October 28, 20169 yr I'm not what what happened, but was moving along fine with write around 100 Mbps and now I'm crawling I have a cache and attaching/including other info. Any thoughts? root@Tower:~# ethtool eth0 Settings for eth0: Supported ports: [ TP ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Supported pause frame use: No Supports auto-negotiation: Yes Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Advertised pause frame use: No Advertised auto-negotiation: Yes Speed: 1000Mb/s Duplex: Full Port: Twisted Pair PHYAD: 2 Transceiver: internal Auto-negotiation: on MDI-X: on (auto) Supports Wake-on: pumbg Wake-on: g Current message level: 0x00000007 (7) drv probe link Link detected: yes root@Tower:~# ifconfig eth0 eth0: flags=4419<UP,BROADCAST,RUNNING,PROMISC,MULTICAST> mtu 1500 ether 18:03:73:33:53:c5 txqueuelen 1000 (Ethernet) RX packets 25750839 bytes 6922097620 (6.4 GiB) RX errors 0 dropped 5 overruns 0 frame 0 TX packets 37747556 bytes 44072732949 (41.0 GiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 20 memory 0xf7f00000-f7f20000 root@Tower:~# ifconfig eth0 eth0: flags=4419<UP,BROADCAST,RUNNING,PROMISC,MULTICAST> mtu 1500 ether 18:03:73:33:53:c5 txqueuelen 1000 (Ethernet) RX packets 25751424 bytes 6922191667 (6.4 GiB) RX errors 0 dropped 5 overruns 0 frame 0 TX packets 37748172 bytes 44072789163 (41.0 GiB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 20 memory 0xf7f00000-f7f20000 root@Tower:~# hdparm -i /dev/sdc /dev/sdc: Model=TOSHIBA MD04ACA500, FwRev=FP2A, SerialNo=55B1K1N9FS9A Config={ Fixed } RawCHS=16383/16/63, TrkSize=0, SectSize=0, ECCbytes=0 BuffType=unknown, BuffSize=unknown, MaxMultSect=16, MultSect=16 CurCHS=16383/16/63, CurSects=16514064, LBA=yes, LBAsects=9767541168 IORDY=on/off, tPIO={min:120,w/IORDY:120}, tDMA={min:120,rec:120} PIO modes: pio0 pio1 pio2 pio3 pio4 DMA modes: sdma0 sdma1 sdma2 mdma0 mdma1 mdma2 UDMA modes: udma0 udma1 udma2 udma3 udma4 *udma5 AdvancedPM=yes: unknown setting WriteCache=enabled Drive conforms to: Unspecified: ATA/ATAPI-3,4,5,6,7 * signifies the current active mode root@Tower:~# hdparm -tT /dev/sdc /dev/sdc: Timing cached reads: 22610 MB in 2.00 seconds = 11317.68 MB/sec Timing buffered disk reads: 44 MB in 3.13 seconds = 14.07 MB/sec root@Tower:~# syslog.txt Edited June 26, 20179 yr by jcarmi04
October 29, 20169 yr Community Expert Timing buffered disk reads: 44 MB in 3.13 seconds = 14.07 MB/sec This disk looks way too slow, have you checked SMART? Or post the diagnostics.
October 29, 20169 yr Author That's my parity. Diagnostics attached. tower-diagnostics-20161028-1537.zip
October 29, 20169 yr Community Expert That's my parity. Still slow, unless it was being used at the time. Don't see nothing obvious on the diags, are you copying to cache or to the array? If using cache, try copying directly to the array.
October 29, 20169 yr Author Thanks for the note, johnnie.black. How do I isolate the copies one way or another? I don't want to interfere with my Docker...
October 29, 20169 yr Community Expert You can temporarily disable cache for that share: Shares -> Sharename -> Use cache disk: No or Enable disk shares and copy directly to any disk: Settings -> Global share settings -> Enable disk shares: Yes (array must be stopped to change, after testing change back to auto.)
October 29, 20169 yr Author Eh, don't think I was copying using Cache previously, but copied directly to disk via the second method and still sitting at 1 Mbps. Any other thoughts or tests I should try? I've tested cabling and pretty much everything I can think of. I can do mc copies at 40-100 Mbps, so unRAID disk to disk seems okay, just not over the LAN. I tried a Windows to Windows copy over LAN and got 100 Mbps...
October 29, 20169 yr Community Expert If speed is the same copying to cache or disk it's almost certainly a network issue, try other cable/switch/NIC.
October 29, 20169 yr Author Thanks. I tried cable and switch. I'll give a new NIC a crack when I can and report.
October 29, 20169 yr Another thing to try is the Tips and Tweaks plugin), to play with the NIC offload setting. Symptoms for this problem is it always starts fast after a boot, but at some random point, network speed drops hugely, until reboot. Tips and Tweaks wiki page explains it a bit more I think.
December 12, 20169 yr Author Hey all, been a minute but ended up upgrading my mobo (new NIC) and still having the same issue. Speeds start at 100Mbps copying, then fall off to around 50, before eventually flat lining resulting in a Windows Error 0x8007003B. Any thoughts/help/etc will be GREATLY appreciated!
December 13, 20169 yr Does Googling that Windows error code give you any pointers? It might be a Windows issue rather than an unRAID one.
December 22, 20169 yr Author John_M: I had done A LOT of searches for Windows, unRAID, NAS, smb, etc solutions and just did a re-check again...got NUTHIN. Couple new notes: 1. Tried a Win 10 to Win 10 transfer on my LAN and maintained 100Mbps. 2. Retried a disk to disk transfer on unRAID using mc and am getting significantly bad copy speeds (after the first file, when Windows usually gets that error, the speeds hover beteen 1-10Mbps). 3. Most interesting (possibly): Tried a FTP transfer and it apparently is suffering from the same failure, but was persistent (unlike Windows which must just time out) - see snippet of transfer log info below. I previously thought it was a SAMBA issue, but now am wondering what's up with my unRAID box Status: Logged in Status: Logged in Status: Starting upload of C:\As Good As It Gets.mkv Status: Retrieving directory listing of "/mnt/user/Movies"... Status: Starting upload of C:\Armageddon.mkv Status: Retrieving directory listing of "/mnt/user/Movies"... Command: TYPE I Response: 200 Switching to Binary mode. Command: PASV Response: 227 Entering Passive Mode ("LOCAL IP",134,195). Command: LIST Response: 150 Here comes the directory listing. Response: 226 Directory send OK. Command: PASV Response: 227 Entering Passive Mode ("LOCAL IP",237,46). Command: REST 1081856000 Response: 350 Restart position accepted (1081856000). Command: STOR As Good As It Gets.mkv Error: Connection timed out after 20 seconds of inactivity Error: File transfer failed after transferring 786,432 bytes in 20 seconds Command: TYPE I Response: 200 Switching to Binary mode. Command: PASV Response: 227 Entering Passive Mode ("LOCAL IP",167,247). Command: REST 5599938828 Response: 350 Restart position accepted (5599938828). Command: STOR Armageddon.mkv Error: Connection timed out after 20 seconds of inactivity Error: File transfer failed after transferring 786,432 bytes in 20 seconds Status: Disconnected from server Status: Disconnected from server Status: Connecting to "LOCAL IP:PORT"... Status: Connection established, waiting for welcome message... Status: Connecting to "LOCAL IP:PORT"... Status: Connection established, waiting for welcome message... Status: Insecure server, it does not support FTP over TLS. Status: Insecure server, it does not support FTP over TLS. Status: Logged in Status: Logged in Status: Starting upload of C:\As Good As It Gets.mkv Status: Retrieving directory listing of "/mnt/user/Movies"... Status: Starting upload of C:\Armageddon.mkv Status: Retrieving directory listing of "/mnt/user/Movies"... Status: File transfer successful, transferred 914,521,076 bytes in 27 seconds Command: TYPE I Response: 200 Switching to Binary mode. Command: PASV Response: 227 Entering Passive Mode ("LOCAL IP",173,250). Command: LIST Response: 150 Here comes the directory listing. Response: 226 Directory send OK. Command: PASV Response: 227 Entering Passive Mode ("LOCAL IP",219,103). Command: REST 1081856000 Response: 350 Restart position accepted (1081856000). Command: STOR As Good As It Gets.mkv Response: 150 Ok to send data. Error: Connection timed out after 20 seconds of inactivity Error: File transfer failed after transferring 837,550,080 bytes in 55 seconds Status: Starting upload of C:\As Good As It Gets.mkv Status: Retrieving directory listing of "/mnt/user/Movies"... Command: PASV Response: 227 Entering Passive Mode ("LOCAL IP",225,93). Command: REST 0 Response: 350 Restart position accepted (0). Command: LIST Response: 150 Here comes the directory listing. Response: 226 Directory send OK. Command: PASV Response: 227 Entering Passive Mode ("LOCAL IP",52,174). Command: REST 1916796928 Response: 350 Restart position accepted (1916796928). Command: STOR As Good As It Gets.mkv Error: Connection timed out after 20 seconds of inactivity Error: File transfer failed after transferring 786,432 bytes in 20 seconds Status: Disconnected from server Status: Connecting to "LOCAL IP:PORT"... Status: Connection established, waiting for welcome message... Status: Insecure server, it does not support FTP over TLS. Status: Logged in Status: Starting upload of C:\As Good As It Gets.mkv Status: Retrieving directory listing of "/mnt/user/Movies"... Status: File transfer successful, transferred 2,284,476,619 bytes in 72 seconds Status: Retrieving directory listing of "/mnt/user/Movies"... Status: Directory listing of "/mnt/user/Movies" successful
December 22, 20169 yr Community Expert If transferring between disks on the same server using MC is still exhibiting the same issues then that would seem to eliminate the network. Post another diagnostic that includes the activities.
December 27, 20169 yr Author trurl/All: Log file attached. I've got notes from a few tests I ran today below and it appears more to do with my unRAID server's ability to refresh/buffer/something, as you can see from my initial notes. Happy to do more specific testing if anyone has any ideas. Started testing at 8:33a ET. Copied a 6 GB .mkv file to the server from my Win10 PC and transferred fine (folder 1). After copying finished, waited 1 minute and tried the same file again which failed (folder 2). Waited 5 minutes and repeated the test at increasing 1 minute intervals until I determined the wait between copying the same 6 GB file for success is approximately 3 minutes. This success is only present for copying 1 large file, as failures (timeouts, Windows error) presents into the second file. Folder #s 1-833-copied successfully 2-1 min later-failed 3-wait 5 mins then copied successfully 4-2 min later-failed 5-wait 5 mins then copied successfully 6-3 min later-success successfully 7-3 min later-success successfully 8-3 min later tried to copy 5 .mkv files (25 GB)-1 file copied, per usual, and the rest failed 9-Same share (possibly different disk) to same share-1 file copied successfully 10-3 min later-Same share (possibly different disk) to same share-1 file copied successfully - started at 500 Mbps 11-Different share (probably a different disk) to that original share-1 file (7 GB) copied successfully 12-3 min later-Different share (probably a different disk) to that original share-1 file (7 GB) copied successfully 13-Since I forgot above, 3 min later-Same share (possibly different disk) to same share-5 files-failed 14-MC-Same share (possibly different disk) to same share-1 file copied successfully 15-3 min later-MC-Same share (possibly different disk) to same share-1 file copied successfully MULT-copied 5 files from Win10 PC same share (possibly different disk) to same share-failed tower118-syslog-20161227-1014.zip
December 27, 20169 yr Community Expert I fought with a problem(s) of occasional very slow reads from the array. Never had an issue with slow copies to the array. But after playing, googling, experimenting, cursing with/at the problem, I think I finally have it fixed. The first one was that I had an out-of-date 'Network Adapter' driver installed in my Win7 computer. (This is actually the last thing that I found...) The second one was that I had revisit by the 'Green Bar of Death' in Windows Explorer. (This was a problem back around 2009-2010.) I decided to try a replacement file manager and picked Explorer++. (Mainly because it does not really install itself into Windows. It is a stand-alone program that you simply click on the executable and it runs...) I suspect that MS snuck a security update into Windows Explorer into the past few months which broke it again. While your problem is not identical, you may want to investigate these possibilities.
December 27, 20169 yr Author Thanks, Frank1940. I actually have tried two separate Win10 PCs and it's present in both. Plus, with the failures doing MC copies I have to feel this is some type of unRAID issues, yes? I have tried using Teracopy and FTP transfers, which does not necessarily mimic Explorer++ it does replicate the problem using a slightly different method with the same (crummy) outcome. The only benefit of using FTP vs all other methods was FTP persisted in copying (retries) and the files eventually copied, whereas Win10 and unRAID both "timed out".
December 27, 20169 yr Author Had a breakthrough, though, can't speak to why I was failing. I thought my issue might be related to RAM or possibly a failing Cache Drive. In the main directory that I tried copying the files to, I turned use of Cache Drive to "Yes" (think I turned it off as part of troubleshooting) and it appears to be holding 100 Mbps + transferring over my network. I'm not sure what would've changed ... and still not sure why I was failing with Cache Drive set to "No". However, will mark as resolved for the time being and revisit if issue(s) rear again. Thanks, all!
December 28, 20169 yr I wouldn't abandon trying to isolate what's happening. Using the cache is likely just masking the issue ... your writes are always to the cache, so you don't "see" the real issue when mover runs -- and is likely writing VERY slow to the array. I didn't ready all of the details here, but it sounds like you have a failing parity drive, which is resulting in VERY slow writes to the array. You could try a couple of things ... (a) replace the parity drive and see if that resolves things (b) if you don't mind running "at risk" (i.e. unprotected), you could do a New Config without assigning a parity drive, and see if writes to the disk shares are at full speed.
December 31, 20169 yr Author garycase: Glad you wrote, cause I think you're right (Parity). I looked at little more and can't even tell - for certain - if my files are being copied from my Cache to a permanent copy with a Parity backup. If I complete a New Config what might result other than proving its with my Parity? I'm imagining I'll need to replace the Parity, yes? Or, will running a New Config possibly "fix" whatever is wrong? Ultimately I'd like to reuse or replace the drive, so want to dig into what's wrong as best as I can...
December 31, 20169 yr If you do a New Config and simply do not include a parity drive, then your system should speed up a LOT. It won't impact any of your data -- it simply will mean you're not fault-tolerant (i.e. you're running "at risk"). If that indeed speeds things up as I expect, that will pretty much confirm that the issue is your parity drive. I'd then get a new drive; assign it as parity, and let the system do a parity sync -- and things should then be back to normal. [Just toss the old parity drive in that case] If things don't speed up, then the issue is something else -- and you'll need to do a bit more testing to try & isolate it. But I think it's very likely you'll find that the New Config w/out parity will fix the issue.
January 4, 20179 yr Author Alright, so ran a New Config anddddd....nothing. Did not assign a Parity, tried to copy to the primary share that had been failing (a share composed of 5 disks) and got the same Windows error. I then reassigned my Parity, performed a Parity Check and got no errors from it. At this point I thought perhaps it was a single drive of my 11 disks (13 total in the unRAID server if counting Parity and Cache) - specifically one of that share. Results all over the map: -Movie Share composed of Disks 1, 5, 8, 10, and 11. Tried copying to the Share again and failed. Created an individual share per disk and Disks 1, 5, 8, and 11 failed with the Windows error. Disk 10 copied successfully though. -Copies to Disks 2, 3, and 6 failed as well. -Copies to Disks 4, 7, and 9 were successful. -I then retried a few disks and the only result that changed was disk 6 had a successful copy. Any thoughts??
January 4, 20179 yr Sounds like you have a controller issue => are the drives that work well all connected to the same controller (motherboard or add-on)? ... and are those that are having problems also connected to a different controller? If so, that's a pretty strong clue
January 4, 20179 yr Author Unfortunately, some of the drives that fail to copy are directly connected to the Mobo. I can try to power down and unplug the controller card if there may be value in ruling that in/out.
