May 1, 20179 yr This is the second month in a row that the scheduled parity check failed and Disk 5 was marked with a Red-X and removed from the array. I have been monitoring the system log all month and there have been no errors and the array was performing fine. When this happens, the drive itself exhibits no hardware issue. I have used 2 different drives in this slot, and if the drives are wiped and rewritten, they work fine. So it does not appear to be a drive error. Parity Check starts at 1:00am. The log shows the first error happening at 04:21:45 (ata 9 is a Crucial 256GB SSD in the cache slot) May 1 04:21:45 Tower kernel: ata9.00: exception Emask 0x0 SAct 0x2000 SErr 0x0 action 0x6 frozen I am attaching the system log and the diagnostics output (I have not rebooted or done anything except read the logs) If anyone can shed some light on this, I would be grateful. Thanks. tower-syslog-20170501-1028.zip tower-diagnostics-20170501-1007.zip
May 1, 20179 yr Community Expert Problem is the Marvell controller, try disabling vt-d if not needed, check for a board bios update and/or use the controller in a different slot if available, if all fails get a non Marvell controller.
May 1, 20179 yr Community Expert Get one with a LSI chipset, e.g., 9211 or 9210-8i, most by the cheaper clones, like the Dell h310 or IBM m1015 but these need to be crossflashed to work with unRAID.
May 1, 20179 yr Author Thanks. I ordered an LSI 9211-8i flashed to IT mode. One last question. Should I wait until the new card is installed to replace the drive? In the past, I have been able to rebuild the failed drive and it seems to work fine until the next parity check. As mentioned, I have been monitoring the system log since last month, and no indication of any errors.
May 1, 20179 yr Community Expert Rebuild and wait for the new controller before running another check.
May 9, 20179 yr Author Solved. I received the LSI 9211-8i, flashed it to IT mode, installed and ran parity check to completion with no errors. Thanks johnnie.black for the help.
