SOLVED: vm connectivity problem (ethernet adapter not accessing internet)
First time I have this problem.
I created my vm (windows 10) a couple of weeks ago and everything was working fine. Yesterday I started it but it did not have internet connection. I tried to open the shares within windows and they were not there. I have not changed anything:
-same vm settings in unraid (using br0)
-same settings in vm for ethernet
On the other hand I can connect to the vm using vnc.
I can ping my array from my laptop. My array has access to internet.
Have no clue where to start. Pls tell me where to start looking.
EDIT: So I had a look at the router config, and I deleted by mistake an IP at the static DCHP.
