 19 02:07:50 Claimco sshd[26776]: Disconnected from 61.177.173.49 port 29188 [preauth] Dec 19 02:08:00 Claimco sshd[26800]: Connection from 61.177.173.35 port 58936 on 192.168.1.233 port 22 rdomain "" Dec 19 02:08:01 Claimco sshd[26800]: Received disconnect from 61.177.173.35 port 58936:11: [preauth] Dec 19 02:08:01 Claimco sshd[26800]: Disconnected from 61.177.173.35 port 58936 [preauth] Dec 19 02:08:17 Claimco sshd[26895]: Connection from 141.98.11.57 port 33786 on 192.168.1.233 port 22 rdomain "" Dec 19 02:08:17 Claimco sshd[26895]: Unable to negotiate with 141.98.11.57 port 33786: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:08:50 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:08:50 Claimco sshd[27021]: Connection from 141.98.11.57 port 41166 on 192.168.1.233 port 22 rdomain "" Dec 19 02:08:50 Claimco sshd[27021]: Unable to negotiate with 141.98.11.57 port 41166: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:09:15 Claimco sshd[27146]: Connection from 61.177.173.52 port 12648 on 192.168.1.233 port 22 rdomain "" Dec 19 02:09:16 Claimco sshd[27146]: Received disconnect from 61.177.173.52 port 12648:11: [preauth] Dec 19 02:09:16 Claimco sshd[27146]: Disconnected from 61.177.173.52 port 12648 [preauth] Dec 19 02:09:23 Claimco sshd[27167]: Connection from 141.98.11.57 port 48546 on 192.168.1.233 port 22 rdomain "" Dec 19 02:09:24 Claimco sshd[27167]: Unable to negotiate with 141.98.11.57 port 48546: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:09:57 Claimco sshd[27266]: Connection from 141.98.11.57 port 55926 on 192.168.1.233 port 22 rdomain "" Dec 19 02:09:57 Claimco sshd[27266]: Unable to negotiate with 141.98.11.57 port 55926: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:10:31 Claimco sshd[27448]: Connection from 141.98.11.57 port 35074 on 192.168.1.233 port 22 rdomain "" Dec 19 02:10:31 Claimco sshd[27448]: Unable to negotiate with 141.98.11.57 port 35074: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:11:00 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:11:05 Claimco sshd[27576]: Connection from 141.98.11.57 port 42454 on 192.168.1.233 port 22 rdomain "" Dec 19 02:11:05 Claimco sshd[27576]: Unable to negotiate with 141.98.11.57 port 42454: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:11:32 Claimco sshd[27663]: Connection from 61.177.172.114 port 10699 on 192.168.1.233 port 22 rdomain "" Dec 19 02:11:34 Claimco sshd[27663]: Received disconnect from 61.177.172.114 port 10699:11: [preauth] Dec 19 02:11:34 Claimco sshd[27663]: Disconnected from 61.177.172.114 port 10699 [preauth] Dec 19 02:11:37 Claimco sshd[27675]: Connection from 141.98.11.57 port 49834 on 192.168.1.233 port 22 rdomain "" Dec 19 02:11:37 Claimco sshd[27675]: Unable to negotiate with 141.98.11.57 port 49834: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:12:17 Claimco sshd[27841]: Connection from 61.177.172.61 port 31444 on 192.168.1.233 port 22 rdomain "" Dec 19 02:12:18 Claimco sshd[27841]: Unable to negotiate with 61.177.172.61 port 31444: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 02:12:25 Claimco sshd[27866]: Connection from 141.98.11.57 port 57214 on 192.168.1.233 port 22 rdomain "" Dec 19 02:12:25 Claimco sshd[27866]: Unable to negotiate with 141.98.11.57 port 57214: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:12:54 Claimco sshd[27950]: Connection from 141.98.11.57 port 36362 on 192.168.1.233 port 22 rdomain "" Dec 19 02:12:54 Claimco sshd[27950]: Unable to negotiate with 141.98.11.57 port 36362: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:13:00 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:13:22 Claimco sshd[28067]: Connection from 141.98.11.57 port 43740 on 192.168.1.233 port 22 rdomain "" Dec 19 02:13:22 Claimco sshd[28067]: Unable to negotiate with 141.98.11.57 port 43740: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:13:50 Claimco sshd[28182]: Connection from 141.98.11.57 port 51120 on 192.168.1.233 port 22 rdomain "" Dec 19 02:13:50 Claimco sshd[28182]: Unable to negotiate with 141.98.11.57 port 51120: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:14:17 Claimco sshd[28288]: Connection from 141.98.11.57 port 58498 on 192.168.1.233 port 22 rdomain "" Dec 19 02:14:17 Claimco sshd[28288]: Unable to negotiate with 141.98.11.57 port 58498: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:14:44 Claimco sshd[28374]: Connection from 141.98.11.57 port 37646 on 192.168.1.233 port 22 rdomain "" Dec 19 02:14:44 Claimco sshd[28374]: Unable to negotiate with 141.98.11.57 port 37646: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:15:04 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:15:10 Claimco sshd[28534]: Connection from 141.98.11.57 port 45024 on 192.168.1.233 port 22 rdomain "" Dec 19 02:15:10 Claimco sshd[28534]: Unable to negotiate with 141.98.11.57 port 45024: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:15:36 Claimco sshd[28821]: Connection from 141.98.11.57 port 52404 on 192.168.1.233 port 22 rdomain "" Dec 19 02:15:36 Claimco sshd[28821]: Unable to negotiate with 141.98.11.57 port 52404: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:16:02 Claimco sshd[28935]: Connection from 141.98.11.57 port 59784 on 192.168.1.233 port 22 rdomain "" Dec 19 02:16:02 Claimco sshd[28935]: Unable to negotiate with 141.98.11.57 port 59784: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:16:28 Claimco sshd[29019]: Connection from 141.98.11.57 port 38932 on 192.168.1.233 port 22 rdomain "" Dec 19 02:16:29 Claimco sshd[29019]: Unable to negotiate with 141.98.11.57 port 38932: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:16:55 Claimco sshd[29099]: Connection from 141.98.11.57 port 46312 on 192.168.1.233 port 22 rdomain "" Dec 19 02:16:55 Claimco sshd[29099]: Unable to negotiate with 141.98.11.57 port 46312: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:17:11 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:17:21 Claimco sshd[29187]: Connection from 141.98.11.57 port 53692 on 192.168.1.233 port 22 rdomain "" Dec 19 02:17:21 Claimco sshd[29187]: Unable to negotiate with 141.98.11.57 port 53692: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:17:45 Claimco sshd[29268]: Connection from 141.98.11.57 port 32840 on 192.168.1.233 port 22 rdomain "" Dec 19 02:17:46 Claimco sshd[29268]: Unable to negotiate with 141.98.11.57 port 32840: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:17:55 Claimco sshd[29291]: Connection from 61.177.173.53 port 29024 on 192.168.1.233 port 22 rdomain "" Dec 19 02:17:56 Claimco sshd[29291]: Received disconnect from 61.177.173.53 port 29024:11: [preauth] Dec 19 02:17:56 Claimco sshd[29291]: Disconnected from 61.177.173.53 port 29024 [preauth] Dec 19 02:18:10 Claimco sshd[29381]: Connection from 141.98.11.57 port 40220 on 192.168.1.233 port 22 rdomain "" Dec 19 02:18:10 Claimco sshd[29381]: Unable to negotiate with 141.98.11.57 port 40220: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:18:34 Claimco sshd[29491]: Connection from 141.98.11.57 port 47600 on 192.168.1.233 port 22 rdomain "" Dec 19 02:18:35 Claimco sshd[29491]: Unable to negotiate with 141.98.11.57 port 47600: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:18:59 Claimco sshd[29566]: Connection from 141.98.11.57 port 54980 on 192.168.1.233 port 22 rdomain "" Dec 19 02:18:59 Claimco sshd[29566]: Unable to negotiate with 141.98.11.57 port 54980: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:19:15 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:19:23 Claimco sshd[29667]: Connection from 141.98.11.57 port 34128 on 192.168.1.233 port 22 rdomain "" Dec 19 02:19:23 Claimco sshd[29667]: Unable to negotiate with 141.98.11.57 port 34128: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:19:46 Claimco sshd[29744]: Connection from 141.98.11.57 port 41508 on 192.168.1.233 port 22 rdomain "" Dec 19 02:19:46 Claimco sshd[29744]: Unable to negotiate with 141.98.11.57 port 41508: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:19:49 Claimco sshd[29752]: Connection from 61.177.173.39 port 54721 on 192.168.1.233 port 22 rdomain "" Dec 19 02:19:50 Claimco sshd[29752]: Received disconnect from 61.177.173.39 port 54721:11: [preauth] Dec 19 02:19:50 Claimco sshd[29752]: Disconnected from 61.177.173.39 port 54721 [preauth] Dec 19 02:20:08 Claimco sshd[29899]: Connection from 141.98.11.57 port 48888 on 192.168.1.233 port 22 rdomain "" Dec 19 02:20:08 Claimco sshd[29899]: Unable to negotiate with 141.98.11.57 port 48888: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 02:21:22 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:22:09 Claimco sshd[30323]: Connection from 61.177.172.98 port 55838 on 192.168.1.233 port 22 rdomain "" Dec 19 02:22:11 Claimco sshd[30323]: Received disconnect from 61.177.172.98 port 55838:11: [preauth] Dec 19 02:22:11 Claimco sshd[30323]: Disconnected from 61.177.172.98 port 55838 [preauth] Dec 19 02:23:23 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:24:47 Claimco sshd[30891]: Connection from 61.177.172.90 port 18186 on 192.168.1.233 port 22 rdomain "" Dec 19 02:24:48 Claimco sshd[30891]: Received disconnect from 61.177.172.90 port 18186:11: [preauth] Dec 19 02:24:48 Claimco sshd[30891]: Disconnected from 61.177.172.90 port 18186 [preauth] Dec 19 02:25:33 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 02:27:43 Claimco sshd[31737]: Connection from 61.177.173.51 port 53019 on 192.168.1.233 port 22 rdomain "" Dec 19 02:27:44 Claimco sshd[31737]: Received disconnect from 61.177.173.51 port 53019:11: [preauth] Dec 19 02:27:44 Claimco sshd[31737]: Disconnected from 61.177.173.51 port 53019 [preauth] Dec 19 02:29:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:31:30 Claimco sshd[32643]: Connection from 61.177.173.35 port 23113 on 192.168.1.233 port 22 rdomain "" Dec 19 02:31:31 Claimco sshd[32643]: Received disconnect from 61.177.173.35 port 23113:11: [preauth] Dec 19 02:31:31 Claimco sshd[32643]: Disconnected from 61.177.173.35 port 23113 [preauth] Dec 19 02:31:46 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 02:34:11 Claimco sshd[819]: Connection from 162.218.126.136 port 42880 on 192.168.1.233 port 22 rdomain "" Dec 19 02:34:11 Claimco sshd[819]: Invalid user test1 from 162.218.126.136 port 42880 Dec 19 02:34:11 Claimco sshd[819]: pam_unix(sshd:auth): check pass; user unknown Dec 19 02:34:11 Claimco sshd[819]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=162.218.126.136 Dec 19 02:34:13 Claimco sshd[819]: Failed password for invalid user test1 from 162.218.126.136 port 42880 ssh2 Dec 19 02:34:13 Claimco sshd[819]: Connection closed by invalid user test1 162.218.126.136 port 42880 [preauth] Dec 19 02:34:28 Claimco sshd[889]: Connection from 84.110.99.202 port 52270 on 192.168.1.233 port 22 rdomain "" Dec 19 02:34:29 Claimco sshd[889]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=84.110.99.202 user=root Dec 19 02:34:31 Claimco sshd[889]: Failed password for root from 84.110.99.202 port 52270 ssh2 Dec 19 02:34:31 Claimco sshd[889]: Connection closed by authenticating user root 84.110.99.202 port 52270 [preauth] Dec 19 02:35:58 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:36:01 Claimco sshd[1452]: Connection from 61.177.172.108 port 61889 on 192.168.1.233 port 22 rdomain "" Dec 19 02:36:02 Claimco sshd[1452]: Received disconnect from 61.177.172.108 port 61889:11: [preauth] Dec 19 02:36:02 Claimco sshd[1452]: Disconnected from 61.177.172.108 port 61889 [preauth] Dec 19 02:36:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 02:37:27 Claimco sshd[1764]: Connection from 61.177.173.49 port 64708 on 192.168.1.233 port 22 rdomain "" Dec 19 02:37:29 Claimco sshd[1764]: Received disconnect from 61.177.173.49 port 64708:11: [preauth] Dec 19 02:37:29 Claimco sshd[1764]: Disconnected from 61.177.173.49 port 64708 [preauth] Dec 19 02:37:59 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:38:18 Claimco sshd[1950]: Connection from 66.240.236.116 port 35508 on 192.168.1.233 port 22 rdomain "" Dec 19 02:38:28 Claimco sshd[1950]: Connection closed by 66.240.236.116 port 35508 [preauth] Dec 19 02:40:04 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:40:54 Claimco sshd[2563]: Connection from 61.177.173.43 port 50146 on 192.168.1.233 port 22 rdomain "" Dec 19 02:40:54 Claimco sshd[2563]: Unable to negotiate with 61.177.173.43 port 50146: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 02:41:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 02:43:15 Claimco sshd[3084]: Connection from 61.177.173.36 port 27134 on 192.168.1.233 port 22 rdomain "" Dec 19 02:43:16 Claimco sshd[3084]: Received disconnect from 61.177.173.36 port 27134:11: [preauth] Dec 19 02:43:16 Claimco sshd[3084]: Disconnected from 61.177.173.36 port 27134 [preauth] Dec 19 02:44:15 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:45:43 Claimco sshd[3874]: Connection from 61.177.172.90 port 57167 on 192.168.1.233 port 22 rdomain "" Dec 19 02:45:44 Claimco sshd[3874]: Received disconnect from 61.177.172.90 port 57167:11: [preauth] Dec 19 02:45:44 Claimco sshd[3874]: Disconnected from 61.177.172.90 port 57167 [preauth] Dec 19 02:46:21 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 02:48:44 Claimco sshd[4539]: Connection from 61.177.173.53 port 52569 on 192.168.1.233 port 22 rdomain "" Dec 19 02:48:45 Claimco sshd[4539]: Received disconnect from 61.177.173.53 port 52569:11: [preauth] Dec 19 02:48:45 Claimco sshd[4539]: Disconnected from 61.177.173.53 port 52569 [preauth] Dec 19 02:50:13 Claimco sshd[4929]: Connection from 61.177.172.98 port 36004 on 192.168.1.233 port 22 rdomain "" Dec 19 02:50:16 Claimco sshd[4929]: Received disconnect from 61.177.172.98 port 36004:11: [preauth] Dec 19 02:50:16 Claimco sshd[4929]: Disconnected from 61.177.172.98 port 36004 [preauth] Dec 19 02:50:33 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 02:55:00 Claimco sshd[5937]: Connection from 61.177.173.35 port 18396 on 192.168.1.233 port 22 rdomain "" Dec 19 02:55:01 Claimco sshd[5937]: Received disconnect from 61.177.173.35 port 18396:11: [preauth] Dec 19 02:55:01 Claimco sshd[5937]: Disconnected from 61.177.173.35 port 18396 [preauth] Dec 19 02:56:52 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:56:53 Claimco sshd[6604]: Connection from 61.177.172.104 port 57053 on 192.168.1.233 port 22 rdomain "" Dec 19 02:56:54 Claimco sshd[6604]: Received disconnect from 61.177.172.104 port 57053:11: [preauth] Dec 19 02:56:54 Claimco sshd[6604]: Disconnected from 61.177.172.104 port 57053 [preauth] Dec 19 02:57:30 Claimco sshd[6749]: Connection from 61.177.173.50 port 51678 on 192.168.1.233 port 22 rdomain "" Dec 19 02:57:32 Claimco sshd[6749]: Received disconnect from 61.177.173.50 port 51678:11: [preauth] Dec 19 02:57:32 Claimco sshd[6749]: Disconnected from 61.177.173.50 port 51678 [preauth] Dec 19 02:57:41 Claimco sshd[6796]: Connection from 134.122.90.159 port 37000 on 192.168.1.233 port 22 rdomain "" Dec 19 02:57:41 Claimco sshd[6796]: Invalid user x from 134.122.90.159 port 37000 Dec 19 02:57:41 Claimco sshd[6796]: pam_unix(sshd:auth): check pass; user unknown Dec 19 02:57:41 Claimco sshd[6796]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=134.122.90.159 Dec 19 02:57:43 Claimco sshd[6796]: Failed password for invalid user x from 134.122.90.159 port 37000 ssh2 Dec 19 02:57:44 Claimco sshd[6796]: Connection closed by invalid user x 134.122.90.159 port 37000 [preauth] Dec 19 02:58:55 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 02:59:15 Claimco sshd[7202]: Connection from 65.2.28.105 port 34690 on 192.168.1.233 port 22 rdomain "" Dec 19 02:59:16 Claimco sshd[7202]: Invalid user user1 from 65.2.28.105 port 34690 Dec 19 02:59:16 Claimco sshd[7202]: pam_unix(sshd:auth): check pass; user unknown Dec 19 02:59:16 Claimco sshd[7202]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=65.2.28.105 Dec 19 02:59:18 Claimco sshd[7202]: Failed password for invalid user user1 from 65.2.28.105 port 34690 ssh2 Dec 19 02:59:20 Claimco sshd[7202]: Connection closed by invalid user user1 65.2.28.105 port 34690 [preauth] Dec 19 03:01:03 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 03:04:11 Claimco sshd[8484]: Connection from 61.177.172.124 port 64581 on 192.168.1.233 port 22 rdomain "" Dec 19 03:04:12 Claimco sshd[8484]: Received disconnect from 61.177.172.124 port 64581:11: [preauth] Dec 19 03:04:12 Claimco sshd[8484]: Disconnected from 61.177.172.124 port 64581 [preauth] Dec 19 03:05:05 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 03:07:00 Claimco sshd[9304]: Connection from 61.177.173.47 port 46460 on 192.168.1.233 port 22 rdomain "" Dec 19 03:07:01 Claimco sshd[9304]: Received disconnect from 61.177.173.47 port 46460:11: [preauth] Dec 19 03:07:01 Claimco sshd[9304]: Disconnected from 61.177.173.47 port 46460 [preauth] Dec 19 03:07:11 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 03:07:24 Claimco sshd[9413]: Connection from 61.177.173.46 port 21221 on 192.168.1.233 port 22 rdomain "" Dec 19 03:07:25 Claimco sshd[9413]: Received disconnect from 61.177.173.46 port 21221:11: [preauth] Dec 19 03:07:25 Claimco sshd[9413]: Disconnected from 61.177.173.46 port 21221 [preauth] Dec 19 03:09:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 03:09:59 Claimco sshd[9977]: Connection from 61.177.173.55 port 37900 on 192.168.1.233 port 22 rdomain "" Dec 19 03:09:59 Claimco sshd[9977]: Unable to negotiate with 61.177.173.55 port 37900: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 03:11:25 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 03:12:48 Claimco sshd[10609]: Connection from 61.177.172.90 port 55364 on 192.168.1.233 port 22 rdomain "" Dec 19 03:12:49 Claimco sshd[10609]: Received disconnect from 61.177.172.90 port 55364:11: [preauth] Dec 19 03:12:49 Claimco sshd[10609]: Disconnected from 61.177.172.90 port 55364 [preauth] Dec 19 03:13:27 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 03:17:31 Claimco sshd[11895]: Connection from 61.177.173.53 port 63181 on 192.168.1.233 port 22 rdomain "" Dec 19 03:17:32 Claimco sshd[11895]: Received disconnect from 61.177.173.53 port 63181:11: [preauth] Dec 19 03:17:32 Claimco sshd[11895]: Disconnected from 61.177.173.53 port 63181 [preauth] Dec 19 03:17:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 03:18:12 Claimco sshd[12061]: Connection from 61.177.172.124 port 16744 on 192.168.1.233 port 22 rdomain "" Dec 19 03:18:13 Claimco sshd[12061]: Received disconnect from 61.177.172.124 port 16744:11: [preauth] Dec 19 03:18:13 Claimco sshd[12061]: Disconnected from 61.177.172.124 port 16744 [preauth] Dec 19 03:18:54 Claimco sshd[12207]: Connection from 61.177.173.35 port 51786 on 192.168.1.233 port 22 rdomain "" Dec 19 03:18:55 Claimco sshd[12207]: Received disconnect from 61.177.173.35 port 51786:11: [preauth] Dec 19 03:18:55 Claimco sshd[12207]: Disconnected from 61.177.173.35 port 51786 [preauth] Dec 19 03:19:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 19 03:27:40 Claimco sshd[14396]: Connection from 61.177.173.51 port 39946 on 192.168.1.233 port 22 rdomain "" Dec 19 03:27:41 Claimco sshd[14396]: Received disconnect from 61.177.173.51 port 39946:11: [preauth] Dec 19 03:27:41 Claimco sshd[14396]: Disconnected from 61.177.173.51 port 39946 [preauth] Dec 19 03:27:59 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 03:28:46 Claimco sshd[14646]: Connection from 61.177.172.90 port 15286 on 192.168.1.233 port 22 rdomain "" Dec 19 03:28:47 Claimco sshd[14646]: Received disconnect from 61.177.172.90 port 15286:11: [preauth] Dec 19 03:28:47 Claimco sshd[14646]: Disconnected from 61.177.172.90 port 15286 [preauth] Dec 19 03:30:05 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 03:30:53 Claimco sshd[15129]: Connection from 61.177.173.47 port 18017 on 192.168.1.233 port 22 rdomain "" Dec 19 03:30:54 Claimco sshd[15129]: Received disconnect from 61.177.173.47 port 18017:11: [preauth] Dec 19 03:30:54 Claimco sshd[15129]: Disconnected from 61.177.173.47 port 18017 [preauth] Dec 19 03:32:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 03:32:21 Claimco sshd[15471]: Connection from 61.177.172.124 port 56331 on 192.168.1.233 port 22 rdomain "" Dec 19 03:32:22 Claimco sshd[15471]: Received disconnect from 61.177.172.124 port 56331:11: [preauth] Dec 19 03:32:22 Claimco sshd[15471]: Disconnected from 61.177.172.124 port 56331 [preauth] Dec 19 03:34:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 03:34:27 Claimco sshd[15938]: Connection from 92.46.108.20 port 47170 on 192.168.1.233 port 22 rdomain "" Dec 19 03:34:29 Claimco sshd[15938]: Invalid user rsync from 92.46.108.20 port 47170 Dec 19 03:34:29 Claimco sshd[15938]: pam_unix(sshd:auth): check pass; user unknown Dec 19 03:34:29 Claimco sshd[15938]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=92.46.108.20 Dec 19 03:34:31 Claimco sshd[15938]: Failed password for invalid user rsync from 92.46.108.20 port 47170 ssh2 Dec 19 03:34:32 Claimco sshd[15938]: Connection closed by invalid user rsync 92.46.108.20 port 47170 [preauth] Dec 19 03:36:20 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 03:36:50 Claimco sshd[16708]: Connection from 58.72.18.130 port 54164 on 192.168.1.233 port 22 rdomain "" Dec 19 03:36:51 Claimco sshd[16708]: error: kex_exchange_identification: Connection closed by remote host Dec 19 03:36:51 Claimco sshd[16708]: Connection closed by 58.72.18.130 port 54164 Dec 19 03:36:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 03:38:20 Claimco sshd[17039]: Connection from 61.177.173.43 port 23588 on 192.168.1.233 port 22 rdomain "" Dec 19 03:38:26 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 03:38:37 Claimco sshd[17105]: Connection from 61.177.173.53 port 33209 on 192.168.1.233 port 22 rdomain "" Dec 19 03:38:38 Claimco sshd[17105]: Received disconnect from 61.177.173.53 port 33209:11: [preauth] Dec 19 03:38:38 Claimco sshd[17105]: Disconnected from 61.177.173.53 port 33209 [preauth] Dec 19 03:40:01 Claimco root: mover: started Dec 19 03:40:02 Claimco move: file: //..G/... ### [PREVIOUS LINE REPEATED 5 TIMES] ### Dec 19 03:40:02 Claimco root: mover: finished Dec 19 03:40:20 Claimco sshd[17039]: fatal: Timeout before authentication for 61.177.173.43 port 23588 Dec 19 03:40:34 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 03:42:59 Claimco sshd[18138]: Connection from 61.177.173.36 port 28550 on 192.168.1.233 port 22 rdomain "" Dec 19 03:43:00 Claimco sshd[18138]: Received disconnect from 61.177.173.36 port 28550:11: [preauth] Dec 19 03:43:00 Claimco sshd[18138]: Disconnected from 61.177.173.36 port 28550 [preauth] Dec 19 03:44:40 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 03:46:09 Claimco sshd[19126]: Connection from 61.177.173.52 port 41150 on 192.168.1.233 port 22 rdomain "" Dec 19 03:46:11 Claimco sshd[19126]: Received disconnect from 61.177.173.52 port 41150:11: [preauth] Dec 19 03:46:11 Claimco sshd[19126]: Disconnected from 61.177.173.52 port 41150 [preauth] Dec 19 03:46:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 03:46:45 Claimco sshd[19231]: Connection from 61.177.172.108 port 50201 on 192.168.1.233 port 22 rdomain "" Dec 19 03:46:46 Claimco sshd[19231]: Received disconnect from 61.177.172.108 port 50201:11: [preauth] Dec 19 03:46:46 Claimco sshd[19231]: Disconnected from 61.177.172.108 port 50201 [preauth] Dec 19 03:47:42 Claimco sshd[19440]: Connection from 61.177.173.53 port 51004 on 192.168.1.233 port 22 rdomain "" Dec 19 03:47:43 Claimco sshd[19440]: Received disconnect from 61.177.173.53 port 51004:11: [preauth] Dec 19 03:47:43 Claimco sshd[19440]: Disconnected from 61.177.173.53 port 51004 [preauth] Dec 19 03:48:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 03:50:52 Claimco sshd[20165]: Connection from 162.142.125.220 port 57874 on 192.168.1.233 port 22 rdomain "" Dec 19 03:51:02 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 03:51:07 Claimco sshd[20165]: Connection closed by 162.142.125.220 port 57874 [preauth] Dec 19 03:53:03 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 03:55:13 Claimco sshd[21170]: Connection from 61.177.173.48 port 30290 on 192.168.1.233 port 22 rdomain "" Dec 19 03:55:14 Claimco sshd[21170]: Received disconnect from 61.177.173.48 port 30290:11: [preauth] Dec 19 03:55:14 Claimco sshd[21170]: Disconnected from 61.177.173.48 port 30290 [preauth] Dec 19 03:57:12 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 03:57:45 Claimco sshd[21904]: Connection from 61.177.173.53 port 49805 on 192.168.1.233 port 22 rdomain "" Dec 19 03:57:46 Claimco sshd[21904]: Received disconnect from 61.177.173.53 port 49805:11: [preauth] Dec 19 03:57:46 Claimco sshd[21904]: Disconnected from 61.177.173.53 port 49805 [preauth] Dec 19 03:59:17 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 04:00:45 Claimco sshd[22608]: Connection from 61.177.172.124 port 57536 on 192.168.1.233 port 22 rdomain "" Dec 19 04:00:46 Claimco sshd[22608]: Received disconnect from 61.177.172.124 port 57536:11: [preauth] Dec 19 04:00:46 Claimco sshd[22608]: Disconnected from 61.177.172.124 port 57536 [preauth] Dec 19 04:01:17 Claimco sshd[22748]: Connection from 61.177.172.104 port 44893 on 192.168.1.233 port 22 rdomain "" Dec 19 04:01:18 Claimco sshd[22748]: Received disconnect from 61.177.172.104 port 44893:11: [preauth] Dec 19 04:01:18 Claimco sshd[22748]: Disconnected from 61.177.172.104 port 44893 [preauth] Dec 19 04:01:21 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 04:03:52 Claimco sshd[23301]: Connection from 162.218.126.136 port 33266 on 192.168.1.233 port 22 rdomain "" Dec 19 04:03:53 Claimco sshd[23301]: Invalid user odoo from 162.218.126.136 port 33266 Dec 19 04:03:53 Claimco sshd[23301]: pam_unix(sshd:auth): check pass; user unknown Dec 19 04:03:53 Claimco sshd[23301]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=162.218.126.136 Dec 19 04:03:54 Claimco sshd[23301]: Failed password for invalid user odoo from 162.218.126.136 port 33266 ssh2 Dec 19 04:03:55 Claimco sshd[23301]: Connection closed by invalid user odoo 162.218.126.136 port 33266 [preauth] Dec 19 04:05:37 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 19 04:07:02 Claimco sshd[24265]: Connection from 84.110.99.202 port 35270 on 192.168.1.233 port 22 rdomain "" Dec 19 04:07:03 Claimco sshd[24265]: Invalid user user1 from 84.110.99.202 port 35270 Dec 19 04:07:03 Claimco sshd[24265]: pam_unix(sshd:auth): check pass; user unknown Dec 19 04:07:03 Claimco sshd[24265]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=84.110.99.202 Dec 19 04:07:06 Claimco sshd[24265]: Failed password for invalid user user1 from 84.110.99.202 port 35270 ssh2 Dec 19 04:07:07 Claimco sshd[24265]: Connection closed by invalid user user1 84.110.99.202 port 35270 [preauth] Dec 19 04:07:15 Claimco sshd[24316]: Connection from 61.177.172.87 port 3438 on 192.168.1.233 port 22 rdomain "" Dec 19 04:07:23 Claimco sshd[24335]: Connection from 61.177.173.47 port 49228 on 192.168.1.233 port 22 rdomain "" Dec 19 04:07:24 Claimco sshd[24335]: Received disconnect from 61.177.173.47 port 49228:11: [preauth] Dec 19 04:07:24 Claimco sshd[24335]: Disconnected from 61.177.173.47 port 49228 [preauth] Dec 19 04:07:37 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 04:08:07 Claimco sshd[24515]: Connection from 61.177.173.53 port 50676 on 192.168.1.233 port 22 rdomain "" Dec 19 04:08:09 Claimco sshd[24515]: Received disconnect from 61.177.173.53 port 50676:11: [preauth] Dec 19 04:08:09 Claimco sshd[24515]: Disconnected from 61.177.173.53 port 50676 [preauth] Dec 19 04:09:15 Claimco sshd[24316]: fatal: Timeout before authentication for 61.177.172.87 port 3438 Dec 19 04:09:46 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 04:14:43 Claimco sshd[25966]: Connection from 61.177.172.19 port 41838 on 192.168.1.233 port 22 rdomain "" Dec 19 04:14:44 Claimco sshd[25966]: Received disconnect from 61.177.172.19 port 41838:11: [preauth] Dec 19 04:14:44 Claimco sshd[25966]: Disconnected from 61.177.172.19 port 41838 [preauth] Dec 19 04:15:58 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 04:18:27 Claimco sshd[27040]: Connection from 61.177.172.90 port 57717 on 192.168.1.233 port 22 rdomain "" Dec 19 04:18:28 Claimco sshd[27040]: Received disconnect from 61.177.172.90 port 57717:11: [preauth] Dec 19 04:18:28 Claimco sshd[27040]: Disconnected from 61.177.172.90 port 57717 [preauth] Dec 19 04:18:29 Claimco sshd[27044]: Connection from 61.177.173.46 port 45873 on 192.168.1.233 port 22 rdomain "" Dec 19 04:18:30 Claimco sshd[27044]: Received disconnect from 61.177.173.46 port 45873:11: [preauth] Dec 19 04:18:30 Claimco sshd[27044]: Disconnected from 61.177.173.46 port 45873 [preauth] Dec 19 04:19:31 Claimco sshd[27288]: Connection from 61.177.173.39 port 43232 on 192.168.1.233 port 22 rdomain "" Dec 19 04:19:32 Claimco sshd[27288]: Received disconnect from 61.177.173.39 port 43232:11: [preauth] Dec 19 04:19:32 Claimco sshd[27288]: Disconnected from 61.177.173.39 port 43232 [preauth] Dec 19 04:20:04 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 4 TIMES] ### Dec 19 04:28:40 Claimco sshd[29549]: Connection from 61.177.172.98 port 40701 on 192.168.1.233 port 22 rdomain "" Dec 19 04:28:41 Claimco sshd[29549]: Received disconnect from 61.177.172.98 port 40701:11: [preauth] Dec 19 04:28:41 Claimco sshd[29549]: Disconnected from 61.177.172.98 port 40701 [preauth] Dec 19 04:28:58 Claimco sshd[29611]: Connection from 61.177.173.53 port 18615 on 192.168.1.233 port 22 rdomain "" Dec 19 04:28:59 Claimco sshd[29611]: Received disconnect from 61.177.173.53 port 18615:11: [preauth] Dec 19 04:28:59 Claimco sshd[29611]: Disconnected from 61.177.173.53 port 18615 [preauth] Dec 19 04:30:29 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 04:31:36 Claimco sshd[30237]: Connection from 61.177.173.36 port 35207 on 192.168.1.233 port 22 rdomain "" Dec 19 04:31:38 Claimco sshd[30237]: Received disconnect from 61.177.173.36 port 35207:11: [preauth] Dec 19 04:31:38 Claimco sshd[30237]: Disconnected from 61.177.173.36 port 35207 [preauth] Dec 19 04:32:03 Claimco sshd[30353]: Connection from 153.127.46.20 port 52608 on 192.168.1.233 port 22 rdomain "" Dec 19 04:32:04 Claimco sshd[30353]: error: kex_exchange_identification: Connection closed by remote host Dec 19 04:32:04 Claimco sshd[30353]: Connection closed by 153.127.46.20 port 52608 Dec 19 04:32:36 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 04:36:06 Claimco sshd[31488]: Connection from 61.177.173.43 port 31504 on 192.168.1.233 port 22 rdomain "" Dec 19 04:36:07 Claimco sshd[31488]: Unable to negotiate with 61.177.173.43 port 31504: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 04:36:45 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 04:38:22 Claimco sshd[31942]: Connection from 65.2.28.105 port 38552 on 192.168.1.233 port 22 rdomain "" Dec 19 04:38:23 Claimco sshd[31942]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=65.2.28.105 user=root Dec 19 04:38:25 Claimco sshd[31942]: Failed password for root from 65.2.28.105 port 38552 ssh2 Dec 19 04:38:26 Claimco sshd[31942]: Connection closed by authenticating user root 65.2.28.105 port 38552 [preauth] Dec 19 04:38:52 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 04:39:32 Claimco sshd[32231]: Connection from 61.177.173.51 port 57923 on 192.168.1.233 port 22 rdomain "" Dec 19 04:39:33 Claimco sshd[32231]: Received disconnect from 61.177.173.51 port 57923:11: [preauth] Dec 19 04:39:33 Claimco sshd[32231]: Disconnected from 61.177.173.51 port 57923 [preauth] Dec 19 04:40:59 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 04:43:37 Claimco sshd[714]: Connection from 61.177.173.35 port 23077 on 192.168.1.233 port 22 rdomain "" Dec 19 04:43:38 Claimco sshd[714]: Received disconnect from 61.177.173.35 port 23077:11: [preauth] Dec 19 04:43:38 Claimco sshd[714]: Disconnected from 61.177.173.35 port 23077 [preauth] Dec 19 04:44:34 Claimco sshd[953]: Connection from 61.177.172.114 port 46274 on 192.168.1.233 port 22 rdomain "" Dec 19 04:44:35 Claimco sshd[953]: Received disconnect from 61.177.172.114 port 46274:11: [preauth] Dec 19 04:44:35 Claimco sshd[953]: Disconnected from 61.177.172.114 port 46274 [preauth] Dec 19 04:45:12 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 04:50:14 Claimco sshd[2512]: Connection from 61.177.173.46 port 54043 on 192.168.1.233 port 22 rdomain "" Dec 19 04:50:15 Claimco sshd[2512]: Received disconnect from 61.177.173.46 port 54043:11: [preauth] Dec 19 04:50:15 Claimco sshd[2512]: Disconnected from 61.177.173.46 port 54043 [preauth] Dec 19 04:50:39 Claimco sshd[2594]: Connection from 61.177.173.37 port 61262 on 192.168.1.233 port 22 rdomain "" Dec 19 04:50:40 Claimco sshd[2594]: Received disconnect from 61.177.173.37 port 61262:11: [preauth] Dec 19 04:50:40 Claimco sshd[2594]: Disconnected from 61.177.173.37 port 61262 [preauth] Dec 19 04:51:20 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 04:51:30 Claimco sshd[2803]: Connection from 133.242.181.16 port 50192 on 192.168.1.233 port 22 rdomain "" Dec 19 04:51:30 Claimco sshd[2803]: error: kex_exchange_identification: Connection closed by remote host Dec 19 04:51:30 Claimco sshd[2803]: Connection closed by 133.242.181.16 port 50192 Dec 19 04:53:26 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 04:55:41 Claimco sshd[3739]: Connection from 61.177.173.48 port 35095 on 192.168.1.233 port 22 rdomain "" Dec 19 04:55:42 Claimco sshd[3739]: Received disconnect from 61.177.173.48 port 35095:11: [preauth] Dec 19 04:55:42 Claimco sshd[3739]: Disconnected from 61.177.173.48 port 35095 [preauth] Dec 19 04:57:42 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 04:57:44 Claimco sshd[4386]: Connection from 61.177.172.114 port 14108 on 192.168.1.233 port 22 rdomain "" Dec 19 04:57:45 Claimco sshd[4386]: Received disconnect from 61.177.172.114 port 14108:11: [preauth] Dec 19 04:57:45 Claimco sshd[4386]: Disconnected from 61.177.172.114 port 14108 [preauth] Dec 19 04:59:43 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 05:00:01 Claimco Recycle Bin: Scheduled: Files older than 7 days have been removed Dec 19 05:00:47 Claimco sshd[5107]: Connection from 61.177.173.53 port 23997 on 192.168.1.233 port 22 rdomain "" Dec 19 05:00:48 Claimco sshd[5107]: Received disconnect from 61.177.173.53 port 23997:11: [preauth] Dec 19 05:00:48 Claimco sshd[5107]: Disconnected from 61.177.173.53 port 23997 [preauth] Dec 19 05:01:47 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 05:04:31 Claimco sshd[5938]: Connection from 61.177.172.61 port 24652 on 192.168.1.233 port 22 rdomain "" Dec 19 05:05:58 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 05:06:31 Claimco sshd[5938]: fatal: Timeout before authentication for 61.177.172.61 port 24652 Dec 19 05:06:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 05:08:01 Claimco sshd[6940]: Connection from 61.177.173.47 port 63744 on 192.168.1.233 port 22 rdomain "" Dec 19 05:08:02 Claimco sshd[6940]: Received disconnect from 61.177.173.47 port 63744:11: [preauth] Dec 19 05:08:02 Claimco sshd[6940]: Disconnected from 61.177.173.47 port 63744 [preauth] Dec 19 05:08:05 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 05:11:10 Claimco sshd[7814]: Connection from 61.177.173.49 port 43440 on 192.168.1.233 port 22 rdomain "" Dec 19 05:11:11 Claimco sshd[7814]: Received disconnect from 61.177.173.49 port 43440:11: [preauth] Dec 19 05:11:11 Claimco sshd[7814]: Disconnected from 61.177.173.49 port 43440 [preauth] Dec 19 05:12:08 Claimco sshd[8094]: Connection from 61.177.172.108 port 39589 on 192.168.1.233 port 22 rdomain "" Dec 19 05:12:10 Claimco sshd[8094]: Received disconnect from 61.177.172.108 port 39589:11: [preauth] Dec 19 05:12:10 Claimco sshd[8094]: Disconnected from 61.177.172.108 port 39589 [preauth] Dec 19 05:12:11 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 19 05:20:21 Claimco sshd[10163]: Connection from 61.177.173.35 port 61159 on 192.168.1.233 port 22 rdomain "" Dec 19 05:20:22 Claimco sshd[10163]: Received disconnect from 61.177.173.35 port 61159:11: [preauth] Dec 19 05:20:22 Claimco sshd[10163]: Disconnected from 61.177.173.35 port 61159 [preauth] Dec 19 05:20:30 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 05:21:29 Claimco sshd[10398]: Connection from 61.177.173.53 port 25626 on 192.168.1.233 port 22 rdomain "" Dec 19 05:21:30 Claimco sshd[10398]: Received disconnect from 61.177.173.53 port 25626:11: [preauth] Dec 19 05:21:30 Claimco sshd[10398]: Disconnected from 61.177.173.53 port 25626 [preauth] Dec 19 05:22:38 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 05:26:50 Claimco sshd[11778]: Connection from 61.177.172.19 port 27237 on 192.168.1.233 port 22 rdomain "" Dec 19 05:26:51 Claimco sshd[11778]: Received disconnect from 61.177.172.19 port 27237:11: [preauth] Dec 19 05:26:51 Claimco sshd[11778]: Disconnected from 61.177.172.19 port 27237 [preauth] Dec 19 05:26:56 Claimco sshd[11816]: Connection from 218.92.0.221 port 35423 on 192.168.1.233 port 22 rdomain "" Dec 19 05:26:57 Claimco sshd[11816]: Received disconnect from 218.92.0.221 port 35423:11: [preauth] Dec 19 05:26:57 Claimco sshd[11816]: Disconnected from 218.92.0.221 port 35423 [preauth] Dec 19 05:28:56 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 05:32:22 Claimco sshd[13057]: Connection from 61.177.173.46 port 28320 on 192.168.1.233 port 22 rdomain "" Dec 19 05:32:23 Claimco sshd[13057]: Received disconnect from 61.177.173.46 port 28320:11: [preauth] Dec 19 05:32:23 Claimco sshd[13057]: Disconnected from 61.177.173.46 port 28320 [preauth] Dec 19 05:32:56 Claimco sshd[13157]: Connection from 162.218.126.136 port 52002 on 192.168.1.233 port 22 rdomain "" Dec 19 05:32:56 Claimco sshd[13157]: Invalid user fuying from 162.218.126.136 port 52002 Dec 19 05:32:56 Claimco sshd[13157]: pam_unix(sshd:auth): check pass; user unknown Dec 19 05:32:56 Claimco sshd[13157]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=162.218.126.136 Dec 19 05:32:58 Claimco sshd[13157]: Failed password for invalid user fuying from 162.218.126.136 port 52002 ssh2 Dec 19 05:32:59 Claimco sshd[13157]: Connection closed by invalid user fuying 162.218.126.136 port 52002 [preauth] Dec 19 05:32:59 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 05:33:08 Claimco sshd[13241]: Connection from 61.177.173.39 port 58434 on 192.168.1.233 port 22 rdomain "" Dec 19 05:33:09 Claimco sshd[13241]: Received disconnect from 61.177.173.39 port 58434:11: [preauth] Dec 19 05:33:09 Claimco sshd[13241]: Disconnected from 61.177.173.39 port 58434 [preauth] Dec 19 05:33:40 Claimco sshd[13366]: Connection from 61.177.172.61 port 45534 on 192.168.1.233 port 22 rdomain "" Dec 19 05:33:40 Claimco sshd[13366]: Unable to negotiate with 61.177.172.61 port 45534: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 05:35:06 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 4 TIMES] ### Dec 19 05:38:40 Claimco sshd[14685]: Connection from 153.127.68.158 port 49455 on 192.168.1.233 port 22 rdomain "" Dec 19 05:38:40 Claimco sshd[14685]: error: kex_exchange_identification: Connection closed by remote host Dec 19 05:38:40 Claimco sshd[14685]: Connection closed by 153.127.68.158 port 49455 Dec 19 05:39:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 05:39:40 Claimco sshd[14895]: Connection from 84.110.99.202 port 46602 on 192.168.1.233 port 22 rdomain "" Dec 19 05:39:41 Claimco sshd[14895]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=84.110.99.202 user=root Dec 19 05:39:44 Claimco sshd[14895]: Failed password for root from 84.110.99.202 port 46602 ssh2 Dec 19 05:39:46 Claimco sshd[14895]: Connection closed by authenticating user root 84.110.99.202 port 46602 [preauth] Dec 19 05:40:12 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 05:40:56 Claimco sshd[15210]: Connection from 61.177.173.37 port 38312 on 192.168.1.233 port 22 rdomain "" Dec 19 05:40:57 Claimco sshd[15210]: Received disconnect from 61.177.173.37 port 38312:11: [preauth] Dec 19 05:40:57 Claimco sshd[15210]: Disconnected from 61.177.173.37 port 38312 [preauth] Dec 19 05:41:25 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 05:41:48 Claimco sshd[15379]: Connection from 61.177.172.114 port 40583 on 192.168.1.233 port 22 rdomain "" Dec 19 05:41:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 05:41:49 Claimco sshd[15379]: Received disconnect from 61.177.172.114 port 40583:11: [preauth] Dec 19 05:41:49 Claimco sshd[15379]: Disconnected from 61.177.172.114 port 40583 [preauth] Dec 19 05:42:53 Claimco sshd[15642]: Connection from 61.177.173.53 port 58698 on 192.168.1.233 port 22 rdomain "" Dec 19 05:42:54 Claimco sshd[15642]: Received disconnect from 61.177.173.53 port 58698:11: [preauth] Dec 19 05:42:54 Claimco sshd[15642]: Disconnected from 61.177.173.53 port 58698 [preauth] Dec 19 05:43:25 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 05:45:50 Claimco sshd[16331]: Connection from 61.177.173.47 port 54669 on 192.168.1.233 port 22 rdomain "" Dec 19 05:45:51 Claimco sshd[16331]: Received disconnect from 61.177.173.47 port 54669:11: [preauth] Dec 19 05:45:51 Claimco sshd[16331]: Disconnected from 61.177.173.47 port 54669 [preauth] Dec 19 05:47:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 19 05:54:39 Claimco sshd[18510]: Connection from 61.177.173.52 port 27751 on 192.168.1.233 port 22 rdomain "" Dec 19 05:54:40 Claimco sshd[18510]: Received disconnect from 61.177.173.52 port 27751:11: [preauth] Dec 19 05:54:40 Claimco sshd[18510]: Disconnected from 61.177.173.52 port 27751 [preauth] Dec 19 05:56:02 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 05:56:47 Claimco sshd[19217]: Connection from 61.177.172.114 port 28667 on 192.168.1.233 port 22 rdomain "" Dec 19 05:56:49 Claimco sshd[19217]: Received disconnect from 61.177.172.114 port 28667:11: [preauth] Dec 19 05:56:49 Claimco sshd[19217]: Disconnected from 61.177.172.114 port 28667 [preauth] Dec 19 05:58:00 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 05:59:06 Claimco sshd[19752]: Connection from 61.177.173.48 port 19186 on 192.168.1.233 port 22 rdomain "" Dec 19 05:59:07 Claimco sshd[19752]: Received disconnect from 61.177.173.48 port 19186:11: [preauth] Dec 19 05:59:07 Claimco sshd[19752]: Disconnected from 61.177.173.48 port 19186 [preauth] Dec 19 06:00:11 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 06:00:44 Claimco sshd[20117]: Connection from 130.61.28.220 port 20761 on 192.168.1.233 port 22 rdomain "" Dec 19 06:00:45 Claimco sshd[20117]: Unable to negotiate with 130.61.28.220 port 20761: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1 [preauth] Dec 19 06:02:09 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 06:03:21 Claimco sshd[20687]: Connection from 61.177.173.55 port 33258 on 192.168.1.233 port 22 rdomain "" Dec 19 06:03:21 Claimco sshd[20687]: Unable to negotiate with 61.177.173.55 port 33258: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 06:04:16 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 19 06:08:02 Claimco sshd[21965]: Connection from 61.177.173.46 port 45561 on 192.168.1.233 port 22 rdomain "" Dec 19 06:08:03 Claimco sshd[21965]: Received disconnect from 61.177.173.46 port 45561:11: [preauth] Dec 19 06:08:03 Claimco sshd[21965]: Disconnected from 61.177.173.46 port 45561 [preauth] Dec 19 06:08:24 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 06:08:49 Claimco sshd[22144]: Connection from 61.177.172.104 port 23675 on 192.168.1.233 port 22 rdomain "" Dec 19 06:08:50 Claimco sshd[22144]: Received disconnect from 61.177.172.104 port 23675:11: [preauth] Dec 19 06:08:50 Claimco sshd[22144]: Disconnected from 61.177.172.104 port 23675 [preauth] Dec 19 06:10:29 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 06:11:41 Claimco sshd[22780]: Connection from 61.177.173.35 port 39511 on 192.168.1.233 port 22 rdomain "" Dec 19 06:11:41 Claimco sshd[22782]: Connection from 61.177.172.19 port 60132 on 192.168.1.233 port 22 rdomain "" Dec 19 06:11:42 Claimco sshd[22782]: Received disconnect from 61.177.172.19 port 60132:11: [preauth] Dec 19 06:11:42 Claimco sshd[22782]: Disconnected from 61.177.172.19 port 60132 [preauth] Dec 19 06:11:42 Claimco sshd[22780]: Received disconnect from 61.177.173.35 port 39511:11: [preauth] Dec 19 06:11:42 Claimco sshd[22780]: Disconnected from 61.177.173.35 port 39511 [preauth] Dec 19 06:12:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 06:12:59 Claimco nginx: 2022/12/19 06:12:59 [crit] 6648#6648: *35216 SSL_do_handshake() failed (SSL: error:141CF06C:SSL routines:tls_parse_ctos_key_share:bad key share) while SSL handshaking, client: 212.102.40.218, server: 0.0.0.0:443 Dec 19 06:14:43 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 06:14:51 Claimco sshd[23500]: Connection from 61.177.173.50 port 55247 on 192.168.1.233 port 22 rdomain "" Dec 19 06:14:52 Claimco sshd[23500]: Received disconnect from 61.177.173.50 port 55247:11: [preauth] Dec 19 06:14:52 Claimco sshd[23500]: Disconnected from 61.177.173.50 port 55247 [preauth] Dec 19 06:16:50 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 06:17:26 Claimco sshd[24311]: Connection from 65.2.28.105 port 36888 on 192.168.1.233 port 22 rdomain "" Dec 19 06:17:27 Claimco sshd[24311]: Invalid user user from 65.2.28.105 port 36888 Dec 19 06:17:27 Claimco sshd[24311]: pam_unix(sshd:auth): check pass; user unknown Dec 19 06:17:27 Claimco sshd[24311]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=65.2.28.105 Dec 19 06:17:29 Claimco sshd[24311]: Failed password for invalid user user from 65.2.28.105 port 36888 ssh2 Dec 19 06:17:30 Claimco sshd[24311]: Connection closed by invalid user user 65.2.28.105 port 36888 [preauth] Dec 19 06:18:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 06:20:13 Claimco sshd[24966]: Connection from 60.251.36.30 port 42326 on 192.168.1.233 port 22 rdomain "" Dec 19 06:20:14 Claimco sshd[24966]: Invalid user jboss from 60.251.36.30 port 42326 Dec 19 06:20:14 Claimco sshd[24966]: pam_unix(sshd:auth): check pass; user unknown Dec 19 06:20:14 Claimco sshd[24966]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=60.251.36.30 Dec 19 06:20:16 Claimco sshd[24966]: Failed password for invalid user jboss from 60.251.36.30 port 42326 ssh2 Dec 19 06:20:18 Claimco sshd[24966]: Connection closed by invalid user jboss 60.251.36.30 port 42326 [preauth] Dec 19 06:20:59 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 06:21:07 Claimco webGUI: Successful login user root from 192.168.1.111 Dec 19 06:22:14 Claimco sshd[27326]: Connection from 61.177.173.37 port 56149 on 192.168.1.233 port 22 rdomain "" Dec 19 06:22:15 Claimco sshd[27326]: Received disconnect from 61.177.173.37 port 56149:11: [preauth] Dec 19 06:22:15 Claimco sshd[27326]: Disconnected from 61.177.173.37 port 56149 [preauth] Dec 19 06:23:01 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 06:23:36 Claimco sshd[29904]: Connection from 92.46.108.20 port 38354 on 192.168.1.233 port 22 rdomain "" Dec 19 06:23:37 Claimco sshd[29904]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=92.46.108.20 user=root Dec 19 06:23:38 Claimco sshd[29904]: Failed password for root from 92.46.108.20 port 38354 ssh2 Dec 19 06:23:39 Claimco sshd[29904]: Connection closed by authenticating user root 92.46.108.20 port 38354 [preauth] Dec 19 06:24:16 Claimco sshd[31388]: Connection from 61.177.173.39 port 27340 on 192.168.1.233 port 22 rdomain "" Dec 19 06:24:17 Claimco sshd[31388]: Received disconnect from 61.177.173.39 port 27340:11: [preauth] Dec 19 06:24:17 Claimco sshd[31388]: Disconnected from 61.177.173.39 port 27340 [preauth] Dec 19 06:24:19 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 06:24:25 Claimco root: plugin: creating: /boot/config/plugins/unassigned.devices/unassigned.devices-2022.12.19.tgz - downloading from URL https://raw.githubusercontent.com/dlandon/unassigned.devices/master/unassigned.devices-2022.12.19.tgz Dec 19 06:24:25 Claimco root: plugin: checking: /boot/config/plugins/unassigned.devices/unassigned.devices-2022.12.19.tgz - MD5 Dec 19 06:24:25 Claimco root: plugin: running: anonymous Dec 19 06:24:26 Claimco root: plugin: creating: /tmp/start_unassigned_devices - from INLINE content Dec 19 06:24:26 Claimco root: plugin: setting: /tmp/start_unassigned_devices - mode to 0770 Dec 19 06:24:26 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices/unassigned.devices.cfg already exists Dec 19 06:24:26 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices/samba_mount.cfg already exists Dec 19 06:24:26 Claimco root: plugin: skipping: /boot/config/plugins/unassigned.devices/iso_mount.cfg already exists Dec 19 06:24:26 Claimco root: plugin: creating: /tmp/unassigned.devices/add-smb - from INLINE content Dec 19 06:24:26 Claimco root: plugin: setting: /tmp/unassigned.devices/add-smb - mode to 0770 Dec 19 06:24:26 Claimco root: plugin: running: anonymous Dec 19 06:24:26 Claimco root: plugin: unassigned.devices.plg updated Dec 19 06:24:28 Claimco flash_backup: adding task: /usr/local/emhttp/plugins/dynamix.my.servers/scripts/UpdateFlashBackup update Dec 19 06:25:06 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 06:26:23 Claimco sshd[2997]: Connection from 61.177.172.19 port 14064 on 192.168.1.233 port 22 rdomain "" Dec 19 06:26:25 Claimco sshd[2997]: Received disconnect from 61.177.172.19 port 14064:11: [preauth] Dec 19 06:26:25 Claimco sshd[2997]: Disconnected from 61.177.172.19 port 14064 [preauth] Dec 19 06:27:08 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 06:32:34 Claimco sshd[13759]: Connection from 61.177.173.43 port 53530 on 192.168.1.233 port 22 rdomain "" Dec 19 06:32:35 Claimco sshd[13759]: Unable to negotiate with 61.177.173.43 port 53530: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 06:33:23 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 06:35:48 Claimco sshd[19084]: Connection from 61.177.173.49 port 13935 on 192.168.1.233 port 22 rdomain "" Dec 19 06:35:49 Claimco sshd[19084]: Received disconnect from 61.177.173.49 port 13935:11: [preauth] Dec 19 06:35:49 Claimco sshd[19084]: Disconnected from 61.177.173.49 port 13935 [preauth] Dec 19 06:36:05 Claimco sshd[19304]: Connection from 218.92.0.221 port 10306 on 192.168.1.233 port 22 rdomain "" Dec 19 06:36:08 Claimco sshd[19304]: Received disconnect from 218.92.0.221 port 10306:11: [preauth] Dec 19 06:36:08 Claimco sshd[19304]: Disconnected from 218.92.0.221 port 10306 [preauth] Dec 19 06:36:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 06:37:06 Claimco sshd[19719]: Connection from 61.177.173.36 port 42610 on 192.168.1.233 port 22 rdomain "" Dec 19 06:37:07 Claimco sshd[19719]: Received disconnect from 61.177.173.36 port 42610:11: [preauth] Dec 19 06:37:07 Claimco sshd[19719]: Disconnected from 61.177.173.36 port 42610 [preauth] Dec 19 06:37:37 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 06:41:30 Claimco sshd[20702]: Connection from 61.177.172.114 port 26183 on 192.168.1.233 port 22 rdomain "" Dec 19 06:41:31 Claimco sshd[20702]: Received disconnect from 61.177.172.114 port 26183:11: [preauth] Dec 19 06:41:31 Claimco sshd[20702]: Disconnected from 61.177.172.114 port 26183 [preauth] Dec 19 06:41:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 4 TIMES] ### Dec 19 06:46:32 Claimco sshd[21861]: Connection from 61.177.173.50 port 28212 on 192.168.1.233 port 22 rdomain "" Dec 19 06:46:33 Claimco sshd[21861]: Received disconnect from 61.177.173.50 port 28212:11: [preauth] Dec 19 06:46:33 Claimco sshd[21861]: Disconnected from 61.177.173.50 port 28212 [preauth] Dec 19 06:48:07 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 06:49:55 Claimco sshd[22810]: Connection from 61.177.173.48 port 24273 on 192.168.1.233 port 22 rdomain "" Dec 19 06:49:56 Claimco sshd[22810]: Received disconnect from 61.177.173.48 port 24273:11: [preauth] Dec 19 06:49:56 Claimco sshd[22810]: Disconnected from 61.177.173.48 port 24273 [preauth] Dec 19 06:50:07 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 06:51:13 Claimco sshd[23136]: Connection from 61.177.173.52 port 64306 on 192.168.1.233 port 22 rdomain "" Dec 19 06:51:14 Claimco sshd[23136]: Received disconnect from 61.177.173.52 port 64306:11: [preauth] Dec 19 06:51:14 Claimco sshd[23136]: Disconnected from 61.177.173.52 port 64306 [preauth] Dec 19 06:52:12 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 06:52:24 Claimco sshd[23398]: Connection from 107.189.14.223 port 39794 on 192.168.1.233 port 22 rdomain "" Dec 19 06:52:24 Claimco sshd[23398]: error: kex_exchange_identification: Connection closed by remote host Dec 19 06:52:24 Claimco sshd[23398]: Connection closed by 107.189.14.223 port 39794 Dec 19 06:53:29 Claimco nginx: 2022/12/19 06:53:29 [crit] 6648#6648: *45129 SSL_do_handshake() failed (SSL: error:141CF06C:SSL routines:tls_parse_ctos_key_share:bad key share) while SSL handshaking, client: 64.62.197.233, server: 0.0.0.0:443 Dec 19 06:53:43 Claimco sshd[23679]: Connection from 188.255.87.214 port 42619 on 192.168.1.233 port 22 rdomain "" Dec 19 06:53:43 Claimco sshd[23679]: Unable to negotiate with 188.255.87.214 port 42619: no matching host key type found. Their offer: ssh-rsa,ssh-dss [preauth] Dec 19 06:54:10 Claimco sshd[23807]: Connection from 64.62.197.58 port 7107 on 192.168.1.233 port 22 rdomain "" Dec 19 06:54:10 Claimco sshd[23807]: Invalid user from 64.62.197.58 port 7107 Dec 19 06:54:14 Claimco sshd[23807]: Connection closed by invalid user 64.62.197.58 port 7107 [preauth] Dec 19 06:54:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 06:56:22 Claimco sshd[24301]: Connection from 61.177.172.98 port 59724 on 192.168.1.233 port 22 rdomain "" Dec 19 06:56:23 Claimco sshd[24301]: Received disconnect from 61.177.172.98 port 59724:11: [preauth] Dec 19 06:56:23 Claimco sshd[24301]: Disconnected from 61.177.172.98 port 59724 [preauth] Dec 19 06:57:38 Claimco sshd[24775]: Connection from 61.177.173.46 port 59621 on 192.168.1.233 port 22 rdomain "" Dec 19 06:57:39 Claimco sshd[24775]: Received disconnect from 61.177.173.46 port 59621:11: [preauth] Dec 19 06:57:39 Claimco sshd[24775]: Disconnected from 61.177.173.46 port 59621 [preauth] Dec 19 06:58:29 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 07:01:10 Claimco sshd[25618]: Connection from 162.218.126.136 port 57202 on 192.168.1.233 port 22 rdomain "" Dec 19 07:01:10 Claimco sshd[25618]: Invalid user user1 from 162.218.126.136 port 57202 Dec 19 07:01:10 Claimco sshd[25618]: pam_unix(sshd:auth): check pass; user unknown Dec 19 07:01:10 Claimco sshd[25618]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=162.218.126.136 Dec 19 07:01:12 Claimco sshd[25618]: Failed password for invalid user user1 from 162.218.126.136 port 57202 ssh2 Dec 19 07:01:13 Claimco sshd[25618]: Connection closed by invalid user user1 162.218.126.136 port 57202 [preauth] Dec 19 07:01:19 Claimco sshd[25653]: Connection from 61.177.172.76 port 31762 on 192.168.1.233 port 22 rdomain "" Dec 19 07:01:19 Claimco sshd[25653]: Unable to negotiate with 61.177.172.76 port 31762: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 07:02:41 Claimco sshd[25941]: Connection from 61.177.173.39 port 24531 on 192.168.1.233 port 22 rdomain "" Dec 19 07:02:42 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:02:42 Claimco sshd[25941]: Received disconnect from 61.177.173.39 port 24531:11: [preauth] Dec 19 07:02:42 Claimco sshd[25941]: Disconnected from 61.177.173.39 port 24531 [preauth] Dec 19 07:04:12 Claimco sshd[26294]: Connection from 61.177.173.37 port 50970 on 192.168.1.233 port 22 rdomain "" Dec 19 07:04:13 Claimco sshd[26294]: Received disconnect from 61.177.173.37 port 50970:11: [preauth] Dec 19 07:04:13 Claimco sshd[26294]: Disconnected from 61.177.173.37 port 50970 [preauth] Dec 19 07:04:45 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 07:09:01 Claimco sshd[27561]: Connection from 61.177.173.53 port 13699 on 192.168.1.233 port 22 rdomain "" Dec 19 07:09:02 Claimco sshd[27561]: Received disconnect from 61.177.173.53 port 13699:11: [preauth] Dec 19 07:09:02 Claimco sshd[27561]: Disconnected from 61.177.173.53 port 13699 [preauth] Dec 19 07:10:56 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:11:15 Claimco sshd[28105]: Connection from 61.177.172.98 port 11798 on 192.168.1.233 port 22 rdomain "" Dec 19 07:11:16 Claimco sshd[28105]: Received disconnect from 61.177.172.98 port 11798:11: [preauth] Dec 19 07:11:16 Claimco sshd[28105]: Disconnected from 61.177.172.98 port 11798 [preauth] Dec 19 07:12:43 Claimco sshd[28405]: Connection from 84.110.99.202 port 33700 on 192.168.1.233 port 22 rdomain "" Dec 19 07:12:44 Claimco sshd[28405]: Invalid user guojinshan from 84.110.99.202 port 33700 Dec 19 07:12:44 Claimco sshd[28405]: pam_unix(sshd:auth): check pass; user unknown Dec 19 07:12:44 Claimco sshd[28405]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=84.110.99.202 Dec 19 07:12:45 Claimco sshd[28405]: Failed password for invalid user guojinshan from 84.110.99.202 port 33700 ssh2 Dec 19 07:12:47 Claimco sshd[28405]: Connection closed by invalid user guojinshan 84.110.99.202 port 33700 [preauth] Dec 19 07:13:04 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 07:15:33 Claimco sshd[29121]: Connection from 61.177.173.39 port 49220 on 192.168.1.233 port 22 rdomain "" Dec 19 07:15:34 Claimco sshd[29121]: Received disconnect from 61.177.173.39 port 49220:11: [preauth] Dec 19 07:15:34 Claimco sshd[29121]: Disconnected from 61.177.173.39 port 49220 [preauth] Dec 19 07:17:10 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:17:51 Claimco sshd[29779]: Connection from 218.92.0.221 port 64754 on 192.168.1.233 port 22 rdomain "" Dec 19 07:17:54 Claimco sshd[29779]: Received disconnect from 218.92.0.221 port 64754:11: [preauth] Dec 19 07:17:54 Claimco sshd[29779]: Disconnected from 218.92.0.221 port 64754 [preauth] Dec 19 07:18:24 Claimco sshd[29907]: Connection from 157.245.98.7 port 49330 on 192.168.1.233 port 22 rdomain "" Dec 19 07:18:34 Claimco sshd[29907]: Connection closed by 157.245.98.7 port 49330 [preauth] Dec 19 07:19:19 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:20:10 Claimco sshd[30366]: Connection from 61.177.173.46 port 20148 on 192.168.1.233 port 22 rdomain "" Dec 19 07:20:11 Claimco sshd[30366]: Received disconnect from 61.177.173.46 port 20148:11: [preauth] Dec 19 07:20:11 Claimco sshd[30366]: Disconnected from 61.177.173.46 port 20148 [preauth] Dec 19 07:20:37 Claimco sshd[30452]: Connection from 61.177.173.2 port 63930 on 192.168.1.233 port 22 rdomain "" Dec 19 07:20:39 Claimco sshd[30452]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:20:41 Claimco sshd[30452]: Failed password for root from 61.177.173.2 port 63930 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 07:20:46 Claimco sshd[30452]: Received disconnect from 61.177.173.2 port 63930:11: [preauth] Dec 19 07:20:46 Claimco sshd[30452]: Disconnected from authenticating user root 61.177.173.2 port 63930 [preauth] Dec 19 07:20:46 Claimco sshd[30452]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:21:23 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:22:33 Claimco sshd[30867]: Connection from 61.177.173.2 port 17872 on 192.168.1.233 port 22 rdomain "" Dec 19 07:23:24 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:24:30 Claimco sshd[31325]: Connection from 61.177.173.2 port 25453 on 192.168.1.233 port 22 rdomain "" Dec 19 07:24:33 Claimco sshd[30867]: fatal: Timeout before authentication for 61.177.173.2 port 17872 Dec 19 07:25:33 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:25:51 Claimco sshd[31621]: Connection from 61.177.172.19 port 50682 on 192.168.1.233 port 22 rdomain "" Dec 19 07:25:53 Claimco sshd[31621]: Received disconnect from 61.177.172.19 port 50682:11: [preauth] Dec 19 07:25:53 Claimco sshd[31621]: Disconnected from 61.177.172.19 port 50682 [preauth] Dec 19 07:26:26 Claimco sshd[31778]: Connection from 61.177.173.2 port 31222 on 192.168.1.233 port 22 rdomain "" Dec 19 07:26:30 Claimco sshd[31325]: fatal: Timeout before authentication for 61.177.173.2 port 25453 Dec 19 07:27:34 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:27:50 Claimco sshd[32243]: Connection from 61.177.173.36 port 30852 on 192.168.1.233 port 22 rdomain "" Dec 19 07:27:51 Claimco sshd[32243]: Received disconnect from 61.177.173.36 port 30852:11: [preauth] Dec 19 07:27:51 Claimco sshd[32243]: Disconnected from 61.177.173.36 port 30852 [preauth] Dec 19 07:28:18 Claimco sshd[32360]: Connection from 61.177.173.2 port 15345 on 192.168.1.233 port 22 rdomain "" Dec 19 07:28:20 Claimco sshd[32365]: Connection from 151.80.220.187 port 40310 on 192.168.1.233 port 22 rdomain "" Dec 19 07:28:21 Claimco sshd[32365]: Invalid user user1 from 151.80.220.187 port 40310 Dec 19 07:28:21 Claimco sshd[32365]: pam_unix(sshd:auth): check pass; user unknown Dec 19 07:28:21 Claimco sshd[32365]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=151.80.220.187 Dec 19 07:28:24 Claimco sshd[32365]: Failed password for invalid user user1 from 151.80.220.187 port 40310 ssh2 Dec 19 07:28:24 Claimco sshd[32365]: Connection closed by invalid user user1 151.80.220.187 port 40310 [preauth] Dec 19 07:28:26 Claimco sshd[31778]: fatal: Timeout before authentication for 61.177.173.2 port 31222 Dec 19 07:29:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:29:55 Claimco sshd[32719]: Connection from 61.177.173.43 port 45156 on 192.168.1.233 port 22 rdomain "" Dec 19 07:30:10 Claimco sshd[392]: Connection from 61.177.173.2 port 49901 on 192.168.1.233 port 22 rdomain "" Dec 19 07:30:12 Claimco sshd[392]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:30:14 Claimco sshd[392]: Failed password for root from 61.177.173.2 port 49901 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 07:30:18 Claimco sshd[32360]: fatal: Timeout before authentication for 61.177.173.2 port 15345 Dec 19 07:30:20 Claimco sshd[392]: Failed password for root from 61.177.173.2 port 49901 ssh2 Dec 19 07:30:22 Claimco sshd[392]: Received disconnect from 61.177.173.2 port 49901:11: [preauth] Dec 19 07:30:22 Claimco sshd[392]: Disconnected from authenticating user root 61.177.173.2 port 49901 [preauth] Dec 19 07:30:22 Claimco sshd[392]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:31:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:31:48 Claimco sshd[719]: Connection from 61.177.173.49 port 18118 on 192.168.1.233 port 22 rdomain "" Dec 19 07:31:50 Claimco sshd[719]: Received disconnect from 61.177.173.49 port 18118:11: [preauth] Dec 19 07:31:50 Claimco sshd[719]: Disconnected from 61.177.173.49 port 18118 [preauth] Dec 19 07:31:55 Claimco sshd[32719]: fatal: Timeout before authentication for 61.177.173.43 port 45156 Dec 19 07:32:00 Claimco sshd[769]: Connection from 61.177.173.2 port 18416 on 192.168.1.233 port 22 rdomain "" Dec 19 07:32:02 Claimco sshd[769]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:32:04 Claimco sshd[769]: Failed password for root from 61.177.173.2 port 18416 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 07:32:09 Claimco sshd[769]: Received disconnect from 61.177.173.2 port 18416:11: [preauth] Dec 19 07:32:09 Claimco sshd[769]: Disconnected from authenticating user root 61.177.173.2 port 18416 [preauth] Dec 19 07:32:09 Claimco sshd[769]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:33:49 Claimco sshd[1216]: Connection from 61.177.173.2 port 34976 on 192.168.1.233 port 22 rdomain "" Dec 19 07:33:50 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:35:26 Claimco sshd[1625]: Connection from 61.177.173.52 port 34895 on 192.168.1.233 port 22 rdomain "" Dec 19 07:35:28 Claimco sshd[1625]: Received disconnect from 61.177.173.52 port 34895:11: [preauth] Dec 19 07:35:28 Claimco sshd[1625]: Disconnected from 61.177.173.52 port 34895 [preauth] Dec 19 07:35:40 Claimco sshd[1685]: Connection from 61.177.173.2 port 14827 on 192.168.1.233 port 22 rdomain "" Dec 19 07:35:43 Claimco sshd[1685]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:35:45 Claimco sshd[1685]: Failed password for root from 61.177.173.2 port 14827 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 07:35:49 Claimco sshd[1216]: fatal: Timeout before authentication for 61.177.173.2 port 34976 Dec 19 07:35:50 Claimco sshd[1685]: Failed password for root from 61.177.173.2 port 14827 ssh2 Dec 19 07:35:52 Claimco sshd[1685]: Received disconnect from 61.177.173.2 port 14827:11: [preauth] Dec 19 07:35:52 Claimco sshd[1685]: Disconnected from authenticating user root 61.177.173.2 port 14827 [preauth] Dec 19 07:35:52 Claimco sshd[1685]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:35:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:37:28 Claimco sshd[2252]: Connection from 61.177.173.2 port 22539 on 192.168.1.233 port 22 rdomain "" Dec 19 07:38:02 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:39:16 Claimco sshd[2690]: Connection from 61.177.173.2 port 44480 on 192.168.1.233 port 22 rdomain "" Dec 19 07:39:17 Claimco sshd[2690]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:39:19 Claimco sshd[2690]: Failed password for root from 61.177.173.2 port 44480 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 07:39:26 Claimco sshd[2690]: Received disconnect from 61.177.173.2 port 44480:11: [preauth] Dec 19 07:39:26 Claimco sshd[2690]: Disconnected from authenticating user root 61.177.173.2 port 44480 [preauth] Dec 19 07:39:26 Claimco sshd[2690]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:39:28 Claimco sshd[2252]: fatal: Timeout before authentication for 61.177.173.2 port 22539 Dec 19 07:40:04 Claimco sshd[2856]: Connection from 61.177.173.48 port 64731 on 192.168.1.233 port 22 rdomain "" Dec 19 07:40:05 Claimco sshd[2856]: Received disconnect from 61.177.173.48 port 64731:11: [preauth] Dec 19 07:40:05 Claimco sshd[2856]: Disconnected from 61.177.173.48 port 64731 [preauth] Dec 19 07:40:12 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:40:41 Claimco sshd[3008]: Connection from 61.177.172.19 port 39015 on 192.168.1.233 port 22 rdomain "" Dec 19 07:40:44 Claimco sshd[3008]: Received disconnect from 61.177.172.19 port 39015:11: [preauth] Dec 19 07:40:44 Claimco sshd[3008]: Disconnected from 61.177.172.19 port 39015 [preauth] Dec 19 07:40:51 Claimco sshd[3053]: Connection from 61.177.173.2 port 62517 on 192.168.1.233 port 22 rdomain "" Dec 19 07:40:52 Claimco sshd[3053]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:40:54 Claimco sshd[3053]: Failed password for root from 61.177.173.2 port 62517 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 07:41:03 Claimco sshd[3053]: Received disconnect from 61.177.173.2 port 62517:11: [preauth] Dec 19 07:41:03 Claimco sshd[3053]: Disconnected from authenticating user root 61.177.173.2 port 62517 [preauth] Dec 19 07:41:03 Claimco sshd[3053]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:41:47 Claimco sshd[3233]: Connection from 61.177.173.49 port 49257 on 192.168.1.233 port 22 rdomain "" Dec 19 07:41:48 Claimco sshd[3233]: Received disconnect from 61.177.173.49 port 49257:11: [preauth] Dec 19 07:41:48 Claimco sshd[3233]: Disconnected from 61.177.173.49 port 49257 [preauth] Dec 19 07:41:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 07:42:29 Claimco sshd[3402]: Connection from 61.177.173.2 port 23194 on 192.168.1.233 port 22 rdomain "" Dec 19 07:42:31 Claimco sshd[3402]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:42:33 Claimco sshd[3402]: Failed password for root from 61.177.173.2 port 23194 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 07:42:40 Claimco sshd[3402]: Received disconnect from 61.177.173.2 port 23194:11: [preauth] Dec 19 07:42:40 Claimco sshd[3402]: Disconnected from authenticating user root 61.177.173.2 port 23194 [preauth] Dec 19 07:42:40 Claimco sshd[3402]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:43:26 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:44:10 Claimco sshd[3804]: Connection from 61.177.173.2 port 36633 on 192.168.1.233 port 22 rdomain "" Dec 19 07:44:12 Claimco sshd[3804]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:44:14 Claimco sshd[3804]: Failed password for root from 61.177.173.2 port 36633 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 07:44:17 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:44:19 Claimco sshd[3804]: Failed password for root from 61.177.173.2 port 36633 ssh2 Dec 19 07:44:21 Claimco sshd[3804]: Received disconnect from 61.177.173.2 port 36633:11: [preauth] Dec 19 07:44:21 Claimco sshd[3804]: Disconnected from authenticating user root 61.177.173.2 port 36633 [preauth] Dec 19 07:44:21 Claimco sshd[3804]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:45:52 Claimco sshd[4193]: Connection from 61.177.173.2 port 56898 on 192.168.1.233 port 22 rdomain "" Dec 19 07:46:19 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:46:50 Claimco sshd[4401]: Connection from 61.177.173.52 port 34532 on 192.168.1.233 port 22 rdomain "" Dec 19 07:46:52 Claimco sshd[4401]: Received disconnect from 61.177.173.52 port 34532:11: [preauth] Dec 19 07:46:52 Claimco sshd[4401]: Disconnected from 61.177.173.52 port 34532 [preauth] Dec 19 07:46:55 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:47:40 Claimco sshd[4795]: Connection from 61.177.173.2 port 64796 on 192.168.1.233 port 22 rdomain "" Dec 19 07:47:52 Claimco sshd[4193]: fatal: Timeout before authentication for 61.177.173.2 port 56898 Dec 19 07:48:29 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:49:27 Claimco sshd[5204]: Connection from 61.177.173.2 port 58700 on 192.168.1.233 port 22 rdomain "" Dec 19 07:49:29 Claimco sshd[5204]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:49:31 Claimco sshd[5204]: Failed password for root from 61.177.173.2 port 58700 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 07:49:39 Claimco sshd[5204]: Received disconnect from 61.177.173.2 port 58700:11: [preauth] Dec 19 07:49:39 Claimco sshd[5204]: Disconnected from authenticating user root 61.177.173.2 port 58700 [preauth] Dec 19 07:49:39 Claimco sshd[5204]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:49:40 Claimco sshd[4795]: fatal: Timeout before authentication for 61.177.173.2 port 64796 Dec 19 07:50:31 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:51:17 Claimco sshd[5651]: Connection from 61.177.173.2 port 23489 on 192.168.1.233 port 22 rdomain "" Dec 19 07:52:22 Claimco sshd[5871]: Connection from 61.177.173.47 port 36206 on 192.168.1.233 port 22 rdomain "" Dec 19 07:52:23 Claimco sshd[5871]: Received disconnect from 61.177.173.47 port 36206:11: [preauth] Dec 19 07:52:23 Claimco sshd[5871]: Disconnected from 61.177.173.47 port 36206 [preauth] Dec 19 07:52:31 Claimco sshd[5896]: Connection from 61.177.173.46 port 56797 on 192.168.1.233 port 22 rdomain "" Dec 19 07:52:32 Claimco sshd[5896]: Received disconnect from 61.177.173.46 port 56797:11: [preauth] Dec 19 07:52:32 Claimco sshd[5896]: Disconnected from 61.177.173.46 port 56797 [preauth] Dec 19 07:52:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:53:08 Claimco sshd[6034]: Connection from 61.177.173.2 port 50989 on 192.168.1.233 port 22 rdomain "" Dec 19 07:53:17 Claimco sshd[5651]: fatal: Timeout before authentication for 61.177.173.2 port 23489 Dec 19 07:54:41 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:54:55 Claimco sshd[6449]: Connection from 61.177.173.2 port 43225 on 192.168.1.233 port 22 rdomain "" Dec 19 07:55:08 Claimco sshd[6034]: fatal: Timeout before authentication for 61.177.173.2 port 50989 Dec 19 07:55:45 Claimco sshd[6688]: Connection from 61.177.172.98 port 63092 on 192.168.1.233 port 22 rdomain "" Dec 19 07:55:46 Claimco sshd[6688]: Received disconnect from 61.177.172.98 port 63092:11: [preauth] Dec 19 07:55:46 Claimco sshd[6688]: Disconnected from 61.177.172.98 port 63092 [preauth] Dec 19 07:56:26 Claimco sshd[6834]: Connection from 65.2.28.105 port 60482 on 192.168.1.233 port 22 rdomain "" Dec 19 07:56:27 Claimco sshd[6834]: Invalid user nagios from 65.2.28.105 port 60482 Dec 19 07:56:27 Claimco sshd[6834]: pam_unix(sshd:auth): check pass; user unknown Dec 19 07:56:27 Claimco sshd[6834]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=65.2.28.105 Dec 19 07:56:29 Claimco sshd[6834]: Failed password for invalid user nagios from 65.2.28.105 port 60482 ssh2 Dec 19 07:56:30 Claimco sshd[6834]: Connection closed by invalid user nagios 65.2.28.105 port 60482 [preauth] Dec 19 07:56:42 Claimco sshd[6900]: Connection from 61.177.173.2 port 51154 on 192.168.1.233 port 22 rdomain "" Dec 19 07:56:43 Claimco sshd[6900]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:56:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:56:46 Claimco sshd[6900]: Failed password for root from 61.177.173.2 port 51154 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 07:56:51 Claimco sshd[6900]: Received disconnect from 61.177.173.2 port 51154:11: [preauth] Dec 19 07:56:51 Claimco sshd[6900]: Disconnected from authenticating user root 61.177.173.2 port 51154 [preauth] Dec 19 07:56:51 Claimco sshd[6900]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:56:55 Claimco sshd[6449]: fatal: Timeout before authentication for 61.177.173.2 port 43225 Dec 19 07:58:19 Claimco sshd[7576]: Connection from 61.177.173.2 port 38752 on 192.168.1.233 port 22 rdomain "" Dec 19 07:58:20 Claimco sshd[7576]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:58:22 Claimco sshd[7576]: Failed password for root from 61.177.173.2 port 38752 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 07:58:30 Claimco sshd[7576]: Received disconnect from 61.177.173.2 port 38752:11: [preauth] Dec 19 07:58:30 Claimco sshd[7576]: Disconnected from authenticating user root 61.177.173.2 port 38752 [preauth] Dec 19 07:58:30 Claimco sshd[7576]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 07:58:33 Claimco sshd[7617]: Connection from 61.177.173.55 port 1634 on 192.168.1.233 port 22 rdomain "" Dec 19 07:58:33 Claimco sshd[7617]: Unable to negotiate with 61.177.173.55 port 1634: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 07:58:57 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 07:59:56 Claimco sshd[7998]: Connection from 61.177.172.104 port 29874 on 192.168.1.233 port 22 rdomain "" Dec 19 07:59:57 Claimco sshd[7998]: Received disconnect from 61.177.172.104 port 29874:11: [preauth] Dec 19 07:59:57 Claimco sshd[7998]: Disconnected from 61.177.172.104 port 29874 [preauth] Dec 19 08:00:05 Claimco sshd[8055]: Connection from 61.177.173.2 port 26798 on 192.168.1.233 port 22 rdomain "" Dec 19 08:00:56 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:01:50 Claimco sshd[8437]: Connection from 61.177.173.2 port 14324 on 192.168.1.233 port 22 rdomain "" Dec 19 08:02:05 Claimco sshd[8055]: fatal: Timeout before authentication for 61.177.173.2 port 26798 Dec 19 08:03:01 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:03:35 Claimco sshd[8857]: Connection from 61.177.173.2 port 61237 on 192.168.1.233 port 22 rdomain "" Dec 19 08:03:50 Claimco sshd[8437]: fatal: Timeout before authentication for 61.177.173.2 port 14324 Dec 19 08:04:22 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 19 08:05:17 Claimco sshd[9438]: Connection from 61.177.173.2 port 28557 on 192.168.1.233 port 22 rdomain "" Dec 19 08:05:35 Claimco sshd[8857]: fatal: Timeout before authentication for 61.177.173.2 port 61237 Dec 19 08:06:43 Claimco sshd[10006]: Connection from 61.177.173.48 port 60654 on 192.168.1.233 port 22 rdomain "" Dec 19 08:06:44 Claimco sshd[10006]: Received disconnect from 61.177.173.48 port 60654:11: [preauth] Dec 19 08:06:44 Claimco sshd[10006]: Disconnected from 61.177.173.48 port 60654 [preauth] Dec 19 08:07:03 Claimco sshd[10417]: Connection from 61.177.173.2 port 25557 on 192.168.1.233 port 22 rdomain "" Dec 19 08:07:09 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:07:17 Claimco sshd[9438]: fatal: Timeout before authentication for 61.177.173.2 port 28557 Dec 19 08:08:49 Claimco sshd[11104]: Connection from 61.177.173.2 port 14815 on 192.168.1.233 port 22 rdomain "" Dec 19 08:08:51 Claimco sshd[11104]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:08:53 Claimco sshd[11104]: Failed password for root from 61.177.173.2 port 14815 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 08:09:00 Claimco sshd[11104]: Received disconnect from 61.177.173.2 port 14815:11: [preauth] Dec 19 08:09:00 Claimco sshd[11104]: Disconnected from authenticating user root 61.177.173.2 port 14815 [preauth] Dec 19 08:09:00 Claimco sshd[11104]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:09:03 Claimco sshd[10417]: fatal: Timeout before authentication for 61.177.173.2 port 25557 Dec 19 08:09:21 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:10:33 Claimco sshd[11917]: Connection from 61.177.173.2 port 49280 on 192.168.1.233 port 22 rdomain "" Dec 19 08:10:35 Claimco sshd[11917]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:10:38 Claimco sshd[11917]: Failed password for root from 61.177.173.2 port 49280 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 08:10:45 Claimco sshd[11917]: Received disconnect from 61.177.173.2 port 49280:11: [preauth] Dec 19 08:10:45 Claimco sshd[11917]: Disconnected from authenticating user root 61.177.173.2 port 49280 [preauth] Dec 19 08:10:45 Claimco sshd[11917]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:11:26 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:12:19 Claimco sshd[12634]: Connection from 61.177.173.2 port 42288 on 192.168.1.233 port 22 rdomain "" Dec 19 08:12:21 Claimco sshd[12634]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:12:23 Claimco sshd[12634]: Failed password for root from 61.177.173.2 port 42288 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 08:12:33 Claimco sshd[12634]: Received disconnect from 61.177.173.2 port 42288:11: [preauth] Dec 19 08:12:33 Claimco sshd[12634]: Disconnected from authenticating user root 61.177.173.2 port 42288 [preauth] Dec 19 08:12:33 Claimco sshd[12634]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:13:30 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:14:03 Claimco sshd[13429]: Connection from 61.177.173.2 port 14790 on 192.168.1.233 port 22 rdomain "" Dec 19 08:15:30 Claimco sshd[13938]: Connection from 61.177.173.50 port 24188 on 192.168.1.233 port 22 rdomain "" Dec 19 08:15:32 Claimco sshd[13938]: Received disconnect from 61.177.173.50 port 24188:11: [preauth] Dec 19 08:15:32 Claimco sshd[13938]: Disconnected from 61.177.173.50 port 24188 [preauth] Dec 19 08:15:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:15:46 Claimco sshd[13970]: Connection from 61.177.173.2 port 36539 on 192.168.1.233 port 22 rdomain "" Dec 19 08:15:48 Claimco sshd[13970]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:15:50 Claimco sshd[13970]: Failed password for root from 61.177.173.2 port 36539 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 08:16:00 Claimco sshd[13970]: Received disconnect from 61.177.173.2 port 36539:11: [preauth] Dec 19 08:16:00 Claimco sshd[13970]: Disconnected from authenticating user root 61.177.173.2 port 36539 [preauth] Dec 19 08:16:00 Claimco sshd[13970]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:16:01 Claimco sshd[14064]: Connection from 61.177.173.35 port 18601 on 192.168.1.233 port 22 rdomain "" Dec 19 08:16:02 Claimco sshd[14064]: Received disconnect from 61.177.173.35 port 18601:11: [preauth] Dec 19 08:16:02 Claimco sshd[14064]: Disconnected from 61.177.173.35 port 18601 [preauth] Dec 19 08:16:03 Claimco sshd[13429]: fatal: Timeout before authentication for 61.177.173.2 port 14790 Dec 19 08:17:31 Claimco sshd[14567]: Connection from 61.177.173.2 port 23167 on 192.168.1.233 port 22 rdomain "" Dec 19 08:17:38 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:19:16 Claimco sshd[14970]: Connection from 61.177.173.2 port 13063 on 192.168.1.233 port 22 rdomain "" Dec 19 08:19:18 Claimco sshd[14970]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:19:21 Claimco sshd[14970]: Failed password for root from 61.177.173.2 port 13063 ssh2 Dec 19 08:19:24 Claimco sshd[14989]: Connection from 61.177.173.52 port 12444 on 192.168.1.233 port 22 rdomain "" Dec 19 08:19:25 Claimco sshd[14989]: Received disconnect from 61.177.173.52 port 12444:11: [preauth] Dec 19 08:19:25 Claimco sshd[14989]: Disconnected from 61.177.173.52 port 12444 [preauth] Dec 19 08:19:25 Claimco sshd[14970]: Failed password for root from 61.177.173.2 port 13063 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 08:19:27 Claimco sshd[14970]: Received disconnect from 61.177.173.2 port 13063:11: [preauth] Dec 19 08:19:27 Claimco sshd[14970]: Disconnected from authenticating user root 61.177.173.2 port 13063 [preauth] Dec 19 08:19:27 Claimco sshd[14970]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:19:31 Claimco sshd[14567]: fatal: Timeout before authentication for 61.177.173.2 port 23167 Dec 19 08:19:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:21:01 Claimco sshd[15411]: Connection from 61.177.173.2 port 55420 on 192.168.1.233 port 22 rdomain "" Dec 19 08:21:27 Claimco sshd[15463]: Connection from 61.177.172.124 port 29302 on 192.168.1.233 port 22 rdomain "" Dec 19 08:21:28 Claimco sshd[15463]: Received disconnect from 61.177.172.124 port 29302:11: [preauth] Dec 19 08:21:28 Claimco sshd[15463]: Disconnected from 61.177.172.124 port 29302 [preauth] Dec 19 08:21:50 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:22:44 Claimco sshd[15739]: Connection from 61.177.173.2 port 19794 on 192.168.1.233 port 22 rdomain "" Dec 19 08:22:46 Claimco sshd[15739]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:22:48 Claimco sshd[15739]: Failed password for root from 61.177.173.2 port 19794 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 08:22:55 Claimco sshd[15739]: Received disconnect from 61.177.173.2 port 19794:11: [preauth] Dec 19 08:22:55 Claimco sshd[15739]: Disconnected from authenticating user root 61.177.173.2 port 19794 [preauth] Dec 19 08:22:55 Claimco sshd[15739]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:23:01 Claimco sshd[15411]: fatal: Timeout before authentication for 61.177.173.2 port 55420 Dec 19 08:23:24 Claimco sshd[15881]: Connection from 61.177.173.50 port 30371 on 192.168.1.233 port 22 rdomain "" Dec 19 08:23:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:24:30 Claimco sshd[16130]: Connection from 61.177.173.2 port 64311 on 192.168.1.233 port 22 rdomain "" Dec 19 08:24:32 Claimco sshd[16130]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:24:34 Claimco sshd[16130]: Failed password for root from 61.177.173.2 port 64311 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 08:24:41 Claimco sshd[16130]: Received disconnect from 61.177.173.2 port 64311:11: [preauth] Dec 19 08:24:41 Claimco sshd[16130]: Disconnected from authenticating user root 61.177.173.2 port 64311 [preauth] Dec 19 08:24:41 Claimco sshd[16130]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:24:51 Claimco sshd[16221]: Connection from 61.177.173.36 port 40019 on 192.168.1.233 port 22 rdomain "" Dec 19 08:24:53 Claimco sshd[16221]: Received disconnect from 61.177.173.36 port 40019:11: [preauth] Dec 19 08:24:53 Claimco sshd[16221]: Disconnected from 61.177.173.36 port 40019 [preauth] Dec 19 08:25:24 Claimco sshd[15881]: fatal: Timeout before authentication for 61.177.173.50 port 30371 Dec 19 08:25:58 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:26:18 Claimco sshd[16591]: Connection from 61.177.173.2 port 13626 on 192.168.1.233 port 22 rdomain "" Dec 19 08:27:25 Claimco sshd[17018]: Connection from 61.177.173.61 port 9922 on 192.168.1.233 port 22 rdomain "" Dec 19 08:27:26 Claimco sshd[17018]: Unable to negotiate with 61.177.173.61 port 9922: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 08:28:03 Claimco sshd[17161]: Connection from 61.177.173.2 port 44755 on 192.168.1.233 port 22 rdomain "" Dec 19 08:28:05 Claimco sshd[17161]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:28:05 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:28:07 Claimco sshd[17161]: Failed password for root from 61.177.173.2 port 44755 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 08:28:14 Claimco sshd[17161]: Received disconnect from 61.177.173.2 port 44755:11: [preauth] Dec 19 08:28:14 Claimco sshd[17161]: Disconnected from authenticating user root 61.177.173.2 port 44755 [preauth] Dec 19 08:28:14 Claimco sshd[17161]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:28:18 Claimco sshd[16591]: fatal: Timeout before authentication for 61.177.173.2 port 13626 Dec 19 08:28:28 Claimco sshd[17237]: Connection from 116.193.159.2 port 57574 on 192.168.1.233 port 22 rdomain "" Dec 19 08:28:28 Claimco sshd[17237]: Received disconnect from 116.193.159.2 port 57574:11: Bye Bye [preauth] Dec 19 08:28:28 Claimco sshd[17237]: Disconnected from 116.193.159.2 port 57574 [preauth] Dec 19 08:29:48 Claimco sshd[17545]: Connection from 61.177.173.2 port 29281 on 192.168.1.233 port 22 rdomain "" Dec 19 08:29:50 Claimco sshd[17545]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:29:52 Claimco sshd[17545]: Failed password for root from 61.177.173.2 port 29281 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 08:30:00 Claimco sshd[17545]: Received disconnect from 61.177.173.2 port 29281:11: [preauth] Dec 19 08:30:00 Claimco sshd[17545]: Disconnected from authenticating user root 61.177.173.2 port 29281 [preauth] Dec 19 08:30:00 Claimco sshd[17545]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:30:05 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:31:06 Claimco sshd[17890]: Connection from 218.92.0.221 port 42365 on 192.168.1.233 port 22 rdomain "" Dec 19 08:31:09 Claimco sshd[17890]: Received disconnect from 218.92.0.221 port 42365:11: [preauth] Dec 19 08:31:09 Claimco sshd[17890]: Disconnected from 218.92.0.221 port 42365 [preauth] Dec 19 08:31:28 Claimco sshd[17962]: Connection from 61.177.173.51 port 11962 on 192.168.1.233 port 22 rdomain "" Dec 19 08:31:37 Claimco sshd[17985]: Connection from 61.177.173.2 port 45961 on 192.168.1.233 port 22 rdomain "" Dec 19 08:32:17 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:32:38 Claimco sshd[18199]: Connection from 59.173.241.166 port 3252 on 192.168.1.233 port 22 rdomain "" Dec 19 08:32:38 Claimco sshd[18199]: Unable to negotiate with 59.173.241.166 port 3252: no matching host key type found. Their offer: ssh-rsa,ssh-dss [preauth] Dec 19 08:32:39 Claimco sshd[18201]: Connection from 162.218.126.136 port 42084 on 192.168.1.233 port 22 rdomain "" Dec 19 08:32:39 Claimco sshd[18201]: Invalid user lhy from 162.218.126.136 port 42084 Dec 19 08:32:39 Claimco sshd[18201]: pam_unix(sshd:auth): check pass; user unknown Dec 19 08:32:39 Claimco sshd[18201]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=162.218.126.136 Dec 19 08:32:41 Claimco sshd[18201]: Failed password for invalid user lhy from 162.218.126.136 port 42084 ssh2 Dec 19 08:32:42 Claimco sshd[18201]: Connection closed by invalid user lhy 162.218.126.136 port 42084 [preauth] Dec 19 08:33:19 Claimco sshd[18384]: Connection from 61.177.173.2 port 58426 on 192.168.1.233 port 22 rdomain "" Dec 19 08:33:27 Claimco sshd[18401]: Connection from 141.98.11.30 port 54218 on 192.168.1.233 port 22 rdomain "" Dec 19 08:33:27 Claimco sshd[18401]: error: kex_exchange_identification: Connection closed by remote host Dec 19 08:33:27 Claimco sshd[18401]: Connection closed by 141.98.11.30 port 54218 Dec 19 08:33:28 Claimco sshd[17962]: fatal: Timeout before authentication for 61.177.173.51 port 11962 Dec 19 08:33:36 Claimco sshd[18454]: Connection from 141.98.11.30 port 39878 on 192.168.1.233 port 22 rdomain "" Dec 19 08:33:36 Claimco sshd[18454]: Unable to negotiate with 141.98.11.30 port 39878: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 08:33:37 Claimco sshd[17985]: fatal: Timeout before authentication for 61.177.173.2 port 45961 Dec 19 08:33:43 Claimco sshd[18471]: Connection from 141.98.11.30 port 45596 on 192.168.1.233 port 22 rdomain "" Dec 19 08:33:44 Claimco sshd[18471]: Unable to negotiate with 141.98.11.30 port 45596: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 08:33:51 Claimco sshd[18514]: Connection from 141.98.11.30 port 51304 on 192.168.1.233 port 22 rdomain "" Dec 19 08:33:52 Claimco sshd[18514]: Unable to negotiate with 141.98.11.30 port 51304: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 08:34:00 Claimco sshd[18533]: Connection from 141.98.11.30 port 57016 on 192.168.1.233 port 22 rdomain "" Dec 19 08:34:00 Claimco sshd[18533]: Unable to negotiate with 141.98.11.30 port 57016: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 08:34:05 Claimco sshd[18580]: Connection from 61.177.173.39 port 14497 on 192.168.1.233 port 22 rdomain "" Dec 19 08:34:07 Claimco sshd[18580]: Received disconnect from 61.177.173.39 port 14497:11: [preauth] Dec 19 08:34:07 Claimco sshd[18580]: Disconnected from 61.177.173.39 port 14497 [preauth] Dec 19 08:34:08 Claimco sshd[18588]: Connection from 141.98.11.30 port 34500 on 192.168.1.233 port 22 rdomain "" Dec 19 08:34:08 Claimco sshd[18588]: Unable to negotiate with 141.98.11.30 port 34500: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 08:34:17 Claimco sshd[18608]: Connection from 141.98.11.30 port 40214 on 192.168.1.233 port 22 rdomain "" Dec 19 08:34:17 Claimco sshd[18608]: Unable to negotiate with 141.98.11.30 port 40214: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 08:34:17 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:34:25 Claimco sshd[18650]: Connection from 141.98.11.30 port 45928 on 192.168.1.233 port 22 rdomain "" Dec 19 08:34:25 Claimco sshd[18650]: Unable to negotiate with 141.98.11.30 port 45928: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 08:34:34 Claimco sshd[18676]: Connection from 141.98.11.30 port 51640 on 192.168.1.233 port 22 rdomain "" Dec 19 08:34:34 Claimco sshd[18676]: Unable to negotiate with 141.98.11.30 port 51640: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 08:34:43 Claimco sshd[18696]: Connection from 141.98.11.30 port 57354 on 192.168.1.233 port 22 rdomain "" Dec 19 08:34:43 Claimco sshd[18696]: Unable to negotiate with 141.98.11.30 port 57354: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 08:35:06 Claimco sshd[18866]: Connection from 61.177.173.2 port 59342 on 192.168.1.233 port 22 rdomain "" Dec 19 08:35:08 Claimco sshd[18866]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:35:10 Claimco sshd[18866]: Failed password for root from 61.177.173.2 port 59342 ssh2 Dec 19 08:35:12 Claimco sshd[18878]: Connection from 61.177.172.108 port 41451 on 192.168.1.233 port 22 rdomain "" Dec 19 08:35:13 Claimco sshd[18866]: Failed password for root from 61.177.173.2 port 59342 ssh2 Dec 19 08:35:13 Claimco sshd[18878]: Received disconnect from 61.177.172.108 port 41451:11: [preauth] Dec 19 08:35:13 Claimco sshd[18878]: Disconnected from 61.177.172.108 port 41451 [preauth] Dec 19 08:35:15 Claimco sshd[18866]: Failed password for root from 61.177.173.2 port 59342 ssh2 Dec 19 08:35:16 Claimco sshd[18866]: Received disconnect from 61.177.173.2 port 59342:11: [preauth] Dec 19 08:35:16 Claimco sshd[18866]: Disconnected from authenticating user root 61.177.173.2 port 59342 [preauth] Dec 19 08:35:16 Claimco sshd[18866]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:35:19 Claimco sshd[18384]: fatal: Timeout before authentication for 61.177.173.2 port 58426 Dec 19 08:36:13 Claimco sshd[19093]: Connection from 92.255.85.173 port 63771 on 192.168.1.233 port 22 rdomain "" Dec 19 08:36:13 Claimco sshd[19093]: error: kex_exchange_identification: banner line contains invalid characters Dec 19 08:36:13 Claimco sshd[19093]: banner exchange: Connection from 92.255.85.173 port 63771: invalid format Dec 19 08:36:21 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:36:50 Claimco sshd[19198]: Connection from 61.177.173.2 port 36084 on 192.168.1.233 port 22 rdomain "" Dec 19 08:36:53 Claimco sshd[19198]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:36:55 Claimco sshd[19198]: Failed password for root from 61.177.173.2 port 36084 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 08:37:02 Claimco sshd[19198]: Received disconnect from 61.177.173.2 port 36084:11: [preauth] Dec 19 08:37:02 Claimco sshd[19198]: Disconnected from authenticating user root 61.177.173.2 port 36084 [preauth] Dec 19 08:37:02 Claimco sshd[19198]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:38:29 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:38:37 Claimco sshd[19823]: Connection from 61.177.173.2 port 37666 on 192.168.1.233 port 22 rdomain "" Dec 19 08:39:17 Claimco sshd[19961]: Connection from 61.177.173.49 port 54295 on 192.168.1.233 port 22 rdomain "" Dec 19 08:39:18 Claimco sshd[19961]: Received disconnect from 61.177.173.49 port 54295:11: [preauth] Dec 19 08:39:18 Claimco sshd[19961]: Disconnected from 61.177.173.49 port 54295 [preauth] Dec 19 08:40:29 Claimco sshd[20258]: Connection from 61.177.173.2 port 21283 on 192.168.1.233 port 22 rdomain "" Dec 19 08:40:31 Claimco sshd[20258]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:40:32 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:40:33 Claimco sshd[20258]: Failed password for root from 61.177.173.2 port 21283 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 08:40:37 Claimco sshd[19823]: fatal: Timeout before authentication for 61.177.173.2 port 37666 Dec 19 08:40:38 Claimco sshd[20258]: Failed password for root from 61.177.173.2 port 21283 ssh2 Dec 19 08:40:38 Claimco sshd[20258]: Received disconnect from 61.177.173.2 port 21283:11: [preauth] Dec 19 08:40:38 Claimco sshd[20258]: Disconnected from authenticating user root 61.177.173.2 port 21283 [preauth] Dec 19 08:40:38 Claimco sshd[20258]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:41:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:42:08 Claimco sshd[20637]: Connection from 61.177.173.2 port 61735 on 192.168.1.233 port 22 rdomain "" Dec 19 08:42:10 Claimco sshd[20637]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:42:12 Claimco sshd[20637]: Failed password for root from 61.177.173.2 port 61735 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 08:42:17 Claimco sshd[20637]: Received disconnect from 61.177.173.2 port 61735:11: [preauth] Dec 19 08:42:17 Claimco sshd[20637]: Disconnected from authenticating user root 61.177.173.2 port 61735 [preauth] Dec 19 08:42:17 Claimco sshd[20637]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:42:28 Claimco sshd[20680]: Connection from 61.177.172.104 port 43477 on 192.168.1.233 port 22 rdomain "" Dec 19 08:42:29 Claimco sshd[20680]: Received disconnect from 61.177.172.104 port 43477:11: [preauth] Dec 19 08:42:29 Claimco sshd[20680]: Disconnected from 61.177.172.104 port 43477 [preauth] Dec 19 08:42:40 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:42:58 Claimco sshd[20772]: Connection from 61.177.173.35 port 21405 on 192.168.1.233 port 22 rdomain "" Dec 19 08:42:59 Claimco sshd[20772]: Received disconnect from 61.177.173.35 port 21405:11: [preauth] Dec 19 08:42:59 Claimco sshd[20772]: Disconnected from 61.177.173.35 port 21405 [preauth] Dec 19 08:43:55 Claimco sshd[21005]: Connection from 61.177.173.2 port 11914 on 192.168.1.233 port 22 rdomain "" Dec 19 08:44:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:45:16 Claimco sshd[21394]: Connection from 84.110.99.202 port 47108 on 192.168.1.233 port 22 rdomain "" Dec 19 08:45:16 Claimco sshd[21394]: Invalid user user from 84.110.99.202 port 47108 Dec 19 08:45:17 Claimco sshd[21394]: pam_unix(sshd:auth): check pass; user unknown Dec 19 08:45:17 Claimco sshd[21394]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=84.110.99.202 Dec 19 08:45:19 Claimco sshd[21394]: Failed password for invalid user user from 84.110.99.202 port 47108 ssh2 Dec 19 08:45:19 Claimco sshd[21394]: Connection closed by invalid user user 84.110.99.202 port 47108 [preauth] Dec 19 08:45:40 Claimco sshd[21451]: Connection from 61.177.173.2 port 46139 on 192.168.1.233 port 22 rdomain "" Dec 19 08:45:42 Claimco sshd[21451]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:45:44 Claimco sshd[21451]: Failed password for root from 61.177.173.2 port 46139 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 08:45:53 Claimco sshd[21451]: Received disconnect from 61.177.173.2 port 46139:11: [preauth] Dec 19 08:45:53 Claimco sshd[21451]: Disconnected from authenticating user root 61.177.173.2 port 46139 [preauth] Dec 19 08:45:53 Claimco sshd[21451]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:45:55 Claimco sshd[21005]: fatal: Timeout before authentication for 61.177.173.2 port 11914 Dec 19 08:46:00 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 19 08:47:21 Claimco sshd[22087]: Connection from 61.177.173.49 port 51883 on 192.168.1.233 port 22 rdomain "" Dec 19 08:47:22 Claimco sshd[22087]: Received disconnect from 61.177.173.49 port 51883:11: [preauth] Dec 19 08:47:22 Claimco sshd[22087]: Disconnected from 61.177.173.49 port 51883 [preauth] Dec 19 08:47:26 Claimco sshd[22100]: Connection from 61.177.173.2 port 40187 on 192.168.1.233 port 22 rdomain "" Dec 19 08:47:27 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:48:07 Claimco sshd[22412]: Connection from 61.177.172.19 port 57726 on 192.168.1.233 port 22 rdomain "" Dec 19 08:48:08 Claimco sshd[22412]: Received disconnect from 61.177.172.19 port 57726:11: [preauth] Dec 19 08:48:08 Claimco sshd[22412]: Disconnected from 61.177.172.19 port 57726 [preauth] Dec 19 08:48:55 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:49:10 Claimco sshd[22881]: Connection from 61.177.173.2 port 19179 on 192.168.1.233 port 22 rdomain "" Dec 19 08:49:12 Claimco sshd[22881]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:49:14 Claimco sshd[22881]: Failed password for root from 61.177.173.2 port 19179 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 08:49:19 Claimco sshd[22881]: Received disconnect from 61.177.173.2 port 19179:11: [preauth] Dec 19 08:49:19 Claimco sshd[22881]: Disconnected from authenticating user root 61.177.173.2 port 19179 [preauth] Dec 19 08:49:19 Claimco sshd[22881]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:49:26 Claimco sshd[22100]: fatal: Timeout before authentication for 61.177.173.2 port 40187 Dec 19 08:50:56 Claimco sshd[23301]: Connection from 61.177.173.2 port 15525 on 192.168.1.233 port 22 rdomain "" Dec 19 08:50:59 Claimco sshd[23301]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:51:01 Claimco sshd[23301]: Failed password for root from 61.177.173.2 port 15525 ssh2 Dec 19 08:51:02 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:51:05 Claimco sshd[23301]: Failed password for root from 61.177.173.2 port 15525 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 08:51:10 Claimco sshd[23301]: Received disconnect from 61.177.173.2 port 15525:11: [preauth] Dec 19 08:51:10 Claimco sshd[23301]: Disconnected from authenticating user root 61.177.173.2 port 15525 [preauth] Dec 19 08:51:10 Claimco sshd[23301]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:52:00 Claimco sshd[23518]: Connection from 61.177.173.35 port 18386 on 192.168.1.233 port 22 rdomain "" Dec 19 08:52:01 Claimco sshd[23518]: Received disconnect from 61.177.173.35 port 18386:11: [preauth] Dec 19 08:52:01 Claimco sshd[23518]: Disconnected from 61.177.173.35 port 18386 [preauth] Dec 19 08:52:41 Claimco sshd[23667]: Connection from 61.177.173.2 port 47172 on 192.168.1.233 port 22 rdomain "" Dec 19 08:52:59 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:54:25 Claimco sshd[24055]: Connection from 61.177.173.2 port 25564 on 192.168.1.233 port 22 rdomain "" Dec 19 08:54:27 Claimco sshd[24055]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:54:29 Claimco sshd[24055]: Failed password for root from 61.177.173.2 port 25564 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 08:54:33 Claimco sshd[24102]: Connection from 61.177.173.37 port 21445 on 192.168.1.233 port 22 rdomain "" Dec 19 08:54:33 Claimco sshd[24055]: Failed password for root from 61.177.173.2 port 25564 ssh2 Dec 19 08:54:34 Claimco sshd[24102]: Received disconnect from 61.177.173.37 port 21445:11: [preauth] Dec 19 08:54:34 Claimco sshd[24102]: Disconnected from 61.177.173.37 port 21445 [preauth] Dec 19 08:54:34 Claimco sshd[24055]: Received disconnect from 61.177.173.2 port 25564:11: [preauth] Dec 19 08:54:34 Claimco sshd[24055]: Disconnected from authenticating user root 61.177.173.2 port 25564 [preauth] Dec 19 08:54:34 Claimco sshd[24055]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 08:54:41 Claimco sshd[23667]: fatal: Timeout before authentication for 61.177.173.2 port 47172 Dec 19 08:55:04 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:55:14 Claimco sshd[24291]: Connection from 61.177.173.50 port 12816 on 192.168.1.233 port 22 rdomain "" Dec 19 08:55:15 Claimco sshd[24291]: Received disconnect from 61.177.173.50 port 12816:11: [preauth] Dec 19 08:55:15 Claimco sshd[24291]: Disconnected from 61.177.173.50 port 12816 [preauth] Dec 19 08:56:11 Claimco sshd[24511]: Connection from 61.177.173.2 port 21394 on 192.168.1.233 port 22 rdomain "" Dec 19 08:56:38 Claimco sshd[24598]: Connection from 61.177.173.43 port 22808 on 192.168.1.233 port 22 rdomain "" Dec 19 08:56:38 Claimco sshd[24598]: Unable to negotiate with 61.177.173.43 port 22808: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 08:56:41 Claimco sshd[24606]: Connection from 61.177.172.114 port 18082 on 192.168.1.233 port 22 rdomain "" Dec 19 08:57:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:57:53 Claimco sshd[25040]: Connection from 61.177.173.2 port 39067 on 192.168.1.233 port 22 rdomain "" Dec 19 08:58:11 Claimco sshd[24511]: fatal: Timeout before authentication for 61.177.173.2 port 21394 Dec 19 08:58:41 Claimco sshd[24606]: fatal: Timeout before authentication for 61.177.172.114 port 18082 Dec 19 08:59:15 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 08:59:39 Claimco sshd[25459]: Connection from 61.177.173.2 port 31561 on 192.168.1.233 port 22 rdomain "" Dec 19 08:59:53 Claimco sshd[25040]: fatal: Timeout before authentication for 61.177.173.2 port 39067 Dec 19 09:00:42 Claimco sshd[25722]: Connection from 61.177.173.35 port 24999 on 192.168.1.233 port 22 rdomain "" Dec 19 09:00:43 Claimco sshd[25722]: Received disconnect from 61.177.173.35 port 24999:11: [preauth] Dec 19 09:00:43 Claimco sshd[25722]: Disconnected from 61.177.173.35 port 24999 [preauth] Dec 19 09:01:22 Claimco sshd[25880]: Connection from 61.177.173.2 port 59826 on 192.168.1.233 port 22 rdomain "" Dec 19 09:01:26 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:01:30 Claimco sshd[25896]: Connection from 61.177.172.98 port 53350 on 192.168.1.233 port 22 rdomain "" Dec 19 09:01:31 Claimco sshd[25896]: Received disconnect from 61.177.172.98 port 53350:11: [preauth] Dec 19 09:01:31 Claimco sshd[25896]: Disconnected from 61.177.172.98 port 53350 [preauth] Dec 19 09:01:39 Claimco sshd[25459]: fatal: Timeout before authentication for 61.177.173.2 port 31561 Dec 19 09:02:50 Claimco sshd[26178]: Connection from 61.177.173.49 port 40580 on 192.168.1.233 port 22 rdomain "" Dec 19 09:02:51 Claimco sshd[26178]: Received disconnect from 61.177.173.49 port 40580:11: [preauth] Dec 19 09:02:51 Claimco sshd[26178]: Disconnected from 61.177.173.49 port 40580 [preauth] Dec 19 09:03:06 Claimco sshd[26248]: Connection from 61.177.173.2 port 41778 on 192.168.1.233 port 22 rdomain "" Dec 19 09:03:22 Claimco sshd[25880]: fatal: Timeout before authentication for 61.177.173.2 port 59826 Dec 19 09:03:24 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:04:25 Claimco sshd[26551]: Connection from 61.177.173.52 port 14400 on 192.168.1.233 port 22 rdomain "" Dec 19 09:04:26 Claimco sshd[26551]: Received disconnect from 61.177.173.52 port 14400:11: [preauth] Dec 19 09:04:26 Claimco sshd[26551]: Disconnected from 61.177.173.52 port 14400 [preauth] Dec 19 09:04:49 Claimco sshd[26632]: Connection from 61.177.173.2 port 12222 on 192.168.1.233 port 22 rdomain "" Dec 19 09:05:06 Claimco sshd[26248]: fatal: Timeout before authentication for 61.177.173.2 port 41778 Dec 19 09:05:38 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:06:25 Claimco sshd[27035]: Connection from 61.177.172.104 port 33480 on 192.168.1.233 port 22 rdomain "" Dec 19 09:06:26 Claimco sshd[27035]: Received disconnect from 61.177.172.104 port 33480:11: [preauth] Dec 19 09:06:26 Claimco sshd[27035]: Disconnected from 61.177.172.104 port 33480 [preauth] Dec 19 09:06:34 Claimco sshd[27059]: Connection from 61.177.173.2 port 49621 on 192.168.1.233 port 22 rdomain "" Dec 19 09:06:49 Claimco sshd[26632]: fatal: Timeout before authentication for 61.177.173.2 port 12222 Dec 19 09:06:53 Claimco sshd[27124]: Connection from 92.46.108.20 port 51652 on 192.168.1.233 port 22 rdomain "" Dec 19 09:06:55 Claimco sshd[27124]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=92.46.108.20 user=root Dec 19 09:06:57 Claimco sshd[27124]: Failed password for root from 92.46.108.20 port 51652 ssh2 Dec 19 09:07:00 Claimco sshd[27124]: Connection closed by authenticating user root 92.46.108.20 port 51652 [preauth] Dec 19 09:07:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:08:19 Claimco sshd[27624]: Connection from 61.177.173.2 port 41681 on 192.168.1.233 port 22 rdomain "" Dec 19 09:08:34 Claimco sshd[27059]: fatal: Timeout before authentication for 61.177.173.2 port 49621 Dec 19 09:09:30 Claimco sshd[27908]: Connection from 61.177.173.35 port 49512 on 192.168.1.233 port 22 rdomain "" Dec 19 09:09:31 Claimco sshd[27908]: Received disconnect from 61.177.173.35 port 49512:11: [preauth] Dec 19 09:09:31 Claimco sshd[27908]: Disconnected from 61.177.173.35 port 49512 [preauth] Dec 19 09:09:43 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:10:04 Claimco sshd[28045]: Connection from 61.177.173.2 port 25645 on 192.168.1.233 port 22 rdomain "" Dec 19 09:10:19 Claimco sshd[27624]: fatal: Timeout before authentication for 61.177.173.2 port 41681 Dec 19 09:10:37 Claimco sshd[28188]: Connection from 61.177.173.49 port 47643 on 192.168.1.233 port 22 rdomain "" Dec 19 09:10:38 Claimco sshd[28188]: Received disconnect from 61.177.173.49 port 47643:11: [preauth] Dec 19 09:10:38 Claimco sshd[28188]: Disconnected from 61.177.173.49 port 47643 [preauth] Dec 19 09:11:47 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:11:50 Claimco sshd[28438]: Connection from 61.177.173.2 port 20663 on 192.168.1.233 port 22 rdomain "" Dec 19 09:12:04 Claimco sshd[28045]: fatal: Timeout before authentication for 61.177.173.2 port 25645 Dec 19 09:13:35 Claimco sshd[28829]: Connection from 61.177.173.2 port 60622 on 192.168.1.233 port 22 rdomain "" Dec 19 09:13:50 Claimco sshd[28438]: fatal: Timeout before authentication for 61.177.173.2 port 20663 Dec 19 09:13:52 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:14:38 Claimco sshd[29075]: Connection from 61.177.172.108 port 14362 on 192.168.1.233 port 22 rdomain "" Dec 19 09:14:40 Claimco sshd[29075]: Received disconnect from 61.177.172.108 port 14362:11: [preauth] Dec 19 09:14:40 Claimco sshd[29075]: Disconnected from 61.177.172.108 port 14362 [preauth] Dec 19 09:15:20 Claimco sshd[29264]: Connection from 61.177.173.2 port 50348 on 192.168.1.233 port 22 rdomain "" Dec 19 09:15:35 Claimco sshd[28829]: fatal: Timeout before authentication for 61.177.173.2 port 60622 Dec 19 09:15:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:16:13 Claimco sshd[29477]: Connection from 153.120.39.228 port 49466 on 192.168.1.233 port 22 rdomain "" Dec 19 09:16:13 Claimco sshd[29477]: error: kex_exchange_identification: Connection closed by remote host Dec 19 09:16:13 Claimco sshd[29477]: Connection closed by 153.120.39.228 port 49466 Dec 19 09:17:04 Claimco sshd[29646]: Connection from 61.177.173.2 port 33816 on 192.168.1.233 port 22 rdomain "" Dec 19 09:17:06 Claimco sshd[29646]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:17:09 Claimco sshd[29646]: Failed password for root from 61.177.173.2 port 33816 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 09:17:18 Claimco sshd[29646]: Received disconnect from 61.177.173.2 port 33816:11: [preauth] Dec 19 09:17:18 Claimco sshd[29646]: Disconnected from authenticating user root 61.177.173.2 port 33816 [preauth] Dec 19 09:17:18 Claimco sshd[29646]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:17:20 Claimco sshd[29264]: fatal: Timeout before authentication for 61.177.173.2 port 50348 Dec 19 09:17:59 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:18:09 Claimco sshd[30090]: Connection from 61.177.172.104 port 62499 on 192.168.1.233 port 22 rdomain "" Dec 19 09:18:10 Claimco sshd[30090]: Received disconnect from 61.177.172.104 port 62499:11: [preauth] Dec 19 09:18:10 Claimco sshd[30090]: Disconnected from 61.177.172.104 port 62499 [preauth] Dec 19 09:18:16 Claimco sshd[30106]: Connection from 61.177.173.36 port 60255 on 192.168.1.233 port 22 rdomain "" Dec 19 09:18:17 Claimco sshd[30106]: Received disconnect from 61.177.173.36 port 60255:11: [preauth] Dec 19 09:18:17 Claimco sshd[30106]: Disconnected from 61.177.173.36 port 60255 [preauth] Dec 19 09:18:33 Claimco sshd[30149]: Connection from 61.177.173.46 port 56679 on 192.168.1.233 port 22 rdomain "" Dec 19 09:18:47 Claimco sshd[30232]: Connection from 61.177.173.2 port 54251 on 192.168.1.233 port 22 rdomain "" Dec 19 09:20:11 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:20:32 Claimco sshd[30644]: Connection from 61.177.173.2 port 39189 on 192.168.1.233 port 22 rdomain "" Dec 19 09:20:33 Claimco sshd[30149]: fatal: Timeout before authentication for 61.177.173.46 port 56679 Dec 19 09:20:34 Claimco sshd[30644]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:20:36 Claimco sshd[30644]: Failed password for root from 61.177.173.2 port 39189 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 09:20:41 Claimco sshd[30644]: Received disconnect from 61.177.173.2 port 39189:11: [preauth] Dec 19 09:20:41 Claimco sshd[30644]: Disconnected from authenticating user root 61.177.173.2 port 39189 [preauth] Dec 19 09:20:41 Claimco sshd[30644]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:20:47 Claimco sshd[30232]: fatal: Timeout before authentication for 61.177.173.2 port 54251 Dec 19 09:22:13 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:22:16 Claimco sshd[31042]: Connection from 61.177.173.2 port 20533 on 192.168.1.233 port 22 rdomain "" Dec 19 09:22:18 Claimco sshd[31042]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:22:20 Claimco sshd[31042]: Failed password for root from 61.177.173.2 port 20533 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 09:22:29 Claimco sshd[31042]: Received disconnect from 61.177.173.2 port 20533:11: [preauth] Dec 19 09:22:29 Claimco sshd[31042]: Disconnected from authenticating user root 61.177.173.2 port 20533 [preauth] Dec 19 09:22:29 Claimco sshd[31042]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:24:01 Claimco sshd[31402]: Connection from 61.177.173.2 port 60868 on 192.168.1.233 port 22 rdomain "" Dec 19 09:24:21 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:25:45 Claimco sshd[31812]: Connection from 61.177.173.2 port 39198 on 192.168.1.233 port 22 rdomain "" Dec 19 09:25:47 Claimco sshd[31812]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:25:49 Claimco sshd[31812]: Failed password for root from 61.177.173.2 port 39198 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 09:25:52 Claimco sshd[31853]: Connection from 61.177.173.61 port 2246 on 192.168.1.233 port 22 rdomain "" Dec 19 09:25:52 Claimco sshd[31853]: Unable to negotiate with 61.177.173.61 port 2246: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 09:25:54 Claimco sshd[31812]: Failed password for root from 61.177.173.2 port 39198 ssh2 Dec 19 09:25:54 Claimco sshd[31812]: Received disconnect from 61.177.173.2 port 39198:11: [preauth] Dec 19 09:25:54 Claimco sshd[31812]: Disconnected from authenticating user root 61.177.173.2 port 39198 [preauth] Dec 19 09:25:54 Claimco sshd[31812]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:26:01 Claimco sshd[31402]: fatal: Timeout before authentication for 61.177.173.2 port 60868 Dec 19 09:26:06 Claimco sshd[31932]: Connection from 61.177.173.49 port 24695 on 192.168.1.233 port 22 rdomain "" Dec 19 09:26:07 Claimco sshd[31932]: Received disconnect from 61.177.173.49 port 24695:11: [preauth] Dec 19 09:26:07 Claimco sshd[31932]: Disconnected from 61.177.173.49 port 24695 [preauth] Dec 19 09:26:20 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:26:54 Claimco sshd[32083]: Connection from 61.177.173.39 port 38213 on 192.168.1.233 port 22 rdomain "" Dec 19 09:26:55 Claimco sshd[32083]: Received disconnect from 61.177.173.39 port 38213:11: [preauth] Dec 19 09:26:55 Claimco sshd[32083]: Disconnected from 61.177.173.39 port 38213 [preauth] Dec 19 09:27:28 Claimco sshd[32415]: Connection from 61.177.173.2 port 11796 on 192.168.1.233 port 22 rdomain "" Dec 19 09:27:30 Claimco sshd[32415]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:27:31 Claimco sshd[32415]: Failed password for root from 61.177.173.2 port 11796 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 09:27:37 Claimco sshd[32415]: Received disconnect from 61.177.173.2 port 11796:11: [preauth] Dec 19 09:27:37 Claimco sshd[32415]: Disconnected from authenticating user root 61.177.173.2 port 11796 [preauth] Dec 19 09:27:37 Claimco sshd[32415]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:28:05 Claimco sshd[32556]: Connection from 61.177.172.98 port 18659 on 192.168.1.233 port 22 rdomain "" Dec 19 09:28:07 Claimco sshd[32556]: Received disconnect from 61.177.172.98 port 18659:11: [preauth] Dec 19 09:28:07 Claimco sshd[32556]: Disconnected from 61.177.172.98 port 18659 [preauth] Dec 19 09:28:30 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:29:12 Claimco sshd[340]: Connection from 61.177.173.2 port 46125 on 192.168.1.233 port 22 rdomain "" Dec 19 09:29:14 Claimco sshd[340]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:29:16 Claimco sshd[340]: Failed password for root from 61.177.173.2 port 46125 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 09:29:23 Claimco sshd[340]: Received disconnect from 61.177.173.2 port 46125:11: [preauth] Dec 19 09:29:23 Claimco sshd[340]: Disconnected from authenticating user root 61.177.173.2 port 46125 [preauth] Dec 19 09:29:23 Claimco sshd[340]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:30:00 Claimco sshd[507]: Connection from 61.177.172.104 port 18331 on 192.168.1.233 port 22 rdomain "" Dec 19 09:30:31 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:30:56 Claimco sshd[748]: Connection from 61.177.173.2 port 26585 on 192.168.1.233 port 22 rdomain "" Dec 19 09:32:00 Claimco sshd[507]: fatal: Timeout before authentication for 61.177.172.104 port 18331 Dec 19 09:32:39 Claimco sshd[1175]: Connection from 61.177.173.2 port 50598 on 192.168.1.233 port 22 rdomain "" Dec 19 09:32:41 Claimco sshd[1175]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:32:42 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:32:42 Claimco sshd[1175]: Failed password for root from 61.177.173.2 port 50598 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 09:32:48 Claimco sshd[1175]: Received disconnect from 61.177.173.2 port 50598:11: [preauth] Dec 19 09:32:48 Claimco sshd[1175]: Disconnected from authenticating user root 61.177.173.2 port 50598 [preauth] Dec 19 09:32:48 Claimco sshd[1175]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:32:56 Claimco sshd[748]: fatal: Timeout before authentication for 61.177.173.2 port 26585 Dec 19 09:33:33 Claimco sshd[1354]: Connection from 61.177.173.50 port 11958 on 192.168.1.233 port 22 rdomain "" Dec 19 09:33:34 Claimco sshd[1354]: Received disconnect from 61.177.173.50 port 11958:11: [preauth] Dec 19 09:33:34 Claimco sshd[1354]: Disconnected from 61.177.173.50 port 11958 [preauth] Dec 19 09:34:25 Claimco sshd[1573]: Connection from 61.177.173.2 port 52056 on 192.168.1.233 port 22 rdomain "" Dec 19 09:34:27 Claimco sshd[1573]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:34:29 Claimco sshd[1573]: Failed password for root from 61.177.173.2 port 52056 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 09:34:34 Claimco sshd[1573]: Received disconnect from 61.177.173.2 port 52056:11: [preauth] Dec 19 09:34:34 Claimco sshd[1573]: Disconnected from authenticating user root 61.177.173.2 port 52056 [preauth] Dec 19 09:34:34 Claimco sshd[1573]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:34:43 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:35:07 Claimco sshd[1797]: Connection from 167.248.133.117 port 56596 on 192.168.1.233 port 22 rdomain "" Dec 19 09:35:15 Claimco sshd[1814]: Connection from 65.2.28.105 port 47060 on 192.168.1.233 port 22 rdomain "" Dec 19 09:35:16 Claimco sshd[1814]: Invalid user oracle from 65.2.28.105 port 47060 Dec 19 09:35:16 Claimco sshd[1814]: pam_unix(sshd:auth): check pass; user unknown Dec 19 09:35:16 Claimco sshd[1814]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=65.2.28.105 Dec 19 09:35:19 Claimco sshd[1814]: Failed password for invalid user oracle from 65.2.28.105 port 47060 ssh2 Dec 19 09:35:19 Claimco sshd[1814]: Connection closed by invalid user oracle 65.2.28.105 port 47060 [preauth] Dec 19 09:35:22 Claimco sshd[1797]: Connection closed by 167.248.133.117 port 56596 [preauth] Dec 19 09:35:35 Claimco sshd[1880]: Connection from 61.177.173.35 port 33324 on 192.168.1.233 port 22 rdomain "" Dec 19 09:35:36 Claimco sshd[1880]: Received disconnect from 61.177.173.35 port 33324:11: [preauth] Dec 19 09:35:36 Claimco sshd[1880]: Disconnected from 61.177.173.35 port 33324 [preauth] Dec 19 09:36:06 Claimco sshd[2003]: Connection from 61.177.173.2 port 61831 on 192.168.1.233 port 22 rdomain "" Dec 19 09:36:47 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:37:51 Claimco sshd[2557]: Connection from 61.177.173.2 port 40935 on 192.168.1.233 port 22 rdomain "" Dec 19 09:37:53 Claimco sshd[2557]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:37:55 Claimco sshd[2557]: Failed password for root from 61.177.173.2 port 40935 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 09:38:02 Claimco sshd[2557]: Received disconnect from 61.177.173.2 port 40935:11: [preauth] Dec 19 09:38:02 Claimco sshd[2557]: Disconnected from authenticating user root 61.177.173.2 port 40935 [preauth] Dec 19 09:38:02 Claimco sshd[2557]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:38:06 Claimco sshd[2003]: fatal: Timeout before authentication for 61.177.173.2 port 61831 Dec 19 09:38:52 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:39:38 Claimco sshd[2955]: Connection from 61.177.173.2 port 20921 on 192.168.1.233 port 22 rdomain "" Dec 19 09:39:39 Claimco sshd[2955]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:39:40 Claimco sshd[2955]: Failed password for root from 61.177.173.2 port 20921 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 09:39:48 Claimco sshd[2955]: Received disconnect from 61.177.173.2 port 20921:11: [preauth] Dec 19 09:39:48 Claimco sshd[2955]: Disconnected from authenticating user root 61.177.173.2 port 20921 [preauth] Dec 19 09:39:48 Claimco sshd[2955]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:40:56 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:41:10 Claimco sshd[3351]: Connection from 61.177.173.2 port 38324 on 192.168.1.233 port 22 rdomain "" Dec 19 09:41:11 Claimco sshd[3351]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:41:13 Claimco sshd[3361]: Connection from 61.177.173.49 port 49227 on 192.168.1.233 port 22 rdomain "" Dec 19 09:41:13 Claimco sshd[3351]: Failed password for root from 61.177.173.2 port 38324 ssh2 Dec 19 09:41:16 Claimco sshd[3361]: Received disconnect from 61.177.173.49 port 49227:11: [preauth] Dec 19 09:41:16 Claimco sshd[3361]: Disconnected from 61.177.173.49 port 49227 [preauth] Dec 19 09:41:18 Claimco sshd[3351]: Failed password for root from 61.177.173.2 port 38324 ssh2 Dec 19 09:41:18 Claimco sshd[3396]: Connection from 61.177.172.98 port 39278 on 192.168.1.233 port 22 rdomain "" Dec 19 09:41:19 Claimco sshd[3396]: Received disconnect from 61.177.172.98 port 39278:11: [preauth] Dec 19 09:41:19 Claimco sshd[3396]: Disconnected from 61.177.172.98 port 39278 [preauth] Dec 19 09:41:22 Claimco sshd[3351]: Failed password for root from 61.177.173.2 port 38324 ssh2 Dec 19 09:41:25 Claimco sshd[3351]: Received disconnect from 61.177.173.2 port 38324:11: [preauth] Dec 19 09:41:25 Claimco sshd[3351]: Disconnected from authenticating user root 61.177.173.2 port 38324 [preauth] Dec 19 09:41:25 Claimco sshd[3351]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:41:30 Claimco sshd[3423]: Connection from 61.177.173.37 port 38030 on 192.168.1.233 port 22 rdomain "" Dec 19 09:41:31 Claimco sshd[3423]: Received disconnect from 61.177.173.37 port 38030:11: [preauth] Dec 19 09:41:31 Claimco sshd[3423]: Disconnected from 61.177.173.37 port 38030 [preauth] Dec 19 09:41:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:42:50 Claimco sshd[3705]: Connection from 61.177.173.2 port 29965 on 192.168.1.233 port 22 rdomain "" Dec 19 09:43:02 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:44:24 Claimco sshd[4072]: Connection from 61.177.173.35 port 55623 on 192.168.1.233 port 22 rdomain "" Dec 19 09:44:25 Claimco sshd[4072]: Received disconnect from 61.177.173.35 port 55623:11: [preauth] Dec 19 09:44:25 Claimco sshd[4072]: Disconnected from 61.177.173.35 port 55623 [preauth] Dec 19 09:44:32 Claimco sshd[4095]: Connection from 61.177.172.114 port 27380 on 192.168.1.233 port 22 rdomain "" Dec 19 09:44:33 Claimco sshd[4100]: Connection from 61.177.173.2 port 60662 on 192.168.1.233 port 22 rdomain "" Dec 19 09:44:50 Claimco sshd[3705]: fatal: Timeout before authentication for 61.177.173.2 port 29965 Dec 19 09:45:05 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 09:46:15 Claimco sshd[4531]: Connection from 61.177.173.2 port 29672 on 192.168.1.233 port 22 rdomain "" Dec 19 09:46:32 Claimco sshd[4095]: fatal: Timeout before authentication for 61.177.172.114 port 27380 Dec 19 09:46:33 Claimco sshd[4100]: fatal: Timeout before authentication for 61.177.173.2 port 60662 Dec 19 09:47:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:47:59 Claimco sshd[5086]: Connection from 61.177.173.2 port 64791 on 192.168.1.233 port 22 rdomain "" Dec 19 09:48:15 Claimco sshd[4531]: fatal: Timeout before authentication for 61.177.173.2 port 29672 Dec 19 09:48:44 Claimco sshd[5270]: Connection from 61.177.173.46 port 58879 on 192.168.1.233 port 22 rdomain "" Dec 19 09:48:45 Claimco sshd[5270]: Received disconnect from 61.177.173.46 port 58879:11: [preauth] Dec 19 09:48:45 Claimco sshd[5270]: Disconnected from 61.177.173.46 port 58879 [preauth] Dec 19 09:49:18 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:49:42 Claimco sshd[5477]: Connection from 61.177.173.2 port 36351 on 192.168.1.233 port 22 rdomain "" Dec 19 09:49:44 Claimco sshd[5477]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:49:46 Claimco sshd[5477]: Failed password for root from 61.177.173.2 port 36351 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 09:49:51 Claimco sshd[5477]: Received disconnect from 61.177.173.2 port 36351:11: [preauth] Dec 19 09:49:51 Claimco sshd[5477]: Disconnected from authenticating user root 61.177.173.2 port 36351 [preauth] Dec 19 09:49:51 Claimco sshd[5477]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:49:59 Claimco sshd[5086]: fatal: Timeout before authentication for 61.177.173.2 port 64791 Dec 19 09:51:20 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:51:23 Claimco sshd[5891]: Connection from 61.177.173.2 port 22668 on 192.168.1.233 port 22 rdomain "" Dec 19 09:51:24 Claimco sshd[5891]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:51:26 Claimco sshd[5891]: Failed password for root from 61.177.173.2 port 22668 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 09:51:31 Claimco sshd[5891]: Received disconnect from 61.177.173.2 port 22668:11: [preauth] Dec 19 09:51:31 Claimco sshd[5891]: Disconnected from authenticating user root 61.177.173.2 port 22668 [preauth] Dec 19 09:51:31 Claimco sshd[5891]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:52:57 Claimco sshd[6205]: Connection from 61.177.173.47 port 23948 on 192.168.1.233 port 22 rdomain "" Dec 19 09:52:58 Claimco sshd[6205]: Received disconnect from 61.177.173.47 port 23948:11: [preauth] Dec 19 09:52:58 Claimco sshd[6205]: Disconnected from 61.177.173.47 port 23948 [preauth] Dec 19 09:52:59 Claimco sshd[6211]: Connection from 61.177.173.2 port 13714 on 192.168.1.233 port 22 rdomain "" Dec 19 09:53:00 Claimco sshd[6211]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:53:02 Claimco sshd[6211]: Failed password for root from 61.177.173.2 port 13714 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 09:53:11 Claimco sshd[6295]: Connection from 61.177.172.104 port 20751 on 192.168.1.233 port 22 rdomain "" Dec 19 09:53:11 Claimco sshd[6211]: Received disconnect from 61.177.173.2 port 13714:11: [preauth] Dec 19 09:53:11 Claimco sshd[6211]: Disconnected from authenticating user root 61.177.173.2 port 13714 [preauth] Dec 19 09:53:11 Claimco sshd[6211]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:53:33 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:54:20 Claimco sshd[6561]: Connection from 61.177.172.108 port 49940 on 192.168.1.233 port 22 rdomain "" Dec 19 09:54:21 Claimco sshd[6561]: Received disconnect from 61.177.172.108 port 49940:11: [preauth] Dec 19 09:54:21 Claimco sshd[6561]: Disconnected from 61.177.172.108 port 49940 [preauth] Dec 19 09:54:34 Claimco sshd[6599]: Connection from 61.177.173.2 port 24848 on 192.168.1.233 port 22 rdomain "" Dec 19 09:54:36 Claimco sshd[6599]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:54:39 Claimco sshd[6599]: Failed password for root from 61.177.173.2 port 24848 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 09:54:46 Claimco sshd[6599]: Received disconnect from 61.177.173.2 port 24848:11: [preauth] Dec 19 09:54:46 Claimco sshd[6599]: Disconnected from authenticating user root 61.177.173.2 port 24848 [preauth] Dec 19 09:54:46 Claimco sshd[6599]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:55:11 Claimco sshd[6295]: fatal: Timeout before authentication for 61.177.172.104 port 20751 Dec 19 09:55:38 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:56:15 Claimco sshd[7050]: Connection from 61.177.173.2 port 38911 on 192.168.1.233 port 22 rdomain "" Dec 19 09:56:23 Claimco sshd[7067]: Connection from 61.177.173.49 port 29075 on 192.168.1.233 port 22 rdomain "" Dec 19 09:56:25 Claimco sshd[7067]: Received disconnect from 61.177.173.49 port 29075:11: [preauth] Dec 19 09:56:25 Claimco sshd[7067]: Disconnected from 61.177.173.49 port 29075 [preauth] Dec 19 09:57:34 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 09:57:58 Claimco sshd[7693]: Connection from 61.177.173.2 port 17725 on 192.168.1.233 port 22 rdomain "" Dec 19 09:58:00 Claimco sshd[7693]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:58:02 Claimco sshd[7693]: Failed password for root from 61.177.173.2 port 17725 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 09:58:06 Claimco sshd[7693]: Received disconnect from 61.177.173.2 port 17725:11: [preauth] Dec 19 09:58:06 Claimco sshd[7693]: Disconnected from authenticating user root 61.177.173.2 port 17725 [preauth] Dec 19 09:58:06 Claimco sshd[7693]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 09:58:15 Claimco sshd[7050]: fatal: Timeout before authentication for 61.177.173.2 port 38911 Dec 19 09:59:09 Claimco sshd[8043]: Connection from 61.177.173.52 port 48009 on 192.168.1.233 port 22 rdomain "" Dec 19 09:59:10 Claimco sshd[8043]: Received disconnect from 61.177.173.52 port 48009:11: [preauth] Dec 19 09:59:10 Claimco sshd[8043]: Disconnected from 61.177.173.52 port 48009 [preauth] Dec 19 09:59:38 Claimco sshd[8139]: Connection from 61.177.173.2 port 27424 on 192.168.1.233 port 22 rdomain "" Dec 19 09:59:40 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:01:23 Claimco sshd[8583]: Connection from 61.177.173.2 port 20682 on 192.168.1.233 port 22 rdomain "" Dec 19 10:01:25 Claimco sshd[8583]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:01:28 Claimco sshd[8583]: Failed password for root from 61.177.173.2 port 20682 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 10:01:37 Claimco sshd[8583]: Received disconnect from 61.177.173.2 port 20682:11: [preauth] Dec 19 10:01:37 Claimco sshd[8583]: Disconnected from authenticating user root 61.177.173.2 port 20682 [preauth] Dec 19 10:01:37 Claimco sshd[8583]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:01:38 Claimco sshd[8139]: fatal: Timeout before authentication for 61.177.173.2 port 27424 Dec 19 10:01:40 Claimco sshd[8626]: Connection from 61.177.173.47 port 17372 on 192.168.1.233 port 22 rdomain "" Dec 19 10:01:41 Claimco sshd[8626]: Received disconnect from 61.177.173.47 port 17372:11: [preauth] Dec 19 10:01:41 Claimco sshd[8626]: Disconnected from 61.177.173.47 port 17372 [preauth] Dec 19 10:01:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:03:02 Claimco sshd[8943]: Connection from 61.177.173.2 port 13507 on 192.168.1.233 port 22 rdomain "" Dec 19 10:03:56 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:03:57 Claimco sshd[9137]: Connection from 61.177.173.51 port 21844 on 192.168.1.233 port 22 rdomain "" Dec 19 10:03:58 Claimco sshd[9137]: Received disconnect from 61.177.173.51 port 21844:11: [preauth] Dec 19 10:03:58 Claimco sshd[9137]: Disconnected from 61.177.173.51 port 21844 [preauth] Dec 19 10:04:16 Claimco sshd[9211]: Connection from 162.218.126.136 port 37524 on 192.168.1.233 port 22 rdomain "" Dec 19 10:04:16 Claimco sshd[9211]: Invalid user gpadmin from 162.218.126.136 port 37524 Dec 19 10:04:16 Claimco sshd[9211]: pam_unix(sshd:auth): check pass; user unknown Dec 19 10:04:16 Claimco sshd[9211]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=162.218.126.136 Dec 19 10:04:18 Claimco sshd[9211]: Failed password for invalid user gpadmin from 162.218.126.136 port 37524 ssh2 Dec 19 10:04:19 Claimco sshd[9211]: Connection closed by invalid user gpadmin 162.218.126.136 port 37524 [preauth] Dec 19 10:04:42 Claimco sshd[9312]: Connection from 61.177.173.2 port 15276 on 192.168.1.233 port 22 rdomain "" Dec 19 10:04:45 Claimco sshd[9312]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:04:46 Claimco sshd[9320]: Connection from 218.92.0.221 port 29505 on 192.168.1.233 port 22 rdomain "" Dec 19 10:04:46 Claimco sshd[9312]: Failed password for root from 61.177.173.2 port 15276 ssh2 Dec 19 10:04:47 Claimco sshd[9320]: Received disconnect from 218.92.0.221 port 29505:11: [preauth] Dec 19 10:04:47 Claimco sshd[9320]: Disconnected from 218.92.0.221 port 29505 [preauth] Dec 19 10:04:49 Claimco sshd[9312]: Failed password for root from 61.177.173.2 port 15276 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 10:04:52 Claimco sshd[9312]: Received disconnect from 61.177.173.2 port 15276:11: [preauth] Dec 19 10:04:52 Claimco sshd[9312]: Disconnected from authenticating user root 61.177.173.2 port 15276 [preauth] Dec 19 10:04:52 Claimco sshd[9312]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:05:02 Claimco sshd[8943]: fatal: Timeout before authentication for 61.177.173.2 port 13507 Dec 19 10:05:55 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:06:26 Claimco sshd[9732]: Connection from 61.177.173.2 port 43667 on 192.168.1.233 port 22 rdomain "" Dec 19 10:06:28 Claimco sshd[9732]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:06:30 Claimco sshd[9732]: Failed password for root from 61.177.173.2 port 43667 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 10:06:37 Claimco sshd[9732]: Received disconnect from 61.177.173.2 port 43667:11: [preauth] Dec 19 10:06:37 Claimco sshd[9732]: Disconnected from authenticating user root 61.177.173.2 port 43667 [preauth] Dec 19 10:06:37 Claimco sshd[9732]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:07:17 Claimco sshd[9927]: Connection from 61.177.172.108 port 23934 on 192.168.1.233 port 22 rdomain "" Dec 19 10:07:19 Claimco sshd[9927]: Received disconnect from 61.177.172.108 port 23934:11: [preauth] Dec 19 10:07:19 Claimco sshd[9927]: Disconnected from 61.177.172.108 port 23934 [preauth] Dec 19 10:08:00 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:08:06 Claimco sshd[10317]: Connection from 61.177.173.2 port 47966 on 192.168.1.233 port 22 rdomain "" Dec 19 10:08:08 Claimco sshd[10317]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:08:10 Claimco sshd[10317]: Failed password for root from 61.177.173.2 port 47966 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 10:08:19 Claimco sshd[10317]: Received disconnect from 61.177.173.2 port 47966:11: [preauth] Dec 19 10:08:19 Claimco sshd[10317]: Disconnected from authenticating user root 61.177.173.2 port 47966 [preauth] Dec 19 10:08:19 Claimco sshd[10317]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:09:47 Claimco sshd[10671]: Connection from 61.177.173.2 port 63847 on 192.168.1.233 port 22 rdomain "" Dec 19 10:10:09 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:10:20 Claimco sshd[10841]: Connection from 61.177.173.36 port 50146 on 192.168.1.233 port 22 rdomain "" Dec 19 10:10:21 Claimco sshd[10841]: Received disconnect from 61.177.173.36 port 50146:11: [preauth] Dec 19 10:10:21 Claimco sshd[10841]: Disconnected from 61.177.173.36 port 50146 [preauth] Dec 19 10:11:23 Claimco sshd[11073]: Connection from 61.177.173.53 port 18313 on 192.168.1.233 port 22 rdomain "" Dec 19 10:11:24 Claimco sshd[11073]: Received disconnect from 61.177.173.53 port 18313:11: [preauth] Dec 19 10:11:24 Claimco sshd[11073]: Disconnected from 61.177.173.53 port 18313 [preauth] Dec 19 10:11:27 Claimco sshd[11086]: Connection from 61.177.173.2 port 12025 on 192.168.1.233 port 22 rdomain "" Dec 19 10:11:29 Claimco sshd[11086]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:11:31 Claimco sshd[11086]: Failed password for root from 61.177.173.2 port 12025 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 10:11:39 Claimco sshd[11086]: Received disconnect from 61.177.173.2 port 12025:11: [preauth] Dec 19 10:11:39 Claimco sshd[11086]: Disconnected from authenticating user root 61.177.173.2 port 12025 [preauth] Dec 19 10:11:39 Claimco sshd[11086]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:11:47 Claimco sshd[10671]: fatal: Timeout before authentication for 61.177.173.2 port 63847 Dec 19 10:12:12 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:13:10 Claimco sshd[11450]: Connection from 61.177.173.2 port 41948 on 192.168.1.233 port 22 rdomain "" Dec 19 10:14:21 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:14:51 Claimco sshd[11824]: Connection from 61.177.173.2 port 54763 on 192.168.1.233 port 22 rdomain "" Dec 19 10:15:10 Claimco sshd[11450]: fatal: Timeout before authentication for 61.177.173.2 port 41948 Dec 19 10:16:07 Claimco sshd[12163]: Connection from 61.177.172.104 port 58228 on 192.168.1.233 port 22 rdomain "" Dec 19 10:16:24 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:16:33 Claimco sshd[12248]: Connection from 61.177.173.2 port 20595 on 192.168.1.233 port 22 rdomain "" Dec 19 10:16:35 Claimco sshd[12248]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:16:38 Claimco sshd[12248]: Failed password for root from 61.177.173.2 port 20595 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 10:16:45 Claimco sshd[12248]: Received disconnect from 61.177.173.2 port 20595:11: [preauth] Dec 19 10:16:45 Claimco sshd[12248]: Disconnected from authenticating user root 61.177.173.2 port 20595 [preauth] Dec 19 10:16:45 Claimco sshd[12248]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:16:51 Claimco sshd[11824]: fatal: Timeout before authentication for 61.177.173.2 port 54763 Dec 19 10:17:26 Claimco sshd[12439]: Connection from 84.110.99.202 port 46250 on 192.168.1.233 port 22 rdomain "" Dec 19 10:17:27 Claimco sshd[12439]: Invalid user user from 84.110.99.202 port 46250 Dec 19 10:17:27 Claimco sshd[12439]: pam_unix(sshd:auth): check pass; user unknown Dec 19 10:17:27 Claimco sshd[12439]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=84.110.99.202 Dec 19 10:17:29 Claimco sshd[12439]: Failed password for invalid user user from 84.110.99.202 port 46250 ssh2 Dec 19 10:17:30 Claimco sshd[12439]: Connection closed by invalid user user 84.110.99.202 port 46250 [preauth] Dec 19 10:18:07 Claimco sshd[12163]: fatal: Timeout before authentication for 61.177.172.104 port 58228 Dec 19 10:18:12 Claimco sshd[12815]: Connection from 61.177.173.2 port 17908 on 192.168.1.233 port 22 rdomain "" Dec 19 10:18:28 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:18:42 Claimco sshd[12935]: Connection from 61.177.173.46 port 34936 on 192.168.1.233 port 22 rdomain "" Dec 19 10:18:44 Claimco sshd[12935]: Received disconnect from 61.177.173.46 port 34936:11: [preauth] Dec 19 10:18:44 Claimco sshd[12935]: Disconnected from 61.177.173.46 port 34936 [preauth] Dec 19 10:18:59 Claimco sshd[12995]: Connection from 61.177.173.36 port 45943 on 192.168.1.233 port 22 rdomain "" Dec 19 10:19:00 Claimco sshd[12995]: Received disconnect from 61.177.173.36 port 45943:11: [preauth] Dec 19 10:19:00 Claimco sshd[12995]: Disconnected from 61.177.173.36 port 45943 [preauth] Dec 19 10:19:54 Claimco sshd[13199]: Connection from 61.177.173.2 port 38333 on 192.168.1.233 port 22 rdomain "" Dec 19 10:20:12 Claimco sshd[12815]: fatal: Timeout before authentication for 61.177.173.2 port 17908 Dec 19 10:20:31 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:20:32 Claimco sshd[13378]: Connection from 61.177.172.124 port 15529 on 192.168.1.233 port 22 rdomain "" Dec 19 10:20:33 Claimco sshd[13378]: Received disconnect from 61.177.172.124 port 15529:11: [preauth] Dec 19 10:20:33 Claimco sshd[13378]: Disconnected from 61.177.172.124 port 15529 [preauth] Dec 19 10:21:37 Claimco sshd[13605]: Connection from 61.177.173.2 port 56614 on 192.168.1.233 port 22 rdomain "" Dec 19 10:21:39 Claimco sshd[13605]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:21:41 Claimco sshd[13605]: Failed password for root from 61.177.173.2 port 56614 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 10:21:48 Claimco sshd[13605]: Received disconnect from 61.177.173.2 port 56614:11: [preauth] Dec 19 10:21:48 Claimco sshd[13605]: Disconnected from authenticating user root 61.177.173.2 port 56614 [preauth] Dec 19 10:21:48 Claimco sshd[13605]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:21:54 Claimco sshd[13199]: fatal: Timeout before authentication for 61.177.173.2 port 38333 Dec 19 10:22:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:23:18 Claimco sshd[13979]: Connection from 61.177.173.2 port 13764 on 192.168.1.233 port 22 rdomain "" Dec 19 10:24:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:25:00 Claimco sshd[14331]: Connection from 61.177.173.2 port 34699 on 192.168.1.233 port 22 rdomain "" Dec 19 10:25:18 Claimco sshd[13979]: fatal: Timeout before authentication for 61.177.173.2 port 13764 Dec 19 10:25:57 Claimco sshd[14583]: Connection from 61.177.173.51 port 54903 on 192.168.1.233 port 22 rdomain "" Dec 19 10:25:58 Claimco sshd[14583]: Received disconnect from 61.177.173.51 port 54903:11: [preauth] Dec 19 10:25:58 Claimco sshd[14583]: Disconnected from 61.177.173.51 port 54903 [preauth] Dec 19 10:26:41 Claimco sshd[14763]: Connection from 61.177.173.2 port 51972 on 192.168.1.233 port 22 rdomain "" Dec 19 10:26:45 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:27:00 Claimco sshd[14331]: fatal: Timeout before authentication for 61.177.173.2 port 34699 Dec 19 10:27:31 Claimco sshd[14937]: Connection from 218.92.0.221 port 57036 on 192.168.1.233 port 22 rdomain "" Dec 19 10:27:32 Claimco sshd[14937]: Received disconnect from 218.92.0.221 port 57036:11: [preauth] Dec 19 10:27:32 Claimco sshd[14937]: Disconnected from 218.92.0.221 port 57036 [preauth] Dec 19 10:27:43 Claimco sshd[15196]: Connection from 61.177.173.36 port 27273 on 192.168.1.233 port 22 rdomain "" Dec 19 10:27:45 Claimco sshd[15196]: Received disconnect from 61.177.173.36 port 27273:11: [preauth] Dec 19 10:27:45 Claimco sshd[15196]: Disconnected from 61.177.173.36 port 27273 [preauth] Dec 19 10:28:25 Claimco sshd[15341]: Connection from 199.76.38.123 port 44304 on 192.168.1.233 port 22 rdomain "" Dec 19 10:28:25 Claimco sshd[15342]: Connection from 199.76.38.123 port 44310 on 192.168.1.233 port 22 rdomain "" Dec 19 10:28:26 Claimco sshd[15342]: Invalid user pi from 199.76.38.123 port 44310 Dec 19 10:28:26 Claimco sshd[15341]: Invalid user pi from 199.76.38.123 port 44304 Dec 19 10:28:26 Claimco sshd[15342]: pam_unix(sshd:auth): check pass; user unknown Dec 19 10:28:26 Claimco sshd[15342]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=199.76.38.123 Dec 19 10:28:26 Claimco sshd[15341]: pam_unix(sshd:auth): check pass; user unknown Dec 19 10:28:26 Claimco sshd[15341]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=199.76.38.123 Dec 19 10:28:27 Claimco sshd[15364]: Connection from 61.177.173.2 port 51702 on 192.168.1.233 port 22 rdomain "" Dec 19 10:28:28 Claimco sshd[15342]: Failed password for invalid user pi from 199.76.38.123 port 44310 ssh2 Dec 19 10:28:28 Claimco sshd[15341]: Failed password for invalid user pi from 199.76.38.123 port 44304 ssh2 Dec 19 10:28:28 Claimco sshd[15342]: Connection closed by invalid user pi 199.76.38.123 port 44310 [preauth] Dec 19 10:28:28 Claimco sshd[15341]: Connection closed by invalid user pi 199.76.38.123 port 44304 [preauth] Dec 19 10:28:41 Claimco sshd[14763]: fatal: Timeout before authentication for 61.177.173.2 port 51972 Dec 19 10:28:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:30:03 Claimco sshd[15740]: Connection from 61.177.173.2 port 20593 on 192.168.1.233 port 22 rdomain "" Dec 19 10:30:27 Claimco sshd[15364]: fatal: Timeout before authentication for 61.177.173.2 port 51702 Dec 19 10:30:57 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:31:02 Claimco sshd[15994]: Connection from 61.177.172.114 port 35073 on 192.168.1.233 port 22 rdomain "" Dec 19 10:31:45 Claimco sshd[16135]: Connection from 61.177.173.2 port 46292 on 192.168.1.233 port 22 rdomain "" Dec 19 10:31:48 Claimco sshd[16135]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:31:49 Claimco sshd[16135]: Failed password for root from 61.177.173.2 port 46292 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 10:31:57 Claimco sshd[16135]: Received disconnect from 61.177.173.2 port 46292:11: [preauth] Dec 19 10:31:57 Claimco sshd[16135]: Disconnected from authenticating user root 61.177.173.2 port 46292 [preauth] Dec 19 10:31:57 Claimco sshd[16135]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:32:03 Claimco sshd[15740]: fatal: Timeout before authentication for 61.177.173.2 port 20593 Dec 19 10:32:59 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:33:02 Claimco sshd[15994]: fatal: Timeout before authentication for 61.177.172.114 port 35073 Dec 19 10:33:21 Claimco sshd[16494]: Connection from 61.177.173.53 port 62641 on 192.168.1.233 port 22 rdomain "" Dec 19 10:33:23 Claimco sshd[16494]: Received disconnect from 61.177.173.53 port 62641:11: [preauth] Dec 19 10:33:23 Claimco sshd[16494]: Disconnected from 61.177.173.53 port 62641 [preauth] Dec 19 10:33:26 Claimco sshd[16507]: Connection from 61.177.173.2 port 53883 on 192.168.1.233 port 22 rdomain "" Dec 19 10:33:29 Claimco sshd[16507]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:33:31 Claimco sshd[16517]: Connection from 61.177.172.98 port 31686 on 192.168.1.233 port 22 rdomain "" Dec 19 10:33:31 Claimco sshd[16507]: Failed password for root from 61.177.173.2 port 53883 ssh2 Dec 19 10:33:32 Claimco sshd[16517]: Received disconnect from 61.177.172.98 port 31686:11: [preauth] Dec 19 10:33:32 Claimco sshd[16517]: Disconnected from 61.177.172.98 port 31686 [preauth] Dec 19 10:33:36 Claimco sshd[16507]: Failed password for root from 61.177.173.2 port 53883 ssh2 Dec 19 10:33:37 Claimco sshd[16565]: Connection from 61.177.172.76 port 2424 on 192.168.1.233 port 22 rdomain "" Dec 19 10:33:37 Claimco sshd[16565]: Unable to negotiate with 61.177.172.76 port 2424: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 10:33:40 Claimco sshd[16507]: Failed password for root from 61.177.173.2 port 53883 ssh2 Dec 19 10:33:40 Claimco sshd[16507]: Received disconnect from 61.177.173.2 port 53883:11: [preauth] Dec 19 10:33:40 Claimco sshd[16507]: Disconnected from authenticating user root 61.177.173.2 port 53883 [preauth] Dec 19 10:33:40 Claimco sshd[16507]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:35:07 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:35:09 Claimco sshd[16946]: Connection from 61.177.173.2 port 18403 on 192.168.1.233 port 22 rdomain "" Dec 19 10:36:24 Claimco sshd[17212]: Connection from 61.177.173.47 port 31145 on 192.168.1.233 port 22 rdomain "" Dec 19 10:36:25 Claimco sshd[17212]: Received disconnect from 61.177.173.47 port 31145:11: [preauth] Dec 19 10:36:25 Claimco sshd[17212]: Disconnected from 61.177.173.47 port 31145 [preauth] Dec 19 10:36:50 Claimco sshd[17271]: Connection from 61.177.173.2 port 32396 on 192.168.1.233 port 22 rdomain "" Dec 19 10:37:09 Claimco sshd[16946]: fatal: Timeout before authentication for 61.177.173.2 port 18403 Dec 19 10:37:12 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:38:31 Claimco sshd[17866]: Connection from 61.177.173.2 port 44457 on 192.168.1.233 port 22 rdomain "" Dec 19 10:38:33 Claimco sshd[17866]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:38:35 Claimco sshd[17866]: Failed password for root from 61.177.173.2 port 44457 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 10:38:40 Claimco sshd[17866]: Received disconnect from 61.177.173.2 port 44457:11: [preauth] Dec 19 10:38:40 Claimco sshd[17866]: Disconnected from authenticating user root 61.177.173.2 port 44457 [preauth] Dec 19 10:38:40 Claimco sshd[17866]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:38:45 Claimco sshd[17929]: Connection from 61.177.172.90 port 52019 on 192.168.1.233 port 22 rdomain "" Dec 19 10:38:46 Claimco sshd[17929]: Received disconnect from 61.177.172.90 port 52019:11: [preauth] Dec 19 10:38:46 Claimco sshd[17929]: Disconnected from 61.177.172.90 port 52019 [preauth] Dec 19 10:38:50 Claimco sshd[17271]: fatal: Timeout before authentication for 61.177.173.2 port 32396 Dec 19 10:39:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:40:13 Claimco sshd[18301]: Connection from 61.177.173.2 port 62042 on 192.168.1.233 port 22 rdomain "" Dec 19 10:40:45 Claimco sshd[18398]: Connection from 61.177.173.53 port 45126 on 192.168.1.233 port 22 rdomain "" Dec 19 10:40:46 Claimco sshd[18398]: Received disconnect from 61.177.173.53 port 45126:11: [preauth] Dec 19 10:40:46 Claimco sshd[18398]: Disconnected from 61.177.173.53 port 45126 [preauth] Dec 19 10:41:19 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 10:41:53 Claimco sshd[18625]: Connection from 61.177.173.2 port 64991 on 192.168.1.233 port 22 rdomain "" Dec 19 10:42:13 Claimco sshd[18301]: fatal: Timeout before authentication for 61.177.173.2 port 62042 Dec 19 10:43:27 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:43:36 Claimco sshd[19026]: Connection from 61.177.173.2 port 37841 on 192.168.1.233 port 22 rdomain "" Dec 19 10:43:53 Claimco sshd[18625]: fatal: Timeout before authentication for 61.177.173.2 port 64991 Dec 19 10:44:52 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:45:00 Claimco sshd[19312]: Connection from 61.177.173.39 port 46208 on 192.168.1.233 port 22 rdomain "" Dec 19 10:45:01 Claimco sshd[19312]: Received disconnect from 61.177.173.39 port 46208:11: [preauth] Dec 19 10:45:01 Claimco sshd[19312]: Disconnected from 61.177.173.39 port 46208 [preauth] Dec 19 10:45:17 Claimco sshd[19471]: Connection from 61.177.173.2 port 50246 on 192.168.1.233 port 22 rdomain "" Dec 19 10:45:22 Claimco sshd[19482]: Connection from 133.242.135.118 port 51157 on 192.168.1.233 port 22 rdomain "" Dec 19 10:45:23 Claimco sshd[19482]: error: kex_exchange_identification: Connection closed by remote host Dec 19 10:45:23 Claimco sshd[19482]: Connection closed by 133.242.135.118 port 51157 Dec 19 10:45:29 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:45:36 Claimco sshd[19026]: fatal: Timeout before authentication for 61.177.173.2 port 37841 Dec 19 10:46:10 Claimco sshd[19644]: Connection from 61.177.172.19 port 12822 on 192.168.1.233 port 22 rdomain "" Dec 19 10:46:11 Claimco sshd[19644]: Received disconnect from 61.177.172.19 port 12822:11: [preauth] Dec 19 10:46:11 Claimco sshd[19644]: Disconnected from 61.177.172.19 port 12822 [preauth] Dec 19 10:46:59 Claimco sshd[19800]: Connection from 61.177.173.2 port 13114 on 192.168.1.233 port 22 rdomain "" Dec 19 10:47:02 Claimco sshd[19800]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:47:04 Claimco sshd[19800]: Failed password for root from 61.177.173.2 port 13114 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 10:47:13 Claimco sshd[19800]: Received disconnect from 61.177.173.2 port 13114:11: [preauth] Dec 19 10:47:13 Claimco sshd[19800]: Disconnected from authenticating user root 61.177.173.2 port 13114 [preauth] Dec 19 10:47:13 Claimco sshd[19800]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:47:17 Claimco sshd[19471]: fatal: Timeout before authentication for 61.177.173.2 port 50246 Dec 19 10:47:38 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:48:10 Claimco sshd[20287]: Connection from 61.177.173.49 port 59102 on 192.168.1.233 port 22 rdomain "" Dec 19 10:48:12 Claimco sshd[20287]: Received disconnect from 61.177.173.49 port 59102:11: [preauth] Dec 19 10:48:12 Claimco sshd[20287]: Disconnected from 61.177.173.49 port 59102 [preauth] Dec 19 10:48:41 Claimco sshd[20410]: Connection from 61.177.173.2 port 25367 on 192.168.1.233 port 22 rdomain "" Dec 19 10:49:43 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:50:10 Claimco sshd[20783]: Connection from 61.177.173.37 port 15111 on 192.168.1.233 port 22 rdomain "" Dec 19 10:50:11 Claimco sshd[20783]: Received disconnect from 61.177.173.37 port 15111:11: [preauth] Dec 19 10:50:11 Claimco sshd[20783]: Disconnected from 61.177.173.37 port 15111 [preauth] Dec 19 10:50:22 Claimco sshd[20832]: Connection from 61.177.173.2 port 38804 on 192.168.1.233 port 22 rdomain "" Dec 19 10:50:41 Claimco sshd[20410]: fatal: Timeout before authentication for 61.177.173.2 port 25367 Dec 19 10:51:40 Claimco sshd[21087]: Connection from 153.127.60.38 port 49461 on 192.168.1.233 port 22 rdomain "" Dec 19 10:51:40 Claimco sshd[21087]: error: kex_exchange_identification: Connection closed by remote host Dec 19 10:51:40 Claimco sshd[21087]: Connection closed by 153.127.60.38 port 49461 Dec 19 10:51:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:52:01 Claimco sshd[21154]: Connection from 61.177.173.2 port 16683 on 192.168.1.233 port 22 rdomain "" Dec 19 10:52:02 Claimco sshd[21154]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:52:04 Claimco sshd[21154]: Failed password for root from 61.177.173.2 port 16683 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 10:52:13 Claimco sshd[21154]: Received disconnect from 61.177.173.2 port 16683:11: [preauth] Dec 19 10:52:13 Claimco sshd[21154]: Disconnected from authenticating user root 61.177.173.2 port 16683 [preauth] Dec 19 10:52:13 Claimco sshd[21154]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:52:22 Claimco sshd[20832]: fatal: Timeout before authentication for 61.177.173.2 port 38804 Dec 19 10:53:36 Claimco sshd[21545]: Connection from 61.177.173.48 port 53666 on 192.168.1.233 port 22 rdomain "" Dec 19 10:53:39 Claimco sshd[21550]: Connection from 61.177.173.2 port 39371 on 192.168.1.233 port 22 rdomain "" Dec 19 10:53:40 Claimco sshd[21550]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:53:42 Claimco sshd[21550]: Failed password for root from 61.177.173.2 port 39371 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 10:53:47 Claimco sshd[21550]: Received disconnect from 61.177.173.2 port 39371:11: [preauth] Dec 19 10:53:47 Claimco sshd[21550]: Disconnected from authenticating user root 61.177.173.2 port 39371 [preauth] Dec 19 10:53:47 Claimco sshd[21550]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:53:50 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:54:37 Claimco sshd[21758]: Connection from 61.177.173.52 port 31339 on 192.168.1.233 port 22 rdomain "" Dec 19 10:54:41 Claimco sshd[21758]: Received disconnect from 61.177.173.52 port 31339:11: [preauth] Dec 19 10:54:41 Claimco sshd[21758]: Disconnected from 61.177.173.52 port 31339 [preauth] Dec 19 10:55:13 Claimco sshd[21939]: Connection from 61.177.173.50 port 27831 on 192.168.1.233 port 22 rdomain "" Dec 19 10:55:15 Claimco sshd[21939]: Received disconnect from 61.177.173.50 port 27831:11: [preauth] Dec 19 10:55:15 Claimco sshd[21939]: Disconnected from 61.177.173.50 port 27831 [preauth] Dec 19 10:55:16 Claimco sshd[21945]: Connection from 61.177.173.2 port 62941 on 192.168.1.233 port 22 rdomain "" Dec 19 10:55:17 Claimco sshd[21945]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:55:19 Claimco sshd[21945]: Failed password for root from 61.177.173.2 port 62941 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 10:55:24 Claimco sshd[21945]: Received disconnect from 61.177.173.2 port 62941:11: [preauth] Dec 19 10:55:24 Claimco sshd[21945]: Disconnected from authenticating user root 61.177.173.2 port 62941 [preauth] Dec 19 10:55:24 Claimco sshd[21945]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:55:36 Claimco sshd[21545]: fatal: Timeout before authentication for 61.177.173.48 port 53666 Dec 19 10:55:55 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:56:53 Claimco sshd[22262]: Connection from 61.177.173.2 port 38818 on 192.168.1.233 port 22 rdomain "" Dec 19 10:56:54 Claimco sshd[22262]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:56:56 Claimco sshd[22262]: Failed password for root from 61.177.173.2 port 38818 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 10:57:04 Claimco sshd[22262]: Received disconnect from 61.177.173.2 port 38818:11: [preauth] Dec 19 10:57:04 Claimco sshd[22262]: Disconnected from authenticating user root 61.177.173.2 port 38818 [preauth] Dec 19 10:57:04 Claimco sshd[22262]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:58:07 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 10:58:32 Claimco sshd[22852]: Connection from 61.177.173.2 port 17651 on 192.168.1.233 port 22 rdomain "" Dec 19 10:58:33 Claimco sshd[22852]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:58:36 Claimco sshd[22852]: Failed password for root from 61.177.173.2 port 17651 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 10:58:47 Claimco sshd[22852]: Received disconnect from 61.177.173.2 port 17651:11: [preauth] Dec 19 10:58:47 Claimco sshd[22852]: Disconnected from authenticating user root 61.177.173.2 port 17651 [preauth] Dec 19 10:58:47 Claimco sshd[22852]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 10:59:08 Claimco sshd[23018]: Connection from 61.177.172.98 port 15203 on 192.168.1.233 port 22 rdomain "" Dec 19 10:59:10 Claimco sshd[23018]: Received disconnect from 61.177.172.98 port 15203:11: [preauth] Dec 19 10:59:10 Claimco sshd[23018]: Disconnected from 61.177.172.98 port 15203 [preauth] Dec 19 11:00:09 Claimco sshd[23277]: Connection from 61.177.173.2 port 37419 on 192.168.1.233 port 22 rdomain "" Dec 19 11:00:10 Claimco sshd[23277]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:00:12 Claimco sshd[23277]: Failed password for root from 61.177.173.2 port 37419 ssh2 Dec 19 11:00:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:00:15 Claimco sshd[23277]: Failed password for root from 61.177.173.2 port 37419 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 11:00:20 Claimco sshd[23277]: Received disconnect from 61.177.173.2 port 37419:11: [preauth] Dec 19 11:00:20 Claimco sshd[23277]: Disconnected from authenticating user root 61.177.173.2 port 37419 [preauth] Dec 19 11:00:20 Claimco sshd[23277]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:01:46 Claimco sshd[23592]: Connection from 61.177.173.2 port 63989 on 192.168.1.233 port 22 rdomain "" Dec 19 11:01:48 Claimco sshd[23592]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:01:49 Claimco sshd[23592]: Failed password for root from 61.177.173.2 port 63989 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:01:57 Claimco sshd[23592]: Received disconnect from 61.177.173.2 port 63989:11: [preauth] Dec 19 11:01:57 Claimco sshd[23592]: Disconnected from authenticating user root 61.177.173.2 port 63989 [preauth] Dec 19 11:01:57 Claimco sshd[23592]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:02:15 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:02:19 Claimco sshd[23719]: Connection from 61.177.173.46 port 25933 on 192.168.1.233 port 22 rdomain "" Dec 19 11:02:20 Claimco sshd[23719]: Received disconnect from 61.177.173.46 port 25933:11: [preauth] Dec 19 11:02:20 Claimco sshd[23719]: Disconnected from 61.177.173.46 port 25933 [preauth] Dec 19 11:03:23 Claimco sshd[23955]: Connection from 61.177.173.2 port 37950 on 192.168.1.233 port 22 rdomain "" Dec 19 11:03:25 Claimco sshd[23955]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:03:26 Claimco sshd[23955]: Failed password for root from 61.177.173.2 port 37950 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:03:34 Claimco sshd[23955]: Received disconnect from 61.177.173.2 port 37950:11: [preauth] Dec 19 11:03:34 Claimco sshd[23955]: Disconnected from authenticating user root 61.177.173.2 port 37950 [preauth] Dec 19 11:03:34 Claimco sshd[23955]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:04:17 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:05:02 Claimco sshd[24340]: Connection from 61.177.173.2 port 63926 on 192.168.1.233 port 22 rdomain "" Dec 19 11:05:03 Claimco sshd[24340]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:05:04 Claimco sshd[24340]: Failed password for root from 61.177.173.2 port 63926 ssh2 Dec 19 11:05:05 Claimco sshd[24350]: Connection from 61.177.172.61 port 18750 on 192.168.1.233 port 22 rdomain "" Dec 19 11:05:06 Claimco sshd[24350]: Unable to negotiate with 61.177.172.61 port 18750: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 11:05:07 Claimco sshd[24340]: Failed password for root from 61.177.173.2 port 63926 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 11:05:12 Claimco sshd[24340]: Received disconnect from 61.177.173.2 port 63926:11: [preauth] Dec 19 11:05:12 Claimco sshd[24340]: Disconnected from authenticating user root 61.177.173.2 port 63926 [preauth] Dec 19 11:05:12 Claimco sshd[24340]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:06:22 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:06:41 Claimco sshd[24707]: Connection from 61.177.173.2 port 42683 on 192.168.1.233 port 22 rdomain "" Dec 19 11:06:42 Claimco sshd[24707]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:06:45 Claimco sshd[24707]: Failed password for root from 61.177.173.2 port 42683 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:06:54 Claimco sshd[24707]: Received disconnect from 61.177.173.2 port 42683:11: [preauth] Dec 19 11:06:54 Claimco sshd[24707]: Disconnected from authenticating user root 61.177.173.2 port 42683 [preauth] Dec 19 11:06:54 Claimco sshd[24707]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:08:18 Claimco sshd[25268]: Connection from 61.177.173.2 port 64317 on 192.168.1.233 port 22 rdomain "" Dec 19 11:08:19 Claimco sshd[25268]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:08:21 Claimco sshd[25268]: Failed password for root from 61.177.173.2 port 64317 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 11:08:25 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:08:26 Claimco sshd[25268]: Failed password for root from 61.177.173.2 port 64317 ssh2 Dec 19 11:08:26 Claimco sshd[25268]: Received disconnect from 61.177.173.2 port 64317:11: [preauth] Dec 19 11:08:26 Claimco sshd[25268]: Disconnected from authenticating user root 61.177.173.2 port 64317 [preauth] Dec 19 11:08:26 Claimco sshd[25268]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:09:25 Claimco sshd[25546]: Connection from 61.177.173.46 port 44860 on 192.168.1.233 port 22 rdomain "" Dec 19 11:09:27 Claimco sshd[25546]: Received disconnect from 61.177.173.46 port 44860:11: [preauth] Dec 19 11:09:27 Claimco sshd[25546]: Disconnected from 61.177.173.46 port 44860 [preauth] Dec 19 11:09:55 Claimco sshd[25638]: Connection from 61.177.173.2 port 34196 on 192.168.1.233 port 22 rdomain "" Dec 19 11:09:56 Claimco sshd[25638]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:09:58 Claimco sshd[25638]: Failed password for root from 61.177.173.2 port 34196 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:10:06 Claimco sshd[25638]: Received disconnect from 61.177.173.2 port 34196:11: [preauth] Dec 19 11:10:06 Claimco sshd[25638]: Disconnected from authenticating user root 61.177.173.2 port 34196 [preauth] Dec 19 11:10:06 Claimco sshd[25638]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:10:07 Claimco sshd[25745]: Connection from 61.177.173.39 port 10740 on 192.168.1.233 port 22 rdomain "" Dec 19 11:10:08 Claimco sshd[25745]: Received disconnect from 61.177.173.39 port 10740:11: [preauth] Dec 19 11:10:08 Claimco sshd[25745]: Disconnected from 61.177.173.39 port 10740 [preauth] Dec 19 11:10:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:11:37 Claimco sshd[26046]: Connection from 61.177.173.2 port 39331 on 192.168.1.233 port 22 rdomain "" Dec 19 11:11:38 Claimco sshd[26046]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:11:40 Claimco sshd[26046]: Failed password for root from 61.177.173.2 port 39331 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:11:48 Claimco sshd[26046]: Received disconnect from 61.177.173.2 port 39331:11: [preauth] Dec 19 11:11:48 Claimco sshd[26046]: Disconnected from authenticating user root 61.177.173.2 port 39331 [preauth] Dec 19 11:11:48 Claimco sshd[26046]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:12:12 Claimco sshd[26177]: Connection from 61.177.172.98 port 28678 on 192.168.1.233 port 22 rdomain "" Dec 19 11:12:14 Claimco sshd[26177]: Received disconnect from 61.177.172.98 port 28678:11: [preauth] Dec 19 11:12:14 Claimco sshd[26177]: Disconnected from 61.177.172.98 port 28678 [preauth] Dec 19 11:12:34 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:12:49 Claimco sshd[26283]: Connection from 61.177.173.52 port 37473 on 192.168.1.233 port 22 rdomain "" Dec 19 11:12:51 Claimco sshd[26283]: Received disconnect from 61.177.173.52 port 37473:11: [preauth] Dec 19 11:12:51 Claimco sshd[26283]: Disconnected from 61.177.173.52 port 37473 [preauth] Dec 19 11:13:14 Claimco sshd[26410]: Connection from 61.177.173.2 port 55043 on 192.168.1.233 port 22 rdomain "" Dec 19 11:13:15 Claimco sshd[26410]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:13:16 Claimco sshd[26410]: Failed password for root from 61.177.173.2 port 55043 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:13:22 Claimco sshd[26410]: Received disconnect from 61.177.173.2 port 55043:11: [preauth] Dec 19 11:13:22 Claimco sshd[26410]: Disconnected from authenticating user root 61.177.173.2 port 55043 [preauth] Dec 19 11:13:22 Claimco sshd[26410]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:14:11 Claimco sshd[26642]: Connection from 65.2.28.105 port 42226 on 192.168.1.233 port 22 rdomain "" Dec 19 11:14:12 Claimco sshd[26642]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=65.2.28.105 user=root Dec 19 11:14:14 Claimco sshd[26642]: Failed password for root from 65.2.28.105 port 42226 ssh2 Dec 19 11:14:15 Claimco sshd[26642]: Connection closed by authenticating user root 65.2.28.105 port 42226 [preauth] Dec 19 11:14:45 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:14:51 Claimco sshd[26754]: Connection from 61.177.173.2 port 25168 on 192.168.1.233 port 22 rdomain "" Dec 19 11:14:52 Claimco sshd[26754]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:14:53 Claimco sshd[26754]: Failed password for root from 61.177.173.2 port 25168 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:14:59 Claimco sshd[26754]: Received disconnect from 61.177.173.2 port 25168:11: [preauth] Dec 19 11:14:59 Claimco sshd[26754]: Disconnected from authenticating user root 61.177.173.2 port 25168 [preauth] Dec 19 11:14:59 Claimco sshd[26754]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:14:59 Claimco sshd[26775]: Connection from 87.236.176.231 port 55635 on 192.168.1.233 port 22 rdomain "" Dec 19 11:15:01 Claimco sshd[26775]: error: kex_exchange_identification: Connection closed by remote host Dec 19 11:15:01 Claimco sshd[26775]: Connection closed by 87.236.176.231 port 55635 Dec 19 11:15:01 Claimco sshd[26840]: Connection from 87.236.176.231 port 48845 on 192.168.1.233 port 22 rdomain "" Dec 19 11:15:02 Claimco sshd[26840]: Connection closed by 87.236.176.231 port 48845 [preauth] Dec 19 11:16:28 Claimco sshd[27150]: Connection from 61.177.173.2 port 58320 on 192.168.1.233 port 22 rdomain "" Dec 19 11:16:30 Claimco sshd[27150]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:16:32 Claimco sshd[27150]: Failed password for root from 61.177.173.2 port 58320 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:16:40 Claimco sshd[27205]: Connection from 61.177.173.49 port 61908 on 192.168.1.233 port 22 rdomain "" Dec 19 11:16:41 Claimco sshd[27150]: Received disconnect from 61.177.173.2 port 58320:11: [preauth] Dec 19 11:16:41 Claimco sshd[27150]: Disconnected from authenticating user root 61.177.173.2 port 58320 [preauth] Dec 19 11:16:41 Claimco sshd[27150]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:16:41 Claimco sshd[27205]: Received disconnect from 61.177.173.49 port 61908:11: [preauth] Dec 19 11:16:41 Claimco sshd[27205]: Disconnected from 61.177.173.49 port 61908 [preauth] Dec 19 11:16:46 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:17:24 Claimco sshd[27354]: Connection from 61.177.172.114 port 29197 on 192.168.1.233 port 22 rdomain "" Dec 19 11:17:26 Claimco sshd[27354]: Received disconnect from 61.177.172.114 port 29197:11: [preauth] Dec 19 11:17:26 Claimco sshd[27354]: Disconnected from 61.177.172.114 port 29197 [preauth] Dec 19 11:18:09 Claimco sshd[27751]: Connection from 61.177.173.2 port 46621 on 192.168.1.233 port 22 rdomain "" Dec 19 11:18:10 Claimco sshd[27751]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:18:12 Claimco sshd[27751]: Failed password for root from 61.177.173.2 port 46621 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:18:17 Claimco sshd[27751]: Received disconnect from 61.177.173.2 port 46621:11: [preauth] Dec 19 11:18:17 Claimco sshd[27751]: Disconnected from authenticating user root 61.177.173.2 port 46621 [preauth] Dec 19 11:18:17 Claimco sshd[27751]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:18:48 Claimco sshd[27891]: Connection from 61.177.173.48 port 41682 on 192.168.1.233 port 22 rdomain "" Dec 19 11:18:49 Claimco sshd[27891]: Received disconnect from 61.177.173.48 port 41682:11: [preauth] Dec 19 11:18:49 Claimco sshd[27891]: Disconnected from 61.177.173.48 port 41682 [preauth] Dec 19 11:18:52 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:19:48 Claimco sshd[28102]: Connection from 61.177.173.2 port 21838 on 192.168.1.233 port 22 rdomain "" Dec 19 11:19:49 Claimco sshd[28102]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:19:51 Claimco sshd[28102]: Failed password for root from 61.177.173.2 port 21838 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:19:58 Claimco sshd[28102]: Received disconnect from 61.177.173.2 port 21838:11: [preauth] Dec 19 11:19:58 Claimco sshd[28102]: Disconnected from authenticating user root 61.177.173.2 port 21838 [preauth] Dec 19 11:19:58 Claimco sshd[28102]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:20:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:21:27 Claimco sshd[28497]: Connection from 61.177.173.2 port 59718 on 192.168.1.233 port 22 rdomain "" Dec 19 11:21:28 Claimco sshd[28497]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:21:29 Claimco sshd[28497]: Failed password for root from 61.177.173.2 port 59718 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:21:35 Claimco sshd[28497]: Received disconnect from 61.177.173.2 port 59718:11: [preauth] Dec 19 11:21:35 Claimco sshd[28497]: Disconnected from authenticating user root 61.177.173.2 port 59718 [preauth] Dec 19 11:21:35 Claimco sshd[28497]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:23:04 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:23:05 Claimco sshd[28866]: Connection from 61.177.173.2 port 38029 on 192.168.1.233 port 22 rdomain "" Dec 19 11:23:06 Claimco sshd[28866]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:23:08 Claimco sshd[28866]: Failed password for root from 61.177.173.2 port 38029 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:23:18 Claimco sshd[28866]: Received disconnect from 61.177.173.2 port 38029:11: [preauth] Dec 19 11:23:18 Claimco sshd[28866]: Disconnected from authenticating user root 61.177.173.2 port 38029 [preauth] Dec 19 11:23:18 Claimco sshd[28866]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:23:59 Claimco sshd[29058]: Connection from 61.177.173.51 port 51716 on 192.168.1.233 port 22 rdomain "" Dec 19 11:24:00 Claimco sshd[29058]: Received disconnect from 61.177.173.51 port 51716:11: [preauth] Dec 19 11:24:00 Claimco sshd[29058]: Disconnected from 61.177.173.51 port 51716 [preauth] Dec 19 11:24:22 Claimco sshd[29164]: Connection from 61.177.172.104 port 32451 on 192.168.1.233 port 22 rdomain "" Dec 19 11:24:44 Claimco sshd[29216]: Connection from 61.177.173.2 port 16174 on 192.168.1.233 port 22 rdomain "" Dec 19 11:24:45 Claimco sshd[29216]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:24:47 Claimco sshd[29216]: Failed password for root from 61.177.173.2 port 16174 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:24:55 Claimco sshd[29216]: Received disconnect from 61.177.173.2 port 16174:11: [preauth] Dec 19 11:24:55 Claimco sshd[29216]: Disconnected from authenticating user root 61.177.173.2 port 16174 [preauth] Dec 19 11:24:55 Claimco sshd[29216]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:25:04 Claimco sshd[29320]: Connection from 61.177.172.98 port 20892 on 192.168.1.233 port 22 rdomain "" Dec 19 11:25:04 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:25:05 Claimco sshd[29320]: Received disconnect from 61.177.172.98 port 20892:11: [preauth] Dec 19 11:25:05 Claimco sshd[29320]: Disconnected from 61.177.172.98 port 20892 [preauth] Dec 19 11:26:22 Claimco sshd[29164]: fatal: Timeout before authentication for 61.177.172.104 port 32451 Dec 19 11:26:25 Claimco sshd[29643]: Connection from 61.177.173.2 port 11871 on 192.168.1.233 port 22 rdomain "" Dec 19 11:26:26 Claimco sshd[29643]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:26:28 Claimco sshd[29643]: Failed password for root from 61.177.173.2 port 11871 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:26:35 Claimco sshd[29643]: Received disconnect from 61.177.173.2 port 11871:11: [preauth] Dec 19 11:26:35 Claimco sshd[29643]: Disconnected from authenticating user root 61.177.173.2 port 11871 [preauth] Dec 19 11:26:35 Claimco sshd[29643]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:27:12 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:27:21 Claimco sshd[29822]: Connection from 61.177.173.47 port 58525 on 192.168.1.233 port 22 rdomain "" Dec 19 11:27:22 Claimco sshd[29822]: Received disconnect from 61.177.173.47 port 58525:11: [preauth] Dec 19 11:27:22 Claimco sshd[29822]: Disconnected from 61.177.173.47 port 58525 [preauth] Dec 19 11:28:02 Claimco sshd[30212]: Connection from 61.177.173.2 port 42531 on 192.168.1.233 port 22 rdomain "" Dec 19 11:28:04 Claimco sshd[30212]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:28:05 Claimco sshd[30212]: Failed password for root from 61.177.173.2 port 42531 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:28:11 Claimco sshd[30212]: Received disconnect from 61.177.173.2 port 42531:11: [preauth] Dec 19 11:28:11 Claimco sshd[30212]: Disconnected from authenticating user root 61.177.173.2 port 42531 [preauth] Dec 19 11:28:11 Claimco sshd[30212]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:29:17 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:29:41 Claimco sshd[30560]: Connection from 61.177.173.2 port 27846 on 192.168.1.233 port 22 rdomain "" Dec 19 11:29:42 Claimco sshd[30560]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:29:44 Claimco sshd[30560]: Failed password for root from 61.177.173.2 port 27846 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:29:54 Claimco sshd[30560]: Received disconnect from 61.177.173.2 port 27846:11: [preauth] Dec 19 11:29:54 Claimco sshd[30560]: Disconnected from authenticating user root 61.177.173.2 port 27846 [preauth] Dec 19 11:29:54 Claimco sshd[30560]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:31:15 Claimco sshd[30944]: Connection from 61.177.173.50 port 60897 on 192.168.1.233 port 22 rdomain "" Dec 19 11:31:16 Claimco sshd[30944]: Received disconnect from 61.177.173.50 port 60897:11: [preauth] Dec 19 11:31:16 Claimco sshd[30944]: Disconnected from 61.177.173.50 port 60897 [preauth] Dec 19 11:31:19 Claimco sshd[30952]: Connection from 61.177.173.2 port 45744 on 192.168.1.233 port 22 rdomain "" Dec 19 11:31:19 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:31:20 Claimco sshd[30952]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:31:22 Claimco sshd[30952]: Failed password for root from 61.177.173.2 port 45744 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 11:31:26 Claimco sshd[30971]: Connection from 162.218.126.136 port 54840 on 192.168.1.233 port 22 rdomain "" Dec 19 11:31:27 Claimco sshd[30971]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=162.218.126.136 user=root Dec 19 11:31:29 Claimco sshd[30952]: Failed password for root from 61.177.173.2 port 45744 ssh2 Dec 19 11:31:29 Claimco sshd[30971]: Failed password for root from 162.218.126.136 port 54840 ssh2 Dec 19 11:31:31 Claimco sshd[30971]: Connection closed by authenticating user root 162.218.126.136 port 54840 [preauth] Dec 19 11:31:31 Claimco sshd[30952]: Received disconnect from 61.177.173.2 port 45744:11: [preauth] Dec 19 11:31:31 Claimco sshd[30952]: Disconnected from authenticating user root 61.177.173.2 port 45744 [preauth] Dec 19 11:31:31 Claimco sshd[30952]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:33:01 Claimco sshd[31282]: Connection from 61.177.173.2 port 51931 on 192.168.1.233 port 22 rdomain "" Dec 19 11:33:02 Claimco sshd[31282]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:33:04 Claimco sshd[31282]: Failed password for root from 61.177.173.2 port 51931 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:33:14 Claimco sshd[31282]: Received disconnect from 61.177.173.2 port 51931:11: [preauth] Dec 19 11:33:14 Claimco sshd[31282]: Disconnected from authenticating user root 61.177.173.2 port 51931 [preauth] Dec 19 11:33:14 Claimco sshd[31282]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:33:29 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:34:37 Claimco sshd[31699]: Connection from 61.177.173.2 port 12840 on 192.168.1.233 port 22 rdomain "" Dec 19 11:34:38 Claimco sshd[31699]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:34:40 Claimco sshd[31699]: Failed password for root from 61.177.173.2 port 12840 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:34:47 Claimco sshd[31699]: Received disconnect from 61.177.173.2 port 12840:11: [preauth] Dec 19 11:34:47 Claimco sshd[31699]: Disconnected from authenticating user root 61.177.173.2 port 12840 [preauth] Dec 19 11:34:47 Claimco sshd[31699]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:35:29 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:35:41 Claimco sshd[31966]: Connection from 61.177.172.104 port 48905 on 192.168.1.233 port 22 rdomain "" Dec 19 11:35:50 Claimco sshd[31985]: Connection from 61.177.173.35 port 17042 on 192.168.1.233 port 22 rdomain "" Dec 19 11:35:51 Claimco sshd[31985]: Received disconnect from 61.177.173.35 port 17042:11: [preauth] Dec 19 11:35:51 Claimco sshd[31985]: Disconnected from 61.177.173.35 port 17042 [preauth] Dec 19 11:36:15 Claimco sshd[32096]: Connection from 61.177.173.2 port 45132 on 192.168.1.233 port 22 rdomain "" Dec 19 11:36:16 Claimco sshd[32096]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:36:18 Claimco sshd[32096]: Failed password for root from 61.177.173.2 port 45132 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:36:26 Claimco sshd[32096]: Received disconnect from 61.177.173.2 port 45132:11: [preauth] Dec 19 11:36:26 Claimco sshd[32096]: Disconnected from authenticating user root 61.177.173.2 port 45132 [preauth] Dec 19 11:36:26 Claimco sshd[32096]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:37:01 Claimco sshd[32256]: Connection from 61.177.172.76 port 61976 on 192.168.1.233 port 22 rdomain "" Dec 19 11:37:02 Claimco sshd[32256]: Unable to negotiate with 61.177.172.76 port 61976: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 11:37:40 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:37:41 Claimco sshd[31966]: fatal: Timeout before authentication for 61.177.172.104 port 48905 Dec 19 11:37:56 Claimco sshd[32426]: Connection from 61.177.173.2 port 40535 on 192.168.1.233 port 22 rdomain "" Dec 19 11:37:57 Claimco sshd[32426]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:38:00 Claimco sshd[32426]: Failed password for root from 61.177.173.2 port 40535 ssh2 Dec 19 11:38:00 Claimco sshd[32632]: Connection from 61.177.172.108 port 27570 on 192.168.1.233 port 22 rdomain "" Dec 19 11:38:01 Claimco sshd[32632]: Received disconnect from 61.177.172.108 port 27570:11: [preauth] Dec 19 11:38:01 Claimco sshd[32632]: Disconnected from 61.177.172.108 port 27570 [preauth] Dec 19 11:38:04 Claimco sshd[32426]: Failed password for root from 61.177.173.2 port 40535 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 11:38:07 Claimco sshd[32426]: Received disconnect from 61.177.173.2 port 40535:11: [preauth] Dec 19 11:38:07 Claimco sshd[32426]: Disconnected from authenticating user root 61.177.173.2 port 40535 [preauth] Dec 19 11:38:07 Claimco sshd[32426]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:38:37 Claimco sshd[347]: Connection from 61.177.173.46 port 32422 on 192.168.1.233 port 22 rdomain "" Dec 19 11:38:38 Claimco sshd[347]: Received disconnect from 61.177.173.46 port 32422:11: [preauth] Dec 19 11:38:38 Claimco sshd[347]: Disconnected from 61.177.173.46 port 32422 [preauth] Dec 19 11:39:33 Claimco sshd[558]: Connection from 61.177.173.2 port 61561 on 192.168.1.233 port 22 rdomain "" Dec 19 11:39:34 Claimco sshd[558]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:39:35 Claimco sshd[558]: Failed password for root from 61.177.173.2 port 61561 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:39:42 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:39:43 Claimco sshd[558]: Received disconnect from 61.177.173.2 port 61561:11: [preauth] Dec 19 11:39:43 Claimco sshd[558]: Disconnected from authenticating user root 61.177.173.2 port 61561 [preauth] Dec 19 11:39:43 Claimco sshd[558]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:41:13 Claimco sshd[994]: Connection from 61.177.173.2 port 52102 on 192.168.1.233 port 22 rdomain "" Dec 19 11:41:14 Claimco sshd[994]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:41:16 Claimco sshd[994]: Failed password for root from 61.177.173.2 port 52102 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:41:21 Claimco sshd[994]: Received disconnect from 61.177.173.2 port 52102:11: [preauth] Dec 19 11:41:21 Claimco sshd[994]: Disconnected from authenticating user root 61.177.173.2 port 52102 [preauth] Dec 19 11:41:21 Claimco sshd[994]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:41:48 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 11:42:50 Claimco sshd[1347]: Connection from 61.177.173.2 port 25193 on 192.168.1.233 port 22 rdomain "" Dec 19 11:42:52 Claimco sshd[1347]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:42:54 Claimco sshd[1347]: Failed password for root from 61.177.173.2 port 25193 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:43:03 Claimco sshd[1347]: Received disconnect from 61.177.173.2 port 25193:11: [preauth] Dec 19 11:43:03 Claimco sshd[1347]: Disconnected from authenticating user root 61.177.173.2 port 25193 [preauth] Dec 19 11:43:03 Claimco sshd[1347]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:43:52 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:44:31 Claimco sshd[1745]: Connection from 61.177.173.2 port 15272 on 192.168.1.233 port 22 rdomain "" Dec 19 11:44:32 Claimco sshd[1745]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:44:34 Claimco sshd[1757]: Connection from 61.177.173.35 port 22281 on 192.168.1.233 port 22 rdomain "" Dec 19 11:44:35 Claimco sshd[1745]: Failed password for root from 61.177.173.2 port 15272 ssh2 Dec 19 11:44:35 Claimco sshd[1757]: Received disconnect from 61.177.173.35 port 22281:11: [preauth] Dec 19 11:44:35 Claimco sshd[1757]: Disconnected from 61.177.173.35 port 22281 [preauth] Dec 19 11:44:40 Claimco sshd[1745]: Failed password for root from 61.177.173.2 port 15272 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 11:44:44 Claimco sshd[1745]: Received disconnect from 61.177.173.2 port 15272:11: [preauth] Dec 19 11:44:44 Claimco sshd[1745]: Disconnected from authenticating user root 61.177.173.2 port 15272 [preauth] Dec 19 11:44:44 Claimco sshd[1745]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:44:51 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:45:02 Claimco sshd[1894]: Connection from 61.177.173.52 port 15330 on 192.168.1.233 port 22 rdomain "" Dec 19 11:45:54 Claimco sshd[2098]: Connection from 61.177.173.53 port 61358 on 192.168.1.233 port 22 rdomain "" Dec 19 11:45:55 Claimco sshd[2098]: Received disconnect from 61.177.173.53 port 61358:11: [preauth] Dec 19 11:45:55 Claimco sshd[2098]: Disconnected from 61.177.173.53 port 61358 [preauth] Dec 19 11:45:59 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:46:09 Claimco sshd[2164]: Connection from 61.177.173.2 port 39588 on 192.168.1.233 port 22 rdomain "" Dec 19 11:46:10 Claimco sshd[2164]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:46:12 Claimco sshd[2164]: Failed password for root from 61.177.173.2 port 39588 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:46:17 Claimco sshd[2164]: Received disconnect from 61.177.173.2 port 39588:11: [preauth] Dec 19 11:46:17 Claimco sshd[2164]: Disconnected from authenticating user root 61.177.173.2 port 39588 [preauth] Dec 19 11:46:17 Claimco sshd[2164]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:47:02 Claimco sshd[1894]: fatal: Timeout before authentication for 61.177.173.52 port 15330 Dec 19 11:47:04 Claimco sshd[2367]: Connection from 218.92.0.221 port 22427 on 192.168.1.233 port 22 rdomain "" Dec 19 11:47:09 Claimco sshd[2367]: Received disconnect from 218.92.0.221 port 22427:11: [preauth] Dec 19 11:47:09 Claimco sshd[2367]: Disconnected from 218.92.0.221 port 22427 [preauth] Dec 19 11:47:47 Claimco sshd[2485]: Connection from 61.177.173.2 port 17665 on 192.168.1.233 port 22 rdomain "" Dec 19 11:47:48 Claimco sshd[2485]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:47:50 Claimco sshd[2485]: Failed password for root from 61.177.173.2 port 17665 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:47:55 Claimco sshd[2485]: Received disconnect from 61.177.173.2 port 17665:11: [preauth] Dec 19 11:47:55 Claimco sshd[2485]: Disconnected from authenticating user root 61.177.173.2 port 17665 [preauth] Dec 19 11:47:55 Claimco sshd[2485]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:47:59 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:49:03 Claimco sshd[3034]: Connection from 84.110.99.202 port 36856 on 192.168.1.233 port 22 rdomain "" Dec 19 11:49:04 Claimco sshd[3034]: Invalid user zxc from 84.110.99.202 port 36856 Dec 19 11:49:04 Claimco sshd[3034]: pam_unix(sshd:auth): check pass; user unknown Dec 19 11:49:04 Claimco sshd[3034]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=84.110.99.202 Dec 19 11:49:06 Claimco sshd[3034]: Failed password for invalid user zxc from 84.110.99.202 port 36856 ssh2 Dec 19 11:49:06 Claimco sshd[3034]: Connection closed by invalid user zxc 84.110.99.202 port 36856 [preauth] Dec 19 11:49:25 Claimco sshd[3079]: Connection from 61.177.173.2 port 46707 on 192.168.1.233 port 22 rdomain "" Dec 19 11:49:26 Claimco sshd[3079]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:49:28 Claimco sshd[3079]: Failed password for root from 61.177.173.2 port 46707 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:49:35 Claimco sshd[3079]: Received disconnect from 61.177.173.2 port 46707:11: [preauth] Dec 19 11:49:35 Claimco sshd[3079]: Disconnected from authenticating user root 61.177.173.2 port 46707 [preauth] Dec 19 11:49:35 Claimco sshd[3079]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:50:08 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:50:15 Claimco sshd[3317]: Connection from 54.173.79.66 port 55362 on 192.168.1.233 port 22 rdomain "" Dec 19 11:50:15 Claimco sshd[3317]: Connection closed by 54.173.79.66 port 55362 [preauth] Dec 19 11:51:09 Claimco sshd[3517]: Connection from 61.177.173.2 port 11733 on 192.168.1.233 port 22 rdomain "" Dec 19 11:51:10 Claimco sshd[3517]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:51:10 Claimco sshd[3521]: Connection from 61.177.172.124 port 31406 on 192.168.1.233 port 22 rdomain "" Dec 19 11:51:11 Claimco sshd[3521]: Received disconnect from 61.177.172.124 port 31406:11: [preauth] Dec 19 11:51:11 Claimco sshd[3521]: Disconnected from 61.177.172.124 port 31406 [preauth] Dec 19 11:51:12 Claimco sshd[3517]: Failed password for root from 61.177.173.2 port 11733 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:51:19 Claimco sshd[3517]: Received disconnect from 61.177.173.2 port 11733:11: [preauth] Dec 19 11:51:19 Claimco sshd[3517]: Disconnected from authenticating user root 61.177.173.2 port 11733 [preauth] Dec 19 11:51:19 Claimco sshd[3517]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:51:53 Claimco sshd[3639]: Connection from 192.241.209.58 port 36820 on 192.168.1.233 port 22 rdomain "" Dec 19 11:51:53 Claimco sshd[3639]: error: kex_exchange_identification: client sent invalid protocol identifier "MGLNDD_70.130.120.50_22" Dec 19 11:51:53 Claimco sshd[3639]: banner exchange: Connection from 192.241.209.58 port 36820: invalid format Dec 19 11:51:54 Claimco sshd[3642]: Connection from 92.46.108.20 port 46566 on 192.168.1.233 port 22 rdomain "" Dec 19 11:51:55 Claimco sshd[3642]: Invalid user test2 from 92.46.108.20 port 46566 Dec 19 11:51:55 Claimco sshd[3642]: pam_unix(sshd:auth): check pass; user unknown Dec 19 11:51:55 Claimco sshd[3642]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=92.46.108.20 Dec 19 11:51:58 Claimco sshd[3642]: Failed password for invalid user test2 from 92.46.108.20 port 46566 ssh2 Dec 19 11:51:59 Claimco sshd[3642]: Connection closed by invalid user test2 92.46.108.20 port 46566 [preauth] Dec 19 11:52:13 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:52:42 Claimco sshd[3844]: Connection from 61.177.173.2 port 59788 on 192.168.1.233 port 22 rdomain "" Dec 19 11:52:43 Claimco sshd[3844]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:52:45 Claimco sshd[3844]: Failed password for root from 61.177.173.2 port 59788 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:52:50 Claimco sshd[3844]: Received disconnect from 61.177.173.2 port 59788:11: [preauth] Dec 19 11:52:50 Claimco sshd[3844]: Disconnected from authenticating user root 61.177.173.2 port 59788 [preauth] Dec 19 11:52:50 Claimco sshd[3844]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:53:09 Claimco sshd[3960]: Connection from 61.177.173.53 port 64611 on 192.168.1.233 port 22 rdomain "" Dec 19 11:53:10 Claimco sshd[3960]: Received disconnect from 61.177.173.53 port 64611:11: [preauth] Dec 19 11:53:10 Claimco sshd[3960]: Disconnected from 61.177.173.53 port 64611 [preauth] Dec 19 11:53:10 Claimco sshd[3964]: Connection from 61.177.173.35 port 22007 on 192.168.1.233 port 22 rdomain "" Dec 19 11:53:11 Claimco sshd[3964]: Received disconnect from 61.177.173.35 port 22007:11: [preauth] Dec 19 11:53:11 Claimco sshd[3964]: Disconnected from 61.177.173.35 port 22007 [preauth] Dec 19 11:54:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:54:21 Claimco sshd[4244]: Connection from 61.177.173.2 port 49709 on 192.168.1.233 port 22 rdomain "" Dec 19 11:54:22 Claimco sshd[4244]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:54:24 Claimco sshd[4244]: Failed password for root from 61.177.173.2 port 49709 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:54:32 Claimco sshd[4244]: Received disconnect from 61.177.173.2 port 49709:11: [preauth] Dec 19 11:54:32 Claimco sshd[4244]: Disconnected from authenticating user root 61.177.173.2 port 49709 [preauth] Dec 19 11:54:32 Claimco sshd[4244]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:56:00 Claimco sshd[4610]: Connection from 61.177.173.2 port 29318 on 192.168.1.233 port 22 rdomain "" Dec 19 11:56:02 Claimco sshd[4610]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:56:04 Claimco sshd[4610]: Failed password for root from 61.177.173.2 port 29318 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:56:15 Claimco sshd[4610]: Received disconnect from 61.177.173.2 port 29318:11: [preauth] Dec 19 11:56:15 Claimco sshd[4610]: Disconnected from authenticating user root 61.177.173.2 port 29318 [preauth] Dec 19 11:56:15 Claimco sshd[4610]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:56:27 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:57:40 Claimco sshd[4966]: Connection from 61.177.173.2 port 10215 on 192.168.1.233 port 22 rdomain "" Dec 19 11:57:42 Claimco sshd[4966]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:57:43 Claimco sshd[4966]: Failed password for root from 61.177.173.2 port 10215 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:57:53 Claimco sshd[4966]: Received disconnect from 61.177.173.2 port 10215:11: [preauth] Dec 19 11:57:53 Claimco sshd[4966]: Disconnected from authenticating user root 61.177.173.2 port 10215 [preauth] Dec 19 11:57:53 Claimco sshd[4966]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:58:32 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 11:58:33 Claimco sshd[5357]: Connection from 61.177.173.52 port 32936 on 192.168.1.233 port 22 rdomain "" Dec 19 11:59:18 Claimco sshd[5566]: Connection from 61.177.173.2 port 40569 on 192.168.1.233 port 22 rdomain "" Dec 19 11:59:19 Claimco sshd[5566]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 11:59:21 Claimco sshd[5566]: Failed password for root from 61.177.173.2 port 40569 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 11:59:27 Claimco sshd[5566]: Received disconnect from 61.177.173.2 port 40569:11: [preauth] Dec 19 11:59:27 Claimco sshd[5566]: Disconnected from authenticating user root 61.177.173.2 port 40569 [preauth] Dec 19 11:59:27 Claimco sshd[5566]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:00:26 Claimco sshd[5855]: Connection from 61.177.173.50 port 39462 on 192.168.1.233 port 22 rdomain "" Dec 19 12:00:27 Claimco sshd[5855]: Received disconnect from 61.177.173.50 port 39462:11: [preauth] Dec 19 12:00:27 Claimco sshd[5855]: Disconnected from 61.177.173.50 port 39462 [preauth] Dec 19 12:00:33 Claimco sshd[5357]: fatal: Timeout before authentication for 61.177.173.52 port 32936 Dec 19 12:00:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:00:57 Claimco sshd[5949]: Connection from 61.177.173.2 port 20608 on 192.168.1.233 port 22 rdomain "" Dec 19 12:00:58 Claimco sshd[5949]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:00:59 Claimco sshd[5949]: Failed password for root from 61.177.173.2 port 20608 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:01:07 Claimco sshd[5949]: Received disconnect from 61.177.173.2 port 20608:11: [preauth] Dec 19 12:01:07 Claimco sshd[5949]: Disconnected from authenticating user root 61.177.173.2 port 20608 [preauth] Dec 19 12:01:07 Claimco sshd[5949]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:01:40 Claimco sshd[6104]: Connection from 61.177.173.48 port 54425 on 192.168.1.233 port 22 rdomain "" Dec 19 12:01:41 Claimco sshd[6104]: Received disconnect from 61.177.173.48 port 54425:11: [preauth] Dec 19 12:01:41 Claimco sshd[6104]: Disconnected from 61.177.173.48 port 54425 [preauth] Dec 19 12:02:36 Claimco sshd[6307]: Connection from 61.177.173.2 port 54784 on 192.168.1.233 port 22 rdomain "" Dec 19 12:02:37 Claimco sshd[6307]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:02:39 Claimco sshd[6307]: Failed password for root from 61.177.173.2 port 54784 ssh2 Dec 19 12:02:42 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:02:44 Claimco sshd[6307]: Failed password for root from 61.177.173.2 port 54784 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 12:02:49 Claimco sshd[6307]: Received disconnect from 61.177.173.2 port 54784:11: [preauth] Dec 19 12:02:49 Claimco sshd[6307]: Disconnected from authenticating user root 61.177.173.2 port 54784 [preauth] Dec 19 12:02:49 Claimco sshd[6307]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:04:07 Claimco sshd[6684]: Connection from 61.177.172.19 port 14827 on 192.168.1.233 port 22 rdomain "" Dec 19 12:04:14 Claimco sshd[6697]: Connection from 61.177.173.2 port 28681 on 192.168.1.233 port 22 rdomain "" Dec 19 12:04:15 Claimco sshd[6697]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:04:17 Claimco sshd[6697]: Failed password for root from 61.177.173.2 port 28681 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:04:24 Claimco sshd[6697]: Received disconnect from 61.177.173.2 port 28681:11: [preauth] Dec 19 12:04:24 Claimco sshd[6697]: Disconnected from authenticating user root 61.177.173.2 port 28681 [preauth] Dec 19 12:04:24 Claimco sshd[6697]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:04:40 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:05:08 Claimco sshd[6971]: Connection from 61.177.172.114 port 34970 on 192.168.1.233 port 22 rdomain "" Dec 19 12:05:10 Claimco sshd[6971]: Received disconnect from 61.177.172.114 port 34970:11: [preauth] Dec 19 12:05:10 Claimco sshd[6971]: Disconnected from 61.177.172.114 port 34970 [preauth] Dec 19 12:05:54 Claimco sshd[7095]: Connection from 61.177.173.2 port 26220 on 192.168.1.233 port 22 rdomain "" Dec 19 12:05:55 Claimco sshd[7095]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:05:57 Claimco sshd[7095]: Failed password for root from 61.177.173.2 port 26220 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:06:02 Claimco sshd[7095]: Received disconnect from 61.177.173.2 port 26220:11: [preauth] Dec 19 12:06:02 Claimco sshd[7095]: Disconnected from authenticating user root 61.177.173.2 port 26220 [preauth] Dec 19 12:06:02 Claimco sshd[7095]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:06:07 Claimco sshd[6684]: fatal: Timeout before authentication for 61.177.172.19 port 14827 Dec 19 12:06:46 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:07:32 Claimco sshd[7575]: Connection from 61.177.173.2 port 55542 on 192.168.1.233 port 22 rdomain "" Dec 19 12:07:33 Claimco sshd[7575]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:07:35 Claimco sshd[7575]: Failed password for root from 61.177.173.2 port 55542 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:07:42 Claimco sshd[7607]: Connection from 61.177.173.51 port 14138 on 192.168.1.233 port 22 rdomain "" Dec 19 12:07:44 Claimco sshd[7607]: Received disconnect from 61.177.173.51 port 14138:11: [preauth] Dec 19 12:07:44 Claimco sshd[7607]: Disconnected from 61.177.173.51 port 14138 [preauth] Dec 19 12:07:45 Claimco sshd[7575]: Received disconnect from 61.177.173.2 port 55542:11: [preauth] Dec 19 12:07:45 Claimco sshd[7575]: Disconnected from authenticating user root 61.177.173.2 port 55542 [preauth] Dec 19 12:07:45 Claimco sshd[7575]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:08:57 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:09:03 Claimco sshd[8183]: Connection from 61.177.173.56 port 62146 on 192.168.1.233 port 22 rdomain "" Dec 19 12:09:03 Claimco sshd[8183]: Unable to negotiate with 61.177.173.56 port 62146: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 12:09:11 Claimco sshd[8224]: Connection from 61.177.173.2 port 31857 on 192.168.1.233 port 22 rdomain "" Dec 19 12:09:12 Claimco sshd[8224]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:09:14 Claimco sshd[8224]: Failed password for root from 61.177.173.2 port 31857 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:09:19 Claimco sshd[8224]: Received disconnect from 61.177.173.2 port 31857:11: [preauth] Dec 19 12:09:19 Claimco sshd[8224]: Disconnected from authenticating user root 61.177.173.2 port 31857 [preauth] Dec 19 12:09:19 Claimco sshd[8224]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:09:41 Claimco sshd[8318]: Connection from 61.177.173.37 port 28358 on 192.168.1.233 port 22 rdomain "" Dec 19 12:09:42 Claimco sshd[8318]: Received disconnect from 61.177.173.37 port 28358:11: [preauth] Dec 19 12:09:42 Claimco sshd[8318]: Disconnected from 61.177.173.37 port 28358 [preauth] Dec 19 12:10:20 Claimco sshd[8504]: Connection from 61.177.173.39 port 20778 on 192.168.1.233 port 22 rdomain "" Dec 19 12:10:21 Claimco sshd[8504]: Received disconnect from 61.177.173.39 port 20778:11: [preauth] Dec 19 12:10:21 Claimco sshd[8504]: Disconnected from 61.177.173.39 port 20778 [preauth] Dec 19 12:10:52 Claimco sshd[8600]: Connection from 61.177.173.2 port 28566 on 192.168.1.233 port 22 rdomain "" Dec 19 12:10:53 Claimco sshd[8600]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:10:55 Claimco sshd[8600]: Failed password for root from 61.177.173.2 port 28566 ssh2 Dec 19 12:10:56 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:10:59 Claimco sshd[8600]: Failed password for root from 61.177.173.2 port 28566 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 12:11:02 Claimco sshd[8600]: Received disconnect from 61.177.173.2 port 28566:11: [preauth] Dec 19 12:11:02 Claimco sshd[8600]: Disconnected from authenticating user root 61.177.173.2 port 28566 [preauth] Dec 19 12:11:02 Claimco sshd[8600]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:12:28 Claimco sshd[8958]: Connection from 61.177.173.2 port 46302 on 192.168.1.233 port 22 rdomain "" Dec 19 12:12:29 Claimco sshd[8958]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:12:31 Claimco sshd[8958]: Failed password for root from 61.177.173.2 port 46302 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:12:39 Claimco sshd[8958]: Received disconnect from 61.177.173.2 port 46302:11: [preauth] Dec 19 12:12:39 Claimco sshd[8958]: Disconnected from authenticating user root 61.177.173.2 port 46302 [preauth] Dec 19 12:12:39 Claimco sshd[8958]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:13:01 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:14:08 Claimco sshd[9344]: Connection from 61.177.173.2 port 36129 on 192.168.1.233 port 22 rdomain "" Dec 19 12:14:09 Claimco sshd[9344]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:14:12 Claimco sshd[9344]: Failed password for root from 61.177.173.2 port 36129 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:14:23 Claimco sshd[9344]: Received disconnect from 61.177.173.2 port 36129:11: [preauth] Dec 19 12:14:23 Claimco sshd[9344]: Disconnected from authenticating user root 61.177.173.2 port 36129 [preauth] Dec 19 12:14:23 Claimco sshd[9344]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:14:46 Claimco sshd[9475]: Connection from 59.127.24.124 port 49820 on 192.168.1.233 port 22 rdomain "" Dec 19 12:14:47 Claimco sshd[9475]: Unable to negotiate with 59.127.24.124 port 49820: no matching host key type found. Their offer: ssh-rsa,ssh-dss [preauth] Dec 19 12:15:07 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:15:10 Claimco sshd[9607]: Connection from 61.177.173.53 port 57616 on 192.168.1.233 port 22 rdomain "" Dec 19 12:15:11 Claimco sshd[9607]: Received disconnect from 61.177.173.53 port 57616:11: [preauth] Dec 19 12:15:11 Claimco sshd[9607]: Disconnected from 61.177.173.53 port 57616 [preauth] Dec 19 12:15:48 Claimco sshd[9738]: Connection from 61.177.173.2 port 23578 on 192.168.1.233 port 22 rdomain "" Dec 19 12:15:50 Claimco sshd[9738]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:15:52 Claimco sshd[9738]: Failed password for root from 61.177.173.2 port 23578 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:15:57 Claimco sshd[9738]: Received disconnect from 61.177.173.2 port 23578:11: [preauth] Dec 19 12:15:57 Claimco sshd[9738]: Disconnected from authenticating user root 61.177.173.2 port 23578 [preauth] Dec 19 12:15:57 Claimco sshd[9738]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:17:15 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:17:23 Claimco sshd[10095]: Connection from 61.177.172.98 port 25483 on 192.168.1.233 port 22 rdomain "" Dec 19 12:17:24 Claimco sshd[10095]: Received disconnect from 61.177.172.98 port 25483:11: [preauth] Dec 19 12:17:24 Claimco sshd[10095]: Disconnected from 61.177.172.98 port 25483 [preauth] Dec 19 12:17:25 Claimco sshd[10100]: Connection from 61.177.173.2 port 38068 on 192.168.1.233 port 22 rdomain "" Dec 19 12:17:26 Claimco sshd[10100]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:17:27 Claimco sshd[10100]: Failed password for root from 61.177.173.2 port 38068 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:17:33 Claimco sshd[10100]: Received disconnect from 61.177.173.2 port 38068:11: [preauth] Dec 19 12:17:33 Claimco sshd[10100]: Disconnected from authenticating user root 61.177.173.2 port 38068 [preauth] Dec 19 12:17:33 Claimco sshd[10100]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:18:52 Claimco sshd[10627]: Connection from 61.177.173.36 port 62023 on 192.168.1.233 port 22 rdomain "" Dec 19 12:18:54 Claimco sshd[10627]: Received disconnect from 61.177.173.36 port 62023:11: [preauth] Dec 19 12:18:54 Claimco sshd[10627]: Disconnected from 61.177.173.36 port 62023 [preauth] Dec 19 12:19:04 Claimco sshd[10687]: Connection from 61.177.173.2 port 24639 on 192.168.1.233 port 22 rdomain "" Dec 19 12:19:05 Claimco sshd[10687]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:19:07 Claimco sshd[10687]: Failed password for root from 61.177.173.2 port 24639 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:19:12 Claimco sshd[10687]: Received disconnect from 61.177.173.2 port 24639:11: [preauth] Dec 19 12:19:12 Claimco sshd[10687]: Disconnected from authenticating user root 61.177.173.2 port 24639 [preauth] Dec 19 12:19:12 Claimco sshd[10687]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:19:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:20:41 Claimco sshd[11050]: Connection from 61.177.173.2 port 51731 on 192.168.1.233 port 22 rdomain "" Dec 19 12:20:42 Claimco sshd[11050]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:20:44 Claimco sshd[11050]: Failed password for root from 61.177.173.2 port 51731 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:20:51 Claimco sshd[11050]: Received disconnect from 61.177.173.2 port 51731:11: [preauth] Dec 19 12:20:51 Claimco sshd[11050]: Disconnected from authenticating user root 61.177.173.2 port 51731 [preauth] Dec 19 12:20:51 Claimco sshd[11050]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:21:19 Claimco sshd[11187]: Connection from 61.177.172.90 port 58680 on 192.168.1.233 port 22 rdomain "" Dec 19 12:21:19 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:21:20 Claimco sshd[11187]: Received disconnect from 61.177.172.90 port 58680:11: [preauth] Dec 19 12:21:20 Claimco sshd[11187]: Disconnected from 61.177.172.90 port 58680 [preauth] Dec 19 12:22:19 Claimco sshd[11414]: Connection from 61.177.173.2 port 22454 on 192.168.1.233 port 22 rdomain "" Dec 19 12:22:20 Claimco sshd[11414]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:22:21 Claimco sshd[11420]: Connection from 61.177.173.46 port 35148 on 192.168.1.233 port 22 rdomain "" Dec 19 12:22:22 Claimco sshd[11414]: Failed password for root from 61.177.173.2 port 22454 ssh2 Dec 19 12:22:23 Claimco sshd[11420]: Received disconnect from 61.177.173.46 port 35148:11: [preauth] Dec 19 12:22:23 Claimco sshd[11420]: Disconnected from 61.177.173.46 port 35148 [preauth] Dec 19 12:22:24 Claimco sshd[11414]: Failed password for root from 61.177.173.2 port 22454 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 12:22:30 Claimco sshd[11414]: Received disconnect from 61.177.173.2 port 22454:11: [preauth] Dec 19 12:22:30 Claimco sshd[11414]: Disconnected from authenticating user root 61.177.173.2 port 22454 [preauth] Dec 19 12:22:30 Claimco sshd[11414]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:23:31 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:23:58 Claimco sshd[11766]: Connection from 61.177.173.2 port 60990 on 192.168.1.233 port 22 rdomain "" Dec 19 12:24:00 Claimco sshd[11766]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:24:01 Claimco sshd[11766]: Failed password for root from 61.177.173.2 port 60990 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:24:09 Claimco sshd[11766]: Received disconnect from 61.177.173.2 port 60990:11: [preauth] Dec 19 12:24:09 Claimco sshd[11766]: Disconnected from authenticating user root 61.177.173.2 port 60990 [preauth] Dec 19 12:24:09 Claimco sshd[11766]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:25:29 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:25:36 Claimco sshd[12188]: Connection from 61.177.173.2 port 38041 on 192.168.1.233 port 22 rdomain "" Dec 19 12:25:38 Claimco sshd[12188]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:25:40 Claimco sshd[12188]: Failed password for root from 61.177.173.2 port 38041 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:25:47 Claimco sshd[12188]: Received disconnect from 61.177.173.2 port 38041:11: [preauth] Dec 19 12:25:47 Claimco sshd[12188]: Disconnected from authenticating user root 61.177.173.2 port 38041 [preauth] Dec 19 12:25:47 Claimco sshd[12188]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:27:16 Claimco sshd[12553]: Connection from 61.177.173.2 port 23306 on 192.168.1.233 port 22 rdomain "" Dec 19 12:27:17 Claimco sshd[12553]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:27:20 Claimco sshd[12553]: Failed password for root from 61.177.173.2 port 23306 ssh2 Dec 19 12:27:22 Claimco sshd[12567]: Connection from 61.177.173.35 port 63036 on 192.168.1.233 port 22 rdomain "" Dec 19 12:27:24 Claimco sshd[12553]: Failed password for root from 61.177.173.2 port 23306 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 12:27:27 Claimco sshd[12567]: Received disconnect from 61.177.173.35 port 63036:11: [preauth] Dec 19 12:27:27 Claimco sshd[12567]: Disconnected from 61.177.173.35 port 63036 [preauth] Dec 19 12:27:29 Claimco sshd[12553]: Received disconnect from 61.177.173.2 port 23306:11: [preauth] Dec 19 12:27:29 Claimco sshd[12553]: Disconnected from authenticating user root 61.177.173.2 port 23306 [preauth] Dec 19 12:27:29 Claimco sshd[12553]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:27:34 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:28:55 Claimco sshd[13106]: Connection from 61.177.173.2 port 57164 on 192.168.1.233 port 22 rdomain "" Dec 19 12:28:56 Claimco sshd[13106]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:28:58 Claimco sshd[13106]: Failed password for root from 61.177.173.2 port 57164 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:29:06 Claimco sshd[13106]: Received disconnect from 61.177.173.2 port 57164:11: [preauth] Dec 19 12:29:06 Claimco sshd[13106]: Disconnected from authenticating user root 61.177.173.2 port 57164 [preauth] Dec 19 12:29:06 Claimco sshd[13106]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:29:39 Claimco sshd[13259]: Connection from 61.177.173.46 port 36601 on 192.168.1.233 port 22 rdomain "" Dec 19 12:29:40 Claimco sshd[13259]: Received disconnect from 61.177.173.46 port 36601:11: [preauth] Dec 19 12:29:40 Claimco sshd[13259]: Disconnected from 61.177.173.46 port 36601 [preauth] Dec 19 12:29:41 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:30:24 Claimco sshd[13481]: Connection from 61.177.172.108 port 15099 on 192.168.1.233 port 22 rdomain "" Dec 19 12:30:25 Claimco sshd[13481]: Received disconnect from 61.177.172.108 port 15099:11: [preauth] Dec 19 12:30:25 Claimco sshd[13481]: Disconnected from 61.177.172.108 port 15099 [preauth] Dec 19 12:30:34 Claimco sshd[13502]: Connection from 61.177.173.2 port 33451 on 192.168.1.233 port 22 rdomain "" Dec 19 12:30:35 Claimco sshd[13502]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:30:36 Claimco sshd[13502]: Failed password for root from 61.177.173.2 port 33451 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:30:44 Claimco sshd[13502]: Received disconnect from 61.177.173.2 port 33451:11: [preauth] Dec 19 12:30:44 Claimco sshd[13502]: Disconnected from authenticating user root 61.177.173.2 port 33451 [preauth] Dec 19 12:30:44 Claimco sshd[13502]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:31:48 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:32:11 Claimco sshd[13869]: Connection from 61.177.173.2 port 60995 on 192.168.1.233 port 22 rdomain "" Dec 19 12:32:12 Claimco sshd[13869]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:32:14 Claimco sshd[13869]: Failed password for root from 61.177.173.2 port 60995 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:32:21 Claimco sshd[13869]: Received disconnect from 61.177.173.2 port 60995:11: [preauth] Dec 19 12:32:21 Claimco sshd[13869]: Disconnected from authenticating user root 61.177.173.2 port 60995 [preauth] Dec 19 12:32:21 Claimco sshd[13869]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:32:30 Claimco sshd[13933]: Connection from 218.92.0.221 port 59826 on 192.168.1.233 port 22 rdomain "" Dec 19 12:32:31 Claimco sshd[13933]: Received disconnect from 218.92.0.221 port 59826:11: [preauth] Dec 19 12:32:31 Claimco sshd[13933]: Disconnected from 218.92.0.221 port 59826 [preauth] Dec 19 12:33:24 Claimco sshd[14133]: Connection from 61.177.173.52 port 13241 on 192.168.1.233 port 22 rdomain "" Dec 19 12:33:25 Claimco sshd[14133]: Received disconnect from 61.177.173.52 port 13241:11: [preauth] Dec 19 12:33:25 Claimco sshd[14133]: Disconnected from 61.177.173.52 port 13241 [preauth] Dec 19 12:33:50 Claimco sshd[14244]: Connection from 61.177.173.2 port 43180 on 192.168.1.233 port 22 rdomain "" Dec 19 12:33:51 Claimco sshd[14244]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:33:53 Claimco sshd[14244]: Failed password for root from 61.177.173.2 port 43180 ssh2 Dec 19 12:33:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:33:56 Claimco sshd[14244]: Failed password for root from 61.177.173.2 port 43180 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 12:34:01 Claimco sshd[14244]: Received disconnect from 61.177.173.2 port 43180:11: [preauth] Dec 19 12:34:01 Claimco sshd[14244]: Disconnected from authenticating user root 61.177.173.2 port 43180 [preauth] Dec 19 12:34:01 Claimco sshd[14244]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:35:30 Claimco sshd[14646]: Connection from 61.177.173.2 port 35631 on 192.168.1.233 port 22 rdomain "" Dec 19 12:35:31 Claimco sshd[14646]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:35:33 Claimco sshd[14646]: Failed password for root from 61.177.173.2 port 35631 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:35:43 Claimco sshd[14646]: Received disconnect from 61.177.173.2 port 35631:11: [preauth] Dec 19 12:35:43 Claimco sshd[14646]: Disconnected from authenticating user root 61.177.173.2 port 35631 [preauth] Dec 19 12:35:43 Claimco sshd[14646]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:36:03 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:36:11 Claimco sshd[14795]: Connection from 61.177.173.47 port 30558 on 192.168.1.233 port 22 rdomain "" Dec 19 12:36:52 Claimco sshd[14906]: Connection from 61.177.173.50 port 56143 on 192.168.1.233 port 22 rdomain "" Dec 19 12:36:53 Claimco sshd[14906]: Received disconnect from 61.177.173.50 port 56143:11: [preauth] Dec 19 12:36:53 Claimco sshd[14906]: Disconnected from 61.177.173.50 port 56143 [preauth] Dec 19 12:37:08 Claimco sshd[15016]: Connection from 61.177.173.2 port 61825 on 192.168.1.233 port 22 rdomain "" Dec 19 12:37:09 Claimco sshd[15016]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:37:10 Claimco sshd[15016]: Failed password for root from 61.177.173.2 port 61825 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:37:16 Claimco sshd[15016]: Received disconnect from 61.177.173.2 port 61825:11: [preauth] Dec 19 12:37:16 Claimco sshd[15016]: Disconnected from authenticating user root 61.177.173.2 port 61825 [preauth] Dec 19 12:37:16 Claimco sshd[15016]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:38:03 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:38:11 Claimco sshd[14795]: fatal: Timeout before authentication for 61.177.173.47 port 30558 Dec 19 12:38:47 Claimco sshd[15564]: Connection from 61.177.173.2 port 50158 on 192.168.1.233 port 22 rdomain "" Dec 19 12:38:48 Claimco sshd[15564]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:38:50 Claimco sshd[15564]: Failed password for root from 61.177.173.2 port 50158 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:38:55 Claimco sshd[15564]: Received disconnect from 61.177.173.2 port 50158:11: [preauth] Dec 19 12:38:55 Claimco sshd[15564]: Disconnected from authenticating user root 61.177.173.2 port 50158 [preauth] Dec 19 12:38:55 Claimco sshd[15564]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:40:11 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:40:25 Claimco sshd[15959]: Connection from 61.177.173.2 port 19995 on 192.168.1.233 port 22 rdomain "" Dec 19 12:40:27 Claimco sshd[15959]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:40:28 Claimco sshd[15959]: Failed password for root from 61.177.173.2 port 19995 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:40:34 Claimco sshd[15959]: Received disconnect from 61.177.173.2 port 19995:11: [preauth] Dec 19 12:40:34 Claimco sshd[15959]: Disconnected from authenticating user root 61.177.173.2 port 19995 [preauth] Dec 19 12:40:34 Claimco sshd[15959]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:40:50 Claimco sshd[16041]: Connection from 61.177.172.61 port 44224 on 192.168.1.233 port 22 rdomain "" Dec 19 12:40:51 Claimco sshd[16041]: Unable to negotiate with 61.177.172.61 port 44224: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 12:41:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:42:07 Claimco sshd[16360]: Connection from 61.177.173.2 port 63723 on 192.168.1.233 port 22 rdomain "" Dec 19 12:42:08 Claimco sshd[16360]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:42:09 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:42:11 Claimco sshd[16360]: Failed password for root from 61.177.173.2 port 63723 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:42:18 Claimco sshd[16360]: Received disconnect from 61.177.173.2 port 63723:11: [preauth] Dec 19 12:42:18 Claimco sshd[16360]: Disconnected from authenticating user root 61.177.173.2 port 63723 [preauth] Dec 19 12:42:18 Claimco sshd[16360]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:43:33 Claimco sshd[16624]: Connection from 61.177.172.98 port 58885 on 192.168.1.233 port 22 rdomain "" Dec 19 12:43:34 Claimco sshd[16624]: Received disconnect from 61.177.172.98 port 58885:11: [preauth] Dec 19 12:43:34 Claimco sshd[16624]: Disconnected from 61.177.172.98 port 58885 [preauth] Dec 19 12:43:46 Claimco sshd[16711]: Connection from 61.177.173.2 port 42512 on 192.168.1.233 port 22 rdomain "" Dec 19 12:43:47 Claimco sshd[16711]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:43:49 Claimco sshd[16711]: Failed password for root from 61.177.173.2 port 42512 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:43:55 Claimco sshd[16711]: Received disconnect from 61.177.173.2 port 42512:11: [preauth] Dec 19 12:43:55 Claimco sshd[16711]: Disconnected from authenticating user root 61.177.173.2 port 42512 [preauth] Dec 19 12:43:55 Claimco sshd[16711]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:44:14 Claimco sshd[16828]: Connection from 61.177.173.49 port 37597 on 192.168.1.233 port 22 rdomain "" Dec 19 12:44:16 Claimco sshd[16828]: Received disconnect from 61.177.173.49 port 37597:11: [preauth] Dec 19 12:44:16 Claimco sshd[16828]: Disconnected from 61.177.173.49 port 37597 [preauth] Dec 19 12:44:20 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:44:21 Claimco sshd[16842]: Connection from 61.177.172.90 port 28472 on 192.168.1.233 port 22 rdomain "" Dec 19 12:44:22 Claimco sshd[16842]: Received disconnect from 61.177.172.90 port 28472:11: [preauth] Dec 19 12:44:22 Claimco sshd[16842]: Disconnected from 61.177.172.90 port 28472 [preauth] Dec 19 12:44:45 Claimco sshd[16924]: Connection from 61.177.173.47 port 24602 on 192.168.1.233 port 22 rdomain "" Dec 19 12:44:46 Claimco sshd[16924]: Received disconnect from 61.177.173.47 port 24602:11: [preauth] Dec 19 12:44:46 Claimco sshd[16924]: Disconnected from 61.177.173.47 port 24602 [preauth] Dec 19 12:45:18 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:45:26 Claimco sshd[17131]: Connection from 61.177.173.2 port 34327 on 192.168.1.233 port 22 rdomain "" Dec 19 12:45:27 Claimco sshd[17131]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:45:29 Claimco sshd[17131]: Failed password for root from 61.177.173.2 port 34327 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:45:37 Claimco sshd[17131]: Received disconnect from 61.177.173.2 port 34327:11: [preauth] Dec 19 12:45:37 Claimco sshd[17131]: Disconnected from authenticating user root 61.177.173.2 port 34327 [preauth] Dec 19 12:45:37 Claimco sshd[17131]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:46:25 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:47:07 Claimco sshd[17504]: Connection from 61.177.173.2 port 18174 on 192.168.1.233 port 22 rdomain "" Dec 19 12:47:08 Claimco sshd[17504]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:47:10 Claimco sshd[17504]: Failed password for root from 61.177.173.2 port 18174 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:47:19 Claimco sshd[17504]: Received disconnect from 61.177.173.2 port 18174:11: [preauth] Dec 19 12:47:19 Claimco sshd[17504]: Disconnected from authenticating user root 61.177.173.2 port 18174 [preauth] Dec 19 12:47:19 Claimco sshd[17504]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:48:25 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:48:55 Claimco sshd[18099]: Connection from 61.177.173.2 port 19812 on 192.168.1.233 port 22 rdomain "" Dec 19 12:48:56 Claimco sshd[18099]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:48:59 Claimco sshd[18099]: Failed password for root from 61.177.173.2 port 19812 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:49:06 Claimco sshd[18099]: Received disconnect from 61.177.173.2 port 19812:11: [preauth] Dec 19 12:49:06 Claimco sshd[18099]: Disconnected from authenticating user root 61.177.173.2 port 19812 [preauth] Dec 19 12:49:06 Claimco sshd[18099]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:50:23 Claimco sshd[18472]: Connection from 61.177.173.2 port 19711 on 192.168.1.233 port 22 rdomain "" Dec 19 12:50:24 Claimco sshd[18472]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:50:26 Claimco sshd[18472]: Failed password for root from 61.177.173.2 port 19711 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:50:31 Claimco sshd[18472]: Received disconnect from 61.177.173.2 port 19711:11: [preauth] Dec 19 12:50:31 Claimco sshd[18472]: Disconnected from authenticating user root 61.177.173.2 port 19711 [preauth] Dec 19 12:50:31 Claimco sshd[18472]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:50:36 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:51:28 Claimco sshd[18694]: Connection from 61.177.173.49 port 39779 on 192.168.1.233 port 22 rdomain "" Dec 19 12:51:31 Claimco sshd[18694]: Received disconnect from 61.177.173.49 port 39779:11: [preauth] Dec 19 12:51:31 Claimco sshd[18694]: Disconnected from 61.177.173.49 port 39779 [preauth] Dec 19 12:51:54 Claimco sshd[18777]: Connection from 61.177.172.114 port 39455 on 192.168.1.233 port 22 rdomain "" Dec 19 12:52:06 Claimco sshd[18853]: Connection from 61.177.173.2 port 32106 on 192.168.1.233 port 22 rdomain "" Dec 19 12:52:07 Claimco sshd[18853]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:52:09 Claimco sshd[18853]: Failed password for root from 61.177.173.2 port 32106 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:52:14 Claimco sshd[18853]: Received disconnect from 61.177.173.2 port 32106:11: [preauth] Dec 19 12:52:14 Claimco sshd[18853]: Disconnected from authenticating user root 61.177.173.2 port 32106 [preauth] Dec 19 12:52:14 Claimco sshd[18853]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:52:19 Claimco sshd[18881]: Connection from 65.2.28.105 port 59542 on 192.168.1.233 port 22 rdomain "" Dec 19 12:52:21 Claimco sshd[18881]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=65.2.28.105 user=root Dec 19 12:52:23 Claimco sshd[18881]: Failed password for root from 65.2.28.105 port 59542 ssh2 Dec 19 12:52:25 Claimco sshd[18881]: Connection closed by authenticating user root 65.2.28.105 port 59542 [preauth] Dec 19 12:52:37 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:53:21 Claimco sshd[19096]: Connection from 61.177.173.36 port 28397 on 192.168.1.233 port 22 rdomain "" Dec 19 12:53:22 Claimco sshd[19096]: Received disconnect from 61.177.173.36 port 28397:11: [preauth] Dec 19 12:53:22 Claimco sshd[19096]: Disconnected from 61.177.173.36 port 28397 [preauth] Dec 19 12:53:46 Claimco sshd[19205]: Connection from 61.177.173.2 port 25539 on 192.168.1.233 port 22 rdomain "" Dec 19 12:53:47 Claimco sshd[19205]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:53:50 Claimco sshd[19205]: Failed password for root from 61.177.173.2 port 25539 ssh2 Dec 19 12:53:54 Claimco sshd[18777]: fatal: Timeout before authentication for 61.177.172.114 port 39455 Dec 19 12:53:54 Claimco sshd[19205]: Failed password for root from 61.177.173.2 port 25539 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 12:53:57 Claimco sshd[19205]: Received disconnect from 61.177.173.2 port 25539:11: [preauth] Dec 19 12:53:57 Claimco sshd[19205]: Disconnected from authenticating user root 61.177.173.2 port 25539 [preauth] Dec 19 12:53:57 Claimco sshd[19205]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:54:45 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:55:18 Claimco sshd[19588]: Connection from 61.177.173.2 port 59340 on 192.168.1.233 port 22 rdomain "" Dec 19 12:55:19 Claimco sshd[19588]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:55:21 Claimco sshd[19588]: Failed password for root from 61.177.173.2 port 59340 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:55:26 Claimco sshd[19588]: Received disconnect from 61.177.173.2 port 59340:11: [preauth] Dec 19 12:55:26 Claimco sshd[19588]: Disconnected from authenticating user root 61.177.173.2 port 59340 [preauth] Dec 19 12:55:26 Claimco sshd[19588]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:56:10 Claimco sshd[19782]: Connection from 218.92.0.221 port 14745 on 192.168.1.233 port 22 rdomain "" Dec 19 12:56:11 Claimco sshd[19782]: Received disconnect from 218.92.0.221 port 14745:11: [preauth] Dec 19 12:56:11 Claimco sshd[19782]: Disconnected from 218.92.0.221 port 14745 [preauth] Dec 19 12:56:16 Claimco sshd[19798]: Connection from 162.218.126.136 port 43900 on 192.168.1.233 port 22 rdomain "" Dec 19 12:56:17 Claimco sshd[19798]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=162.218.126.136 user=root Dec 19 12:56:19 Claimco sshd[19798]: Failed password for root from 162.218.126.136 port 43900 ssh2 Dec 19 12:56:21 Claimco sshd[19798]: Connection closed by authenticating user root 162.218.126.136 port 43900 [preauth] Dec 19 12:56:25 Claimco sshd[19819]: Connection from 61.177.172.124 port 45271 on 192.168.1.233 port 22 rdomain "" Dec 19 12:56:26 Claimco sshd[19819]: Received disconnect from 61.177.172.124 port 45271:11: [preauth] Dec 19 12:56:26 Claimco sshd[19819]: Disconnected from 61.177.172.124 port 45271 [preauth] Dec 19 12:56:46 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 12:56:57 Claimco sshd[19915]: Connection from 61.177.173.2 port 47299 on 192.168.1.233 port 22 rdomain "" Dec 19 12:56:59 Claimco sshd[19915]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:57:00 Claimco sshd[19915]: Failed password for root from 61.177.173.2 port 47299 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:57:06 Claimco sshd[19915]: Received disconnect from 61.177.173.2 port 47299:11: [preauth] Dec 19 12:57:06 Claimco sshd[19915]: Disconnected from authenticating user root 61.177.173.2 port 47299 [preauth] Dec 19 12:57:06 Claimco sshd[19915]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:58:34 Claimco sshd[20505]: Connection from 61.177.173.46 port 25013 on 192.168.1.233 port 22 rdomain "" Dec 19 12:58:35 Claimco sshd[20505]: Received disconnect from 61.177.173.46 port 25013:11: [preauth] Dec 19 12:58:35 Claimco sshd[20505]: Disconnected from 61.177.173.46 port 25013 [preauth] Dec 19 12:58:36 Claimco sshd[20509]: Connection from 61.177.173.2 port 26642 on 192.168.1.233 port 22 rdomain "" Dec 19 12:58:37 Claimco sshd[20509]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:58:39 Claimco sshd[20509]: Failed password for root from 61.177.173.2 port 26642 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 12:58:49 Claimco sshd[20509]: Received disconnect from 61.177.173.2 port 26642:11: [preauth] Dec 19 12:58:49 Claimco sshd[20509]: Disconnected from authenticating user root 61.177.173.2 port 26642 [preauth] Dec 19 12:58:49 Claimco sshd[20509]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 12:58:50 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:00:17 Claimco sshd[20950]: Connection from 61.177.173.2 port 11673 on 192.168.1.233 port 22 rdomain "" Dec 19 13:00:18 Claimco sshd[20950]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 13:00:20 Claimco sshd[20950]: Failed password for root from 61.177.173.2 port 11673 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 13:00:27 Claimco sshd[20950]: Received disconnect from 61.177.173.2 port 11673:11: [preauth] Dec 19 13:00:27 Claimco sshd[20950]: Disconnected from authenticating user root 61.177.173.2 port 11673 [preauth] Dec 19 13:00:27 Claimco sshd[20950]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 13:00:55 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:01:57 Claimco sshd[21274]: Connection from 61.177.173.2 port 53995 on 192.168.1.233 port 22 rdomain "" Dec 19 13:01:58 Claimco sshd[21274]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 13:02:00 Claimco sshd[21274]: Failed password for root from 61.177.173.2 port 53995 ssh2 Dec 19 13:02:04 Claimco sshd[21340]: Connection from 61.177.173.35 port 54044 on 192.168.1.233 port 22 rdomain "" Dec 19 13:02:05 Claimco sshd[21274]: Failed password for root from 61.177.173.2 port 53995 ssh2 Dec 19 13:02:05 Claimco sshd[21340]: Received disconnect from 61.177.173.35 port 54044:11: [preauth] Dec 19 13:02:05 Claimco sshd[21340]: Disconnected from 61.177.173.35 port 54044 [preauth] Dec 19 13:02:06 Claimco sshd[21274]: Failed password for root from 61.177.173.2 port 53995 ssh2 Dec 19 13:02:07 Claimco sshd[21274]: Received disconnect from 61.177.173.2 port 53995:11: [preauth] Dec 19 13:02:07 Claimco sshd[21274]: Disconnected from authenticating user root 61.177.173.2 port 53995 [preauth] Dec 19 13:02:07 Claimco sshd[21274]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 13:03:02 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:03:50 Claimco sshd[21726]: Connection from 61.177.173.2 port 53295 on 192.168.1.233 port 22 rdomain "" Dec 19 13:03:55 Claimco sshd[21726]: Received disconnect from 61.177.173.2 port 53295:11: [preauth] Dec 19 13:03:55 Claimco sshd[21726]: Disconnected from 61.177.173.2 port 53295 [preauth] Dec 19 13:05:11 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:05:51 Claimco sshd[22197]: Connection from 61.177.173.2 port 31262 on 192.168.1.233 port 22 rdomain "" Dec 19 13:05:54 Claimco sshd[22205]: Connection from 61.177.173.46 port 29445 on 192.168.1.233 port 22 rdomain "" Dec 19 13:05:55 Claimco sshd[22205]: Received disconnect from 61.177.173.46 port 29445:11: [preauth] Dec 19 13:05:55 Claimco sshd[22205]: Disconnected from 61.177.173.46 port 29445 [preauth] Dec 19 13:05:56 Claimco sshd[22197]: Received disconnect from 61.177.173.2 port 31262:11: [preauth] Dec 19 13:05:56 Claimco sshd[22197]: Disconnected from 61.177.173.2 port 31262 [preauth] Dec 19 13:07:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:07:41 Claimco sshd[22591]: Connection from 218.92.0.221 port 48127 on 192.168.1.233 port 22 rdomain "" Dec 19 13:07:47 Claimco sshd[22630]: Connection from 61.177.173.2 port 28152 on 192.168.1.233 port 22 rdomain "" Dec 19 13:07:54 Claimco sshd[22630]: Received disconnect from 61.177.173.2 port 28152:11: [preauth] Dec 19 13:07:54 Claimco sshd[22630]: Disconnected from 61.177.173.2 port 28152 [preauth] Dec 19 13:09:12 Claimco sshd[23153]: Connection from 61.177.172.19 port 47678 on 192.168.1.233 port 22 rdomain "" Dec 19 13:09:13 Claimco sshd[23153]: Received disconnect from 61.177.172.19 port 47678:11: [preauth] Dec 19 13:09:13 Claimco sshd[23153]: Disconnected from 61.177.172.19 port 47678 [preauth] Dec 19 13:09:17 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:09:41 Claimco sshd[22591]: fatal: Timeout before authentication for 218.92.0.221 port 48127 Dec 19 13:09:54 Claimco sshd[23292]: Connection from 61.177.173.2 port 21453 on 192.168.1.233 port 22 rdomain "" Dec 19 13:10:02 Claimco sshd[23292]: Received disconnect from 61.177.173.2 port 21453:11: [preauth] Dec 19 13:10:02 Claimco sshd[23292]: Disconnected from 61.177.173.2 port 21453 [preauth] Dec 19 13:10:39 Claimco sshd[23498]: Connection from 61.177.173.35 port 53834 on 192.168.1.233 port 22 rdomain "" Dec 19 13:10:40 Claimco sshd[23498]: Received disconnect from 61.177.173.35 port 53834:11: [preauth] Dec 19 13:10:40 Claimco sshd[23498]: Disconnected from 61.177.173.35 port 53834 [preauth] Dec 19 13:11:24 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:11:55 Claimco sshd[23765]: Connection from 61.177.173.2 port 52033 on 192.168.1.233 port 22 rdomain "" Dec 19 13:12:01 Claimco sshd[23765]: Received disconnect from 61.177.173.2 port 52033:11: [preauth] Dec 19 13:12:01 Claimco sshd[23765]: Disconnected from 61.177.173.2 port 52033 [preauth] Dec 19 13:12:50 Claimco sshd[23957]: Connection from 61.177.172.76 port 54890 on 192.168.1.233 port 22 rdomain "" Dec 19 13:12:50 Claimco sshd[23957]: Unable to negotiate with 61.177.172.76 port 54890: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 13:13:23 Claimco sshd[24084]: Connection from 61.177.173.50 port 55773 on 192.168.1.233 port 22 rdomain "" Dec 19 13:13:24 Claimco sshd[24084]: Received disconnect from 61.177.173.50 port 55773:11: [preauth] Dec 19 13:13:24 Claimco sshd[24084]: Disconnected from 61.177.173.50 port 55773 [preauth] Dec 19 13:13:26 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:14:04 Claimco sshd[24284]: Connection from 61.177.173.2 port 49921 on 192.168.1.233 port 22 rdomain "" Dec 19 13:14:08 Claimco sshd[24284]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 13:14:10 Claimco sshd[24284]: Failed password for root from 61.177.173.2 port 49921 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 13:14:19 Claimco sshd[24284]: Received disconnect from 61.177.173.2 port 49921:11: [preauth] Dec 19 13:14:19 Claimco sshd[24284]: Disconnected from authenticating user root 61.177.173.2 port 49921 [preauth] Dec 19 13:14:19 Claimco sshd[24284]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 13:15:33 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:15:54 Claimco sshd[24672]: Connection from 61.177.173.2 port 46608 on 192.168.1.233 port 22 rdomain "" Dec 19 13:16:07 Claimco sshd[24672]: Received disconnect from 61.177.173.2 port 46608:11: [preauth] Dec 19 13:16:07 Claimco sshd[24672]: Disconnected from authenticating user root 61.177.173.2 port 46608 [preauth] Dec 19 13:17:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:17:54 Claimco sshd[25109]: Connection from 61.177.173.2 port 54702 on 192.168.1.233 port 22 rdomain "" Dec 19 13:17:59 Claimco sshd[25109]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 13:18:02 Claimco sshd[25109]: Failed password for root from 61.177.173.2 port 54702 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 13:18:07 Claimco sshd[25109]: Received disconnect from 61.177.173.2 port 54702:11: [preauth] Dec 19 13:18:07 Claimco sshd[25109]: Disconnected from authenticating user root 61.177.173.2 port 54702 [preauth] Dec 19 13:18:07 Claimco sshd[25109]: PAM 1 more authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 13:19:09 Claimco sshd[25641]: Connection from 61.177.173.37 port 28337 on 192.168.1.233 port 22 rdomain "" Dec 19 13:19:10 Claimco sshd[25641]: Received disconnect from 61.177.173.37 port 28337:11: [preauth] Dec 19 13:19:10 Claimco sshd[25641]: Disconnected from 61.177.173.37 port 28337 [preauth] Dec 19 13:19:22 Claimco sshd[25671]: Connection from 61.177.173.47 port 64202 on 192.168.1.233 port 22 rdomain "" Dec 19 13:19:23 Claimco sshd[25671]: Received disconnect from 61.177.173.47 port 64202:11: [preauth] Dec 19 13:19:23 Claimco sshd[25671]: Disconnected from 61.177.173.47 port 64202 [preauth] Dec 19 13:19:41 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:19:54 Claimco sshd[25767]: Connection from 61.177.173.2 port 56622 on 192.168.1.233 port 22 rdomain "" Dec 19 13:19:59 Claimco sshd[25767]: Received disconnect from 61.177.173.2 port 56622:11: [preauth] Dec 19 13:19:59 Claimco sshd[25767]: Disconnected from 61.177.173.2 port 56622 [preauth] Dec 19 13:20:51 Claimco sshd[26018]: Connection from 61.177.173.46 port 35007 on 192.168.1.233 port 22 rdomain "" Dec 19 13:20:52 Claimco sshd[26018]: Received disconnect from 61.177.173.46 port 35007:11: [preauth] Dec 19 13:20:52 Claimco sshd[26018]: Disconnected from 61.177.173.46 port 35007 [preauth] Dec 19 13:20:58 Claimco sshd[26035]: Connection from 84.110.99.202 port 46868 on 192.168.1.233 port 22 rdomain "" Dec 19 13:20:59 Claimco sshd[26035]: Invalid user user1 from 84.110.99.202 port 46868 Dec 19 13:20:59 Claimco sshd[26035]: pam_unix(sshd:auth): check pass; user unknown Dec 19 13:20:59 Claimco sshd[26035]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=84.110.99.202 Dec 19 13:21:01 Claimco sshd[26035]: Failed password for invalid user user1 from 84.110.99.202 port 46868 ssh2 Dec 19 13:21:03 Claimco sshd[26035]: Connection closed by invalid user user1 84.110.99.202 port 46868 [preauth] Dec 19 13:21:52 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:21:57 Claimco sshd[26259]: Connection from 61.177.173.2 port 53053 on 192.168.1.233 port 22 rdomain "" Dec 19 13:22:08 Claimco sshd[26259]: Received disconnect from 61.177.173.2 port 53053:11: [preauth] Dec 19 13:22:08 Claimco sshd[26259]: Disconnected from authenticating user root 61.177.173.2 port 53053 [preauth] Dec 19 13:23:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:23:53 Claimco sshd[26699]: Connection from 61.177.173.2 port 45251 on 192.168.1.233 port 22 rdomain "" Dec 19 13:24:00 Claimco sshd[26699]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 13:24:02 Claimco sshd[26699]: Failed password for root from 61.177.173.2 port 45251 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 13:24:08 Claimco sshd[26699]: Received disconnect from 61.177.173.2 port 45251:11: [preauth] Dec 19 13:24:08 Claimco sshd[26699]: Disconnected from authenticating user root 61.177.173.2 port 45251 [preauth] Dec 19 13:24:08 Claimco sshd[26699]: PAM 1 more authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 13:25:52 Claimco sshd[27164]: Connection from 61.177.173.2 port 42195 on 192.168.1.233 port 22 rdomain "" Dec 19 13:25:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:25:58 Claimco sshd[27164]: Received disconnect from 61.177.173.2 port 42195:11: [preauth] Dec 19 13:25:58 Claimco sshd[27164]: Disconnected from 61.177.173.2 port 42195 [preauth] Dec 19 13:27:54 Claimco sshd[27603]: Connection from 61.177.173.2 port 10492 on 192.168.1.233 port 22 rdomain "" Dec 19 13:27:57 Claimco sshd[27603]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 13:28:00 Claimco sshd[27603]: Failed password for root from 61.177.173.2 port 10492 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 13:28:06 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:28:07 Claimco sshd[27669]: Connection from 61.177.173.36 port 17569 on 192.168.1.233 port 22 rdomain "" Dec 19 13:28:08 Claimco sshd[27603]: Received disconnect from 61.177.173.2 port 10492:11: [preauth] Dec 19 13:28:08 Claimco sshd[27603]: Disconnected from authenticating user root 61.177.173.2 port 10492 [preauth] Dec 19 13:28:08 Claimco sshd[27603]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 13:28:15 Claimco sshd[27684]: Connection from 61.177.173.51 port 22769 on 192.168.1.233 port 22 rdomain "" Dec 19 13:28:16 Claimco sshd[27684]: Received disconnect from 61.177.173.51 port 22769:11: [preauth] Dec 19 13:28:16 Claimco sshd[27684]: Disconnected from 61.177.173.51 port 22769 [preauth] Dec 19 13:29:57 Claimco sshd[28263]: Connection from 61.177.173.2 port 35870 on 192.168.1.233 port 22 rdomain "" Dec 19 13:30:02 Claimco sshd[28263]: Received disconnect from 61.177.173.2 port 35870:11: [preauth] Dec 19 13:30:02 Claimco sshd[28263]: Disconnected from 61.177.173.2 port 35870 [preauth] Dec 19 13:30:07 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:30:07 Claimco sshd[27669]: fatal: Timeout before authentication for 61.177.173.36 port 17569 Dec 19 13:30:59 Claimco sshd[28524]: Connection from 61.177.172.90 port 55403 on 192.168.1.233 port 22 rdomain "" Dec 19 13:31:00 Claimco sshd[28524]: Received disconnect from 61.177.172.90 port 55403:11: [preauth] Dec 19 13:31:00 Claimco sshd[28524]: Disconnected from 61.177.172.90 port 55403 [preauth] Dec 19 13:31:58 Claimco sshd[28711]: Connection from 61.177.173.2 port 11073 on 192.168.1.233 port 22 rdomain "" Dec 19 13:32:03 Claimco sshd[28711]: Received disconnect from 61.177.173.2 port 11073:11: [preauth] Dec 19 13:32:03 Claimco sshd[28711]: Disconnected from 61.177.173.2 port 11073 [preauth] Dec 19 13:32:11 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:33:58 Claimco sshd[29177]: Connection from 61.177.173.2 port 47521 on 192.168.1.233 port 22 rdomain "" Dec 19 13:34:03 Claimco sshd[29177]: Received disconnect from 61.177.173.2 port 47521:11: [preauth] Dec 19 13:34:03 Claimco sshd[29177]: Disconnected from 61.177.173.2 port 47521 [preauth] Dec 19 13:34:16 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:35:41 Claimco sshd[29609]: Connection from 61.177.173.49 port 59465 on 192.168.1.233 port 22 rdomain "" Dec 19 13:35:43 Claimco sshd[29609]: Received disconnect from 61.177.173.49 port 59465:11: [preauth] Dec 19 13:35:43 Claimco sshd[29609]: Disconnected from 61.177.173.49 port 59465 [preauth] Dec 19 13:35:55 Claimco sshd[29640]: Connection from 61.177.173.2 port 37685 on 192.168.1.233 port 22 rdomain "" Dec 19 13:36:00 Claimco sshd[29640]: Received disconnect from 61.177.173.2 port 37685:11: [preauth] Dec 19 13:36:00 Claimco sshd[29640]: Disconnected from 61.177.173.2 port 37685 [preauth] Dec 19 13:36:19 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:36:48 Claimco sshd[29836]: Connection from 61.177.173.47 port 63574 on 192.168.1.233 port 22 rdomain "" Dec 19 13:36:49 Claimco sshd[29836]: Received disconnect from 61.177.173.47 port 63574:11: [preauth] Dec 19 13:36:49 Claimco sshd[29836]: Disconnected from 61.177.173.47 port 63574 [preauth] Dec 19 13:38:03 Claimco sshd[30130]: Connection from 61.177.173.2 port 59098 on 192.168.1.233 port 22 rdomain "" Dec 19 13:38:08 Claimco sshd[30130]: Received disconnect from 61.177.173.2 port 59098:11: [preauth] Dec 19 13:38:08 Claimco sshd[30130]: Disconnected from 61.177.173.2 port 59098 [preauth] Dec 19 13:38:29 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:38:33 Claimco sshd[30415]: Connection from 61.177.172.114 port 57849 on 192.168.1.233 port 22 rdomain "" Dec 19 13:38:35 Claimco sshd[30415]: Received disconnect from 61.177.172.114 port 57849:11: [preauth] Dec 19 13:38:35 Claimco sshd[30415]: Disconnected from 61.177.172.114 port 57849 [preauth] Dec 19 13:40:05 Claimco sshd[30787]: Connection from 61.177.173.2 port 50247 on 192.168.1.233 port 22 rdomain "" Dec 19 13:40:11 Claimco sshd[30787]: Received disconnect from 61.177.173.2 port 50247:11: [preauth] Dec 19 13:40:11 Claimco sshd[30787]: Disconnected from 61.177.173.2 port 50247 [preauth] Dec 19 13:40:29 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 13:42:08 Claimco sshd[31272]: Connection from 61.177.173.2 port 22334 on 192.168.1.233 port 22 rdomain "" Dec 19 13:42:13 Claimco sshd[31272]: Received disconnect from 61.177.173.2 port 22334:11: [preauth] Dec 19 13:42:13 Claimco sshd[31272]: Disconnected from 61.177.173.2 port 22334 [preauth] Dec 19 13:42:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:42:44 Claimco sshd[31377]: Connection from 61.177.173.37 port 47132 on 192.168.1.233 port 22 rdomain "" Dec 19 13:42:45 Claimco sshd[31377]: Received disconnect from 61.177.173.37 port 47132:11: [preauth] Dec 19 13:42:45 Claimco sshd[31377]: Disconnected from 61.177.173.37 port 47132 [preauth] Dec 19 13:43:11 Claimco sshd[31494]: Connection from 61.177.173.53 port 46392 on 192.168.1.233 port 22 rdomain "" Dec 19 13:43:13 Claimco sshd[31494]: Received disconnect from 61.177.173.53 port 46392:11: [preauth] Dec 19 13:43:13 Claimco sshd[31494]: Disconnected from 61.177.173.53 port 46392 [preauth] Dec 19 13:43:52 Claimco sshd[31656]: Connection from 61.177.173.43 port 48992 on 192.168.1.233 port 22 rdomain "" Dec 19 13:43:53 Claimco sshd[31656]: Unable to negotiate with 61.177.173.43 port 48992: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 13:44:13 Claimco sshd[31736]: Connection from 61.177.173.2 port 37447 on 192.168.1.233 port 22 rdomain "" Dec 19 13:44:18 Claimco sshd[31736]: Received disconnect from 61.177.173.2 port 37447:11: [preauth] Dec 19 13:44:18 Claimco sshd[31736]: Disconnected from 61.177.173.2 port 37447 [preauth] Dec 19 13:44:42 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 13:45:37 Claimco sshd[32088]: Connection from 61.177.173.35 port 60593 on 192.168.1.233 port 22 rdomain "" Dec 19 13:45:38 Claimco sshd[32088]: Received disconnect from 61.177.173.35 port 60593:11: [preauth] Dec 19 13:45:38 Claimco sshd[32088]: Disconnected from 61.177.173.35 port 60593 [preauth] Dec 19 13:46:09 Claimco sshd[32215]: Connection from 61.177.173.2 port 26871 on 192.168.1.233 port 22 rdomain "" Dec 19 13:46:14 Claimco sshd[32215]: Received disconnect from 61.177.173.2 port 26871:11: [preauth] Dec 19 13:46:14 Claimco sshd[32215]: Disconnected from 61.177.173.2 port 26871 [preauth] Dec 19 13:46:47 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:46:54 Claimco sshd[32339]: Connection from 61.177.172.19 port 33158 on 192.168.1.233 port 22 rdomain "" Dec 19 13:46:55 Claimco sshd[32339]: Received disconnect from 61.177.172.19 port 33158:11: [preauth] Dec 19 13:46:55 Claimco sshd[32339]: Disconnected from 61.177.172.19 port 33158 [preauth] Dec 19 13:48:14 Claimco sshd[32666]: Connection from 61.177.173.2 port 61927 on 192.168.1.233 port 22 rdomain "" Dec 19 13:48:21 Claimco sshd[32666]: Received disconnect from 61.177.173.2 port 61927:11: [preauth] Dec 19 13:48:21 Claimco sshd[32666]: Disconnected from 61.177.173.2 port 61927 [preauth] Dec 19 13:48:51 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:50:12 Claimco sshd[937]: Connection from 61.177.173.2 port 42618 on 192.168.1.233 port 22 rdomain "" Dec 19 13:50:17 Claimco sshd[937]: Received disconnect from 61.177.173.2 port 42618:11: [preauth] Dec 19 13:50:17 Claimco sshd[937]: Disconnected from 61.177.173.2 port 42618 [preauth] Dec 19 13:50:34 Claimco sshd[1009]: Connection from 61.177.173.51 port 17137 on 192.168.1.233 port 22 rdomain "" Dec 19 13:50:35 Claimco sshd[1009]: Received disconnect from 61.177.173.51 port 17137:11: [preauth] Dec 19 13:50:35 Claimco sshd[1009]: Disconnected from 61.177.173.51 port 17137 [preauth] Dec 19 13:50:55 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:52:18 Claimco sshd[1399]: Connection from 61.177.173.2 port 60605 on 192.168.1.233 port 22 rdomain "" Dec 19 13:52:23 Claimco sshd[1399]: Connection reset by 61.177.173.2 port 60605 [preauth] Dec 19 13:53:02 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:54:10 Claimco sshd[1834]: Connection from 61.177.173.2 port 49171 on 192.168.1.233 port 22 rdomain "" Dec 19 13:54:16 Claimco sshd[1834]: Received disconnect from 61.177.173.2 port 49171:11: [preauth] Dec 19 13:54:16 Claimco sshd[1834]: Disconnected from 61.177.173.2 port 49171 [preauth] Dec 19 13:54:19 Claimco sshd[1854]: Connection from 61.177.173.35 port 37040 on 192.168.1.233 port 22 rdomain "" Dec 19 13:54:20 Claimco sshd[1854]: Received disconnect from 61.177.173.35 port 37040:11: [preauth] Dec 19 13:54:20 Claimco sshd[1854]: Disconnected from 61.177.173.35 port 37040 [preauth] Dec 19 13:54:25 Claimco sshd[1869]: Connection from 61.177.173.52 port 25364 on 192.168.1.233 port 22 rdomain "" Dec 19 13:54:26 Claimco sshd[1869]: Received disconnect from 61.177.173.52 port 25364:11: [preauth] Dec 19 13:54:26 Claimco sshd[1869]: Disconnected from 61.177.173.52 port 25364 [preauth] Dec 19 13:55:05 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:56:16 Claimco sshd[2319]: Connection from 61.177.173.2 port 61206 on 192.168.1.233 port 22 rdomain "" Dec 19 13:56:33 Claimco sshd[2319]: Received disconnect from 61.177.173.2 port 61206:11: [preauth] Dec 19 13:56:33 Claimco sshd[2319]: Disconnected from 61.177.173.2 port 61206 [preauth] Dec 19 13:57:11 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 13:58:00 Claimco sshd[2649]: Connection from 61.177.173.51 port 27481 on 192.168.1.233 port 22 rdomain "" Dec 19 13:58:02 Claimco sshd[2649]: Received disconnect from 61.177.173.51 port 27481:11: [preauth] Dec 19 13:58:02 Claimco sshd[2649]: Disconnected from 61.177.173.51 port 27481 [preauth] Dec 19 13:58:09 Claimco sshd[2717]: Connection from 61.177.173.2 port 56904 on 192.168.1.233 port 22 rdomain "" Dec 19 13:58:16 Claimco sshd[2717]: Received disconnect from 61.177.173.2 port 56904:11: [preauth] Dec 19 13:58:16 Claimco sshd[2717]: Disconnected from 61.177.173.2 port 56904 [preauth] Dec 19 13:59:20 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:00:14 Claimco sshd[3424]: Connection from 61.177.173.2 port 20284 on 192.168.1.233 port 22 rdomain "" Dec 19 14:00:20 Claimco sshd[3424]: Received disconnect from 61.177.173.2 port 20284:11: [preauth] Dec 19 14:00:20 Claimco sshd[3424]: Disconnected from 61.177.173.2 port 20284 [preauth] Dec 19 14:01:21 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 14:04:26 Claimco sshd[4358]: Connection from 61.177.173.2 port 62576 on 192.168.1.233 port 22 rdomain "" Dec 19 14:04:37 Claimco sshd[4358]: Received disconnect from 61.177.173.2 port 62576:11: [preauth] Dec 19 14:04:37 Claimco sshd[4358]: Disconnected from 61.177.173.2 port 62576 [preauth] Dec 19 14:05:06 Claimco sshd[4552]: Connection from 61.177.173.39 port 25205 on 192.168.1.233 port 22 rdomain "" Dec 19 14:05:07 Claimco sshd[4552]: Received disconnect from 61.177.173.39 port 25205:11: [preauth] Dec 19 14:05:07 Claimco sshd[4552]: Disconnected from 61.177.173.39 port 25205 [preauth] Dec 19 14:05:32 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:06:19 Claimco sshd[4789]: Connection from 61.177.173.2 port 53858 on 192.168.1.233 port 22 rdomain "" Dec 19 14:06:26 Claimco sshd[4789]: Received disconnect from 61.177.173.2 port 53858:11: [preauth] Dec 19 14:06:26 Claimco sshd[4789]: Disconnected from 61.177.173.2 port 53858 [preauth] Dec 19 14:07:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:08:18 Claimco sshd[5224]: Connection from 61.177.173.2 port 28585 on 192.168.1.233 port 22 rdomain "" Dec 19 14:08:25 Claimco sshd[5224]: Received disconnect from 61.177.173.2 port 28585:11: [preauth] Dec 19 14:08:25 Claimco sshd[5224]: Disconnected from 61.177.173.2 port 28585 [preauth] Dec 19 14:09:41 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:10:18 Claimco sshd[5918]: Connection from 61.177.173.2 port 11978 on 192.168.1.233 port 22 rdomain "" Dec 19 14:10:23 Claimco sshd[5918]: Received disconnect from 61.177.173.2 port 11978:11: [preauth] Dec 19 14:10:23 Claimco sshd[5918]: Disconnected from 61.177.173.2 port 11978 [preauth] Dec 19 14:11:52 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:12:17 Claimco sshd[6338]: Connection from 61.177.173.2 port 39540 on 192.168.1.233 port 22 rdomain "" Dec 19 14:12:22 Claimco sshd[6338]: Received disconnect from 61.177.173.2 port 39540:11: [preauth] Dec 19 14:12:22 Claimco sshd[6338]: Disconnected from 61.177.173.2 port 39540 [preauth] Dec 19 14:13:51 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:14:14 Claimco sshd[6808]: Connection from 61.177.173.2 port 49834 on 192.168.1.233 port 22 rdomain "" Dec 19 14:14:23 Claimco sshd[6808]: Received disconnect from 61.177.173.2 port 49834:11: [preauth] Dec 19 14:14:23 Claimco sshd[6808]: Disconnected from 61.177.173.2 port 49834 [preauth] Dec 19 14:15:43 Claimco sshd[7144]: Connection from 61.177.172.87 port 48450 on 192.168.1.233 port 22 rdomain "" Dec 19 14:15:43 Claimco sshd[7144]: Unable to negotiate with 61.177.172.87 port 48450: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 14:15:55 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:16:10 Claimco sshd[7259]: Connection from 61.177.173.2 port 51976 on 192.168.1.233 port 22 rdomain "" Dec 19 14:16:16 Claimco sshd[7259]: Received disconnect from 61.177.173.2 port 51976:11: [preauth] Dec 19 14:16:16 Claimco sshd[7259]: Disconnected from 61.177.173.2 port 51976 [preauth] Dec 19 14:18:01 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:18:10 Claimco sshd[7813]: Connection from 61.177.173.2 port 35635 on 192.168.1.233 port 22 rdomain "" Dec 19 14:20:09 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:20:10 Claimco sshd[7813]: fatal: Timeout before authentication for 61.177.173.2 port 35635 Dec 19 14:20:14 Claimco sshd[8571]: Connection from 61.177.173.2 port 51328 on 192.168.1.233 port 22 rdomain "" Dec 19 14:20:19 Claimco sshd[8571]: Received disconnect from 61.177.173.2 port 51328:11: [preauth] Dec 19 14:20:19 Claimco sshd[8571]: Disconnected from 61.177.173.2 port 51328 [preauth] Dec 19 14:21:07 Claimco sshd[8770]: Connection from 162.218.126.136 port 40518 on 192.168.1.233 port 22 rdomain "" Dec 19 14:21:07 Claimco sshd[8770]: Invalid user ubuntu from 162.218.126.136 port 40518 Dec 19 14:21:08 Claimco sshd[8770]: pam_unix(sshd:auth): check pass; user unknown Dec 19 14:21:08 Claimco sshd[8770]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=162.218.126.136 Dec 19 14:21:10 Claimco sshd[8770]: Failed password for invalid user ubuntu from 162.218.126.136 port 40518 ssh2 Dec 19 14:21:11 Claimco sshd[8770]: Connection closed by invalid user ubuntu 162.218.126.136 port 40518 [preauth] Dec 19 14:22:09 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:22:09 Claimco sshd[9002]: Connection from 61.177.173.2 port 45320 on 192.168.1.233 port 22 rdomain "" Dec 19 14:24:08 Claimco sshd[9462]: Connection from 61.177.173.2 port 16861 on 192.168.1.233 port 22 rdomain "" Dec 19 14:24:09 Claimco sshd[9002]: fatal: Timeout before authentication for 61.177.173.2 port 45320 Dec 19 14:24:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:26:08 Claimco sshd[9462]: fatal: Timeout before authentication for 61.177.173.2 port 16861 Dec 19 14:26:11 Claimco sshd[9936]: Connection from 61.177.173.2 port 28106 on 192.168.1.233 port 22 rdomain "" Dec 19 14:26:23 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:27:53 Claimco nginx: 2022/12/19 14:27:53 [crit] 6648#6648: *73162 SSL_do_handshake() failed (SSL: error:141CF06C:SSL routines:tls_parse_ctos_key_share:bad key share) while SSL handshaking, client: 69.55.55.153, server: 0.0.0.0:443 Dec 19 14:28:09 Claimco sshd[10369]: Connection from 61.177.173.2 port 22676 on 192.168.1.233 port 22 rdomain "" Dec 19 14:28:11 Claimco sshd[9936]: fatal: Timeout before authentication for 61.177.173.2 port 28106 Dec 19 14:28:26 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:30:09 Claimco sshd[11038]: Connection from 61.177.173.2 port 63382 on 192.168.1.233 port 22 rdomain "" Dec 19 14:30:09 Claimco sshd[10369]: fatal: Timeout before authentication for 61.177.173.2 port 22676 Dec 19 14:30:14 Claimco sshd[11038]: Received disconnect from 61.177.173.2 port 63382:11: [preauth] Dec 19 14:30:14 Claimco sshd[11038]: Disconnected from 61.177.173.2 port 63382 [preauth] Dec 19 14:30:15 Claimco sshd[11077]: Connection from 65.2.28.105 port 49822 on 192.168.1.233 port 22 rdomain "" Dec 19 14:30:16 Claimco sshd[11077]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=65.2.28.105 user=root Dec 19 14:30:18 Claimco sshd[11077]: Failed password for root from 65.2.28.105 port 49822 ssh2 Dec 19 14:30:19 Claimco sshd[11077]: Connection closed by authenticating user root 65.2.28.105 port 49822 [preauth] Dec 19 14:30:38 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:32:10 Claimco sshd[11465]: Connection from 61.177.173.2 port 31443 on 192.168.1.233 port 22 rdomain "" Dec 19 14:32:11 Claimco sshd[11470]: Connection from 92.46.108.20 port 46336 on 192.168.1.233 port 22 rdomain "" Dec 19 14:32:14 Claimco sshd[11470]: Invalid user user from 92.46.108.20 port 46336 Dec 19 14:32:14 Claimco sshd[11470]: pam_unix(sshd:auth): check pass; user unknown Dec 19 14:32:14 Claimco sshd[11470]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=92.46.108.20 Dec 19 14:32:16 Claimco sshd[11470]: Failed password for invalid user user from 92.46.108.20 port 46336 ssh2 Dec 19 14:32:18 Claimco sshd[11470]: Connection closed by invalid user user 92.46.108.20 port 46336 [preauth] Dec 19 14:32:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:34:08 Claimco sshd[11928]: Connection from 61.177.173.2 port 53135 on 192.168.1.233 port 22 rdomain "" Dec 19 14:34:10 Claimco sshd[11465]: fatal: Timeout before authentication for 61.177.173.2 port 31443 Dec 19 14:34:14 Claimco sshd[11928]: Received disconnect from 61.177.173.2 port 53135:11: [preauth] Dec 19 14:34:14 Claimco sshd[11928]: Disconnected from 61.177.173.2 port 53135 [preauth] Dec 19 14:34:45 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:36:08 Claimco sshd[12397]: Connection from 61.177.173.2 port 36936 on 192.168.1.233 port 22 rdomain "" Dec 19 14:36:14 Claimco sshd[12397]: Received disconnect from 61.177.173.2 port 36936:11: [preauth] Dec 19 14:36:14 Claimco sshd[12397]: Disconnected from 61.177.173.2 port 36936 [preauth] Dec 19 14:36:50 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:38:08 Claimco sshd[12834]: Connection from 61.177.173.2 port 20683 on 192.168.1.233 port 22 rdomain "" Dec 19 14:38:52 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:40:06 Claimco sshd[13483]: Connection from 61.177.173.2 port 40273 on 192.168.1.233 port 22 rdomain "" Dec 19 14:40:08 Claimco sshd[12834]: fatal: Timeout before authentication for 61.177.173.2 port 20683 Dec 19 14:40:28 Claimco sshd[13483]: Connection reset by 61.177.173.2 port 40273 [preauth] Dec 19 14:40:55 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:41:43 Claimco sshd[13842]: Connection from 151.80.220.187 port 52804 on 192.168.1.233 port 22 rdomain "" Dec 19 14:41:44 Claimco sshd[13842]: Invalid user test from 151.80.220.187 port 52804 Dec 19 14:41:44 Claimco sshd[13842]: pam_unix(sshd:auth): check pass; user unknown Dec 19 14:41:44 Claimco sshd[13842]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=151.80.220.187 Dec 19 14:41:47 Claimco sshd[13842]: Failed password for invalid user test from 151.80.220.187 port 52804 ssh2 Dec 19 14:41:48 Claimco sshd[13842]: Connection closed by invalid user test 151.80.220.187 port 52804 [preauth] Dec 19 14:41:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:42:10 Claimco sshd[13974]: Connection from 61.177.173.2 port 55724 on 192.168.1.233 port 22 rdomain "" Dec 19 14:43:07 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:44:08 Claimco sshd[14432]: Connection from 61.177.173.2 port 61326 on 192.168.1.233 port 22 rdomain "" Dec 19 14:44:10 Claimco sshd[13974]: fatal: Timeout before authentication for 61.177.173.2 port 55724 Dec 19 14:44:18 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 14:46:07 Claimco sshd[14890]: Connection from 61.177.173.2 port 39873 on 192.168.1.233 port 22 rdomain "" Dec 19 14:46:08 Claimco sshd[14432]: fatal: Timeout before authentication for 61.177.173.2 port 61326 Dec 19 14:46:19 Claimco sshd[14890]: Received disconnect from 61.177.173.2 port 39873:11: [preauth] Dec 19 14:46:19 Claimco sshd[14890]: Disconnected from 61.177.173.2 port 39873 [preauth] Dec 19 14:47:10 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:47:46 Claimco sshd[15236]: Connection from 61.177.173.42 port 34312 on 192.168.1.233 port 22 rdomain "" Dec 19 14:47:46 Claimco sshd[15236]: Unable to negotiate with 61.177.173.42 port 34312: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 14:48:04 Claimco sshd[15323]: Connection from 61.177.173.2 port 57905 on 192.168.1.233 port 22 rdomain "" Dec 19 14:49:20 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:50:04 Claimco sshd[15323]: fatal: Timeout before authentication for 61.177.173.2 port 57905 Dec 19 14:50:04 Claimco sshd[15978]: Connection from 61.177.173.2 port 40624 on 192.168.1.233 port 22 rdomain "" Dec 19 14:51:28 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:52:04 Claimco sshd[15978]: fatal: Timeout before authentication for 61.177.173.2 port 40624 Dec 19 14:52:08 Claimco sshd[16452]: Connection from 61.177.173.2 port 27945 on 192.168.1.233 port 22 rdomain "" Dec 19 14:52:26 Claimco sshd[16513]: Connection from 84.110.99.202 port 35450 on 192.168.1.233 port 22 rdomain "" Dec 19 14:52:27 Claimco sshd[16513]: Invalid user user from 84.110.99.202 port 35450 Dec 19 14:52:27 Claimco sshd[16513]: pam_unix(sshd:auth): check pass; user unknown Dec 19 14:52:27 Claimco sshd[16513]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=84.110.99.202 Dec 19 14:52:30 Claimco sshd[16513]: Failed password for invalid user user from 84.110.99.202 port 35450 ssh2 Dec 19 14:52:30 Claimco sshd[16513]: Connection closed by invalid user user 84.110.99.202 port 35450 [preauth] Dec 19 14:53:30 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:54:03 Claimco sshd[16905]: Connection from 61.177.173.2 port 47725 on 192.168.1.233 port 22 rdomain "" Dec 19 14:54:08 Claimco sshd[16452]: fatal: Timeout before authentication for 61.177.173.2 port 27945 Dec 19 14:54:40 Claimco sshd[16905]: Connection reset by 61.177.173.2 port 47725 [preauth] Dec 19 14:55:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:56:09 Claimco sshd[17387]: Connection from 61.177.173.2 port 56798 on 192.168.1.233 port 22 rdomain "" Dec 19 14:56:15 Claimco sshd[17387]: Received disconnect from 61.177.173.2 port 56798:11: [preauth] Dec 19 14:56:15 Claimco sshd[17387]: Disconnected from 61.177.173.2 port 56798 [preauth] Dec 19 14:56:22 Claimco sshd[17415]: Connection from 92.255.85.173 port 62983 on 192.168.1.233 port 22 rdomain "" Dec 19 14:56:22 Claimco sshd[17415]: error: kex_exchange_identification: banner line contains invalid characters Dec 19 14:56:22 Claimco sshd[17415]: banner exchange: Connection from 92.255.85.173 port 62983: invalid format Dec 19 14:56:29 Claimco sshd[17452]: Connection from 165.227.87.78 port 35536 on 192.168.1.233 port 22 rdomain "" Dec 19 14:56:29 Claimco sshd[17452]: error: kex_exchange_identification: Connection closed by remote host Dec 19 14:56:29 Claimco sshd[17452]: Connection closed by 165.227.87.78 port 35536 Dec 19 14:57:38 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 14:58:15 Claimco sshd[17835]: Connection from 61.177.173.2 port 19616 on 192.168.1.233 port 22 rdomain "" Dec 19 14:58:31 Claimco sshd[17835]: Received disconnect from 61.177.173.2 port 19616:11: [preauth] Dec 19 14:58:31 Claimco sshd[17835]: Disconnected from 61.177.173.2 port 19616 [preauth] Dec 19 14:59:45 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:00:16 Claimco sshd[18536]: Connection from 61.177.173.2 port 60178 on 192.168.1.233 port 22 rdomain "" Dec 19 15:01:51 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:02:02 Claimco sshd[18902]: Connection from 61.177.173.2 port 64109 on 192.168.1.233 port 22 rdomain "" Dec 19 15:02:16 Claimco sshd[18536]: fatal: Timeout before authentication for 61.177.173.2 port 60178 Dec 19 15:03:55 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:04:02 Claimco sshd[18902]: fatal: Timeout before authentication for 61.177.173.2 port 64109 Dec 19 15:04:06 Claimco sshd[19375]: Connection from 61.177.173.2 port 21533 on 192.168.1.233 port 22 rdomain "" Dec 19 15:04:15 Claimco sshd[19375]: Connection reset by 61.177.173.2 port 21533 [preauth] Dec 19 15:04:40 Claimco sshd[19500]: Connection from 109.146.142.153 port 53746 on 192.168.1.233 port 22 rdomain "" Dec 19 15:04:41 Claimco sshd[19501]: Connection from 109.146.142.153 port 53754 on 192.168.1.233 port 22 rdomain "" Dec 19 15:04:41 Claimco sshd[19500]: Invalid user pi from 109.146.142.153 port 53746 Dec 19 15:04:41 Claimco sshd[19501]: Invalid user pi from 109.146.142.153 port 53754 Dec 19 15:04:42 Claimco sshd[19501]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:04:42 Claimco sshd[19501]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=109.146.142.153 Dec 19 15:04:42 Claimco sshd[19500]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:04:42 Claimco sshd[19500]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=109.146.142.153 Dec 19 15:04:43 Claimco sshd[19501]: Failed password for invalid user pi from 109.146.142.153 port 53754 ssh2 Dec 19 15:04:43 Claimco sshd[19500]: Failed password for invalid user pi from 109.146.142.153 port 53746 ssh2 Dec 19 15:04:44 Claimco sshd[19501]: Connection closed by invalid user pi 109.146.142.153 port 53754 [preauth] Dec 19 15:04:44 Claimco sshd[19500]: Connection closed by invalid user pi 109.146.142.153 port 53746 [preauth] Dec 19 15:06:03 Claimco sshd[19855]: Connection from 61.177.173.2 port 29435 on 192.168.1.233 port 22 rdomain "" Dec 19 15:06:03 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:06:08 Claimco sshd[19855]: Received disconnect from 61.177.173.2 port 29435:11: [preauth] Dec 19 15:06:08 Claimco sshd[19855]: Disconnected from 61.177.173.2 port 29435 [preauth] Dec 19 15:08:01 Claimco sshd[20288]: Connection from 61.177.173.2 port 53569 on 192.168.1.233 port 22 rdomain "" Dec 19 15:08:05 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:08:07 Claimco sshd[20288]: Received disconnect from 61.177.173.2 port 53569:11: [preauth] Dec 19 15:08:07 Claimco sshd[20288]: Disconnected from 61.177.173.2 port 53569 [preauth] Dec 19 15:10:00 Claimco sshd[20900]: Connection from 61.177.173.2 port 26498 on 192.168.1.233 port 22 rdomain "" Dec 19 15:10:07 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:10:10 Claimco sshd[20900]: Connection reset by 61.177.173.2 port 26498 [preauth] Dec 19 15:12:01 Claimco sshd[21369]: Connection from 61.177.173.2 port 54214 on 192.168.1.233 port 22 rdomain "" Dec 19 15:12:09 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:14:01 Claimco sshd[21369]: fatal: Timeout before authentication for 61.177.173.2 port 54214 Dec 19 15:14:07 Claimco sshd[21878]: Connection from 61.177.173.2 port 17446 on 192.168.1.233 port 22 rdomain "" Dec 19 15:14:17 Claimco sshd[21878]: Connection reset by 61.177.173.2 port 17446 [preauth] Dec 19 15:14:22 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:15:53 Claimco sshd[22258]: Connection from 61.177.173.2 port 36607 on 192.168.1.233 port 22 rdomain "" Dec 19 15:16:21 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:17:32 Claimco sshd[22632]: Connection from 61.177.173.2 port 32266 on 192.168.1.233 port 22 rdomain "" Dec 19 15:17:53 Claimco sshd[22258]: fatal: Timeout before authentication for 61.177.173.2 port 36607 Dec 19 15:18:26 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:19:13 Claimco sshd[23234]: Connection from 61.177.173.2 port 37863 on 192.168.1.233 port 22 rdomain "" Dec 19 15:19:32 Claimco sshd[22632]: fatal: Timeout before authentication for 61.177.173.2 port 32266 Dec 19 15:19:59 Claimco sshd[23358]: Connection from 61.177.172.61 port 5746 on 192.168.1.233 port 22 rdomain "" Dec 19 15:19:59 Claimco sshd[23358]: Unable to negotiate with 61.177.172.61 port 5746: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 15:20:33 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:20:56 Claimco sshd[23609]: Connection from 61.177.173.2 port 62126 on 192.168.1.233 port 22 rdomain "" Dec 19 15:20:58 Claimco sshd[23609]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:20:59 Claimco sshd[23609]: Failed password for root from 61.177.173.2 port 62126 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 15:21:07 Claimco sshd[23609]: Received disconnect from 61.177.173.2 port 62126:11: [preauth] Dec 19 15:21:07 Claimco sshd[23609]: Disconnected from authenticating user root 61.177.173.2 port 62126 [preauth] Dec 19 15:21:07 Claimco sshd[23609]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:21:13 Claimco sshd[23234]: fatal: Timeout before authentication for 61.177.173.2 port 37863 Dec 19 15:22:34 Claimco sshd[23957]: Connection from 61.177.173.2 port 54167 on 192.168.1.233 port 22 rdomain "" Dec 19 15:22:37 Claimco sshd[23957]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:22:39 Claimco sshd[23957]: Failed password for root from 61.177.173.2 port 54167 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 15:22:41 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:22:44 Claimco sshd[23957]: Failed password for root from 61.177.173.2 port 54167 ssh2 Dec 19 15:22:44 Claimco sshd[23957]: Received disconnect from 61.177.173.2 port 54167:11: [preauth] Dec 19 15:22:44 Claimco sshd[23957]: Disconnected from authenticating user root 61.177.173.2 port 54167 [preauth] Dec 19 15:22:44 Claimco sshd[23957]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:24:19 Claimco sshd[24388]: Connection from 61.177.173.2 port 39687 on 192.168.1.233 port 22 rdomain "" Dec 19 15:24:45 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:25:58 Claimco sshd[24756]: Connection from 61.177.173.2 port 35652 on 192.168.1.233 port 22 rdomain "" Dec 19 15:26:19 Claimco sshd[24388]: fatal: Timeout before authentication for 61.177.173.2 port 39687 Dec 19 15:26:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:27:39 Claimco sshd[25113]: Connection from 61.177.173.2 port 40911 on 192.168.1.233 port 22 rdomain "" Dec 19 15:27:42 Claimco sshd[25113]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:27:44 Claimco sshd[25113]: Failed password for root from 61.177.173.2 port 40911 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 15:27:49 Claimco sshd[25113]: Received disconnect from 61.177.173.2 port 40911:11: [preauth] Dec 19 15:27:49 Claimco sshd[25113]: Disconnected from authenticating user root 61.177.173.2 port 40911 [preauth] Dec 19 15:27:49 Claimco sshd[25113]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:27:58 Claimco sshd[24756]: fatal: Timeout before authentication for 61.177.173.2 port 35652 Dec 19 15:28:52 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:29:23 Claimco sshd[25738]: Connection from 61.177.173.2 port 64302 on 192.168.1.233 port 22 rdomain "" Dec 19 15:29:25 Claimco sshd[25738]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:29:27 Claimco sshd[25738]: Failed password for root from 61.177.173.2 port 64302 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 15:29:32 Claimco sshd[25738]: Received disconnect from 61.177.173.2 port 64302:11: [preauth] Dec 19 15:29:32 Claimco sshd[25738]: Disconnected from authenticating user root 61.177.173.2 port 64302 [preauth] Dec 19 15:29:32 Claimco sshd[25738]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:31:00 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:31:05 Claimco sshd[26147]: Connection from 61.177.173.2 port 27636 on 192.168.1.233 port 22 rdomain "" Dec 19 15:32:47 Claimco sshd[26471]: Connection from 61.177.173.2 port 41495 on 192.168.1.233 port 22 rdomain "" Dec 19 15:33:00 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:33:05 Claimco sshd[26147]: fatal: Timeout before authentication for 61.177.173.2 port 27636 Dec 19 15:34:28 Claimco sshd[26870]: Connection from 61.177.173.2 port 48438 on 192.168.1.233 port 22 rdomain "" Dec 19 15:34:30 Claimco sshd[26870]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:34:32 Claimco sshd[26870]: Failed password for root from 61.177.173.2 port 48438 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 15:34:37 Claimco sshd[26870]: Received disconnect from 61.177.173.2 port 48438:11: [preauth] Dec 19 15:34:37 Claimco sshd[26870]: Disconnected from authenticating user root 61.177.173.2 port 48438 [preauth] Dec 19 15:34:37 Claimco sshd[26870]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:34:47 Claimco sshd[26471]: fatal: Timeout before authentication for 61.177.173.2 port 41495 Dec 19 15:35:09 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:36:09 Claimco sshd[27300]: Connection from 61.177.173.2 port 61625 on 192.168.1.233 port 22 rdomain "" Dec 19 15:37:10 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:37:51 Claimco sshd[27624]: Connection from 61.177.173.2 port 24275 on 192.168.1.233 port 22 rdomain "" Dec 19 15:38:09 Claimco sshd[27300]: fatal: Timeout before authentication for 61.177.173.2 port 61625 Dec 19 15:39:21 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:39:33 Claimco sshd[28221]: Connection from 61.177.173.2 port 32894 on 192.168.1.233 port 22 rdomain "" Dec 19 15:39:35 Claimco sshd[28221]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:39:37 Claimco sshd[28221]: Failed password for root from 61.177.173.2 port 32894 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 15:39:42 Claimco sshd[28221]: Received disconnect from 61.177.173.2 port 32894:11: [preauth] Dec 19 15:39:42 Claimco sshd[28221]: Disconnected from authenticating user root 61.177.173.2 port 32894 [preauth] Dec 19 15:39:42 Claimco sshd[28221]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:39:51 Claimco sshd[27624]: fatal: Timeout before authentication for 61.177.173.2 port 24275 Dec 19 15:41:15 Claimco sshd[28652]: Connection from 61.177.173.2 port 55203 on 192.168.1.233 port 22 rdomain "" Dec 19 15:41:18 Claimco sshd[28652]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:41:19 Claimco sshd[28652]: Failed password for root from 61.177.173.2 port 55203 ssh2 Dec 19 15:41:20 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:41:22 Claimco sshd[28652]: Failed password for root from 61.177.173.2 port 55203 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 15:41:27 Claimco sshd[28652]: Received disconnect from 61.177.173.2 port 55203:11: [preauth] Dec 19 15:41:27 Claimco sshd[28652]: Disconnected from authenticating user root 61.177.173.2 port 55203 [preauth] Dec 19 15:41:27 Claimco sshd[28652]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:41:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:42:59 Claimco sshd[28980]: Connection from 61.177.173.2 port 25477 on 192.168.1.233 port 22 rdomain "" Dec 19 15:43:01 Claimco sshd[28980]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:43:03 Claimco sshd[28980]: Failed password for root from 61.177.173.2 port 25477 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 15:43:13 Claimco sshd[28980]: Received disconnect from 61.177.173.2 port 25477:11: [preauth] Dec 19 15:43:13 Claimco sshd[28980]: Disconnected from authenticating user root 61.177.173.2 port 25477 [preauth] Dec 19 15:43:13 Claimco sshd[28980]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:43:27 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 15:44:39 Claimco sshd[29380]: Connection from 61.177.173.2 port 24682 on 192.168.1.233 port 22 rdomain "" Dec 19 15:45:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:46:19 Claimco sshd[29792]: Connection from 61.177.173.2 port 23329 on 192.168.1.233 port 22 rdomain "" Dec 19 15:46:39 Claimco sshd[29380]: fatal: Timeout before authentication for 61.177.173.2 port 24682 Dec 19 15:47:36 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:48:03 Claimco sshd[30198]: Connection from 61.177.173.2 port 58154 on 192.168.1.233 port 22 rdomain "" Dec 19 15:48:19 Claimco sshd[29792]: fatal: Timeout before authentication for 61.177.173.2 port 23329 Dec 19 15:49:15 Claimco sshd[30662]: Connection from 13.127.82.216 port 49368 on 192.168.1.233 port 22 rdomain "" Dec 19 15:49:15 Claimco sshd[30662]: error: kex_exchange_identification: Connection closed by remote host Dec 19 15:49:15 Claimco sshd[30662]: Connection closed by 13.127.82.216 port 49368 Dec 19 15:49:23 Claimco sshd[30679]: Connection from 162.218.126.136 port 39858 on 192.168.1.233 port 22 rdomain "" Dec 19 15:49:23 Claimco sshd[30679]: Invalid user user1 from 162.218.126.136 port 39858 Dec 19 15:49:23 Claimco sshd[30679]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:49:23 Claimco sshd[30679]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=162.218.126.136 Dec 19 15:49:25 Claimco sshd[30679]: Failed password for invalid user user1 from 162.218.126.136 port 39858 ssh2 Dec 19 15:49:25 Claimco sshd[30679]: Connection closed by invalid user user1 162.218.126.136 port 39858 [preauth] Dec 19 15:49:41 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:49:45 Claimco sshd[30770]: Connection from 61.177.173.2 port 23782 on 192.168.1.233 port 22 rdomain "" Dec 19 15:49:48 Claimco sshd[30770]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:49:50 Claimco sshd[30770]: Failed password for root from 61.177.173.2 port 23782 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 15:49:55 Claimco sshd[30770]: Received disconnect from 61.177.173.2 port 23782:11: [preauth] Dec 19 15:49:55 Claimco sshd[30770]: Disconnected from authenticating user root 61.177.173.2 port 23782 [preauth] Dec 19 15:49:55 Claimco sshd[30770]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:50:03 Claimco sshd[30198]: fatal: Timeout before authentication for 61.177.173.2 port 58154 Dec 19 15:50:38 Claimco sshd[31016]: Connection from 13.127.82.216 port 45800 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:39 Claimco sshd[31018]: Connection from 13.127.82.216 port 45802 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:39 Claimco sshd[31020]: Connection from 13.127.82.216 port 45816 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:39 Claimco sshd[31024]: Connection from 13.127.82.216 port 45818 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:40 Claimco sshd[31027]: Connection from 13.127.82.216 port 45820 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:40 Claimco sshd[31016]: Invalid user admin from 13.127.82.216 port 45800 Dec 19 15:50:40 Claimco sshd[31018]: Invalid user admin from 13.127.82.216 port 45802 Dec 19 15:50:40 Claimco sshd[31043]: Connection from 13.127.82.216 port 45822 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:40 Claimco sshd[31020]: Invalid user admin from 13.127.82.216 port 45816 Dec 19 15:50:40 Claimco sshd[31018]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:40 Claimco sshd[31018]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:40 Claimco sshd[31016]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:40 Claimco sshd[31016]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:40 Claimco sshd[31020]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:40 Claimco sshd[31020]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:40 Claimco sshd[31047]: Connection from 13.127.82.216 port 45824 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:40 Claimco sshd[31024]: Invalid user admin from 13.127.82.216 port 45818 Dec 19 15:50:40 Claimco sshd[31049]: Connection from 13.127.82.216 port 45828 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:40 Claimco sshd[31024]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:40 Claimco sshd[31024]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:41 Claimco sshd[31027]: Invalid user admin from 13.127.82.216 port 45820 Dec 19 15:50:41 Claimco sshd[31051]: Connection from 13.127.82.216 port 45838 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:41 Claimco sshd[31027]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:41 Claimco sshd[31027]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:41 Claimco sshd[31043]: Invalid user centos from 13.127.82.216 port 45822 Dec 19 15:50:41 Claimco sshd[31053]: Connection from 13.127.82.216 port 45854 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:41 Claimco sshd[31043]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:41 Claimco sshd[31043]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:41 Claimco sshd[31047]: Invalid user centos from 13.127.82.216 port 45824 Dec 19 15:50:41 Claimco sshd[31057]: Connection from 13.127.82.216 port 45868 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:41 Claimco sshd[31049]: Invalid user default from 13.127.82.216 port 45828 Dec 19 15:50:41 Claimco sshd[31047]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:41 Claimco sshd[31047]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:42 Claimco sshd[31059]: Connection from 13.127.82.216 port 45882 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:42 Claimco sshd[31049]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:42 Claimco sshd[31049]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:42 Claimco sshd[31051]: Invalid user guest from 13.127.82.216 port 45838 Dec 19 15:50:42 Claimco sshd[6415]: error: beginning MaxStartups throttling Dec 19 15:50:42 Claimco sshd[6415]: drop connection #12 from [13.127.82.216]:45886 on [192.168.1.233]:22 past MaxStartups Dec 19 15:50:42 Claimco sshd[31051]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:42 Claimco sshd[31051]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:42 Claimco sshd[31053]: Invalid user pi from 13.127.82.216 port 45854 Dec 19 15:50:42 Claimco sshd[31063]: Connection from 13.127.82.216 port 45900 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:42 Claimco sshd[31053]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:42 Claimco sshd[31053]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:42 Claimco sshd[31057]: Invalid user pi from 13.127.82.216 port 45868 Dec 19 15:50:42 Claimco sshd[31065]: Connection from 13.127.82.216 port 45908 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:42 Claimco sshd[31057]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:42 Claimco sshd[31057]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:43 Claimco sshd[31059]: Invalid user debianuser from 13.127.82.216 port 45882 Dec 19 15:50:43 Claimco sshd[31067]: Connection from 13.127.82.216 port 45924 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:43 Claimco sshd[31018]: Failed password for invalid user admin from 13.127.82.216 port 45802 ssh2 Dec 19 15:50:43 Claimco sshd[31016]: Failed password for invalid user admin from 13.127.82.216 port 45800 ssh2 Dec 19 15:50:43 Claimco sshd[31059]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:43 Claimco sshd[31059]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:43 Claimco sshd[6415]: drop connection #15 from [13.127.82.216]:45940 on [192.168.1.233]:22 past MaxStartups Dec 19 15:50:43 Claimco sshd[31020]: Failed password for invalid user admin from 13.127.82.216 port 45816 ssh2 Dec 19 15:50:43 Claimco sshd[31072]: Connection from 13.127.82.216 port 45954 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:43 Claimco sshd[31024]: Failed password for invalid user admin from 13.127.82.216 port 45818 ssh2 Dec 19 15:50:43 Claimco sshd[31018]: Connection closed by invalid user admin 13.127.82.216 port 45802 [preauth] Dec 19 15:50:43 Claimco sshd[31016]: Connection closed by invalid user admin 13.127.82.216 port 45800 [preauth] Dec 19 15:50:43 Claimco sshd[31063]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 user=root Dec 19 15:50:43 Claimco sshd[6415]: drop connection #14 from [13.127.82.216]:45968 on [192.168.1.233]:22 past MaxStartups Dec 19 15:50:43 Claimco sshd[31020]: Connection closed by invalid user admin 13.127.82.216 port 45816 [preauth] Dec 19 15:50:44 Claimco sshd[31065]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 user=root Dec 19 15:50:44 Claimco sshd[31049]: Failed password for invalid user default from 13.127.82.216 port 45828 ssh2 Dec 19 15:50:44 Claimco sshd[31027]: Failed password for invalid user admin from 13.127.82.216 port 45820 ssh2 Dec 19 15:50:44 Claimco sshd[31074]: Connection from 13.127.82.216 port 45982 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:44 Claimco sshd[31024]: Connection closed by invalid user admin 13.127.82.216 port 45818 [preauth] Dec 19 15:50:44 Claimco sshd[31067]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 user=root Dec 19 15:50:44 Claimco sshd[31076]: Connection from 13.127.82.216 port 45996 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:44 Claimco sshd[31051]: Failed password for invalid user guest from 13.127.82.216 port 45838 ssh2 Dec 19 15:50:44 Claimco sshd[31043]: Failed password for invalid user centos from 13.127.82.216 port 45822 ssh2 Dec 19 15:50:44 Claimco sshd[31027]: Connection closed by invalid user admin 13.127.82.216 port 45820 [preauth] Dec 19 15:50:44 Claimco sshd[31053]: Failed password for invalid user pi from 13.127.82.216 port 45854 ssh2 Dec 19 15:50:44 Claimco sshd[31080]: Connection from 13.127.82.216 port 46000 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:44 Claimco sshd[31051]: Connection closed by invalid user guest 13.127.82.216 port 45838 [preauth] Dec 19 15:50:44 Claimco sshd[31047]: Failed password for invalid user centos from 13.127.82.216 port 45824 ssh2 Dec 19 15:50:44 Claimco sshd[31072]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 user=root Dec 19 15:50:44 Claimco sshd[31057]: Failed password for invalid user pi from 13.127.82.216 port 45868 ssh2 Dec 19 15:50:44 Claimco sshd[31082]: Connection from 13.127.82.216 port 46010 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:45 Claimco sshd[31043]: Connection closed by invalid user centos 13.127.82.216 port 45822 [preauth] Dec 19 15:50:45 Claimco sshd[31059]: Failed password for invalid user debianuser from 13.127.82.216 port 45882 ssh2 Dec 19 15:50:45 Claimco sshd[31049]: Connection closed by invalid user default 13.127.82.216 port 45828 [preauth] Dec 19 15:50:45 Claimco sshd[6415]: drop connection #12 from [13.127.82.216]:54008 on [192.168.1.233]:22 past MaxStartups Dec 19 15:50:45 Claimco sshd[31053]: Connection closed by invalid user pi 13.127.82.216 port 45854 [preauth] Dec 19 15:50:45 Claimco sshd[31047]: Connection closed by invalid user centos 13.127.82.216 port 45824 [preauth] Dec 19 15:50:45 Claimco sshd[31074]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 user=root Dec 19 15:50:45 Claimco sshd[6415]: drop connection #10 from [13.127.82.216]:54018 on [192.168.1.233]:22 past MaxStartups Dec 19 15:50:45 Claimco sshd[31057]: Connection closed by invalid user pi 13.127.82.216 port 45868 [preauth] Dec 19 15:50:45 Claimco sshd[31063]: Failed password for root from 13.127.82.216 port 45900 ssh2 Dec 19 15:50:45 Claimco sshd[31076]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 user=root Dec 19 15:50:45 Claimco sshd[31086]: Connection from 13.127.82.216 port 54030 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:45 Claimco sshd[31080]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 user=root Dec 19 15:50:45 Claimco sshd[31082]: Invalid user test from 13.127.82.216 port 46010 Dec 19 15:50:46 Claimco sshd[31065]: Failed password for root from 13.127.82.216 port 45908 ssh2 Dec 19 15:50:46 Claimco sshd[31088]: Connection from 13.127.82.216 port 54040 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:46 Claimco sshd[31082]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:46 Claimco sshd[31082]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:46 Claimco sshd[31063]: Connection closed by authenticating user root 13.127.82.216 port 45900 [preauth] Dec 19 15:50:46 Claimco sshd[31067]: Failed password for root from 13.127.82.216 port 45924 ssh2 Dec 19 15:50:46 Claimco sshd[31090]: Connection from 13.127.82.216 port 54044 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:46 Claimco sshd[31065]: Connection closed by authenticating user root 13.127.82.216 port 45908 [preauth] Dec 19 15:50:46 Claimco sshd[31092]: Connection from 13.127.82.216 port 54050 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:46 Claimco sshd[31072]: Failed password for root from 13.127.82.216 port 45954 ssh2 Dec 19 15:50:46 Claimco sshd[31067]: Connection closed by authenticating user root 13.127.82.216 port 45924 [preauth] Dec 19 15:50:46 Claimco sshd[31096]: Connection from 13.127.82.216 port 54060 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:46 Claimco sshd[31059]: Connection closed by invalid user debianuser 13.127.82.216 port 45882 [preauth] Dec 19 15:50:46 Claimco sshd[31088]: Invalid user test from 13.127.82.216 port 54040 Dec 19 15:50:46 Claimco sshd[31086]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 user=root Dec 19 15:50:47 Claimco sshd[31098]: Connection from 13.127.82.216 port 54064 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:47 Claimco sshd[31088]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:47 Claimco sshd[31088]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:47 Claimco sshd[31090]: Invalid user test from 13.127.82.216 port 54044 Dec 19 15:50:47 Claimco sshd[31072]: Connection closed by authenticating user root 13.127.82.216 port 45954 [preauth] Dec 19 15:50:47 Claimco sshd[31100]: Connection from 13.127.82.216 port 54066 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:47 Claimco sshd[31090]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:47 Claimco sshd[31090]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:47 Claimco sshd[31092]: Invalid user git from 13.127.82.216 port 54050 Dec 19 15:50:47 Claimco sshd[6415]: drop connection #11 from [13.127.82.216]:54076 on [192.168.1.233]:22 past MaxStartups Dec 19 15:50:47 Claimco sshd[31092]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:47 Claimco sshd[31092]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:47 Claimco sshd[31074]: Failed password for root from 13.127.82.216 port 45982 ssh2 Dec 19 15:50:47 Claimco sshd[31096]: Invalid user git from 13.127.82.216 port 54060 Dec 19 15:50:47 Claimco sshd[31104]: Connection from 13.127.82.216 port 54080 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:48 Claimco sshd[31076]: Failed password for root from 13.127.82.216 port 45996 ssh2 Dec 19 15:50:48 Claimco sshd[31096]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:48 Claimco sshd[31096]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:48 Claimco sshd[31098]: Invalid user guest from 13.127.82.216 port 54064 Dec 19 15:50:48 Claimco sshd[31106]: Connection from 13.127.82.216 port 54088 on 192.168.1.233 port 22 rdomain "" Dec 19 15:50:48 Claimco sshd[31080]: Failed password for root from 13.127.82.216 port 46000 ssh2 Dec 19 15:50:48 Claimco sshd[31100]: Invalid user ubuntu from 13.127.82.216 port 54066 Dec 19 15:50:48 Claimco sshd[31082]: Failed password for invalid user test from 13.127.82.216 port 46010 ssh2 Dec 19 15:50:48 Claimco sshd[31098]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:48 Claimco sshd[31098]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:48 Claimco sshd[31100]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:48 Claimco sshd[31100]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:48 Claimco sshd[31104]: Invalid user guest from 13.127.82.216 port 54080 Dec 19 15:50:49 Claimco sshd[31104]: pam_unix(sshd:auth): check pass; user unknown Dec 19 15:50:49 Claimco sshd[31104]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 Dec 19 15:50:49 Claimco sshd[31086]: Failed password for root from 13.127.82.216 port 54030 ssh2 Dec 19 15:50:49 Claimco sshd[31106]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=13.127.82.216 user=root Dec 19 15:50:49 Claimco sshd[31096]: Failed password for invalid user git from 13.127.82.216 port 54060 ssh2 Dec 19 15:50:49 Claimco sshd[31098]: Failed password for invalid user guest from 13.127.82.216 port 54064 ssh2 Dec 19 15:50:49 Claimco sshd[31088]: Failed password for invalid user test from 13.127.82.216 port 54040 ssh2 Dec 19 15:50:49 Claimco sshd[31096]: Connection closed by invalid user git 13.127.82.216 port 54060 [preauth] Dec 19 15:50:50 Claimco sshd[31100]: Failed password for invalid user ubuntu from 13.127.82.216 port 54066 ssh2 Dec 19 15:50:50 Claimco sshd[31074]: Connection closed by authenticating user root 13.127.82.216 port 45982 [preauth] Dec 19 15:50:50 Claimco sshd[31090]: Failed password for invalid user test from 13.127.82.216 port 54044 ssh2 Dec 19 15:50:50 Claimco sshd[31076]: Connection closed by authenticating user root 13.127.82.216 port 45996 [preauth] Dec 19 15:50:50 Claimco sshd[31082]: Connection reset by invalid user test 13.127.82.216 port 46010 [preauth] Dec 19 15:50:50 Claimco sshd[31100]: Connection reset by invalid user ubuntu 13.127.82.216 port 54066 [preauth] Dec 19 15:50:50 Claimco sshd[31098]: Connection reset by invalid user guest 13.127.82.216 port 54064 [preauth] Dec 19 15:50:50 Claimco sshd[31092]: Failed password for invalid user git from 13.127.82.216 port 54050 ssh2 Dec 19 15:50:50 Claimco sshd[31080]: Connection reset by authenticating user root 13.127.82.216 port 46000 [preauth] Dec 19 15:50:51 Claimco sshd[31092]: Connection reset by invalid user git 13.127.82.216 port 54050 [preauth] Dec 19 15:50:51 Claimco sshd[31104]: Failed password for invalid user guest from 13.127.82.216 port 54080 ssh2 Dec 19 15:50:51 Claimco sshd[31088]: Connection reset by invalid user test 13.127.82.216 port 54040 [preauth] Dec 19 15:50:51 Claimco sshd[31104]: Connection reset by invalid user guest 13.127.82.216 port 54080 [preauth] Dec 19 15:50:51 Claimco sshd[31106]: Failed password for root from 13.127.82.216 port 54088 ssh2 Dec 19 15:50:51 Claimco sshd[31090]: Connection reset by invalid user test 13.127.82.216 port 54044 [preauth] Dec 19 15:50:51 Claimco sshd[31086]: Connection reset by authenticating user root 13.127.82.216 port 54030 [preauth] Dec 19 15:50:51 Claimco sshd[31106]: Connection reset by authenticating user root 13.127.82.216 port 54088 [preauth] Dec 19 15:51:23 Claimco sshd[6415]: exited MaxStartups throttling after 00:00:41, 6 connections dropped Dec 19 15:51:23 Claimco sshd[31237]: Connection from 61.177.173.42 port 32036 on 192.168.1.233 port 22 rdomain "" Dec 19 15:51:23 Claimco sshd[31237]: Unable to negotiate with 61.177.173.42 port 32036: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 15:51:25 Claimco sshd[31243]: Connection from 61.177.173.2 port 19381 on 192.168.1.233 port 22 rdomain "" Dec 19 15:51:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:53:05 Claimco sshd[31640]: Connection from 61.177.173.2 port 23962 on 192.168.1.233 port 22 rdomain "" Dec 19 15:53:25 Claimco sshd[31243]: fatal: Timeout before authentication for 61.177.173.2 port 19381 Dec 19 15:53:58 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:54:49 Claimco sshd[31995]: Connection from 61.177.173.2 port 51941 on 192.168.1.233 port 22 rdomain "" Dec 19 15:55:05 Claimco sshd[31640]: fatal: Timeout before authentication for 61.177.173.2 port 23962 Dec 19 15:56:02 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:56:30 Claimco sshd[32394]: Connection from 61.177.173.2 port 60066 on 192.168.1.233 port 22 rdomain "" Dec 19 15:56:32 Claimco sshd[32394]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:56:34 Claimco sshd[32394]: Failed password for root from 61.177.173.2 port 60066 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 15:56:41 Claimco sshd[32394]: Received disconnect from 61.177.173.2 port 60066:11: [preauth] Dec 19 15:56:41 Claimco sshd[32394]: Disconnected from authenticating user root 61.177.173.2 port 60066 [preauth] Dec 19 15:56:41 Claimco sshd[32394]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 15:56:49 Claimco sshd[31995]: fatal: Timeout before authentication for 61.177.173.2 port 51941 Dec 19 15:58:01 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 15:58:11 Claimco sshd[32767]: Connection from 61.177.173.2 port 15876 on 192.168.1.233 port 22 rdomain "" Dec 19 15:59:01 Claimco sshd[496]: Connection from 69.112.204.55 port 57700 on 192.168.1.233 port 22 rdomain "" Dec 19 15:59:02 Claimco sshd[496]: ssh_dispatch_run_fatal: Connection from 69.112.204.55 port 57700: Connection corrupted [preauth] Dec 19 15:59:52 Claimco sshd[918]: Connection from 61.177.173.2 port 21873 on 192.168.1.233 port 22 rdomain "" Dec 19 16:00:09 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:00:11 Claimco sshd[32767]: fatal: Timeout before authentication for 61.177.173.2 port 15876 Dec 19 16:01:33 Claimco sshd[1334]: Connection from 61.177.173.2 port 35702 on 192.168.1.233 port 22 rdomain "" Dec 19 16:01:35 Claimco sshd[1334]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:01:38 Claimco sshd[1334]: Failed password for root from 61.177.173.2 port 35702 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 16:01:45 Claimco sshd[1334]: Received disconnect from 61.177.173.2 port 35702:11: [preauth] Dec 19 16:01:45 Claimco sshd[1334]: Disconnected from authenticating user root 61.177.173.2 port 35702 [preauth] Dec 19 16:01:45 Claimco sshd[1334]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:01:52 Claimco sshd[918]: fatal: Timeout before authentication for 61.177.173.2 port 21873 Dec 19 16:02:16 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:03:15 Claimco sshd[1711]: Connection from 61.177.173.2 port 54845 on 192.168.1.233 port 22 rdomain "" Dec 19 16:04:23 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:04:56 Claimco sshd[2090]: Connection from 61.177.173.2 port 58320 on 192.168.1.233 port 22 rdomain "" Dec 19 16:05:15 Claimco sshd[1711]: fatal: Timeout before authentication for 61.177.173.2 port 54845 Dec 19 16:06:23 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:06:37 Claimco sshd[2496]: Connection from 61.177.173.2 port 14578 on 192.168.1.233 port 22 rdomain "" Dec 19 16:06:56 Claimco sshd[2090]: fatal: Timeout before authentication for 61.177.173.2 port 58320 Dec 19 16:07:59 Claimco sshd[2751]: Connection from 65.2.28.105 port 34596 on 192.168.1.233 port 22 rdomain "" Dec 19 16:08:01 Claimco sshd[2751]: Invalid user user33 from 65.2.28.105 port 34596 Dec 19 16:08:01 Claimco sshd[2751]: pam_unix(sshd:auth): check pass; user unknown Dec 19 16:08:01 Claimco sshd[2751]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=65.2.28.105 Dec 19 16:08:03 Claimco sshd[2751]: Failed password for invalid user user33 from 65.2.28.105 port 34596 ssh2 Dec 19 16:08:04 Claimco sshd[2751]: Connection closed by invalid user user33 65.2.28.105 port 34596 [preauth] Dec 19 16:08:20 Claimco sshd[2868]: Connection from 61.177.173.2 port 43915 on 192.168.1.233 port 22 rdomain "" Dec 19 16:08:24 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:08:37 Claimco sshd[2496]: fatal: Timeout before authentication for 61.177.173.2 port 14578 Dec 19 16:10:01 Claimco sshd[3421]: Connection from 61.177.173.2 port 54932 on 192.168.1.233 port 22 rdomain "" Dec 19 16:10:20 Claimco sshd[2868]: fatal: Timeout before authentication for 61.177.173.2 port 43915 Dec 19 16:10:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:11:17 Claimco sshd[3770]: Connection from 103.203.57.11 port 37468 on 192.168.1.233 port 22 rdomain "" Dec 19 16:11:17 Claimco sshd[3770]: error: kex_exchange_identification: Connection closed by remote host Dec 19 16:11:17 Claimco sshd[3770]: Connection closed by 103.203.57.11 port 37468 Dec 19 16:11:44 Claimco sshd[3855]: Connection from 61.177.173.2 port 23400 on 192.168.1.233 port 22 rdomain "" Dec 19 16:12:01 Claimco sshd[3421]: fatal: Timeout before authentication for 61.177.173.2 port 54932 Dec 19 16:12:38 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:13:25 Claimco sshd[4222]: Connection from 61.177.173.2 port 30491 on 192.168.1.233 port 22 rdomain "" Dec 19 16:13:27 Claimco sshd[4222]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:13:29 Claimco sshd[4222]: Failed password for root from 61.177.173.2 port 30491 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 16:13:34 Claimco sshd[4222]: Received disconnect from 61.177.173.2 port 30491:11: [preauth] Dec 19 16:13:34 Claimco sshd[4222]: Disconnected from authenticating user root 61.177.173.2 port 30491 [preauth] Dec 19 16:13:34 Claimco sshd[4222]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:13:44 Claimco sshd[3855]: fatal: Timeout before authentication for 61.177.173.2 port 23400 Dec 19 16:14:42 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:15:06 Claimco sshd[4611]: Connection from 61.177.173.2 port 41992 on 192.168.1.233 port 22 rdomain "" Dec 19 16:15:08 Claimco sshd[4611]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:15:10 Claimco sshd[4611]: Failed password for root from 61.177.173.2 port 41992 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 16:15:17 Claimco sshd[4611]: Received disconnect from 61.177.173.2 port 41992:11: [preauth] Dec 19 16:15:17 Claimco sshd[4611]: Disconnected from authenticating user root 61.177.173.2 port 41992 [preauth] Dec 19 16:15:17 Claimco sshd[4611]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:16:49 Claimco sshd[5008]: Connection from 61.177.173.2 port 13784 on 192.168.1.233 port 22 rdomain "" Dec 19 16:16:51 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:17:07 Claimco proftpd[5079]: 127.0.0.1 (43.138.183.196[43.138.183.196]) - USER www: no such user found from 43.138.183.196 [43.138.183.196] to ::ffff:192.168.1.233:21 Dec 19 16:17:08 Claimco proftpd[5097]: 127.0.0.1 (43.138.183.196[43.138.183.196]) - USER www: no such user found from 43.138.183.196 [43.138.183.196] to ::ffff:192.168.1.233:21 Dec 19 16:17:09 Claimco proftpd[5100]: 127.0.0.1 (43.138.183.196[43.138.183.196]) - USER www: no such user found from 43.138.183.196 [43.138.183.196] to ::ffff:192.168.1.233:21 Dec 19 16:17:10 Claimco proftpd[5103]: 127.0.0.1 (43.138.183.196[43.138.183.196]) - USER www: no such user found from 43.138.183.196 [43.138.183.196] to ::ffff:192.168.1.233:21 Dec 19 16:17:11 Claimco proftpd[5106]: 127.0.0.1 (43.138.183.196[43.138.183.196]) - USER www: no such user found from 43.138.183.196 [43.138.183.196] to ::ffff:192.168.1.233:21 Dec 19 16:17:11 Claimco proftpd[5109]: 127.0.0.1 (43.138.183.196[43.138.183.196]) - USER www: no such user found from 43.138.183.196 [43.138.183.196] to ::ffff:192.168.1.233:21 Dec 19 16:17:12 Claimco proftpd[5112]: 127.0.0.1 (43.138.183.196[43.138.183.196]) - USER www: no such user found from 43.138.183.196 [43.138.183.196] to ::ffff:192.168.1.233:21 Dec 19 16:17:13 Claimco proftpd[5115]: 127.0.0.1 (43.138.183.196[43.138.183.196]) - USER www: no such user found from 43.138.183.196 [43.138.183.196] to ::ffff:192.168.1.233:21 Dec 19 16:17:14 Claimco proftpd[5116]: 127.0.0.1 (43.138.183.196[43.138.183.196]) - USER www: no such user found from 43.138.183.196 [43.138.183.196] to ::ffff:192.168.1.233:21 Dec 19 16:17:15 Claimco proftpd[5119]: 127.0.0.1 (43.138.183.196[43.138.183.196]) - USER www: no such user found from 43.138.183.196 [43.138.183.196] to ::ffff:192.168.1.233:21 Dec 19 16:18:28 Claimco sshd[5381]: Connection from 61.177.173.2 port 61040 on 192.168.1.233 port 22 rdomain "" Dec 19 16:18:49 Claimco sshd[5008]: fatal: Timeout before authentication for 61.177.173.2 port 13784 Dec 19 16:18:52 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:20:10 Claimco sshd[6017]: Connection from 61.177.173.2 port 25750 on 192.168.1.233 port 22 rdomain "" Dec 19 16:20:28 Claimco sshd[5381]: fatal: Timeout before authentication for 61.177.173.2 port 61040 Dec 19 16:20:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:21:56 Claimco sshd[6376]: Connection from 61.177.173.2 port 19830 on 192.168.1.233 port 22 rdomain "" Dec 19 16:22:06 Claimco sshd[6441]: Connection from 61.177.173.61 port 65376 on 192.168.1.233 port 22 rdomain "" Dec 19 16:22:10 Claimco sshd[6017]: fatal: Timeout before authentication for 61.177.173.2 port 25750 Dec 19 16:23:02 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:23:33 Claimco sshd[6749]: Connection from 61.177.173.2 port 47178 on 192.168.1.233 port 22 rdomain "" Dec 19 16:23:42 Claimco sshd[6801]: Connection from 84.110.99.202 port 33850 on 192.168.1.233 port 22 rdomain "" Dec 19 16:23:42 Claimco sshd[6801]: Invalid user hive from 84.110.99.202 port 33850 Dec 19 16:23:43 Claimco sshd[6801]: pam_unix(sshd:auth): check pass; user unknown Dec 19 16:23:43 Claimco sshd[6801]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=84.110.99.202 Dec 19 16:23:45 Claimco sshd[6801]: Failed password for invalid user hive from 84.110.99.202 port 33850 ssh2 Dec 19 16:23:46 Claimco sshd[6801]: Connection closed by invalid user hive 84.110.99.202 port 33850 [preauth] Dec 19 16:23:56 Claimco sshd[6376]: fatal: Timeout before authentication for 61.177.173.2 port 19830 Dec 19 16:24:06 Claimco sshd[6441]: fatal: Timeout before authentication for 61.177.173.61 port 65376 Dec 19 16:25:11 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:25:16 Claimco sshd[7197]: Connection from 61.177.173.2 port 17266 on 192.168.1.233 port 22 rdomain "" Dec 19 16:25:33 Claimco sshd[6749]: fatal: Timeout before authentication for 61.177.173.2 port 47178 Dec 19 16:26:55 Claimco sshd[7627]: Connection from 61.177.173.2 port 11983 on 192.168.1.233 port 22 rdomain "" Dec 19 16:27:12 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:27:16 Claimco sshd[7197]: fatal: Timeout before authentication for 61.177.173.2 port 17266 Dec 19 16:27:23 Claimco nginx: 2022/12/19 16:27:23 [crit] 6648#6648: *80509 SSL_do_handshake() failed (SSL: error:141CF06C:SSL routines:tls_parse_ctos_key_share:bad key share) while SSL handshaking, client: 157.245.98.7, server: 0.0.0.0:443 Dec 19 16:28:38 Claimco sshd[8092]: Connection from 61.177.173.2 port 38606 on 192.168.1.233 port 22 rdomain "" Dec 19 16:28:55 Claimco sshd[7627]: fatal: Timeout before authentication for 61.177.173.2 port 11983 Dec 19 16:29:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:30:19 Claimco sshd[8720]: Connection from 61.177.173.2 port 49149 on 192.168.1.233 port 22 rdomain "" Dec 19 16:30:21 Claimco sshd[8720]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:30:23 Claimco sshd[8720]: Failed password for root from 61.177.173.2 port 49149 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 16:30:33 Claimco sshd[8720]: Received disconnect from 61.177.173.2 port 49149:11: [preauth] Dec 19 16:30:33 Claimco sshd[8720]: Disconnected from authenticating user root 61.177.173.2 port 49149 [preauth] Dec 19 16:30:33 Claimco sshd[8720]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:30:38 Claimco sshd[8092]: fatal: Timeout before authentication for 61.177.173.2 port 38606 Dec 19 16:31:24 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:32:02 Claimco sshd[9085]: Connection from 61.177.173.2 port 19601 on 192.168.1.233 port 22 rdomain "" Dec 19 16:32:04 Claimco sshd[9085]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:32:06 Claimco sshd[9085]: Failed password for root from 61.177.173.2 port 19601 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 16:32:11 Claimco sshd[9085]: Received disconnect from 61.177.173.2 port 19601:11: [preauth] Dec 19 16:32:11 Claimco sshd[9085]: Disconnected from authenticating user root 61.177.173.2 port 19601 [preauth] Dec 19 16:32:11 Claimco sshd[9085]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:33:27 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:33:43 Claimco sshd[9452]: Connection from 61.177.173.2 port 32124 on 192.168.1.233 port 22 rdomain "" Dec 19 16:33:45 Claimco sshd[9452]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:33:47 Claimco sshd[9452]: Failed password for root from 61.177.173.2 port 32124 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 16:33:52 Claimco sshd[9452]: Received disconnect from 61.177.173.2 port 32124:11: [preauth] Dec 19 16:33:52 Claimco sshd[9452]: Disconnected from authenticating user root 61.177.173.2 port 32124 [preauth] Dec 19 16:33:52 Claimco sshd[9452]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:33:53 Claimco sshd[9497]: Connection from 130.61.28.220 port 22618 on 192.168.1.233 port 22 rdomain "" Dec 19 16:33:54 Claimco sshd[9497]: Unable to negotiate with 130.61.28.220 port 22618: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1 [preauth] Dec 19 16:35:25 Claimco sshd[9881]: Connection from 61.177.173.2 port 52537 on 192.168.1.233 port 22 rdomain "" Dec 19 16:35:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:37:05 Claimco sshd[10234]: Connection from 61.177.173.2 port 46450 on 192.168.1.233 port 22 rdomain "" Dec 19 16:37:25 Claimco sshd[9881]: fatal: Timeout before authentication for 61.177.173.2 port 52537 Dec 19 16:37:34 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:38:46 Claimco sshd[10600]: Connection from 61.177.173.2 port 10364 on 192.168.1.233 port 22 rdomain "" Dec 19 16:38:48 Claimco sshd[10600]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:38:51 Claimco sshd[10600]: Failed password for root from 61.177.173.2 port 10364 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 16:38:56 Claimco sshd[10600]: Received disconnect from 61.177.173.2 port 10364:11: [preauth] Dec 19 16:38:56 Claimco sshd[10600]: Disconnected from authenticating user root 61.177.173.2 port 10364 [preauth] Dec 19 16:38:56 Claimco sshd[10600]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:39:05 Claimco sshd[10234]: fatal: Timeout before authentication for 61.177.173.2 port 46450 Dec 19 16:39:41 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:40:28 Claimco sshd[11227]: Connection from 61.177.173.2 port 25729 on 192.168.1.233 port 22 rdomain "" Dec 19 16:40:30 Claimco sshd[11227]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:40:31 Claimco sshd[11227]: Failed password for root from 61.177.173.2 port 25729 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 16:40:37 Claimco sshd[11227]: Received disconnect from 61.177.173.2 port 25729:11: [preauth] Dec 19 16:40:37 Claimco sshd[11227]: Disconnected from authenticating user root 61.177.173.2 port 25729 [preauth] Dec 19 16:40:37 Claimco sshd[11227]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:41:45 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 16:42:08 Claimco sshd[11585]: Connection from 61.177.173.2 port 32368 on 192.168.1.233 port 22 rdomain "" Dec 19 16:43:38 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:43:50 Claimco sshd[11952]: Connection from 61.177.173.2 port 51449 on 192.168.1.233 port 22 rdomain "" Dec 19 16:43:51 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:44:08 Claimco sshd[11585]: fatal: Timeout before authentication for 61.177.173.2 port 32368 Dec 19 16:45:32 Claimco sshd[12370]: Connection from 61.177.173.2 port 14903 on 192.168.1.233 port 22 rdomain "" Dec 19 16:45:50 Claimco sshd[11952]: fatal: Timeout before authentication for 61.177.173.2 port 51449 Dec 19 16:45:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:47:13 Claimco sshd[12754]: Connection from 61.177.173.2 port 25270 on 192.168.1.233 port 22 rdomain "" Dec 19 16:47:32 Claimco sshd[12370]: fatal: Timeout before authentication for 61.177.173.2 port 14903 Dec 19 16:48:02 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:48:55 Claimco sshd[13123]: Connection from 61.177.173.2 port 44083 on 192.168.1.233 port 22 rdomain "" Dec 19 16:49:13 Claimco sshd[12754]: fatal: Timeout before authentication for 61.177.173.2 port 25270 Dec 19 16:50:05 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:50:36 Claimco sshd[13724]: Connection from 61.177.173.2 port 56360 on 192.168.1.233 port 22 rdomain "" Dec 19 16:50:38 Claimco sshd[13724]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:50:40 Claimco sshd[13724]: Failed password for root from 61.177.173.2 port 56360 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 16:50:48 Claimco sshd[13724]: Received disconnect from 61.177.173.2 port 56360:11: [preauth] Dec 19 16:50:48 Claimco sshd[13724]: Disconnected from authenticating user root 61.177.173.2 port 56360 [preauth] Dec 19 16:50:48 Claimco sshd[13724]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:50:55 Claimco sshd[13123]: fatal: Timeout before authentication for 61.177.173.2 port 44083 Dec 19 16:52:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:52:18 Claimco sshd[14107]: Connection from 61.177.173.2 port 25438 on 192.168.1.233 port 22 rdomain "" Dec 19 16:52:41 Claimco sshd[14161]: Connection from 61.177.173.56 port 11336 on 192.168.1.233 port 22 rdomain "" Dec 19 16:53:58 Claimco sshd[14473]: Connection from 61.177.173.2 port 29787 on 192.168.1.233 port 22 rdomain "" Dec 19 16:54:01 Claimco sshd[14473]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:54:02 Claimco sshd[14473]: Failed password for root from 61.177.173.2 port 29787 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 16:54:08 Claimco sshd[14473]: Received disconnect from 61.177.173.2 port 29787:11: [preauth] Dec 19 16:54:08 Claimco sshd[14473]: Disconnected from authenticating user root 61.177.173.2 port 29787 [preauth] Dec 19 16:54:08 Claimco sshd[14473]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:54:18 Claimco sshd[14107]: fatal: Timeout before authentication for 61.177.173.2 port 25438 Dec 19 16:54:19 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:54:41 Claimco sshd[14161]: fatal: Timeout before authentication for 61.177.173.56 port 11336 Dec 19 16:55:40 Claimco sshd[14878]: Connection from 61.177.173.2 port 43436 on 192.168.1.233 port 22 rdomain "" Dec 19 16:56:21 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:57:22 Claimco sshd[15233]: Connection from 61.177.173.2 port 11818 on 192.168.1.233 port 22 rdomain "" Dec 19 16:57:40 Claimco sshd[14878]: fatal: Timeout before authentication for 61.177.173.2 port 43436 Dec 19 16:58:25 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 16:59:03 Claimco sshd[15658]: Connection from 61.177.173.2 port 28241 on 192.168.1.233 port 22 rdomain "" Dec 19 16:59:05 Claimco sshd[15658]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:59:07 Claimco sshd[15658]: Failed password for root from 61.177.173.2 port 28241 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 16:59:15 Claimco sshd[15658]: Received disconnect from 61.177.173.2 port 28241:11: [preauth] Dec 19 16:59:15 Claimco sshd[15658]: Disconnected from authenticating user root 61.177.173.2 port 28241 [preauth] Dec 19 16:59:15 Claimco sshd[15658]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 16:59:22 Claimco sshd[15233]: fatal: Timeout before authentication for 61.177.173.2 port 11818 Dec 19 17:00:30 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:00:41 Claimco sshd[16223]: Connection from 61.177.173.2 port 13516 on 192.168.1.233 port 22 rdomain "" Dec 19 17:00:43 Claimco sshd[16223]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:00:45 Claimco sshd[16223]: Failed password for root from 61.177.173.2 port 13516 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:00:50 Claimco sshd[16223]: Received disconnect from 61.177.173.2 port 13516:11: [preauth] Dec 19 17:00:50 Claimco sshd[16223]: Disconnected from authenticating user root 61.177.173.2 port 13516 [preauth] Dec 19 17:00:50 Claimco sshd[16223]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:02:25 Claimco sshd[16582]: Connection from 61.177.173.2 port 52253 on 192.168.1.233 port 22 rdomain "" Dec 19 17:02:41 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:04:04 Claimco sshd[16979]: Connection from 61.177.173.2 port 45952 on 192.168.1.233 port 22 rdomain "" Dec 19 17:04:25 Claimco sshd[16582]: fatal: Timeout before authentication for 61.177.173.2 port 52253 Dec 19 17:04:40 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:05:45 Claimco sshd[17374]: Connection from 61.177.173.2 port 63115 on 192.168.1.233 port 22 rdomain "" Dec 19 17:06:04 Claimco sshd[16979]: fatal: Timeout before authentication for 61.177.173.2 port 45952 Dec 19 17:06:45 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:07:27 Claimco sshd[17729]: Connection from 61.177.173.2 port 26297 on 192.168.1.233 port 22 rdomain "" Dec 19 17:07:45 Claimco sshd[17374]: fatal: Timeout before authentication for 61.177.173.2 port 63115 Dec 19 17:08:51 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:09:09 Claimco sshd[18131]: Connection from 61.177.173.2 port 40716 on 192.168.1.233 port 22 rdomain "" Dec 19 17:09:27 Claimco sshd[17729]: fatal: Timeout before authentication for 61.177.173.2 port 26297 Dec 19 17:10:50 Claimco sshd[18725]: Connection from 61.177.173.2 port 32491 on 192.168.1.233 port 22 rdomain "" Dec 19 17:10:51 Claimco sshd[18725]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:10:53 Claimco sshd[18725]: Failed password for root from 61.177.173.2 port 32491 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 17:10:56 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:10:57 Claimco sshd[18725]: Failed password for root from 61.177.173.2 port 32491 ssh2 Dec 19 17:10:58 Claimco sshd[18725]: Received disconnect from 61.177.173.2 port 32491:11: [preauth] Dec 19 17:10:58 Claimco sshd[18725]: Disconnected from authenticating user root 61.177.173.2 port 32491 [preauth] Dec 19 17:10:58 Claimco sshd[18725]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:11:09 Claimco sshd[18131]: fatal: Timeout before authentication for 61.177.173.2 port 40716 Dec 19 17:12:27 Claimco sshd[19071]: Connection from 61.177.173.2 port 51771 on 192.168.1.233 port 22 rdomain "" Dec 19 17:12:28 Claimco sshd[19071]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:12:30 Claimco sshd[19071]: Failed password for root from 61.177.173.2 port 51771 ssh2 Dec 19 17:12:31 Claimco sshd[19081]: Connection from 162.218.126.136 port 39348 on 192.168.1.233 port 22 rdomain "" Dec 19 17:12:31 Claimco sshd[19081]: Invalid user user from 162.218.126.136 port 39348 Dec 19 17:12:31 Claimco sshd[19081]: pam_unix(sshd:auth): check pass; user unknown Dec 19 17:12:31 Claimco sshd[19081]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=162.218.126.136 Dec 19 17:12:32 Claimco sshd[19071]: Failed password for root from 61.177.173.2 port 51771 ssh2 Dec 19 17:12:33 Claimco sshd[19081]: Failed password for invalid user user from 162.218.126.136 port 39348 ssh2 Dec 19 17:12:34 Claimco sshd[19081]: Connection closed by invalid user user 162.218.126.136 port 39348 [preauth] Dec 19 17:12:35 Claimco sshd[19071]: Failed password for root from 61.177.173.2 port 51771 ssh2 Dec 19 17:12:35 Claimco sshd[19071]: Received disconnect from 61.177.173.2 port 51771:11: [preauth] Dec 19 17:12:35 Claimco sshd[19071]: Disconnected from authenticating user root 61.177.173.2 port 51771 [preauth] Dec 19 17:12:35 Claimco sshd[19071]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:13:00 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:14:07 Claimco sshd[19486]: Connection from 61.177.173.2 port 26116 on 192.168.1.233 port 22 rdomain "" Dec 19 17:14:08 Claimco sshd[19486]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:14:10 Claimco sshd[19486]: Failed password for root from 61.177.173.2 port 26116 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:14:18 Claimco sshd[19486]: Received disconnect from 61.177.173.2 port 26116:11: [preauth] Dec 19 17:14:18 Claimco sshd[19486]: Disconnected from authenticating user root 61.177.173.2 port 26116 [preauth] Dec 19 17:14:18 Claimco sshd[19486]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:15:13 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:15:41 Claimco sshd[19842]: Connection from 92.46.108.20 port 40436 on 192.168.1.233 port 22 rdomain "" Dec 19 17:15:43 Claimco sshd[19842]: Invalid user user from 92.46.108.20 port 40436 Dec 19 17:15:43 Claimco sshd[19842]: pam_unix(sshd:auth): check pass; user unknown Dec 19 17:15:43 Claimco sshd[19842]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=92.46.108.20 Dec 19 17:15:45 Claimco sshd[19842]: Failed password for invalid user user from 92.46.108.20 port 40436 ssh2 Dec 19 17:15:46 Claimco sshd[19842]: Connection closed by invalid user user 92.46.108.20 port 40436 [preauth] Dec 19 17:15:46 Claimco sshd[19871]: Connection from 61.177.173.2 port 38232 on 192.168.1.233 port 22 rdomain "" Dec 19 17:15:47 Claimco sshd[19871]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:15:49 Claimco sshd[19871]: Failed password for root from 61.177.173.2 port 38232 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:15:55 Claimco sshd[19871]: Received disconnect from 61.177.173.2 port 38232:11: [preauth] Dec 19 17:15:55 Claimco sshd[19871]: Disconnected from authenticating user root 61.177.173.2 port 38232 [preauth] Dec 19 17:15:55 Claimco sshd[19871]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:17:11 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:17:24 Claimco sshd[20215]: Connection from 61.177.173.2 port 47296 on 192.168.1.233 port 22 rdomain "" Dec 19 17:17:25 Claimco sshd[20215]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:17:27 Claimco sshd[20215]: Failed password for root from 61.177.173.2 port 47296 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:17:32 Claimco sshd[20215]: Received disconnect from 61.177.173.2 port 47296:11: [preauth] Dec 19 17:17:32 Claimco sshd[20215]: Disconnected from authenticating user root 61.177.173.2 port 47296 [preauth] Dec 19 17:17:32 Claimco sshd[20215]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:18:59 Claimco sshd[20558]: Connection from 61.177.173.2 port 46644 on 192.168.1.233 port 22 rdomain "" Dec 19 17:19:00 Claimco sshd[20558]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:19:02 Claimco sshd[20558]: Failed password for root from 61.177.173.2 port 46644 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:19:10 Claimco sshd[20558]: Received disconnect from 61.177.173.2 port 46644:11: [preauth] Dec 19 17:19:10 Claimco sshd[20558]: Disconnected from authenticating user root 61.177.173.2 port 46644 [preauth] Dec 19 17:19:10 Claimco sshd[20558]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:19:23 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:20:37 Claimco sshd[21191]: Connection from 61.177.173.2 port 51550 on 192.168.1.233 port 22 rdomain "" Dec 19 17:20:38 Claimco sshd[21191]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:20:40 Claimco sshd[21191]: Failed password for root from 61.177.173.2 port 51550 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:20:45 Claimco sshd[21191]: Received disconnect from 61.177.173.2 port 51550:11: [preauth] Dec 19 17:20:45 Claimco sshd[21191]: Disconnected from authenticating user root 61.177.173.2 port 51550 [preauth] Dec 19 17:20:45 Claimco sshd[21191]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:21:20 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:22:13 Claimco sshd[21540]: Connection from 61.177.173.2 port 53862 on 192.168.1.233 port 22 rdomain "" Dec 19 17:22:15 Claimco sshd[21540]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:22:16 Claimco sshd[21540]: Failed password for root from 61.177.173.2 port 53862 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:22:24 Claimco sshd[21540]: Received disconnect from 61.177.173.2 port 53862:11: [preauth] Dec 19 17:22:24 Claimco sshd[21540]: Disconnected from authenticating user root 61.177.173.2 port 53862 [preauth] Dec 19 17:22:24 Claimco sshd[21540]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:23:30 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:23:49 Claimco sshd[21883]: Connection from 61.177.173.2 port 59834 on 192.168.1.233 port 22 rdomain "" Dec 19 17:23:51 Claimco sshd[21883]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:23:53 Claimco sshd[21883]: Failed password for root from 61.177.173.2 port 59834 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:23:58 Claimco sshd[21883]: Received disconnect from 61.177.173.2 port 59834:11: [preauth] Dec 19 17:23:58 Claimco sshd[21883]: Disconnected from authenticating user root 61.177.173.2 port 59834 [preauth] Dec 19 17:23:58 Claimco sshd[21883]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:25:26 Claimco sshd[22288]: Connection from 61.177.173.2 port 12767 on 192.168.1.233 port 22 rdomain "" Dec 19 17:25:27 Claimco sshd[22288]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:25:29 Claimco sshd[22288]: Failed password for root from 61.177.173.2 port 12767 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:25:38 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:25:39 Claimco sshd[22288]: Received disconnect from 61.177.173.2 port 12767:11: [preauth] Dec 19 17:25:39 Claimco sshd[22288]: Disconnected from authenticating user root 61.177.173.2 port 12767 [preauth] Dec 19 17:25:39 Claimco sshd[22288]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:27:02 Claimco sshd[22638]: Connection from 61.177.173.2 port 12579 on 192.168.1.233 port 22 rdomain "" Dec 19 17:27:03 Claimco sshd[22638]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:27:05 Claimco sshd[22638]: Failed password for root from 61.177.173.2 port 12579 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:27:15 Claimco sshd[22638]: Received disconnect from 61.177.173.2 port 12579:11: [preauth] Dec 19 17:27:15 Claimco sshd[22638]: Disconnected from authenticating user root 61.177.173.2 port 12579 [preauth] Dec 19 17:27:15 Claimco sshd[22638]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:27:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:28:40 Claimco sshd[22982]: Connection from 61.177.173.2 port 27759 on 192.168.1.233 port 22 rdomain "" Dec 19 17:28:42 Claimco sshd[22982]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:28:44 Claimco sshd[22982]: Failed password for root from 61.177.173.2 port 27759 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:28:49 Claimco sshd[22982]: Received disconnect from 61.177.173.2 port 27759:11: [preauth] Dec 19 17:28:49 Claimco sshd[22982]: Disconnected from authenticating user root 61.177.173.2 port 27759 [preauth] Dec 19 17:28:49 Claimco sshd[22982]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:29:40 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:30:15 Claimco sshd[23586]: Connection from 61.177.173.2 port 21449 on 192.168.1.233 port 22 rdomain "" Dec 19 17:30:16 Claimco sshd[23586]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:30:18 Claimco sshd[23586]: Failed password for root from 61.177.173.2 port 21449 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:30:23 Claimco sshd[23586]: Received disconnect from 61.177.173.2 port 21449:11: [preauth] Dec 19 17:30:23 Claimco sshd[23586]: Disconnected from authenticating user root 61.177.173.2 port 21449 [preauth] Dec 19 17:30:23 Claimco sshd[23586]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:31:49 Claimco sshd[23897]: Connection from 61.177.173.2 port 18251 on 192.168.1.233 port 22 rdomain "" Dec 19 17:31:51 Claimco sshd[23897]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:31:53 Claimco sshd[23897]: Failed password for root from 61.177.173.2 port 18251 ssh2 Dec 19 17:31:53 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:31:54 Claimco sshd[23897]: Failed password for root from 61.177.173.2 port 18251 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 17:32:00 Claimco sshd[23897]: Received disconnect from 61.177.173.2 port 18251:11: [preauth] Dec 19 17:32:00 Claimco sshd[23897]: Disconnected from authenticating user root 61.177.173.2 port 18251 [preauth] Dec 19 17:32:00 Claimco sshd[23897]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:33:28 Claimco sshd[24246]: Connection from 61.177.173.2 port 40149 on 192.168.1.233 port 22 rdomain "" Dec 19 17:33:30 Claimco sshd[24246]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:33:31 Claimco sshd[24246]: Failed password for root from 61.177.173.2 port 40149 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:33:37 Claimco sshd[24246]: Received disconnect from 61.177.173.2 port 40149:11: [preauth] Dec 19 17:33:37 Claimco sshd[24246]: Disconnected from authenticating user root 61.177.173.2 port 40149 [preauth] Dec 19 17:33:37 Claimco sshd[24246]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:33:50 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:35:04 Claimco sshd[24665]: Connection from 61.177.173.2 port 41433 on 192.168.1.233 port 22 rdomain "" Dec 19 17:35:05 Claimco sshd[24665]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:35:06 Claimco sshd[24665]: Failed password for root from 61.177.173.2 port 41433 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:35:14 Claimco sshd[24665]: Received disconnect from 61.177.173.2 port 41433:11: [preauth] Dec 19 17:35:14 Claimco sshd[24665]: Disconnected from authenticating user root 61.177.173.2 port 41433 [preauth] Dec 19 17:35:14 Claimco sshd[24665]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:35:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:36:41 Claimco sshd[25024]: Connection from 61.177.173.2 port 50977 on 192.168.1.233 port 22 rdomain "" Dec 19 17:36:42 Claimco sshd[25024]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:36:44 Claimco sshd[25024]: Failed password for root from 61.177.173.2 port 50977 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:36:49 Claimco sshd[25024]: Received disconnect from 61.177.173.2 port 50977:11: [preauth] Dec 19 17:36:49 Claimco sshd[25024]: Disconnected from authenticating user root 61.177.173.2 port 50977 [preauth] Dec 19 17:36:49 Claimco sshd[25024]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:37:59 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:38:16 Claimco sshd[25366]: Connection from 61.177.173.2 port 50283 on 192.168.1.233 port 22 rdomain "" Dec 19 17:38:17 Claimco sshd[25366]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:38:18 Claimco sshd[25366]: Failed password for root from 61.177.173.2 port 50283 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:38:24 Claimco sshd[25366]: Received disconnect from 61.177.173.2 port 50283:11: [preauth] Dec 19 17:38:24 Claimco sshd[25366]: Disconnected from authenticating user root 61.177.173.2 port 50283 [preauth] Dec 19 17:38:24 Claimco sshd[25366]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:38:30 Claimco sshd[25397]: Connection from 60.251.36.30 port 53578 on 192.168.1.233 port 22 rdomain "" Dec 19 17:38:31 Claimco sshd[25397]: Invalid user user1 from 60.251.36.30 port 53578 Dec 19 17:38:32 Claimco sshd[25397]: pam_unix(sshd:auth): check pass; user unknown Dec 19 17:38:32 Claimco sshd[25397]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=60.251.36.30 Dec 19 17:38:34 Claimco sshd[25397]: Failed password for invalid user user1 from 60.251.36.30 port 53578 ssh2 Dec 19 17:38:35 Claimco sshd[25397]: Connection closed by invalid user user1 60.251.36.30 port 53578 [preauth] Dec 19 17:39:53 Claimco sshd[25927]: Connection from 61.177.173.2 port 52675 on 192.168.1.233 port 22 rdomain "" Dec 19 17:39:54 Claimco sshd[25927]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:39:56 Claimco sshd[25927]: Failed password for root from 61.177.173.2 port 52675 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:40:01 Claimco sshd[25927]: Received disconnect from 61.177.173.2 port 52675:11: [preauth] Dec 19 17:40:01 Claimco sshd[25927]: Disconnected from authenticating user root 61.177.173.2 port 52675 [preauth] Dec 19 17:40:01 Claimco sshd[25927]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:40:06 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:41:30 Claimco sshd[26321]: Connection from 61.177.173.2 port 54241 on 192.168.1.233 port 22 rdomain "" Dec 19 17:41:31 Claimco sshd[26321]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:41:33 Claimco sshd[26321]: Failed password for root from 61.177.173.2 port 54241 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:41:39 Claimco sshd[26321]: Received disconnect from 61.177.173.2 port 54241:11: [preauth] Dec 19 17:41:39 Claimco sshd[26321]: Disconnected from authenticating user root 61.177.173.2 port 54241 [preauth] Dec 19 17:41:39 Claimco sshd[26321]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:41:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 17:43:05 Claimco sshd[26668]: Connection from 61.177.173.2 port 59999 on 192.168.1.233 port 22 rdomain "" Dec 19 17:43:06 Claimco sshd[26668]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:43:08 Claimco sshd[26668]: Failed password for root from 61.177.173.2 port 59999 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:43:14 Claimco sshd[26668]: Received disconnect from 61.177.173.2 port 59999:11: [preauth] Dec 19 17:43:14 Claimco sshd[26668]: Disconnected from authenticating user root 61.177.173.2 port 59999 [preauth] Dec 19 17:43:14 Claimco sshd[26668]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:43:38 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 17:44:40 Claimco sshd[27023]: Connection from 61.177.173.2 port 61835 on 192.168.1.233 port 22 rdomain "" Dec 19 17:44:42 Claimco sshd[27023]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:44:44 Claimco sshd[27023]: Failed password for root from 61.177.173.2 port 61835 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:44:49 Claimco sshd[27023]: Received disconnect from 61.177.173.2 port 61835:11: [preauth] Dec 19 17:44:49 Claimco sshd[27023]: Disconnected from authenticating user root 61.177.173.2 port 61835 [preauth] Dec 19 17:44:49 Claimco sshd[27023]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:45:44 Claimco sshd[27303]: Connection from 65.2.28.105 port 41170 on 192.168.1.233 port 22 rdomain "" Dec 19 17:45:45 Claimco sshd[27303]: Invalid user user from 65.2.28.105 port 41170 Dec 19 17:45:45 Claimco sshd[27303]: pam_unix(sshd:auth): check pass; user unknown Dec 19 17:45:45 Claimco sshd[27303]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=65.2.28.105 Dec 19 17:45:47 Claimco sshd[27303]: Failed password for invalid user user from 65.2.28.105 port 41170 ssh2 Dec 19 17:45:48 Claimco sshd[27303]: Connection closed by invalid user user 65.2.28.105 port 41170 [preauth] Dec 19 17:46:16 Claimco sshd[27445]: Connection from 61.177.173.2 port 12876 on 192.168.1.233 port 22 rdomain "" Dec 19 17:46:18 Claimco sshd[27445]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:46:19 Claimco sshd[27445]: Failed password for root from 61.177.173.2 port 12876 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:46:25 Claimco sshd[27445]: Received disconnect from 61.177.173.2 port 12876:11: [preauth] Dec 19 17:46:25 Claimco sshd[27445]: Disconnected from authenticating user root 61.177.173.2 port 12876 [preauth] Dec 19 17:46:25 Claimco sshd[27445]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:46:26 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:47:52 Claimco sshd[27760]: Connection from 61.177.173.2 port 14332 on 192.168.1.233 port 22 rdomain "" Dec 19 17:47:53 Claimco sshd[27760]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:47:56 Claimco sshd[27760]: Failed password for root from 61.177.173.2 port 14332 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:48:07 Claimco sshd[27760]: Received disconnect from 61.177.173.2 port 14332:11: [preauth] Dec 19 17:48:07 Claimco sshd[27760]: Disconnected from authenticating user root 61.177.173.2 port 14332 [preauth] Dec 19 17:48:07 Claimco sshd[27760]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:48:25 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:49:28 Claimco sshd[28172]: Connection from 61.177.173.2 port 16316 on 192.168.1.233 port 22 rdomain "" Dec 19 17:49:30 Claimco sshd[28172]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:49:32 Claimco sshd[28172]: Failed password for root from 61.177.173.2 port 16316 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:49:39 Claimco sshd[28172]: Received disconnect from 61.177.173.2 port 16316:11: [preauth] Dec 19 17:49:39 Claimco sshd[28172]: Disconnected from authenticating user root 61.177.173.2 port 16316 [preauth] Dec 19 17:49:39 Claimco sshd[28172]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:50:34 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:51:05 Claimco sshd[28769]: Connection from 61.177.173.2 port 23010 on 192.168.1.233 port 22 rdomain "" Dec 19 17:51:06 Claimco sshd[28769]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:51:08 Claimco sshd[28769]: Failed password for root from 61.177.173.2 port 23010 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:51:16 Claimco sshd[28769]: Received disconnect from 61.177.173.2 port 23010:11: [preauth] Dec 19 17:51:16 Claimco sshd[28769]: Disconnected from authenticating user root 61.177.173.2 port 23010 [preauth] Dec 19 17:51:16 Claimco sshd[28769]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:52:36 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:52:43 Claimco sshd[29087]: Connection from 61.177.173.2 port 45204 on 192.168.1.233 port 22 rdomain "" Dec 19 17:52:44 Claimco sshd[29087]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:52:47 Claimco sshd[29087]: Failed password for root from 61.177.173.2 port 45204 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:52:56 Claimco sshd[29087]: Received disconnect from 61.177.173.2 port 45204:11: [preauth] Dec 19 17:52:56 Claimco sshd[29087]: Disconnected from authenticating user root 61.177.173.2 port 45204 [preauth] Dec 19 17:52:56 Claimco sshd[29087]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:54:19 Claimco sshd[29471]: Connection from 61.177.173.2 port 41988 on 192.168.1.233 port 22 rdomain "" Dec 19 17:54:20 Claimco sshd[29471]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:54:22 Claimco sshd[29471]: Failed password for root from 61.177.173.2 port 41988 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:54:32 Claimco sshd[29471]: Received disconnect from 61.177.173.2 port 41988:11: [preauth] Dec 19 17:54:32 Claimco sshd[29471]: Disconnected from authenticating user root 61.177.173.2 port 41988 [preauth] Dec 19 17:54:32 Claimco sshd[29471]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:54:34 Claimco sshd[29504]: Connection from 84.110.99.202 port 40588 on 192.168.1.233 port 22 rdomain "" Dec 19 17:54:35 Claimco sshd[29504]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=84.110.99.202 user=root Dec 19 17:54:37 Claimco sshd[29504]: Failed password for root from 84.110.99.202 port 40588 ssh2 Dec 19 17:54:37 Claimco sshd[29504]: Connection closed by authenticating user root 84.110.99.202 port 40588 [preauth] Dec 19 17:54:48 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:55:15 Claimco sshd[29722]: Connection from 61.177.172.87 port 3394 on 192.168.1.233 port 22 rdomain "" Dec 19 17:55:15 Claimco sshd[29722]: Unable to negotiate with 61.177.172.87 port 3394: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 17:55:54 Claimco sshd[29833]: Connection from 61.177.173.2 port 38312 on 192.168.1.233 port 22 rdomain "" Dec 19 17:55:55 Claimco sshd[29833]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:55:56 Claimco sshd[29833]: Failed password for root from 61.177.173.2 port 38312 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:56:02 Claimco sshd[29833]: Received disconnect from 61.177.173.2 port 38312:11: [preauth] Dec 19 17:56:02 Claimco sshd[29833]: Disconnected from authenticating user root 61.177.173.2 port 38312 [preauth] Dec 19 17:56:02 Claimco sshd[29833]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:56:45 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:57:30 Claimco sshd[30178]: Connection from 61.177.173.2 port 42780 on 192.168.1.233 port 22 rdomain "" Dec 19 17:57:31 Claimco sshd[30178]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:57:33 Claimco sshd[30178]: Failed password for root from 61.177.173.2 port 42780 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:57:38 Claimco sshd[30178]: Received disconnect from 61.177.173.2 port 42780:11: [preauth] Dec 19 17:57:38 Claimco sshd[30178]: Disconnected from authenticating user root 61.177.173.2 port 42780 [preauth] Dec 19 17:57:38 Claimco sshd[30178]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:58:51 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 17:59:06 Claimco sshd[30571]: Connection from 61.177.173.2 port 44922 on 192.168.1.233 port 22 rdomain "" Dec 19 17:59:08 Claimco sshd[30571]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 17:59:10 Claimco sshd[30571]: Failed password for root from 61.177.173.2 port 44922 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 17:59:17 Claimco sshd[30571]: Received disconnect from 61.177.173.2 port 44922:11: [preauth] Dec 19 17:59:17 Claimco sshd[30571]: Disconnected from authenticating user root 61.177.173.2 port 44922 [preauth] Dec 19 17:59:17 Claimco sshd[30571]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:00:46 Claimco sshd[31138]: Connection from 61.177.173.2 port 11923 on 192.168.1.233 port 22 rdomain "" Dec 19 18:00:47 Claimco sshd[31138]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:00:49 Claimco sshd[31138]: Failed password for root from 61.177.173.2 port 11923 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:00:54 Claimco sshd[31138]: Received disconnect from 61.177.173.2 port 11923:11: [preauth] Dec 19 18:00:54 Claimco sshd[31138]: Disconnected from authenticating user root 61.177.173.2 port 11923 [preauth] Dec 19 18:00:54 Claimco sshd[31138]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:00:59 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:02:22 Claimco sshd[31507]: Connection from 61.177.173.2 port 20821 on 192.168.1.233 port 22 rdomain "" Dec 19 18:02:24 Claimco sshd[31507]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:02:26 Claimco sshd[31507]: Failed password for root from 61.177.173.2 port 20821 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:02:33 Claimco sshd[31507]: Received disconnect from 61.177.173.2 port 20821:11: [preauth] Dec 19 18:02:33 Claimco sshd[31507]: Disconnected from authenticating user root 61.177.173.2 port 20821 [preauth] Dec 19 18:02:33 Claimco sshd[31507]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:03:04 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:03:55 Claimco sshd[31844]: Connection from 61.177.173.2 port 50128 on 192.168.1.233 port 22 rdomain "" Dec 19 18:03:56 Claimco sshd[31844]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:03:58 Claimco sshd[31844]: Failed password for root from 61.177.173.2 port 50128 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:04:06 Claimco sshd[31844]: Received disconnect from 61.177.173.2 port 50128:11: [preauth] Dec 19 18:04:06 Claimco sshd[31844]: Disconnected from authenticating user root 61.177.173.2 port 50128 [preauth] Dec 19 18:04:06 Claimco sshd[31844]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:05:10 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:05:32 Claimco sshd[32248]: Connection from 61.177.173.2 port 51524 on 192.168.1.233 port 22 rdomain "" Dec 19 18:05:33 Claimco sshd[32248]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:05:35 Claimco sshd[32248]: Failed password for root from 61.177.173.2 port 51524 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:05:45 Claimco sshd[32248]: Received disconnect from 61.177.173.2 port 51524:11: [preauth] Dec 19 18:05:45 Claimco sshd[32248]: Disconnected from authenticating user root 61.177.173.2 port 51524 [preauth] Dec 19 18:05:45 Claimco sshd[32248]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:07:09 Claimco sshd[32601]: Connection from 61.177.173.2 port 54364 on 192.168.1.233 port 22 rdomain "" Dec 19 18:07:10 Claimco sshd[32601]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:07:12 Claimco sshd[32601]: Failed password for root from 61.177.173.2 port 54364 ssh2 Dec 19 18:07:15 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:07:16 Claimco sshd[32601]: Failed password for root from 61.177.173.2 port 54364 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 18:07:19 Claimco sshd[32601]: Received disconnect from 61.177.173.2 port 54364:11: [preauth] Dec 19 18:07:19 Claimco sshd[32601]: Disconnected from authenticating user root 61.177.173.2 port 54364 [preauth] Dec 19 18:07:19 Claimco sshd[32601]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:08:42 Claimco sshd[477]: Connection from 61.177.173.2 port 38960 on 192.168.1.233 port 22 rdomain "" Dec 19 18:08:43 Claimco sshd[477]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:08:45 Claimco sshd[477]: Failed password for root from 61.177.173.2 port 38960 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:08:50 Claimco sshd[477]: Received disconnect from 61.177.173.2 port 38960:11: [preauth] Dec 19 18:08:50 Claimco sshd[477]: Disconnected from authenticating user root 61.177.173.2 port 38960 [preauth] Dec 19 18:08:50 Claimco sshd[477]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:09:19 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:10:18 Claimco sshd[1122]: Connection from 61.177.173.2 port 48622 on 192.168.1.233 port 22 rdomain "" Dec 19 18:10:19 Claimco sshd[1122]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:10:21 Claimco sshd[1122]: Failed password for root from 61.177.173.2 port 48622 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:10:26 Claimco sshd[1122]: Received disconnect from 61.177.173.2 port 48622:11: [preauth] Dec 19 18:10:26 Claimco sshd[1122]: Disconnected from authenticating user root 61.177.173.2 port 48622 [preauth] Dec 19 18:10:26 Claimco sshd[1122]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:11:20 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:11:55 Claimco sshd[1444]: Connection from 61.177.173.2 port 59652 on 192.168.1.233 port 22 rdomain "" Dec 19 18:11:56 Claimco sshd[1444]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:11:58 Claimco sshd[1444]: Failed password for root from 61.177.173.2 port 59652 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:12:03 Claimco sshd[1500]: Connection from 192.241.204.230 port 40648 on 192.168.1.233 port 22 rdomain "" Dec 19 18:12:05 Claimco sshd[1444]: Received disconnect from 61.177.173.2 port 59652:11: [preauth] Dec 19 18:12:05 Claimco sshd[1444]: Disconnected from authenticating user root 61.177.173.2 port 59652 [preauth] Dec 19 18:12:05 Claimco sshd[1444]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:12:16 Claimco sshd[1500]: Connection closed by 192.241.204.230 port 40648 [preauth] Dec 19 18:13:30 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:13:33 Claimco sshd[1797]: Connection from 61.177.173.2 port 17019 on 192.168.1.233 port 22 rdomain "" Dec 19 18:13:34 Claimco sshd[1797]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:13:36 Claimco sshd[1797]: Failed password for root from 61.177.173.2 port 17019 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:13:43 Claimco sshd[1797]: Received disconnect from 61.177.173.2 port 17019:11: [preauth] Dec 19 18:13:43 Claimco sshd[1797]: Disconnected from authenticating user root 61.177.173.2 port 17019 [preauth] Dec 19 18:13:43 Claimco sshd[1797]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:15:08 Claimco sshd[2231]: Connection from 61.177.173.2 port 21931 on 192.168.1.233 port 22 rdomain "" Dec 19 18:15:09 Claimco sshd[2231]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:15:12 Claimco sshd[2231]: Failed password for root from 61.177.173.2 port 21931 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:15:19 Claimco sshd[2231]: Received disconnect from 61.177.173.2 port 21931:11: [preauth] Dec 19 18:15:19 Claimco sshd[2231]: Disconnected from authenticating user root 61.177.173.2 port 21931 [preauth] Dec 19 18:15:19 Claimco sshd[2231]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:15:30 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:16:45 Claimco sshd[2572]: Connection from 61.177.173.2 port 23177 on 192.168.1.233 port 22 rdomain "" Dec 19 18:16:46 Claimco sshd[2572]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:16:48 Claimco sshd[2572]: Failed password for root from 61.177.173.2 port 23177 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:16:55 Claimco sshd[2572]: Received disconnect from 61.177.173.2 port 23177:11: [preauth] Dec 19 18:16:55 Claimco sshd[2572]: Disconnected from authenticating user root 61.177.173.2 port 23177 [preauth] Dec 19 18:16:55 Claimco sshd[2572]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:17:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:18:20 Claimco sshd[2914]: Connection from 61.177.173.2 port 18365 on 192.168.1.233 port 22 rdomain "" Dec 19 18:18:21 Claimco sshd[2914]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:18:24 Claimco sshd[2914]: Failed password for root from 61.177.173.2 port 18365 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:18:33 Claimco sshd[2914]: Received disconnect from 61.177.173.2 port 18365:11: [preauth] Dec 19 18:18:33 Claimco sshd[2914]: Disconnected from authenticating user root 61.177.173.2 port 18365 [preauth] Dec 19 18:18:33 Claimco sshd[2914]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:19:12 Claimco sshd[3128]: Connection from 36.112.171.51 port 17417 on 192.168.1.233 port 22 rdomain "" Dec 19 18:19:42 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:19:59 Claimco sshd[3480]: Connection from 61.177.173.2 port 34995 on 192.168.1.233 port 22 rdomain "" Dec 19 18:20:00 Claimco sshd[3480]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:20:02 Claimco sshd[3480]: Failed password for root from 61.177.173.2 port 34995 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:20:09 Claimco sshd[3480]: Received disconnect from 61.177.173.2 port 34995:11: [preauth] Dec 19 18:20:09 Claimco sshd[3480]: Disconnected from authenticating user root 61.177.173.2 port 34995 [preauth] Dec 19 18:20:09 Claimco sshd[3480]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:21:12 Claimco sshd[3128]: fatal: Timeout before authentication for 36.112.171.51 port 17417 Dec 19 18:21:32 Claimco sshd[3865]: Connection from 61.177.173.2 port 21503 on 192.168.1.233 port 22 rdomain "" Dec 19 18:21:34 Claimco sshd[3865]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:21:36 Claimco sshd[3865]: Failed password for root from 61.177.173.2 port 21503 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:21:43 Claimco sshd[3865]: Received disconnect from 61.177.173.2 port 21503:11: [preauth] Dec 19 18:21:43 Claimco sshd[3865]: Disconnected from authenticating user root 61.177.173.2 port 21503 [preauth] Dec 19 18:21:43 Claimco sshd[3865]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:21:52 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:23:09 Claimco sshd[4218]: Connection from 61.177.173.2 port 39409 on 192.168.1.233 port 22 rdomain "" Dec 19 18:23:11 Claimco sshd[4218]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:23:13 Claimco sshd[4218]: Failed password for root from 61.177.173.2 port 39409 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:23:20 Claimco sshd[4218]: Received disconnect from 61.177.173.2 port 39409:11: [preauth] Dec 19 18:23:20 Claimco sshd[4218]: Disconnected from authenticating user root 61.177.173.2 port 39409 [preauth] Dec 19 18:23:20 Claimco sshd[4218]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:23:56 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:24:47 Claimco sshd[4575]: Connection from 61.177.173.2 port 45789 on 192.168.1.233 port 22 rdomain "" Dec 19 18:24:48 Claimco sshd[4575]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:24:49 Claimco sshd[4575]: Failed password for root from 61.177.173.2 port 45789 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:24:55 Claimco sshd[4575]: Received disconnect from 61.177.173.2 port 45789:11: [preauth] Dec 19 18:24:55 Claimco sshd[4575]: Disconnected from authenticating user root 61.177.173.2 port 45789 [preauth] Dec 19 18:24:55 Claimco sshd[4575]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:25:59 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:26:22 Claimco sshd[4964]: Connection from 61.177.173.2 port 50593 on 192.168.1.233 port 22 rdomain "" Dec 19 18:26:24 Claimco sshd[4964]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:26:25 Claimco sshd[4964]: Failed password for root from 61.177.173.2 port 50593 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:26:33 Claimco sshd[4964]: Received disconnect from 61.177.173.2 port 50593:11: [preauth] Dec 19 18:26:33 Claimco sshd[4964]: Disconnected from authenticating user root 61.177.173.2 port 50593 [preauth] Dec 19 18:26:33 Claimco sshd[4964]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:26:42 Claimco sshd[5036]: Connection from 61.177.172.87 port 58406 on 192.168.1.233 port 22 rdomain "" Dec 19 18:26:42 Claimco sshd[5036]: Unable to negotiate with 61.177.172.87 port 58406: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 18:27:58 Claimco sshd[5280]: Connection from 61.177.173.2 port 53935 on 192.168.1.233 port 22 rdomain "" Dec 19 18:27:59 Claimco sshd[5280]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:28:01 Claimco sshd[5280]: Failed password for root from 61.177.173.2 port 53935 ssh2 Dec 19 18:28:03 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:28:04 Claimco sshd[5280]: Failed password for root from 61.177.173.2 port 53935 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 18:28:06 Claimco sshd[5280]: Received disconnect from 61.177.173.2 port 53935:11: [preauth] Dec 19 18:28:06 Claimco sshd[5280]: Disconnected from authenticating user root 61.177.173.2 port 53935 [preauth] Dec 19 18:28:06 Claimco sshd[5280]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:29:34 Claimco sshd[5666]: Connection from 61.177.173.2 port 59097 on 192.168.1.233 port 22 rdomain "" Dec 19 18:29:36 Claimco sshd[5666]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:29:37 Claimco sshd[5666]: Failed password for root from 61.177.173.2 port 59097 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:29:45 Claimco sshd[5666]: Received disconnect from 61.177.173.2 port 59097:11: [preauth] Dec 19 18:29:45 Claimco sshd[5666]: Disconnected from authenticating user root 61.177.173.2 port 59097 [preauth] Dec 19 18:29:45 Claimco sshd[5666]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:30:07 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:31:12 Claimco sshd[6289]: Connection from 61.177.173.2 port 13618 on 192.168.1.233 port 22 rdomain "" Dec 19 18:31:13 Claimco sshd[6289]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:31:16 Claimco sshd[6289]: Failed password for root from 61.177.173.2 port 13618 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:31:23 Claimco sshd[6289]: Received disconnect from 61.177.173.2 port 13618:11: [preauth] Dec 19 18:31:23 Claimco sshd[6289]: Disconnected from authenticating user root 61.177.173.2 port 13618 [preauth] Dec 19 18:31:23 Claimco sshd[6289]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:32:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:32:51 Claimco sshd[6621]: Connection from 61.177.173.2 port 32944 on 192.168.1.233 port 22 rdomain "" Dec 19 18:32:53 Claimco sshd[6621]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:32:55 Claimco sshd[6621]: Failed password for root from 61.177.173.2 port 32944 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:33:02 Claimco sshd[6621]: Received disconnect from 61.177.173.2 port 32944:11: [preauth] Dec 19 18:33:02 Claimco sshd[6621]: Disconnected from authenticating user root 61.177.173.2 port 32944 [preauth] Dec 19 18:33:02 Claimco sshd[6621]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:34:18 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:34:26 Claimco sshd[7022]: Connection from 61.177.173.2 port 24152 on 192.168.1.233 port 22 rdomain "" Dec 19 18:34:27 Claimco sshd[7022]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:34:29 Claimco sshd[7022]: Failed password for root from 61.177.173.2 port 24152 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:34:36 Claimco sshd[7022]: Received disconnect from 61.177.173.2 port 24152:11: [preauth] Dec 19 18:34:36 Claimco sshd[7022]: Disconnected from authenticating user root 61.177.173.2 port 24152 [preauth] Dec 19 18:34:36 Claimco sshd[7022]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:35:36 Claimco sshd[7306]: Connection from 162.218.126.136 port 37862 on 192.168.1.233 port 22 rdomain "" Dec 19 18:35:36 Claimco sshd[7306]: Invalid user user from 162.218.126.136 port 37862 Dec 19 18:35:37 Claimco sshd[7306]: pam_unix(sshd:auth): check pass; user unknown Dec 19 18:35:37 Claimco sshd[7306]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=162.218.126.136 Dec 19 18:35:38 Claimco sshd[7306]: Failed password for invalid user user from 162.218.126.136 port 37862 ssh2 Dec 19 18:35:39 Claimco sshd[7306]: Connection closed by invalid user user 162.218.126.136 port 37862 [preauth] Dec 19 18:36:03 Claimco sshd[7516]: Connection from 61.177.173.2 port 34166 on 192.168.1.233 port 22 rdomain "" Dec 19 18:36:04 Claimco sshd[7516]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:36:06 Claimco sshd[7516]: Failed password for root from 61.177.173.2 port 34166 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:36:13 Claimco sshd[7516]: Received disconnect from 61.177.173.2 port 34166:11: [preauth] Dec 19 18:36:13 Claimco sshd[7516]: Disconnected from authenticating user root 61.177.173.2 port 34166 [preauth] Dec 19 18:36:13 Claimco sshd[7516]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:36:27 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:37:38 Claimco sshd[7871]: Connection from 61.177.173.2 port 25854 on 192.168.1.233 port 22 rdomain "" Dec 19 18:37:39 Claimco sshd[7871]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:37:41 Claimco sshd[7871]: Failed password for root from 61.177.173.2 port 25854 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:37:46 Claimco sshd[7871]: Received disconnect from 61.177.173.2 port 25854:11: [preauth] Dec 19 18:37:46 Claimco sshd[7871]: Disconnected from authenticating user root 61.177.173.2 port 25854 [preauth] Dec 19 18:37:46 Claimco sshd[7871]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:38:24 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:39:15 Claimco sshd[8307]: Connection from 61.177.173.2 port 37770 on 192.168.1.233 port 22 rdomain "" Dec 19 18:39:16 Claimco sshd[8307]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:39:18 Claimco sshd[8307]: Failed password for root from 61.177.173.2 port 37770 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:39:23 Claimco sshd[8307]: Received disconnect from 61.177.173.2 port 37770:11: [preauth] Dec 19 18:39:23 Claimco sshd[8307]: Disconnected from authenticating user root 61.177.173.2 port 37770 [preauth] Dec 19 18:39:23 Claimco sshd[8307]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:40:30 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:40:51 Claimco sshd[8870]: Connection from 61.177.173.2 port 43384 on 192.168.1.233 port 22 rdomain "" Dec 19 18:40:52 Claimco sshd[8870]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:40:54 Claimco sshd[8870]: Failed password for root from 61.177.173.2 port 43384 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:41:01 Claimco sshd[8870]: Received disconnect from 61.177.173.2 port 43384:11: [preauth] Dec 19 18:41:01 Claimco sshd[8870]: Disconnected from authenticating user root 61.177.173.2 port 43384 [preauth] Dec 19 18:41:01 Claimco sshd[8870]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:41:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:42:27 Claimco sshd[9216]: Connection from 61.177.173.2 port 50426 on 192.168.1.233 port 22 rdomain "" Dec 19 18:42:28 Claimco sshd[9216]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:42:30 Claimco sshd[9216]: Failed password for root from 61.177.173.2 port 50426 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:42:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:42:35 Claimco sshd[9216]: Received disconnect from 61.177.173.2 port 50426:11: [preauth] Dec 19 18:42:35 Claimco sshd[9216]: Disconnected from authenticating user root 61.177.173.2 port 50426 [preauth] Dec 19 18:42:35 Claimco sshd[9216]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:42:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:44:04 Claimco sshd[9633]: Connection from 61.177.173.2 port 56608 on 192.168.1.233 port 22 rdomain "" Dec 19 18:44:05 Claimco sshd[9633]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:44:08 Claimco sshd[9633]: Failed password for root from 61.177.173.2 port 56608 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:44:13 Claimco sshd[9633]: Received disconnect from 61.177.173.2 port 56608:11: [preauth] Dec 19 18:44:13 Claimco sshd[9633]: Disconnected from authenticating user root 61.177.173.2 port 56608 [preauth] Dec 19 18:44:13 Claimco sshd[9633]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:44:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:45:40 Claimco sshd[10008]: Connection from 61.177.173.2 port 56076 on 192.168.1.233 port 22 rdomain "" Dec 19 18:45:41 Claimco sshd[10008]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:45:43 Claimco sshd[10008]: Failed password for root from 61.177.173.2 port 56076 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:45:51 Claimco sshd[10008]: Received disconnect from 61.177.173.2 port 56076:11: [preauth] Dec 19 18:45:51 Claimco sshd[10008]: Disconnected from authenticating user root 61.177.173.2 port 56076 [preauth] Dec 19 18:45:51 Claimco sshd[10008]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:46:48 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:47:16 Claimco sshd[10352]: Connection from 61.177.173.2 port 54878 on 192.168.1.233 port 22 rdomain "" Dec 19 18:47:17 Claimco sshd[10352]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:47:19 Claimco sshd[10352]: Failed password for root from 61.177.173.2 port 54878 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:47:26 Claimco sshd[10352]: Received disconnect from 61.177.173.2 port 54878:11: [preauth] Dec 19 18:47:26 Claimco sshd[10352]: Disconnected from authenticating user root 61.177.173.2 port 54878 [preauth] Dec 19 18:47:26 Claimco sshd[10352]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:48:52 Claimco sshd[10695]: Connection from 61.177.173.2 port 61530 on 192.168.1.233 port 22 rdomain "" Dec 19 18:48:53 Claimco sshd[10695]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:48:55 Claimco sshd[10695]: Failed password for root from 61.177.173.2 port 61530 ssh2 Dec 19 18:48:55 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:48:57 Claimco sshd[10695]: Failed password for root from 61.177.173.2 port 61530 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 18:49:02 Claimco sshd[10695]: Received disconnect from 61.177.173.2 port 61530:11: [preauth] Dec 19 18:49:02 Claimco sshd[10695]: Disconnected from authenticating user root 61.177.173.2 port 61530 [preauth] Dec 19 18:49:02 Claimco sshd[10695]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:50:30 Claimco sshd[11306]: Connection from 61.177.173.2 port 23809 on 192.168.1.233 port 22 rdomain "" Dec 19 18:50:31 Claimco sshd[11306]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:50:33 Claimco sshd[11306]: Failed password for root from 61.177.173.2 port 23809 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:50:38 Claimco sshd[11306]: Received disconnect from 61.177.173.2 port 23809:11: [preauth] Dec 19 18:50:38 Claimco sshd[11306]: Disconnected from authenticating user root 61.177.173.2 port 23809 [preauth] Dec 19 18:50:38 Claimco sshd[11306]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:50:55 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:52:07 Claimco sshd[11658]: Connection from 61.177.173.2 port 42209 on 192.168.1.233 port 22 rdomain "" Dec 19 18:52:09 Claimco sshd[11658]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:52:10 Claimco sshd[11658]: Failed password for root from 61.177.173.2 port 42209 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:52:18 Claimco sshd[11658]: Received disconnect from 61.177.173.2 port 42209:11: [preauth] Dec 19 18:52:18 Claimco sshd[11658]: Disconnected from authenticating user root 61.177.173.2 port 42209 [preauth] Dec 19 18:52:18 Claimco sshd[11658]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:53:04 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:53:43 Claimco sshd[11998]: Connection from 61.177.173.2 port 40101 on 192.168.1.233 port 22 rdomain "" Dec 19 18:53:44 Claimco sshd[11998]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:53:46 Claimco sshd[11998]: Failed password for root from 61.177.173.2 port 40101 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:53:51 Claimco sshd[11998]: Received disconnect from 61.177.173.2 port 40101:11: [preauth] Dec 19 18:53:51 Claimco sshd[11998]: Disconnected from authenticating user root 61.177.173.2 port 40101 [preauth] Dec 19 18:53:51 Claimco sshd[11998]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:55:06 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:55:20 Claimco sshd[12404]: Connection from 61.177.173.2 port 47189 on 192.168.1.233 port 22 rdomain "" Dec 19 18:55:21 Claimco sshd[12404]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:55:24 Claimco sshd[12404]: Failed password for root from 61.177.173.2 port 47189 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:55:33 Claimco sshd[12404]: Received disconnect from 61.177.173.2 port 47189:11: [preauth] Dec 19 18:55:33 Claimco sshd[12404]: Disconnected from authenticating user root 61.177.173.2 port 47189 [preauth] Dec 19 18:55:33 Claimco sshd[12404]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:56:19 Claimco sshd[12615]: Connection from 141.98.11.30 port 33142 on 192.168.1.233 port 22 rdomain "" Dec 19 18:56:20 Claimco sshd[12615]: error: kex_exchange_identification: Connection closed by remote host Dec 19 18:56:20 Claimco sshd[12615]: Connection closed by 141.98.11.30 port 33142 Dec 19 18:56:35 Claimco sshd[12670]: Connection from 141.98.11.30 port 48676 on 192.168.1.233 port 22 rdomain "" Dec 19 18:56:35 Claimco sshd[12670]: Unable to negotiate with 141.98.11.30 port 48676: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 18:56:43 Claimco sshd[12694]: Connection from 141.98.11.30 port 54460 on 192.168.1.233 port 22 rdomain "" Dec 19 18:56:43 Claimco sshd[12694]: Unable to negotiate with 141.98.11.30 port 54460: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 18:56:51 Claimco sshd[12712]: Connection from 141.98.11.30 port 60244 on 192.168.1.233 port 22 rdomain "" Dec 19 18:56:51 Claimco sshd[12712]: Unable to negotiate with 141.98.11.30 port 60244: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 18:56:58 Claimco sshd[12754]: Connection from 61.177.173.2 port 59737 on 192.168.1.233 port 22 rdomain "" Dec 19 18:56:59 Claimco sshd[12754]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:57:00 Claimco sshd[12760]: Connection from 141.98.11.30 port 37796 on 192.168.1.233 port 22 rdomain "" Dec 19 18:57:00 Claimco sshd[12760]: Unable to negotiate with 141.98.11.30 port 37796: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 18:57:01 Claimco sshd[12754]: Failed password for root from 61.177.173.2 port 59737 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:57:09 Claimco sshd[12754]: Received disconnect from 61.177.173.2 port 59737:11: [preauth] Dec 19 18:57:09 Claimco sshd[12754]: Disconnected from authenticating user root 61.177.173.2 port 59737 [preauth] Dec 19 18:57:09 Claimco sshd[12754]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:57:09 Claimco sshd[12813]: Connection from 141.98.11.30 port 43578 on 192.168.1.233 port 22 rdomain "" Dec 19 18:57:09 Claimco sshd[12813]: Unable to negotiate with 141.98.11.30 port 43578: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 18:57:10 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 18:57:18 Claimco sshd[12835]: Connection from 141.98.11.30 port 49362 on 192.168.1.233 port 22 rdomain "" Dec 19 18:57:18 Claimco sshd[12835]: Unable to negotiate with 141.98.11.30 port 49362: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 18:57:27 Claimco sshd[12879]: Connection from 141.98.11.30 port 55144 on 192.168.1.233 port 22 rdomain "" Dec 19 18:57:28 Claimco sshd[12879]: Unable to negotiate with 141.98.11.30 port 55144: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 18:57:37 Claimco sshd[12901]: Connection from 141.98.11.30 port 60928 on 192.168.1.233 port 22 rdomain "" Dec 19 18:57:37 Claimco sshd[12901]: Unable to negotiate with 141.98.11.30 port 60928: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 18:57:40 Claimco sshd[12915]: Connection from 61.177.173.42 port 44928 on 192.168.1.233 port 22 rdomain "" Dec 19 18:57:40 Claimco sshd[12915]: Unable to negotiate with 61.177.173.42 port 44928: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 18:57:47 Claimco sshd[12931]: Connection from 141.98.11.30 port 38480 on 192.168.1.233 port 22 rdomain "" Dec 19 18:57:47 Claimco sshd[12931]: Unable to negotiate with 141.98.11.30 port 38480: no matching key exchange method found. Their offer: diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1,diffie-hellman-group1-sha1 [preauth] Dec 19 18:58:33 Claimco sshd[13109]: Connection from 61.177.173.2 port 53085 on 192.168.1.233 port 22 rdomain "" Dec 19 18:58:34 Claimco sshd[13109]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:58:36 Claimco sshd[13109]: Failed password for root from 61.177.173.2 port 53085 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 18:58:42 Claimco sshd[13109]: Received disconnect from 61.177.173.2 port 53085:11: [preauth] Dec 19 18:58:42 Claimco sshd[13109]: Disconnected from authenticating user root 61.177.173.2 port 53085 [preauth] Dec 19 18:58:42 Claimco sshd[13109]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 18:59:15 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 19:00:10 Claimco sshd[13749]: Connection from 61.177.173.2 port 13948 on 192.168.1.233 port 22 rdomain "" Dec 19 19:00:11 Claimco sshd[13749]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:00:13 Claimco sshd[13749]: Failed password for root from 61.177.173.2 port 13948 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:00:19 Claimco sshd[13749]: Received disconnect from 61.177.173.2 port 13948:11: [preauth] Dec 19 19:00:19 Claimco sshd[13749]: Disconnected from authenticating user root 61.177.173.2 port 13948 [preauth] Dec 19 19:00:19 Claimco sshd[13749]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:01:19 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 19:01:45 Claimco sshd[14061]: Connection from 61.177.173.2 port 20842 on 192.168.1.233 port 22 rdomain "" Dec 19 19:01:46 Claimco sshd[14061]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:01:49 Claimco sshd[14061]: Failed password for root from 61.177.173.2 port 20842 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:01:58 Claimco sshd[14061]: Received disconnect from 61.177.173.2 port 20842:11: [preauth] Dec 19 19:01:58 Claimco sshd[14061]: Disconnected from authenticating user root 61.177.173.2 port 20842 [preauth] Dec 19 19:01:58 Claimco sshd[14061]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:03:25 Claimco sshd[14411]: Connection from 61.177.173.2 port 63448 on 192.168.1.233 port 22 rdomain "" Dec 19 19:03:26 Claimco sshd[14411]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:03:28 Claimco sshd[14411]: Failed password for root from 61.177.173.2 port 63448 ssh2 Dec 19 19:03:29 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 19:03:31 Claimco sshd[14411]: Failed password for root from 61.177.173.2 port 63448 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 19:03:33 Claimco sshd[14411]: Received disconnect from 61.177.173.2 port 63448:11: [preauth] Dec 19 19:03:33 Claimco sshd[14411]: Disconnected from authenticating user root 61.177.173.2 port 63448 [preauth] Dec 19 19:03:33 Claimco sshd[14411]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:05:07 Claimco sshd[14862]: Connection from 61.177.173.2 port 21036 on 192.168.1.233 port 22 rdomain "" Dec 19 19:05:08 Claimco sshd[14862]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:05:10 Claimco sshd[14862]: Failed password for root from 61.177.173.2 port 21036 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:05:15 Claimco sshd[14862]: Received disconnect from 61.177.173.2 port 21036:11: [preauth] Dec 19 19:05:15 Claimco sshd[14862]: Disconnected from authenticating user root 61.177.173.2 port 21036 [preauth] Dec 19 19:05:15 Claimco sshd[14862]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:05:30 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 19:06:39 Claimco sshd[15162]: Connection from 61.177.173.2 port 11672 on 192.168.1.233 port 22 rdomain "" Dec 19 19:06:40 Claimco sshd[15162]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:06:42 Claimco sshd[15162]: Failed password for root from 61.177.173.2 port 11672 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:06:48 Claimco sshd[15162]: Received disconnect from 61.177.173.2 port 11672:11: [preauth] Dec 19 19:06:48 Claimco sshd[15162]: Disconnected from authenticating user root 61.177.173.2 port 11672 [preauth] Dec 19 19:06:48 Claimco sshd[15162]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:07:42 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 19:08:16 Claimco sshd[15537]: Connection from 61.177.173.2 port 36186 on 192.168.1.233 port 22 rdomain "" Dec 19 19:08:17 Claimco sshd[15537]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:08:20 Claimco sshd[15537]: Failed password for root from 61.177.173.2 port 36186 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:08:31 Claimco sshd[15537]: Received disconnect from 61.177.173.2 port 36186:11: [preauth] Dec 19 19:08:31 Claimco sshd[15537]: Disconnected from authenticating user root 61.177.173.2 port 36186 [preauth] Dec 19 19:08:31 Claimco sshd[15537]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:09:43 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 19:09:56 Claimco sshd[15886]: Connection from 61.177.173.2 port 26525 on 192.168.1.233 port 22 rdomain "" Dec 19 19:09:57 Claimco sshd[15886]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:09:59 Claimco sshd[15886]: Failed password for root from 61.177.173.2 port 26525 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:10:04 Claimco sshd[15886]: Received disconnect from 61.177.173.2 port 26525:11: [preauth] Dec 19 19:10:04 Claimco sshd[15886]: Disconnected from authenticating user root 61.177.173.2 port 26525 [preauth] Dec 19 19:10:04 Claimco sshd[15886]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:11:32 Claimco sshd[16493]: Connection from 61.177.173.2 port 44797 on 192.168.1.233 port 22 rdomain "" Dec 19 19:11:33 Claimco sshd[16493]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:11:35 Claimco sshd[16493]: Failed password for root from 61.177.173.2 port 44797 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:11:40 Claimco sshd[16493]: Received disconnect from 61.177.173.2 port 44797:11: [preauth] Dec 19 19:11:40 Claimco sshd[16493]: Disconnected from authenticating user root 61.177.173.2 port 44797 [preauth] Dec 19 19:11:40 Claimco sshd[16493]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:11:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 19:13:10 Claimco sshd[16843]: Connection from 61.177.173.2 port 19326 on 192.168.1.233 port 22 rdomain "" Dec 19 19:13:11 Claimco sshd[16843]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:13:13 Claimco sshd[16843]: Failed password for root from 61.177.173.2 port 19326 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:13:20 Claimco sshd[16843]: Received disconnect from 61.177.173.2 port 19326:11: [preauth] Dec 19 19:13:20 Claimco sshd[16843]: Disconnected from authenticating user root 61.177.173.2 port 19326 [preauth] Dec 19 19:13:20 Claimco sshd[16843]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:13:55 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 19:14:43 Claimco sshd[17181]: Connection from 94.14.128.125 port 47326 on 192.168.1.233 port 22 rdomain "" Dec 19 19:14:43 Claimco sshd[17182]: Connection from 94.14.128.125 port 47328 on 192.168.1.233 port 22 rdomain "" Dec 19 19:14:45 Claimco sshd[17182]: Invalid user pi from 94.14.128.125 port 47328 Dec 19 19:14:45 Claimco sshd[17181]: Invalid user pi from 94.14.128.125 port 47326 Dec 19 19:14:45 Claimco sshd[17182]: pam_unix(sshd:auth): check pass; user unknown Dec 19 19:14:45 Claimco sshd[17182]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=94.14.128.125 Dec 19 19:14:45 Claimco sshd[17181]: pam_unix(sshd:auth): check pass; user unknown Dec 19 19:14:45 Claimco sshd[17181]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=94.14.128.125 Dec 19 19:14:47 Claimco sshd[17182]: Failed password for invalid user pi from 94.14.128.125 port 47328 ssh2 Dec 19 19:14:47 Claimco sshd[17181]: Failed password for invalid user pi from 94.14.128.125 port 47326 ssh2 Dec 19 19:14:47 Claimco sshd[17181]: Connection closed by invalid user pi 94.14.128.125 port 47326 [preauth] Dec 19 19:14:47 Claimco sshd[17182]: Connection closed by invalid user pi 94.14.128.125 port 47328 [preauth] Dec 19 19:14:48 Claimco sshd[17208]: Connection from 61.177.173.2 port 50868 on 192.168.1.233 port 22 rdomain "" Dec 19 19:14:49 Claimco sshd[17208]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:14:51 Claimco sshd[17208]: Failed password for root from 61.177.173.2 port 50868 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:14:58 Claimco sshd[17208]: Received disconnect from 61.177.173.2 port 50868:11: [preauth] Dec 19 19:14:58 Claimco sshd[17208]: Disconnected from authenticating user root 61.177.173.2 port 50868 [preauth] Dec 19 19:14:58 Claimco sshd[17208]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:15:58 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 19:16:26 Claimco sshd[17605]: Connection from 61.177.173.2 port 30689 on 192.168.1.233 port 22 rdomain "" Dec 19 19:16:27 Claimco sshd[17605]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:16:30 Claimco sshd[17605]: Failed password for root from 61.177.173.2 port 30689 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:16:39 Claimco sshd[17605]: Received disconnect from 61.177.173.2 port 30689:11: [preauth] Dec 19 19:16:39 Claimco sshd[17605]: Disconnected from authenticating user root 61.177.173.2 port 30689 [preauth] Dec 19 19:16:39 Claimco sshd[17605]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:18:04 Claimco sshd[17980]: Connection from 61.177.173.2 port 49123 on 192.168.1.233 port 22 rdomain "" Dec 19 19:18:05 Claimco sshd[17980]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:18:07 Claimco sshd[17980]: Failed password for root from 61.177.173.2 port 49123 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 19:18:09 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 19:18:12 Claimco sshd[17980]: Failed password for root from 61.177.173.2 port 49123 ssh2 Dec 19 19:18:12 Claimco sshd[17980]: Received disconnect from 61.177.173.2 port 49123:11: [preauth] Dec 19 19:18:12 Claimco sshd[17980]: Disconnected from authenticating user root 61.177.173.2 port 49123 [preauth] Dec 19 19:18:12 Claimco sshd[17980]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:19:21 Claimco sshd[18254]: Connection from 167.94.138.120 port 56840 on 192.168.1.233 port 22 rdomain "" Dec 19 19:19:36 Claimco sshd[18254]: Connection closed by 167.94.138.120 port 56840 [preauth] Dec 19 19:19:43 Claimco sshd[18330]: Connection from 61.177.173.2 port 35428 on 192.168.1.233 port 22 rdomain "" Dec 19 19:19:44 Claimco sshd[18330]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:19:46 Claimco sshd[18330]: Failed password for root from 61.177.173.2 port 35428 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:19:51 Claimco sshd[18330]: Received disconnect from 61.177.173.2 port 35428:11: [preauth] Dec 19 19:19:51 Claimco sshd[18330]: Disconnected from authenticating user root 61.177.173.2 port 35428 [preauth] Dec 19 19:19:51 Claimco sshd[18330]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:20:05 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 19:21:21 Claimco sshd[18939]: Connection from 61.177.173.2 port 64766 on 192.168.1.233 port 22 rdomain "" Dec 19 19:21:22 Claimco sshd[18939]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:21:24 Claimco sshd[18939]: Failed password for root from 61.177.173.2 port 64766 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:21:31 Claimco sshd[18939]: Received disconnect from 61.177.173.2 port 64766:11: [preauth] Dec 19 19:21:31 Claimco sshd[18939]: Disconnected from authenticating user root 61.177.173.2 port 64766 [preauth] Dec 19 19:21:31 Claimco sshd[18939]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:22:11 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:22:58 Claimco sshd[19255]: Connection from 61.177.173.2 port 28011 on 192.168.1.233 port 22 rdomain "" Dec 19 19:22:59 Claimco sshd[19255]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:23:01 Claimco sshd[19255]: Failed password for root from 61.177.173.2 port 28011 ssh2 Dec 19 19:23:01 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 19:23:06 Claimco sshd[19255]: Failed password for root from 61.177.173.2 port 28011 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 19:23:11 Claimco sshd[19255]: Received disconnect from 61.177.173.2 port 28011:11: [preauth] Dec 19 19:23:11 Claimco sshd[19255]: Disconnected from authenticating user root 61.177.173.2 port 28011 [preauth] Dec 19 19:23:11 Claimco sshd[19255]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:23:33 Claimco sshd[19388]: Connection from 65.2.28.105 port 49380 on 192.168.1.233 port 22 rdomain "" Dec 19 19:23:35 Claimco sshd[19388]: Invalid user a from 65.2.28.105 port 49380 Dec 19 19:23:35 Claimco sshd[19388]: pam_unix(sshd:auth): check pass; user unknown Dec 19 19:23:35 Claimco sshd[19388]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=65.2.28.105 Dec 19 19:23:37 Claimco sshd[19388]: Failed password for invalid user a from 65.2.28.105 port 49380 ssh2 Dec 19 19:23:40 Claimco sshd[19388]: Connection closed by invalid user a 65.2.28.105 port 49380 [preauth] Dec 19 19:24:23 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 19:24:34 Claimco sshd[19643]: Connection from 61.177.173.2 port 47671 on 192.168.1.233 port 22 rdomain "" Dec 19 19:24:34 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 19:24:35 Claimco sshd[19643]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:24:38 Claimco sshd[19643]: Failed password for root from 61.177.173.2 port 47671 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:24:45 Claimco sshd[19643]: Received disconnect from 61.177.173.2 port 47671:11: [preauth] Dec 19 19:24:45 Claimco sshd[19643]: Disconnected from authenticating user root 61.177.173.2 port 47671 [preauth] Dec 19 19:24:45 Claimco sshd[19643]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:25:22 Claimco sshd[19893]: Connection from 84.110.99.202 port 57556 on 192.168.1.233 port 22 rdomain "" Dec 19 19:25:23 Claimco sshd[19893]: Invalid user cm from 84.110.99.202 port 57556 Dec 19 19:25:23 Claimco sshd[19893]: pam_unix(sshd:auth): check pass; user unknown Dec 19 19:25:23 Claimco sshd[19893]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=84.110.99.202 Dec 19 19:25:25 Claimco sshd[19893]: Failed password for invalid user cm from 84.110.99.202 port 57556 ssh2 Dec 19 19:25:26 Claimco sshd[19893]: Connection closed by invalid user cm 84.110.99.202 port 57556 [preauth] Dec 19 19:26:04 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 19:26:12 Claimco sshd[20061]: Connection from 61.177.173.2 port 28382 on 192.168.1.233 port 22 rdomain "" Dec 19 19:26:14 Claimco sshd[20061]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:26:15 Claimco sshd[20061]: Failed password for root from 61.177.173.2 port 28382 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:26:23 Claimco sshd[20061]: Received disconnect from 61.177.173.2 port 28382:11: [preauth] Dec 19 19:26:23 Claimco sshd[20061]: Disconnected from authenticating user root 61.177.173.2 port 28382 [preauth] Dec 19 19:26:23 Claimco sshd[20061]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:26:24 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:27:52 Claimco sshd[20406]: Connection from 61.177.173.2 port 19359 on 192.168.1.233 port 22 rdomain "" Dec 19 19:27:54 Claimco sshd[20406]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:27:56 Claimco sshd[20406]: Failed password for root from 61.177.173.2 port 19359 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:28:03 Claimco sshd[20406]: Received disconnect from 61.177.173.2 port 19359:11: [preauth] Dec 19 19:28:03 Claimco sshd[20406]: Disconnected from authenticating user root 61.177.173.2 port 19359 [preauth] Dec 19 19:28:03 Claimco sshd[20406]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:28:27 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 19:28:33 Claimco sshd[20550]: Connection from 61.177.173.42 port 48970 on 192.168.1.233 port 22 rdomain "" Dec 19 19:28:33 Claimco sshd[20550]: Unable to negotiate with 61.177.173.42 port 48970: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 19:29:04 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 19:29:29 Claimco sshd[20782]: Connection from 61.177.173.2 port 36603 on 192.168.1.233 port 22 rdomain "" Dec 19 19:29:31 Claimco sshd[20782]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:29:32 Claimco sshd[20782]: Failed password for root from 61.177.173.2 port 36603 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:29:38 Claimco sshd[20782]: Received disconnect from 61.177.173.2 port 36603:11: [preauth] Dec 19 19:29:38 Claimco sshd[20782]: Disconnected from authenticating user root 61.177.173.2 port 36603 [preauth] Dec 19 19:29:38 Claimco sshd[20782]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:30:31 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:30:54 Claimco sshd[21321]: Connection from 192.241.208.175 port 43406 on 192.168.1.233 port 22 rdomain "" Dec 19 19:31:08 Claimco sshd[21321]: Connection closed by 192.241.208.175 port 43406 [preauth] Dec 19 19:31:11 Claimco sshd[21408]: Connection from 61.177.173.2 port 49558 on 192.168.1.233 port 22 rdomain "" Dec 19 19:31:13 Claimco sshd[21408]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:31:14 Claimco sshd[21408]: Failed password for root from 61.177.173.2 port 49558 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:31:20 Claimco sshd[21408]: Received disconnect from 61.177.173.2 port 49558:11: [preauth] Dec 19 19:31:20 Claimco sshd[21408]: Disconnected from authenticating user root 61.177.173.2 port 49558 [preauth] Dec 19 19:31:20 Claimco sshd[21408]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:32:01 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:32:45 Claimco sshd[21716]: Connection from 61.177.173.2 port 46044 on 192.168.1.233 port 22 rdomain "" Dec 19 19:32:46 Claimco sshd[21716]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:32:48 Claimco sshd[21716]: Failed password for root from 61.177.173.2 port 46044 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:32:53 Claimco sshd[21716]: Received disconnect from 61.177.173.2 port 46044:11: [preauth] Dec 19 19:32:53 Claimco sshd[21716]: Disconnected from authenticating user root 61.177.173.2 port 46044 [preauth] Dec 19 19:32:53 Claimco sshd[21716]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:33:31 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 19 19:34:24 Claimco sshd[22095]: Connection from 61.177.173.2 port 21583 on 192.168.1.233 port 22 rdomain "" Dec 19 19:34:25 Claimco sshd[22095]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:34:27 Claimco sshd[22095]: Failed password for root from 61.177.173.2 port 21583 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:34:37 Claimco sshd[22095]: Received disconnect from 61.177.173.2 port 21583:11: [preauth] Dec 19 19:34:37 Claimco sshd[22095]: Disconnected from authenticating user root 61.177.173.2 port 21583 [preauth] Dec 19 19:34:37 Claimco sshd[22095]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:34:40 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:36:01 Claimco sshd[22508]: Connection from 61.177.173.2 port 44289 on 192.168.1.233 port 22 rdomain "" Dec 19 19:36:02 Claimco sshd[22508]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:36:04 Claimco sshd[22508]: Failed password for root from 61.177.173.2 port 44289 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:36:12 Claimco sshd[22508]: Received disconnect from 61.177.173.2 port 44289:11: [preauth] Dec 19 19:36:12 Claimco sshd[22508]: Disconnected from authenticating user root 61.177.173.2 port 44289 [preauth] Dec 19 19:36:12 Claimco sshd[22508]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:36:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:36:58 Claimco sshd[22680]: Connection from 211.34.251.153 port 42836 on 192.168.1.233 port 22 rdomain "" Dec 19 19:36:58 Claimco sshd[22682]: Connection from 211.34.251.153 port 42838 on 192.168.1.233 port 22 rdomain "" Dec 19 19:36:59 Claimco sshd[22680]: Invalid user pi from 211.34.251.153 port 42836 Dec 19 19:36:59 Claimco sshd[22682]: Invalid user pi from 211.34.251.153 port 42838 Dec 19 19:36:59 Claimco sshd[22680]: pam_unix(sshd:auth): check pass; user unknown Dec 19 19:36:59 Claimco sshd[22680]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=211.34.251.153 Dec 19 19:37:00 Claimco sshd[22682]: pam_unix(sshd:auth): check pass; user unknown Dec 19 19:37:00 Claimco sshd[22682]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=211.34.251.153 Dec 19 19:37:01 Claimco sshd[22682]: Failed password for invalid user pi from 211.34.251.153 port 42838 ssh2 Dec 19 19:37:01 Claimco sshd[22680]: Failed password for invalid user pi from 211.34.251.153 port 42836 ssh2 Dec 19 19:37:02 Claimco sshd[22680]: Connection closed by invalid user pi 211.34.251.153 port 42836 [preauth] Dec 19 19:37:02 Claimco sshd[22682]: Connection closed by invalid user pi 211.34.251.153 port 42838 [preauth] Dec 19 19:37:43 Claimco sshd[22862]: Connection from 61.177.173.2 port 48712 on 192.168.1.233 port 22 rdomain "" Dec 19 19:37:44 Claimco sshd[22862]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:37:46 Claimco sshd[22862]: Failed password for root from 61.177.173.2 port 48712 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:37:55 Claimco sshd[22862]: Received disconnect from 61.177.173.2 port 48712:11: [preauth] Dec 19 19:37:55 Claimco sshd[22862]: Disconnected from authenticating user root 61.177.173.2 port 48712 [preauth] Dec 19 19:37:55 Claimco sshd[22862]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:38:09 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:39:17 Claimco sshd[23228]: Connection from 61.177.173.2 port 49650 on 192.168.1.233 port 22 rdomain "" Dec 19 19:39:18 Claimco sshd[23228]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:39:19 Claimco sshd[23228]: Failed password for root from 61.177.173.2 port 49650 ssh2 ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:39:27 Claimco sshd[23228]: Received disconnect from 61.177.173.2 port 49650:11: [preauth] Dec 19 19:39:27 Claimco sshd[23228]: Disconnected from authenticating user root 61.177.173.2 port 49650 [preauth] Dec 19 19:39:27 Claimco sshd[23228]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:39:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 19:40:54 Claimco sshd[23792]: Connection from 61.177.173.2 port 17585 on 192.168.1.233 port 22 rdomain "" Dec 19 19:40:55 Claimco sshd[23792]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:40:57 Claimco sshd[23792]: Failed password for root from 61.177.173.2 port 17585 ssh2 Dec 19 19:40:58 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 19:41:00 Claimco sshd[23792]: Failed password for root from 61.177.173.2 port 17585 ssh2 ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 19:41:05 Claimco sshd[23792]: Received disconnect from 61.177.173.2 port 17585:11: [preauth] Dec 19 19:41:05 Claimco sshd[23792]: Disconnected from authenticating user root 61.177.173.2 port 17585 [preauth] Dec 19 19:41:05 Claimco sshd[23792]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=61.177.173.2 user=root Dec 19 19:41:09 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 17 TIMES] ### Dec 19 19:52:39 Claimco sshd[26664]: Connection from 92.46.108.20 port 58900 on 192.168.1.233 port 22 rdomain "" Dec 19 19:52:41 Claimco sshd[26664]: Invalid user user1 from 92.46.108.20 port 58900 Dec 19 19:52:42 Claimco sshd[26664]: pam_unix(sshd:auth): check pass; user unknown Dec 19 19:52:42 Claimco sshd[26664]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=92.46.108.20 Dec 19 19:52:44 Claimco sshd[26664]: Failed password for invalid user user1 from 92.46.108.20 port 58900 ssh2 Dec 19 19:52:46 Claimco sshd[26664]: Connection closed by invalid user user1 92.46.108.20 port 58900 [preauth] Dec 19 19:53:34 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 19:58:34 Claimco sshd[27993]: Connection from 61.177.173.61 port 53846 on 192.168.1.233 port 22 rdomain "" Dec 19 19:58:35 Claimco sshd[27996]: Connection from 162.218.126.136 port 35176 on 192.168.1.233 port 22 rdomain "" Dec 19 19:58:36 Claimco sshd[27996]: Invalid user wsj from 162.218.126.136 port 35176 Dec 19 19:58:36 Claimco sshd[27996]: pam_unix(sshd:auth): check pass; user unknown Dec 19 19:58:36 Claimco sshd[27996]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=162.218.126.136 Dec 19 19:58:38 Claimco sshd[27996]: Failed password for invalid user wsj from 162.218.126.136 port 35176 ssh2 Dec 19 19:58:39 Claimco sshd[27996]: Connection closed by invalid user wsj 162.218.126.136 port 35176 [preauth] Dec 19 19:59:41 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 20:00:34 Claimco sshd[27993]: fatal: Timeout before authentication for 61.177.173.61 port 53846 Dec 19 20:01:45 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 5 TIMES] ### Dec 19 20:13:57 Claimco sshd[31904]: Connection from 61.177.173.46 port 11999 on 192.168.1.233 port 22 rdomain "" Dec 19 20:13:58 Claimco sshd[31904]: Received disconnect from 61.177.173.46 port 11999:11: [preauth] Dec 19 20:13:58 Claimco sshd[31904]: Disconnected from 61.177.173.46 port 11999 [preauth] Dec 19 20:14:13 Claimco sshd[31996]: Connection from 61.177.173.35 port 51016 on 192.168.1.233 port 22 rdomain "" Dec 19 20:14:14 Claimco sshd[31996]: Received disconnect from 61.177.173.35 port 51016:11: [preauth] Dec 19 20:14:14 Claimco sshd[31996]: Disconnected from 61.177.173.35 port 51016 [preauth] Dec 19 20:14:19 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 20:16:17 Claimco sshd[32488]: Connection from 61.177.172.104 port 47664 on 192.168.1.233 port 22 rdomain "" Dec 19 20:16:18 Claimco sshd[32488]: Received disconnect from 61.177.172.104 port 47664:11: [preauth] Dec 19 20:16:18 Claimco sshd[32488]: Disconnected from 61.177.172.104 port 47664 [preauth] Dec 19 20:16:20 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 20:17:22 Claimco sshd[32709]: Connection from 61.177.172.108 port 40595 on 192.168.1.233 port 22 rdomain "" Dec 19 20:18:30 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 20:19:22 Claimco sshd[32709]: fatal: Timeout before authentication for 61.177.172.108 port 40595 Dec 19 20:20:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 20:22:15 Claimco sshd[1604]: Connection from 61.177.173.49 port 33204 on 192.168.1.233 port 22 rdomain "" Dec 19 20:22:16 Claimco sshd[1604]: Received disconnect from 61.177.173.49 port 33204:11: [preauth] Dec 19 20:22:16 Claimco sshd[1604]: Disconnected from 61.177.173.49 port 33204 [preauth] Dec 19 20:22:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 20:22:43 Claimco sshd[1694]: Connection from 61.177.173.48 port 41684 on 192.168.1.233 port 22 rdomain "" Dec 19 20:22:44 Claimco sshd[1694]: Received disconnect from 61.177.173.48 port 41684:11: [preauth] Dec 19 20:22:44 Claimco sshd[1694]: Disconnected from 61.177.173.48 port 41684 [preauth] Dec 19 20:24:41 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 20:27:24 Claimco sshd[2762]: Connection from 218.92.0.221 port 61178 on 192.168.1.233 port 22 rdomain "" Dec 19 20:28:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 20:28:59 Claimco sshd[3102]: Connection from 61.177.173.51 port 46150 on 192.168.1.233 port 22 rdomain "" Dec 19 20:29:00 Claimco sshd[3102]: Received disconnect from 61.177.173.51 port 46150:11: [preauth] Dec 19 20:29:00 Claimco sshd[3102]: Disconnected from 61.177.173.51 port 46150 [preauth] Dec 19 20:29:08 Claimco sshd[3180]: Connection from 61.177.172.108 port 56351 on 192.168.1.233 port 22 rdomain "" Dec 19 20:29:09 Claimco sshd[3180]: Received disconnect from 61.177.172.108 port 56351:11: [preauth] Dec 19 20:29:09 Claimco sshd[3180]: Disconnected from 61.177.172.108 port 56351 [preauth] Dec 19 20:29:19 Claimco sshd[3204]: Connection from 61.177.173.61 port 15424 on 192.168.1.233 port 22 rdomain "" Dec 19 20:29:19 Claimco sshd[3204]: Unable to negotiate with 61.177.173.61 port 15424: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 20:29:24 Claimco sshd[2762]: fatal: Timeout before authentication for 218.92.0.221 port 61178 Dec 19 20:31:00 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 20:31:16 Claimco sshd[3882]: Connection from 61.177.173.36 port 63613 on 192.168.1.233 port 22 rdomain "" Dec 19 20:31:17 Claimco sshd[3882]: Received disconnect from 61.177.173.36 port 63613:11: [preauth] Dec 19 20:31:17 Claimco sshd[3882]: Disconnected from 61.177.173.36 port 63613 [preauth] Dec 19 20:33:02 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 20:36:31 Claimco sshd[5060]: Connection from 61.177.173.49 port 51220 on 192.168.1.233 port 22 rdomain "" Dec 19 20:36:32 Claimco sshd[5060]: Received disconnect from 61.177.173.49 port 51220:11: [preauth] Dec 19 20:36:32 Claimco sshd[5060]: Disconnected from 61.177.173.49 port 51220 [preauth] Dec 19 20:37:09 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 20:39:27 Claimco sshd[5708]: Connection from 61.177.173.52 port 39307 on 192.168.1.233 port 22 rdomain "" Dec 19 20:39:57 Claimco sshd[5801]: Connection from 61.177.173.35 port 19870 on 192.168.1.233 port 22 rdomain "" Dec 19 20:39:58 Claimco sshd[5801]: Received disconnect from 61.177.173.35 port 19870:11: [preauth] Dec 19 20:39:58 Claimco sshd[5801]: Disconnected from 61.177.173.35 port 19870 [preauth] Dec 19 20:41:26 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 20:41:27 Claimco sshd[5708]: fatal: Timeout before authentication for 61.177.173.52 port 39307 Dec 19 20:41:44 Claimco sshd[6442]: Connection from 61.177.172.19 port 24095 on 192.168.1.233 port 22 rdomain "" Dec 19 20:41:45 Claimco sshd[6442]: Received disconnect from 61.177.172.19 port 24095:11: [preauth] Dec 19 20:41:45 Claimco sshd[6442]: Disconnected from 61.177.172.19 port 24095 [preauth] Dec 19 20:41:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 20:43:26 Claimco sshd[6802]: Connection from 61.177.172.114 port 59676 on 192.168.1.233 port 22 rdomain "" Dec 19 20:43:27 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 20:43:27 Claimco sshd[6802]: Received disconnect from 61.177.172.114 port 59676:11: [preauth] Dec 19 20:43:27 Claimco sshd[6802]: Disconnected from 61.177.172.114 port 59676 [preauth] Dec 19 20:45:30 Claimco sshd[7347]: Connection from 61.177.173.51 port 19787 on 192.168.1.233 port 22 rdomain "" Dec 19 20:45:33 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 20:47:30 Claimco sshd[7347]: fatal: Timeout before authentication for 61.177.173.51 port 19787 Dec 19 20:47:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 20:48:35 Claimco sshd[8163]: Connection from 61.177.173.47 port 26910 on 192.168.1.233 port 22 rdomain "" Dec 19 20:48:36 Claimco sshd[8163]: Received disconnect from 61.177.173.47 port 26910:11: [preauth] Dec 19 20:48:36 Claimco sshd[8163]: Disconnected from 61.177.173.47 port 26910 [preauth] Dec 19 20:48:37 Claimco sshd[8169]: Connection from 61.177.172.90 port 45093 on 192.168.1.233 port 22 rdomain "" Dec 19 20:48:38 Claimco sshd[8169]: Received disconnect from 61.177.172.90 port 45093:11: [preauth] Dec 19 20:48:38 Claimco sshd[8169]: Disconnected from 61.177.172.90 port 45093 [preauth] Dec 19 20:48:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 20:51:38 Claimco sshd[9093]: Connection from 61.177.173.52 port 64068 on 192.168.1.233 port 22 rdomain "" Dec 19 20:51:38 Claimco sshd[9095]: Connection from 61.177.173.53 port 61178 on 192.168.1.233 port 22 rdomain "" Dec 19 20:51:39 Claimco sshd[9093]: Received disconnect from 61.177.173.52 port 64068:11: [preauth] Dec 19 20:51:39 Claimco sshd[9093]: Disconnected from 61.177.173.52 port 64068 [preauth] Dec 19 20:51:52 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 20:53:38 Claimco sshd[9095]: fatal: Timeout before authentication for 61.177.173.53 port 61178 Dec 19 20:53:52 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 20:54:17 Claimco sshd[9685]: Connection from 61.177.172.124 port 30513 on 192.168.1.233 port 22 rdomain "" Dec 19 20:54:19 Claimco sshd[9685]: Received disconnect from 61.177.172.124 port 30513:11: [preauth] Dec 19 20:54:19 Claimco sshd[9685]: Disconnected from 61.177.172.124 port 30513 [preauth] Dec 19 20:55:42 Claimco sshd[10024]: Connection from 45.79.181.179 port 14080 on 192.168.1.233 port 22 rdomain "" Dec 19 20:55:43 Claimco sshd[10024]: Connection closed by 45.79.181.179 port 14080 [preauth] Dec 19 20:55:43 Claimco sshd[10026]: Connection from 45.79.181.179 port 14096 on 192.168.1.233 port 22 rdomain "" Dec 19 20:55:43 Claimco sshd[10026]: Connection closed by 45.79.181.179 port 14096 [preauth] Dec 19 20:55:43 Claimco sshd[10028]: Connection from 45.79.181.179 port 14106 on 192.168.1.233 port 22 rdomain "" Dec 19 20:55:43 Claimco sshd[10028]: Connection closed by 45.79.181.179 port 14106 [preauth] Dec 19 20:55:55 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 20:56:05 Claimco sshd[10150]: Connection from 84.110.99.202 port 56222 on 192.168.1.233 port 22 rdomain "" Dec 19 20:56:06 Claimco sshd[10150]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=84.110.99.202 user=root Dec 19 20:56:08 Claimco sshd[10150]: Failed password for root from 84.110.99.202 port 56222 ssh2 Dec 19 20:56:11 Claimco sshd[10150]: Connection closed by authenticating user root 84.110.99.202 port 56222 [preauth] Dec 19 20:57:13 Claimco sshd[10377]: Connection from 61.177.173.47 port 13916 on 192.168.1.233 port 22 rdomain "" Dec 19 20:57:14 Claimco sshd[10377]: Received disconnect from 61.177.173.47 port 13916:11: [preauth] Dec 19 20:57:14 Claimco sshd[10377]: Disconnected from 61.177.173.47 port 13916 [preauth] Dec 19 20:58:06 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 20:59:13 Claimco sshd[10825]: Connection from 61.177.173.51 port 21341 on 192.168.1.233 port 22 rdomain "" Dec 19 21:00:09 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 21:00:21 Claimco sshd[11098]: Connection from 61.177.173.56 port 33590 on 192.168.1.233 port 22 rdomain "" Dec 19 21:00:21 Claimco sshd[11098]: Unable to negotiate with 61.177.173.56 port 33590: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 21:01:03 Claimco sshd[11493]: Connection from 65.2.28.105 port 37250 on 192.168.1.233 port 22 rdomain "" Dec 19 21:01:04 Claimco sshd[11493]: Invalid user user1 from 65.2.28.105 port 37250 Dec 19 21:01:05 Claimco sshd[11493]: pam_unix(sshd:auth): check pass; user unknown Dec 19 21:01:05 Claimco sshd[11493]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=65.2.28.105 Dec 19 21:01:07 Claimco sshd[11493]: Failed password for invalid user user1 from 65.2.28.105 port 37250 ssh2 Dec 19 21:01:08 Claimco sshd[11493]: Connection closed by invalid user user1 65.2.28.105 port 37250 [preauth] Dec 19 21:01:13 Claimco sshd[10825]: fatal: Timeout before authentication for 61.177.173.51 port 21341 Dec 19 21:02:11 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 21:06:14 Claimco sshd[12656]: Connection from 61.177.172.124 port 50511 on 192.168.1.233 port 22 rdomain "" Dec 19 21:06:15 Claimco sshd[12656]: Received disconnect from 61.177.172.124 port 50511:11: [preauth] Dec 19 21:06:15 Claimco sshd[12656]: Disconnected from 61.177.172.124 port 50511 [preauth] Dec 19 21:06:22 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 21:06:52 Claimco sshd[12764]: Connection from 61.177.173.50 port 38923 on 192.168.1.233 port 22 rdomain "" Dec 19 21:08:28 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 21:08:52 Claimco sshd[12764]: fatal: Timeout before authentication for 61.177.173.50 port 38923 Dec 19 21:10:04 Claimco sshd[13482]: Connection from 61.177.173.37 port 41328 on 192.168.1.233 port 22 rdomain "" Dec 19 21:10:05 Claimco sshd[13482]: Received disconnect from 61.177.173.37 port 41328:11: [preauth] Dec 19 21:10:05 Claimco sshd[13482]: Disconnected from 61.177.173.37 port 41328 [preauth] Dec 19 21:10:33 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 21:14:17 Claimco sshd[14636]: Connection from 61.177.173.49 port 52000 on 192.168.1.233 port 22 rdomain "" Dec 19 21:14:18 Claimco sshd[14636]: Received disconnect from 61.177.173.49 port 52000:11: [preauth] Dec 19 21:14:18 Claimco sshd[14636]: Disconnected from 61.177.173.49 port 52000 [preauth] Dec 19 21:14:36 Claimco sshd[14700]: Connection from 61.177.173.47 port 22326 on 192.168.1.233 port 22 rdomain "" Dec 19 21:14:37 Claimco sshd[14700]: Received disconnect from 61.177.173.47 port 22326:11: [preauth] Dec 19 21:14:37 Claimco sshd[14700]: Disconnected from 61.177.173.47 port 22326 [preauth] Dec 19 21:14:46 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 21:15:29 Claimco sshd[14943]: Connection from 61.177.173.39 port 16777 on 192.168.1.233 port 22 rdomain "" Dec 19 21:15:30 Claimco sshd[14943]: Received disconnect from 61.177.173.39 port 16777:11: [preauth] Dec 19 21:15:30 Claimco sshd[14943]: Disconnected from 61.177.173.39 port 16777 [preauth] Dec 19 21:16:45 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 21:18:24 Claimco sshd[15556]: Connection from 61.177.172.108 port 31892 on 192.168.1.233 port 22 rdomain "" Dec 19 21:18:26 Claimco sshd[15556]: Received disconnect from 61.177.172.108 port 31892:11: [preauth] Dec 19 21:18:26 Claimco sshd[15556]: Disconnected from 61.177.172.108 port 31892 [preauth] Dec 19 21:18:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 19 21:21:04 Claimco sshd[16399]: Connection from 61.177.173.52 port 37136 on 192.168.1.233 port 22 rdomain "" Dec 19 21:21:05 Claimco sshd[16399]: Received disconnect from 61.177.173.52 port 37136:11: [preauth] Dec 19 21:21:05 Claimco sshd[16399]: Disconnected from 61.177.173.52 port 37136 [preauth] Dec 19 21:21:35 Claimco sshd[16487]: Connection from 162.218.126.136 port 34354 on 192.168.1.233 port 22 rdomain "" Dec 19 21:21:35 Claimco sshd[16487]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=162.218.126.136 user=root Dec 19 21:21:38 Claimco sshd[16487]: Failed password for root from 162.218.126.136 port 34354 ssh2 Dec 19 21:21:38 Claimco sshd[16487]: Connection closed by authenticating user root 162.218.126.136 port 34354 [preauth] Dec 19 21:21:48 Claimco sshd[16547]: Connection from 61.177.173.51 port 41633 on 192.168.1.233 port 22 rdomain "" Dec 19 21:21:50 Claimco sshd[16547]: Received disconnect from 61.177.173.51 port 41633:11: [preauth] Dec 19 21:21:50 Claimco sshd[16547]: Disconnected from 61.177.173.51 port 41633 [preauth] Dec 19 21:23:07 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 21:23:30 Claimco sshd[16917]: Connection from 61.177.173.35 port 29870 on 192.168.1.233 port 22 rdomain "" Dec 19 21:23:31 Claimco sshd[16917]: Received disconnect from 61.177.173.35 port 29870:11: [preauth] Dec 19 21:23:31 Claimco sshd[16917]: Disconnected from 61.177.173.35 port 29870 [preauth] Dec 19 21:25:05 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 21:26:14 Claimco sshd[17563]: Connection from 61.177.172.114 port 12237 on 192.168.1.233 port 22 rdomain "" Dec 19 21:27:19 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 21:28:14 Claimco sshd[17563]: fatal: Timeout before authentication for 61.177.172.114 port 12237 Dec 19 21:29:21 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 21:29:29 Claimco sshd[18293]: Connection from 61.177.173.53 port 21112 on 192.168.1.233 port 22 rdomain "" Dec 19 21:30:23 Claimco sshd[18537]: Connection from 61.177.172.19 port 52831 on 192.168.1.233 port 22 rdomain "" Dec 19 21:30:51 Claimco sshd[18802]: Connection from 61.177.172.87 port 61432 on 192.168.1.233 port 22 rdomain "" Dec 19 21:30:51 Claimco sshd[18802]: Unable to negotiate with 61.177.172.87 port 61432: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 21:31:23 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 21:31:29 Claimco sshd[18293]: fatal: Timeout before authentication for 61.177.173.53 port 21112 Dec 19 21:32:23 Claimco sshd[18537]: fatal: Timeout before authentication for 61.177.172.19 port 52831 Dec 19 21:32:23 Claimco sshd[19154]: Connection from 61.177.173.47 port 43966 on 192.168.1.233 port 22 rdomain "" Dec 19 21:33:27 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 21:34:23 Claimco sshd[19154]: fatal: Timeout before authentication for 61.177.173.47 port 43966 Dec 19 21:35:38 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 21:37:12 Claimco sshd[20270]: Connection from 61.177.173.46 port 14165 on 192.168.1.233 port 22 rdomain "" Dec 19 21:37:13 Claimco sshd[20270]: Received disconnect from 61.177.173.46 port 14165:11: [preauth] Dec 19 21:37:13 Claimco sshd[20270]: Disconnected from 61.177.173.46 port 14165 [preauth] Dec 19 21:37:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 7 TIMES] ### Dec 19 21:41:18 Claimco sshd[21398]: Connection from 61.177.173.36 port 21322 on 192.168.1.233 port 22 rdomain "" Dec 19 21:41:19 Claimco sshd[21398]: Received disconnect from 61.177.173.36 port 21322:11: [preauth] Dec 19 21:41:19 Claimco sshd[21398]: Disconnected from 61.177.173.36 port 21322 [preauth] Dec 19 21:41:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 19 21:42:48 Claimco sshd[21714]: Connection from 61.177.172.98 port 60959 on 192.168.1.233 port 22 rdomain "" Dec 19 21:42:59 Claimco sshd[21739]: Connection from 61.177.172.90 port 41982 on 192.168.1.233 port 22 rdomain "" Dec 19 21:43:00 Claimco sshd[21739]: Received disconnect from 61.177.172.90 port 41982:11: [preauth] Dec 19 21:43:00 Claimco sshd[21739]: Disconnected from 61.177.172.90 port 41982 [preauth] Dec 19 21:43:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 21:43:26 Claimco sshd[21853]: Connection from 61.177.173.52 port 54919 on 192.168.1.233 port 22 rdomain "" Dec 19 21:43:27 Claimco sshd[21853]: Received disconnect from 61.177.173.52 port 54919:11: [preauth] Dec 19 21:43:27 Claimco sshd[21853]: Disconnected from 61.177.173.52 port 54919 [preauth] Dec 19 21:43:53 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 21:44:45 Claimco sshd[22136]: Connection from 61.177.173.46 port 56330 on 192.168.1.233 port 22 rdomain "" Dec 19 21:44:45 Claimco sshd[22136]: Received disconnect from 61.177.173.46 port 56330:11: [preauth] Dec 19 21:44:45 Claimco sshd[22136]: Disconnected from 61.177.173.46 port 56330 [preauth] Dec 19 21:44:47 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 21:44:48 Claimco sshd[21714]: fatal: Timeout before authentication for 61.177.172.98 port 60959 Dec 19 21:46:00 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 8 TIMES] ### Dec 19 21:50:25 Claimco sshd[23481]: Connection from 61.177.173.39 port 38361 on 192.168.1.233 port 22 rdomain "" Dec 19 21:50:26 Claimco sshd[23481]: Received disconnect from 61.177.173.39 port 38361:11: [preauth] Dec 19 21:50:26 Claimco sshd[23481]: Disconnected from 61.177.173.39 port 38361 [preauth] Dec 19 21:50:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 4 TIMES] ### Dec 19 21:53:19 Claimco sshd[24315]: Connection from 61.177.173.53 port 20247 on 192.168.1.233 port 22 rdomain "" Dec 19 21:53:21 Claimco sshd[24315]: Received disconnect from 61.177.173.53 port 20247:11: [preauth] Dec 19 21:53:21 Claimco sshd[24315]: Disconnected from 61.177.173.53 port 20247 [preauth] Dec 19 21:53:43 Claimco sshd[24423]: Connection from 61.177.172.104 port 64506 on 192.168.1.233 port 22 rdomain "" Dec 19 21:53:44 Claimco sshd[24423]: Received disconnect from 61.177.172.104 port 64506:11: [preauth] Dec 19 21:53:44 Claimco sshd[24423]: Disconnected from 61.177.172.104 port 64506 [preauth] Dec 19 21:53:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 4 TIMES] ### Dec 19 21:55:47 Claimco sshd[24897]: Connection from 61.177.172.98 port 36707 on 192.168.1.233 port 22 rdomain "" Dec 19 21:56:24 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 21:57:47 Claimco sshd[24897]: fatal: Timeout before authentication for 61.177.172.98 port 36707 Dec 19 21:58:28 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 21:59:28 Claimco sshd[25714]: Connection from 61.177.173.35 port 63397 on 192.168.1.233 port 22 rdomain "" Dec 19 21:59:29 Claimco sshd[25714]: Received disconnect from 61.177.173.35 port 63397:11: [preauth] Dec 19 21:59:29 Claimco sshd[25714]: Disconnected from 61.177.173.35 port 63397 [preauth] Dec 19 22:00:35 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:01:30 Claimco sshd[26386]: Connection from 61.177.173.51 port 58020 on 192.168.1.233 port 22 rdomain "" Dec 19 22:02:34 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:02:38 Claimco sshd[26627]: Connection from 61.177.172.87 port 12324 on 192.168.1.233 port 22 rdomain "" Dec 19 22:02:38 Claimco sshd[26627]: Unable to negotiate with 61.177.172.87 port 12324: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 22:03:30 Claimco sshd[26386]: fatal: Timeout before authentication for 61.177.173.51 port 58020 Dec 19 22:04:43 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:04:56 Claimco sshd[27145]: Connection from 218.92.0.221 port 14679 on 192.168.1.233 port 22 rdomain "" Dec 19 22:06:46 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:06:56 Claimco sshd[27145]: fatal: Timeout before authentication for 218.92.0.221 port 14679 Dec 19 22:07:57 Claimco sshd[27838]: Connection from 61.177.173.53 port 24342 on 192.168.1.233 port 22 rdomain "" Dec 19 22:08:34 Claimco sshd[27970]: Connection from 61.177.172.98 port 41113 on 192.168.1.233 port 22 rdomain "" Dec 19 22:08:38 Claimco sshd[27979]: Connection from 61.177.173.48 port 56565 on 192.168.1.233 port 22 rdomain "" Dec 19 22:08:39 Claimco sshd[27979]: Received disconnect from 61.177.173.48 port 56565:11: [preauth] Dec 19 22:08:39 Claimco sshd[27979]: Disconnected from 61.177.173.48 port 56565 [preauth] Dec 19 22:08:51 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:09:57 Claimco sshd[27838]: fatal: Timeout before authentication for 61.177.173.53 port 24342 Dec 19 22:10:34 Claimco sshd[27970]: fatal: Timeout before authentication for 61.177.172.98 port 41113 Dec 19 22:10:59 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:12:00 Claimco sshd[28936]: Connection from 61.177.172.114 port 41953 on 192.168.1.233 port 22 rdomain "" Dec 19 22:13:00 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:14:00 Claimco sshd[28936]: fatal: Timeout before authentication for 61.177.172.114 port 41953 Dec 19 22:15:12 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:15:41 Claimco sshd[29819]: Connection from 61.177.173.50 port 29399 on 192.168.1.233 port 22 rdomain "" Dec 19 22:16:04 Claimco sshd[29908]: Connection from 218.92.0.221 port 24026 on 192.168.1.233 port 22 rdomain "" Dec 19 22:17:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:17:41 Claimco sshd[29819]: fatal: Timeout before authentication for 61.177.173.50 port 29399 Dec 19 22:17:45 Claimco sshd[30269]: Connection from 61.177.173.47 port 40326 on 192.168.1.233 port 22 rdomain "" Dec 19 22:17:46 Claimco sshd[30269]: Received disconnect from 61.177.173.47 port 40326:11: [preauth] Dec 19 22:17:46 Claimco sshd[30269]: Disconnected from 61.177.173.47 port 40326 [preauth] Dec 19 22:18:04 Claimco sshd[29908]: fatal: Timeout before authentication for 218.92.0.221 port 24026 Dec 19 22:19:18 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 22:21:27 Claimco sshd[31322]: Connection from 64.227.140.108 port 60324 on 192.168.1.233 port 22 rdomain "" Dec 19 22:21:31 Claimco sshd[31332]: Connection from 61.177.172.19 port 30947 on 192.168.1.233 port 22 rdomain "" Dec 19 22:21:32 Claimco sshd[31332]: Received disconnect from 61.177.172.19 port 30947:11: [preauth] Dec 19 22:21:32 Claimco sshd[31332]: Disconnected from 61.177.172.19 port 30947 [preauth] Dec 19 22:21:37 Claimco sshd[31322]: Connection closed by 64.227.140.108 port 60324 [preauth] Dec 19 22:23:25 Claimco sshd[31754]: Connection from 61.177.173.50 port 46907 on 192.168.1.233 port 22 rdomain "" Dec 19 22:23:25 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:23:26 Claimco sshd[31754]: Received disconnect from 61.177.173.50 port 46907:11: [preauth] Dec 19 22:23:26 Claimco sshd[31754]: Disconnected from 61.177.173.50 port 46907 [preauth] Dec 19 22:25:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 22:26:44 Claimco sshd[32504]: Connection from 61.177.172.104 port 49245 on 192.168.1.233 port 22 rdomain "" Dec 19 22:26:46 Claimco sshd[32504]: Received disconnect from 61.177.172.104 port 49245:11: [preauth] Dec 19 22:26:46 Claimco sshd[32504]: Disconnected from 61.177.172.104 port 49245 [preauth] Dec 19 22:27:06 Claimco sshd[32624]: Connection from 61.177.173.36 port 30843 on 192.168.1.233 port 22 rdomain "" Dec 19 22:27:07 Claimco sshd[32624]: Received disconnect from 61.177.173.36 port 30843:11: [preauth] Dec 19 22:27:07 Claimco sshd[32624]: Disconnected from 61.177.173.36 port 30843 [preauth] Dec 19 22:27:17 Claimco sshd[32648]: Connection from 84.110.99.202 port 36372 on 192.168.1.233 port 22 rdomain "" Dec 19 22:27:17 Claimco sshd[32648]: Invalid user user1 from 84.110.99.202 port 36372 Dec 19 22:27:18 Claimco sshd[32648]: pam_unix(sshd:auth): check pass; user unknown Dec 19 22:27:18 Claimco sshd[32648]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=84.110.99.202 Dec 19 22:27:20 Claimco sshd[32648]: Failed password for invalid user user1 from 84.110.99.202 port 36372 ssh2 Dec 19 22:27:21 Claimco sshd[32648]: Connection closed by invalid user user1 84.110.99.202 port 36372 [preauth] Dec 19 22:27:40 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 22:31:11 Claimco sshd[1340]: Connection from 61.177.173.53 port 11957 on 192.168.1.233 port 22 rdomain "" Dec 19 22:31:13 Claimco sshd[1340]: Received disconnect from 61.177.173.53 port 11957:11: [preauth] Dec 19 22:31:13 Claimco sshd[1340]: Disconnected from 61.177.173.53 port 11957 [preauth] Dec 19 22:31:50 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 22:33:58 Claimco sshd[1936]: Connection from 61.177.173.55 port 18126 on 192.168.1.233 port 22 rdomain "" Dec 19 22:33:58 Claimco sshd[1936]: Unable to negotiate with 61.177.173.55 port 18126: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1,diffie-hellman-group14-sha1,diffie-hellman-group-exchange-sha1 [preauth] Dec 19 22:34:09 Claimco webGUI: Successful login user root from 192.168.1.111 Dec 19 22:34:44 Claimco sshd[3394]: Connection from 61.177.172.98 port 32528 on 192.168.1.233 port 22 rdomain "" Dec 19 22:34:45 Claimco sshd[3394]: Received disconnect from 61.177.172.98 port 32528:11: [preauth] Dec 19 22:34:45 Claimco sshd[3394]: Disconnected from 61.177.172.98 port 32528 [preauth] Dec 19 22:35:13 Claimco sshd[4264]: Connection from 125.229.136.143 port 37103 on 192.168.1.233 port 22 rdomain "" Dec 19 22:35:13 Claimco sshd[4264]: Unable to negotiate with 125.229.136.143 port 37103: no matching host key type found. Their offer: ssh-rsa,ssh-dss [preauth] Dec 19 22:35:20 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 9 TIMES] ### Dec 19 22:35:26 Claimco kernel: net_ratelimit: 1182 callbacks suppressed Dec 19 22:35:26 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 9 TIMES] ### Dec 19 22:35:58 Claimco kernel: net_ratelimit: 214 callbacks suppressed Dec 19 22:35:58 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:36:06 Claimco sshd[6611]: Connection from 61.177.173.52 port 19506 on 192.168.1.233 port 22 rdomain "" Dec 19 22:36:07 Claimco sshd[6611]: Received disconnect from 61.177.173.52 port 19506:11: [preauth] Dec 19 22:36:07 Claimco sshd[6611]: Disconnected from 61.177.173.52 port 19506 [preauth] Dec 19 22:36:10 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:36:16 Claimco sshd[6993]: Connection from 61.177.173.35 port 21299 on 192.168.1.233 port 22 rdomain "" Dec 19 22:36:17 Claimco sshd[6993]: Received disconnect from 61.177.173.35 port 21299:11: [preauth] Dec 19 22:36:17 Claimco sshd[6993]: Disconnected from 61.177.173.35 port 21299 [preauth] Dec 19 22:37:35 Claimco unassigned.devices: Mounting Remote Share '//CLAIMCO/BM_PA_files'... Dec 19 22:37:35 Claimco unassigned.devices: Mount SMB share '//CLAIMCO/BM_PA_files' using SMB default protocol. Dec 19 22:37:35 Claimco unassigned.devices: Mount SMB command: /sbin/mount -t 'cifs' -o rw,noserverino,nounix,iocharset=utf8,file_mode=0777,dir_mode=0777,uid=99,gid=100,credentials='/tmp/unassigned.devices/credentials_BM_PA_files' '//CLAIMCO/BM_PA_files' '/mnt/remotes/CLAIMCO_BM_PA_files' Dec 19 22:37:35 Claimco kernel: Key type dns_resolver registered Dec 19 22:37:35 Claimco kernel: Key type cifs.idmap registered Dec 19 22:37:35 Claimco kernel: CIFS: No dialect specified on mount. Default has changed to a more secure dialect, SMB2.1 or later (e.g. SMB3.1.1), from CIFS (SMB1). To use the less secure SMB1 dialect to access old servers which do not support SMB3.1.1 (or even SMB3 or SMB2.1) specify vers=1.0 on mount. Dec 19 22:37:35 Claimco kernel: CIFS: Attempting to mount \\CLAIMCO\BM_PA_files Dec 19 22:37:35 Claimco unassigned.devices: Successfully mounted '//CLAIMCO/BM_PA_files' on '/mnt/remotes/CLAIMCO_BM_PA_files'. Dec 19 22:37:35 Claimco unassigned.devices: Adding SMB share 'CLAIMCO_BM_PA_files'. Dec 19 22:37:39 Claimco sshd[9822]: Connection from 92.46.108.20 port 35182 on 192.168.1.233 port 22 rdomain "" Dec 19 22:37:41 Claimco sshd[9822]: Invalid user user from 92.46.108.20 port 35182 Dec 19 22:37:41 Claimco sshd[9822]: pam_unix(sshd:auth): check pass; user unknown Dec 19 22:37:41 Claimco sshd[9822]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=92.46.108.20 Dec 19 22:37:43 Claimco flash_backup: adding task: /usr/local/emhttp/plugins/dynamix.my.servers/scripts/UpdateFlashBackup update Dec 19 22:37:44 Claimco sshd[9822]: Failed password for invalid user user from 92.46.108.20 port 35182 ssh2 Dec 19 22:37:47 Claimco sshd[9822]: Connection closed by invalid user user 92.46.108.20 port 35182 [preauth] Dec 19 22:37:47 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 22:38:24 Claimco sshd[11704]: Connection from 61.177.172.90 port 43884 on 192.168.1.233 port 22 rdomain "" Dec 19 22:38:25 Claimco sshd[11704]: Received disconnect from 61.177.172.90 port 43884:11: [preauth] Dec 19 22:38:25 Claimco sshd[11704]: Disconnected from 61.177.172.90 port 43884 [preauth] Dec 19 22:38:27 Claimco sshd[11810]: Connection from 65.2.28.105 port 53426 on 192.168.1.233 port 22 rdomain "" Dec 19 22:38:28 Claimco sshd[11810]: Invalid user user from 65.2.28.105 port 53426 Dec 19 22:38:28 Claimco sshd[11810]: pam_unix(sshd:auth): check pass; user unknown Dec 19 22:38:28 Claimco sshd[11810]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=65.2.28.105 Dec 19 22:38:31 Claimco sshd[11810]: Failed password for invalid user user from 65.2.28.105 port 53426 ssh2 Dec 19 22:38:31 Claimco sshd[11810]: Connection closed by invalid user user 65.2.28.105 port 53426 [preauth] Dec 19 22:38:59 Claimco sshd[12677]: Connection from 61.177.173.46 port 56741 on 192.168.1.233 port 22 rdomain "" Dec 19 22:39:00 Claimco sshd[12677]: Received disconnect from 61.177.173.46 port 56741:11: [preauth] Dec 19 22:39:00 Claimco sshd[12677]: Disconnected from 61.177.173.46 port 56741 [preauth] Dec 19 22:39:13 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:39:41 Claimco emhttpd: Starting services... Dec 19 22:39:41 Claimco emhttpd: shcmd (267): /etc/rc.d/rc.samba restart Dec 19 22:39:41 Claimco wsdd2[7837]: 'Terminated' signal received. Dec 19 22:39:41 Claimco wsdd2[7837]: terminating. Dec 19 22:39:41 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 22:39:43 Claimco flash_backup: adding task: /usr/local/emhttp/plugins/dynamix.my.servers/scripts/UpdateFlashBackup update Dec 19 22:39:44 Claimco root: Starting Samba: /usr/sbin/smbd -D Dec 19 22:39:44 Claimco root: /usr/sbin/wsdd2 -d Dec 19 22:39:44 Claimco wsdd2[14669]: starting. Dec 19 22:39:44 Claimco root: /usr/sbin/winbindd -D Dec 19 22:39:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 22:39:44 Claimco emhttpd: shcmd (271): /etc/rc.d/rc.avahidaemon restart Dec 19 22:39:44 Claimco root: Stopping Avahi mDNS/DNS-SD Daemon: stopped Dec 19 22:39:44 Claimco avahi-daemon[7857]: Got SIGTERM, quitting. Dec 19 22:39:44 Claimco avahi-dnsconfd[7866]: read(): EOF Dec 19 22:39:44 Claimco avahi-daemon[7857]: Leaving mDNS multicast group on interface virbr0.IPv4 with address 192.168.122.1. Dec 19 22:39:44 Claimco avahi-daemon[7857]: Leaving mDNS multicast group on interface br0.IPv4 with address 192.168.1.233. Dec 19 22:39:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:39:44 Claimco avahi-daemon[7857]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1. Dec 19 22:39:44 Claimco avahi-daemon[7857]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Dec 19 22:39:44 Claimco avahi-daemon[7857]: avahi-daemon 0.8 exiting. Dec 19 22:39:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:39:44 Claimco root: Starting Avahi mDNS/DNS-SD Daemon: /usr/sbin/avahi-daemon -D Dec 19 22:39:44 Claimco avahi-daemon[14703]: Found user 'avahi' (UID 61) and group 'avahi' (GID 214). Dec 19 22:39:44 Claimco avahi-daemon[14703]: Successfully dropped root privileges. Dec 19 22:39:44 Claimco avahi-daemon[14703]: avahi-daemon 0.8 starting up. Dec 19 22:39:44 Claimco avahi-daemon[14703]: Successfully called chroot(). Dec 19 22:39:44 Claimco avahi-daemon[14703]: Successfully dropped remaining capabilities. Dec 19 22:39:44 Claimco avahi-daemon[14703]: Loading service file /services/sftp-ssh.service. Dec 19 22:39:44 Claimco avahi-daemon[14703]: Loading service file /services/smb.service. Dec 19 22:39:44 Claimco avahi-daemon[14703]: Loading service file /services/ssh.service. Dec 19 22:39:44 Claimco avahi-daemon[14703]: Joining mDNS multicast group on interface virbr0.IPv4 with address 192.168.122.1. Dec 19 22:39:44 Claimco avahi-daemon[14703]: New relevant interface virbr0.IPv4 for mDNS. Dec 19 22:39:44 Claimco avahi-daemon[14703]: Joining mDNS multicast group on interface br0.IPv4 with address 192.168.1.233. Dec 19 22:39:44 Claimco avahi-daemon[14703]: New relevant interface br0.IPv4 for mDNS. Dec 19 22:39:44 Claimco avahi-daemon[14703]: Joining mDNS multicast group on interface lo.IPv6 with address ::1. Dec 19 22:39:44 Claimco avahi-daemon[14703]: New relevant interface lo.IPv6 for mDNS. Dec 19 22:39:44 Claimco avahi-daemon[14703]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Dec 19 22:39:44 Claimco avahi-daemon[14703]: New relevant interface lo.IPv4 for mDNS. Dec 19 22:39:44 Claimco avahi-daemon[14703]: Network interface enumeration completed. Dec 19 22:39:44 Claimco avahi-daemon[14703]: Registering new address record for 192.168.122.1 on virbr0.IPv4. Dec 19 22:39:44 Claimco avahi-daemon[14703]: Registering new address record for 192.168.1.233 on br0.IPv4. Dec 19 22:39:44 Claimco avahi-daemon[14703]: Registering new address record for ::1 on lo.*. Dec 19 22:39:44 Claimco avahi-daemon[14703]: Registering new address record for 127.0.0.1 on lo.IPv4. Dec 19 22:39:44 Claimco emhttpd: shcmd (272): /etc/rc.d/rc.avahidnsconfd restart Dec 19 22:39:44 Claimco root: Stopping Avahi mDNS/DNS-SD DNS Server Configuration Daemon: stopped Dec 19 22:39:44 Claimco root: Starting Avahi mDNS/DNS-SD DNS Server Configuration Daemon: /usr/sbin/avahi-dnsconfd -D Dec 19 22:39:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:39:44 Claimco avahi-dnsconfd[14714]: Successfully connected to Avahi daemon. Dec 19 22:39:44 Claimco emhttpd: shcmd (277): smbcontrol smbd close-share 'BM_PA_files' Dec 19 22:39:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 22:39:45 Claimco avahi-daemon[14703]: Server startup complete. Host name is Claimco.local. Local service cookie is 3321412350. Dec 19 22:39:45 Claimco avahi-daemon[14703]: Service "Claimco" (/services/ssh.service) successfully established. Dec 19 22:39:45 Claimco avahi-daemon[14703]: Service "Claimco" (/services/smb.service) successfully established. Dec 19 22:39:45 Claimco avahi-daemon[14703]: Service "Claimco" (/services/sftp-ssh.service) successfully established. Dec 19 22:39:47 Claimco kernel: net_ratelimit: 11 callbacks suppressed Dec 19 22:39:47 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 10 TIMES] ### Dec 19 22:41:37 Claimco emhttpd: Starting services... Dec 19 22:41:37 Claimco emhttpd: shcmd (280): /etc/rc.d/rc.samba restart Dec 19 22:41:37 Claimco wsdd2[14669]: 'Terminated' signal received. Dec 19 22:41:37 Claimco wsdd2[14669]: terminating. Dec 19 22:41:37 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 22:41:39 Claimco root: Starting Samba: /usr/sbin/smbd -D Dec 19 22:41:39 Claimco root: /usr/sbin/wsdd2 -d Dec 19 22:41:39 Claimco wsdd2[18422]: starting. Dec 19 22:41:39 Claimco root: /usr/sbin/winbindd -D Dec 19 22:41:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 22:41:39 Claimco emhttpd: shcmd (284): /etc/rc.d/rc.avahidaemon restart Dec 19 22:41:39 Claimco root: Stopping Avahi mDNS/DNS-SD Daemon: stopped Dec 19 22:41:39 Claimco avahi-daemon[14703]: Got SIGTERM, quitting. Dec 19 22:41:39 Claimco avahi-dnsconfd[14714]: read(): EOF Dec 19 22:41:39 Claimco avahi-daemon[14703]: Leaving mDNS multicast group on interface virbr0.IPv4 with address 192.168.122.1. Dec 19 22:41:39 Claimco avahi-daemon[14703]: Leaving mDNS multicast group on interface br0.IPv4 with address 192.168.1.233. Dec 19 22:41:39 Claimco avahi-daemon[14703]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1. Dec 19 22:41:39 Claimco avahi-daemon[14703]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Dec 19 22:41:39 Claimco avahi-daemon[14703]: avahi-daemon 0.8 exiting. Dec 19 22:41:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 22:41:39 Claimco root: Starting Avahi mDNS/DNS-SD Daemon: /usr/sbin/avahi-daemon -D Dec 19 22:41:39 Claimco avahi-daemon[18455]: Found user 'avahi' (UID 61) and group 'avahi' (GID 214). Dec 19 22:41:39 Claimco avahi-daemon[18455]: Successfully dropped root privileges. Dec 19 22:41:39 Claimco avahi-daemon[18455]: avahi-daemon 0.8 starting up. Dec 19 22:41:39 Claimco avahi-daemon[18455]: Successfully called chroot(). Dec 19 22:41:39 Claimco avahi-daemon[18455]: Successfully dropped remaining capabilities. Dec 19 22:41:39 Claimco avahi-daemon[18455]: Loading service file /services/sftp-ssh.service. Dec 19 22:41:39 Claimco avahi-daemon[18455]: Loading service file /services/smb.service. Dec 19 22:41:39 Claimco avahi-daemon[18455]: Loading service file /services/ssh.service. Dec 19 22:41:39 Claimco avahi-daemon[18455]: Joining mDNS multicast group on interface virbr0.IPv4 with address 192.168.122.1. Dec 19 22:41:39 Claimco avahi-daemon[18455]: New relevant interface virbr0.IPv4 for mDNS. Dec 19 22:41:39 Claimco avahi-daemon[18455]: Joining mDNS multicast group on interface br0.IPv4 with address 192.168.1.233. Dec 19 22:41:39 Claimco avahi-daemon[18455]: New relevant interface br0.IPv4 for mDNS. Dec 19 22:41:39 Claimco avahi-daemon[18455]: Joining mDNS multicast group on interface lo.IPv6 with address ::1. Dec 19 22:41:39 Claimco avahi-daemon[18455]: New relevant interface lo.IPv6 for mDNS. Dec 19 22:41:39 Claimco avahi-daemon[18455]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Dec 19 22:41:39 Claimco avahi-daemon[18455]: New relevant interface lo.IPv4 for mDNS. Dec 19 22:41:39 Claimco avahi-daemon[18455]: Network interface enumeration completed. Dec 19 22:41:39 Claimco avahi-daemon[18455]: Registering new address record for 192.168.122.1 on virbr0.IPv4. Dec 19 22:41:39 Claimco avahi-daemon[18455]: Registering new address record for 192.168.1.233 on br0.IPv4. Dec 19 22:41:39 Claimco avahi-daemon[18455]: Registering new address record for ::1 on lo.*. Dec 19 22:41:39 Claimco avahi-daemon[18455]: Registering new address record for 127.0.0.1 on lo.IPv4. Dec 19 22:41:39 Claimco emhttpd: shcmd (285): /etc/rc.d/rc.avahidnsconfd restart Dec 19 22:41:39 Claimco root: Stopping Avahi mDNS/DNS-SD DNS Server Configuration Daemon: stopped Dec 19 22:41:39 Claimco root: Starting Avahi mDNS/DNS-SD DNS Server Configuration Daemon: /usr/sbin/avahi-dnsconfd -D Dec 19 22:41:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:41:39 Claimco avahi-dnsconfd[18466]: Successfully connected to Avahi daemon. Dec 19 22:41:39 Claimco emhttpd: shcmd (290): smbcontrol smbd close-share 'BM_PA_files' Dec 19 22:41:39 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 22:41:40 Claimco avahi-daemon[18455]: Server startup complete. Host name is Claimco.local. Local service cookie is 402045220. Dec 19 22:41:41 Claimco avahi-daemon[18455]: Service "Claimco" (/services/ssh.service) successfully established. Dec 19 22:41:41 Claimco avahi-daemon[18455]: Service "Claimco" (/services/smb.service) successfully established. Dec 19 22:41:41 Claimco avahi-daemon[18455]: Service "Claimco" (/services/sftp-ssh.service) successfully established. Dec 19 22:41:42 Claimco kernel: net_ratelimit: 11 callbacks suppressed Dec 19 22:41:42 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 22:41:43 Claimco flash_backup: adding task: /usr/local/emhttp/plugins/dynamix.my.servers/scripts/UpdateFlashBackup update Dec 19 22:41:44 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 8 TIMES] ### Dec 19 22:44:49 Claimco sshd[23627]: Connection from 162.218.126.136 port 52636 on 192.168.1.233 port 22 rdomain "" Dec 19 22:44:49 Claimco sshd[23627]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=162.218.126.136 user=root Dec 19 22:44:51 Claimco sshd[23627]: Failed password for root from 162.218.126.136 port 52636 ssh2 Dec 19 22:44:51 Claimco sshd[23627]: Connection closed by authenticating user root 162.218.126.136 port 52636 [preauth] Dec 19 22:45:18 Claimco sshd[24418]: Connection from 61.177.173.36 port 51308 on 192.168.1.233 port 22 rdomain "" Dec 19 22:45:20 Claimco sshd[24418]: Received disconnect from 61.177.173.36 port 51308:11: [preauth] Dec 19 22:45:20 Claimco sshd[24418]: Disconnected from 61.177.173.36 port 51308 [preauth] Dec 19 22:45:49 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 10 TIMES] ### Dec 19 22:46:35 Claimco sshd[26238]: Connection from 61.177.173.53 port 53813 on 192.168.1.233 port 22 rdomain "" Dec 19 22:46:36 Claimco sshd[26238]: Received disconnect from 61.177.173.53 port 53813:11: [preauth] Dec 19 22:46:36 Claimco sshd[26238]: Disconnected from 61.177.173.53 port 53813 [preauth] Dec 19 22:46:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 14 TIMES] ### Dec 19 22:48:10 Claimco sshd[28590]: Connection from 61.177.172.108 port 38369 on 192.168.1.233 port 22 rdomain "" Dec 19 22:48:12 Claimco sshd[28590]: Received disconnect from 61.177.172.108 port 38369:11: [preauth] Dec 19 22:48:12 Claimco sshd[28590]: Disconnected from 61.177.172.108 port 38369 [preauth] Dec 19 22:48:16 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 19 22:48:27 Claimco sshd[28957]: Connection from 61.177.172.104 port 57999 on 192.168.1.233 port 22 rdomain "" Dec 19 22:48:28 Claimco sshd[28957]: Received disconnect from 61.177.172.104 port 57999:11: [preauth] Dec 19 22:48:28 Claimco sshd[28957]: Disconnected from 61.177.172.104 port 57999 [preauth] Dec 19 22:49:05 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 24 TIMES] ### Dec 19 22:54:08 Claimco sshd[7282]: Connection from 61.177.173.36 port 53619 on 192.168.1.233 port 22 rdomain "" Dec 19 22:54:09 Claimco sshd[7282]: Received disconnect from 61.177.173.36 port 53619:11: [preauth] Dec 19 22:54:09 Claimco sshd[7282]: Disconnected from 61.177.173.36 port 53619 [preauth] Dec 19 22:54:41 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:54:54 Claimco sshd[8688]: Connection from 61.177.173.49 port 35588 on 192.168.1.233 port 22 rdomain "" Dec 19 22:54:57 Claimco sshd[8688]: Received disconnect from 61.177.173.49 port 35588:11: [preauth] Dec 19 22:54:57 Claimco sshd[8688]: Disconnected from 61.177.173.49 port 35588 [preauth] Dec 19 22:55:10 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 22:55:43 Claimco flash_backup: adding task: /usr/local/emhttp/plugins/dynamix.my.servers/scripts/UpdateFlashBackup update Dec 19 22:56:10 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:56:43 Claimco flash_backup: adding task: /usr/local/emhttp/plugins/dynamix.my.servers/scripts/UpdateFlashBackup update Dec 19 22:56:47 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 22:58:08 Claimco kernel: mdcmd (37): nocheck cancel Dec 19 22:58:09 Claimco emhttpd: Spinning up all drives... Dec 19 22:58:09 Claimco emhttpd: read SMART /dev/sdj Dec 19 22:58:09 Claimco emhttpd: read SMART /dev/sdk Dec 19 22:58:09 Claimco emhttpd: read SMART /dev/sdh Dec 19 22:58:09 Claimco emhttpd: read SMART /dev/sdg Dec 19 22:58:09 Claimco emhttpd: read SMART /dev/sdd Dec 19 22:58:09 Claimco emhttpd: read SMART /dev/sde Dec 19 22:58:09 Claimco emhttpd: read SMART /dev/sdb Dec 19 22:58:09 Claimco emhttpd: read SMART /dev/sdf Dec 19 22:58:09 Claimco emhttpd: read SMART /dev/sdc Dec 19 22:58:09 Claimco emhttpd: read SMART /dev/nvme0n1 Dec 19 22:58:09 Claimco emhttpd: read SMART /dev/sdi Dec 19 22:58:09 Claimco emhttpd: read SMART /dev/sda Dec 19 22:58:09 Claimco emhttpd: Stopping services... Dec 19 22:58:09 Claimco emhttpd: shcmd (293): /etc/rc.d/rc.libvirt stop Dec 19 22:58:09 Claimco root: Stopping libvirtd... Dec 19 22:58:09 Claimco dnsmasq[8062]: exiting on receipt of SIGTERM Dec 19 22:58:09 Claimco avahi-daemon[18455]: Interface virbr0.IPv4 no longer relevant for mDNS. Dec 19 22:58:09 Claimco avahi-daemon[18455]: Leaving mDNS multicast group on interface virbr0.IPv4 with address 192.168.122.1. Dec 19 22:58:09 Claimco avahi-daemon[18455]: Withdrawing address record for 192.168.122.1 on virbr0. Dec 19 22:58:09 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 22:58:09 Claimco root: Network 4d44ecbc-1949-476b-b660-c6fd29f7d003 destroyed Dec 19 22:58:09 Claimco root: Dec 19 22:58:10 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:58:12 Claimco root: Stopping virtlogd... Dec 19 22:58:13 Claimco root: Stopping virtlockd... Dec 19 22:58:14 Claimco emhttpd: shcmd (294): umount /etc/libvirt Dec 19 22:58:14 Claimco root: Stopping CA Turbo Mode Dec 19 22:58:14 Claimco root: Terminating 7632 Dec 19 22:58:14 Claimco Recycle Bin: Stopping Recycle Bin Dec 19 22:58:14 Claimco emhttpd: Stopping Recycle Bin... Dec 19 22:58:14 Claimco unassigned.devices: Unmounting All Devices... Dec 19 22:58:14 Claimco unassigned.devices: Removing Remote SMB/NFS share '//CLAIMCO/BM_PA_files'... Dec 19 22:58:14 Claimco unassigned.devices: Running device script: 'CLAIMCO_BM_PA_files.sh' with action 'UNMOUNT'. Dec 19 22:58:14 Claimco unassigned.devices: Unmounting Remote SMB/NFS Share '//CLAIMCO/BM_PA_files'... Dec 19 22:58:14 Claimco unassigned.devices: Unmount cmd: /sbin/umount -t cifs -fl '//CLAIMCO/BM_PA_files' 2>&1 Dec 19 22:58:14 Claimco unassigned.devices: Successfully unmounted 'BM_PA_files' Dec 19 22:58:14 Claimco unassigned.devices: Removing SMB share 'CLAIMCO_BM_PA_files' Dec 19 22:58:15 Claimco unassigned.devices: Running device script: 'CLAIMCO_BM_PA_files.sh' with action 'REMOVE'. Dec 19 22:58:16 Claimco emhttpd: shcmd (296): /etc/rc.d/rc.samba stop Dec 19 22:58:16 Claimco wsdd2[18422]: 'Terminated' signal received. Dec 19 22:58:16 Claimco wsdd2[18422]: terminating. Dec 19 22:58:16 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 22:58:16 Claimco emhttpd: shcmd (297): rm -f /etc/avahi/services/smb.service Dec 19 22:58:16 Claimco avahi-daemon[18455]: Files changed, reloading. Dec 19 22:58:16 Claimco avahi-daemon[18455]: Service group file /services/smb.service vanished, removing services. Dec 19 22:58:16 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:58:16 Claimco emhttpd: Stopping mover... Dec 19 22:58:16 Claimco emhttpd: shcmd (299): /usr/local/sbin/mover stop Dec 19 22:58:16 Claimco root: mover: not running Dec 19 22:58:16 Claimco emhttpd: Sync filesystems... Dec 19 22:58:16 Claimco emhttpd: shcmd (300): sync Dec 19 22:58:16 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:58:17 Claimco ProFTPd: Running unmountscript.sh... Dec 19 22:58:17 Claimco emhttpd: Stopping ProFTPd... Dec 19 22:58:18 Claimco proftpd[1655]: 127.0.0.1 - ProFTPD killed (signal 15) Dec 19 22:58:18 Claimco proftpd[1655]: 127.0.0.1 - ProFTPD 1.3.7a standalone mode SHUTDOWN Dec 19 22:58:19 Claimco emhttpd: ... Stop OK Dec 19 22:58:20 Claimco emhttpd: shcmd (301): umount /mnt/user0 Dec 19 22:58:20 Claimco emhttpd: shcmd (302): rmdir /mnt/user0 Dec 19 22:58:20 Claimco emhttpd: shcmd (303): umount /mnt/user Dec 19 22:58:20 Claimco emhttpd: shcmd (304): rmdir /mnt/user Dec 19 22:58:20 Claimco emhttpd: shcmd (306): /usr/local/sbin/update_cron Dec 19 22:58:20 Claimco emhttpd: Unmounting disks... Dec 19 22:58:20 Claimco emhttpd: shcmd (307): umount /mnt/disk1 Dec 19 22:58:20 Claimco kernel: XFS (md1): Unmounting Filesystem Dec 19 22:58:20 Claimco emhttpd: shcmd (308): rmdir /mnt/disk1 Dec 19 22:58:20 Claimco emhttpd: shcmd (309): umount /mnt/disk2 Dec 19 22:58:20 Claimco kernel: XFS (md2): Unmounting Filesystem Dec 19 22:58:21 Claimco emhttpd: shcmd (310): rmdir /mnt/disk2 Dec 19 22:58:21 Claimco emhttpd: shcmd (311): umount /mnt/disk3 Dec 19 22:58:21 Claimco kernel: XFS (md3): Unmounting Filesystem Dec 19 22:58:21 Claimco emhttpd: shcmd (312): rmdir /mnt/disk3 Dec 19 22:58:21 Claimco emhttpd: shcmd (313): umount /mnt/disk4 Dec 19 22:58:21 Claimco kernel: XFS (md4): Unmounting Filesystem Dec 19 22:58:21 Claimco emhttpd: shcmd (314): rmdir /mnt/disk4 Dec 19 22:58:21 Claimco emhttpd: shcmd (315): umount /mnt/disk5 Dec 19 22:58:21 Claimco kernel: XFS (md5): Unmounting Filesystem Dec 19 22:58:21 Claimco emhttpd: shcmd (316): rmdir /mnt/disk5 Dec 19 22:58:21 Claimco emhttpd: shcmd (317): umount /mnt/disk6 Dec 19 22:58:21 Claimco kernel: XFS (md6): Unmounting Filesystem Dec 19 22:58:21 Claimco emhttpd: shcmd (318): rmdir /mnt/disk6 Dec 19 22:58:21 Claimco emhttpd: shcmd (319): umount /mnt/disk7 Dec 19 22:58:21 Claimco kernel: XFS (md7): Unmounting Filesystem Dec 19 22:58:21 Claimco emhttpd: shcmd (320): rmdir /mnt/disk7 Dec 19 22:58:21 Claimco emhttpd: shcmd (321): umount /mnt/disk8 Dec 19 22:58:21 Claimco kernel: XFS (md8): Unmounting Filesystem Dec 19 22:58:21 Claimco emhttpd: shcmd (322): rmdir /mnt/disk8 Dec 19 22:58:21 Claimco emhttpd: shcmd (323): umount /mnt/disk9 Dec 19 22:58:21 Claimco kernel: XFS (md9): Unmounting Filesystem Dec 19 22:58:21 Claimco emhttpd: shcmd (324): rmdir /mnt/disk9 Dec 19 22:58:21 Claimco emhttpd: shcmd (325): umount /mnt/cache Dec 19 22:58:21 Claimco emhttpd: shcmd (326): rmdir /mnt/cache Dec 19 22:58:21 Claimco kernel: mdcmd (38): stop Dec 19 22:58:21 Claimco kernel: md1: stopping Dec 19 22:58:21 Claimco kernel: md2: stopping Dec 19 22:58:21 Claimco kernel: md3: stopping Dec 19 22:58:21 Claimco kernel: md4: stopping Dec 19 22:58:21 Claimco kernel: md5: stopping Dec 19 22:58:21 Claimco kernel: md6: stopping Dec 19 22:58:21 Claimco kernel: md7: stopping Dec 19 22:58:21 Claimco kernel: md8: stopping Dec 19 22:58:21 Claimco kernel: md9: stopping Dec 19 22:58:21 Claimco emhttpd: shcmd (328): rm -f /boot/config/forcesync Dec 19 22:58:21 Claimco emhttpd: shcmd (329): sync Dec 19 22:58:22 Claimco emhttpd: Starting services... Dec 19 22:58:22 Claimco emhttpd: shcmd (331): /etc/rc.d/rc.samba start Dec 19 22:58:22 Claimco root: Starting Samba: /usr/sbin/smbd -D Dec 19 22:58:22 Claimco root: /usr/sbin/wsdd2 -d Dec 19 22:58:22 Claimco wsdd2[17172]: starting. Dec 19 22:58:22 Claimco root: /usr/sbin/winbindd -D Dec 19 22:58:22 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 22:58:22 Claimco emhttpd: shcmd (332): cp /tmp/emhttp/smb.service /etc/avahi/services/smb.service Dec 19 22:58:22 Claimco avahi-daemon[18455]: Files changed, reloading. Dec 19 22:58:22 Claimco avahi-daemon[18455]: Loading service file /services/smb.service. Dec 19 22:58:22 Claimco emhttpd: shcmd (335): /etc/rc.d/rc.avahidaemon restart Dec 19 22:58:22 Claimco root: Stopping Avahi mDNS/DNS-SD Daemon: stopped Dec 19 22:58:22 Claimco avahi-daemon[18455]: Got SIGTERM, quitting. Dec 19 22:58:22 Claimco avahi-dnsconfd[18466]: read(): EOF Dec 19 22:58:22 Claimco avahi-daemon[18455]: Leaving mDNS multicast group on interface br0.IPv4 with address 192.168.1.233. Dec 19 22:58:22 Claimco avahi-daemon[18455]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1. Dec 19 22:58:22 Claimco avahi-daemon[18455]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Dec 19 22:58:22 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:58:22 Claimco avahi-daemon[18455]: avahi-daemon 0.8 exiting. Dec 19 22:58:22 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:58:22 Claimco root: Starting Avahi mDNS/DNS-SD Daemon: /usr/sbin/avahi-daemon -D Dec 19 22:58:22 Claimco avahi-daemon[17206]: Found user 'avahi' (UID 61) and group 'avahi' (GID 214). Dec 19 22:58:22 Claimco avahi-daemon[17206]: Successfully dropped root privileges. Dec 19 22:58:22 Claimco avahi-daemon[17206]: avahi-daemon 0.8 starting up. Dec 19 22:58:22 Claimco avahi-daemon[17206]: Successfully called chroot(). Dec 19 22:58:22 Claimco avahi-daemon[17206]: Successfully dropped remaining capabilities. Dec 19 22:58:22 Claimco avahi-daemon[17206]: Loading service file /services/sftp-ssh.service. Dec 19 22:58:22 Claimco avahi-daemon[17206]: Loading service file /services/smb.service. Dec 19 22:58:22 Claimco avahi-daemon[17206]: Loading service file /services/ssh.service. Dec 19 22:58:22 Claimco avahi-daemon[17206]: Joining mDNS multicast group on interface br0.IPv4 with address 192.168.1.233. Dec 19 22:58:22 Claimco avahi-daemon[17206]: New relevant interface br0.IPv4 for mDNS. Dec 19 22:58:22 Claimco avahi-daemon[17206]: Joining mDNS multicast group on interface lo.IPv6 with address ::1. Dec 19 22:58:22 Claimco avahi-daemon[17206]: New relevant interface lo.IPv6 for mDNS. Dec 19 22:58:22 Claimco avahi-daemon[17206]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Dec 19 22:58:22 Claimco avahi-daemon[17206]: New relevant interface lo.IPv4 for mDNS. Dec 19 22:58:22 Claimco avahi-daemon[17206]: Network interface enumeration completed. Dec 19 22:58:22 Claimco avahi-daemon[17206]: Registering new address record for 192.168.1.233 on br0.IPv4. Dec 19 22:58:22 Claimco avahi-daemon[17206]: Registering new address record for ::1 on lo.*. Dec 19 22:58:22 Claimco avahi-daemon[17206]: Registering new address record for 127.0.0.1 on lo.IPv4. Dec 19 22:58:22 Claimco emhttpd: shcmd (336): /etc/rc.d/rc.avahidnsconfd restart Dec 19 22:58:22 Claimco root: Stopping Avahi mDNS/DNS-SD DNS Server Configuration Daemon: stopped Dec 19 22:58:22 Claimco root: Starting Avahi mDNS/DNS-SD DNS Server Configuration Daemon: /usr/sbin/avahi-dnsconfd -D Dec 19 22:58:22 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:58:22 Claimco avahi-dnsconfd[17220]: Successfully connected to Avahi daemon. Dec 19 22:58:22 Claimco emhttpd: no mountpoint along path: /mnt/user/system/libvirt Dec 19 22:58:22 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 4 TIMES] ### Dec 19 22:58:23 Claimco avahi-daemon[17206]: Server startup complete. Host name is Claimco.local. Local service cookie is 2783161666. Dec 19 22:58:24 Claimco avahi-daemon[17206]: Service "Claimco" (/services/ssh.service) successfully established. Dec 19 22:58:24 Claimco avahi-daemon[17206]: Service "Claimco" (/services/smb.service) successfully established. Dec 19 22:58:24 Claimco avahi-daemon[17206]: Service "Claimco" (/services/sftp-ssh.service) successfully established. Dec 19 22:58:27 Claimco kernel: net_ratelimit: 10 callbacks suppressed Dec 19 22:58:27 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 22:58:31 Claimco emhttpd: shcmd (355): rmmod md-mod Dec 19 22:58:31 Claimco kernel: md: unRAID driver removed Dec 19 22:58:31 Claimco emhttpd: shcmd (356): modprobe md-mod super=/boot/config/super.dat Dec 19 22:58:31 Claimco kernel: md: unRAID driver 2.9.25 installed Dec 19 22:58:31 Claimco emhttpd: Device inventory: Dec 19 22:58:31 Claimco emhttpd: APPLE_HDD_ST2000DM001_Z8E0AL3H (sdj) 512 3907029168 Dec 19 22:58:31 Claimco emhttpd: ST2000DM001-1CH164_Z1E4ZXL1 (sdk) 512 3907029168 Dec 19 22:58:31 Claimco emhttpd: ST2000DM001-1ER164_Z4Z7FTDQ (sdh) 512 3907029168 Dec 19 22:58:31 Claimco emhttpd: WDC_WD6400AAKS-22A7B2_WD-WMASY5990247 (sdg) 512 1250263728 Dec 19 22:58:31 Claimco emhttpd: ST8000DM004-2CX188_ZR10QKFN (sdd) 512 15628053168 Dec 19 22:58:31 Claimco emhttpd: ST32000542AS_5XW1JRXG (sde) 512 3907029168 Dec 19 22:58:31 Claimco emhttpd: ST32000644NS_9WM55H64 (sdb) 512 3907029168 Dec 19 22:58:31 Claimco emhttpd: ST4000DM004-2U9104_ZTT3YVPM (sdf) 512 7814037168 Dec 19 22:58:31 Claimco emhttpd: WDC_WD4005FZBX-00K5WB0_V3GDVTJG (sdc) 512 7814037168 Dec 19 22:58:31 Claimco emhttpd: INTEL_SSDPEKNU020TZ_BTKA204200RJ2P0C (nvme0n1) 512 4000797360 Dec 19 22:58:31 Claimco emhttpd: WDC_WD4005FZBX-00K5WB0_VBHN4KNF (sdi) 512 7814037168 Dec 19 22:58:31 Claimco emhttpd: Memorex_TRAVELDRIVE_005B_079117160100-0:0 (sda) 512 31277056 Dec 19 22:58:32 Claimco kernel: mdcmd (1): import 0 sdd 64 7814026532 0 ST8000DM004-2CX188_ZR10QKFN Dec 19 22:58:32 Claimco kernel: md: import disk0: (sdd) ST8000DM004-2CX188_ZR10QKFN size: 7814026532 Dec 19 22:58:32 Claimco kernel: mdcmd (2): import 1 sdk 64 1953514552 0 ST2000DM001-1CH164_Z1E4ZXL1 Dec 19 22:58:32 Claimco kernel: md: import disk1: (sdk) ST2000DM001-1CH164_Z1E4ZXL1 size: 1953514552 Dec 19 22:58:32 Claimco kernel: mdcmd (3): import 2 sdh 64 1953514552 0 ST2000DM001-1ER164_Z4Z7FTDQ Dec 19 22:58:32 Claimco kernel: md: import disk2: (sdh) ST2000DM001-1ER164_Z4Z7FTDQ size: 1953514552 Dec 19 22:58:32 Claimco kernel: mdcmd (4): import 3 sde 64 1953514552 0 ST32000542AS_5XW1JRXG Dec 19 22:58:32 Claimco kernel: md: import disk3: (sde) ST32000542AS_5XW1JRXG size: 1953514552 Dec 19 22:58:32 Claimco kernel: mdcmd (5): import 4 sdb 64 1953514552 0 ST32000644NS_9WM55H64 Dec 19 22:58:32 Claimco kernel: md: import disk4: (sdb) ST32000644NS_9WM55H64 size: 1953514552 Dec 19 22:58:32 Claimco kernel: mdcmd (6): import 5 Dec 19 22:58:32 Claimco kernel: md: import_slot: 5 missing Dec 19 22:58:32 Claimco kernel: mdcmd (7): import 6 sdc 64 3907018532 0 WDC_WD4005FZBX-00K5WB0_V3GDVTJG Dec 19 22:58:32 Claimco kernel: md: import disk6: (sdc) WDC_WD4005FZBX-00K5WB0_V3GDVTJG size: 3907018532 Dec 19 22:58:32 Claimco kernel: mdcmd (8): import 7 sdf 64 3907018532 0 ST4000DM004-2U9104_ZTT3YVPM Dec 19 22:58:32 Claimco kernel: md: import disk7: (sdf) ST4000DM004-2U9104_ZTT3YVPM size: 3907018532 Dec 19 22:58:32 Claimco kernel: mdcmd (9): import 8 sdg 64 625131832 0 WDC_WD6400AAKS-22A7B2_WD-WMASY5990247 Dec 19 22:58:32 Claimco kernel: md: import disk8: (sdg) WDC_WD6400AAKS-22A7B2_WD-WMASY5990247 size: 625131832 Dec 19 22:58:32 Claimco emhttpd: import 30 cache device: (nvme0n1) INTEL_SSDPEKNU020TZ_BTKA204200RJ2P0C Dec 19 22:58:32 Claimco kernel: mdcmd (10): import 9 sdi 64 3907018532 0 WDC_WD4005FZBX-00K5WB0_VBHN4KNF Dec 19 22:58:32 Claimco kernel: md: import disk9: (sdi) WDC_WD4005FZBX-00K5WB0_VBHN4KNF size: 3907018532 Dec 19 22:58:32 Claimco kernel: mdcmd (11): import 10 Dec 19 22:58:32 Claimco kernel: mdcmd (12): import 11 Dec 19 22:58:32 Claimco kernel: mdcmd (13): import 12 Dec 19 22:58:32 Claimco kernel: mdcmd (14): import 13 Dec 19 22:58:32 Claimco kernel: mdcmd (15): import 14 Dec 19 22:58:32 Claimco kernel: mdcmd (16): import 15 Dec 19 22:58:32 Claimco kernel: mdcmd (17): import 16 Dec 19 22:58:32 Claimco kernel: mdcmd (18): import 17 Dec 19 22:58:32 Claimco kernel: mdcmd (19): import 18 Dec 19 22:58:32 Claimco kernel: mdcmd (20): import 19 Dec 19 22:58:32 Claimco kernel: mdcmd (21): import 20 Dec 19 22:58:32 Claimco kernel: mdcmd (22): import 21 Dec 19 22:58:32 Claimco kernel: mdcmd (23): import 22 Dec 19 22:58:32 Claimco kernel: mdcmd (24): import 23 Dec 19 22:58:32 Claimco kernel: mdcmd (25): import 24 Dec 19 22:58:32 Claimco kernel: mdcmd (26): import 25 Dec 19 22:58:32 Claimco kernel: mdcmd (27): import 26 Dec 19 22:58:32 Claimco kernel: mdcmd (28): import 27 Dec 19 22:58:32 Claimco kernel: mdcmd (29): import 28 Dec 19 22:58:32 Claimco kernel: mdcmd (30): import 29 Dec 19 22:58:32 Claimco kernel: md: import_slot: 29 empty Dec 19 22:58:32 Claimco emhttpd: import flash device: sda Dec 19 22:58:32 Claimco emhttpd: read SMART /dev/sdj Dec 19 22:58:32 Claimco emhttpd: read SMART /dev/sdk Dec 19 22:58:32 Claimco emhttpd: read SMART /dev/sdh Dec 19 22:58:32 Claimco emhttpd: read SMART /dev/sdg Dec 19 22:58:32 Claimco emhttpd: read SMART /dev/sdd Dec 19 22:58:32 Claimco emhttpd: read SMART /dev/sde Dec 19 22:58:32 Claimco emhttpd: read SMART /dev/sdb Dec 19 22:58:32 Claimco emhttpd: read SMART /dev/sdf Dec 19 22:58:32 Claimco emhttpd: read SMART /dev/sdc Dec 19 22:58:32 Claimco emhttpd: read SMART /dev/nvme0n1 Dec 19 22:58:32 Claimco emhttpd: read SMART /dev/sdi Dec 19 22:58:32 Claimco emhttpd: read SMART /dev/sda Dec 19 22:58:37 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:58:42 Claimco emhttpd: shcmd (376): echo 128 > /sys/block/sdd/queue/nr_requests Dec 19 22:58:42 Claimco kernel: mdcmd (31): set md_num_stripes 4096 Dec 19 22:58:42 Claimco kernel: mdcmd (32): set md_queue_limit 80 Dec 19 22:58:42 Claimco kernel: mdcmd (33): set md_sync_limit 32 Dec 19 22:58:42 Claimco kernel: mdcmd (34): set md_write_method 1 Dec 19 22:58:42 Claimco emhttpd: shcmd (377): echo 128 > /sys/block/sdk/queue/nr_requests Dec 19 22:58:42 Claimco emhttpd: shcmd (378): echo 128 > /sys/block/sdh/queue/nr_requests Dec 19 22:58:42 Claimco emhttpd: shcmd (379): echo 128 > /sys/block/sde/queue/nr_requests Dec 19 22:58:42 Claimco emhttpd: shcmd (380): echo 128 > /sys/block/sdb/queue/nr_requests Dec 19 22:58:42 Claimco emhttpd: shcmd (381): echo 128 > /sys/block/sdc/queue/nr_requests Dec 19 22:58:42 Claimco emhttpd: shcmd (382): echo 128 > /sys/block/sdf/queue/nr_requests Dec 19 22:58:42 Claimco emhttpd: shcmd (383): echo 128 > /sys/block/sdg/queue/nr_requests Dec 19 22:58:42 Claimco emhttpd: shcmd (384): echo 128 > /sys/block/sdi/queue/nr_requests Dec 19 22:58:42 Claimco kernel: mdcmd (35): start DISABLE_DISK Dec 19 22:58:42 Claimco kernel: unraid: allocating 181472K for 4096 stripes (11 disks) Dec 19 22:58:42 Claimco kernel: md1: running, size: 1953514552 blocks Dec 19 22:58:42 Claimco kernel: md2: running, size: 1953514552 blocks Dec 19 22:58:42 Claimco kernel: md3: running, size: 1953514552 blocks Dec 19 22:58:42 Claimco kernel: md4: running, size: 1953514552 blocks Dec 19 22:58:43 Claimco kernel: md5: running, size: 1953514552 blocks Dec 19 22:58:43 Claimco kernel: md6: running, size: 3907018532 blocks Dec 19 22:58:43 Claimco kernel: md7: running, size: 3907018532 blocks Dec 19 22:58:43 Claimco kernel: md8: running, size: 625131832 blocks Dec 19 22:58:43 Claimco kernel: md9: running, size: 3907018532 blocks Dec 19 22:58:43 Claimco emhttpd: shcmd (385): udevadm settle Dec 19 22:58:43 Claimco flash_backup: adding task: /usr/local/emhttp/plugins/dynamix.my.servers/scripts/UpdateFlashBackup update Dec 19 22:58:44 Claimco emhttpd: Opening encrypted volumes... Dec 19 22:58:44 Claimco emhttpd: shcmd (386): touch /boot/config/forcesync Dec 19 22:58:44 Claimco emhttpd: Mounting disks... Dec 19 22:58:45 Claimco emhttpd: shcmd (388): mkdir -p /mnt/disk1 Dec 19 22:58:45 Claimco emhttpd: shcmd (389): mount -t xfs -o noatime,nouuid /dev/md1 /mnt/disk1 Dec 19 22:58:45 Claimco kernel: XFS (md1): Mounting V5 Filesystem Dec 19 22:58:45 Claimco kernel: XFS (md1): Ending clean mount Dec 19 22:58:45 Claimco emhttpd: shcmd (390): xfs_growfs /mnt/disk1 Dec 19 22:58:45 Claimco root: meta-data=/dev/md1 isize=512 agcount=4, agsize=122094660 blks Dec 19 22:58:45 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:58:45 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:58:45 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:58:45 Claimco root: data = bsize=4096 blocks=488378638, imaxpct=5 Dec 19 22:58:45 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:58:45 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:58:45 Claimco root: log =internal log bsize=4096 blocks=238466, version=2 Dec 19 22:58:45 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:58:45 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:58:45 Claimco emhttpd: shcmd (391): mkdir -p /mnt/disk2 Dec 19 22:58:45 Claimco emhttpd: shcmd (392): mount -t xfs -o noatime,nouuid /dev/md2 /mnt/disk2 Dec 19 22:58:45 Claimco kernel: XFS (md2): Mounting V5 Filesystem Dec 19 22:58:45 Claimco kernel: XFS (md2): Ending clean mount Dec 19 22:58:45 Claimco emhttpd: shcmd (393): xfs_growfs /mnt/disk2 Dec 19 22:58:46 Claimco root: meta-data=/dev/md2 isize=512 agcount=4, agsize=122094660 blks Dec 19 22:58:46 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:58:46 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:58:46 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:58:46 Claimco root: data = bsize=4096 blocks=488378638, imaxpct=5 Dec 19 22:58:46 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:58:46 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:58:46 Claimco root: log =internal log bsize=4096 blocks=238466, version=2 Dec 19 22:58:46 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:58:46 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:58:46 Claimco emhttpd: shcmd (394): mkdir -p /mnt/disk3 Dec 19 22:58:46 Claimco emhttpd: shcmd (395): mount -t xfs -o noatime,nouuid /dev/md3 /mnt/disk3 Dec 19 22:58:46 Claimco kernel: XFS (md3): Mounting V5 Filesystem Dec 19 22:58:46 Claimco kernel: XFS (md3): Ending clean mount Dec 19 22:58:46 Claimco emhttpd: shcmd (396): xfs_growfs /mnt/disk3 Dec 19 22:58:46 Claimco root: meta-data=/dev/md3 isize=512 agcount=4, agsize=122094660 blks Dec 19 22:58:46 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:58:46 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:58:46 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:58:46 Claimco root: data = bsize=4096 blocks=488378638, imaxpct=5 Dec 19 22:58:46 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:58:46 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:58:46 Claimco root: log =internal log bsize=4096 blocks=238466, version=2 Dec 19 22:58:46 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:58:46 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:58:46 Claimco emhttpd: shcmd (397): mkdir -p /mnt/disk4 Dec 19 22:58:46 Claimco emhttpd: shcmd (398): mount -t xfs -o noatime,nouuid /dev/md4 /mnt/disk4 Dec 19 22:58:46 Claimco kernel: XFS (md4): Mounting V5 Filesystem Dec 19 22:58:46 Claimco kernel: XFS (md4): Ending clean mount Dec 19 22:58:46 Claimco emhttpd: shcmd (399): xfs_growfs /mnt/disk4 Dec 19 22:58:46 Claimco root: meta-data=/dev/md4 isize=512 agcount=4, agsize=122094660 blks Dec 19 22:58:46 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:58:46 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:58:46 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:58:46 Claimco root: data = bsize=4096 blocks=488378638, imaxpct=5 Dec 19 22:58:46 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:58:46 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:58:46 Claimco root: log =internal log bsize=4096 blocks=238466, version=2 Dec 19 22:58:46 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:58:46 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:58:46 Claimco emhttpd: shcmd (400): mkdir -p /mnt/disk5 Dec 19 22:58:46 Claimco emhttpd: shcmd (401): mount -t xfs -o noatime,nouuid /dev/md5 /mnt/disk5 Dec 19 22:58:46 Claimco kernel: XFS (md5): Mounting V5 Filesystem Dec 19 22:58:46 Claimco kernel: XFS (md5): Ending clean mount Dec 19 22:58:46 Claimco emhttpd: shcmd (402): xfs_growfs /mnt/disk5 Dec 19 22:58:46 Claimco root: meta-data=/dev/md5 isize=512 agcount=8, agsize=61047660 blks Dec 19 22:58:46 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:58:46 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:58:46 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:58:46 Claimco root: data = bsize=4096 blocks=488378638, imaxpct=25 Dec 19 22:58:46 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:58:46 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:58:46 Claimco root: log =internal log bsize=4096 blocks=119233, version=2 Dec 19 22:58:46 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:58:46 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:58:46 Claimco emhttpd: shcmd (403): mkdir -p /mnt/disk6 Dec 19 22:58:46 Claimco emhttpd: shcmd (404): mount -t xfs -o noatime,nouuid /dev/md6 /mnt/disk6 Dec 19 22:58:46 Claimco kernel: XFS (md6): Mounting V5 Filesystem Dec 19 22:58:46 Claimco kernel: XFS (md6): Ending clean mount Dec 19 22:58:46 Claimco emhttpd: shcmd (405): xfs_growfs /mnt/disk6 Dec 19 22:58:46 Claimco root: meta-data=/dev/md6 isize=512 agcount=4, agsize=244188659 blks Dec 19 22:58:46 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:58:46 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:58:46 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:58:46 Claimco root: data = bsize=4096 blocks=976754633, imaxpct=5 Dec 19 22:58:46 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:58:46 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:58:46 Claimco root: log =internal log bsize=4096 blocks=476930, version=2 Dec 19 22:58:46 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:58:46 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:58:46 Claimco emhttpd: shcmd (406): mkdir -p /mnt/disk7 Dec 19 22:58:46 Claimco emhttpd: shcmd (407): mount -t xfs -o noatime,nouuid /dev/md7 /mnt/disk7 Dec 19 22:58:46 Claimco kernel: XFS (md7): Mounting V5 Filesystem Dec 19 22:58:47 Claimco kernel: XFS (md7): Ending clean mount Dec 19 22:58:47 Claimco emhttpd: shcmd (408): xfs_growfs /mnt/disk7 Dec 19 22:58:47 Claimco root: meta-data=/dev/md7 isize=512 agcount=4, agsize=244188659 blks Dec 19 22:58:47 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:58:47 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:58:47 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:58:47 Claimco root: data = bsize=4096 blocks=976754633, imaxpct=5 Dec 19 22:58:47 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:58:47 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:58:47 Claimco root: log =internal log bsize=4096 blocks=476930, version=2 Dec 19 22:58:47 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:58:47 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:58:47 Claimco emhttpd: shcmd (409): mkdir -p /mnt/disk8 Dec 19 22:58:47 Claimco emhttpd: shcmd (410): mount -t xfs -o noatime,nouuid /dev/md8 /mnt/disk8 Dec 19 22:58:47 Claimco kernel: XFS (md8): Mounting V5 Filesystem Dec 19 22:58:47 Claimco kernel: XFS (md8): Ending clean mount Dec 19 22:58:47 Claimco emhttpd: shcmd (411): xfs_growfs /mnt/disk8 Dec 19 22:58:47 Claimco root: meta-data=/dev/md8 isize=512 agcount=4, agsize=39070740 blks Dec 19 22:58:47 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:58:47 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:58:47 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:58:47 Claimco root: data = bsize=4096 blocks=156282958, imaxpct=25 Dec 19 22:58:47 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:58:47 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:58:47 Claimco root: log =internal log bsize=4096 blocks=76310, version=2 Dec 19 22:58:47 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:58:47 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:58:47 Claimco emhttpd: shcmd (412): mkdir -p /mnt/disk9 Dec 19 22:58:47 Claimco emhttpd: shcmd (413): mount -t xfs -o noatime,nouuid /dev/md9 /mnt/disk9 Dec 19 22:58:47 Claimco kernel: XFS (md9): Mounting V5 Filesystem Dec 19 22:58:47 Claimco kernel: XFS (md9): Ending clean mount Dec 19 22:58:47 Claimco emhttpd: shcmd (414): xfs_growfs /mnt/disk9 Dec 19 22:58:47 Claimco root: meta-data=/dev/md9 isize=512 agcount=4, agsize=244188659 blks Dec 19 22:58:47 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:58:47 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:58:47 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:58:47 Claimco root: data = bsize=4096 blocks=976754633, imaxpct=5 Dec 19 22:58:47 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:58:47 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:58:47 Claimco root: log =internal log bsize=4096 blocks=476930, version=2 Dec 19 22:58:47 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:58:47 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:58:47 Claimco emhttpd: shcmd (415): mkdir -p /mnt/cache Dec 19 22:58:48 Claimco emhttpd: shcmd (416): mount -t btrfs -o noatime,space_cache=v2 /dev/nvme0n1p1 /mnt/cache Dec 19 22:58:48 Claimco kernel: BTRFS info (device nvme0n1p1): using free space tree Dec 19 22:58:48 Claimco kernel: BTRFS info (device nvme0n1p1): has skinny extents Dec 19 22:58:48 Claimco kernel: BTRFS info (device nvme0n1p1): enabling ssd optimizations Dec 19 22:58:48 Claimco emhttpd: shcmd (417): sync Dec 19 22:58:48 Claimco emhttpd: shcmd (418): mkdir /mnt/user0 Dec 19 22:58:48 Claimco emhttpd: shcmd (419): /usr/local/sbin/shfs /mnt/user0 -disks 1022 -o default_permissions,allow_other,noatime |& logger Dec 19 22:58:48 Claimco emhttpd: shcmd (420): mkdir /mnt/user Dec 19 22:58:48 Claimco emhttpd: shcmd (421): /usr/local/sbin/shfs /mnt/user -disks 1023 -o default_permissions,allow_other,noatime -o remember=0 |& logger Dec 19 22:58:49 Claimco emhttpd: shcmd (423): /usr/local/sbin/update_cron Dec 19 22:58:49 Claimco ProFTPd: Running mountscript.sh... Dec 19 22:58:49 Claimco emhttpd: Renewing userjail... Dec 19 22:58:50 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:58:50 Claimco emhttpd: ...OK Dec 19 22:58:51 Claimco emhttpd: Starting ProFTPd... Dec 19 22:58:52 Claimco sudo: root : PWD=/ ; USER=root ; COMMAND=/usr/local/SlrG-Common/usr/local/sbin/proftpd -c /etc/proftpd.conf Dec 19 22:58:52 Claimco sudo: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0) Dec 19 22:58:52 Claimco proftpd[19473]: 127.0.0.1 - ProFTPD 1.3.7a (maint) (built Thu Feb 18 2021 00:42:08 CET) standalone mode STARTUP Dec 19 22:58:52 Claimco sudo: pam_unix(sudo:session): session closed for user root Dec 19 22:58:53 Claimco emhttpd: ...OK Dec 19 22:58:53 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:58:54 Claimco root: Starting CA Auto Turbo Mode Dec 19 22:58:54 Claimco root: Delaying execution of fix common problems scan for 10 minutes Dec 19 22:58:54 Claimco Recycle Bin: Starting Recycle Bin Dec 19 22:58:54 Claimco emhttpd: Starting Recycle Bin... Dec 19 22:58:54 Claimco kernel: mdcmd (36): set md_write_method 1 Dec 19 22:58:54 Claimco kernel: Dec 19 22:58:54 Claimco wsdd2[17172]: 'Terminated' signal received. Dec 19 22:58:54 Claimco wsdd2[17172]: terminating. Dec 19 22:58:54 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 22:58:56 Claimco wsdd2[19742]: starting. Dec 19 22:58:56 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 22:58:57 Claimco unassigned.devices: Mounting 'Auto Mount' Devices... Dec 19 22:58:57 Claimco unassigned.devices: Disk with ID 'APPLE_HDD_ST2000DM001_Z8E0AL3H (sdj)' is not set to auto mount. Dec 19 22:58:57 Claimco emhttpd: Starting services... Dec 19 22:58:57 Claimco emhttpd: shcmd (425): /etc/rc.d/rc.samba restart Dec 19 22:58:57 Claimco wsdd2[19742]: 'Terminated' signal received. Dec 19 22:58:57 Claimco wsdd2[19742]: terminating. Dec 19 22:58:57 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 22:58:59 Claimco root: Starting Samba: /usr/sbin/smbd -D Dec 19 22:58:59 Claimco root: /usr/sbin/wsdd2 -d Dec 19 22:58:59 Claimco wsdd2[19963]: starting. Dec 19 22:58:59 Claimco root: /usr/sbin/winbindd -D Dec 19 22:58:59 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 22:58:59 Claimco emhttpd: shcmd (429): /etc/rc.d/rc.avahidaemon restart Dec 19 22:58:59 Claimco root: Stopping Avahi mDNS/DNS-SD Daemon: stopped Dec 19 22:58:59 Claimco avahi-daemon[17206]: Got SIGTERM, quitting. Dec 19 22:58:59 Claimco avahi-dnsconfd[17220]: read(): EOF Dec 19 22:58:59 Claimco avahi-daemon[17206]: Leaving mDNS multicast group on interface br0.IPv4 with address 192.168.1.233. Dec 19 22:58:59 Claimco avahi-daemon[17206]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1. Dec 19 22:58:59 Claimco avahi-daemon[17206]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Dec 19 22:58:59 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 22:58:59 Claimco avahi-daemon[17206]: avahi-daemon 0.8 exiting. Dec 19 22:58:59 Claimco root: Starting Avahi mDNS/DNS-SD Daemon: /usr/sbin/avahi-daemon -D Dec 19 22:58:59 Claimco avahi-daemon[19983]: Found user 'avahi' (UID 61) and group 'avahi' (GID 214). Dec 19 22:58:59 Claimco avahi-daemon[19983]: Successfully dropped root privileges. Dec 19 22:58:59 Claimco avahi-daemon[19983]: avahi-daemon 0.8 starting up. Dec 19 22:58:59 Claimco avahi-daemon[19983]: Successfully called chroot(). Dec 19 22:58:59 Claimco avahi-daemon[19983]: Successfully dropped remaining capabilities. Dec 19 22:58:59 Claimco avahi-daemon[19983]: Loading service file /services/sftp-ssh.service. Dec 19 22:58:59 Claimco avahi-daemon[19983]: Loading service file /services/smb.service. Dec 19 22:58:59 Claimco avahi-daemon[19983]: Loading service file /services/ssh.service. Dec 19 22:58:59 Claimco avahi-daemon[19983]: Joining mDNS multicast group on interface br0.IPv4 with address 192.168.1.233. Dec 19 22:58:59 Claimco avahi-daemon[19983]: New relevant interface br0.IPv4 for mDNS. Dec 19 22:58:59 Claimco avahi-daemon[19983]: Joining mDNS multicast group on interface lo.IPv6 with address ::1. Dec 19 22:58:59 Claimco avahi-daemon[19983]: New relevant interface lo.IPv6 for mDNS. Dec 19 22:58:59 Claimco avahi-daemon[19983]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Dec 19 22:58:59 Claimco avahi-daemon[19983]: New relevant interface lo.IPv4 for mDNS. Dec 19 22:58:59 Claimco avahi-daemon[19983]: Network interface enumeration completed. Dec 19 22:58:59 Claimco avahi-daemon[19983]: Registering new address record for 192.168.1.233 on br0.IPv4. Dec 19 22:58:59 Claimco avahi-daemon[19983]: Registering new address record for ::1 on lo.*. Dec 19 22:58:59 Claimco avahi-daemon[19983]: Registering new address record for 127.0.0.1 on lo.IPv4. Dec 19 22:58:59 Claimco emhttpd: shcmd (430): /etc/rc.d/rc.avahidnsconfd restart Dec 19 22:58:59 Claimco root: Stopping Avahi mDNS/DNS-SD DNS Server Configuration Daemon: stopped Dec 19 22:58:59 Claimco root: Starting Avahi mDNS/DNS-SD DNS Server Configuration Daemon: /usr/sbin/avahi-dnsconfd -D Dec 19 22:58:59 Claimco avahi-dnsconfd[19992]: Successfully connected to Avahi daemon. Dec 19 22:58:59 Claimco emhttpd: shcmd (446): /usr/local/sbin/mount_image '/mnt/user/system/libvirt/libvirt.img' /etc/libvirt 1 Dec 19 22:59:00 Claimco kernel: loop2: detected capacity change from 0 to 2097152 Dec 19 22:59:00 Claimco kernel: BTRFS info (device loop2): using free space tree Dec 19 22:59:00 Claimco kernel: BTRFS info (device loop2): has skinny extents Dec 19 22:59:00 Claimco root: Resize device id 1 (/dev/loop2) from 1.00GiB to max Dec 19 22:59:00 Claimco emhttpd: shcmd (448): /etc/rc.d/rc.libvirt start Dec 19 22:59:00 Claimco root: Starting virtlockd... Dec 19 22:59:00 Claimco root: Starting virtlogd... Dec 19 22:59:00 Claimco root: Starting libvirtd... Dec 19 22:59:00 Claimco kernel: tun: Universal TUN/TAP device driver, 1.6 Dec 19 22:59:00 Claimco emhttpd: nothing to sync Dec 19 22:59:00 Claimco unassigned.devices: Mounting 'Auto Mount' Remote Shares... Dec 19 22:59:00 Claimco avahi-daemon[19983]: Server startup complete. Host name is Claimco.local. Local service cookie is 2807243294. Dec 19 22:59:01 Claimco avahi-daemon[19983]: Service "Claimco" (/services/ssh.service) successfully established. Dec 19 22:59:01 Claimco avahi-daemon[19983]: Service "Claimco" (/services/smb.service) successfully established. Dec 19 22:59:01 Claimco avahi-daemon[19983]: Service "Claimco" (/services/sftp-ssh.service) successfully established. Dec 19 22:59:01 Claimco sshd[20239]: Connection from 61.177.172.104 port 10936 on 192.168.1.233 port 22 rdomain "" Dec 19 22:59:01 Claimco kernel: net_ratelimit: 13 callbacks suppressed Dec 19 22:59:01 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 4 TIMES] ### Dec 19 22:59:05 Claimco unassigned.devices: Remote Share '//CLAIMCO/BM_PA_files' is not set to auto mount. Dec 19 22:59:06 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 22:59:18 Claimco kernel: mdcmd (37): nocheck cancel Dec 19 22:59:19 Claimco emhttpd: Spinning up all drives... Dec 19 22:59:19 Claimco emhttpd: read SMART /dev/sdj Dec 19 22:59:19 Claimco emhttpd: read SMART /dev/sdk Dec 19 22:59:19 Claimco emhttpd: read SMART /dev/sdh Dec 19 22:59:19 Claimco emhttpd: read SMART /dev/sdg Dec 19 22:59:19 Claimco emhttpd: read SMART /dev/sdd Dec 19 22:59:19 Claimco emhttpd: read SMART /dev/sde Dec 19 22:59:19 Claimco emhttpd: read SMART /dev/sdb Dec 19 22:59:19 Claimco emhttpd: read SMART /dev/sdf Dec 19 22:59:19 Claimco emhttpd: read SMART /dev/sdc Dec 19 22:59:19 Claimco emhttpd: read SMART /dev/nvme0n1 Dec 19 22:59:19 Claimco emhttpd: read SMART /dev/sdi Dec 19 22:59:19 Claimco emhttpd: read SMART /dev/sda Dec 19 22:59:19 Claimco emhttpd: Stopping services... Dec 19 22:59:19 Claimco emhttpd: shcmd (451): /etc/rc.d/rc.libvirt stop Dec 19 22:59:19 Claimco root: Stopping libvirtd... Dec 19 22:59:22 Claimco root: Stopping virtlogd... Dec 19 22:59:23 Claimco root: Stopping virtlockd... Dec 19 22:59:24 Claimco emhttpd: shcmd (452): umount /etc/libvirt Dec 19 22:59:24 Claimco root: Stopping CA Turbo Mode Dec 19 22:59:24 Claimco root: Terminating 19506 Dec 19 22:59:24 Claimco Recycle Bin: Stopping Recycle Bin Dec 19 22:59:24 Claimco emhttpd: Stopping Recycle Bin... Dec 19 22:59:25 Claimco unassigned.devices: Unmounting All Devices... Dec 19 22:59:25 Claimco unassigned.devices: Remote SMB/NFS share '//CLAIMCO/BM_PA_files' is not mounted. Dec 19 22:59:25 Claimco emhttpd: shcmd (454): /etc/rc.d/rc.samba stop Dec 19 22:59:25 Claimco wsdd2[19963]: 'Terminated' signal received. Dec 19 22:59:25 Claimco wsdd2[19963]: terminating. Dec 19 22:59:25 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 22:59:26 Claimco emhttpd: shcmd (455): rm -f /etc/avahi/services/smb.service Dec 19 22:59:26 Claimco avahi-daemon[19983]: Files changed, reloading. Dec 19 22:59:26 Claimco avahi-daemon[19983]: Service group file /services/smb.service vanished, removing services. Dec 19 22:59:26 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:59:26 Claimco emhttpd: Stopping mover... Dec 19 22:59:26 Claimco emhttpd: shcmd (457): /usr/local/sbin/mover stop Dec 19 22:59:26 Claimco root: mover: not running Dec 19 22:59:26 Claimco emhttpd: Sync filesystems... Dec 19 22:59:26 Claimco emhttpd: shcmd (458): sync Dec 19 22:59:26 Claimco ProFTPd: Running unmountscript.sh... Dec 19 22:59:26 Claimco emhttpd: Stopping ProFTPd... Dec 19 22:59:26 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:59:27 Claimco proftpd[19473]: 127.0.0.1 - ProFTPD killed (signal 15) Dec 19 22:59:27 Claimco proftpd[19473]: 127.0.0.1 - ProFTPD 1.3.7a standalone mode SHUTDOWN Dec 19 22:59:28 Claimco emhttpd: ... Stop OK Dec 19 22:59:29 Claimco emhttpd: shcmd (459): umount /mnt/user0 Dec 19 22:59:29 Claimco emhttpd: shcmd (460): rmdir /mnt/user0 Dec 19 22:59:29 Claimco emhttpd: shcmd (461): umount /mnt/user Dec 19 22:59:29 Claimco emhttpd: shcmd (462): rmdir /mnt/user Dec 19 22:59:29 Claimco emhttpd: shcmd (464): /usr/local/sbin/update_cron Dec 19 22:59:29 Claimco emhttpd: Unmounting disks... Dec 19 22:59:29 Claimco emhttpd: shcmd (465): umount /mnt/disk1 Dec 19 22:59:29 Claimco kernel: XFS (md1): Unmounting Filesystem Dec 19 22:59:30 Claimco emhttpd: shcmd (466): rmdir /mnt/disk1 Dec 19 22:59:30 Claimco emhttpd: shcmd (467): umount /mnt/disk2 Dec 19 22:59:30 Claimco kernel: XFS (md2): Unmounting Filesystem Dec 19 22:59:30 Claimco emhttpd: shcmd (468): rmdir /mnt/disk2 Dec 19 22:59:30 Claimco emhttpd: shcmd (469): umount /mnt/disk3 Dec 19 22:59:30 Claimco kernel: XFS (md3): Unmounting Filesystem Dec 19 22:59:30 Claimco emhttpd: shcmd (470): rmdir /mnt/disk3 Dec 19 22:59:30 Claimco emhttpd: shcmd (471): umount /mnt/disk4 Dec 19 22:59:30 Claimco kernel: XFS (md4): Unmounting Filesystem Dec 19 22:59:30 Claimco emhttpd: shcmd (472): rmdir /mnt/disk4 Dec 19 22:59:30 Claimco emhttpd: shcmd (473): umount /mnt/disk5 Dec 19 22:59:30 Claimco kernel: XFS (md5): Unmounting Filesystem Dec 19 22:59:30 Claimco emhttpd: shcmd (474): rmdir /mnt/disk5 Dec 19 22:59:30 Claimco emhttpd: shcmd (475): umount /mnt/disk6 Dec 19 22:59:30 Claimco kernel: XFS (md6): Unmounting Filesystem Dec 19 22:59:30 Claimco emhttpd: shcmd (476): rmdir /mnt/disk6 Dec 19 22:59:30 Claimco emhttpd: shcmd (477): umount /mnt/disk7 Dec 19 22:59:30 Claimco kernel: XFS (md7): Unmounting Filesystem Dec 19 22:59:30 Claimco emhttpd: shcmd (478): rmdir /mnt/disk7 Dec 19 22:59:30 Claimco emhttpd: shcmd (479): umount /mnt/disk8 Dec 19 22:59:30 Claimco kernel: XFS (md8): Unmounting Filesystem Dec 19 22:59:30 Claimco emhttpd: shcmd (480): rmdir /mnt/disk8 Dec 19 22:59:30 Claimco emhttpd: shcmd (481): umount /mnt/disk9 Dec 19 22:59:30 Claimco kernel: XFS (md9): Unmounting Filesystem Dec 19 22:59:30 Claimco emhttpd: shcmd (482): rmdir /mnt/disk9 Dec 19 22:59:30 Claimco emhttpd: shcmd (483): umount /mnt/cache Dec 19 22:59:30 Claimco emhttpd: shcmd (484): rmdir /mnt/cache Dec 19 22:59:30 Claimco kernel: mdcmd (38): stop Dec 19 22:59:30 Claimco kernel: md1: stopping Dec 19 22:59:30 Claimco kernel: md2: stopping Dec 19 22:59:30 Claimco kernel: md3: stopping Dec 19 22:59:30 Claimco kernel: md4: stopping Dec 19 22:59:30 Claimco kernel: md5: stopping Dec 19 22:59:30 Claimco kernel: md6: stopping Dec 19 22:59:30 Claimco kernel: md7: stopping Dec 19 22:59:30 Claimco kernel: md8: stopping Dec 19 22:59:30 Claimco kernel: md9: stopping Dec 19 22:59:30 Claimco emhttpd: shcmd (486): rm -f /boot/config/forcesync Dec 19 22:59:30 Claimco emhttpd: shcmd (487): sync Dec 19 22:59:30 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:59:31 Claimco emhttpd: Starting services... Dec 19 22:59:31 Claimco emhttpd: shcmd (489): /etc/rc.d/rc.samba start Dec 19 22:59:31 Claimco root: Starting Samba: /usr/sbin/smbd -D Dec 19 22:59:31 Claimco root: /usr/sbin/wsdd2 -d Dec 19 22:59:31 Claimco root: /usr/sbin/winbindd -D Dec 19 22:59:31 Claimco wsdd2[22473]: starting. Dec 19 22:59:31 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 22:59:31 Claimco emhttpd: shcmd (490): cp /tmp/emhttp/smb.service /etc/avahi/services/smb.service Dec 19 22:59:31 Claimco avahi-daemon[19983]: Files changed, reloading. Dec 19 22:59:31 Claimco avahi-daemon[19983]: Loading service file /services/smb.service. Dec 19 22:59:31 Claimco emhttpd: shcmd (493): /etc/rc.d/rc.avahidaemon restart Dec 19 22:59:31 Claimco root: Stopping Avahi mDNS/DNS-SD Daemon: stopped Dec 19 22:59:31 Claimco avahi-daemon[19983]: Got SIGTERM, quitting. Dec 19 22:59:31 Claimco avahi-dnsconfd[19992]: read(): EOF Dec 19 22:59:31 Claimco avahi-daemon[19983]: Leaving mDNS multicast group on interface br0.IPv4 with address 192.168.1.233. Dec 19 22:59:31 Claimco avahi-daemon[19983]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1. Dec 19 22:59:31 Claimco avahi-daemon[19983]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Dec 19 22:59:31 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:59:31 Claimco avahi-daemon[19983]: avahi-daemon 0.8 exiting. Dec 19 22:59:31 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:59:31 Claimco root: Starting Avahi mDNS/DNS-SD Daemon: /usr/sbin/avahi-daemon -D Dec 19 22:59:31 Claimco avahi-daemon[22495]: Found user 'avahi' (UID 61) and group 'avahi' (GID 214). Dec 19 22:59:31 Claimco avahi-daemon[22495]: Successfully dropped root privileges. Dec 19 22:59:31 Claimco avahi-daemon[22495]: avahi-daemon 0.8 starting up. Dec 19 22:59:31 Claimco avahi-daemon[22495]: Successfully called chroot(). Dec 19 22:59:31 Claimco avahi-daemon[22495]: Successfully dropped remaining capabilities. Dec 19 22:59:31 Claimco avahi-daemon[22495]: Loading service file /services/sftp-ssh.service. Dec 19 22:59:31 Claimco avahi-daemon[22495]: Loading service file /services/smb.service. Dec 19 22:59:31 Claimco avahi-daemon[22495]: Loading service file /services/ssh.service. Dec 19 22:59:31 Claimco avahi-daemon[22495]: Joining mDNS multicast group on interface br0.IPv4 with address 192.168.1.233. Dec 19 22:59:31 Claimco avahi-daemon[22495]: New relevant interface br0.IPv4 for mDNS. Dec 19 22:59:31 Claimco avahi-daemon[22495]: Joining mDNS multicast group on interface lo.IPv6 with address ::1. Dec 19 22:59:31 Claimco avahi-daemon[22495]: New relevant interface lo.IPv6 for mDNS. Dec 19 22:59:31 Claimco avahi-daemon[22495]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Dec 19 22:59:31 Claimco avahi-daemon[22495]: New relevant interface lo.IPv4 for mDNS. Dec 19 22:59:31 Claimco avahi-daemon[22495]: Network interface enumeration completed. Dec 19 22:59:31 Claimco avahi-daemon[22495]: Registering new address record for 192.168.1.233 on br0.IPv4. Dec 19 22:59:31 Claimco avahi-daemon[22495]: Registering new address record for ::1 on lo.*. Dec 19 22:59:31 Claimco avahi-daemon[22495]: Registering new address record for 127.0.0.1 on lo.IPv4. Dec 19 22:59:31 Claimco emhttpd: shcmd (494): /etc/rc.d/rc.avahidnsconfd restart Dec 19 22:59:31 Claimco root: Stopping Avahi mDNS/DNS-SD DNS Server Configuration Daemon: stopped Dec 19 22:59:31 Claimco root: Starting Avahi mDNS/DNS-SD DNS Server Configuration Daemon: /usr/sbin/avahi-dnsconfd -D Dec 19 22:59:31 Claimco avahi-dnsconfd[22504]: Successfully connected to Avahi daemon. Dec 19 22:59:31 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:59:31 Claimco emhttpd: no mountpoint along path: /mnt/user/system/libvirt Dec 19 22:59:31 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 19 22:59:32 Claimco avahi-daemon[22495]: Server startup complete. Host name is Claimco.local. Local service cookie is 642220288. Dec 19 22:59:33 Claimco avahi-daemon[22495]: Service "Claimco" (/services/ssh.service) successfully established. Dec 19 22:59:33 Claimco avahi-daemon[22495]: Service "Claimco" (/services/smb.service) successfully established. Dec 19 22:59:33 Claimco avahi-daemon[22495]: Service "Claimco" (/services/sftp-ssh.service) successfully established. Dec 19 22:59:35 Claimco emhttpd: shcmd (507): rmmod md-mod Dec 19 22:59:35 Claimco kernel: md: unRAID driver removed Dec 19 22:59:35 Claimco emhttpd: shcmd (508): modprobe md-mod super=/boot/config/super.dat Dec 19 22:59:35 Claimco kernel: md: unRAID driver 2.9.25 installed Dec 19 22:59:35 Claimco emhttpd: Device inventory: Dec 19 22:59:35 Claimco emhttpd: APPLE_HDD_ST2000DM001_Z8E0AL3H (sdj) 512 3907029168 Dec 19 22:59:35 Claimco emhttpd: ST2000DM001-1CH164_Z1E4ZXL1 (sdk) 512 3907029168 Dec 19 22:59:35 Claimco emhttpd: ST2000DM001-1ER164_Z4Z7FTDQ (sdh) 512 3907029168 Dec 19 22:59:35 Claimco emhttpd: WDC_WD6400AAKS-22A7B2_WD-WMASY5990247 (sdg) 512 1250263728 Dec 19 22:59:35 Claimco emhttpd: ST8000DM004-2CX188_ZR10QKFN (sdd) 512 15628053168 Dec 19 22:59:35 Claimco emhttpd: ST32000542AS_5XW1JRXG (sde) 512 3907029168 Dec 19 22:59:35 Claimco emhttpd: ST32000644NS_9WM55H64 (sdb) 512 3907029168 Dec 19 22:59:35 Claimco emhttpd: ST4000DM004-2U9104_ZTT3YVPM (sdf) 512 7814037168 Dec 19 22:59:35 Claimco emhttpd: WDC_WD4005FZBX-00K5WB0_V3GDVTJG (sdc) 512 7814037168 Dec 19 22:59:35 Claimco emhttpd: INTEL_SSDPEKNU020TZ_BTKA204200RJ2P0C (nvme0n1) 512 4000797360 Dec 19 22:59:35 Claimco emhttpd: WDC_WD4005FZBX-00K5WB0_VBHN4KNF (sdi) 512 7814037168 Dec 19 22:59:35 Claimco emhttpd: Memorex_TRAVELDRIVE_005B_079117160100-0:0 (sda) 512 31277056 Dec 19 22:59:35 Claimco kernel: mdcmd (1): import 0 sdd 64 7814026532 0 ST8000DM004-2CX188_ZR10QKFN Dec 19 22:59:35 Claimco kernel: md: import disk0: (sdd) ST8000DM004-2CX188_ZR10QKFN size: 7814026532 Dec 19 22:59:35 Claimco kernel: mdcmd (2): import 1 sdk 64 1953514552 0 ST2000DM001-1CH164_Z1E4ZXL1 Dec 19 22:59:35 Claimco kernel: md: import disk1: (sdk) ST2000DM001-1CH164_Z1E4ZXL1 size: 1953514552 Dec 19 22:59:35 Claimco kernel: mdcmd (3): import 2 sdh 64 1953514552 0 ST2000DM001-1ER164_Z4Z7FTDQ Dec 19 22:59:35 Claimco kernel: md: import disk2: (sdh) ST2000DM001-1ER164_Z4Z7FTDQ size: 1953514552 Dec 19 22:59:35 Claimco kernel: mdcmd (4): import 3 sde 64 1953514552 0 ST32000542AS_5XW1JRXG Dec 19 22:59:35 Claimco kernel: md: import disk3: (sde) ST32000542AS_5XW1JRXG size: 1953514552 Dec 19 22:59:35 Claimco kernel: mdcmd (5): import 4 sdb 64 1953514552 0 ST32000644NS_9WM55H64 Dec 19 22:59:35 Claimco kernel: md: import disk4: (sdb) ST32000644NS_9WM55H64 size: 1953514552 Dec 19 22:59:35 Claimco kernel: mdcmd (6): import 5 sdj 64 1953514552 0 APPLE_HDD_ST2000DM001_Z8E0AL3H Dec 19 22:59:35 Claimco kernel: md: import disk5: (sdj) APPLE_HDD_ST2000DM001_Z8E0AL3H size: 1953514552 Dec 19 22:59:35 Claimco kernel: md: import_slot: 5 replaced Dec 19 22:59:35 Claimco kernel: mdcmd (7): import 6 sdc 64 3907018532 0 WDC_WD4005FZBX-00K5WB0_V3GDVTJG Dec 19 22:59:35 Claimco kernel: md: import disk6: (sdc) WDC_WD4005FZBX-00K5WB0_V3GDVTJG size: 3907018532 Dec 19 22:59:35 Claimco kernel: mdcmd (8): import 7 sdf 64 3907018532 0 ST4000DM004-2U9104_ZTT3YVPM Dec 19 22:59:35 Claimco kernel: md: import disk7: (sdf) ST4000DM004-2U9104_ZTT3YVPM size: 3907018532 Dec 19 22:59:35 Claimco kernel: mdcmd (9): import 8 sdg 64 625131832 0 WDC_WD6400AAKS-22A7B2_WD-WMASY5990247 Dec 19 22:59:35 Claimco kernel: md: import disk8: (sdg) WDC_WD6400AAKS-22A7B2_WD-WMASY5990247 size: 625131832 Dec 19 22:59:35 Claimco kernel: mdcmd (10): import 9 sdi 64 3907018532 0 WDC_WD4005FZBX-00K5WB0_VBHN4KNF Dec 19 22:59:35 Claimco kernel: md: import disk9: (sdi) WDC_WD4005FZBX-00K5WB0_VBHN4KNF size: 3907018532 Dec 19 22:59:35 Claimco kernel: mdcmd (11): import 10 Dec 19 22:59:35 Claimco kernel: mdcmd (12): import 11 Dec 19 22:59:35 Claimco kernel: mdcmd (13): import 12 Dec 19 22:59:35 Claimco kernel: mdcmd (14): import 13 Dec 19 22:59:35 Claimco kernel: mdcmd (15): import 14 Dec 19 22:59:35 Claimco kernel: mdcmd (16): import 15 Dec 19 22:59:35 Claimco kernel: mdcmd (17): import 16 Dec 19 22:59:35 Claimco kernel: mdcmd (18): import 17 Dec 19 22:59:35 Claimco kernel: mdcmd (19): import 18 Dec 19 22:59:35 Claimco kernel: mdcmd (20): import 19 Dec 19 22:59:35 Claimco kernel: mdcmd (21): import 20 Dec 19 22:59:35 Claimco kernel: mdcmd (22): import 21 Dec 19 22:59:35 Claimco kernel: mdcmd (23): import 22 Dec 19 22:59:35 Claimco kernel: mdcmd (24): import 23 Dec 19 22:59:35 Claimco kernel: mdcmd (25): import 24 Dec 19 22:59:35 Claimco kernel: mdcmd (26): import 25 Dec 19 22:59:35 Claimco kernel: mdcmd (27): import 26 Dec 19 22:59:35 Claimco kernel: mdcmd (28): import 27 Dec 19 22:59:35 Claimco kernel: mdcmd (29): import 28 Dec 19 22:59:35 Claimco kernel: mdcmd (30): import 29 Dec 19 22:59:35 Claimco kernel: md: import_slot: 29 empty Dec 19 22:59:35 Claimco emhttpd: import 30 cache device: (nvme0n1) INTEL_SSDPEKNU020TZ_BTKA204200RJ2P0C Dec 19 22:59:35 Claimco emhttpd: import flash device: sda Dec 19 22:59:35 Claimco emhttpd: read SMART /dev/sdj Dec 19 22:59:35 Claimco emhttpd: read SMART /dev/sdk Dec 19 22:59:35 Claimco emhttpd: read SMART /dev/sdh Dec 19 22:59:35 Claimco emhttpd: read SMART /dev/sdg Dec 19 22:59:35 Claimco emhttpd: read SMART /dev/sdd Dec 19 22:59:35 Claimco emhttpd: read SMART /dev/sde Dec 19 22:59:35 Claimco emhttpd: read SMART /dev/sdb Dec 19 22:59:35 Claimco emhttpd: read SMART /dev/sdf Dec 19 22:59:35 Claimco emhttpd: read SMART /dev/sdc Dec 19 22:59:35 Claimco emhttpd: read SMART /dev/nvme0n1 Dec 19 22:59:35 Claimco emhttpd: read SMART /dev/sdi Dec 19 22:59:35 Claimco emhttpd: read SMART /dev/sda Dec 19 22:59:36 Claimco kernel: net_ratelimit: 11 callbacks suppressed Dec 19 22:59:36 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 22:59:43 Claimco flash_backup: adding task: /usr/local/emhttp/plugins/dynamix.my.servers/scripts/UpdateFlashBackup update Dec 19 22:59:46 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 22:59:54 Claimco emhttpd: shcmd (537): echo 128 > /sys/block/sdd/queue/nr_requests Dec 19 22:59:54 Claimco kernel: mdcmd (31): set md_num_stripes 4096 Dec 19 22:59:54 Claimco kernel: mdcmd (32): set md_queue_limit 80 Dec 19 22:59:54 Claimco kernel: mdcmd (33): set md_sync_limit 32 Dec 19 22:59:54 Claimco kernel: mdcmd (34): set md_write_method 1 Dec 19 22:59:54 Claimco emhttpd: shcmd (538): echo 128 > /sys/block/sdk/queue/nr_requests Dec 19 22:59:54 Claimco emhttpd: shcmd (539): echo 128 > /sys/block/sdh/queue/nr_requests Dec 19 22:59:54 Claimco emhttpd: shcmd (540): echo 128 > /sys/block/sde/queue/nr_requests Dec 19 22:59:54 Claimco emhttpd: shcmd (541): echo 128 > /sys/block/sdb/queue/nr_requests Dec 19 22:59:54 Claimco emhttpd: shcmd (542): echo 128 > /sys/block/sdj/queue/nr_requests Dec 19 22:59:54 Claimco emhttpd: shcmd (543): echo 128 > /sys/block/sdc/queue/nr_requests Dec 19 22:59:54 Claimco emhttpd: shcmd (544): echo 128 > /sys/block/sdf/queue/nr_requests Dec 19 22:59:54 Claimco emhttpd: shcmd (545): echo 128 > /sys/block/sdg/queue/nr_requests Dec 19 22:59:54 Claimco emhttpd: shcmd (546): echo 128 > /sys/block/sdi/queue/nr_requests Dec 19 22:59:54 Claimco kernel: mdcmd (35): start RECON_DISK Dec 19 22:59:54 Claimco kernel: unraid: allocating 181472K for 4096 stripes (11 disks) Dec 19 22:59:54 Claimco kernel: md1: running, size: 1953514552 blocks Dec 19 22:59:54 Claimco kernel: md2: running, size: 1953514552 blocks Dec 19 22:59:54 Claimco kernel: md3: running, size: 1953514552 blocks Dec 19 22:59:54 Claimco kernel: md4: running, size: 1953514552 blocks Dec 19 22:59:54 Claimco kernel: md5: running, size: 1953514552 blocks Dec 19 22:59:54 Claimco kernel: md6: running, size: 3907018532 blocks Dec 19 22:59:54 Claimco kernel: md7: running, size: 3907018532 blocks Dec 19 22:59:54 Claimco kernel: md8: running, size: 625131832 blocks Dec 19 22:59:54 Claimco kernel: md9: running, size: 3907018532 blocks Dec 19 22:59:55 Claimco emhttpd: shcmd (547): udevadm settle Dec 19 22:59:56 Claimco emhttpd: Opening encrypted volumes... Dec 19 22:59:56 Claimco emhttpd: shcmd (548): touch /boot/config/forcesync Dec 19 22:59:56 Claimco emhttpd: Mounting disks... Dec 19 22:59:57 Claimco emhttpd: shcmd (550): mkdir -p /mnt/disk1 Dec 19 22:59:57 Claimco emhttpd: shcmd (551): mount -t xfs -o noatime,nouuid /dev/md1 /mnt/disk1 Dec 19 22:59:57 Claimco kernel: XFS (md1): Mounting V5 Filesystem Dec 19 22:59:57 Claimco kernel: XFS (md1): Ending clean mount Dec 19 22:59:57 Claimco emhttpd: shcmd (552): xfs_growfs /mnt/disk1 Dec 19 22:59:57 Claimco root: meta-data=/dev/md1 isize=512 agcount=4, agsize=122094660 blks Dec 19 22:59:57 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:59:57 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:59:57 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:59:57 Claimco root: data = bsize=4096 blocks=488378638, imaxpct=5 Dec 19 22:59:57 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:59:57 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:59:57 Claimco root: log =internal log bsize=4096 blocks=238466, version=2 Dec 19 22:59:57 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:59:57 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:59:57 Claimco emhttpd: shcmd (553): mkdir -p /mnt/disk2 Dec 19 22:59:57 Claimco emhttpd: shcmd (554): mount -t xfs -o noatime,nouuid /dev/md2 /mnt/disk2 Dec 19 22:59:57 Claimco kernel: XFS (md2): Mounting V5 Filesystem Dec 19 22:59:57 Claimco kernel: XFS (md2): Ending clean mount Dec 19 22:59:57 Claimco emhttpd: shcmd (555): xfs_growfs /mnt/disk2 Dec 19 22:59:57 Claimco root: meta-data=/dev/md2 isize=512 agcount=4, agsize=122094660 blks Dec 19 22:59:57 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:59:57 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:59:57 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:59:57 Claimco root: data = bsize=4096 blocks=488378638, imaxpct=5 Dec 19 22:59:57 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:59:57 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:59:57 Claimco root: log =internal log bsize=4096 blocks=238466, version=2 Dec 19 22:59:57 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:59:57 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:59:57 Claimco emhttpd: shcmd (556): mkdir -p /mnt/disk3 Dec 19 22:59:57 Claimco emhttpd: shcmd (557): mount -t xfs -o noatime,nouuid /dev/md3 /mnt/disk3 Dec 19 22:59:57 Claimco kernel: XFS (md3): Mounting V5 Filesystem Dec 19 22:59:57 Claimco kernel: XFS (md3): Ending clean mount Dec 19 22:59:57 Claimco emhttpd: shcmd (558): xfs_growfs /mnt/disk3 Dec 19 22:59:57 Claimco root: meta-data=/dev/md3 isize=512 agcount=4, agsize=122094660 blks Dec 19 22:59:57 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:59:57 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:59:57 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:59:57 Claimco root: data = bsize=4096 blocks=488378638, imaxpct=5 Dec 19 22:59:57 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:59:57 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:59:57 Claimco root: log =internal log bsize=4096 blocks=238466, version=2 Dec 19 22:59:57 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:59:57 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:59:57 Claimco emhttpd: shcmd (559): mkdir -p /mnt/disk4 Dec 19 22:59:57 Claimco emhttpd: shcmd (560): mount -t xfs -o noatime,nouuid /dev/md4 /mnt/disk4 Dec 19 22:59:57 Claimco kernel: XFS (md4): Mounting V5 Filesystem Dec 19 22:59:58 Claimco kernel: XFS (md4): Ending clean mount Dec 19 22:59:58 Claimco emhttpd: shcmd (561): xfs_growfs /mnt/disk4 Dec 19 22:59:58 Claimco root: meta-data=/dev/md4 isize=512 agcount=4, agsize=122094660 blks Dec 19 22:59:58 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:59:58 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:59:58 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:59:58 Claimco root: data = bsize=4096 blocks=488378638, imaxpct=5 Dec 19 22:59:58 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:59:58 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:59:58 Claimco root: log =internal log bsize=4096 blocks=238466, version=2 Dec 19 22:59:58 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:59:58 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:59:58 Claimco emhttpd: shcmd (562): mkdir -p /mnt/disk5 Dec 19 22:59:58 Claimco emhttpd: shcmd (563): mount -t xfs -o noatime,nouuid /dev/md5 /mnt/disk5 Dec 19 22:59:58 Claimco kernel: XFS (md5): Mounting V5 Filesystem Dec 19 22:59:58 Claimco kernel: XFS (md5): Ending clean mount Dec 19 22:59:58 Claimco emhttpd: shcmd (564): xfs_growfs /mnt/disk5 Dec 19 22:59:58 Claimco root: meta-data=/dev/md5 isize=512 agcount=8, agsize=61047660 blks Dec 19 22:59:58 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:59:58 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:59:58 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:59:58 Claimco root: data = bsize=4096 blocks=488378638, imaxpct=25 Dec 19 22:59:58 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:59:58 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:59:58 Claimco root: log =internal log bsize=4096 blocks=119233, version=2 Dec 19 22:59:58 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:59:58 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:59:58 Claimco emhttpd: shcmd (565): mkdir -p /mnt/disk6 Dec 19 22:59:58 Claimco emhttpd: shcmd (566): mount -t xfs -o noatime,nouuid /dev/md6 /mnt/disk6 Dec 19 22:59:58 Claimco kernel: XFS (md6): Mounting V5 Filesystem Dec 19 22:59:58 Claimco kernel: XFS (md6): Ending clean mount Dec 19 22:59:58 Claimco emhttpd: shcmd (567): xfs_growfs /mnt/disk6 Dec 19 22:59:58 Claimco root: meta-data=/dev/md6 isize=512 agcount=4, agsize=244188659 blks Dec 19 22:59:58 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:59:58 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:59:58 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:59:58 Claimco root: data = bsize=4096 blocks=976754633, imaxpct=5 Dec 19 22:59:58 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:59:58 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:59:58 Claimco root: log =internal log bsize=4096 blocks=476930, version=2 Dec 19 22:59:58 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:59:58 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:59:58 Claimco emhttpd: shcmd (568): mkdir -p /mnt/disk7 Dec 19 22:59:58 Claimco emhttpd: shcmd (569): mount -t xfs -o noatime,nouuid /dev/md7 /mnt/disk7 Dec 19 22:59:58 Claimco kernel: XFS (md7): Mounting V5 Filesystem Dec 19 22:59:58 Claimco emhttpd: shcmd (570): xfs_growfs /mnt/disk7 Dec 19 22:59:58 Claimco kernel: XFS (md7): Ending clean mount Dec 19 22:59:58 Claimco root: meta-data=/dev/md7 isize=512 agcount=4, agsize=244188659 blks Dec 19 22:59:58 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:59:58 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:59:58 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:59:58 Claimco root: data = bsize=4096 blocks=976754633, imaxpct=5 Dec 19 22:59:58 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:59:58 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:59:58 Claimco root: log =internal log bsize=4096 blocks=476930, version=2 Dec 19 22:59:58 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:59:58 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:59:58 Claimco emhttpd: shcmd (571): mkdir -p /mnt/disk8 Dec 19 22:59:58 Claimco emhttpd: shcmd (572): mount -t xfs -o noatime,nouuid /dev/md8 /mnt/disk8 Dec 19 22:59:58 Claimco kernel: XFS (md8): Mounting V5 Filesystem Dec 19 22:59:59 Claimco kernel: XFS (md8): Ending clean mount Dec 19 22:59:59 Claimco emhttpd: shcmd (573): xfs_growfs /mnt/disk8 Dec 19 22:59:59 Claimco root: meta-data=/dev/md8 isize=512 agcount=4, agsize=39070740 blks Dec 19 22:59:59 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:59:59 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:59:59 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:59:59 Claimco root: data = bsize=4096 blocks=156282958, imaxpct=25 Dec 19 22:59:59 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:59:59 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:59:59 Claimco root: log =internal log bsize=4096 blocks=76310, version=2 Dec 19 22:59:59 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:59:59 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:59:59 Claimco emhttpd: shcmd (574): mkdir -p /mnt/disk9 Dec 19 22:59:59 Claimco emhttpd: shcmd (575): mount -t xfs -o noatime,nouuid /dev/md9 /mnt/disk9 Dec 19 22:59:59 Claimco kernel: XFS (md9): Mounting V5 Filesystem Dec 19 22:59:59 Claimco kernel: XFS (md9): Ending clean mount Dec 19 22:59:59 Claimco emhttpd: shcmd (576): xfs_growfs /mnt/disk9 Dec 19 22:59:59 Claimco root: meta-data=/dev/md9 isize=512 agcount=4, agsize=244188659 blks Dec 19 22:59:59 Claimco root: = sectsz=512 attr=2, projid32bit=1 Dec 19 22:59:59 Claimco root: = crc=1 finobt=1, sparse=1, rmapbt=0 Dec 19 22:59:59 Claimco root: = reflink=1 bigtime=1 inobtcount=1 Dec 19 22:59:59 Claimco root: data = bsize=4096 blocks=976754633, imaxpct=5 Dec 19 22:59:59 Claimco root: = sunit=0 swidth=0 blks Dec 19 22:59:59 Claimco root: naming =version 2 bsize=4096 ascii-ci=0, ftype=1 Dec 19 22:59:59 Claimco root: log =internal log bsize=4096 blocks=476930, version=2 Dec 19 22:59:59 Claimco root: = sectsz=512 sunit=0 blks, lazy-count=1 Dec 19 22:59:59 Claimco root: realtime =none extsz=4096 blocks=0, rtextents=0 Dec 19 22:59:59 Claimco emhttpd: shcmd (577): mkdir -p /mnt/cache Dec 19 23:00:00 Claimco emhttpd: shcmd (578): mount -t btrfs -o noatime,space_cache=v2 /dev/nvme0n1p1 /mnt/cache Dec 19 23:00:00 Claimco kernel: BTRFS info (device nvme0n1p1): using free space tree Dec 19 23:00:00 Claimco kernel: BTRFS info (device nvme0n1p1): has skinny extents Dec 19 23:00:00 Claimco kernel: BTRFS info (device nvme0n1p1): enabling ssd optimizations Dec 19 23:00:00 Claimco emhttpd: shcmd (579): sync Dec 19 23:00:00 Claimco emhttpd: shcmd (580): mkdir /mnt/user0 Dec 19 23:00:00 Claimco emhttpd: shcmd (581): /usr/local/sbin/shfs /mnt/user0 -disks 1022 -o default_permissions,allow_other,noatime |& logger Dec 19 23:00:00 Claimco emhttpd: shcmd (582): mkdir /mnt/user Dec 19 23:00:00 Claimco emhttpd: shcmd (583): /usr/local/sbin/shfs /mnt/user -disks 1023 -o default_permissions,allow_other,noatime -o remember=0 |& logger Dec 19 23:00:01 Claimco emhttpd: shcmd (585): /usr/local/sbin/update_cron Dec 19 23:00:01 Claimco ProFTPd: Running mountscript.sh... Dec 19 23:00:01 Claimco emhttpd: Renewing userjail... Dec 19 23:00:02 Claimco emhttpd: ...OK Dec 19 23:00:02 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 23:00:03 Claimco emhttpd: Starting ProFTPd... Dec 19 23:00:04 Claimco sudo: root : PWD=/ ; USER=root ; COMMAND=/usr/local/SlrG-Common/usr/local/sbin/proftpd -c /etc/proftpd.conf Dec 19 23:00:04 Claimco sudo: pam_unix(sudo:session): session opened for user root(uid=0) by (uid=0) Dec 19 23:00:04 Claimco proftpd[24275]: 127.0.0.1 - ProFTPD 1.3.7a (maint) (built Thu Feb 18 2021 00:42:08 CET) standalone mode STARTUP Dec 19 23:00:04 Claimco sudo: pam_unix(sudo:session): session closed for user root Dec 19 23:00:05 Claimco emhttpd: ...OK Dec 19 23:00:06 Claimco root: Starting CA Auto Turbo Mode Dec 19 23:00:06 Claimco root: Delaying execution of fix common problems scan for 10 minutes Dec 19 23:00:06 Claimco Recycle Bin: Starting Recycle Bin Dec 19 23:00:06 Claimco emhttpd: Starting Recycle Bin... Dec 19 23:00:06 Claimco kernel: mdcmd (36): set md_write_method 1 Dec 19 23:00:06 Claimco kernel: Dec 19 23:00:06 Claimco wsdd2[22473]: 'Terminated' signal received. Dec 19 23:00:06 Claimco wsdd2[22473]: terminating. Dec 19 23:00:06 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 23:00:10 Claimco wsdd2[24649]: starting. Dec 19 23:00:10 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 3 TIMES] ### Dec 19 23:00:11 Claimco unassigned.devices: Mounting 'Auto Mount' Devices... Dec 19 23:00:11 Claimco emhttpd: Starting services... Dec 19 23:00:11 Claimco emhttpd: shcmd (587): /etc/rc.d/rc.samba restart Dec 19 23:00:11 Claimco wsdd2[24649]: 'Terminated' signal received. Dec 19 23:00:11 Claimco wsdd2[24649]: terminating. Dec 19 23:00:11 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 23:00:14 Claimco root: Starting Samba: /usr/sbin/smbd -D Dec 19 23:00:14 Claimco root: /usr/sbin/wsdd2 -d Dec 19 23:00:14 Claimco wsdd2[24957]: starting. Dec 19 23:00:14 Claimco root: /usr/sbin/winbindd -D Dec 19 23:00:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 23:00:14 Claimco emhttpd: shcmd (591): /etc/rc.d/rc.avahidaemon restart Dec 19 23:00:14 Claimco root: Stopping Avahi mDNS/DNS-SD Daemon: stopped Dec 19 23:00:14 Claimco avahi-daemon[22495]: Got SIGTERM, quitting. Dec 19 23:00:14 Claimco avahi-dnsconfd[22504]: read(): EOF Dec 19 23:00:14 Claimco avahi-daemon[22495]: Leaving mDNS multicast group on interface br0.IPv4 with address 192.168.1.233. Dec 19 23:00:14 Claimco avahi-daemon[22495]: Leaving mDNS multicast group on interface lo.IPv6 with address ::1. Dec 19 23:00:14 Claimco avahi-daemon[22495]: Leaving mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Dec 19 23:00:14 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 23:00:14 Claimco avahi-daemon[22495]: avahi-daemon 0.8 exiting. Dec 19 23:00:14 Claimco root: Starting Avahi mDNS/DNS-SD Daemon: /usr/sbin/avahi-daemon -D Dec 19 23:00:14 Claimco avahi-daemon[24980]: Found user 'avahi' (UID 61) and group 'avahi' (GID 214). Dec 19 23:00:14 Claimco avahi-daemon[24980]: Successfully dropped root privileges. Dec 19 23:00:14 Claimco avahi-daemon[24980]: avahi-daemon 0.8 starting up. Dec 19 23:00:14 Claimco avahi-daemon[24980]: Successfully called chroot(). Dec 19 23:00:14 Claimco avahi-daemon[24980]: Successfully dropped remaining capabilities. Dec 19 23:00:14 Claimco avahi-daemon[24980]: Loading service file /services/sftp-ssh.service. Dec 19 23:00:14 Claimco avahi-daemon[24980]: Loading service file /services/smb.service. Dec 19 23:00:14 Claimco avahi-daemon[24980]: Loading service file /services/ssh.service. Dec 19 23:00:14 Claimco avahi-daemon[24980]: Joining mDNS multicast group on interface br0.IPv4 with address 192.168.1.233. Dec 19 23:00:14 Claimco avahi-daemon[24980]: New relevant interface br0.IPv4 for mDNS. Dec 19 23:00:14 Claimco avahi-daemon[24980]: Joining mDNS multicast group on interface lo.IPv6 with address ::1. Dec 19 23:00:14 Claimco avahi-daemon[24980]: New relevant interface lo.IPv6 for mDNS. Dec 19 23:00:14 Claimco avahi-daemon[24980]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1. Dec 19 23:00:14 Claimco avahi-daemon[24980]: New relevant interface lo.IPv4 for mDNS. Dec 19 23:00:14 Claimco avahi-daemon[24980]: Network interface enumeration completed. Dec 19 23:00:14 Claimco avahi-daemon[24980]: Registering new address record for 192.168.1.233 on br0.IPv4. Dec 19 23:00:14 Claimco avahi-daemon[24980]: Registering new address record for ::1 on lo.*. Dec 19 23:00:14 Claimco avahi-daemon[24980]: Registering new address record for 127.0.0.1 on lo.IPv4. Dec 19 23:00:14 Claimco emhttpd: shcmd (592): /etc/rc.d/rc.avahidnsconfd restart Dec 19 23:00:14 Claimco root: Stopping Avahi mDNS/DNS-SD DNS Server Configuration Daemon: stopped Dec 19 23:00:14 Claimco root: Starting Avahi mDNS/DNS-SD DNS Server Configuration Daemon: /usr/sbin/avahi-dnsconfd -D Dec 19 23:00:14 Claimco avahi-dnsconfd[24989]: Successfully connected to Avahi daemon. Dec 19 23:00:14 Claimco emhttpd: shcmd (608): /usr/local/sbin/mount_image '/mnt/user/system/libvirt/libvirt.img' /etc/libvirt 1 Dec 19 23:00:14 Claimco kernel: loop2: detected capacity change from 0 to 2097152 Dec 19 23:00:14 Claimco kernel: BTRFS info (device loop2): using free space tree Dec 19 23:00:14 Claimco kernel: BTRFS info (device loop2): has skinny extents Dec 19 23:00:14 Claimco root: Resize device id 1 (/dev/loop2) from 1.00GiB to max Dec 19 23:00:14 Claimco emhttpd: shcmd (610): /etc/rc.d/rc.libvirt start Dec 19 23:00:14 Claimco root: Starting virtlockd... Dec 19 23:00:14 Claimco root: Starting virtlogd... Dec 19 23:00:14 Claimco root: Starting libvirtd... Dec 19 23:00:14 Claimco kernel: tun: Universal TUN/TAP device driver, 1.6 Dec 19 23:00:14 Claimco kernel: mdcmd (37): check Dec 19 23:00:14 Claimco kernel: md: recovery thread: recon D5 ... Dec 19 23:00:15 Claimco avahi-daemon[24980]: Server startup complete. Host name is Claimco.local. Local service cookie is 3469965696. Dec 19 23:00:15 Claimco kernel: net_ratelimit: 11 callbacks suppressed Dec 19 23:00:15 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 23:00:16 Claimco avahi-daemon[24980]: Service "Claimco" (/services/ssh.service) successfully established. Dec 19 23:00:16 Claimco avahi-daemon[24980]: Service "Claimco" (/services/smb.service) successfully established. Dec 19 23:00:16 Claimco avahi-daemon[24980]: Service "Claimco" (/services/sftp-ssh.service) successfully established. Dec 19 23:00:16 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 23:00:16 Claimco unassigned.devices: Mounting 'Auto Mount' Remote Shares... Dec 19 23:00:17 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 4 TIMES] ### Dec 19 23:00:21 Claimco unassigned.devices: Remote Share '//CLAIMCO/BM_PA_files' is not set to auto mount. Dec 19 23:00:29 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 23:00:43 Claimco flash_backup: adding task: /usr/local/emhttp/plugins/dynamix.my.servers/scripts/UpdateFlashBackup update Dec 19 23:00:45 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 23:01:01 Claimco sshd[20239]: fatal: Timeout before authentication for 61.177.172.104 port 10936 Dec 19 23:01:17 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 23:01:21 Claimco sshd[27675]: Connection from 61.177.172.114 port 33764 on 192.168.1.233 port 22 rdomain "" Dec 19 23:01:27 Claimco sshd[27861]: Connection from 61.177.172.98 port 43093 on 192.168.1.233 port 22 rdomain "" Dec 19 23:01:31 Claimco sshd[27861]: Received disconnect from 61.177.172.98 port 43093:11: [preauth] Dec 19 23:01:31 Claimco sshd[27861]: Disconnected from 61.177.172.98 port 43093 [preauth] Dec 19 23:01:51 Claimco sshd[28528]: Connection from 61.177.173.46 port 58652 on 192.168.1.233 port 22 rdomain "" Dec 19 23:01:52 Claimco sshd[28528]: Received disconnect from 61.177.173.46 port 58652:11: [preauth] Dec 19 23:01:52 Claimco sshd[28528]: Disconnected from 61.177.173.46 port 58652 [preauth] Dec 19 23:02:21 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 23:03:21 Claimco sshd[27675]: fatal: Timeout before authentication for 61.177.172.114 port 33764 Dec 19 23:03:32 Claimco unassigned.devices: Mounting Remote Share '//CLAIMCO/BM_PA_files'... Dec 19 23:03:32 Claimco unassigned.devices: Mount SMB share '//CLAIMCO/BM_PA_files' using SMB default protocol. Dec 19 23:03:32 Claimco unassigned.devices: Mount SMB command: /sbin/mount -t 'cifs' -o rw,noserverino,nounix,iocharset=utf8,file_mode=0777,dir_mode=0777,uid=99,gid=100,credentials='/tmp/unassigned.devices/credentials_BM_PA_files' '//CLAIMCO/BM_PA_files' '/mnt/remotes/CLAIMCO_BM_PA_files' Dec 19 23:03:32 Claimco kernel: CIFS: Attempting to mount \\CLAIMCO\BM_PA_files Dec 19 23:03:32 Claimco unassigned.devices: Successfully mounted '//CLAIMCO/BM_PA_files' on '/mnt/remotes/CLAIMCO_BM_PA_files'. Dec 19 23:03:32 Claimco unassigned.devices: Adding SMB share 'CLAIMCO_BM_PA_files'. Dec 19 23:03:32 Claimco unassigned.devices: Running device script: 'CLAIMCO_BM_PA_files.sh' with action 'ADD'. Dec 19 23:03:42 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 23:04:25 Claimco sshd[1024]: Connection from 61.177.172.76 port 3812 on 192.168.1.233 port 22 rdomain "" Dec 19 23:04:29 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 23:04:41 Claimco emhttpd: shcmd (614): /usr/local/sbin/update_cron Dec 19 23:04:43 Claimco flash_backup: adding task: /usr/local/emhttp/plugins/dynamix.my.servers/scripts/UpdateFlashBackup update Dec 19 23:05:03 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 23:06:25 Claimco sshd[1024]: fatal: Timeout before authentication for 61.177.172.76 port 3812 Dec 19 23:06:29 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 1 TIMES] ### Dec 19 23:08:00 Claimco root: Fix Common Problems Version 2022.12.18 Dec 19 23:08:07 Claimco root: Fix Common Problems: Error: Possible Hack Attempt on Dec 19 Dec 19 23:08:17 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) Dec 19 23:08:38 Claimco sshd[9475]: Connection from 61.177.173.36 port 13713 on 192.168.1.233 port 22 rdomain "" Dec 19 23:08:39 Claimco sshd[9475]: Received disconnect from 61.177.173.36 port 13713:11: [preauth] Dec 19 23:08:39 Claimco sshd[9475]: Disconnected from 61.177.173.36 port 13713 [preauth] Dec 19 23:08:45 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0) ### [PREVIOUS LINE REPEATED 2 TIMES] ### Dec 19 23:09:27 Claimco sshd[10961]: Connection from 61.177.173.49 port 59716 on 192.168.1.233 port 22 rdomain "" Dec 19 23:09:30 Claimco sshd[10961]: Received disconnect from 61.177.173.49 port 59716:11: [preauth] Dec 19 23:09:30 Claimco sshd[10961]: Disconnected from 61.177.173.49 port 59716 [preauth] Dec 19 23:10:00 Claimco root: Fix Common Problems Version 2022.12.18 Dec 19 23:10:02 Claimco sshd[12042]: Connection from 61.177.173.37 port 30745 on 192.168.1.233 port 22 rdomain "" Dec 19 23:10:02 Claimco root: Fix Common Problems: Error: Possible Hack Attempt on Dec 19 Dec 19 23:10:04 Claimco sshd[12042]: Received disconnect from 61.177.173.37 port 30745:11: [preauth] Dec 19 23:10:04 Claimco sshd[12042]: Disconnected from 61.177.173.37 port 30745 [preauth] Dec 19 23:10:34 Claimco kernel: br0: received packet on bond0 with own address as source address (addr:d0:50:99:5a:1b:96, vlan:0)
December 20, 20223 yr Author Yeah. You have multiple attempts to log in, Probably because you've forwarded the SSH port to be wide open to the internet or have the server within the router's DMZ. You should be using a VPN / reverse proxy (ie: MyServers) if you need to access your system remotely
December 20, 20223 yr 6 hours ago, Claimco file server said: More Information Since this was your first post, some advice about using the forum. Please don't post syslog snippets as a wall of text. Best thing is to post your diagnostics as a single attachment. Diagnostics is already a single zip file. When you get your diagnostics, find that single zip file wherever your browser saves downloads, and attach it. DO NOT post each file in the zip separately. If you need to post anything else, unless it is something you type in yourself, we prefer plain text, zipped if long, or screenshots (not photos).
December 20, 20223 yr 6 hours ago, Claimco file server said: It is not recommended under any circumstance to ignore this error @Claimco file server Please let us know you have fixed this very serious problem. You are getting hacked from around the world. You must not put your server on the internet, it is full of bots that will automatically and relentlessly try to get in. https://www.abuseipdb.com/check/61.177.173.43 China https://www.abuseipdb.com/check/172.104.11.4 USA https://www.abuseipdb.com/check/61.177.173.55 China https://www.abuseipdb.com/check/92.46.108.20 Kazakhstan https://www.abuseipdb.com/check/61.177.172.61 China https://www.abuseipdb.com/check/84.110.99.202 Israel https://www.abuseipdb.com/check/141.98.11.30 Lithuania https://www.abuseipdb.com/check/65.2.28.105 India and many, many more. Until you take action it will continue.
December 20, 20223 yr I have accidently added my media folder the the excluded list for the Docker Safe Perms is there a way to remove it?
December 24, 20223 yr 7xl-diagnostics-20221224-1421.zip Hi! I can't check updates of plagins and docker and os update. Aslo my servers is offline. Changing dns didn't help. Apps appeared after dns change. Edited December 24, 20223 yr by lutili
December 24, 20223 yr Author 11 minutes ago, lutili said: Apps appeared after dns change. Are you saying that the "Apps" page will work after you made the change? (And even after a reboot?) If so, there is nothing fundamentally wrong with the system as a whole. Plugin Updates in particular should definitely work... With current world events (unjust wars) and weather situations (North America), perhaps this is a blip. Where are you located?
December 24, 20223 yr Author If the Apps Tab says you're running on the Backup Server, then plugin installs, updates etc won't work, but the OS updates should work. Reboot everything network related including the server and try it all again.
December 26, 20223 yr I have a few years of experience running Unraid. I also run pfsense community in a pretty vanilla setup. Since I upgraded from 6.9.2 to 6.11.5 I have been unable to connect the machine to the internet. I probably have munged things up. I've tried lots of things including. Using the OpenDNS servers which were suggested in an error message. Now running with Google DNS and still there is no internet connection. Removed any kind of ad blocking from pFsense. Also, got rid of IPV6 Removed various plugins that I saw suggested in threads Docker and VM's are turneed off. Fix Common problems says that it can not contact GitHub. I can: From within Unraid ping the other nodes on my network including the router. I can not ping anything out the Wan. All other systems are working fine. I've attached my diagnostics in the hope that someone can help. tower-diagnostics-20221225-1959.zip
December 26, 20223 yr I am getting "Multiple NICs on the same IPv4 network" eth3 and eth7 both have IP addresses on the 10.0.2.0 network. This is rarely a valid configuration. I don't have an eth7 anymore, I did throw a NIC in to test something but I didn't assign any IP address and its been removed. I already deleted and regenerated the docker config file and network rules file to try and solve but the warning won't go away. Attached are diagnostics. hank you for all your work!T tower-diagnostics-20221226-0851.zip
December 26, 20223 yr Author Try making a change (any change) to settings - Network, revert and then reapply
December 28, 20223 yr Not sure if you saw this, but Spaceinvader left a message for you in his last video: (time-coded URL)
January 1, 20233 yr WARNINGS FOUND SUGGESTED FIX /var/log is getting full (currently 73 % used)Either your server has an extremely long uptime, or your syslog could be potentially being spammed with error messages. A reboot of your server will at least temporarily solve this problem, but ideally you should seek assistance in the forums and post your More Information Per the directions, i was to post the message and the files. I have been having intermittent errors stating my docker image was getting full, but it would correct itself, this happens at least daily and sometimes more than once. It may be related and if not, is yet another issue I'll need to sort out. razz-diagnostics-20230101-1851.zip Edited January 12, 20233 yr by razzellu There had not been a response to this in almost two weeks, but yesterday i swapped my ryzen 3700 for my intel 13600k which resulted in no need for ram troubleshooting, and have not had the error since. I believe this error is now resolved.
January 2, 20233 yr I replaced my RAM last week after some errors were occurring. Today after backups ran I woke up to errors due to memory. Do I need to add more? Is there an errant backup process mucking things up? Thanks in advance. trescommas-diagnostics-20230102-1021.zip
January 3, 20233 yr On 12/26/2022 at 9:31 AM, Squid said: Try making a change (any change) to settings - Network, revert and then reapply OK I tried that and same issue. I even cleared all settings and re-setup the interfaces...
January 3, 20233 yr 20 hours ago, jackfalveyiv said: I replaced my RAM last week after some errors were occurring. Today after backups ran I woke up to errors due to memory. Do I need to add more? Is there an errant backup process mucking things up? Thanks in advance. trescommas-diagnostics-20230102-1021.zip 867.33 kB · 0 downloads I would update unraid first and post diagnostics when it happens again, looks like you are on 6.11.1, 6.11.5 is the latest bug fix release and contains a lot of improvements. there were numerous issues with 6.11 that have been subsequently fixed in point updates, that's where I would start. I also see some virtio errors that probably aren't related but usually occur when there is a GPU or other device that's not being passed correctly to a VM. The app data backup/restore issue is also separate and you would ask in that thread, but if you have error checking on the backups that could cause that error since (depending on what you are backing up) it will always fail that (as an example if you backup USB or system, since checksums will fail as the files will have changed between start and end of backup)
January 3, 20233 yr the extended scan has gone missing... is there a glitch or something that removed it as i wanted to run an extended scan but i cant find it
January 3, 20233 yr 10 minutes ago, comet424 said: the extended scan has gone missing... is there a glitch or something that removed it as i wanted to run an extended scan but i cant find it On 12/10/2022 at 8:46 AM, Squid said: Extended Tests are now removed from FCP Extended tests had their use a number of years ago, but nowadays No matter what you do it's a given that it will always return issues Those issues are not "real" per se They're primarily tests for SMB compatibility, (and any errors are once again not "real" issues) It takes forever to run
January 3, 20233 yr ah ok cuz i used it to remove the non windows files with the extra space padding extended scans found that are not compatible for windows shares but were there in for unraid so how do i scan for those files then as i used it to clean up those files is there another program plugin to scan for incompatible windows files etc Edited January 3, 20233 yr by comet424
January 4, 20233 yr cuz i wanna fix the root/root (0) i used to get the "test .txt" file errors with the wrong spacings that are not compatible in windows and also scan for errors of like same folder names videos Videos unraid considers them 2 different but windows buggers up and only chooses one.. so i need a scanner to tell me these errors is there another scanner to scan these then? for these common issues Edited January 4, 20233 yr by comet424
