Call Traces Error, Fix common problems
Had this message come up:
Your server has issued one or more call traces. This could be caused by a Kernel Issue, Bad Memory, etc. You should post your diagnostics and ask for assistance on the unRaid forums
diags attached, nothing seems to be wrong with the system.
server-diagnostics-20170611-0758.zip
Various processes are having brain farts with trying to allocate memory for themselves.  Basically harmless and can be ignored, but the odd process is stalling for ~20seconds here and there while it figures things out.  You can install the tips & tweaks plugin and try this.
I made those changes, acknowledged the error, did a re scan and the error is gone.
The acknowledge stops the nagging until the next boot. With the tweaks applied reboot and then see what happens
Sent from my LG-D852 using Tapatalk
Rebooted all good so far
