June 6, 20179 yr I am not sure what is happening. I am not too savvy when it comes to linux. I just have a handful of dockers running. Crashplan, Jackett, Netdata, NZBGet, plex, plexpy, radarr, sonarr and transmission. My downloads are set to run from 10pm - 6am. But today at about 4:20pm central, my wife told me that Plex as not being responsive. This happens very frequently. I log in and do an iotop and this is what I see http://imgur.com/a/1mvnr LOTS and LOTS of ioactivity. I have upgraded my cache drive TWICE and this keeps happening. Any insight from my screenshot on what is causing it?
June 6, 20179 yr It should be know limitation, 6.4rc2 may have some different. Edited June 6, 20179 yr by Benson
June 6, 20179 yr Author 5 hours ago, Benson said: It should be know limitation, 6.4rc2 may have some different. I'm not sure I understand? Should I upgrade my unRAID version? I am running 6.3.5 currently. Edited June 6, 20179 yr by Stuke00
June 6, 20179 yr Community Expert What Benson posted has nothing to do with your issue. When this happens again stop your dockers one at a time to see if you can find the culprit(s). Edited June 6, 20179 yr by johnnie.black
June 6, 20179 yr Author 3 minutes ago, johnnie.black said: What Benson posted has nothing to do with your issue. When this happens again stop your dockers one at a time to see if you can find the culprit(s). It seems when I stop Plex, it ends. I had to walk my wife through restarting Plex twice in my 30 min drive to work today. I am not sure what Plex is doing to cause this. I am not really seeing anything in the logs (or I don't know what I am looking for). I have my downloads set to only occur at night, and Plex only updates the library during maintenance which is from 12am to 6am.
June 6, 20179 yr Community Expert Don't use Plex so can't help you but post in the appropriate docker support thread.
