May 31, 20179 yr I am having problem with my fans on Supermicro X9SCM-F. Fans seem to be revving up and down. Upon reading a few posts, people say lower the lowest threshold to lower than the fan's specs. All say use freeipmi. Can anyone share with me how to install freeipmi? Thanks Reading forums
June 1, 20179 yr Author hi wgstarks, I have that installed already, and reading the link, it says "IPMI fan control is supported for Asrock boards only." In my case, indeed, you cannot enable fan control. It's grayed out.
June 1, 20179 yr That's correct. You can still use it to edit your fan settings though. Just no automated fan control yet.
June 1, 20179 yr Author Thanks. Does it mean if I set the lower threshold, it will still be automatically revved up when needed? Just won't go up nd down like crazy? Sent from my LG-D855 using Tapatalk
June 1, 20179 yr I would suggest posting these questions in the ipmi support thread. Lots of people there with a lot more experience with this.
