January 7, 201016 yr I have an OptiUPS clever series UPS and APCUPSD doesn't work with it (which I didn't think it would). From my syslog Jan 6 21:46:59 Backup kernel: usb-storage: device found at 2 Jan 6 21:46:59 Backup kernel: usb-storage: waiting for device to settle before scanning Jan 6 21:46:59 Backup kernel: usb 5-1: new low speed USB device using uhci_hcd and address 2 Jan 6 21:46:59 Backup kernel: usb 5-1: configuration #1 chosen from 1 choice Then using unmenu ups status http://lime-technology.com/forum/index.php?action=post;board=3.0 (from /sbin/apcaccess status) Error contacting host localhost port 3551: Connection refused back to the syslog Jan 6 21:47:12 Backup apcupsd[1644]: apcupsd FATAL ERROR in linux-usb.c at line 609 Cannot find UPS device -- For a link to detailed USB trouble shooting information, please see . Jan 6 21:47:12 Backup apcupsd[1644]: apcupsd error shutdown completed I've searched the web a bit but am not that linux savy. One page I found suggested using http://www.networkupstools.org/ but I don't know where to start. Where would I find the right package to intall? Thanks
January 10, 201016 yr Author I found a package that was compiled for openbsd. When I tried to install it I get an error. Verifying package nut-2.2.1p0.tgz. Installing package nut-2.2.1p0.tgz: PACKAGE DESCRIPTION: WARNING: Package has not been created with 'makepkg' http://www.openbsd.org/4.4_packages/sparc64/nut-2.2.1p0.tgz-contents.html Is there a way to recompile it? Or do I need to find the source and how can I package it?
January 12, 201016 yr Well, unRAID is linux based (Slackware if I remember rightly), so I'd start with a linux solution if possible rather than BSD.
