Accessing motherboard features - fan control, over clocking, lighting etc
I'm guessing the answer to my question is no, but I just want to make sure.
My mobo has fan control, lighting, over clocking features etc etc.  Is there anyway of accessing these in a VM? I'm assuming no, but I wondered how do the system plugins work that report cpu temp etc.
Thanks in advance
If you are trying to access them through software than I can tell you, no it won't work. I tried the software package for my z710-a and it couldn't even startup as it tries to communicate with the hardware which it can't due to being virtualized and errors out.
I am able to tune using the mobo features in BIOS and that works great but not through the software bundle. When I had the system running windows, I had it OC'ed but not sure if that helps/benefits for unRAID.
yeah, that's what I was expecting.  Was just wondering if anyone has any clever methods
You'll be able to control fans if you use a USB fan controller and have that plugged into a USB controller you've passed through, but to overclock on the fly you'd have to be able to pass through other components on the motherboard to the VM which isn't possible.
