August 31, 20169 yr hi all, I have an Asus ROG Xonar Phoebus Solo 7.1 PCI-E Soundcard i would liek to pass through to my main rig but this is the error i keep getting ... Any advise or help wopuld be apreciated.. internal error: process exited while connecting to monitor: 2016-08-31T17:11:31.564704Z qemu-system-x86_64: -device vfio-pci,host=04:00.0,id=hostdev0,bus=pci.0,addr=0x6: vfio: msix_init failed 2016-08-31T17:11:31.564728Z qemu-system-x86_64: -device vfio-pci,host=04:00.0,id=hostdev0,bus=pci.0,addr=0x6: vfio: 0000:04:00.0 Error adding PCI capability 0x11[0x53]@0xac: -22 2016-08-31T17:11:31.564883Z qemu-system-x86_64: -device vfio-pci,host=04:00.0,id=hostdev0,bus=pci.0,addr=0x6: Device initialization failed the card is pplugged int the last PCIE x4 slot available on myu motherbaoard -- System Spec -- M/B: ASUSTeK COMPUTER INC. - RAMPAGE V EXTREME CPU: Intel® Core™ i7-5960X CPU @ 3.00GHz HVM: Enabled IOMMU: Enabled Cache: 512 kB, 2048 kB, 20480 kB Memory: 64 GB (max. installable capacity 512 GB) i have uploaded a diagnoistic if this helps g-a-m-e-b-o-x-diagnostics-20160831-1825.zip
