I'll add my thoughts on the extended tests: I found the search for duplicate files handy - sometimes in the past a Move operation would do weird things. Would be nice to verify my FS.
  • Replies 2.6k
  • Views 690.7k
  • kennymc.c
    kennymc.c
I previously was having memory errors, I bought new RAM and installed it successfully and was waiting for another Backup task to fire, and it looks like I was alerted of out-of-memory issues again.  Posting the diagnostic in the hopes someone has an idea of what's going on.  Thanks in advance.
trescommas-diagnostics-20230110-0740.zip
Hi all,
My scan stucks alway at 13% sameShareDifferentCase. No way to close the process. Any ideas? Thanks.
Hi all, my scan always stucks at 13% sameShareDifferentCase. Any ideas for me? Thanks.
On 1/10/2023 at 8:21 AM, jackfalveyiv said:
bought new RAM
Jan 10 02:26:10 TresCommas kernel: BTRFS warning (device sdb1): csum failed root 5 ino 13278304 off 454656 csum 0x80d4bb59 expected csum 0x000b680c mirror 1
Jan 10 02:26:10 TresCommas kernel: BTRFS error (device sdb1): bdev /dev/sdb1 errs: wr 0, rd 0, flush 0, corrupt 206, gen 0
Jan 10 02:26:10 TresCommas kernel: BTRFS warning (device sdb1): csum failed root 5 ino 13278304 off 458752 csum 0x5107da90 expected csum 0x8588ffff mirror 1
Jan 10 02:26:10 TresCommas kernel: BTRFS error (device sdb1): bdev /dev/sdb1 errs: wr 0, rd 0, flush 0, corrupt 207, gen 0
Jan 10 02:26:10 TresCommas kernel: BTRFS error (device sdb1): bdev /dev/sdb1 errs: wr 0, rd 0, flush 0, corrupt 208, gen 0
Jan 10 02:26:10 TresCommas kernel: BTRFS error (device sdb1): bdev /dev/sdb1 errs: wr 0, rd 0, flush 0, corrupt 209, gen 0
These suggest bad memory corrupted cache, possibly the old memory.
The old memory has been removed, as of the 7th, it's no longer installed.  Is there anything else I can look at?
If the new memory passes memtest then you might try scrub on cache
Gotcha.  Is there some documentation for executing a scrub on cache?
Main - Pool Devices - Cache - Cache Settings - Scrub Status - Scrub button
Thanks!
Server passed Memtest, scrub came back with two unfixable errors.  Found a similar post:
I started this process by moving everything from the Cache, however the move has taken an inordinate amount of time.  I have a 1TB SSD, I think it was maybe half-full when I began the move today around 1030AM EST (after adjusting my shares to not use cache) and it still has 273GB of data to move.  Is this typical, or indicative of another issue?
EDIT: current diagnostic attached
trescommas-diagnostics-20230112-2221.zip
EDIT: I've since stopped the mover and started migrating data using the Dynamix file manager, which is moving things at normal speeds.
Edited by jackfalveyiv
Just an update for any future folks troubleshooting, I was able to use the file manager to migrate all data to the array, neutralized the corrupted files from the SSD, and moved everything back to cache.  Services are back online now and I'll be monitoring during my next backup window to see whether I get an error again.
Since the extended tests are gone, can anyone recommend another tool for finding and dealing with files that have ended up duplicated on more than one disk?
Thanks in advance!
On 12/19/2022 at 5:38 PM, kim_sv said:
Dear Squid!
As usual, thank you for your great work for this community!
I just have a question regarding having appdata split over multiple pools, and backup thereof.
I have all but one appdata-folder on /cache and only my Plex appdata on a separate pool /cache_plex.
FCP flags this as a problem:
So far I've just ignored it, since the update seems to still be functioning correctly.
Question is, can I leave it as is (and solve the issue of "how to backup my plex pool" this way) or is this a bad practice?
Merry Christmas!
Sorry for reposting, but I fear this question disappeared due to someone posting their whole log file in plain text. :P
... am i in the wrong forum regarding this?
crosstposting from General Support since I didn't realize this thread was here ;)
My Fix Common Problems plugin recently started reported a warning for a new cache pool I created and moved files to. The corresponding share is set to "Only: fastcache". Is there any way/log that tells me, which files the plugin is reporting? How do I proceed?
Share fastappdata set to use pool fastcache, but files / folders exist on the cache pool
Thanks!
Thanks!
If you haven't installed it yet, install "Dynamix File Manager" from CA and using that you can view the shares content and it also gives you a Location column where each directory/file is located on your system. You can also use the file manager to move those files into your fastcache pool.
Should FCP remove the warning that a docker container needs an update after it has been updated (for compose based containers)?
I have a few compose based containers and it seems that once the alert it triggered it never clears.  Even after I update the container and verify via cli that there is not a newer container image to pull FCP does "clear".  I'm happy with the warnings, I just want them to clear like they do for non-compose based containers.
Hello, My logs partition appears to have randomly filled up today, Not sure of any changes in the last couple days that would lead to this. I was advised to post my diagnostics zip here for help. Thanks for any help!
nasrun-diagnostics-20230127-1804.zip
Your problem is
nginx: 2023/01/26 16:20:25 [alert] 8077#8077: worker process 1534 exited on signal 6
In the past this has been reported to occur with multiple stale browser connections open on multiple machines. Try closing all those connections on all laptops, desktops, phones, etc.
55 minutes ago, svennibenni said:
/var/log is getting full (currently 100 % used)
You will have to reboot to clear log
Problem still exists - just days after reboot folder is at 100% full again. It seems I cannot run diagnostics when there is no error ...
On 9/30/2022 at 1:40 AM, MammothJerk said:
I recently started getting the error
"Share " " contains only spaces which is illegal Windows systems."
and the button to "Ignore error" is not responding when i click on it. tried in both edge and firefox
Did you find the share? Then simply delete/rename it! I had this error pointing to a directory "/" above "appdata", left over from a hanging "delete network share" action.
I had to go -> console -> mc -> /mnt/user and delete it there (from the command line). Also in my case the button "ignore" did not work.
Edited by azche24
