December 18, 20169 yr Hi community I'm facing problems with flash content on my Win10 (Build 1607) VM. It stops playing flash content (youtube etc) from time to time and also stops playing sound from Spotify. I passed throught my GPU "ASUS GeForce GTX 1060 STRIX 6G-GAMING (6GB)" and my Razer Kraken 7.1 Chroma headset. The monitor is attached via HDMI with sound output - maybe that's the problem? When it doesn't work via headset I switch to the monitor sound output and it works. If I switch back to my headset it probably works again. Anyone else have this problem? I searched the web and the forum but didn't find similar problems. Thanks in advance for feedback!
January 5, 20179 yr post logs and xml. are you running the vm from the array or cache disk/ssd? there are many variables. could be hardware conflict, could be corrupt windows install... more info is needed.
January 5, 20179 yr Author Hello Thanks for your reply! The Windows system disk is running on SSD Cache. Please find the logs and xml attached. Regards srvunraid1-syslog-20170105-2045.zip pc1_log.txt pc1_xml.txt
