I tried changing to ipvlan and it broke DuckDNS. Putting it back restored operation. Not sure why. It's not on a custom network, just Host.
Guess I'll leave it alone unless someone else has some guidance.
Seems that the plugin should flag macvlan as a warning versus an error.
Edited by nraygun
  • Replies 2.6k
  • Views 696.6k
  • kennymc.c
    kennymc.c
Anyone else getting "not available" for this plugin when looking at update status on the plugin page?
Edited by rkotara
+1
Yeah.  inadvertent change to the .plg that messed it up.
If it was summer and I had a pool, you have permission to beat me with a wet noodle
Is there a way to disable checking for new docker versions?  My dockers all auto-update on a set schedule, but this means I'll often have 20+ notifications (for docker updates) all of which have already automatically been updated since.  It's not useful and spams the notification list badly.
Me too.
Wasn't happening until recently. Not sure where those emails are coming from but FCP seems the only logical source.
Yeah I know, this here is mentioned very often already but still unresolved and nagging:
May 14 04:40:02 F root: Fix Common Problems Version 2023.04.26
May 14 04:40:04 F root: Fix Common Problems: Warning: unRaids built in FTP server is currently disabled, but users are defined ** Ignored
The message is simply wrong, There are no ftp users in unraid, there is a docker with crushftp installed (and with its own database for users). Also, nobody knows how to "resolve" this common problem.
Yeah, you can ignore it, but the message should never pop up.
This is not "Fix Common Problems" this is more "Create Common Problems".
My file log is filling up to 110%. I have added my diagnostic file for review.
syslog.1.txt
Tame your client  192.168.88.110.
He is banging something on your server many thousands of times per seconds. The log does not say which program is been banged, but I would look for something that offers net services like nextcloud or so.
There is something running wild on that client.
You can see the FCP code here:
  https://github.com/Squidly271/fix.common.problems/blob/ce84e87f79caaf750bc84a16f7ecdb93561f4cec/source/fix.common.problems/usr/local/emhttp/plugins/fix.common.problems/include/tests.php#L714
If this file exists on your flash drive it will trigger that message:
  /boot/config/vsftpd.user_list
It looks like when you go to Settings -> FTP Server and remove the users, it empties the file but does not delete it.
The FCP test could be updated to ignore a file with no data.
In the meantime you can get rid of the message by deleting the empty config/vsftpd.user_list file from your flash drive.
tnx! this worked. Maybe you should  add this explanation/solution to the warning message? So affected people instantly would know why it happens and how to fix it?
I never had any vsftp users, as far as I can remember, but in the beginnings I have turned on the builtin ftp just to see that it does not fulfill my needs. So I guess, the file was autocreated, but how could I know?
20 hours ago, RMichaelRae said:
/var/log is getting full
Doesn't seem to be a problem with FCP plugin
On 5/8/2016 at 4:01 PM, Squid said:
Any support for problems this plugin finds, should be posted in the General v6 section of these forums
I am having a problem with FCP hanging on scanning.  I initially was running this because a script that I back of PFSense with is not assigning permissions they way it should, not sure what to do about that.  But, FPC should not hang.
tower-diagnostics-20230606-1052.zip
When running a manual scan, the popup shows the progress (the current scan).  What does it say?
This is all I get... would a manual scan be something different than clicking rescan in the GUI?
On 3/4/2023 at 8:11 AM, Squid said:
"addons" issue fixed on today's release
I had a feeling an update was just needed to correct the error. But I am still receiving the error. Can you or someone else help me ID the folder the errant folder.
root@******:~# ls -l /mnt/
total 32
drwxrwxrwt 2 nobody users  40 May 25 23:21 addons/
drwxr-xr-x 3 root   root   60 May 25 23:21 cache/
drwxrwxrwx 1 nobody users  28 Jun 10 04:40 cache_downloads/
drwxrwxrwx 1 nobody users  48 Jun 10 04:40 cache_main/
drwxrwxrwx 7 nobody users 101 Jun 10 04:40 disk1/
drwxrwxrwx 5 nobody users  66 Jun 10 04:40 disk10/
drwxrwxrwx 4 nobody users  48 Jun 10 04:40 disk11/
drwxrwxrwx 5 nobody users  66 Jun 10 04:40 disk12/
drwxrwxrwx 5 nobody users  66 Jun 10 04:40 disk13/
drwxrwxrwx 5 nobody users  66 Jun 10 04:40 disk14/
drwxrwxrwx 5 nobody users  50 Jun 10 04:40 disk15/
drwxrwxrwx 5 nobody users  66 Jun 10 04:40 disk16/
drwxrwxrwx 5 nobody users  66 Jun 10 04:40 disk17/
drwxrwxrwx 5 nobody users  66 Jun 10 04:40 disk18/
drwxrwxrwx 5 nobody users  66 Jun 10 04:40 disk19/
drwxrwxrwx 6 nobody users  85 Jun 10 04:40 disk2/
drwxrwxrwx 6 nobody users  84 Jun 10 04:40 disk20/
drwxrwxrwx 6 nobody users  87 Jun 10 04:40 disk21/
drwxrwxrwx 5 nobody users  66 Jun 10 04:40 disk22/
drwxrwxrwx 4 nobody users  48 Jun 10 04:40 disk23/
drwxrwxrwx 5 nobody users  69 Jun 10 04:40 disk24/
drwxrwxrwx 7 nobody users 101 Jun 10 04:40 disk3/
drwxrwxrwx 6 nobody users  85 Jun 10 04:40 disk4/
drwxrwxrwx 6 nobody users  82 Jun 10 04:40 disk5/
drwxrwxrwx 5 nobody users  66 Jun 10 04:40 disk6/
drwxrwxrwx 5 nobody users  66 Jun 10 04:40 disk7/
drwxrwxrwx 5 nobody users  66 Jun 10 04:40 disk8/
drwxrwxrwx 6 nobody users  87 Jun 10 04:40 disk9/
drwxrwxrwt 2 nobody users  40 May 25 23:21 disks/
drwxrwxrwt 2 nobody users  40 May 25 23:21 remotes/
drwxrwxrwt 2 nobody users  40 May 25 23:21 rootshare/
drwxrwxrwx 1 nobody users 101 Jun 10 04:40 user/
drwxrwxrwx 1 nobody users 101 Jun 10 04:40 user0/
Edited by jginzkey
In Settings > NetworkSettings change IPv4 DNS server assignment from Automatic to Static
Set IPv4 DNS server to 8.8.8.8 and 8.8.4.4
Now try and see if it works.
*EDIT* You will have to disable Docker and VM's in the settings before you can make these adjustments.
Edited by Grimbone
Clarity
every day i get this "root: Fix Common Problems: Warning: Write Cache is disabled on disk8"
Disk8 is actual disk 8 in the array?
I tested every disk with that command that the plugin links to, and it says that cache is ON.
But every day im getting a report that cache is off
since some month I got the warning:
I've ignored this because everything works fine, but before updating to 6.12 I would like to solve this issue...
All shares works like a charm, the system is running smoothly without any other problems.
But I can not find any problem in my shares configuration.
It would be great if someone has an idea!
nasgw-diagnostics-20230616-0726.zip
Edited by KHP_BOH
Have you checked that you do not have a top level folder called 'disks' on either a cache pool or on any array drive?  The FCP messages imply it might be on the cache.
Great, thanks a lot for this!
Some time ago I've made a copy of the USB-Disk to the cache...
Deleted -> Error has gone.
Current version not compatible with Unraid latest version 6.12.0? When click on it just hanging on scanning screen without moving.
100% it is compatible.
Does it show any scan in progress or just the popup not doing anything at all?
If you give it a couple of minutes and then go back to FCP it will have the results.
After reboot Unraid again it back to work. Thank you.
