Permission problem
Remove the appdata and then reinstall....
  • 4 weeks later...
  • Replies 51
  • Views 23.3k
My take on you problem:
1) You updated Nzbget - which now comes with unrar 5.4x+. These versions of unrar also restores files permissions from the archive, if you do not pass the "-ai" option.
2) Without the "-ai" option most archives will still unpack with correct permissons as normally the rw attributes are set correctly. Only a few archives contain (at least for me)  unusual permissions/attributes -> and these lead to your problems
If you do not want to use the -ai option you can also use the umask option, as pointed out by another user.
This explains:
1) That the problem only occured recently and only on some files
2) That resetting permissions from the unraid->tools fixes the issue for exisitng files
While the nzbget settings page points out the "-ai" option, it is not the default. The reasoning might be that it is a useful feature to include attributes in an archive and that the expected behavious is that they are restored intact.
Edited by Videodr0me
