Flash drive problems after WoL
I've been trying to get WoL to work reliably under unRAID for nearly two years now.  I recently tried sending my unRAID box to sleep via the Dynamix S3 Sleep plugin, waking it using 'rtcwake' (see https://forums.lime-technology.com/topic/58194-scheduled-wake-from-sleep/), which appeared to work, but after waking there was no 'Docker' tab or apps and the system was in a rather confused state.  Clicking on the 'Log' button, I got the following immediately after the wake-from-sleep:
Jun 20 11:49:32 Tower kernel: xhci_hcd 0000:03:00.0: HC died; cleaning up
Jun 20 11:49:32 Tower kernel: dpm_run_callback(): usb_dev_resume+0x0/0x10 returns -22
Jun 20 11:49:32 Tower kernel: PM: Device 6-2 failed to resume async: error -22
Jun 20 11:49:32 Tower kernel: PM: resume of devices complete after 11021.862 msecs
Jun 20 11:49:32 Tower kernel: Restarting tasks ...
Jun 20 11:49:32 Tower kernel: usb 6-2: USB disconnect, device number 2
Jun 20 11:49:32 Tower kernel: done.
Jun 20 11:49:32 Tower kernel: udevd[18947]: inotify_add_watch(5, /dev/sda, 10) failed: No such file or directory
Jun 20 11:49:32 Tower s3_sleep: Wake-up from sleep mode
Jun 20 11:49:32 Tower kernel: FAT-fs (sda1): Directory bread(block 8192) failed
Jun 20 11:49:32 Tower kernel: FAT-fs (sda1): Directory bread(block 8193) failed
Jun 20 11:49:32 Tower kernel: FAT-fs (sda1): Directory bread(block 8194) failed
Jun 20 11:49:32 Tower kernel: FAT-fs (sda1): Directory bread(block 8195) failed
Jun 20 11:49:32 Tower kernel: FAT-fs (sda1): Directory bread(block 8196) failed
Jun 20 11:49:32 Tower kernel: FAT-fs (sda1): Directory bread(block 8197) failed
Jun 20 11:49:32 Tower kernel: FAT-fs (sda1): Directory bread(block 8198) failed
Jun 20 11:49:32 Tower kernel: FAT-fs (sda1): Directory bread(block 8199) failed
Jun 20 11:49:32 Tower kernel: FAT-fs (sda1): Directory bread(block 8200) failed
Jun 20 11:49:32 Tower kernel: FAT-fs (sda1): Directory bread(block 8201) failed
Jun 20 11:49:32 Tower root:
Jun 20 11:49:32 Tower root: Warning: file_put_contents(/boot/config/docker.cfg): failed to open stream: No such file or directory in /usr/local/emhttp/plugins/dynamix.docker.manager/scripts/dockerconfig.php on line 35
Jun 20 11:49:32 Tower root: Warning: file_put_contents(/boot/config/domain.cfg): failed to open stream: No such file or directory in /usr/local/emhttp/plugins/dynamix.vm.manager/scripts/libvirtconfig.php on line 39
Jun 20 11:51:50 Tower kernel: fat__get_entry: 182 callbacks suppressed
Jun 20 11:51:50 Tower kernel: FAT-fs (sda1): Directory bread(block 8192) failed
Jun 20 11:51:50 Tower kernel: FAT-fs (sda1): Directory bread(block 8193) failed
Jun 20 11:51:50 Tower kernel: FAT-fs (sda1): Directory bread(block 8194) failed
Jun 20 11:51:50 Tower kernel: FAT-fs (sda1): Directory bread(block 8195) failed
Jun 20 11:51:50 Tower kernel: FAT-fs (sda1): Directory bread(block 8196) failed
Jun 20 11:51:50 Tower kernel: FAT-fs (sda1): Directory bread(block 8197) failed
Jun 20 11:51:50 Tower kernel: FAT-fs (sda1): Directory bread(block 8198) failed
Jun 20 11:51:50 Tower kernel: FAT-fs (sda1): Directory bread(block 8199) failed
Jun 20 11:51:50 Tower kernel: FAT-fs (sda1): Directory bread(block 8200) failed
Jun 20 11:51:50 Tower root:
Jun 20 11:51:50 Tower root: Warning: file_put_contents(/boot/config/docker.cfg): failed to open stream: No such file or directory in /usr/local/emhttp/plugins/dynamix.docker.manager/scripts/dockerconfig.php on line 35
Jun 20 11:51:50 Tower kernel: FAT-fs (sda1): Directory bread(block 8201) failed
Jun 20 11:51:50 Tower root: Warning: file_put_contents(/boot/config/domain.cfg): failed to open stream: No such file or directory in /usr/local/emhttp/plugins/dynamix.vm.manager/scripts/libvirtconfig.php on line 39
This is characteristic of the sleep issues that have plagued my unRAID experience.  Has anyone else had this problem and found a solution?
