October 28, 20169 yr Over 50% of the time I am unable to access the unRAID dashboard, SABnzbd, CouchPotato, Sonarr, etc. from my wireless network. I've tried multiple laptops and still have the same results. While this happens I'm also unable to SSH into the machine, however ping works without issue. I am able to RDP into other machines that are on the LAN and can access the URLs that way without issue. I've tried different ports on the router, different ports on the NIC and different cables as well, all still have the same issue. I also have an Apple TV which connects to Plex via wireless and always comes up having problems finding the server, which results in me having to manually select it. Not sure if it's related but does speak to random network issues. I'm running out of ideas and was hoping that someone else may have this problem or could point me in the right direction?
