July 10, 201610 yr Hi, I have nvidia gtx titan I notice that i have probelm with VMs sound Some of them can work and others cant work and some of the working vm have sound late and not in real time!! I did download liberElec and openELEC from the VM and i have no sound out!! I did try to install kodibuntu but no luck and it cant work And I wonder if i can install LiberELEC Custom Built ? tower-diagnostics-20160709-2227.zip
July 10, 201610 yr Did you go into OpenElec / LibreElec's settings and set the sound device? Yes if i remember the default options in kodi (openelec/libre) will not be set to the hdmi of your gpu
July 11, 201610 yr Author Sorry for the late reply but i was busy last two days Here is the vm log ErrorWarningSystemArrayLogin 2016-07-09 18:48:26.955+0000: starting up libvirt version: 1.3.1, qemu version: 2.5.1, hostname: Tower LC_ALL=C PATH=/bin:/sbin:/usr/bin:/usr/sbin HOME=/ QEMU_AUDIO_DRV=none /usr/local/sbin/qemu -name LibreELEC -S -machine pc-q35-2.5,accel=kvm,usb=off,mem-merge=off -cpu host -drive file=/usr/share/qemu/ovmf-x64/OVMF_CODE-pure-efi.fd,if=pflash,format=raw,unit=0,readonly=on -drive file=/etc/libvirt/qemu/nvram/e9fb181a-eb09-fa98-f302-7ad173d8fc89_VARS-pure-efi.fd,if=pflash,format=raw,unit=1 -m 2048 -realtime mlock=off -smp 2,sockets=1,cores=1,threads=2 -uuid e9fb181a-eb09-fa98-f302-7ad173d8fc89 -no-user-config -nodefaults -chardev socket,id=charmonitor,path=/var/lib/libvirt/qemu/domain-LibreELEC/monitor.sock,server,nowait -mon chardev=charmonitor,id=monitor,mode=control -rtc base=utc,driftfix=slew -global kvm-pit.lost_tick_policy=discard -no-hpet -no-shutdown -boot strict=on -device i82801b11-bridge,id=pci.1,bus=pcie.0,addr=0x1e -device pci-bridge,chassis_nr=2,id=pci.2,bus=pci.1,addr=0x1 -device nec-usb-xhci,id=usb,bus=pcie.0,addr=0x7 -device virtio-serial-pci,id=virtio-serial0,,bus=pcie.0,addr=0x1 -device virtio-balloon-pci,id=balloon0,bus=pci.2,addr=0x5 -msg timestamp=on Domain id=4 is tainted: high-privileges Domain id=4 is tainted: host-cpu char device redirected to /dev/pts/0 (label charserial0) 2016-07-09T18:48:38.103888Z qemu-system-x86_64: terminating on signal 15 from pid 12139 2016-07-09 18:48:38.304+0000: shutting down 2016-07-09 18:49:11.839+0000: starting up libvirt version: 1.3.1, qemu version: 2.5.1, hostname: Tower LC_ALL=C PATH=/bin:/sbin:/usr/bin:/usr/sbin HOME=/ QEMU_AUDIO_DRV=none /usr/local/sbin/qemu -name LibreELEC -S -machine pc-q35-2.5,accel=kvm,usb=off,mem-merge=off -cpu host -drive file=/usr/share/qemu/ovmf-x64/OVMF_CODE-pure-efi.fd,if=pflash,format=raw,unit=0,readonly=on -drive file=/etc/libvirt/qemu/nvram/e9fb181a-eb09-fa98-f302-7ad173d8fc89_VARS-pure-efi.fd,if=pflash,format=raw,unit=1 -m 2048 -realtime mlock=on -smp 2,sockets=1,cores=1,threads=2 -uuid e9fb181a-eb09-fa98-f302-7ad173d8fc89 -nographic -no-user-config -nodefaults -chardev socket,id=charmonitor,path=/var/lib/libvirt/qemu/domain-LibreELEC/monitor.sock,server,nowait -mon chardev=charmonitor,id=monitor,mode=control -rtc base=utc,driftfix=slew -global kvm-pit.lost_tick_policy=discard -no-hpet -no-shutdown -boot strict=on -device i82801b11-bridge,id=pci.1,bus=pcie.0,addr=0x1e -device pci-bridge,chassis_nr=2,id=pci.2,bus=pci.1,addr=0x1 -device nec-usb-xhci,id=usb,bus=pcie.0,addr=0x7 -device virtio-serial-pci,id=virtievice usb-host,hostbus=1,hostaddr=3,id=hostdev2 -device usb-host,hostbus=1,hostaddr=5,id=hostdev3 -device virtio-balloon-pci,id=balloon0,bus=pci.2,addr=0x7 -msg timestamp=on Domain id=5 is tainted: high-privileges Domain id=5 is tainted: host-cpu char device redirected to /dev/pts/0 (label charserial0) 2016-07-09T18:50:18.987757Z qemu-system-x86_64: terminating on signal 15 from pid 12139 2016-07-09 18:50:20.588+0000: shutting down 2016-07-09 18:50:31.927+0000: starting up libvirt version: 1.3.1, qemu version: 2.5.1, hostname: Tower LC_ALL=C PATH=/bin:/sbin:/usr/bin:/usr/sbin HOME=/ QEMU_AUDIO_DRV=none /usr/local/sbin/qemu -name LibreELEC -S -machine pc-q35-2.5,accel=kvm,usb=off,mem-merge=off -cpu host -drive file=/usr/share/qemu/ovmf-x64/OVMF_CODE-pure-efi.fd,if=pflash,format=raw,unit=0,readonly=on -drive file=/etc/libvirt/qemu/nvram/e9fb181a-eb09-fa98-f302-7ad173d8fc89_VARS-pure-efi.fd,if=pflash,format=raw,unit=1 -m 2048 -realtime mlock=on -smp 2,sockets=1,cores=1,threads=2 -uuid e9fb181a-eb09-fa98-f302-7ad173d8fc89 -nographic -no-user-config -nodefaults -chardev socket,id=charmonitor,path=/var/lib/libvirt/qemu/domain-LibreELEC/monitor.sock,server,nowait -mon chardev=charmonitor,id=monitor,mode=control -rtc base=utc,driftfix=slew -global kvm-pit.lost_tick_policy=discard -no-hpet -no-shutdown -boot strict=on -device i82801b11-bridge,id=pci.1,bus=pcie.0,addr=0x1e -device pci-bridge,chassis_nr=2,id=pci.2,bus=pci.1,addr=0x1 -device nec-usb-xhci,id=usb,bus=pcie.0,addr=0x7 -device virtio-serial-pci,id=virtist,hostbus=1,hostaddr=3,id=hostdev2 -device usb-host,hostbus=1,hostaddr=5,id=hostdev3 -device virtio-balloon-pci,id=balloon0,bus=pci.2,addr=0x7 -msg timestamp=on Domain id=6 is tainted: high-privileges Domain id=6 is tainted: host-cpu char device redirected to /dev/pts/0 (label charserial0) 2016-07-09T19:06:21.601708Z qemu-system-x86_64: terminating on signal 15 from pid 12139 2016-07-09 19:06:23.202+0000: shutting down 2016-07-09 19:07:01.024+0000: starting up libvirt version: 1.3.1, qemu version: 2.5.1, hostname: Tower LC_ALL=C PATH=/bin:/sbin:/usr/bin:/usr/sbin HOME=/ QEMU_AUDIO_DRV=none /usr/local/sbin/qemu -name LibreELEC -S -machine pc-q35-2.5,accel=kvm,usb=off,mem-merge=off -cpu host -drive file=/usr/share/qemu/ovmf-x64/OVMF_CODE-pure-efi.fd,if=pflash,format=raw,unit=0,readonly=on -drive file=/etc/libvirt/qemu/nvram/e9fb181a-eb09-fa98-f302-7ad173d8fc89_VARS-pure-efi.fd,if=pflash,format=raw,unit=1 -m 2048 -realtime mlock=on -smp 2,sockets=1,cores=1,threads=2 -uuid e9fb181a-eb09-fa98-f302-7ad173d8fc89 -nographic -no-user-config -nodefaults -chardev socket,id=charmonitor,path=/var/lib/libvirt/qemu/domain-LibreELEC/monitor.sock,server,nowait -mon chardev=charmonitor,id=monitor,mode=control -rtc base=utc,driftfix=slew -global kvm-pit.lost_tick_policy=discard -no-hpet -no-shutdown -boot strict=on -device i82801b11-bridge,id=pci.1,bus=pcie.0,addr=0x1e -device pci-bridge,chassis_nr=2,id=pci.2,bus=pci.1,addr=0x1 -device nec-usb-xhci,id=usb,bus=pcie.0,addr=0x7 -device virtio-serial-pci,id=virtist,hostbus=1,hostaddr=3,id=hostdev2 -device usb-host,hostbus=1,hostaddr=5,id=hostdev3 -device virtio-balloon-pci,id=balloon0,bus=pci.2,addr=0x7 -msg timestamp=on Domain id=7 is tainted: high-privileges Domain id=7 is tainted: host-cpu char device redirected to /dev/pts/0 (label charserial0) 2016-07-09T19:07:29.192199Z qemu-system-x86_64: terminating on signal 15 from pid 12139 2016-07-09 19:07:30.793+0000: shutting down 2016-07-11 05:57:07.830+0000: starting up libvirt version: 1.3.1, qemu version: 2.5.1, hostname: Tower LC_ALL=C PATH=/bin:/sbin:/usr/bin:/usr/sbin HOME=/ QEMU_AUDIO_DRV=none /usr/local/sbin/qemu -name LibreELEC -S -machine pc-q35-2.5,accel=kvm,usb=off,mem-merge=off -cpu host -drive file=/usr/share/qemu/ovmf-x64/OVMF_CODE-pure-efi.fd,if=pflash,format=raw,unit=0,readonly=on -drive file=/etc/libvirt/qemu/nvram/af1d666a-068e-4a46-9d7c-7bacbdbe2412_VARS-pure-efi.fd,if=pflash,format=raw,unit=1 -m 5120 -realtime mlock=on -smp 2,sockets=1,cores=1,threads=2 -uuid af1d666a-068e-4a46-9d7c-7bacbdbe2412 -nographic -no-user-config -nodefaults -chardev socket,id=charmonitor,path=/var/lib/libvirt/qemu/domain-LibreELEC/monitor.sock,server,nowait -mon chardev=charmonitor,id=monitor,mode=control -rtc base=utc,driftfix=slew -global kvm-pit.lost_tick_policy=discard -no-hpet -no-shutdown -boot strict=on -device i82801b11-bridge,id=pci.1,bus=pcie.0,addr=0x1e -device pci-bridge,chassis_nr=2,id=pci.2,bus=pci.1,addr=0x1 -device nec-usb-xhci,id=usb,bus=pcie.0,addr=0x7 -device virtio-serial-pci,id=virtist,hostbus=1,hostaddr=3,id=hostdev2 -device usb-host,hostbus=1,hostaddr=5,id=hostdev3 -device virtio-balloon-pci,id=balloon0,bus=pci.2,addr=0x7 -msg timestamp=on Domain id=25 is tainted: high-privileges Domain id=25 is tainted: host-cpu char device redirected to /dev/pts/0 (label charserial0) I did get into system and audio output and choose hdmi lg tv Nothing happen In vm edit page i did try both bios Nothing happen And i did try to install custom liber built but no luck This happen with openelec too And i use the latest unraid 6.2 rc1 with tbs dvb Update: openelec did work now { i am a worry to shutdown the vm LOL } but i hope i use liberelec and i want this build https://forum.libreelec.tv/thread-302.html Update 2:It did broke again after watching one episode !!
July 11, 201610 yr Author Hi CHBMB, Here the xml for OpenELEC <domain type='kvm'> <name>OpenELEC</name> <uuid>f6b0c2ce-f392-b84e-0af2-0a1ff29b3fa1</uuid> <metadata> <vmtemplate xmlns="unraid" name="OpenELEC" icon="openelec.png" openelec="6.0.3_1"/> </metadata> <memory unit='KiB'>4194304</memory> <currentMemory unit='KiB'>4194304</currentMemory> <memoryBacking> <nosharepages/> <locked/> </memoryBacking> <vcpu placement='static'>2</vcpu> <cputune> <vcpupin vcpu='0' cpuset='10'/> <vcpupin vcpu='1' cpuset='11'/> </cputune> <os> <type arch='x86_64' machine='pc-q35-2.5'>hvm</type> <loader readonly='yes' type='pflash'>/usr/share/qemu/ovmf-x64/OVMF_CODE-pure-efi.fd</loader> <nvram>/etc/libvirt/qemu/nvram/f6b0c2ce-f392-b84e-0af2-0a1ff29b3fa1_VARS-pure-efi.fd</nvram> </os> <features> <acpi/> <apic/> </features> <cpu mode='host-passthrough'> <topology sockets='1' cores='1' threads='2'/> </cpu> <clock offset='utc'> <timer name='rtc' tickpolicy='catchup'/> <timer name='pit' tickpolicy='delay'/> <timer name='hpet' present='no'/> </clock> <on_poweroff>destroy</on_poweroff> <on_reboot>restart</on_reboot> <on_crash>restart</on_crash> <devices> <emulator>/usr/local/sbin/qemu</emulator> <disk type='file' device='disk'> <driver name='qemu' type='raw' cache='writeback'/> <source file='/mnt/disks/kvm/domains/OpenELEC/OpenELEC-unRAID.x86_64-6.0.3_1.img'/> <target dev='hdc' bus='virtio'/> <readonly/> <boot order='1'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x04' function='0x0'/> </disk> <controller type='usb' index='0' model='nec-xhci'> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x0'/> </controller> <controller type='sata' index='0'> <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/> </controller> <controller type='pci' index='0' model='pcie-root'/> <controller type='pci' index='1' model='dmi-to-pci-bridge'> <model name='i82801b11-bridge'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x1e' function='0x0'/> </controller> <controller type='pci' index='2' model='pci-bridge'> <model name='pci-bridge'/> <target chassisNr='2'/> <address type='pci' domain='0x0000' bus='0x01' slot='0x01' function='0x0'/> </controller> <controller type='virtio-serial' index='0'> <address type='pci' domain='0x0000' bus='0x02' slot='0x03' function='0x0'/> </controller> <filesystem type='mount' accessmode='passthrough'> <source dir='/mnt/user/appdata/OpenELEC/'/> <target dir='appconfig'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x01' function='0x0'/> </filesystem> <interface type='bridge'> <mac address='52:54:00:b7:78:20'/> <source bridge='br0'/> <model type='virtio'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x02' function='0x0'/> </interface> <serial type='pty'> <target port='0'/> </serial> <console type='pty'> <target type='serial' port='0'/> </console> <channel type='unix'> <source mode='connect'/> <target type='virtio' name='org.qemu.guest_agent.0'/> <address type='virtio-serial' controller='0' bus='0' port='1'/> </channel> <hostdev mode='subsystem' type='pci' managed='yes'> <driver name='vfio'/> <source> <address domain='0x0000' bus='0x08' slot='0x00' function='0x0'/> </source> <address type='pci' domain='0x0000' bus='0x02' slot='0x05' function='0x0'/> </hostdev> <hostdev mode='subsystem' type='pci' managed='yes'> <driver name='vfio'/> <source> <address domain='0x0000' bus='0x08' slot='0x00' function='0x1'/> </source> <address type='pci' domain='0x0000' bus='0x02' slot='0x06' function='0x0'/> </hostdev> <hostdev mode='subsystem' type='usb' managed='no'> <source> <vendor id='0x046d'/> <product id='0xc52b'/> </source> </hostdev> <hostdev mode='subsystem' type='usb' managed='no'> <source> <vendor id='0x04f2'/> <product id='0x0860'/> </source> </hostdev> <memballoon model='virtio'> <address type='pci' domain='0x0000' bus='0x02' slot='0x07' function='0x0'/> </memballoon> </devices> </domain> And Right now LiberELEC work now but as always i think it will broke (UPDATE it did broke ) here are LiberELEC xml <domain type='kvm' id='29'> <name>LibreELEC</name> <uuid>af1d666a-068e-4a46-9d7c-7bacbdbe2412</uuid> <metadata> <vmtemplate xmlns="unraid" name="LibreELEC" icon="libreelec.png" libreelec="7.0.1_1"/> </metadata> <memory unit='KiB'>4194304</memory> <currentMemory unit='KiB'>4194304</currentMemory> <memoryBacking> <nosharepages/> <locked/> </memoryBacking> <vcpu placement='static'>4</vcpu> <cputune> <vcpupin vcpu='0' cpuset='8'/> <vcpupin vcpu='1' cpuset='9'/> <vcpupin vcpu='2' cpuset='10'/> <vcpupin vcpu='3' cpuset='11'/> </cputune> <resource> <partition>/machine</partition> </resource> <os> <type arch='x86_64' machine='pc-q35-2.5'>hvm</type> <loader readonly='yes' type='pflash'>/usr/share/qemu/ovmf-x64/OVMF_CODE-pure-efi.fd</loader> <nvram>/etc/libvirt/qemu/nvram/af1d666a-068e-4a46-9d7c-7bacbdbe2412_VARS-pure-efi.fd</nvram> </os> <features> <acpi/> <apic/> </features> <cpu mode='host-passthrough'> <topology sockets='1' cores='2' threads='2'/> </cpu> <clock offset='utc'> <timer name='rtc' tickpolicy='catchup'/> <timer name='pit' tickpolicy='delay'/> <timer name='hpet' present='no'/> </clock> <on_poweroff>destroy</on_poweroff> <on_reboot>restart</on_reboot> <on_crash>restart</on_crash> <devices> <emulator>/usr/local/sbin/qemu</emulator> <disk type='file' device='disk'> <driver name='qemu' type='raw' cache='writeback'/> <source file='/mnt/disks/kvm/domains/LibreELEC/LibreELEC-unRAID.x86_64-7.0.1_1.img'/> <backingStore/> <target dev='hdc' bus='virtio'/> <readonly/> <boot order='1'/> <alias name='virtio-disk2'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x04' function='0x0'/> </disk> <controller type='usb' index='0' model='nec-xhci'> <alias name='usb'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x07' function='0x0'/> </controller> <controller type='sata' index='0'> <alias name='ide'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x1f' function='0x2'/> </controller> <controller type='pci' index='0' model='pcie-root'> <alias name='pcie.0'/> </controller> <controller type='pci' index='1' model='dmi-to-pci-bridge'> <model name='i82801b11-bridge'/> <alias name='pci.1'/> <address type='pci' domain='0x0000' bus='0x00' slot='0x1e' function='0x0'/> </controller> <controller type='pci' index='2' model='pci-bridge'> <model name='pci-bridge'/> <target chassisNr='2'/> <alias name='pci.2'/> <address type='pci' domain='0x0000' bus='0x01' slot='0x01' function='0x0'/> </controller> <controller type='virtio-serial' index='0'> <alias name='virtio-serial0'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x03' function='0x0'/> </controller> <filesystem type='mount' accessmode='passthrough'> <source dir='/mnt/user/appdata/LibreELEC/'/> <target dir='appconfig'/> <alias name='fs0'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x01' function='0x0'/> </filesystem> <interface type='bridge'> <mac address='52:54:00:3e:28:00'/> <source bridge='br0'/> <target dev='vnet0'/> <model type='virtio'/> <alias name='net0'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x02' function='0x0'/> </interface> <serial type='pty'> <source path='/dev/pts/0'/> <target port='0'/> <alias name='serial0'/> </serial> <console type='pty' tty='/dev/pts/0'> <source path='/dev/pts/0'/> <target type='serial' port='0'/> <alias name='serial0'/> </console> <channel type='unix'> <source mode='bind' path='/var/lib/libvirt/qemu/channel/target/domain-LibreELEC/org.qemu.guest_agent.0'/> <target type='virtio' name='org.qemu.guest_agent.0' state='disconnected'/> <alias name='channel0'/> <address type='virtio-serial' controller='0' bus='0' port='1'/> </channel> <hostdev mode='subsystem' type='pci' managed='yes'> <driver name='vfio'/> <source> <address domain='0x0000' bus='0x08' slot='0x00' function='0x0'/> </source> <alias name='hostdev0'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x05' function='0x0'/> </hostdev> <hostdev mode='subsystem' type='pci' managed='yes'> <driver name='vfio'/> <source> <address domain='0x0000' bus='0x08' slot='0x00' function='0x1'/> </source> <alias name='hostdev1'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x06' function='0x0'/> </hostdev> <hostdev mode='subsystem' type='usb' managed='no'> <source> <vendor id='0x046d'/> <product id='0xc52b'/> <address bus='1' device='3'/> </source> <alias name='hostdev2'/> </hostdev> <hostdev mode='subsystem' type='usb' managed='no'> <source> <vendor id='0x04f2'/> <product id='0x0860'/> <address bus='1' device='5'/> </source> <alias name='hostdev3'/> </hostdev> <memballoon model='virtio'> <alias name='balloon0'/> <address type='pci' domain='0x0000' bus='0x02' slot='0x07' function='0x0'/> </memballoon> </devices> </domain>
