2 minutes ago, itimpi said:
a mistake - I meant the docker service.
Sorry for all the questions.  I haven't been keeping up with everything for quite some time and rebuilt my server after my old one died...so lots of things have changed.
So I go to Settings and set Doker to Disabled. Then go to the Main page and at the bottom click Move.
Then go back to appdata share, set secondary to None. Go back to Settings and re-enable the Docker service.
Then stop my array and change Settings->Global Share settings to allow Exclusive Shares. Then start up the array again
Do I have that all correct?
  • Replies 2.5k
  • Views 669.7k
  • kennymc.c
    kennymc.c
Yes, although strictly speaking the last is optional.
Ok that worked! Thanks!
A rescan no longer shows that error. However, I still have the Slave error...
Docker application Sonarr has volumes being passed that are mounted by Unassigned Devices, but they are not mounted with the slave option
If I open the settings for Sonarr I have two paths
Container Path: /tv ---> This points to /mnt/disks/UNASSNDisk/Media/TV Shows/
Container Path: /data ---> This points to /mnt/disks/DELUGETorrents/Deluge/
I'm unsure which I click Edit on and change to Slave.
Both of them should have Slave mode set
I'm now getting this in my downloads from Sonarr
Couldn't import episode /data/completed/Beacon.23.S01E03.1080p.WEB.h264-EDITH[TGx]/Beacon.23.S01E03.1080p.WEB.h264-EDITH.mkv: Access to the path '/tv/Beacon 23' is denied.
I wasn't before I made the changes to Slave - Read/Write and Exclusive mode
For Sonarr Permissions I have
https://photos.app.goo.gl/WY11UkxLkqJySGt66
Edited by DigitalDivide
Shouldn't be the slave setting.  More likely the exclusive.
Either way, Slave and FCP is a guideline to minimize issues (as is most of the stuff in FCP).  Nothing strictly says you have to follow what it says if you're having issues.
Just an update on the above. I tried various settings and found that for the below
If I set only Container Path: /tv ---> This points to /mnt/disks/UNASSNDisk/Media/TV Shows/  to Slave Read/Write and the other one to just read/write, everything works fine.
Fix Common Problems has reported an error but the solution is quite unclear to me.
Your server has detected hardware errors. You should install mcelog via the NerdPack plugin, post your diagnostics and ask for assistance on the Unraid forums. The output of mcelog (if installed) has been logged  More Information
The More information link further discusses this mcelog as part of NerdPack, but the thing is I don't have "NerdPack" I have "NerdTools" and there is no "mcelog" toggle under NerdTools. Somewhere in my search I found something that suggested to use "edac_mce_amd" since I have an AMD CPU, but even that isn't found under NerdTools.
I doubt my diagnostics (attached) are much help without the required log suggested by Fix Common Problems but if someone could give me some direction I thank you in advance.
bkhunraid-diagnostics-20231217-1129.zip
I just installed the latest update to the plugin -
2023.12.21
and now it just sits at the scanning modal forever.  It just never goes away.  I think it is broken.
Matt
2023.12.21
Can you show a screenshot of what the scanning modal says when it gets stuck?
Please also upload your diagnostics (from Tools -> Diagnostics)
Hello, after running the plugin the results suggest to search for r8186 in CA, which leads to "no results". It should say search for rtl8186. I suppose it's the same for the other realtek devices too.
Edited by DMcK
17 minutes ago, DMcK said:
rtl8186
Please search for rtl8168 there is a typo in there.
Ah, yes. So the plugin results say search for "r8168" and should say search for "rtl8168".
Edited by DMcK
The plugin currently says r8186 and it should be r8168, it doesn't matter if you search for r8168 or rtl8168, already issued a PR.
Sorry @Squid
Looks like this test could use some improvements for your situation.
The good news is it doesn't look like you have anything to worry about:
Dec 16 04:35:31 BKHunraid kernel: mce: [Hardware Error]: Machine check events logged
Dec 16 04:35:31 BKHunraid kernel: [Hardware Error]: Corrected error, no action required.
Sorry @Squid
Facepalm
Hello,
May I suggest adding a notification to this plug-in to warn users who are still using the old AppData Backup plug-in? I only recently updated from 6.11.5 to 6.12.x (6.12.1 is the cut-off) and only today did I realize a backup hasn't been run since that upgrade (~1mo). I'm having some cache drive trouble right now and could have really used some recent backups.
Edited by thatsthefrickenlightning
Curious if you also have an issue with the dashboard not populating CPU usage etc correctly.  Upshot with FCP is that if you just let it sit for a couple of minutes and then reload the page it should populate everything that it found.
FWIW, probable fix to these issues for a small minority of users are probably in the soon to be released 6.13
On 11/28/2023 at 8:34 PM, ConnerVT said:
Hi Squid.  A little bug you may/may not know of.
Pressing the WHAT IS CHECKED button pops up the window, but no text is displayed.
Latest updated plugin, 6.12.4, happens in both Firefox and Chrome.
Was just poking around, in preparation of updating to 6.12.5.
Can confirm this behaviour on 6.12.6 with the latest plugin version installed (2023.12.24) in both Google Chrome 120.0.6099.129 and Safari 17.2
Can we have an option to disable Docker update check for all? It shouldn't be warning, but notice at most.
Invalid folder appdata contained within /mnt
I can't seem to find what the issue is, Server will start then things are running then it just freezes I have to then reboot to get it back going. adjusted time in the bios and in unraid as well need help figuring this out been on it for a few days now. Thanks for any help.
conwayserver-diagnostics-20231228-1934.zip
This means you have something (almost certainly a docker container) configured to use the path /mnt/appdata..    Since that path is in RAM it will likely fill up your RAM and crash the system.
What I seen so far was I change to plexpass binhex from the other binhex and I just notice that the transcode was /mnt/appdata/plexmediaserver/transcode/, so I change it to /mnt/user/appdata/binhex-plexpass/transcode/, went to common fix and ran scan and still shows error.
