December 8, 20169 yr So I have checked memory in memtest86 and no error. So i reformated flash and put brand new clean unraid. Installed dockers. Unraid was running over night, when i woke up i found out it again freezed. :-( How long did you let the memtst run? Twenty-four hours is considered to be the minimum. You said you replaced the Hardware. Did you reuse the Power Supply or any other components except the disk drives? ( I seem to recall that the PS has been the culprit in a couple of cases with similar symptoms.) In my signature you can see my completely new HW. its all brand new including brand new PSU: Fractal Design Integra M 550W, so i doubt its PSU issue. I was running memtest86 only for 2h. So i might run it for 24h. My friend also recommend to install windows on SSD, and let run some benchmarks.
December 10, 20169 yr So I have checked memory in memtest86 and no error. So i reformated flash and put brand new clean unraid. Installed dockers. Unraid was running over night, when i woke up i found out it again freezed. :-( How long did you let the memtst run? Twenty-four hours is considered to be the minimum. You said you replaced the Hardware. Did you reuse the Power Supply or any other components except the disk drives? ( I seem to recall that the PS has been the culprit in a couple of cases with similar symptoms.) Hi, RAM's are fine. PSU is brand new. I opened separate thread for my issue here https://lime-technology.com/forum/index.php?topic=54561.msg521260#msg521260
