May 22, 201610 yr Hi, Iwant to preclear a new 3TB drive (sdk): [0:0:0:0] disk TOSHIBA TransMemory 1.00 /dev/sda [1:0:0:0] disk ATA ST32000542AS CC34 /dev/sdb [1:0:1:0] disk ATA ST2000DM001-1CH1 CC27 /dev/sdc [1:0:2:0] disk ATA ST32000542AS CC34 /dev/sdd [1:0:3:0] disk ATA ST3000DM001-1CH1 CC27 /dev/sde [1:0:4:0] disk ATA ST32000542AS CC34 /dev/sdf [1:0:5:0] disk ATA ST3000DM001-1ER1 CC25 /dev/sdg [1:0:6:0] disk ATA WDC WD20EZRX-00D 0A80 /dev/sdh [1:0:7:0] disk ATA ST2000DM001-1CH1 CC27 /dev/sdi [2:0:0:0] disk ATA ST2000DL003-9VT1 CC32 /dev/sdj [3:0:0:0] disk ATA WDC WD30EFRX-68E 0A82 /dev/sdk [4:0:0:0] disk ATA SanDisk SDSSDXP1 1 /dev/sdl [5:0:0:0] disk ATA ST3750330AS SD15 /dev/sdm But after I type preclear: Linux 4.1.18-unRAID. root@Tower_kvm:~# screen root@Tower_kvm:~# cd /boot/ root@Tower_kvm:/boot# preclear_disk.sh -l ====================================1.15 Disks not assigned to the unRAID array (potential candidates for clearing) ======================================== No un-assigned disks detected sdk shows up in Unassigned devices as not mounted, but it seems Unraid is not able to see it dor preclear. Any Ideas how to solve this. I am running6.1.9. Rgds.
June 6, 201610 yr Author Hi, I have been away but would like to come back to this again. PLs, let m know how to make the diagnostics? Rgds.
June 6, 201610 yr Hi, I have been away but would like to come back to this again. PLs, let m know how to make the diagnostics? Rgds. On the unRAID Webgui, go to tools > diagnostics, then click download.
