**VIDEO GUIDE How to Passthrough Harddrives, Convert Disks and test Vdisk speed
Awesome video as always!
solid work.
Hi gridrunner, would the sata connection be properly detected if i were to passthrough a disk to an OSX VM? Currently it sees the vdisk as a sata 1 connection?
Yes if you pass through the the disk to an osx vm you will need the have the bus set to sata in the xml
  • 3 years later...
i follow the video to convert my nvme windows10 boot ssd to vdisk with this command
qemu-img convert -p -O raw /dev/nvme0n1 "/mnt/user/domains/Windows 10 ssd/cVdisk.img"
when i mount the vdisk to VM,
      <source file='/mnt/user/domains/Windows 10 ssd/cVdisk.img'/>
      <target dev='hdd' bus='sata'/>
      <boot order='1'/>
      <address type='drive' controller='0' bus='0' target='0' unit='3'/>
    </disk>
and boot it,
it shows the windows loading screen but it just looped and enter the windows recovery, failed to boot.
is there any extra step or different step for converting nvme ssd to vdisk?
Thanks btw.
Edited by audias
