help with vive on unraid
hi,
I'm trying to get vive on a vm on my machine and I've used this guide to get it working: https://lime-technology.com/forum/index.php?topic=49580.0
Everything works fine but the controllers. They dont seem to get detected at all. The headset works fine and detects the base stations fine but the controllers are not detected. I've tried unpairing and re-pairing the controllers but they dont get detected.
The machine has 2x gtx 980 and the vm is just using 1 of them. The machine has 64GB of RAM and the vm has 30GB of it.
The vm is using windows 7 professional x64.
Also I've tried using oculus on it and it works fine with the latest unraid (6.2 i think). I was going to try the pre-release one but I was wondering if anyone has any suggestions ?
Thanks
